  3. Einsteigerfragen
  4. System updaten raspberry + iobroker + node
    5.3k
30 Beiträge 6 Kommentatoren 15.0k Aufrufe 5 Beobachtet
  • T TheAriba
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.4.72-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     10:45:37 up 419 days, 17:11,  1 user,  load average: 0.40, 0.70, 0.50
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-18 10:45:37 GMT
               Universal time: Mon 2023-12-18 10:45:37 UTC
                     RTC time: n/a
                    Time zone: Europe/London (GMT, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           7.9G        850M        5.8G        400M        1.2G        6.6G
    Swap:           99M          0B         99M
    Total:         8.0G        850M        5.9G
             7875 M total memory
              850 M used memory
             1117 M active memory
              829 M inactive memory
             5779 M free memory
              144 M buffer memory
             1101 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  3.9G   53G   7% /
    devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  401M  3.5G  11% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   55M  198M  22% /boot
    tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
    [Mon Oct 24 18:34:35 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:D5:EF:A1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=39b6b4e5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): recovery complete
    [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 24 18:34:36 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Oct 24 18:34:38 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    416M	/var/
    217M	/var/cache
    212M	/var/cache/apt
    153M	/var/cache/apt/archives
    96M	/var/lib
    Archived and active journals take up 400.0M in the file system.
    /opt/iobroker/backups:
    20M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    215M	/opt/iobroker/iobroker-data/
    106M	/opt/iobroker/iobroker-data/files
    79M	/opt/iobroker/iobroker-data/backup-objects
    48M	/opt/iobroker/iobroker-data/files/javascript.admin
    32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    8.3M	/opt/iobroker/iobroker-data/objects.jsonl
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
    6.1M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.e9a02d96.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DC_FT41KIFB-if00-port0
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v12.22.2
    /usr/bin/node 		v12.22.2
    /usr/bin/npm 		6.14.13
    /usr/bin/npx 		6.14.13
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.2-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
     *** 12.22.2-1nodesource1 100
         10.24.0~dfsg-1~deb10u1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.2.22
    javascript: 	6.0.3
    Adapters from github: 	3
    Adapter State
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
    + system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.122
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.2.22 [Updatable]
    Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.2.2  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.0.5  [Updatable]
    Adapter    "doorbird"     : 1.3.0    , installed 0.1.5  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.11.9 [Updatable]
    Adapter    "javascript"   : 7.1.6    , installed 6.0.3  [Updatable]
    Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
    Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
    Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "sonos"        : 3.0.0    , installed 2.2.3  [Updatable]
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
    Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
    Objects and States
    Objects: 	5746
    States: 	4775
    E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
    E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
    Pending Updates: 132
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38307         0.0.0.0:*               LISTEN      1001       131216559  14146/io.yahka.0
    tcp        0      0 127.0.0.1:41925         0.0.0.0:*               LISTEN      1001       131216564  14146/io.yahka.0
    tcp        0      0 127.0.0.1:33989         0.0.0.0:*               LISTEN      1001       131216547  14146/io.yahka.0
    tcp        0      0 127.0.0.1:41703         0.0.0.0:*               LISTEN      1001       131217334  14807/io.yahka.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       131213641  13946/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       131213634  13946/iobroker.js-c
    tcp        0      0 127.0.0.1:45291         0.0.0.0:*               LISTEN      1001       131219694  14146/io.yahka.0
    tcp        0      0 127.0.0.1:43851         0.0.0.0:*               LISTEN      1001       131217891  14807/io.yahka.1
    tcp        0      0 127.0.0.1:43631         0.0.0.0:*               LISTEN      1001       131216552  14146/io.yahka.0
    tcp        0      0 127.0.0.1:34769         0.0.0.0:*               LISTEN      1001       131218669  14840/io.yahka.2
    tcp        0      0 127.0.0.1:38131         0.0.0.0:*               LISTEN      1001       131220567  14840/io.yahka.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16813      572/sshd
    tcp        0      0 127.0.0.1:33561         0.0.0.0:*               LISTEN      1001       131218665  14840/io.yahka.2
    tcp        0      0 127.0.0.1:42905         0.0.0.0:*               LISTEN      1001       131216015  14807/io.yahka.1
    tcp        0      0 127.0.0.1:37211         0.0.0.0:*               LISTEN      1001       131219699  14146/io.yahka.0
    tcp6       0      0 :::38783                :::*                    LISTEN      1001       131216908  14807/io.yahka.1
    tcp6       0      0 :::42977                :::*                    LISTEN      1001       131214296  14146/io.yahka.0
    tcp6       0      0 :::34243                :::*                    LISTEN      1001       131217947  14840/io.yahka.2
    tcp6       0      0 :::36049                :::*                    LISTEN      1001       131214295  14146/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131213697  13964/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       131215920  14730/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16815      572/sshd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       131217864  14781/io.terminal.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       131218481  14650/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14315      564/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131217948  14840/io.yahka.2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131216909  14807/io.yahka.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214300  14146/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214297  14146/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15108      382/avahi-daemon: r
    udp        0      0 0.0.0.0:43289           0.0.0.0:*                           108        15110      382/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          31124735   564/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15109      382/avahi-daemon: r
    udp6       0      0 :::42292                :::*                                108        15111      382/avahi-daemon: r
    2023-12-18 10:40:51.439  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
    2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Unknown Device, but enabling commands, Try it and report back if commands work.
    2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2023-12-18 10:41:17.822  - info: alexa2.0 (14089)     Device-type:A2RG3FY1YV97SS - Sascha's Sonos Move (Sonos Move) (HANDS_FREE,SET_LOCALE,DEEZER,DIALOG_INTERFACE_VERSION,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SOUND_SETTINGS,SUPPORTS_LOCALE,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SPEECH_RECOGNIZER_USS,APPLE_MUSIC,FAR_FIELD,AUDIO_PLAYER,EARCONS,SUPPORTS_LOCALE_SWITCH,SET_TIME_ZONE,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS)
    2023-12-18 10:41:21.475  - info: host.raspberrypi instance system.adapter.doorbird.0 started with pid 15127
    2023-12-18 10:41:24.179  - info: doorbird.0 (15127) starting. Version 0.1.5 (non-npm: https://github.com/BuZZy1337/ioBroker.doorbird/tarball/47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb) in /opt/iobroker/node_modules/iobroker.doorbird, node: v12.22.2, js-controller: 4.0.23
    2023-12-18 10:41:24.275  - error: doorbird.0 (15127) uncaught exception: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
    2023-12-18 10:41:24.277  - error: doorbird.0 (15127) Error: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
        at Server.setupListenHandle [as _listen2] (net.js:1299:21)
        at listenInCluster (net.js:1364:12)
        at doListen (net.js:1501:7)
        at processTicksAndRejections (internal/process/task_queues.js:85:21)
    2023-12-18 10:41:24.278  - error: doorbird.0 (15127) Exception-Code: EADDRNOTAVAIL: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
    2023-12-18 10:41:24.299  - info: doorbird.0 (15127) terminating
    2023-12-18 10:41:24.300  - warn: doorbird.0 (15127) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-12-18 10:41:24.899  - error: host.raspberrypi instance system.adapter.doorbird.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-12-18 10:41:24.900  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
    2023-12-18 10:41:24.900  - warn: host.raspberrypi Do not restart adapter system.adapter.doorbird.0 because restart loop detected
    2023-12-18 10:41:32.861  - info: alexa2.0 (14089) No smart home devices to query
    2023-12-18 10:41:36.052  - info: alexa2.0 (14089) Subscribing to states...
    2023-12-18 10:41:36.056  - info: alexa2.0 (14089) Deleting the following states: ["Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint-scale","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint-scale"]
    2023-12-18 10:41:37.858  - info: alexa2.0 (14089) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-18 10:41:52.977  - info: alexa2.0 (14089) Initialization Done ...
    2023-12-18 10:45:27.558  - info: enocean.0 (14745) state 0584df18.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1702896327553,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896327553}
    2023-12-18 10:45:28.908  - info: enocean.0 (14745) state 0584df18.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1702896328901,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896328901}
    @theariba
    Zeitzone falsch.
    sudo timedatectl set-timezone "Europe/Berlin"
    Dein Dateisystem hat einen Treffer:
    Die Pending Updates: 132 zuerst einspielen:
    sudo apt update
    iob stop
    sudo apt full-upgrade
    iob nodejs-update
    sudo reboot
    Wenn der Server wieder auf die Beine gekommen ist:
    iob update
    iob upgrade all -y
    iob stop
    iob upgrade self
    iob start
    Dann davon ein Backup extern ablegen und das ganze System NEU als Raspberry OS 64Bit Lite installieren. Dort das Backup wieder einspielen, fertig.
      @theariba
      Zeitzone falsch.
      sudo apt update
      iob stop
      iob nodejs-update
      sudo reboot
      iob update
      iob upgrade all -y
      iob stop
      iob upgrade self
      iob start
      TheAriba
      für mich als Noob:
      1. Zeitzone korrigieren
      1. diese Befehle ausführen:
      sudo apt update
      iob stop
      iob nodejs-update
      sudo reboot
      iob update
      iob upgrade all -y
      iob stop
      iob upgrade self
      iob start
      Wie ich dann ein Backup extern ablegen kann muss ich dann noch recherchieren.
      Dann mache ich quasi den pi platt und setze es mit raspberry 64 OS bit Lite neu auf und spiele dann das backup ein?
      • T TheAriba
        für mich als Noob:
        sudo apt update
        iob stop
        iob nodejs-update
        sudo reboot
        iob update
        iob upgrade all -y
        iob stop
        iob upgrade self
        iob start
        @theariba sagte in System updaten raspberry + iobroker + node:
        Ja, das ist der Plan.
          TheAriba
          Ok. Werde nachher mal die Befehle so durchführen.
          Kannst du mir evtl. Sagen wie ich das mit dem Backup auf usb Stick oder so hinbekomme?
          Und wie macht man den Pi platt und setzt ihn neu auf?
          • T TheAriba
            Ich würde es per Backitup-Adapter machen.
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
              TheAriba
              @thomas-braun so, habe die erste Runde der Befehle mal ausgeführt. Nun Backitup Adapter installiert und versuche ein Backup auf Google Drive zu erstellen. Finde leider keinen USB Stick gerade...
              wie kann ich sehen ob es erfolgreich war bzw. ob alles dabei ist? Am wichtigsiten ist mir mein Enocean Adapter...
              • T TheAriba
                @theariba
                Im Backup sind die Adapter und deren Einstellungen enthalten.
                  @theariba
                  TheAriba
                  @thomas-braun ok danke. Habe irgendwie Bedenken dass ich mir das zerschiesse. Warum genau empfiehlt es sich denn das Raspberry OS zu aktualisieren?
                  • T TheAriba
                    Weil deine Version 10 'Buster' abgekündigt wurde, das EndOfLife erreicht hat und weil du da seinerzeit eine 32Bit-Version installiert hast, mittlerweile aber die 64Bit-Variante die besser für einen Raspberry Pi geeignete ist.
                    Und ganz allgemein, weil man seinen Softwarestack immer auf Stand hält.
                      TheAriba
                      @thomas-braun ok alles klar. Dann mache ich mich da heute Abend mal dran. Kurz zum Verständnis der Vorgehensweise:
                      • Über den Backitup auf einen beliebigen USB Stick das Backup ablegen.
                        Dafür gebe ich im Backitup Adapter unter NAS/Kopieren den Pfad /media/usbstick/backupDir an. Muss ich hier sonst noch etwas beachten?
                      • Dann formatiere ich die SD Karte, und setze dann das neue OS so auf wie in deiner Beschreibung
                      • Wie spielt man dann das Backup wieder auf?
                        Die Geräte muss ich sicher nicht mehr neu einlernen?
                      Sorry aber ich habe ein wenig Schiss :)
                      • OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @theariba
                        ich würde lieber eine neue SD-Karte nehmen. dann hast du a) die alte zur Sicherheit noch zur Hand und b) das Risiko, das die SD-Karte bereits einen Hau hat (wegen den verwaisten inodes) ist weg.
                        Meine Adapter und Widgets
                        Links im Profil
                        • OliverIOO OliverIO
                          @theariba
                          TheAriba
                          @oliverio ok verstehe. Bedeutet das sobald ich die alte Karte einstecke habe ich den aktuellen Stand wieder und das funktioniert alles wie gehabt? Habe ich das mit dem Backup soweit richtig verstanden? Wie füge ich das dann wieder auf im neuen System ein? Muss ich dazu einen neuen iobroker aufsetzen oder geht das über Befehle? bspw. hole dir die Datei vom USB Stick?
                          • T TheAriba
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            ja, das ist wie die Festplatte wechseln. Wenn die alte wieder einbaust, dann gehts genau mit dem letzten stand weiter. der raspi ist nur hardware und hat kein weiteres "Gedächtnis".
                            Dann kannst du zur Not immer mal noch nachschauen
                            Links im Profil
                            • W Offline
                              W Offline
                              wrod
                              Hallo, ich habe gerade mein Raspi OS neu aufgesetzt auf TRIXIE.
                              Vorher habe ich alle diese Backups gemacht.
                              Der iobroker backup konnte ich auch wieder einspielen. Beim Wiedereinspielen des influxdb-Backup bricht er aber immer ab mit "ECONNREFUSED"
                              Das LOG sagt zwischendurch auch File /opt/iobroker/backups/influxDB_2026_05_24-14_00_39_backupiobroker.tar.gz not found
                              Das ist aber nicht wirklich der Pfad, an dem sie liegt. In der Backitup-Instanz ist vielmehr unter FTP eingetragen: "/iobrokerbackups/backupDir". Dieser wird auch aufgerufen, dort wird sie gefunden, aber bei Aufruf: ECONNREFUSED.
                              Auch ein Hochladen der Datei auf lokal führt nicht dazu, dass sie angezeigt wird, wenn man als restore-Quelle "lokal" angibt.
                              Kann jemand helfen?
                              Ach ja: Die Option, die alter DB zu löschen vor wem Wiederherstellen, ist gesetzt!
                              • W wrod
                                Kann jemand helfen?
                                @wrod
                                Ich würde das auch nicht per ollem ftp machen sondern per NFS / CIFS, je nachdem was da auf dem NAS verfügbar ist.
                                Ist aber auch am Thema des Threads vorbei.
                                • W Offline
                                  W Offline
                                  wrod
                                  Danke, das habe ich schon früher versucht. FTP lief am stabilsten.
                                  Es geht ja nun um ein Restore - da möchte ich die gleiche Technik nehmen, mit der die Daten angelegt wurden.
                                  Aber was ist ECONNREFUSED?
                                  • W wrod
                                    @wrod sagte:
                                    Der FTP-Server lässt deinen user nicht rein.
                                    Hast du da einen user 'iobroker' mit dessen UID angelegt?
                                    • W Offline
                                      W Offline
                                      wrod
                                      OK, mal probiert. Wenn ich NAS (CFIS) wähle, ruft Backitup beim Restore das Verzeichnis auf, und
                                      1. zeigt bei iobroker und Javascript nur die jeweils letzten Backups (obwohl da mehrere sind)
                                      2. zeigt NICHT das InfluxDB-Backup, obwohl es im selben Verzeichnis liegt (und bei FTP angezeigt wird). Es sind beides tar.gz"
                                      • W wrod
                                        @wrod
                                        Bei CIFS muss der mount-Punkt aber auch leer sein.
                                        • W Offline
                                          W Offline
                                          wrod
                                          OK, einen Schritt weiter.
                                          Nochmalige Installation von influxDB auf der Konsole bewirkt, dass das restore gestartet wird - von FTP. Es bleibt aber gleich bei der ersten Zeile stehen "INFO gui starting Restore ...."
