  3. Einsteigerfragen
  4. System updaten raspberry + iobroker + node
    5.3k
30 Beiträge 6 Kommentatoren 15.0k Aufrufe 5 Beobachtet
  • T TheAriba
    wenn ich den backitup adapter installieren möchte, kommt leider folgenden Meldung:
    $ iobroker add backitup --host raspberrypi
    NPM version: 6.14.13
    Installing iobroker.backitup@2.8.7... (System call)
    host.raspberrypi Cannot install iobroker.backitup@2.8.7: 1
    ERROR: Process exited with code 25
    iob diag gibt :
    iobroker [command]
    Commands:
    iobroker setup Setup ioBroker
    iobroker start [all|<adapter>.<instance>] Starts the js-controller or a specified adapter instance
    iobroker stop [<adapter>.<instance>] stops the js-controller or a specified adapter instance
    iobroker restart [<adapter>.<instance>] Restarts js-controller or a specified adapter instance [aliases: r]
    iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
    iobroker info Shows the host info
    iobroker logs [<adapter>] Monitor log
    iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
    iobroker install <adapter> Installs a specified adapter [aliases: i]
    iobroker rebuild [<module>] Rebuild all native modules or path
    iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
    iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
    iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
    iobroker update [<repositoryUrl>] Update repository and list adapters
    iobroker upgrade Upgrade management
    iobroker upload [all|<adapter>] Upload management [aliases: u]
    iobroker object Object management [aliases: o]
    iobroker state State management [aliases: s]
    iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
    iobroker list <type> [<filter>] List all entries, like objects
    iobroker chmod <mode> <file> Change file rights
    iobroker chown <user> <group> <file> Change file ownership
    iobroker touch <file> Touch file
    iobroker rm <file> Remove file
    iobroker file File management
    iobroker user User commands
    iobroker group group management
    iobroker host <hostname> Set host to given hostname
    iobroker set <adapter>.<instance> Change settings of adapter config
    iobroker license <license.file or license.text> Update license by given file
    iobroker cert Certificate management
    iobroker clean <yes> Clears all objects and states
    iobroker backup Create backup
    iobroker restore <backup name or path> Restore a specified backup
    iobroker validate <backup name or path> Validate a specified backup
    iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
    iobroker repo [<name>] Show repo information
    iobroker uuid Show uuid of the installation [aliases: id]
    iobroker unsetup Reset license, installation secret and language
    iobroker fix Execute the installation fixer script, this updates your ioBroker installation
    iobroker multihost Multihost management
    iobroker compact compact group management
    iobroker plugin Plugin management
    iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
    Options:
    --help Show help [boolean]
    @theariba
    Bitte Texte aus der Konsole in CodeTags eingebettet posten.
    iob stop
    iob fix
    ausführen. Danach wird
    iob diag
    vorhanden sein.
    • T TheAriba
      kann mir jemand evtl. helfen wie ich das raspberry pi OS Update? Hintergrund ist, ich habe Jahre nichts gemacht.
      cat /etc/os-release
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      PlatformBetriebssystem:linux
      Architektur:arm
      CPUs:4
      Geschwindigkeit:1500 MHz
      Modell:ARMv7 Processor rev 3 (v7l)
      RAM:7.6 GB
      System-Betriebszeit:419 T. 16:32:47
      Node.js:v12.22.2
      time:1702894043012
      timeOffset:--
      Adapter-Anzahl:517
      NPM:6.14.13
      Datenträgergröße:58.3 GB
      Freier Festplattenspeicher:54.3 GB
      Betriebszeit:419 T. 16:32:54
      Aktive Instanzen:16
      Pfad:/opt/iobroker/
      aktiv:true
      _nodeCurrent:12.22.2
      _nodeNewest:12.22.12
      _nodeNewestNext:16.20.2
      _npmCurrent:6.14.13
      _npmNewest:6.14.13
      _npmNewestNext:8.19.4
      Würde gerne auch den ioboker updaten:
      • was genau muss ich tun?
      • Kann ich vorher meine komplette io broker Konfiguration sichern? Wie kann ich das tun das nach dem Update wieder alles läuft?
      • Habe hauptsächlich enocean Geräte angelernt was ein brutaler Aufwand war und hab bisschen Sorge dass ich mir das zerschiesse.
      Dann habe ich noch eine Frage bzgl. Zigbee Steckdose (Ikea) angelernt in den IoBroker, nun aber irgendwie nicht mehr mit dem Zigbee adapter gekoppelt - wieso hat sich das disconnected? Wie bekomme ich das erneut gekoppelt? Ich bin etwas verwirrt da die zweite Steckdose problemlos funktioniert. Wie kann ich die Geräte über Alexa steuern? Habe es der Instanz schon hinzugefügt, finde es aber nicht in der Alexa App. Gefühlt ging das früher anders?
      Ich danke euch vielmals vorab!
      @theariba
      mach erstmal n backup der kompletten SD Karte, bevor du weiter machst... oder wenigstens ein backup von iobroker und kopiert dir das file aufn Stick oder aufs Nas..
        @theariba
        TheAriba
        @ilovegym gute Sache. Wie kann ich mir das denn auf einen stick sichern?
          @theariba
          iob stop
          iob fix
          iob diag
          vorhanden sein.
          TheAriba
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.4.72-v7l+
                Architecture: arm
          Model		: Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           10:45:37 up 419 days, 17:11,  1 user,  load average: 0.40, 0.70, 0.50
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2023-12-18 10:45:37 GMT
                     Universal time: Mon 2023-12-18 10:45:37 UTC
                           RTC time: n/a
                          Time zone: Europe/London (GMT, +0000)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:           7.9G        850M        5.8G        400M        1.2G        6.6G
          Swap:           99M          0B         99M
          Total:         8.0G        850M        5.9G
                   7875 M total memory
                    850 M used memory
                   1117 M active memory
                    829 M inactive memory
                   5779 M free memory
                    144 M buffer memory
                   1101 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       59G  3.9G   53G   7% /
          devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     3.9G  401M  3.5G  11% /run
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   55M  198M  22% /boot
          tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
          [Mon Oct 24 18:34:35 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:D5:EF:A1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=39b6b4e5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): recovery complete
          [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct 24 18:34:36 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Mon Oct 24 18:34:38 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          416M	/var/
          217M	/var/cache
          212M	/var/cache/apt
          153M	/var/cache/apt/archives
          96M	/var/lib
          Archived and active journals take up 400.0M in the file system.
          /opt/iobroker/backups:
          20M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          215M	/opt/iobroker/iobroker-data/
          106M	/opt/iobroker/iobroker-data/files
          79M	/opt/iobroker/iobroker-data/backup-objects
          48M	/opt/iobroker/iobroker-data/files/javascript.admin
          32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
          8.3M	/opt/iobroker/iobroker-data/objects.jsonl
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          6.2M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
          6.1M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.e9a02d96.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DC_FT41KIFB-if00-port0
          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v12.22.2
          /usr/bin/node 		v12.22.2
          /usr/bin/npm 		6.14.13
          /usr/bin/npx 		6.14.13
          /home/iobroker/.diag.sh: line 281: corepack: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 12.22.2-1nodesource1
            Candidate: 12.22.12-deb-1nodesource1
            Version table:
               12.22.12-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           *** 12.22.2-1nodesource1 100
               10.24.0~dfsg-1~deb10u1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.23
          admin: 		6.2.22
          javascript: 	6.0.3
          Adapters from github: 	3
          Adapter State
            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
            system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
          + system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.122
            system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
          + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
          + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
          + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.2.22 [Updatable]
          Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
          Adapter    "cloud"        : 4.4.1    , installed 4.2.2  [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 3.0.5  [Updatable]
          Adapter    "doorbird"     : 1.3.0    , installed 0.1.5  [Updatable]
          Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
          Adapter    "iot"          : 2.0.11   , installed 1.11.9 [Updatable]
          Adapter    "javascript"   : 7.1.6    , installed 6.0.3  [Updatable]
          Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
          Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
          Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
          Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
          Adapter    "sonos"        : 3.0.0    , installed 2.2.3  [Updatable]
          Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
          Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
          Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
          Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
          Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
          Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
          Objects and States
          Objects: 	5746
          States: 	4775
          E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
          E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
          Pending Updates: 132
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:38307         0.0.0.0:*               LISTEN      1001       131216559  14146/io.yahka.0
          tcp        0      0 127.0.0.1:41925         0.0.0.0:*               LISTEN      1001       131216564  14146/io.yahka.0
          tcp        0      0 127.0.0.1:33989         0.0.0.0:*               LISTEN      1001       131216547  14146/io.yahka.0
          tcp        0      0 127.0.0.1:41703         0.0.0.0:*               LISTEN      1001       131217334  14807/io.yahka.1
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       131213641  13946/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       131213634  13946/iobroker.js-c
          tcp        0      0 127.0.0.1:45291         0.0.0.0:*               LISTEN      1001       131219694  14146/io.yahka.0
          tcp        0      0 127.0.0.1:43851         0.0.0.0:*               LISTEN      1001       131217891  14807/io.yahka.1
          tcp        0      0 127.0.0.1:43631         0.0.0.0:*               LISTEN      1001       131216552  14146/io.yahka.0
          tcp        0      0 127.0.0.1:34769         0.0.0.0:*               LISTEN      1001       131218669  14840/io.yahka.2
          tcp        0      0 127.0.0.1:38131         0.0.0.0:*               LISTEN      1001       131220567  14840/io.yahka.2
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16813      572/sshd
          tcp        0      0 127.0.0.1:33561         0.0.0.0:*               LISTEN      1001       131218665  14840/io.yahka.2
          tcp        0      0 127.0.0.1:42905         0.0.0.0:*               LISTEN      1001       131216015  14807/io.yahka.1
          tcp        0      0 127.0.0.1:37211         0.0.0.0:*               LISTEN      1001       131219699  14146/io.yahka.0
          tcp6       0      0 :::38783                :::*                    LISTEN      1001       131216908  14807/io.yahka.1
          tcp6       0      0 :::42977                :::*                    LISTEN      1001       131214296  14146/io.yahka.0
          tcp6       0      0 :::34243                :::*                    LISTEN      1001       131217947  14840/io.yahka.2
          tcp6       0      0 :::36049                :::*                    LISTEN      1001       131214295  14146/io.yahka.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131213697  13964/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       131215920  14730/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16815      572/sshd
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       131217864  14781/io.terminal.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       131218481  14650/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14315      564/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131217948  14840/io.yahka.2
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131216909  14807/io.yahka.1
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214300  14146/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214297  14146/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15108      382/avahi-daemon: r
          udp        0      0 0.0.0.0:43289           0.0.0.0:*                           108        15110      382/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          31124735   564/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        15109      382/avahi-daemon: r
          udp6       0      0 :::42292                :::*                                108        15111      382/avahi-daemon: r
          2023-12-18 10:40:51.439  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
          2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Unknown Device, but enabling commands, Try it and report back if commands work.
          2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          2023-12-18 10:41:17.822  - info: alexa2.0 (14089)     Device-type:A2RG3FY1YV97SS - Sascha's Sonos Move (Sonos Move) (HANDS_FREE,SET_LOCALE,DEEZER,DIALOG_INTERFACE_VERSION,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SOUND_SETTINGS,SUPPORTS_LOCALE,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SPEECH_RECOGNIZER_USS,APPLE_MUSIC,FAR_FIELD,AUDIO_PLAYER,EARCONS,SUPPORTS_LOCALE_SWITCH,SET_TIME_ZONE,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS)
          2023-12-18 10:41:21.475  - info: host.raspberrypi instance system.adapter.doorbird.0 started with pid 15127
          2023-12-18 10:41:24.179  - info: doorbird.0 (15127) starting. Version 0.1.5 (non-npm: https://github.com/BuZZy1337/ioBroker.doorbird/tarball/47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb) in /opt/iobroker/node_modules/iobroker.doorbird, node: v12.22.2, js-controller: 4.0.23
          2023-12-18 10:41:24.275  - error: doorbird.0 (15127) uncaught exception: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
          2023-12-18 10:41:24.277  - error: doorbird.0 (15127) Error: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
              at Server.setupListenHandle [as _listen2] (net.js:1299:21)
              at listenInCluster (net.js:1364:12)
              at doListen (net.js:1501:7)
              at processTicksAndRejections (internal/process/task_queues.js:85:21)
          2023-12-18 10:41:24.278  - error: doorbird.0 (15127) Exception-Code: EADDRNOTAVAIL: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
          2023-12-18 10:41:24.299  - info: doorbird.0 (15127) terminating
          2023-12-18 10:41:24.300  - warn: doorbird.0 (15127) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-12-18 10:41:24.899  - error: host.raspberrypi instance system.adapter.doorbird.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-12-18 10:41:24.900  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
          2023-12-18 10:41:24.900  - warn: host.raspberrypi Do not restart adapter system.adapter.doorbird.0 because restart loop detected
          2023-12-18 10:41:32.861  - info: alexa2.0 (14089) No smart home devices to query
          2023-12-18 10:41:36.052  - info: alexa2.0 (14089) Subscribing to states...
          2023-12-18 10:41:36.056  - info: alexa2.0 (14089) Deleting the following states: ["Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint-scale","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint-scale"]
          2023-12-18 10:41:37.858  - info: alexa2.0 (14089) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-12-18 10:41:52.977  - info: alexa2.0 (14089) Initialization Done ...
          2023-12-18 10:45:27.558  - info: enocean.0 (14745) state 0584df18.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1702896327553,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896327553}
          2023-12-18 10:45:28.908  - info: enocean.0 (14745) state 0584df18.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1702896328901,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896328901}
          • T TheAriba
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:           99M          0B         99M
                     7875 M total memory
                      850 M used memory
                     5779 M free memory
                      144 M buffer memory
                     1101 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            416M	/var/
            217M	/var/cache
            212M	/var/cache/apt
            96M	/var/lib
            USB-Devices by-id:
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.2.22
            javascript: 	6.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	5746
            States: 	4775
            @theariba
            Zeitzone falsch.
            sudo timedatectl set-timezone "Europe/Berlin"
            Dein Dateisystem hat einen Treffer:
            Die Pending Updates: 132 zuerst einspielen:
            sudo apt update
            iob stop
            sudo apt full-upgrade
            iob nodejs-update
            sudo reboot
            Wenn der Server wieder auf die Beine gekommen ist:
            iob update
            iob upgrade all -y
            iob stop
            iob upgrade self
            iob start
            Dann davon ein Backup extern ablegen und das ganze System NEU als Raspberry OS 64Bit Lite installieren. Dort das Backup wieder einspielen, fertig.
              @theariba
              Zeitzone falsch.
              sudo apt update
              iob stop
              iob nodejs-update
              sudo reboot
              iob update
              iob upgrade all -y
              iob stop
              iob upgrade self
              iob start
              TheAriba
              für mich als Noob:
              1. Zeitzone korrigieren
              1. diese Befehle ausführen:
              sudo apt update
              iob stop
              iob nodejs-update
              sudo reboot
              iob update
              iob upgrade all -y
              iob stop
              iob upgrade self
              iob start
              Wie ich dann ein Backup extern ablegen kann muss ich dann noch recherchieren.
              Dann mache ich quasi den pi platt und setze es mit raspberry 64 OS bit Lite neu auf und spiele dann das backup ein?
              • T TheAriba
                für mich als Noob:
                sudo apt update
                iob stop
                iob nodejs-update
                sudo reboot
                iob update
                iob upgrade all -y
                iob stop
                iob upgrade self
                iob start
                @theariba sagte in System updaten raspberry + iobroker + node:
                Ja, das ist der Plan.
                  TheAriba
                  Ok. Werde nachher mal die Befehle so durchführen.
                  Kannst du mir evtl. Sagen wie ich das mit dem Backup auf usb Stick oder so hinbekomme?
                  Und wie macht man den Pi platt und setzt ihn neu auf?
                  • T TheAriba
                    Ich würde es per Backitup-Adapter machen.
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      TheAriba
                      @thomas-braun so, habe die erste Runde der Befehle mal ausgeführt. Nun Backitup Adapter installiert und versuche ein Backup auf Google Drive zu erstellen. Finde leider keinen USB Stick gerade...
                      wie kann ich sehen ob es erfolgreich war bzw. ob alles dabei ist? Am wichtigsiten ist mir mein Enocean Adapter...
                      • T TheAriba
                        @theariba
                        Im Backup sind die Adapter und deren Einstellungen enthalten.
                          @theariba
                          TheAriba
                          @thomas-braun ok danke. Habe irgendwie Bedenken dass ich mir das zerschiesse. Warum genau empfiehlt es sich denn das Raspberry OS zu aktualisieren?
                          • T TheAriba
                            Weil deine Version 10 'Buster' abgekündigt wurde, das EndOfLife erreicht hat und weil du da seinerzeit eine 32Bit-Version installiert hast, mittlerweile aber die 64Bit-Variante die besser für einen Raspberry Pi geeignete ist.
                            Und ganz allgemein, weil man seinen Softwarestack immer auf Stand hält.
                              TheAriba
                              @thomas-braun ok alles klar. Dann mache ich mich da heute Abend mal dran. Kurz zum Verständnis der Vorgehensweise:
                              • Über den Backitup auf einen beliebigen USB Stick das Backup ablegen.
                                Dafür gebe ich im Backitup Adapter unter NAS/Kopieren den Pfad /media/usbstick/backupDir an. Muss ich hier sonst noch etwas beachten?
                              • Dann formatiere ich die SD Karte, und setze dann das neue OS so auf wie in deiner Beschreibung
                              • Wie spielt man dann das Backup wieder auf?
                                Die Geräte muss ich sicher nicht mehr neu einlernen?
                              Sorry aber ich habe ein wenig Schiss :)
                              • OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @theariba
                                ich würde lieber eine neue SD-Karte nehmen. dann hast du a) die alte zur Sicherheit noch zur Hand und b) das Risiko, das die SD-Karte bereits einen Hau hat (wegen den verwaisten inodes) ist weg.
                                Meine Adapter und Widgets
                                Links im Profil
                                • OliverIOO OliverIO
                                  @theariba
                                  TheAriba
                                  @oliverio ok verstehe. Bedeutet das sobald ich die alte Karte einstecke habe ich den aktuellen Stand wieder und das funktioniert alles wie gehabt? Habe ich das mit dem Backup soweit richtig verstanden? Wie füge ich das dann wieder auf im neuen System ein? Muss ich dazu einen neuen iobroker aufsetzen oder geht das über Befehle? bspw. hole dir die Datei vom USB Stick?
                                  • T TheAriba
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    ja, das ist wie die Festplatte wechseln. Wenn die alte wieder einbaust, dann gehts genau mit dem letzten stand weiter. der raspi ist nur hardware und hat kein weiteres "Gedächtnis".
                                    Dann kannst du zur Not immer mal noch nachschauen
                                    Links im Profil
                                    • W Offline
                                      W Offline
                                      wrod
                                      Hallo, ich habe gerade mein Raspi OS neu aufgesetzt auf TRIXIE.
                                      Vorher habe ich alle diese Backups gemacht.
                                      Der iobroker backup konnte ich auch wieder einspielen. Beim Wiedereinspielen des influxdb-Backup bricht er aber immer ab mit "ECONNREFUSED"
                                      Das LOG sagt zwischendurch auch File /opt/iobroker/backups/influxDB_2026_05_24-14_00_39_backupiobroker.tar.gz not found
                                      Das ist aber nicht wirklich der Pfad, an dem sie liegt. In der Backitup-Instanz ist vielmehr unter FTP eingetragen: "/iobrokerbackups/backupDir". Dieser wird auch aufgerufen, dort wird sie gefunden, aber bei Aufruf: ECONNREFUSED.
                                      Auch ein Hochladen der Datei auf lokal führt nicht dazu, dass sie angezeigt wird, wenn man als restore-Quelle "lokal" angibt.
                                      Kann jemand helfen?
                                      Ach ja: Die Option, die alter DB zu löschen vor wem Wiederherstellen, ist gesetzt!
                                      • W wrod
                                        Kann jemand helfen?
                                        @wrod
                                        Ich würde das auch nicht per ollem ftp machen sondern per NFS / CIFS, je nachdem was da auf dem NAS verfügbar ist.
                                        Ist aber auch am Thema des Threads vorbei.
                                        • W Offline
                                          W Offline
                                          wrod
                                          Danke, das habe ich schon früher versucht. FTP lief am stabilsten.
                                          Es geht ja nun um ein Restore - da möchte ich die gleiche Technik nehmen, mit der die Daten angelegt wurden.
                                          Aber was ist ECONNREFUSED?
