  4. Nach Plattformupdate Alles träge und CPU teilweise Volllast
42 Beiträge 7 Kommentatoren 4.7k Aufrufe 7 Beobachtet
    @megamatze
    iob diag
    sagt nun?
    MegaMatze
    @thomas-braun jetzt zeigt er mir das hier an. Passt das jetzt so?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 5.15.0-91-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:07:25 up 49 min,  2 users,  load average: 1.45, 1.35, 1.25
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sun 2023-12-17 21:07:26 UTC
               Universal time: Sun 2023-12-17 21:07:26 UTC
                     RTC time: Sun 2023-12-17 21:07:26
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    matze
    /home/matze
    matze adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.8G        2.7G        2.0G        1.0M        1.0G        2.8G
    Swap:           2.0G          0B        2.0G
    Total:          7.8G        2.7G        4.0G
             5779 M total memory
             2744 M used memory
              582 M active memory
             2870 M inactive memory
             1992 M free memory
               81 M buffer memory
              961 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  578M  1.1M  577M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G  9.8G  4.1G  71% /
    tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
    tmpfs                             tmpfs  578M  4.0K  578M   1% /run/user/1000
    [Sun Dec 17 20:18:02 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Sun Dec 17 20:18:03 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
    [Sun Dec 17 20:18:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/2105 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/core20/2015 /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/snapd/19457 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/snapd/20290 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    812M    /var/
    622M    /var/lib
    398M    /var/lib/snapd
    334M    /var/lib/snapd/snaps
    178M    /var/lib/apt/lists
    Archived and active journals take up 72.0M in the file system.
    /opt/iobroker/backups:
    11M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    937M    /opt/iobroker/iobroker-data/
    380M    /opt/iobroker/iobroker-data/history
    329M    /opt/iobroker/iobroker-data/files
    103M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    78M     /opt/iobroker/iobroker-data/states.jsonl
    49M     /opt/iobroker/iobroker-data/objects.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.9~dfsg-1ubuntu3.2 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Pac        kages
            500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Pack        ages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker        -  enabled, port: 8081, bind: 192.168.178.101, run        as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker        -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker        -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker        -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker        -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker        - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker        - disabled
    + system.adapter.deconz.0                 : deconz                : iobroker        -  enabled, port: 80
    + system.adapter.device-reminder.0        : device-reminder       : iobroker        -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker        -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker        - disabled
      system.adapter.flot.0                   : flot                  : iobroker        - disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker        -  enabled
    + system.adapter.haassohn.0               : haassohn              : iobroker        -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker        - disabled
    + system.adapter.history.0                : history               : iobroker        -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker        -  enabled
    + system.adapter.info.0                   : info                  : iobroker        -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker        -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker        -  enabled
      system.adapter.material.0               : material              : iobroker        -  enabled
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker        - disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker        - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker        -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker        -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker        -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker        -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker        -  enabled
    + system.adapter.senec.0                  : senec                 : iobroker        -  enabled
      system.adapter.smartthings.0            : smartthings           : iobroker        - disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker        -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : iobroker        -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker        -  enabled, port: 8088, bind: 0.0.0.0, run as: admi        n
    + system.adapter.text2command.0           : text2command          : iobroker        -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker        - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker        -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker        -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker        -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker        -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker        -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker        -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker        -  enabled
      system.adapter.vis.0                    : vis                   : iobroker        -  enabled
      system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker        - disabled
    + system.adapter.web.0                    : web                   : iobroker        -  enabled, port: 8082, bind: 192.168.178.101, run        as: admin
      system.adapter.worx.0                   : worx                  : iobroker        - disabled
    + system.adapter.yeelight-2.0             : yeelight-2            : iobroker        -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bmw"          : 2.5.7    , installed 2.7.2
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "go-e"         : 1.0.29   , installed 1.0.29
    Adapter    "haassohn"     : 1.0.9    , installed 1.0.9
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Objects and States
    Objects:        68279
    States:         66374
    Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       36044      2866/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34633      2888/io.sonoff.0
    tcp        0      0 192.168.178.101:8081    0.0.0.0:*               LISTEN      1001       34853      2668/io.admin.0
    tcp        0      0 192.168.178.101:8082    0.0.0.0:*               LISTEN      1001       36243      3236/io.web.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32732      2642/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33148      2642/iobroker.js-co
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22562      634/systemd-resolve
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14261      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21002      693/sshd: /usr/sbin
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       36217      3177/io.terminal.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15839      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21013      693/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       34781      2970/io.deconz.0
    udp        0      0 0.0.0.0:59472           0.0.0.0:*                           1001       48028      4673/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       48003      4673/io.broadlink2.
    udp        0      0 0.0.0.0:56912           0.0.0.0:*                           1001       48004      4673/io.broadlink2.
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22561      634/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19077      1/init
    udp6       0      0 :::1900                 :::*                                1001       34783      2970/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       34782      2970/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          2039       1/init
    2023-12-17 21:09:15.987  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.120.power:{"val":0,"ack":true,"ts":1702847355933,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1696254644875}
    2023-12-17 21:09:15.987  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.120.voltage:{"val":221,"ack":true,"ts":1702847355933,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702847043172}
    2023-12-17 21:09:17.040  - warn: mqtt.0 (2866) Client [BlueIris] has invalid password(Matze#89) or username(admin)
    2023-12-17 21:09:17.956  - warn: sonoff.0 (2888) Client [RollladenZu] has invalid password or username
    2023-12-17 21:09:21.043  - debug: deconz.0 (2970) Websocket message: {"e":"changed","id":"165","r":"sensors","state":{"consumption":9440,"lastupdated":"2023-12-17T21:09:21.039","power":null},"t":"event","uniqueid":"54:0f:57:ff:fe:3c:1e:d9-01-0702"}
    2023-12-17 21:09:21.288  - warn: sonoff.0 (2888) Client [Touch Schalter Keller] has invalid password or username
    2023-12-17 21:09:21.313  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.165.consumption:{"val":9440,"ack":true,"ts":1702847361309,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702740264454}
    2023-12-17 21:09:21.317  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.165.lastupdated:{"val":"2023-12-17T21:09:21.039Z","ack":true,"ts":1702847361310,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702847361310}
    2023-12-17 21:09:21.585  - warn: sonoff.0 (2888) Client [WerkbankBeleuchtung] has invalid password or username
    2023-12-17 21:09:21.951  - debug: deconz.0 (2970) Websocket message: {"e":"changed","id":"166","r":"sensors","state":{"current":0,"lastupdated":"2023-12-17T21:09:21.947","power":0,"voltage":230},"t":"event","uniqueid":"54:0f:57:ff:fe:3c:1e:d9-01-0b04"}
    2023-12-17 21:09:22.045  - warn: mqtt.0 (2866) Client [BlueIris] has invalid password(Matze#89) or username(admin)
    2023-12-17 21:09:22.173  - debug: deconz.0 (2970) Websocket message: {"attr":{"id":"2","lastannounced":"2023-10-15T12:50:14Z","lastseen":"2023-12-17T21:09Z","manufacturername":"LUMI","modelid":"lumi.plug","name":"Power 2","swversion":"04-20-2018","type":"ZHAPower","uniqueid":"00:15:8d:00:01:10:17:6d-02-000c"},"e":"changed","id":"2","r":"sensors","t":"event","uniqueid":"00:15:8d:00:01:10:17:6d-02-000c"}
    2023-12-17 21:09:22.175  - debug: deconz.0 (2970) Websocket message: {"attr":{"id":"3","lastannounced":"2023-10-15T12:50:14Z","lastseen":"2023-12-17T21:09Z","manufacturername":"LUMI","modelid":"lumi.plug","name":"Consumption 3","swversion":"04-20-2018","type":"ZHAConsumption","uniqueid":"00:15:8d:00:01:10:17:6d-03-000c"},"e":"changed","id":"3","r":"sensors","t":"event","uniqueid":"00:15:8d:00:01:10:17:6d-03-000c"}
    2023-12-17 21:09:22.830  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.166.current:{"val":0,"ack":true,"ts":1702847362825,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702808054166}
    2023-12-17 21:09:22.836  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.166.lastupdated:{"val":"2023-12-17T21:09:21.947Z","ack":true,"ts":1702847362825,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702847362825}
    2023-12-17 21:09:22.845  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.166.power:{"val":0,"ack":true,"ts":1702847362826,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702808054254}
    2023-12-17 21:09:22.919  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Sensors.166.voltage:{"val":230,"ack":true,"ts":1702847362915,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702846778234}
    2023-12-17 21:09:23.371  - warn: sonoff.0 (2888) Client [GaragenTor] has invalid password or username
    2023-12-17 21:09:23.828  - warn: sonoff.0 (2888) Client [RollladenAuf] has invalid password or username
    2023-12-17 21:09:24.416  - silly: deconz.0 (2970) States user redis pmessage deconz.0.*/deconz.0.Gateway_info.alive:{"val":true,"ack":true,"ts":1702847364413,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1702845404969,"expire":true}
    2023-12-17 21:09:25.546  - debug: deconz.0 (2970) Websocket message: {"attr":{"id":"21","lastannounced":null,"lastseen":"2023-12-17T21:09Z","manufacturername":"_TZ3000_u5u4cakc","modelid":"TS011F","name":"Eiswürfelmaschine","swversion":"69","type":"On/Off plug-in unit","uniqueid":"00:3c:84:ff:fe:8c:8b:6b-01"},"e":"changed","id":"21","r":"lights","t":"event","uniqueid":"00:3c:84:ff:fe:8c:8b:6b-01"}
    2023-12-17 21:09:25.547  - debug: deconz.0 (2970) Event has attr-Tag
    2023-12-17 21:09:27.050  - warn: mqtt.0 (2866) Client [BlueIris] has invalid password(Matze#89) or username(admin)
    2023-12-17 21:09:32.062  - warn: mqtt.0 (2866) Client [BlueIris] has invalid password(Matze#89) or username(admin)
    2023-12-17 21:09:33.253  - debug: deconz.0 (2970) Websocket message: {"e":"changed","id":"141","r":"sensors","state":{"consumption":340420,"lastupdated":"2023-12-17T21:09:33.079"},"t":"event","uniqueid":"a4:c1:38:14:7d:66:62:3f-01-0702"}
    Thomas BraunT ? 2 Antworten Letzte Antwort
    • M MegaMatze
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      matze
      /home/matze
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               5779 M total memory
               2744 M used memory
                582 M active memory
               1992 M free memory
                 81 M buffer memory
                961 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      812M    /var/
      622M    /var/lib
      398M    /var/lib/snapd
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        68279
      States:         66374
      Pending Updates: 0
      @megamatze
      Die Uhrzeit ist falsch/ es wurde keine Zeitzone gesetzt.
      Der deconz steht auf LogLevel silly.
      • M MegaMatze
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        matze
        /home/matze
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
                 5779 M total memory
                 2744 M used memory
                  582 M active memory
                 1992 M free memory
                   81 M buffer memory
                  961 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        /var:
        812M    /var/
        622M    /var/lib
        398M    /var/lib/snapd
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        68279
        States:         66374
        Pending Updates: 0
        @megamatze sagte in Nach Plattformupdate Alles träge und CPU teilweise Volllast:
        Moin,
        lebst/wohnst Du wirklich in der Zeitzone?
        Bernd
        P.S.: da hab ich den letzten Beitrag von @Thomas-Braun nicht gelesen, sorry.
          Moin,
          Bernd
          MegaMatze
          Hab gestern noch die Zeit im Ubuntu korrekt gesetzt und noch das silly logging vom deconz deaktiviert. Jetzt schau ich Mal, ob der heute wieder performant ist und gebe euch nachher gleich noch Rückmeldung.
          System sollte jetzt aber voll auf Stand sein denke ich.
          • M MegaMatze
            denke ich.
            ist eine Sache.
            Interessant sind aber Fakten!
            die finden sich in iob diag
              denke ich.
              ist eine Sache.
              MegaMatze
              Leider immer noch keine Besserung auch nach Updates und Herstellen von Stable zum größten Teil (BMW und Senec brauchen die Github Version da APIs geändert und noch nicht im Stable integriert)
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               16:24:54 up 19:06,  2 users,  load average: 0.98, 0.89, 0.76
              CPU threads: 8
                             Local time: Mon 2023-12-18 15:24:54 UTC
                         Universal time: Mon 2023-12-18 15:24:54 UTC
                               RTC time: Mon 2023-12-18 15:24:54
                            NTP service: active
                        RTC in local TZ: no
              matze
              /home/matze
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            5.8G        3.0G        781M        1.0M        2.0G        2.5G
              Swap:           2.0G          0B        2.0G
              Total:          7.8G        3.0G        2.8G
                       5779 M total memory
                       2994 M used memory
                        630 M active memory
                       4021 M inactive memory
                        781 M free memory
                        134 M buffer memory
                       1869 M swap cache
                       2047 M total swap
                          0 M used swap
                       2047 M free swap
              *** FILESYSTEM ***
              /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   10G  4.0G  72% /
              [Sun Dec 17 21:18:02 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
              [Sun Dec 17 21:18:03 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
              [Sun Dec 17 21:18:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
              /var:
              813M    /var/
              622M    /var/lib
              398M    /var/lib/snapd
              27M     /opt/iobroker/backups/
              977M    /opt/iobroker/iobroker-data/
              387M    /opt/iobroker/iobroker-data/history
              110M    /opt/iobroker/iobroker-data/states.jsonl
              50M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
                system.adapter.chromecast.0             : chromecast            : iobroker        -  enabled
                system.adapter.mqtt.0                   : mqtt                  : iobroker        - disabled, port: 1885, bind: 0.0.0.0
                system.adapter.sonoff.0                 : sonoff                : iobroker        - disabled, port: 1883, bind: 0.0.0.0
              + instance is alive
              Objects and States
              Objects:        68286
              States:         66362
              Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
              Pending Updates: 0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91001      11682/io.deconz.0
              udp        0      0 0.0.0.0:59941           0.0.0.0:*                           1001       338175     32740/io.broadlink2
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       335701     32740/io.broadlink2
              udp        0      0 0.0.0.0:45198           0.0.0.0:*                           1001       338182     32740/io.broadlink2
              udp6       0      0 :::1900                 :::*                                1001       91003      11682/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       91002      11682/io.deconz.0
              2023-12-18 15:22:11.535  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:22:11.573  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:22:11.597  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:22:11.700  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:22:11.703  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:22:11.775  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:22:45.342  - info: admin.0 (2668) failed connection to socket.io from 192.168.178.79: Passport was not initialized
              2023-12-18 15:22:52.004  - info: admin.0 (2668) ==> Connected system.user.admin from 192.168.178.79
              2023-12-18 15:23:06.325  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 vis.0
              2023-12-18 15:23:09.133  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:23:09.294  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:23:09.385  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:23:09.401  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:23:09.540  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:23:09.600  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:23:16.514  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:24:48.037  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:24:49.990  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:25:10.188  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.152 vis.0
              2023-12-18 15:25:47.700  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:25:47.741  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:25:47.893  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:25:48.033  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              2023-12-18 15:27:10.031  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
              2023-12-18 15:27:10.250  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
              ? HomoranH 2 Antworten Letzte Antwort
              • M MegaMatze
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 8
                              NTP service: active
                          RTC in local TZ: no
                matze
                /home/matze
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           2.0G          0B        2.0G
                         5779 M total memory
                         2994 M used memory
                          630 M active memory
                          781 M free memory
                          134 M buffer memory
                         1869 M swap cache
                         2047 M total swap
                            0 M used swap
                         2047 M free swap
                *** FILESYSTEM ***
                /var:
                813M    /var/
                622M    /var/lib
                398M    /var/lib/snapd
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        68286
                States:         66362
                Pending Updates: 0
                Moin,
                Zeitzone ist nicht umgestellt, ist zwar nicht das Problem, aber richtig ist besser ;)
                Dann solltest/kannst Du ja mal darüber nachdenken, die Objekts und States Datenbank von jsonl auf Redis umzustellen, da du doch recht viele States und Objekte hast.
                Objects type: jsonl
                States  type: jsonl
                Objects and States
                Objects:        68286
                States:         66362
                Bernd
                • M MegaMatze
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                  CPU threads: 8
                                NTP service: active
                            RTC in local TZ: no
                  matze
                  /home/matze
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           2.0G          0B        2.0G
                           5779 M total memory
                           2994 M used memory
                            630 M active memory
                            781 M free memory
                            134 M buffer memory
                           1869 M swap cache
                           2047 M total swap
                              0 M used swap
                           2047 M free swap
                  *** FILESYSTEM ***
                  /var:
                  813M    /var/
                  622M    /var/lib
                  398M    /var/lib/snapd
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        68286
                  States:         66362
                  Pending Updates: 0
                  @megamatze
                  und
                  @homoran sagte in Nach Plattformupdate Alles träge und CPU teilweise Volllast:
                  @megamatze Die Frage zu Proxmox bitte auch noch beantworten.
                    @megamatze
                    und
                    MegaMatze
                    @homoran Oh das hab ich ganz übersehen mit dem Proxmox. Das habe ich nie upgedatet, weil ich da sehr viel Respekt vor habe. Da läuft noch Virtual Environment 6.3-2. Muss das auch zwingend upgedatet werden? Falls ja, gibt es da auch ein Updateskript bei dem nix kaputt geht? Oder können die Backups der VMs einfach bei Neuinstallation wiederhergestellt werden?
                    @dp20eic das verstehe ich nicht ganz, wenn ich in der Shell date eingebe kommt in Ubuntu die korrekte Uhrzeit. Muss das in iob auch noch angepasst werden?
                    Meister MopperM Thomas BraunT ? 3 Antworten Letzte Antwort
                      Moin,
                      Objects type: jsonl
                      States  type: jsonl
                      Objects and States
                      Objects:        68286
                      States:         66362
                      Bernd
                      MegaMatze
                      @dp20eic Wegen der Objects bin ich irgendwie überfragt. Kann ich irgendwie rausfinden, welche Instanz so viele Objects eingeführt hat? Eigenltich habe ich nicht so viele Komponenten im Smarthome....das wirkt ja als wäre die iob in einem Konzern installiert :D
                      • M MegaMatze
                        Meister MopperM Online
                        Meister Mopper
                        schrieb am zuletzt editiert von Meister Mopper
                        Um es philosophisch auszudrücken: "Alles fließt!"
                        Die Hardware ändert sich ständig, und so sollten auch Betriebs- und Virtualisierungssysteme, die ja mit der Hardware arbeiten, ständig aktualisiert werden.
                        Und dann gibt es noch die Liga derer, die Systeme infiltrieren möchten, um illegal Ressourcen zu ergattern oder illegal an mehr Geld zu kommen.
                        Der Ausspruch: "Never change a running system" ist nicht nur in Richtung Hardware unsinnig sondern insbesondere in Sachen Sicherheit vollumfänglicher Unsinn.
                        Proxmox und HA ...
                        • M MegaMatze
                          Ja, wie jegliche andere Software halt auch.
                            MegaMatze
                            @thomas-braun und @Meister-Mopper Ok verstanden, dann werde ich mich da mal nach Weihnachten ransetzen und das aktualisieren. Gibt es dafür vielleicht eine Anleitung irgendwo, wie man das am geschicktesten mit Wiederherstellung der VMs hinkriegt?
                            Bezüglich der vielen Objects und States: Gibt es da eine Möglichkeit den Übertäter zu finden wo die alle herkommen? Ich vermute mal, dass das der Grund allen Übels ist.
                            • M MegaMatze
                              Moin,
                              ich auch nicht, da ich nicht weis, was Du wo, wie eingestellt hast. Du sitzt vor der Kiste, dann solltest Du uns auch zeigen, was Du gemacht hast. Zudem nutze ich kein Ubuntu -> https://wiki.ubuntuusers.de/Systemzeit/, dann unter
                              Anpassungen in einem Terminal
                              Hier hast Du die Zeit total verschlafen, wir sind aktuell bei 8.1, eine Migration über zwei Releases ist keine gute Idee, außer Du hast genug Linux Erfahrungen. Also VMs und LXC Backupen auf extern Datenträgern, dann lieber Proxmox neu installieren und die Backups wieder Restoren.
                              Das ist auch wieder so was, wenn man alles Mögliche an Adaptern installiert aber nicht nutzt, dann liegen viele nutzlose Daten im System herum, was Du dann noch per Skript machst, kannst auch nur Du beantworten.
                              Ich würde mir mal wirklich Gedanken machen, was Du brauchst und was nicht, dann das was nicht deinstallieren.
                              Bernd
                                Moin,
                                Bernd
                                MegaMatze
                                Jetzt habe ich gerade einen Aha Moment gehabt. Euer Hinweis bezüglich der vielen Objekte hat mich tatsächlich zu dem als Fehlerursache geführt. Aus eigener Suche habe ich dann entdeckt, dass ich per JSON Download die 68k Elemente schnell und einfach lesbar downloaden kann und beim Öffnen festgestellt, dass 55k Objekte einfach mal vom Smartthings Adapter für meine Samsung Wärmepumpe gekommen sind. Offenbar ist dieser Adapter nicht ganz Banane. Ich versuche jetzt mal diesen zu löschen, aber vermute mal, dass er der Übeltäter war. Vermutlich hat der nach dem Nodejs Update Hohl gedreht oder so. Ich probier das jetzt mal aus alles zu löschen und dann bin ich gespannt, was dann Phase auf meinem iob ist. Nichts desto trotz werde ich mal das Proxmox Update über Weihnachten in Angriff nehmen. Ich halt euch mal uptodate was jetzt beim Löschen rauskommt. Danke für die HIlfe
                                • M MegaMatze
                                  wohl kaum.
                                  oder so.
                                  kann schon eher sein!
