  4. VIS 2 lässt sich nicht installieren
    1.0k
    6.1k
32 Beiträge 4 Kommentatoren 4.2k Aufrufe 3 Beobachtet
  • A Alveran
    Nachtschicht beendet und Hausaufgaben gemacht :-)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker1
             Icon name: computer-vm
               Chassis: vm
        Virtualization: vmware
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    model name      : 12th Gen Intel(R) Core(TM) i5-1240P
    Docker          : false
    Virtualization  : vmware
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:28:44 up 49 min,  1 user,  load average: 0.80, 0.60, 0.31
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-18 11:28:44 CET
               Universal time: Mon 2023-12-18 10:28:44 UTC
                     RTC time: Mon 2023-12-18 10:28:44
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    alveran
    /home/alveran
    alveran cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        2.3G        2.3G        0.0K        1.4G        3.3G
    Swap:           2.0G          0B        2.0G
    Total:          8.0G        2.3G        4.3G
             5929 M total memory
             2294 M used memory
              684 M active memory
             2545 M inactive memory
             2285 M free memory
              297 M buffer memory
             1052 M swap cache
             2045 M total swap
                0 M used swap
             2045 M free swap
    *** FAILED SERVICES ***
      UNIT              LOAD   ACTIVE SUB    DESCRIPTION
    * motioneye.service loaded failed failed motionEye Server
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs          tmpfs     593M  684K  593M   1% /run
    /dev/sda1      ext4       18G   12G  5.0G  71% /
    tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
    [Mon Dec 18 10:39:24 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Dec 18 10:39:24 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    843M    /var/
    448M    /var/cache
    439M    /var/cache/apt
    367M    /var/cache/apt/archives
    251M    /var/log
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    254M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/history
    560M    /opt/iobroker/iobroker-data/files
    167M    /opt/iobroker/iobroker-data/files/vis-2
    91M     /opt/iobroker/iobroker-data/backup-objects
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.061c8d42.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_015AD341-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker1                                -  enabled
    + system.adapter.admin.0                  : admin                 : iobroker1                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker1                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker1                                -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker1                                -  enabled
      system.adapter.devices.0                : devices               : iobroker1                                -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker1                                -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker1                                -  enabled
    + system.adapter.ebus.0                   : ebus                  : iobroker1                                -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker1                                -  enabled
      system.adapter.flot.0                   : flot                  : iobroker1                                -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker1                                - disabled
    + system.adapter.history.0                : history               : iobroker1                                -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker1                                -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.hs100.0                  : hs100                 : iobroker1                                -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker1                                -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker1                                -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker1                                -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker1                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker1                                -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker1                                -  enabled
    + system.adapter.info.0                   : info                  : iobroker1                                -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker1                                -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker1                                -  enabled
    + system.adapter.mclighting.0             : mclighting            : iobroker1                                -  enabled, port: 81
      system.adapter.mclighting.1             : mclighting            : iobroker1                                - disabled, port: 81
    + system.adapter.modbus.0                 : modbus                : iobroker1                                -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker1                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker1                                -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker1                                -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker1                                - disabled
    + system.adapter.ping.0                   : ping                  : iobroker1                                -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : iobroker1                                -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker1                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker1                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker1                                -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker1                                -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker1                                -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker1                                -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker1                                -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker1                                - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker1                                -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker1                                -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker1                                -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker1                                -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker1                                -  enabled
      system.adapter.vis.0                    : vis                   : iobroker1                                -  enabled
    + system.adapter.web.0                    : web                   : iobroker1                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : iobroker1                                -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker1                                -  enabled
      system.adapter.ws.0                     : ws                    : iobroker1                                - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobroker1                                - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "apcups"       : 1.0.15   , installed 1.0.15
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "ebus"         : 3.2.4    , installed 3.2.4
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
    Adapter    "landroid"     : 1.0.3    , installed 1.0.3
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "modbus"       : 5.0.11   , installed 6.1.0
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 0.4.5   , installed 1.0.4
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:        14918
    States:         14498
    Hit:1 http://ftp.debian.org/debian bullseye-backports InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://repo.ebusd.eu/apt/default/buster buster InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       130322     69245/iobroker.js-c
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        12434      584/redis-server 12
    tcp        0      0 192.168.6.222:2001      0.0.0.0:*               LISTEN      1002       130723     69447/io.hm-rpc.0
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      110        10011      686/proftpd: (accep
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12389      594/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1002       131202     69339/node-red
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          10117      608/ebusd
    tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          10118      608/ebusd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          10094      869/exim4
    tcp        0      0 192.168.6.222:2010      0.0.0.0:*               LISTEN      1002       132149     69568/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       130582     69376/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       130652     69407/io.mqtt.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        12435      584/redis-server 12
    tcp6       0      0 :::80                   :::*                    LISTEN      1002       131220     69339/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       129009     69267/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       132225     69583/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1002       131858     69613/io.socketio.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12392      594/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          10095      869/exim4
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       134853     70535/io.wled.0
    udp        0      0 192.168.6.222:5353      0.0.0.0:*                           1002       131679     69553/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9923       573/avahi-daemon: r
    udp        0      0 0.0.0.0:43794           0.0.0.0:*                           108        9925       573/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        9924       573/avahi-daemon: r
    udp6       0      0 :::42311                :::*                                108        9926       573/avahi-daemon: r
    2023-12-18 11:28:13.355  - info: host.iobroker1 iobroker host.iobroker1 Counted 1 states (system.adapter.milight.*) from states
    2023-12-18 11:28:14.182  - info: host.iobroker1 iobroker host.iobroker1 file vis/widgets/milight deleted
    2023-12-18 11:28:14.195  - info: host.iobroker1 iobroker host.iobroker1 file vis/widgets/milight.html deleted
    2023-12-18 11:28:14.202  - info: host.iobroker1 iobroker host.iobroker1 file vis-2/widgets/milight deleted
    2023-12-18 11:28:14.212  - info: host.iobroker1 iobroker host.iobroker1 file vis-2/widgets/milight.html deleted
    2023-12-18 11:28:14.219  - info: host.iobroker1 iobroker host.iobroker1 file milight.admin deleted
    2023-12-18 11:28:14.225  - info: host.iobroker1 iobroker host.iobroker1 object milight deleted
    2023-12-18 11:28:14.228  - info: host.iobroker1 iobroker host.iobroker1 object milight.admin deletedhost.iobroker1 Deleting 3 object(s).
    2023-12-18 11:28:14.252  - info: host.iobroker1 iobroker host.iobroker1 Deleting 1 state(s).
    2023-12-18 11:28:19.316  - info: host.iobroker1 iobroker removed 4 packages, and changed 1 package in 5s210 packages are looking for funding  run `npm fund` for details
    2023-12-18 11:28:19.350  - info: host.iobroker1 "system.adapter.vis.0" disabled
    2023-12-18 11:28:19.361  - info: host.iobroker1 "system.adapter.vis.0" enabled
    2023-12-18 11:28:19.383  - info: host.iobroker1 iobroker Adapter "system.adapter.vis.0" restarted.
    2023-12-18 11:28:20.065  - info: vis.0 (73236) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.16
    2023-12-18 11:28:20.339  - info: vis.0 (73236) config.js changed. Upload.
    2023-12-18 11:28:20.399  - info: host.iobroker1 iobroker exit 0
    2023-12-18 11:28:20.431  - info: vis.0 (73236) Changes in index.html detected => update cache.manifest
    2023-12-18 11:28:20.437  - info: vis.0 (73236) Upload vis anew, while changes detected...
    2023-12-18 11:28:21.272  - info: host.iobroker1 "system.adapter.vis.0" disabled
    2023-12-18 11:28:21.272  - info: host.iobroker1 stopInstance system.adapter.vis.0 (force=false, process=true)
    2023-12-18 11:28:21.280  - info: host.iobroker1 "system.adapter.vis.0" enabled
    2023-12-18 11:28:21.280  - info: host.iobroker1 stopInstance system.adapter.vis.0 (force=false, process=true)
    2023-12-18 11:28:28.124  - info: vis.0 (73236) Uploaded. 0
    2023-12-18 11:28:28.626  - info: vis.0 (73236) Terminated (NO_ERROR): Without reason
    2023-12-18 11:28:29.176  - info: host.iobroker1 instance system.adapter.vis.0 terminated while should be started once
                            v.2023-10-10
               Chassis: vm
    Installation:           vmware
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            5.9G        2.3G        2.2G        0.0K        1.4G        3.3G
    Swap:           2.0G          0B        2.0G
    Active iob-Instances:   29
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.0
    Objects type: jsonl
    States  type: redis
    Objects:                14918
    States:                 14498
    Size of iob-Database:
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    4.0K    /opt/iobroker/iobroker-data/states.json
    @alveran sagte in VIS 2 lässt sich nicht installieren:
    Und was ist mit dem los?
    • A Alveran
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: vm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      alveran
      /home/alveran
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               5929 M total memory
               2294 M used memory
                684 M active memory
               2285 M free memory
                297 M buffer memory
               1052 M swap cache
               2045 M total swap
                  0 M used swap
               2045 M free swap
      *** FILESYSTEM ***
      /var:
      843M    /var/
      448M    /var/cache
      439M    /var/cache/apt
      251M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        14918
      States:         14498
      Pending Updates: 0
                              v.2023-10-10
                 Chassis: vm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      MEMORY:
      Swap:           2.0G          0B        2.0G
                              admin                   6.12.0
      Objects type: jsonl
      States  type: redis
      Objects:                14918
      States:                 14498
      Update das auf die aktuelle Version.
      • A Alveran
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: vm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        alveran
        /home/alveran
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
                 5929 M total memory
                 2294 M used memory
                  684 M active memory
                 2285 M free memory
                  297 M buffer memory
                 1052 M swap cache
                 2045 M total swap
                    0 M used swap
                 2045 M free swap
        *** FILESYSTEM ***
        /var:
        843M    /var/
        448M    /var/cache
        439M    /var/cache/apt
        251M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        14918
        States:         14498
        Pending Updates: 0
                                v.2023-10-10
                   Chassis: vm
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        MEMORY:
        Swap:           2.0G          0B        2.0G
                                admin                   6.12.0
        Objects type: jsonl
        States  type: redis
        Objects:                14918
        States:                 14498
        Stell das auf bullseye um.
          Alveran
          @thomas-braun said in VIS 2 lässt sich nicht installieren:
          OK. Wie mach ich das? Hab dazu leider nichts gefunden.
            Alveran
            Motioneye habe ich deinstalliert, keine Ahnung warum er den Service immer noch starten will. Gibt es eine Art Autostart Liste?
            • A Alveran
              motioneye.service
              sudo systemctl disable motioneye.service
              sudo systemctl mask motioneye.service
              • A Alveran
                @alveran
                ebusd:
                https://github.com/john30/ebusd-debian/tree/master
                  Alveran
                  motioneye.service
                  Der erste Befehl hat funktioniert beim zweiten kommt das:
                  Failed to mask unit: File /etc/systemd/system/motioneye.service already exists.
                  alveran@iobroker1:~$
                    Alveran
                    EBUSD hat geklappt, hier nochmal zur Kontrolle:
                    Aber warum schon wieder npm Fehler?
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder
                    npm ERR! A complete log of this run can be found in: /home/alveran/.npm/_logs/2023-12-18T13_25_24_117Z-debug-0.log
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: vm
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     14:25:21 up  2:46,  1 user,  load average: 0.48, 0.41, 0.25
                    CPU threads: 2
                                   Local time: Mon 2023-12-18 14:25:22 CET
                               Universal time: Mon 2023-12-18 13:25:22 UTC
                                     RTC time: Mon 2023-12-18 13:25:22
                                  NTP service: active
                              RTC in local TZ: no
                    alveran
                    /home/alveran
                    alveran adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            5.9G        2.2G        2.7G        0.0K        981M        3.4G
                    Swap:           2.0G          0B        2.0G
                    Total:          8.0G        2.2G        4.8G
                             5929 M total memory
                             2212 M used memory
                              568 M active memory
                             2299 M inactive memory
                             2735 M free memory
                              152 M buffer memory
                              829 M swap cache
                             2045 M total swap
                                0 M used swap
                             2045 M free swap
                    *** FILESYSTEM ***
                    /dev/sda1      ext4       18G   12G  4.9G  71% /
                    [Mon Dec 18 11:39:15 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Dec 18 11:39:16 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                    /var:
                    844M    /var/
                    448M    /var/cache
                    439M    /var/cache/apt
                    253M    /var/log
                    Archived and active journals take up 184.0M in the file system.
                    21M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    js-controller:  5.0.17
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Objects and States
                    Objects:        14918
                    States:         14498
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
                    Hit:5 https://repo.ebusd.eu/apt/default/bullseye bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       374094     344046/iobroker.js-
                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        12791      573/redis-server 12
                    tcp        0      0 192.168.6.222:2001      0.0.0.0:*               LISTEN      1002       374584     344247/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      110        12828      850/proftpd: (accep
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11690      585/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1002       374315     344136/node-red
                    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          12877      626/ebusd
                    tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          12878      626/ebusd
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          11887      869/exim4
                    tcp        0      0 192.168.6.222:2010      0.0.0.0:*               LISTEN      1002       375682     344354/io.hm-rpc.1
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       374393     344173/io.sonoff.0
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       375243     344217/io.mqtt.0
                    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        12792      573/redis-server 12
                    tcp6       0      0 :::80                   :::*                    LISTEN      1002       374322     344136/node-red
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       375068     344064/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       375978     344369/io.web.0
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1002       376238     344399/io.socketio.
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          11692      585/sshd: /usr/sbin
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          11888      869/exim4
                    udp        0      0 0.0.0.0:47708           0.0.0.0:*                           108        11606      481/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       378888     345582/io.wled.0
                    udp        0      0 192.168.6.222:5353      0.0.0.0:*                           1002       375616     344339/io.tr-064.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11604      481/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        11605      481/avahi-daemon: r
                    udp6       0      0 :::42223                :::*                                108        11607      481/avahi-daemon: r
                    2023-12-18 14:22:45.956  - info: wled.0 (345582) Try to contact 2 known devices
                    2023-12-18 14:22:45.957  - info: wled.0 (345582) Try to contact : "WLED" on IP : 192.168.6.164
                    2023-12-18 14:22:47.297  - info: alexa2.0 (344294) Initialization Done ...
                    2023-12-18 14:22:48.968  - info: wled.0 (345582) Try to contact : "WLED" on IP : 192.168.6.155
                    2023-12-18 14:22:49.074  - info: host.iobroker1 instance system.adapter.accuweather.0 started with pid 345621
                    2023-12-18 14:22:49.510  - info: accuweather.0 (345621) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:22:51.971  - info: wled.0 (345582) Bonjour service started, new  devices  will  be detected automatically
                    2023-12-18 14:22:53.058  - info: host.iobroker1 instance system.adapter.ebus.0 started with pid 345891
                    2023-12-18 14:22:57.060  - info: host.iobroker1 instance system.adapter.discovery.0 started with pid 345939
                    2023-12-18 14:22:57.902  - info: discovery.0 (345939) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:23:01.061  - info: host.iobroker1 instance system.adapter.iqontrol.0 started with pid 346205
                    2023-12-18 14:23:01.915  - info: iqontrol.0 (346205) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:23:01.939  - info: iqontrol.0 (346205) systemLanguage = de
                    2023-12-18 14:23:01.939  - info: iqontrol.0 (346205) Creating Passphrase...
                    2023-12-18 14:23:01.975  - info: wled.0 (345582) WLED initialisation finalized, ready to do my job have fun !
                    2023-12-18 14:23:01.984  - info: iqontrol.0 (346205) Creating Popup States...
                    2023-12-18 14:23:02.020  - info: iqontrol.0 (346205) Creating Widget States...
                    2023-12-18 14:23:02.021  - info: iqontrol.0 (346205) Lists deactivated.
                    2023-12-18 14:23:02.021  - info: iqontrol.0 (346205) Deleting unused Objects...
                    2023-12-18 14:23:02.021  - info: iqontrol.0 (346205) Subscribing to states...
                    2023-12-18 14:23:02.022  - info: iqontrol.0 (346205) iQontrol ready.
                    2023-12-18 14:25:00.016  - info: host.iobroker1 instance system.adapter.dwd.0 started with pid 350964
                    2023-12-18 14:25:00.865  - info: dwd.0 (350964) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:01.343  - info: dwd.0 (350964) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-12-18 14:25:01.854  - info: host.iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    • A Alveran
                      Errors in npm tree:
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: vm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 2
                                    NTP service: active
                                RTC in local TZ: no
                      alveran
                      /home/alveran
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           2.0G          0B        2.0G
                               5929 M total memory
                               2212 M used memory
                                568 M active memory
                               2735 M free memory
                                152 M buffer memory
                                829 M swap cache
                               2045 M total swap
                                  0 M used swap
                               2045 M free swap
                      *** FILESYSTEM ***
                      /var:
                      844M    /var/
                      448M    /var/cache
                      439M    /var/cache/apt
                      253M    /var/log
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: redis
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        14918
                      States:         14498
                      Pending Updates: 0
                      xmlbuilder@0.4.2
                      Da musst du mal schauen wo der liegt:
                      cd /opt/iobroker/ && npm ls xmlbuilder
                      Die Version ist allerdings steinalt. In meinem System spukt eine xmlbuilder@11.0.1 herum.
                        xmlbuilder@0.4.2
                        Alveran
                        Da kommt folgendes:
                        alveran@iobroker1:/opt/iobroker$ cd /opt/iobroker/ && npm ls xmlbuilder
                        iobroker.inst@1.1.1 /opt/iobroker
                        ├─┬ iobroker.hm-rega@4.0.0
                        │ └─┬ xml2js@0.6.2
                        │   └── xmlbuilder@11.0.1
                        ├─┬ iobroker.hm-rpc@1.15.19
                        │ └─┬ homematic-xmlrpc@1.0.2
                        │   └── xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                        ├─┬ iobroker.tr-064@4.2.18
                        │ └─┬ xml2js@0.4.23
                        │   └── xmlbuilder@11.0.1 deduped
                        └─┬ iobroker.yahka@1.0.3
                          └─┬ hap-nodejs@0.11.1
                            └─┬ @homebridge/dbus-native@0.5.1
                              └─┬ xml2js@0.5.0
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-18T13_45_23_610Z-debug-0.log
                        • A Alveran
                          Da kommt folgendes:
                          │ └─┬ xml2js@0.6.2
                          │ └─┬ xml2js@0.4.23
                                └─┬ xml2js@0.5.0
                          Alveran
                          schrieb am zuletzt editiert von Alveran
                          Besser?
                          alveran@iobroker1:/opt/iobroker$ npm install xmlbuilder
                          added 3 packages, and changed 2 packages in 5s
                          │ └─┬ xml2js@0.6.2
                          │ └─┬ xml2js@0.4.23
                          ├─┬ iobroker.yahka@1.0.3
                          │ └─┬ hap-nodejs@0.11.1
                          │   └─┬ @homebridge/dbus-native@0.5.1
                          │     └─┬ xml2js@0.5.0
                          └── xmlbuilder@15.1.1
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                     Chassis: vm
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           14:50:28 up  3:11,  2 users,  load average: 0.19, 0.16, 0.18
                          CPU threads: 2
                                         Local time: Mon 2023-12-18 14:50:28 CET
                                     Universal time: Mon 2023-12-18 13:50:28 UTC
                                           RTC time: Mon 2023-12-18 13:50:28
                                        NTP service: active
                                    RTC in local TZ: no
                          alveran
                          /home/alveran
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            5.9G        2.4G        2.6G        0.0K        987M        3.3G
                          Swap:           2.0G          0B        2.0G
                          Total:          8.0G        2.4G        4.6G
                                   5929 M total memory
                                   2363 M used memory
                                    547 M active memory
                                   2471 M inactive memory
                                   2578 M free memory
                                    154 M buffer memory
                                    832 M swap cache
                                   2045 M total swap
                                      0 M used swap
                                   2045 M free swap
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     593M  692K  593M   1% /run
                          /var:
                          844M    /var/
                          448M    /var/cache
                          439M    /var/cache/apt
                          253M    /var/log
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        14918
                          States:         14472
                          Hit:2 http://ftp.debian.org/debian bullseye-backports InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Hit:6 https://repo.ebusd.eu/apt/default/bullseye bullseye InRelease
                          Pending Updates: 0
                          2023-12-18 14:30:00.013  - info: host.iobroker1 instance system.adapter.ical.0 started with pid 362900
                          2023-12-18 14:30:00.988  - info: ical.0 (362900) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:30:02.187  - info: ical.0 (362900) processing URL: calendar1 https://calendar.google.com/calendar/ical/goeran.kickeritz%40googlemail.com/private-e54d67ed3f8efee7b8046752033283ed/basic.ics
                          2023-12-18 14:30:07.430  - info: ical.0 (362900) Terminated (NO_ERROR): Without reason
                          2023-12-18 14:30:07.944  - info: host.iobroker1 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          2023-12-18 14:35:06.953  - info: admin.0 (344064) <== Disconnect system.user.admin from ::ffff:192.168.6.182 admin
                          2023-12-18 14:35:13.209  - info: admin.0 (344064) <== Disconnect system.user.admin from ::ffff:192.168.6.182
                          • A Alveran
                            Besser?
                            │ └─┬ xml2js@0.6.2
                            │ └─┬ xml2js@0.4.23
                            │     └─┬ xml2js@0.5.0
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                       Chassis: vm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 2
                                          NTP service: active
                                      RTC in local TZ: no
                            alveran
                            /home/alveran
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           2.0G          0B        2.0G
                                     5929 M total memory
                                     2363 M used memory
                                      547 M active memory
                                     2578 M free memory
                                      154 M buffer memory
                                      832 M swap cache
                                     2045 M total swap
                                        0 M used swap
                                     2045 M free swap
                            *** FILESYSTEM ***
                            /var:
                            844M    /var/
                            448M    /var/cache
                            439M    /var/cache/apt
                            253M    /var/log
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        14918
                            States:         14472
                            Pending Updates: 0
                            Besser?
                            Nein. Falsches Verzeichnis.
                            Installier den iobroker.hm-rpc nochmal. Wenn das nicht falsch eingetragen wurde müsste der Kram dann eigentlich neu geladen werden.
                              Alveran
                              Das kann ich jetzt leider auf die schnelle nicht machen. Da hängt meine ganze Automatisierung dran und ich bin viele 100km entfernt. Ist das schlimm mit dem falschen Verzeichnis?
                              • A Alveran
                                @alveran
                                Kratz das Modul halt wieder raus.
                                  @alveran
                                  Alveran
                                  @alveran
                                  • A Alveran
                                    @alveran
                                    @alveran
                                    Halt so wieder rauskratzen, wie du es auch reingedonnert hast. Nur mit uninstall halt.
                                    npm uninstall MODULNAME
