  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 328.0k Aufrufe 63 Beobachtet
    ma
    #634
    $ iobroker upgrade parser@2.0.7
    Update parser from @1.3.2 to @2.0.7
    Installing iobroker.parser@2.0.7... (System call)
    npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/ursa-optional/node_modules/bindingsnpm ERR! dest /opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ursa-optional/node_modules/bindings' -> '/opt/iobroker/node_modules/ursa-optional/node_modules/.bindings-4WLiqHNJ'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_07_22_021Z-debug-0.log
    host.iobroker Cannot install iobroker.parser@2.0.7: 217
    ERROR: Process exited with code 25
      ma
      #635
      sonos update nochmal mit debug
      iobroker upgrade sonos —debug
      This upgrade of "sonos" will introduce the following changes:
      -> 3.0.0:
      Added support for the playing Sonos playlists (added new state `playlist_set`)
      The minimal node.js version is 16
      -> 2.3.3:
      fixed cover url
      -> 2.3.2:
      store the cover file in files instead of binary states
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade sonos from @2.3.1 to @3.0.0 now? [(y)es, (n)o]: y
      Update sonos from @2.3.1 to @3.0.0
      NPM version: 9.8.1
      Installing iobroker.sonos@3.0.0... (System call)
      Try to solve ENOTEMPTY error automatically
      host.iobroker deleted npm temp directory: ".bindings-4WLiqHNJ")
      npm ERR! path /opt/iobroker/node_modules/@75lb/deep-merge
      npm ERR! dest /opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@75lb/deep-merge' -> '/opt/iobroker/node_modules/@75lb/.deep-merge-EwaPBSLA'
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-18T02_24_19_780Z-debug-0.log
      host.iobroker Cannot install iobroker.sonos@3.0.0: 217```
        ma
        #636
        habe den fixer nochmal durchlaufen lassen danach nochmal das update von sonos und sonoff gestartet.
        Danach ist der iobroker garnicht mehr gestartet, konnte ich lösen indem ich den PC neugestartet habe.
        Nun starten die adapter garnicht mehr.
        sonoff.0 2023-11-19 02:44:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        sonoff.0 2023-11-19 02:44:31.857	info	terminating
        sonoff.0 2023-11-19 02:44:31.839	error	Cannot read properties of undefined (reading 'length')
        sonoff.0 2023-11-19 02:44:31.838	error	TypeError: Cannot read properties of undefined (reading 'length') at decrypt (/opt/iobroker/node_modules/iobroker.sonoff/main.js:25:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sonoff/main.js:43:39) at processImmediate (node:internal/timers:478:21)
        sonoff.0 2023-11-19 02:44:31.837	error	uncaught exception: Cannot read properties of undefined (reading 'length')
        sonoff.0 2023-11-19 02:44:31.794	info	starting. Version 2.5.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v18.18.2, js-controller: 5.0.12
        sonos.0
        	2023-11-19 02:52:04.672	warn	State "sonos.0.root.192_168_170_7.favorites_list_html" has no existing object, this might lead to an error in future versions
        sonos.0
        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_5.favorites_list_html" has no existing object, this might lead to an error in future versions
        sonos.0
        	2023-11-19 02:52:04.671	warn	State "sonos.0.root.192_168_170_8.favorites_list_html" has no existing object, this might lead to an error in future versions
        sonos.0
        	2023-11-19 02:52:04.666	warn	State "sonos.0.root.192_168_170_5.current_track_number" has no existing object, this might lead to an error in future versions
        sonos.0
        	2023-11-19 02:52:04.646	error	Cannot getFavorites: TypeError: Cannot read properties of null (reading 'players')
        sonos.0
        	2023-11-19 02:52:04.638	warn	State "sonos.0.root.192_168_170_7.current_track_number" has no existing object, this might lead to an error in future versions
        sonos.0
        	2023-11-19 02:52:04.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        sonos.0
        	2023-11-19 02:52:04.622	info	terminating
        sonos.0
        	2023-11-19 02:52:04.617	info	terminating
        sonos.0
        	2023-11-19 02:52:04.614	error	sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:04.614	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35) at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:24) at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4809:31) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31) at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17) at SonosSystem.<anonymous> (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13) at SonosSystem.emit (node:events:517:28)
        sonos.0
        	2023-11-19 02:52:04.611	error	unhandled promise rejection: sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:04.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        sonos.0
        	2023-11-19 02:52:04.577	error	sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:04.577	error	Error: sonos is not an object of type "meta" at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39) at runNextTicks (node:internal/process/task_queues:60:5) at process.processImmediate (node:internal/timers:447:9) at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:824:13)
        sonos.0
        	2023-11-19 02:52:04.575	error	unhandled promise rejection: sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:04.575	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        sonos.0
        	2023-11-19 02:52:04.571	error	Cannot write file coverImage/192_168_170_5.png: sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:04.538	error	Cannot write file coverImage/192_168_170_7.png: sonos is not an object of type "meta"
        sonos.0
        	2023-11-19 02:52:03.470	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.18.2, js-controller: 5.0.12
        brauche dazu eine lösung.
        vor dem update auf node v18 gab es da nie probleme
        R 1 Antwort Letzte Antwort
        • M ma
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          sonos.0
          reutli
          schrieb am zuletzt editiert von reutli
          #637
          @ma sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
          und das gemacht und dann nochmals Update gestartet?
          und da mal reingeschaut?
          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
          *Wer freundlich ist, dem wird freundlich geholfen *
          • R reutli
            kkickingereder
            schrieb am zuletzt editiert von kkickingereder
            #638
            Könnt ihr mir helfen bitte, bin noch auf 16.15.1
            nach
            iob stop
            iob fix (schon 2x)
            iob nodejs-update
            bekomme ich folgend Fehlermeldung
            You are running nodejs v16.15.1. Do you want to install recommended version 18.19.0?
            Press <y> to continue or any other key to quit
            Trying to update your installation now. Please be patient.
            find: '/run/user/1000/gvfs': Permission denied
            Waiting for ioBroker to shut down - Give me a minute...
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
            W: Failed to fetch https://repos.influxdata.com/ubuntu/dists/bionic/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            E: Broken packages
            Installing the recommended nodejs version!
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            E: Broken packages
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            • K kkickingereder
              nach
              iob stop
              iob fix (schon 2x)
              iob nodejs-update
              E: Broken packages
              E: Broken packages
              #639
              @kkickingereder
              grafana und influx Repository müssen nochmal frisch angelegt werden.
              Das Ganze muss allerdings bereits geraume Zeit bei dir falsch laufen. Regelmäßiger das System pflegen!
              Und schalt den Desktop AUS!
              Und das google-Repo brauchst du vermutlich nicht.
              Alles rauswerfen, was nicht für den Serverbetrieb benötigt wird.
                @kkickingereder
                kkickingereder
                #640
                @thomas-braun vielen lieben Dank
                grafana und influx brauch ich eh nicht
                Hast du einen Tip wie ich sauber runter kriege?
                Was meinst du mit, schalt den Desktop aus?
                • K kkickingereder
                  #641
                  @kkickingereder
                  Poste mal on einem separaten Thread die Langfassung von
                  iob diag
                  Da scheint mir so einiges im Argen zu liegen.
                    @kkickingereder
                    iob diag
                    kkickingereder
                    #642
                    @thomas-braun oh oh 😖
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: iob-server
                             Icon name: computer-laptop
                               Chassis: laptop
                      Operating System: Ubuntu 18.04.4 LTS
                                Kernel: Linux 5.4.0-150-generic
                          Architecture: x86-64
                    model name	: Intel(R) Pentium(R) 3805U @ 1.90GHz
                    Docker          : false
                    Virtualization  : none
                    Kernel          : x86_64
                    Userland        : amd64
                    Systemuptime and Load:
                     16:46:43 up 89 days,  3:58,  2 users,  load average: 0.65, 0.74, 0.92
                    CPU threads: 2
                    *** Time and Time Zones ***
                                          Local time: Sun 2023-12-17 16:46:43 CET
                                      Universal time: Sun 2023-12-17 15:46:43 UTC
                                            RTC time: Sun 2023-12-17 15:46:43
                    systemd-timesyncd.service active: yes
                                     RTC in local TZ: no
                    *** User and Groups ***
                    iob
                    /home/iob
                    iob adm cdrom sudo dip plugdev lpadmin sambashare iobroker
                    *** X-Server-Setup ***
                    X-Server: 	true
                    Desktop:
                    Terminal:
                    Boot Target: 	graphical.target
                    *** MEMORY ***
                    Mem:           3.9G        2.9G        263M        1.7M        761M        768M
                    Swap:          2.1G        1.4G        733M
                    Total:         6.0G        4.3G        996M
                             3848 M total memory
                             2847 M used memory
                             2464 M active memory
                              752 M inactive memory
                              256 M free memory
                               96 M buffer memory
                              647 M swap cache
                             2047 M total swap
                             1331 M used swap
                              716 M free swap
                    *** FAILED SERVICES ***
                    0 loaded units listed. Pass --all to see loaded but inactive units, too.
                    To show all installed unit files use 'systemctl list-unit-files'.
                    *** FILESYSTEM ***
                    udev           devtmpfs  1.9G     0  1.9G   0% /dev
                    tmpfs          tmpfs     385M  2.0M  383M   1% /run
                    /dev/sda1      ext4       59G   30G   27G  53% /
                    tmpfs          tmpfs     1.9G  176K  1.9G   1% /dev/shm
                    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                    /dev/loop0     squashfs   74M   74M     0 100% /snap/core22/864
                    /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16091
                    /dev/loop4     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                    /dev/loop5     squashfs  1.5M  1.5M     0 100% /snap/gnome-system-monitor/184
                    /dev/loop6     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                    /dev/loop7     squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/90
                    /dev/loop9     squashfs  896K  896K     0 100% /snap/gnome-logs/119
                    /dev/loop15    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                    /dev/loop17    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/194
                    /dev/loop18    squashfs  128K  128K     0 100% /snap/bare/5
                    /dev/loop20    squashfs  219M  219M     0 100% /snap/gnome-3-34-1804/93
                    /dev/loop22    squashfs  165M  165M     0 100% /snap/gnome-3-28-1804/198
                    /dev/loop24    squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                    /dev/loop26    squashfs   64M   64M     0 100% /snap/core20/2015
                    tmpfs          tmpfs     385M   56K  385M   1% /run/user/1000
                    /dev/loop27    squashfs  497M  497M     0 100% /snap/gnome-42-2204/132
                    /dev/loop23    squashfs  896K  896K     0 100% /snap/gnome-logs/121
                    /dev/loop28    squashfs  512K  512K     0 100% /snap/gnome-characters/791
                    /dev/loop8     squashfs  497M  497M     0 100% /snap/gnome-42-2204/141
                    /dev/loop10    squashfs  512K  512K     0 100% /snap/gnome-characters/795
                    /dev/loop12    squashfs  2.3M  2.3M     0 100% /snap/gnome-calculator/953
                    /dev/loop2     squashfs  106M  106M     0 100% /snap/core/16202
                    /dev/loop3     squashfs  1.7M  1.7M     0 100% /snap/gnome-system-monitor/186
                    /dev/loop11    squashfs   56M   56M     0 100% /snap/core18/2796
                    /dev/loop21    squashfs  2.3M  2.3M     0 100% /snap/gnome-calculator/955
                    /dev/loop19    squashfs   56M   56M     0 100% /snap/core18/2812
                    /dev/loop16    squashfs   75M   75M     0 100% /snap/core22/1033
                    /dev/loop13    squashfs   64M   64M     0 100% /snap/core20/2105
                    findmnt: unrecognized option '--real'
                    Try 'findmnt --help' for more information.
                    /var:
                    9.4G	/var/
                    5.3G	/var/lib
                    4.6G	/var/lib/snapd
                    3.9G	/var/log/journal
                    3.9G	/var/log
                    Archived and active journals take up 3.5G in the file system.
                    /opt/iobroker/backups:
                    373M	/opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    666M	/opt/iobroker/iobroker-data/
                    321M	/opt/iobroker/iobroker-data/files
                    255M	/opt/iobroker/iobroker-data/backup-objects
                    67M	/opt/iobroker/iobroker-data/files/javascript.admin
                    48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    26M	/opt/iobroker/iobroker-data/states.jsonl
                    26M	/opt/iobroker/iobroker-data/objects.jsonl
                    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                    16M	/opt/iobroker/iobroker-data/objects.json.migrated
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs 	v16.15.1
                    /usr/bin/node 		v16.15.1
                    /usr/bin/npm 		8.11.0
                    /usr/bin/npx 		8.11.0
                    /usr/bin/corepack 	0.10.0
                    nodejs:
                      Installed: 16.15.1-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                         18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                     *** 16.15.1-1nodesource1 100
                         8.10.0~dfsg-2ubuntu0.4 500
                            500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                         8.10.0~dfsg-2ubuntu0.2 500
                            500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                         8.10.0~dfsg-2 500
                            500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller: 	5.0.17
                    admin: 		6.12.0
                    javascript: 	7.1.6
                    Adapters from github: 	2
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
                    + system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
                    + system.adapter.bmw.0                    : bmw                   : iob-server                               -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iob-server                               -  enabled
                      system.adapter.daswetter.0              : daswetter             : iob-server                               -  enabled
                    + system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
                      system.adapter.dwd.0                    : dwd                   : iob-server                               -  enabled
                    + system.adapter.dysonairpurifier.0       : dysonairpurifier      : iob-server                               -  enabled
                    + system.adapter.easee.0                  : easee                 : iob-server                               -  enabled
                    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-server                               -  enabled
                      system.adapter.feiertage.0              : feiertage             : iob-server                               -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : iob-server                               -  enabled
                    + system.adapter.hmip.0                   : hmip                  : iob-server                               -  enabled
                    + system.adapter.homeconnect.0            : homeconnect           : iob-server                               -  enabled
                    + system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
                    + system.adapter.hue.0                    : hue                   : iob-server                               -  enabled, port: 443
                      system.adapter.ical.0                   : ical                  : iob-server                               -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-server                               - disabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iob-server                               - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-server                               - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-server                               - disabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-server                               - disabled
                    + system.adapter.info.0                   : info                  : iob-server                               -  enabled
                    + system.adapter.iot.0                    : iot                   : iob-server                               -  enabled
                    + system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
                      system.adapter.mobile.0                 : mobile                : iob-server                               - disabled
                    + system.adapter.netatmo.0                : netatmo               : iob-server                               -  enabled
                    + system.adapter.nuki-extended.0          : nuki-extended         : iob-server                               -  enabled
                    + system.adapter.nuki.0                   : nuki                  : iob-server                               -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : iob-server                               -  enabled
                    + system.adapter.panasonic-viera.0        : panasonic-viera       : iob-server                               -  enabled
                    + system.adapter.ping.0                   : ping                  : iob-server                               -  enabled
                    + system.adapter.ring.0                   : ring                  : iob-server                               -  enabled
                    + system.adapter.simple-api.0             : simple-api            : iob-server                               -  enabled, port: 8087, run as: admin
                    + system.adapter.smart-eq.0               : smart-eq              : iob-server                               -  enabled
                    + system.adapter.socketio.0               : socketio              : iob-server                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      system.adapter.spotify-premium.0        : spotify-premium       : iob-server                               - disabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-server                               -  enabled
                    + system.adapter.telegram.0               : telegram              : iob-server                               -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : iob-server                               -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : iob-server                               - disabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-server                               - disabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-server                               - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-server                               - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iob-server                               - disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-server                               -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-server                               - disabled
                      system.adapter.vis-knob.0               : vis-knob              : iob-server                               - disabled
                      system.adapter.vis-material.0           : vis-material          : iob-server                               - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-server                               - disabled
                      system.adapter.vis-metro.0              : vis-metro             : iob-server                               - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-server                               - disabled
                      system.adapter.vis-weather.0            : vis-weather           : iob-server                               - disabled
                      system.adapter.vis.0                    : vis                   : iob-server                               -  enabled
                    + system.adapter.web.0                    : web                   : iob-server                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.worx.0                   : worx                  : iob-server                               -  enabled
                    + system.adapter.yahka.0                  : yahka                 : iob-server                               -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                    Adapter    "bmw"          : 2.5.7    , installed 2.6.0
                    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                    Adapter    "dysonairpurifier": 2.5.9 , installed 2.5.9
                    Adapter    "easee"        : 1.0.10   , installed 1.0.10
                    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                    Adapter    "hue"          : 3.10.1   , installed 3.10.1
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                    Adapter    "ring"         : 5.0.10   , installed 3.2.2  [Updatable]
                    Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
                    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 6.1.10   , installed 6.1.10
                    Adapter    "worx"         : 2.3.4    , installed 2.3.4
                    Adapter    "ws"           : 2.5.8    , installed 2.5.8
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Objects and States
                    Objects: 	36971
                    States: 	29630
                    Get:1 http://dl.google.com/linux/chrome/deb stable InRelease [1825 B]
                    Hit:2 http://de.archive.ubuntu.com/ubuntu bionic InRelease
                    Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
                    Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                    Get:5 https://repos.influxdata.com/ubuntu bionic InRelease [7047 B]
                    Hit:6 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:8 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
                    Err:1 http://dl.google.com/linux/chrome/deb stable InRelease
                    Err:4 https://packages.grafana.com/oss/deb stable InRelease
                    Err:5 https://repos.influxdata.com/ubuntu bionic InRelease
                    Fetched 7047 B in 1s (5895 B/s)
                    Reading package lists...
                    Pending Updates: 100
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       81137075   2865/iobroker.js-co
                    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      125        28671      824/mysqld
                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      123        28780      791/redis-server 12
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          22257      456/rpcbind
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22287      459/systemd-resolve
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          81096893   783/sshd
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          80457378   29056/cupsd
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        34230      1402/influxd
                    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          29805      663/python
                    tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          28902      766/anydesk
                    tcp        0      0 127.0.0.1:40007         0.0.0.0:*               LISTEN      1001       81147331   4068/io.yahka.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       81137082   2865/iobroker.js-co
                    tcp6       0      0 ::1:6379                :::*                    LISTEN      123        28781      791/redis-server 12
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          22260      456/rpcbind
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       81137183   2884/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       81146340   4035/io.web.0
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       81147056   3985/io.socketio.0
                    tcp6       0      0 :::51989                :::*                    LISTEN      1001       81147932   4175/io.nuki-extend
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          81096895   783/sshd
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        34678      1402/influxd
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       81147008   3967/io.simple-api.
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          80457377   29056/cupsd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      124        34587      1407/grafana-server
                    tcp6       0      0 :::35107                :::*                    LISTEN      1001       81146436   4068/io.yahka.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22286      459/systemd-resolve
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          81095893   28837/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          22255      456/rpcbind
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          80457386   29057/cups-browsed
                    udp        0      0 0.0.0.0:632             0.0.0.0:*                           0          22256      456/rpcbind
                    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          28903      766/anydesk
                    udp        0      0 192.168.0.20:5353       0.0.0.0:*                           1001       81138845   3067/io.tr-064.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        25090      656/avahi-daemon: r
                    udp        0      0 0.0.0.0:48439           0.0.0.0:*                           116        25092      656/avahi-daemon: r
                    udp6       0      0 :::48975                :::*                                116        25093      656/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          22258      456/rpcbind
                    udp6       0      0 :::632                  :::*                                0          22259      456/rpcbind
                    udp6       0      0 :::5353                 :::*                                116        25091      656/avahi-daemon: r
                    2023-12-17 16:39:37.301  - info: admin.0 (2884) ==> Connected system.user.admin from ::ffff:192.168.0.32
                    2023-12-17 16:39:39.585  - info: host.iob-server Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2023-12-17 16:47:37.193  - error: bmw.0 (3115) update  failed
                    2023-12-17 16:47:37.196  - error: bmw.0 (3115) AxiosError: Request failed with status code 403
                    2023-12-17 16:47:37.196  - error: bmw.0 (3115) {"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:12:23."}
                    iob diag has finished.
                    • K kkickingereder
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: laptop
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 2
                                       RTC in local TZ: no
                      iob
                      /home/iob
                      X-Server: 	true
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                               3848 M total memory
                               2847 M used memory
                                256 M free memory
                                 96 M buffer memory
                                647 M swap cache
                               2047 M total swap
                               1331 M used swap
                                716 M free swap
                      *** FILESYSTEM ***
                      /var:
                      9.4G	/var/
                      5.3G	/var/lib
                      4.6G	/var/lib/snapd
                      3.9G	/var/log
                      USB-Devices by-id:
                      /usr/bin/npm 		8.11.0
                      /usr/bin/npx 		8.11.0
                      nodejs:
                        Version table:
                           8.10.0~dfsg-2 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin: 		6.12.0
                      javascript: 	7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	36971
                      States: 	29630
                      #643
                      @kkickingereder
                      Ubuntu 18.irgendwas ist tot.
                      Brauch ich gar nicht weiterlesen.
                      Installier da was lebendes.
                      Ich würde ein Debian 12 'Bookworm' empfehlen.
                      Als Server dann natürlich OHNE Desktop-Umgebung.
                      S R 2 Antworten Letzte Antwort
                        @kkickingereder
                        skorpil
                        #644
                        @thomas-braun auch wenn es hier nicht direkt hinpasst: ich bin auf debian bullseye. Ich sollte auf bookworm… Hier im Forum hast Du irgendwo geschrieben, man solle das System komplett neu aufsetzen. Das wäre für mich als Linux Dummy ein Wahnsinn. Gilt Dein Hinweis auf komplette Neuinstallation nur für Raspian Installationen auf einem Raspi? Oder auch für Debian Installationen? Bei mir läuft der Iob in einer VM unter Oracle Virtual Box sehr gut, bisher…
                          @kkickingereder
                          reutli
                          #645
                          @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                          @kkickingereder
                          oder wenn es unbedingt Ubuntu sein/bleiben muss (warum auch immer), dann kannste ein 'in place' update im Zwei-Schritt-Verfahren, wie hier: https://doku.lrz.de/upgrade-auf-ubuntu-22-04-lts-jammy-11491296.html beschrieben versuchen...
                          @Thomas-Braun hat aber grundsätzlich (wie immer 😀 ) Recht: Bookworm wäre das am besten unterstütze OS.
                          • S skorpil
                            #646
                            @skorpil sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                            Ja , gilt primär für die Installation von Raspberry OS 12 'Bookworm'.
                            Bei Debian waren die Änderungen nicht so gravierend wie bei Raspberry OS.
                            • R reutli
                              @kkickingereder
                              #647
                              @reutli
                              Wenn die das wie bei Schnubbibuntu üblich schon alles vom Server geräumt haben wird das mit einem Dist-Upgrade schwierig.
                              Die Repos müssen aber so oder so aufgeräumt werden. Und der ganze Desktop-Krampf rumpelt dann auch immer noch mit.
                              Ich würde die Zeit sinnvoller in eine Neuinstallation von Debian investieren.
                                @reutli
                                reutli
                                #648
                                Volle Zustimmung!
                                Mist, siehst nicht dran gedacht, dass das oft genug das Problem ist!
                                Habe ohnehin meine Versuche auf Ubuntu und irgendwelchen "Versucherli's" ebenfalls eingestellt.
                                Ordentliches Backup und Doku, Neuinstallation und schwups alles wieder i.O.
                                Die meisten (nicht Linux affinen) Leute haben aber wahnsinnige Angst vor Neuinstallationen...
                                @kkickingereder Du machst Dir das Leben mit einer ordentlichen Debian bookworm Installation definitiv leichter!
                                  skorpil
                                  #649
                                  Danke Thomas. Ich bin aber jetzt erst, beim Lesen dieses ganzen threats, darauf gekommen, dass es einen Unterschied macht, ob man Debian oder Raspberry OS installiert hat.
                                  Hier mal der summary von iob diag
                                                          v.2023-10-10
                                     Static hostname: LinuxNeu
                                           Icon name: computer-vm
                                             Chassis: vm
                                      Virtualization: oracle
                                    Operating System: Debian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 5.10.0-25-amd64
                                  Installation:           oracle
                                  Kernel:                 x86_64
                                  Userland:               amd64
                                  Timezone:               Europe/Berlin (CET, +0100)
                                  User-ID:                1000
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Pending iob updates:    0
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                          /usr/bin/node           v18.19.0
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                                          /usr/bin/corepack       0.22.0
                                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                  MEMORY:
                                  Mem:            3.9G        2.0G        331M        0.0K        1.6G        1.7G
                                  Swap:           974M         28M        946M
                                  Total:          4.9G        2.0G        1.3G
                                  Active iob-Instances:   15
                                  ioBroker Core:          js-controller           5.0.17
                                                          admin                   6.12.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : LinuxNeu                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  Objects:                16217
                                  States:                 13635
                                  Size of iob-Database:
                                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                                  11M     /opt/iobroker/iobroker-data/objects.json.migrated
                                  11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  0       /opt/iobroker/iobroker-data/objects.json.broken
                                  5.3M    /opt/iobroker/iobroker-data/states.jsonl
                                  1.6M    /opt/iobroker/iobroker-data/states.json.migrated
                                  1.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  0       /opt/iobroker/iobroker-data/states.json.broken
                                  Anregung (oder habe da was übersehen): könntet ihr Profis noch irgendwo mal eine Schritt für Schritt Anleitung zum Update auf Bookworm posten? Und dabei vielleicht die unterschiedlichen Systeme berücksichtigen. Ich hab das zumindest so nicht gefunden.
                                  • S skorpil
                                                            v.2023-10-10
                                               Chassis: vm
                                    Kernel:                 x86_64
                                    Userland:               amd64
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            10.2.3
                                                            /usr/bin/npx            10.2.3
                                    MEMORY:
                                    Swap:           974M         28M        946M
                                                            admin                   6.12.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                16217
                                    States:                 13635
                                    #650
                                    Schau in meine Threads rein. Hab ich mal irgendwann beschrieben.
                                      skorpil
                                      #651
                                      @thomas-braun aber war das nicht ausschließlich raspian bezogen?
                                      • S skorpil
                                        #652
                                        @skorpil
                                        Nein, es ist allgemein auf ein Upgrade auf Bookworm bezogen. Zu Raspberry OS steht sogar drin, dass man das dieses Mal besser komplett neuinstalliert.
                                        https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                                          @skorpil
                                          skorpil
                                          #653
                                          @thomas-braun sorry, dann hatte ich nicht gut gelesen. Danke u. frohe Weihnachten u. DANKE für gute Beratung u. Betreuung von uns allen!
                                          W 1 Antwort Letzte Antwort
