  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
    2.8k
    2.9k
120 Beiträge 4 Kommentatoren 15.0k Aufrufe 2 Beobachtet
  • R Radix75
    @homoran said in Daikin Adapter:
    @mcm57 sagte in Daikin Adapter:
    könnte es ein wenig älter sein.
    so was schwebte mir vor
    Erst mal das System aktualisisern - dann kannst du über den Daikin Adapter nachdenken
    Ich würde deswegen gerne den aktuellen Status sehen.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     18:04:49 up 50 days, 23:10,  2 users,  load average: 2.42, 5.83, 7.14
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Wed 2023-12-13 18:04:49 CET
               Universal time: Wed 2023-12-13 17:04:49 UTC
                     RTC time: Wed 2023-12-13 17:04:50
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           3.8G        1.3G        1.7G        211M        743M        2.2G
    Swap:           99M         58M         41M
    Total:         3.9G        1.4G        1.8G
             3787 M total memory
             1298 M used memory
              367 M active memory
             1445 M inactive memory
             1745 M free memory
              140 M buffer memory
              603 M swap cache
               99 M total swap
               58 M used swap
               41 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * dhcpcd.service loaded failed failed dhcpcd on all interfaces
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   27G   30G  48% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  175M  1.7G  10% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     379M  4.0K  379M   1% /run/user/1000
    [Mon Oct 23 19:54:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:49:AE:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2fef1976-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Oct 23 19:54:16 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Mon Oct 23 19:54:16 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted
    [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 23 19:54:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Oct 23 19:54:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/var/lib/lxcfs      lxcfs          fuse.lxcfs      rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    4.9G	/var/
    3.7G	/var/cache/apt/archives
    3.7G	/var/cache/apt
    3.7G	/var/cache
    739M	/var/lib
    Archived and active journals take up 173.7M in the file system.
    /opt/iobroker/backups:
    9.6G	/opt/iobroker/backups/
    4.0K	/opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    625M	/opt/iobroker/iobroker-data/
    462M	/opt/iobroker/iobroker-data/files
    120M	/opt/iobroker/iobroker-data/files/javascript.admin
    102M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    101M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    18M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.3257a139.chunk.js.map
    12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
    9.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    9.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    8.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v14.21.3
    /usr/bin/node 		v14.21.3
    /usr/bin/npm 		6.14.18
    /usr/bin/npx 		6.14.18
    /usr/bin/corepack 	0.15.1
    nodejs:
      Installed: 14.21.3-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
     *** 14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    Radix75
    schrieb am zuletzt editiert von Radix75
    So welche schritte muss ich jetzt ausführen für ein aktuelles System ?
    • R Radix75
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Swap:           99M         58M         41M
               3787 M total memory
               1298 M used memory
                367 M active memory
               1745 M free memory
                140 M buffer memory
                603 M swap cache
                 99 M total swap
                 58 M used swap
                 41 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.9G	/var/
      3.7G	/var/cache/apt
      3.7G	/var/cache
      739M	/var/lib
      USB-Devices by-id:
      nodejs:
        Version table:
      Errors in npm tree:
      @radix75 sagte in Daikin Adapter:
      was hängt alles am USB?
      Das Netzteil ist zu schwach!
      Das Dateisystem hat Treffer abbekommen
      Niemals per Stecker raus "abschalten"!
      wie befürchtet vollkommen veraltet
      zum Desktop auf einem Server sag ich jetzt nichts
      und da fehlt noch mehr als die Hälfte
      R 1 Antwort Letzte Antwort
        Radix75
        @homoran Usb :_ Tastatur mit Bel. ist derzeit aus , Optische Maus sowie ein Deconz 2 Stick und ein Kartenleser für SD karten ähnlich dem Bild 046f8c49-996c-4314-9d4e-003c047be6e5-image.png für die Sicherung
        Netzteil https://www.amazon.de/gp/product/B0B4NPDDTF/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
        Fehler durch unterbrechen der Spannungsversorgung da ich leider keine USV habe und der Gruppen FI von Stromkreis gekommen ist
        • R Radix75
          Netzteil
          dann reicht das wohl nicht.
          besser aktiven Hub nehmen wenn da so vieles Strom zieht.
          und was ist mit dem Rest von diag?
          @homoran sagte in Daikin Adapter:
          • R Radix75
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Current issues:
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server: 	true
            Desktop: 	LXDE-pi
            Terminal: 	x11
            *** MEMORY ***
            Swap:           99M         58M         41M
                     3787 M total memory
                     1298 M used memory
                      367 M active memory
                     1745 M free memory
                      140 M buffer memory
                      603 M swap cache
                       99 M total swap
                       58 M used swap
                       41 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            4.9G	/var/
            3.7G	/var/cache/apt
            3.7G	/var/cache
            739M	/var/lib
            USB-Devices by-id:
            nodejs:
              Version table:
            Errors in npm tree:
            @radix75
            Installier da neu ein Debian 12 'Bookworm' / 64Bit Lite.
              Netzteil
              Radix75
              @homoran was meinst Du mit dem Rest von diag ? Ich habe alles kopiert was in der
              raspberry Kommandozeile als Antwort kam.
              Thomas Braun MOST ACTIVE 9 minutes ago
              @radix75
              Ich komme mit Lite Versionen ohne Grafische Oberfläche nicht klar da sich auf dem System auch mein 73 Jähriger Vater zurecht finden muss.
              Mir währe eine Reparatur und ein Update viel lieber für die Einrichtung der Raspberry und Iobroker sowie Deconz habe ich damals mehrere Tage benötigt
              HomoranH Thomas BraunT 4 Antworten Letzte Antwort
              • R Radix75
                @radix75
                da wäre noch viel mehr gekommen.
                Wahrscheinlich hast du eine Atempause für das Ende gehalten.
                und was gibt es da zu sehen?
                sind doch nur Daten und Dateien drauf.
                ...und 73 ist kein Alter!
                • R Radix75
                  @radix75
                  dafür hast du ja Backups.
                  und bitte nichts nachträglich hinzufügen!
                    Radix75
                    @homoran so also wie nun weiter? Meine Rasperry macht gerade sudo apt upgrade
                    bekomme ich die Dateifehler irgendwie behoben ??? 7 orphan inodes deleted
                    • R Radix75
                      das vollständige iob diag nach den updates posten.
                      nein.
                      Das schlimme daran ist, dass man nicht weiss wo diese Dateiwaisen jetzt fehlen
                      Da wäre wirklich ein Neuaufbau mit anschließendem Restore des letzten Backups der sinnvollste Weg.
                      • R Radix75
                        @radix75
                        Macht keinen Sinn, weil ein 32Bit-System nicht auf 64Bit gebracht werden kann.
                        • R Radix75
                          @radix75
                          Die Handvoll Linux-Kommandos sollte man sich draufschaffn können.
                          • R Offline
                            Radix75
                            @thomas-braun ok also wenn ich jetzt npm 6. update und node 18. drauf mache sind die Fehler noch da ???
                            Hätte dann mein 32 Bit System mit einem 64 Bit System überspielt ???
                            Die Raspberry macht noch das pivccu Update
                            • R Radix75
                              npm wird gar nicht separat auf irgendwas geupdated, das kommt IMMER im Paket nodejs mit.
                              iob nodejs-update
                              Und Buster ist dann immer noch tot. Du wirst nicht umhin kommen die Kiste zu aktualisieren. Dann kann man es aber auch gleich gescheit machen.
                              • R Radix75
                                @radix75
                                Und zeig mal die vollständige Langfassung von
                                iob diag
                                  @radix75
                                  iob diag
                                  Radix75
                                  @thomas-braun opy text starting here:
                                  			v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm
                                  Installation: 		native
                                  Kernel: 		armv7l
                                  Userland: 		armhf
                                  Timezone: 		Europe/Berlin (CET, +0100)
                                  User-ID: 		1000
                                  X-Server: 		true
                                  Pending OS-Updates: 	0
                                  Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                                  Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                                  Pending iob updates: 	0
                                  This system needs to be REBOOTED NOW!
                                  Nodejs-Installation: 	/usr/bin/nodejs 	v14.21.3
                                  Recommended versions are nodejs  and npm
                                  MEMORY:
                                  Mem:           3.8G        1.9G        785M        174M        1.1G        1.7G
                                  Swap:           99M         99M          0B
                                  Total:         3.9G        2.0G        785M
                                  Active iob-Instances: 	41
                                  Active repo(s): stable
                                  ioBroker Core: 		js-controller 		4.0.21
                                  			admin 			5.3.1
                                  ioBroker Status: 	iobroker is running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects: 		9350
                                  States: 		7445
                                  Size of iob-Database:
                                  13M	/opt/iobroker/iobroker-data/objects.jsonl
                                  8.2M	/opt/iobroker/iobroker-data/objects.json.migrated
                                  8.2M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  13M	/opt/iobroker/iobroker-data/states.jsonl
                                  1.7M	/opt/iobroker/iobroker-data/states.json.migrated
                                  1.7M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                                  Thomas BraunT 3 Antworten Letzte Antwort
                                  • R Radix75
                                    			v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm
                                    Kernel: 		armv7l
                                    Userland: 		armhf
                                    User-ID: 		1000
                                    X-Server: 		true
                                    MEMORY:
                                    Swap:           99M         99M          0B
                                    			admin 			5.3.1
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		9350
                                    States: 		7445
                                    @radix75
                                    Ist nicht vollständig...
                                    • R Radix75
                                      			v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm
                                      Kernel: 		armv7l
                                      Userland: 		armhf
                                      User-ID: 		1000
                                      X-Server: 		true
                                      MEMORY:
                                      Swap:           99M         99M          0B
                                      			admin 			5.3.1
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects: 		9350
                                      States: 		7445
                                      Tu das!
                                        @radix75
                                        Radix75
                                        @thomas-braun said in Daikin Adapter:
                                        @radix75
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm
                                        Docker          : false
                                        Kernel          : armv7l
                                        Userland        : armhf
                                         20:01:59 up 51 days,  1:07,  2 users,  load average: 3.98, 3.66, 3.98
                                        CPU threads: 4
                                        Current issues:
                                        ~ Arm frequency capping has occurred
                                        ~ Throttling has occurred
                                        ~ Soft temperature limit has occurred
                                        This system needs to be REBOOTED!
                                                       Local time: Wed 2023-12-13 20:01:59 CET
                                                   Universal time: Wed 2023-12-13 19:01:59 UTC
                                                         RTC time: Wed 2023-12-13 19:01:59
                                        System clock synchronized: no
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server: 	true
                                        Desktop: 	LXDE-pi
                                        Terminal: 	x11
                                        *** MEMORY ***
                                        Mem:           3.8G        2.0G        678M        174M        1.1G        1.6G
                                        Swap:           99M         99M          0B
                                        Total:         3.9G        2.1G        678M
                                                 3787 M total memory
                                                 2025 M used memory
                                                  588 M active memory
                                                 2246 M inactive memory
                                                  678 M free memory
                                                  192 M buffer memory
                                                  891 M swap cache
                                                   99 M total swap
                                                   99 M used swap
                                                    0 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        * deconz-wifi.service loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
                                        2 loaded units listed. Pass --all to see loaded but inactive units, too.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G   27G   29G  49% /
                                        tmpfs          tmpfs     1.9G  183M  1.7G  10% /run
                                        [Wed Dec 13 19:48:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                        /var:
                                        du: cannot access '/var/lib/lxcfs/cgroup/cpu,cpuacct/system.slice/nodered.service': No such file or directory
                                        5.5G	/var/
                                        4.4G	/var/cache/apt
                                        4.4G	/var/cache
                                        4.3G	/var/cache/apt/archives
                                        749M	/var/lib
                                        Archived and active journals take up 181.7M in the file system.
                                        641M	/opt/iobroker/iobroker-data/
                                        USB-Devices by-id:
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller: 	4.0.21
                                        admin: 		5.3.1
                                        javascript: 	5.2.21
                                        Adapters from github: 	4
                                        Adapter State
                                        + system.adapter.alexa2.1                 : alexa2                : raspberrypi                              -  enabled
                                        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                        + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
                                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                                          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                                        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                                        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                                        + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
                                          system.adapter.hue-extended.1           : hue-extended          : raspberrypi                              -  enabled
                                        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
                                        + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 443
                                        + system.adapter.i2c.0                    : i2c                   : raspberrypi                              -  enabled
                                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
                                        + system.adapter.iot.1                    : iot                   : raspberrypi                              -  enabled
                                        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                                          system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                                          system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                        + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                        + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.1.221 (SSL)
                                        + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
                                          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                        + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                                        + system.adapter.sia.0                    : sia                   : raspberrypi                              -  enabled, port: 50001, bind: 0.0.0.0
                                        + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
                                        + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
                                        + system.adapter.solax.1                  : solax                 : raspberrypi                              -  enabled
                                        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                        + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
                                        + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
                                          system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
                                          system.adapter.tr-064.4                 : tr-064                : raspberrypi                              -  enabled
                                        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                                        + system.adapter.velux.0                  : velux                 : raspberrypi                              -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
                                          system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
                                          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                        + system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 5.3.1    , installed 5.3.1
                                        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                        Adapter    "amazon-dash"  : 1.1.0    , installed 1.1.0
                                        Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                                        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                        Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                        Adapter    "cloud"        : 4.1.0    , installed 4.1.0
                                        Adapter    "daikin"       : 1.3.3    , installed 1.3.3
                                        Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
                                        Adapter    "deconz"       : 1.3.20   , installed 1.3.20
                                        Adapter    "devices"      : 1.0.9    , installed 1.0.9
                                        Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                                        Adapter    "firetv"       : 1.0.0    , installed 1.0.0
                                        Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                                        Adapter    "history"      : 1.10.5   , installed 1.10.5
                                        Adapter    "hm-rega"      : 3.0.39   , installed 3.0.39
                                        Adapter    "hm-rpc"       : 1.15.11  , installed 1.15.11
                                        Adapter    "hmip"         : 1.15.4   , installed 1.15.4
                                        Adapter    "hue"          : 3.6.5    , installed 3.6.5
                                        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                        Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                        Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                                        Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
                                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                        Adapter    "info"         : 1.9.8    , installed 1.9.8
                                        Adapter    "iot"          : 1.8.24   , installed 1.8.24
                                        Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
                                        Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                                        Controller "js-controller": 4.0.21   , installed 4.0.21
                                        Adapter    "meross"       : 1.10.1   , installed 1.10.1
                                        Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                        Adapter    "node-red"     : 2.4.2    , installed 2.4.2
                                        Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                                        Adapter    "ping"         : 1.5.0    , installed 1.5.0
                                        Adapter    "rpi2"         : 1.3.1    , installed 1.3.1
                                        Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                                        Adapter    "sia"          : 1.0.4    , installed 1.0.4
                                        Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                                        Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                                        Adapter    "socketio"     : 4.1.4    , installed 4.1.4
                                        Adapter    "solax"        : 0.3.7    , installed 0.3.7
                                        Adapter    "text2command" : 2.1.1    , installed 2.1.1
                                        Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
                                        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                        Adapter    "velux"        : 0.0.7    , installed 0.0.7
                                        Adapter    "vis"          : 1.4.5    , installed 1.4.5
                                        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                        Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                        Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                                        Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                        Adapter    "web"          : 4.2.0    , installed 4.2.0
                                        Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                        Adapter    "ws"           : 1.2.0    , installed 1.2.0
                                        Objects and States
                                        Objects: 	9350
                                        States: 	7445
                                        W: GPG error: https://apt.pivccu.de/piVCCU stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
                                        E: The repository 'https://apt.pivccu.de/piVCCU stable InRelease' is not signed.
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       710268300  12768/io.jarvis.0
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       20751      445/deCONZ
                                        tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       710261634  11645/io.sia.0
                                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        15943      415/systemd-resolve
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          711437637  30282/sshd
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          711439926  30859/cupsd
                                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       22096      445/deCONZ
                                        tcp        0      0 192.168.1.221:12002     0.0.0.0:*               LISTEN      1001       711473005  10727/io.hm-rpc.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       710249984  9627/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       710249977  9627/iobroker.js-co
                                        tcp        0      0 192.168.1.221:12010     0.0.0.0:*               LISTEN      1001       711480777  11259/io.hm-rpc.1
                                        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        15932      415/systemd-resolve
                                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          21754      780/vncserver-x11-c
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       710249260  9714/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       710270042  12661/io.web.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          711437639  30282/sshd
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          711439925  30859/cupsd
                                        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       710274458  11986/io.upnp.0
                                        tcp6       0      0 :::5355                 :::*                    LISTEN      102        15935      415/systemd-resolve
                                        tcp6       0      0 :::5900                 :::*                    LISTEN      0          21753      780/vncserver-x11-c
                                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        15942      415/systemd-resolve
                                        udp        0      0 0.0.0.0:44150           0.0.0.0:*                           1001       710994379  11423/io.broadlink2
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          711451900  30916/cups-browsed
                                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       710263244  11423/io.broadlink2
                                        udp        0      0 0.0.0.0:49876           0.0.0.0:*                           1001       710265501  11986/io.upnp.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        711440939  31347/avahi-daemon:
                                        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        15931      415/systemd-resolve
                                        udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       710261635  11645/io.sia.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       710271145  12987/io.deconz.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       710269968  11986/io.upnp.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       22803      445/deCONZ
                                        udp        0      0 0.0.0.0:34175           0.0.0.0:*                           108        711440941  31347/avahi-daemon:
                                        udp6       0      0 :::60452                :::*                                108        711440942  31347/avahi-daemon:
                                        udp6       0      0 :::5353                 :::*                                108        711440940  31347/avahi-daemon:
                                        udp6       0      0 :::5355                 :::*                                102        15934      415/systemd-resolve
                                        udp6       0      0 :::1900                 :::*                                1001       710271150  12987/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       710271149  12987/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       710271148  12987/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       710271147  12987/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       710271146  12987/io.deconz.0
                                        2023-12-13 20:04:47.297  - error: node-red.0 (31052) Error: Huejay: Request failed with status code 403
                                            at /opt/iobroker/iobroker-data/node-red/node_modules/huejay/lib/Transport.js:106:15
                                            at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                        2023-12-13 20:04:47.297  - error: node-red.0 (31052) Huejay: Request failed with status code 403
                                        2023-12-13 20:04:47.766  - info: node-red.0 (31052) terminating
                                        2023-12-13 20:04:47.767  - warn: node-red.0 (31052) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2023-12-13 20:04:48.320  - info: node-red.0 (9829) node-red exited with 6
                                        2023-12-13 20:04:51.421  - error: hue.0 (9964) connect EHOSTUNREACH 192.168.1.229:80
                                        2023-12-13 20:04:51.422  - warn: hue.0 (9964) Could not get configuration from HUE bridge (192.168.1.229:80)
                                        2023-12-13 20:04:51.878  - error: hue.1 (10446) Client network socket disconnected before secure TLS connection was established
                                        2023-12-13 20:04:51.879  - warn: hue.1 (10446) Could not get configuration from HUE bridge (192.168.1.221:443)
                                        2023-12-13 20:04:51.953  - error: hue.1 (10446) Could not poll all: Cannot read property 'configuration' of undefined
                                        2023-12-13 20:04:53.321  - info: node-red.0 (9829) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                        2023-12-13 20:04:56.913  - error: hue.1 (10446) Client network socket disconnected before secure TLS connection was established
                                        2023-12-13 20:04:56.917  - warn: hue.1 (10446) Could not get configuration from HUE bridge (192.168.1.221:443)
                                        2023-12-13 20:04:57.477  - error: hm-rpc.2 (29960) Init not possible, going to stop: response timeout
                                        2023-12-13 20:04:57.482  - info: hm-rpc.2 (29960) binrpc -> 192.168.1.220:2001/ init ["xmlrpc_bin://192.168.1.221:12001",""]
                                        2023-12-13 20:04:57.894  - info: host.raspberrypi instance system.adapter.tr-064.4 started with pid 32313
                                        2023-12-13 20:04:58.590  - info: hm-rpc.2 (29960) terminating
                                        2023-12-13 20:04:58.594  - info: hm-rpc.2 (29960) Terminated (NO_ERROR): Without reason
                                        2023-12-13 20:04:59.502  - info: hm-rpc.2 (29960) terminating with timeout
                                        2023-12-13 20:04:59.582  - error: hue.0 (9964) connect EHOSTUNREACH 192.168.1.229:80
                                        2023-12-13 20:04:59.583  - warn: hue.0 (9964) Could not get configuration from HUE bridge (192.168.1.229:80)
                                        2023-12-13 20:05:00.017  - info: host.raspberrypi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
                                        2023-12-13 20:05:00.018  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.2 because enabled
                                        iob diag has finished.
                                        Press any key for a summary
                                        • R Radix75
                                          			v.2023-10-10
                                                   Icon name: computer
                                                Architecture: arm
                                          Kernel: 		armv7l
                                          Userland: 		armhf
                                          User-ID: 		1000
                                          X-Server: 		true
                                          MEMORY:
                                          Swap:           99M         99M          0B
                                          			admin 			5.3.1
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		9350
                                          States: 		7445
                                          Ist bei 4GB UND dem mitrumpelnden Desktop-Quatsch auch zu viel. Dein SWAP läuft über.
                                          Load ist auch zu hoch...
