  4. *Gelöst* Adapter Install für Telegram funktioniert nicht.
31 Beiträge 2 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • B Bibo*13
    Ein anderer Adapter(Tuya) wird auch nicht installiert.
    Den Diag habe ich schon durchgeführt und im ersten Post mit angehängt. Der sah aber auch sauber aus.
    host.iobrokermaster
    2023-12-10 11:45:50.171	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    host.iobrokermaster
    2023-12-10 11:45:17.155	info	iobroker exit 0
    host.iobrokermaster
    2023-12-10 11:45:16.113	info	iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
    host.iobrokermaster
    2023-12-10 11:45:16.103	info	iobroker upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
    host.iobrokermaster
    2023-12-10 11:45:16.092	info	iobroker upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
    host.iobrokermaster
    2023-12-10 11:45:16.066	info	iobroker upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
    host.iobrokermaster
    2023-12-10 11:45:15.410	info	iobroker Update "system.adapter.tuya.0"
    host.iobrokermaster
    2023-12-10 11:45:15.183	info	iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-10T10_41_56_818Z-debug-0.log
    host.iobrokermaster
    2023-12-10 11:45:15.180	info	iobroker
    host.iobrokermaster
    2023-12-10 11:45:15.172	info	iobroker npm ERR! notsup Valid os: win32npm ERR! notsup Actual os: linuxnpm ERR! notsup Valid cpu: x64npm ERR! notsup Actual cpu: arm
    host.iobrokermaster
    2023-12-10 11:45:15.170	info	iobroker npm ERR! notsup Unsupported platform for @img/sharp-win32-x64@0.33.0: wanted {"os":"win32","cpu":"x64"} (current: {"os":"linux","cpu":"arm"})
    host.iobrokermaster
    2023-12-10 11:45:15.162	info	iobroker npm ERR! code EBADPLATFORM
    host.iobrokermaster
    2023-12-10 11:45:07.425	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    dwd.0
    2023-12-10 11:45:06.883	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    dwd.0
    2023-12-10 11:45:05.183	info	starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
    host.iobrokermaster
    2023-12-10 11:45:00.042	info	instance system.adapter.dwd.0 started with pid 29584
    host.iobrokermaster
    2023-12-10 11:41:55.613	info	iobroker NPM version: 10.2.3Installing iobroker.tuya@3.14.1... (System call)
    host.iobrokermaster
    2023-12-10 11:41:54.231	info	iobroker Update tuya from @3.14.2 to @3.14.1
    host.iobrokermaster
    2023-12-10 11:41:49.792	info	iobroker upgrade tuya@3.14.1 --debug
    @bibo-13
    iob diag
    in der Langfassung.
      @bibo-13
      iob diag
      in der Langfassung.
      Bibo*13
      @thomas-braun Here we are
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobrokermaster
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       12:07:03 up  2:25,  1 user,  load average: 1.97, 1.78, 1.65
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2023-12-10 12:07:03 CET
                 Universal time: Sun 2023-12-10 11:07:03 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        2.1G        4.8G        0.0K        948M        5.5G
      Swap:            99M          0B         99M
      Total:          8.0G        2.1G        4.9G
               7897 M total memory
               2101 M used memory
                377 M active memory
               2505 M inactive memory
               4847 M free memory
                154 M buffer memory
                794 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      110G   20G   86G  19% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  860K  1.6G   1% /run
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M   20K  790M   1% /run/user/1000
      [Sun Dec 10 09:41:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:EE:30:6C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Dec 10 09:41:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Dec 10 09:41:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Dec 10 09:41:51 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      4.9G    /var/
      3.9G    /var/cache
      3.8G    /var/cache/apt/archives
      3.8G    /var/cache/apt
      821M    /var/log
      Archived and active journals take up 808.0M in the file system.
      /opt/iobroker/backups:
      15M     /opt/iobroker/backups/
      2.8M    /opt/iobroker/backups/scripte
      2.4M    /opt/iobroker/backups/scripte/Meine_Geräte
      312K    /opt/iobroker/backups/scripte/Meine_Geräte/Temp_Ansagen
      284K    /opt/iobroker/backups/scripte/Test
      /opt/iobroker/iobroker-data:
      4.9G    /opt/iobroker/iobroker-data/
      4.2G    /opt/iobroker/iobroker-data/history
      454M    /opt/iobroker/iobroker-data/files
      191M    /opt/iobroker/iobroker-data/backup-objects
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.alexa2@3.26.3 /opt/iobroker/node_modules/iobroker.alexa2
      npm ERR! invalid: iobroker.cameras@1.3.0 /opt/iobroker/node_modules/iobroker.cameras
      npm ERR! invalid: iobroker.fully-tablet-control@0.3.6-1 /opt/iobroker/node_modules/iobroker.fully-tablet-control
      npm ERR! invalid: iobroker.homepilot20@0.0.32 /opt/iobroker/node_modules/iobroker.homepilot20
      npm ERR! invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
      npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
      npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
      npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder
      npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
      npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
      npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
      npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_13_165Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      admin:          6.12.0
      javascript:     7.1.6
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-10T11_07_36_329Z-debug-0.log
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.2                  : admin                 : iobrokermaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobrokermaster                           -  enabled
      + system.adapter.alexa2.1                 : alexa2                : iobrokermaster                           -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobrokermaster                           -  enabled
      + system.adapter.backitup.0               : backitup              : iobrokermaster                           -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobrokermaster                           -  enabled
        system.adapter.cloud.0                  : cloud                 : iobrokermaster                           - disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobrokermaster                           -  enabled
        system.adapter.discovery.0              : discovery             : iobrokermaster                           - disabled
        system.adapter.dwd.0                    : dwd                   : iobrokermaster                           -  enabled
      + system.adapter.echarts.0                : echarts               : iobrokermaster                           -  enabled
      + system.adapter.email.0                  : email                 : iobrokermaster                           -  enabled
        system.adapter.flot.0                   : flot                  : iobrokermaster                           -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobrokermaster                           -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobrokermaster                           -  enabled
        system.adapter.harmony.0                : harmony               : iobrokermaster                           - disabled
      + system.adapter.history.0                : history               : iobrokermaster                           -  enabled
      + system.adapter.homepilot20.0            : homepilot20           : iobrokermaster                           -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : iobrokermaster                           -  enabled
        system.adapter.hue.0                    : hue                   : iobrokermaster                           - disabled, port: 443
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokermaster                           -  enabled
      + system.adapter.info.0                   : info                  : iobrokermaster                           -  enabled
      + system.adapter.iot.0                    : iot                   : iobrokermaster                           -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobrokermaster                           -  enabled
      + system.adapter.javascript.0             : javascript            : iobrokermaster                           -  enabled
      + system.adapter.meross.0                 : meross                : iobrokermaster                           -  enabled
        system.adapter.mobile.0                 : mobile                : iobrokermaster                           - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobrokermaster                           -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : iobrokermaster                           - disabled
      + system.adapter.parser.0                 : parser                : iobrokermaster                           -  enabled
      + system.adapter.ping.0                   : ping                  : iobrokermaster                           -  enabled
      + system.adapter.psa.0                    : psa                   : iobrokermaster                           -  enabled
      + system.adapter.pushover.1               : pushover              : iobrokermaster                           -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobrokermaster                           -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobrokermaster                           -  enabled, port: 1893, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokermaster                           -  enabled
        system.adapter.starline.0               : starline              : iobrokermaster                           - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokermaster                           -  enabled
      + system.adapter.telegram.0               : telegram              : iobrokermaster                           -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobrokermaster                           -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobrokermaster                           -  enabled
        system.adapter.tuya.0                   : tuya                  : iobrokermaster                           - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokermaster                           -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokermaster                           -  enabled
        system.adapter.vis-history.0            : vis-history           : iobrokermaster                           -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokermaster                           -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokermaster                           -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokermaster                           -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokermaster                           -  enabled
        system.adapter.vis-map.0                : vis-map               : iobrokermaster                           -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokermaster                           -  enabled
        system.adapter.vis-material.0           : vis-material          : iobrokermaster                           -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokermaster                           -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobrokermaster                           -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokermaster                           -  enabled
        system.adapter.vis.0                    : vis                   : iobrokermaster                           -  enabled
      + system.adapter.web.0                    : web                   : iobrokermaster                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : iobrokermaster                           -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobrokermaster                           -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "parser"       : 2.0.7    , installed 2.0.7
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "psa"          : 0.0.11   , installed 0.0.12
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "starline"     : 1.1.3    , installed 1.1.3
      Adapter    "telegram"     : 3.0.0    , installed 2.0.1  [Updatable]
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        25038
      States:         20414
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21419      2373/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14404      493/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14379      467/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14264      1104/io.mqtt.0
      tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       14175      1028/io.sonoff.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14588      545/iobroker.js-con
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      116        10816      478/redis-server 12
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14869      698/io.admin.2
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14280      1119/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14406      493/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14378      467/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       23143      2121/io.fullybrowse
      tcp6       0      0 :::8099                 :::*                    LISTEN      1001       23516      2434/io.simple-api.
      tcp6       0      0 ::1:6379                :::*                    LISTEN      116        10817      478/redis-server 12
      udp        0      0 0.0.0.0:36256           0.0.0.0:*                           1001       21786      1613/io.broadlink2.
      udp        0      0 0.0.0.0:60987           0.0.0.0:*                           1001       20598      1613/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12157      769/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13626      496/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20595      1613/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13504      364/avahi-daemon: r
      udp        0      0 0.0.0.0:48526           0.0.0.0:*                           108        13506      364/avahi-daemon: r
      udp6       0      0 :::57783                :::*                                108        13507      364/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12169      769/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13505      364/avahi-daemon: r
      2023-12-10 11:45:16.113  - info: host.iobrokermaster iobroker upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
      2023-12-10 11:45:17.155  - info: host.iobrokermaster iobroker exit 0
      2023-12-10 11:45:50.171  - info: host.iobrokermaster Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2023-12-10 11:51:57.166  - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: neue Tagezeit: Mittag
      2023-12-10 11:51:57.168  - info: javascript.0 (915) script.js.Meine_Geraete.Astrotag_Night: nächste kommende Tagezeit: Nachmittag
      2023-12-10 11:59:00.603  - info: host.iobrokermaster instance system.adapter.yr.0 started with pid 24957
      2023-12-10 11:59:48.870  - info: host.iobrokermaster instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-10 12:00:00.541  - info: host.iobrokermaster instance system.adapter.dwd.0 started with pid 27411
      2023-12-10 12:00:04.590  - info: dwd.0 (27411) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.16
      2023-12-10 12:00:07.822  - info: dwd.0 (27411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-10 12:00:08.373  - info: host.iobrokermaster instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-10 12:01:00.059  - info: tankerkoenig.0 (1720) Scheduled restart.
      2023-12-10 12:01:00.066  - info: tankerkoenig.0 (1720) terminating
      2023-12-10 12:01:00.069  - info: tankerkoenig.0 (1720) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-12-10 12:01:00.576  - info: tankerkoenig.0 (1720) terminating
      2023-12-10 12:01:00.623  - warn: tankerkoenig.0 (1720) Could not perform strict object check of state tankerkoenig.0.stations.adapterStatus: DB closed
      2023-12-10 12:01:01.210  - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 scheduled normal terminated and will be restarted on schedule.
      2023-12-10 12:01:01.212  - info: host.iobrokermaster Restart adapter system.adapter.tankerkoenig.0 because enabled
      2023-12-10 12:01:02.478  - info: host.iobrokermaster instance system.adapter.tankerkoenig.0 started with pid 29149
      2023-12-10 12:01:06.161  - info: tankerkoenig.0 (29149) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.19.0, js-controller: 5.0.16
      2023-12-10 12:01:06.405  - info: tankerkoenig.0 (29149) Adapter is already in daemon mode
      2023-12-10 12:01:06.407  - info: tankerkoenig.0 (29149) Sync time set to 30 minutes or 1800000 ms
      2023-12-10 12:01:14.416  - info: tankerkoenig.0 (29149) Start first request
      2023-12-10 12:07:40.619  - info: javascript.0 (915) script.js.Meine_Geraete.Bewegung_Speisekammer: Speisekammer offen
      2023-12-10 12:08:22.271  - info: javascript.0 (915) script.js.common.Lichtauswertung: Speisekammer Licht ausgeschaltet.
      iob diag has finished.
      • B Bibo*13
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7897 M total memory
                 2101 M used memory
                  377 M active memory
                 4847 M free memory
                  154 M buffer memory
                  794 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        4.9G    /var/
        3.9G    /var/cache
        3.8G    /var/cache/apt
        821M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        25038
        States:         20414
        Pending Updates: 0
        @bibo-13
        sudo systemctl set-default multi-user.target
        Installier diese Adapter nochmal (oder schmeiß sie raus):
          @bibo-13
          Bibo*13
          was bewirkt das sudo systemctl set-default multi-user.target
          • B Bibo*13
            @bibo-13
            Das bewirkt, das die Meldung mit dem nicht startenden Service lightdm.service verschwindet.
              @bibo-13
              Bibo*13
              @thomas-braun Ok dann installiere ich diese Adapter noch einmal. Ist es besser sie vorher zu deinstallieren?
              • B Bibo*13
                @bibo-13 sagte in Adapter Install für Telegram funktioniert nicht.:
                Nein. Einfach drüber installieren. Kommen die alle aus dem github? Werden die überhaupt verwendet?
                B 2 Antworten Letzte Antwort
                  Bibo*13
                  @thomas-braun ja bis auf cameras sind alle aktiv
                    Bibo*13
                    Den ersten Adapter Alexa2 ausprobiert das gleiche mit den NPM Errors
                    host.iobrokermaster
                    2023-12-10 12:37:47.757	info	stopInstance system.adapter.alexa2.0 send kill signal
                    host.iobrokermaster
                    2023-12-10 12:37:47.747	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
                    host.iobrokermaster
                    2023-12-10 12:37:47.630	info	iobroker Update "system.adapter.alexa2.0"
                    host.iobrokermaster
                    2023-12-10 12:37:47.348	info	iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-10T11_34_11_619Z-debug-0.log
                    host.iobrokermaster
                    2023-12-10 12:37:47.341	info	iobroker npm ERR! notsup Unsupported platform for @img/sharp-win32-x64@0.33.0: wanted {"os":"win32","cpu":"x64"} (current: {"os":"linux","cpu":"arm"})npm ERR! notsup Valid os: win32npm ERR! notsup Actual os: linuxnpm ERR! notsup Valid cpu: x64npm ERR! notsup Actual cpu: arm
                    host.iobrokermaster
                    2023-12-10 12:37:47.330	info	iobroker npm ERR! code EBADPLATFORM
                    host.iobrokermaster
                    2023-12-10 12:34:10.135	info	iobroker NPM version: 10.2.3Installing iobroker.alexa2@3.26.3... (System call)
                    host.iobrokermaster
                    2023-12-10 12:34:08.453	info	iobroker Update alexa2 from @3.26.3 to @3.26.3
                    host.iobrokermaster
                    2023-12-10 12:34:04.202	info	iobroker upgrade alexa2@3.26.3 --debug
                    • B Bibo*13
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      host.iobrokermaster
                      @bibo-13
                      Die Meldungen kommen ja auch nicht von dem Adapter, die hängen da generell in der Pipeline.
                      Ist die 'invalid'-Eintragung denn jetzt weg?
                        @bibo-13
                        Bibo*13
                        ja bis auf da bin ich noch dran. Aber keine Ahnung was cli socksv5 oder cliff sein sein:
                        Errors in npm tree:
                        • B Bibo*13
                          Errors in npm tree:
                          @bibo-13
                          https://forum.iobroker.net/topic/69758/update-js-controller-nodejs-is-not-correctly-installed/35?_=1702205201927
                            @bibo-13
                            Bibo*13
                            So der Homepilot20 invalid ist jetzt auch weg.
                            was kann/muß ich jetzt noch machen?
                            • B Bibo*13
                              @bibo-13
                              Zeig mal
                              cd /opt/iobroker
                              npm ls
                              • B Bibo*13
                                @bibo-13
                                Und
                                iob update
                                  @bibo-13
                                  Zeig mal
                                  cd /opt/iobroker
                                  npm ls
                                  Bibo*13
                                  Hier bitte:
                                  pi@iobrokermaster:~ $ cd /opt/iobroker
                                  pi@iobrokermaster:/opt/iobroker $ npm ls
                                  iobroker.inst@2.0.3 /opt/iobroker
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── iobroker.admin@6.12.0
                                  ├── iobroker.alexa2@3.26.1
                                  ├── iobroker.awtrix-light@0.10.0
                                  ├── iobroker.backitup@2.8.7
                                  ├── iobroker.broadlink2@2.1.5
                                  ├── iobroker.cloud@4.4.1
                                  ├── iobroker.device-reminder@3.0.0
                                  ├── iobroker.discovery@4.2.0
                                  ├── iobroker.dwd@2.8.5
                                  ├── iobroker.echarts@1.5.4
                                  ├── iobroker.email@1.2.0
                                  ├── iobroker.flot@1.12.0
                                  ├── iobroker.fully-tablet-control@0.3.8
                                  ├── iobroker.fullybrowser@3.0.6
                                  ├── iobroker.harmony@1.3.0
                                  ├── iobroker.history@3.0.1
                                  ├── iobroker.homepilot20@0.0.48
                                  ├── iobroker.hue-extended@2.0.0
                                  ├── iobroker.hue@3.10.1
                                  ├── iobroker.icons-mfd-svg@1.1.0
                                  ├── iobroker.info@2.0.0
                                  ├── iobroker.iot@2.0.11
                                  ├── iobroker.jarvis@3.1.8
                                  ├── iobroker.javascript@7.1.6
                                  ├── iobroker.js-controller@5.0.16
                                  ├── iobroker.meross@1.15.1
                                  ├── iobroker.mobile@1.0.1
                                  ├── iobroker.mqtt@5.1.0
                                  ├── iobroker.nina@0.0.25
                                  ├── iobroker.parser@2.0.7
                                  ├── iobroker.ping@1.6.2
                                  ├── iobroker.proxy@1.3.2
                                  ├── iobroker.psa@0.0.12
                                  ├── iobroker.pushover@3.0.3
                                  ├── iobroker.rpi2@1.3.2
                                  ├── iobroker.simple-api@2.7.2
                                  ├── iobroker.socketio@6.6.0
                                  ├── iobroker.sonoff@3.0.3
                                  ├── iobroker.sourceanalytix@0.4.14
                                  ├── iobroker.starline@1.1.3
                                  ├── iobroker.tankerkoenig@3.3.7
                                  ├── iobroker.telegram@2.0.1
                                  ├── iobroker.text2command@3.0.2
                                  ├── iobroker.tr-064@4.2.18
                                  ├── iobroker.tuya@3.14.2
                                  ├── iobroker.vis-colorpicker@2.0.3
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.4.0
                                  ├── iobroker.vis-inventwo@3.3.3
                                  ├── iobroker.vis-jqui-mfd@1.0.12
                                  ├── iobroker.vis-keyboard@0.0.2
                                  ├── iobroker.vis-map@1.0.4
                                  ├── iobroker.vis-material-advanced@1.7.4
                                  ├── iobroker.vis-material@0.1.3
                                  ├── iobroker.vis-metro@1.2.0
                                  ├── iobroker.vis-timeandweather@1.2.2
                                  ├── iobroker.vis@1.4.16
                                  ├── iobroker.web@6.1.10
                                  ├── iobroker.ws@2.5.8
                                  ├── iobroker.yr@5.3.0
                                  ├── iobroker.zigbee@1.8.24
                                  ├── iobroker@2.0.3
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                    @bibo-13
                                    Und
                                    iob update
                                    Bibo*13
                                    Hier bitte:
                                    pi@iobrokermaster:/opt/iobroker $ iob update
                                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.1 [Updatable]
                                    • B Bibo*13
                                      Hier bitte:
                                      @bibo-13
                                      iob upgrade all -y --debug
                                        @bibo-13
                                        Bibo*13
                                        Ok telegram ist durch ohne probleme
                                        • B Bibo*13
                                          @bibo-13
                                          Und
                                          iob update
                                          ist jetzt auch sauber? Alles auf Stand?
