  4. Tabelle mit allen Shellys
    6.1k
84 Beiträge 11 Kommentatoren 5.7k Aufrufe 11 Beobachtet
  • P passi64
    @liv-in-sky Sorry, hab das Log eingefügt, hier die Ausgabe:
    8.12.2023, 16:37:28.453 [info ]: javascript.0 (3575) Start javascript script.js.Shellys.Shelly_Liste
    8.12.2023, 16:37:28.706 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHDM-2#4CEBD6EDA772#1.lights.Switch
    8.12.2023, 16:37:28.742 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHDM-2#C45BBE6ADB99#1.lights.Switch
    8.12.2023, 16:37:28.786 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHDM-2#C45BBE6B19BC#1.lights.Switch
    8.12.2023, 16:37:28.825 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHEM#C45BBE777410#1.Relay0.Switch
    8.12.2023, 16:37:28.857 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHEM-3#84CCA8ACAA87#1.Relay0.Switch
    8.12.2023, 16:37:29.039 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHPLG-S#B4DA64#1.Relay0.Switch
    8.12.2023, 16:37:29.081 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHPLG-S#B4E49B#1.Relay0.Switch
    8.12.2023, 16:37:29.118 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHPLG-S#BC7045#1.Relay0.Switch
    8.12.2023, 16:37:29.171 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHSW-1#3494547AB1E1#1.Relay0.Switch
    8.12.2023, 16:37:29.215 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHSW-1#68C63AFA7075#1.Relay0.Switch
    8.12.2023, 16:37:29.260 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHSW-1#E09806962D46#1.Relay0.Switch
    8.12.2023, 16:37:29.307 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: shelly.0.SHSW-25#10521C452F23#1.Relay0.Switch
    8.12.2023, 16:37:29.313 [warn ]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:410:86
    8.12.2023, 16:37:29.314 [warn ]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:409:45
    8.12.2023, 16:37:29.315 [warn ]: javascript.0 (3575) at writeHTML (script.js.Shellys.Shelly_Liste:341:23)
    8.12.2023, 16:37:29.316 [warn ]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:790:5
    8.12.2023, 16:37:29.317 [warn ]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:1500:3
    8.12.2023, 16:37:29.318 [info ]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    8.12.2023, 16:37:29.320 [error]: javascript.0 (3575) script.js.Shellys.Shelly_Liste: TypeError: Cannot read properties of null (reading 'includes')
    8.12.2023, 16:37:29.321 [error]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:410:126
    8.12.2023, 16:37:29.321 [error]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:409:45
    8.12.2023, 16:37:29.322 [error]: javascript.0 (3575) at writeHTML (script.js.Shellys.Shelly_Liste:341:23)
    8.12.2023, 16:37:29.322 [error]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:790:5
    8.12.2023, 16:37:29.322 [error]: javascript.0 (3575) at script.js.Shellys.Shelly_Liste:1500:3
    liv-in-skyL Offline
    liv-in-skyL Offline
    @passi64 sagte in Tabelle mit allen Shellys:
    echt schwierig ohne es zu sehen - anydesk wäre mir lieber
    sind die dp unter .....SHSW-25#10521C452F23#1..... alle mit inhalt versehen ?
    was ist das für ein typ von schalter ? müßte shutter sein ?
    P 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      passi64
      @liv-in-sky Ok, wie mache ich das mit anydesk, kenne nur Teamviewer
      • P passi64
        liv-in-skyL Offline
        liv-in-skyL Offline
        @passi64 du kannst anydesk download auf google eingeben - downloaden starten - aufrufen - dann bekommst du eine nummer - die brauche ich - aber nicht hier im forum, sondern im chat
        ich brauche noch in wenig - sage dir im chat, wenn ich bereit bin - oder wir machen es am WE
          da_WoodyD Online
          da_WoodyD Online
          @liv-in-sky schau dir mein edit an. zeile 1500?
          • da_WoodyD da_Woody
            @passi64 boah, könntest du deine logs in codetags einbetten? 9154bdfe-1839-4351-aba3-21160ddbee14-grafik.png
            ich tip mal drauf, du hast das script mit firefox kopiert. geht nur mit chrome. wurde auch DA schon geschrieben
            hab erst vorgestern das script nach langer zeit wieder mal zum spielen getestet, tut einwandfrei.
            hab aber wieder paar kleinigkeiten modifiziert.
            edith:
            das ganze script hat nur 800 zeilen...
            amg_666A Offline
            amg_666A Offline
            amg_666
            @da_woody sagte in Tabelle mit allen Shellys:
            also ich hab bei mir firefox am Start und damit ging das einwandfrei und bei mir hat das Skript 1498 Zeilen (inkl Leerzeilen) und er hat ja mein Skript auch nochmal ausprobiert, sollte also funzen...
            • P passi64
              liv-in-skyL Offline
              liv-in-skyL Offline
              @passi64 schau mal in den chat
                edith:
                passi64
                @da_woody @amg_666 Ich habe das original Skript mit Chrome eingefügt, ich benutze keinen Firefox. Zusätzlich habe das Skript auch noch in einem reinen Texteditor kopiert und gespeichert und wieder kopiert. Hat alles nicht funktioniert. Aber trotzdem vielen Dank das ihr euch meinem Problem annehmt.
                • amg_666A amg_666
                  @passi64 warte mal, ich glaube @liv-in-sky hat recht mit seiner Frage "welche DP". Da ist wahrscheinlich etwas in den shelly Datenpunkten falsch/veraltet/zerschossen und daran hängt sich das Skript auf.
                  Radikale Lösung :-) Lösche alle Shelly DP und starte den Adapter neu (aber da übernehme ich keine Garantie, dass dann alles gleich wieder wie gewünscht läuft, wenn du z.B. Skripte hast, die dann auf DP zugreifen wollen, die du grade gelöscht hast).
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @amg_666 @da_Woody
                  haben etwas seltsames festgestellt - die dp sind anders gewesen - es wurde da im adapter etwas geändert - aber warum fällt das bei dir nicht auf
                  beispiel:#
                  shelly.0.SHSW-25#737AB7#1.mode
                  ist jetzt
                  shelly.0.SHSW-25#737AB7#1.Sys.deviceMode
                  würdest du alle dp des shelly adapters löschen, würde wahrscheinlich nach dem neuanlegen der dp shelly.0.SHSW-25#737AB7#1.mode
                  nicht mehr existieren und das scrpt nicht funktionieren
                  nur eine vermutung
                  amg_666A da_WoodyD 2 Antworten Letzte Antwort
                    @amg_666 @da_Woody
                    beispiel:#
                    ist jetzt
                    nur eine vermutung
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    schrieb am zuletzt editiert von amg_666
                    @liv-in-sky Ich hab nur Shelly-1 Switches im Einsatz (SHSW-1...) die haben den DP ...#1.mode nicht:
                    SHSW-25 ist ein Shelly 2.5, da kann ich leider nicht weiterhelfen, ist bei mir nicht im Einsatz
                    • amg_666A amg_666
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @amg_666 das erklärt, warum du kein problem hast :-)
                        @amg_666 @da_Woody
                        beispiel:#
                        ist jetzt
                        nur eine vermutung
                        da_WoodyD Online
                        da_WoodyD Online
                        @liv-in-sky bringt mich zur frage: welche adapterversion
                        abgesehn davon. bei mir gibts auch kein mode, sondern deviceMode und bei mir klappt das script.
                        nach stöbern in den objekten hab ich rausgefunden, der DP existiert nur in geräten die 2 modi haben.
                        liv-in-skyL 3 Antworten Letzte Antwort
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @da_woody ja - genau da frage ich ab - aber der dp mode muss auch noch in deinen dp sein
                          eine ebene höher
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @da_woody filtee mal nach mode
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @da_woody
                              ach ja - version - neuste version im stable
                                da_WoodyD Online
                                da_WoodyD Online
                                @liv-in-sky hab ich als erstes gemacht. mode gibts nicht.
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @da_woody hat der C4CC7A einen unterordner Shutter ?
                                  ganz unten im bild
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @da_woody
                                    ich gecheckt - würdest du diesen von shutter auf relay ändern, hätte das script ein problem - also wenn shutter(roller) als relays genutzt werden
                                      ganz unten im bild
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      @liv-in-sky na klar
                                        @da_woody
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        @liv-in-sky hast glück, hab da einen 25er amschreibtisch rumliegen im ralaismode.
                                        der hat witzigerweise auch kein problem.
                                        allerdinx hab ich grad was anderes festgestellt...
                                        hab das script aus dem tread kopiert, auf github ist aber ein anders. meins hat nur 800 zeilen. das auf git fast das doppelte!
                                        werd mal beide testen... :)
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @da_woody ja - bei deiner tabelle sieht das anders aus
