  4. Test Adapter alpha-ess v4.1.0
302 Beiträge 37 Kommentatoren 106.8k Aufrufe 35 Beobachtet
  • RaspiUserR RaspiUser
    @Gaspode
    ... Verständnisfrage:
    Mit der "Closed API" bekomme ich seit einigen Tage div. Meldungen im Log ...
    alpha-ess.0
    	2023-09-19 10:03:42.852	error	authenticate Exception occurred: AxiosError: Request failed with status code 404
    alpha-ess.0
    	2023-09-19 10:03:41.971	error	authenticate Exception occurred: AxiosError: Request failed with status code 404
    alpha-ess.0
    	2023-09-19 10:03:41.016	error	authenticate Exception occurred: AxiosError: Request failed with status code 404
    alpha-ess.0
    	2023-09-19 10:03:40.098	error	authenticate Exception occurred: AxiosError: Request failed with status code 404
    alpha-ess.0
    	2023-09-19 10:03:30.081	error	fetchData Exception occurred: AxiosError: timeout of 10000ms exceeded (error count: 1)
    und jede Menge "warn", z.B. ...
    099+
    Log-Größe: 223.6 KB
    Zeit
    Nachricht
    alpha-ess.0
    	2023-09-19 10:08:42.069	warn	Watchdog: State Summary.Currency not updated for 599766 ms
    alpha-ess.0
    	2023-09-19 10:08:42.058	warn	Watchdog: State Summary.CO2_reduction_total not updated for 599756 ms
    alpha-ess.0
    	2023-09-19 10:08:42.052	warn	Watchdog: State Summary.Trees_plantet_total not updated for 599752 ms
    alpha-ess.0
    	2023-09-19 10:08:42.046	warn	Watchdog: State Summary.Self_sufficiency_total not updated for 599751 ms
    alpha-ess.0
    	2023-09-19 10:08:42.040	warn	Watchdog: State Summary.Self_consumption_total not updated for 599747 ms
    alpha-ess.0
    	2023-09-19 10:08:42.033	warn	Watchdog: State Summary.Income_total not updated for 599742 ms
    alpha-ess.0
    	2023-09-19 10:08:42.027	warn	Watchdog: State Summary.Income_today not updated for 599737 ms
    alpha-ess.0
    	2023-09-19 10:08:42.020	warn	Watchdog: State Summary.Generation_total not updated for 599738 ms
    alpha-ess.0
    	2023-09-19 10:08:42.011	warn	Watchdog: State Summary.Generation_today not updated for 599731 ms
    alpha-ess.0
    	2023-09-19 10:08:42.005	warn	Watchdog: State StatisticsToday.Self_consumption not updated for 600622 ms
    alpha-ess.0
    	2023-09-19 10:08:41.998	warn	Watchdog: State StatisticsToday.Self_sufficiency not updated for 600607 ms
    alpha-ess.0
    	2023-09-19 10:08:41.992	warn	Watchdog: State StatisticsToday.Charging pile not updated for 600591 ms
    alpha-ess.0
    	2023-09-19 10:08:41.987	warn	Watchdog: State StatisticsToday.Grid_consumption not updated for 600588 ms
    alpha-ess.0
    	2023-09-19 10:08:41.981	warn	Watchdog: State StatisticsToday.Grid_charging_the_loads not updated for 600606 ms
    alpha-ess.0
    	2023-09-19 10:08:41.976	warn	Watchdog: State StatisticsToday.Grid_charge not updated for 600607 ms
    Der Adapter mit "Open API" läuft ohne eine einzige Meldung.
    Ist das die von Dir erwartete / beschriebene Änderung bei AlphaESS ?
    GaspodeG Offline
    GaspodeG Offline
    Gaspode
    #84
    @raspiuser said in Test Adapter alpha-ess v1.0.0-beta.0:
    Ich denke, das sind eher Störungen bei Alpha-ESS. Die bauen gerade viel hinter den Kulissen um, grundsätzlich scheint die "Closed API" aber noch(?) nicht verändert worden zu sein.
    Derzeit berichten viele Alpha-ESS-Anlagen-Besitzer von Problemen mit App und Web Interface (die beide auf der gleichen API aufsetzen und von Alpha-ESS selbst stammen).
    • GaspodeG Offline
      GaspodeG Offline
      Gaspode
      #85
      ​Leider funktioniert bei Verwendung der Closed API das Abrufen der Energiewerte nicht mehr in Version 1.0.0
      Ich habe jetzt auf einen anderen API Call umgestellt, Version 1.0.1 sollte im Laufe des Tages im Beta Repository auftauchen. Wer es eilig hat, kann auch jetzt schon über die "Katze" direkt von npm aktualisieren.
      Nach ersten (hoffentlich positiven) Rückmeldungen, packe ich die 1.0.1 dann ins Stable Repository.
      • GaspodeG Offline
        GaspodeG Offline
        Gaspode
        #86
        Version 1.0.2 im Stable Repository verfügbar. Behebt das Problem der Energiewerte bei Verwendung der Closed API.
          Martin d
          #87
          Hallo, ich bin völlig neu im Thema iobroker. Ich habe eine prinzipielle Frage. Ich besitze eine Anlage von Alpha ESS und würde gerne je nach Batteriestand oder PV-Erzeugung meine Rademacher Homepilot Zwischenstecker steuern. Beispiel: Sobald der Batteriespeicher 100 % ist, würde ich gerne meinen Infrarot Heizkörper über den Zwischenstecker anschalten. Einen Adapter für Rademacher soll es wohl geben. Vielen Dank!
          GaspodeG 1 Antwort Letzte Antwort
          • M Martin d
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            #88
            @martin-d
            Dafür wirst du wohl drei Adapter brauchen:
            Den Alpha-ESS Adapter, den Rademacher Adapter (das wäre dann wohl der Homepilot Adapter für Rademacher Duofern Geräte?) und den Javascript Adapter.
            Ich würde an deiner Stelle mal die Adapter installieren und sehen, wie weit du kommst. Bei Fragen einfach wieder melden.
            • GaspodeG Gaspode
              @martin-d
              Martin d
              #89
              @gaspode
              Habe alle Adapter installiert. Das habe ich schonmal zusammen gebastelt. Bin aber ein absoluter Anfänger. "Position" ist die Schaltung für den Rademacher Homepilot Zwischenstecker. Er soll die Heizung einschalten sobald die Batterie mindestens 50 % und die Eispeisung > 1500 Watt ist. Trifft beides ein soll er die Heizung mindestens 30 Minuten anlassen bis er den Zustand wieder überprüft. Was meinst du dazu?
              • M Martin d
                @gaspode
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                #90
                @martin-d said in Test Adapter alpha-ess v1.0.1:
                Ich bin jetzt nicht so der Blockly Experte und das ist jetzt auch keine Adapter-spezifische Sache, von daher wärst du wahrscheinlich besser beraten, wenn du im Scripting Bereich des Forums um Rat fragst.
                Auf den ersten Blick würde ich sagen, dass die Heizung nicht mindestens 30 Minuten an bleibt, sondern höchstens. Sobald SOC unter 50 % fällt oder Einspeisung unter 1500 W, wird sofort ausgeschaltet.
                • GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  schrieb am zuletzt editiert von Gaspode
                  #91
                  Alpha-ESS hat sich endlich dazu durchringen können, die gegenüber der "ClosedAPI" fehlenden Werte auch in der Open API bereit zu stellen. Ich habe den Adapter entsprechend angepasst und die Version 1.2.1 sollte in den nächsten Stunden im Beta Repository verfügbar sein. Wer es eilig hat, kann wie immer über die "Katze" von npm installieren. Demnächst kommt Version 2.0, die dann auch in das Stable Repository aufgenommen werden soll.
                  ACHTUNG:
                  Die kommende Version 2.0 wird die "ClosedAPI" NICHT MEHR unterstützen, da Alpha-ESS angekündigt hat, diese in Kürze für Fremdanwendungen zu blockieren. Da die OpenAPI jetzt auch alle relevanten Werte bereit stellt, sollte das auch kein Problem sein.
                  Es wäre also ein guter Zeitpunkt, jetzt auf die OpenAPI umzusteigen.
                  Eins noch:
                  Leider musste ich in der OpenAPI einige State Namen gegenüber der ClosedAPI ändern, damit die Sache einheitlich wird. Auch innerhalb der OpenAPI mussten Umbenennungen vorgenommen werden.
                  Ihr müsst also ggfs. eure Scripte und Visualisierungen einmalig anpassen. Sorry dafür, aber immerhin sollten die Bezeichnungen jetzt einheitlich sein und dem gleichen Muster folgen.
                  • GaspodeG Offline
                    GaspodeG Offline
                    Gaspode
                    #92
                    Version 1.3.0 ist jetzt im Beta Repository verfügbar bzw. sollte in den nächsten Stunden dort auftauchen.
                    Es wird jetzt eine(!) Wallbox über OpenAPI unterstützt. Sollte jemand mehrere Wallboxen betreiben, wird derzeit nur die erste davon unterstützt.
                    @all
                    Bitte achtet mal drauf, ob neben der Wallbox Unterstützung auch alle anderen Features funktionieren, insbesondere das Schreiben von Settings in der OpenAPI.
                    • O Offline
                      O Offline
                      obod0002
                      #93
                      nachdem ich seit einiger Zeit keine Daten meiner PV im iobroker mehr erhalten habe, war es wohl an der Zeit für ein Update.
                      iobroker ist mittlerweile (mit Hilfe) aktualisiert, der alpha ess Adapter auch.
                      Leider hat das nicht wirklich geholfen:
                      Könnt ihr helfen, was ich falsch mache? Danke
                      • O obod0002
                        GaspodeG Offline
                        GaspodeG Offline
                        Gaspode
                        #94
                        @obod0002
                        Kann es sein, dass du von einer gaaaaanz alten Version aus aktualisiert hast? Das sieht mir aus, als hätte er die Datenquelle in den Settings im Hintergrung auf die "neue" und empfohlene Open API gesetzt.
                        Wenn du wieder auf Closed API stellst, sollte es wieder funktionieren.
                        Grund ist wohl ein anderer, s. meinen nächsten Beitrag.
                        Aber Achtung: Ich arbeite gerade an der Version 2.0 des Adapters, der u.a. eine rudimentäre Wallbox Steuerung und Info zum Ladestatus unterstützt. Diese Version wird die so genannte "Closed API" nicht mehr unterstützen, da Alpha-ESS die Anwender aufgefordert hat, das zu unterlassen und angekündigt hat, dass sie diese API für Third Party Anwendungen ohnehin dicht machen wird.
                        Es wäre also ein guter Zeitpunkt, auf die Open API umzusteigen. Du musst dein System dafür registrieren, s. im Readme des Adapters:
                        *To be able to use the new Open API you have to register your Alpha-ESS device under https://open.alphaess.com. Once registered, you get a developer ID and a developer key (called "Secret"). You will need these to have access to the Open API. Currently I have no information if this will be changed in the future. How to find SN and Check code for registration is described here: https://github.com/alphaess-developer/alphacloud_open_api*~~strikethrough text~~
                        • GaspodeG Offline
                          GaspodeG Offline
                          Gaspode
                          #95
                          Nachtrag:
                          Anscheinend hat Alpha-ESS heute Morgen, 02.12.2023, etwa 8:10 Uhr die Closed API geändert. Sie funktioniert somit wie angekündigt nicht mehr und ihr müsst auf die Open API umsteigen.
                          • GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            #96
                            Version 2.0.0 im Beta Repository verfügbar, s. erster Post für Details.
                            • O Offline
                              O Offline
                              obod0002
                              #97
                              nach doppelter Registrierung bei alpha ess, Hinzufügen des System ("Addieren"), ist der rote Eintrag bei den Instanzen verschwunden:
                              Weiterhin leider kein Erfolg:
                              • O Offline
                                O Offline
                                obod0002
                                #98
                                dann versuche ich es mal mit der 2er Version
                                • O obod0002
                                  GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  #99
                                  @obod0002 said in Test Adapter alpha-ess v2.0.0:
                                  Zeig mal bitte einen Screenshot deiner Config (SN unkenntlich machen!)
                                  Dein Log ist zwar "schön", aber leider ohne sichtbaren Eintrag des Alpha-ESS Adapters. Du hast anscheinend gerade Probleme mit der Kommunikation zu den ioBroker Repository Servern. Das ist aber eine andere Baustelle.
                                  • O Offline
                                    O Offline
                                    obod0002
                                    #100
                                    ich vermute, du meinst diesen Screen?
                                    • O Offline
                                      O Offline
                                      obod0002
                                      #101
                                      das Log hat zwar schon ein paar Einträge die Alpha Ess betreffen,
                                      Alpha ESS Api returns an error! Group: Realtime
                                      Alpha ESS Api returns an error! Group: Energy
                                      aber eben auch solche:
                                      Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": getaddrinfo ENOTFOUND download.iobroker.net
                                      • O obod0002
                                        GaspodeG Offline
                                        GaspodeG Offline
                                        Gaspode
                                        #102
                                        Die sind in deinem Screenshot halt nicht zu sehen.
                                        Bitte ein vollständiges Log mit allen Meldungen des Adapters in Textform.
                                        Bist du sicher, dass du eine Internetverbindung auf deinem ioBroker Server hast?
                                        deutet darauf hin, dass das nicht der Fall ist (oder die DNS Auflösung nicht sauber funktioniert). In beiden Fällen kann der Alpha-ESS Adapter natürlich auch nicht funktionieren.
                                        • O Offline
                                          O Offline
                                          obod0002
                                          #103
                                          ich war froh, daß ich das überhaupt zum Laufen bekommen hab, "damals" ;-)
                                          iobroker.2023-12-04.log.html
                                          GaspodeG Thomas BraunT 2 Antworten Letzte Antwort
