  4. Test Adapter Bosch ebik connect / flow
208 Beiträge 41 Kommentatoren 59.1k Aufrufe 46 Beobachtet
    backfisch88
    läuft wieder! besten dank!
    • Marco StiegM Offline
      Marco Stieg
      Hallo zusammen.
      Hat schon jemand die Problematik gelöst, dass die Zeit in Bewegung immer eine Stunde zuviel ausgibt?
        Marcus007
        Wird an dem Adapter noch was gemacht?
        Gruss Marcus
        • M Marcus007
          Gruss Marcus
          tombox
          @marcus007 ja bitte beta channel von iobroker verwenden
          draexlerD 1 Antwort Letzte Antwort
          • T tombox
            draexlerD Offline
            draexlerD Offline
            draexler
            @tombox Seit heute (evtl. auch schon länger) wird der Adapter nicht mehr grün:
            Das ist im LOG:
            	2023-12-01 18:46:34.962	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.iobroker
            2023-12-01 18:46:34.962	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
            host.iobroker
            2023-12-01 18:46:34.962	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
            host.iobroker
            2023-12-01 18:46:34.961	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
            host.iobroker
            2023-12-01 18:46:34.961	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'value')
            host.iobroker
            2023-12-01 18:46:34.960	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            bosch-ebike.0
            2023-12-01 18:46:34.339	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            bosch-ebike.0
            2023-12-01 18:46:34.313	error	Cannot read properties of undefined (reading 'value')
            bosch-ebike.0
            2023-12-01 18:46:34.312	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
            bosch-ebike.0
            2023-12-01 18:46:34.310	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
            bosch-ebike.0
            2023-12-01 18:46:34.308	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            admin.0
            2023-12-01 18:45:36.024	warn	bosch-ebike has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
            • draexlerD draexler
              Das ist im LOG:
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              bosch-ebike.0
              bosch-ebike.0
              bosch-ebike.0
              bosch-ebike.0
              bosch-ebike.0
              admin.0
              @draexler
              iobroker und nodejs sind auf dem letzten Stand?
              Auf welchem?
              iob diag
              anschauen.
                @draexler
                Auf welchem?
                iob diag
                anschauen.
                draexlerD Offline
                draexlerD Offline
                draexler
                schrieb am zuletzt editiert von draexler
                @thomas-braun: Jetzt wo du so schreibst mit der nodejs..
                Das habe ich heute morgen mit:
                curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update
                chmod 744 iob_node_update
                /iob_node_update
                geupdatet und evtl. funktioniert es seit dem nicht mehr.
                hier das iob diag:
                                        v.2023-10-10
                   Static hostname: iobroker
                         Icon name: computer-vm
                           Chassis: vm
                    Virtualization: kvm
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.10.0-26-amd64
                      Architecture: x86-64
                Installation:           kvm
                Kernel:                 x86_64
                Userland:               amd64
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                        /usr/bin/node           v18.19.0
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        /usr/bin/corepack       0.22.0
                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                MEMORY:
                Mem:            7.9G        4.8G        2.1G        0.0K        1.0G        2.9G
                Swap:           974M          0B        974M
                Total:          8.9G        4.8G        3.1G
                Active iob-Instances:   57
                ioBroker Core:          js-controller           5.0.16
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                27161
                States:                 21499
                Size of iob-Database:
                37M     /opt/iobroker/iobroker-data/objects.jsonl
                35M     /opt/iobroker/iobroker-data/states.jsonl
                  /iob_node_update
                  hier das iob diag:
                                          v.2023-10-10
                             Chassis: vm
                      Virtualization: kvm
                  Installation:           kvm
                  Kernel:                 x86_64
                  Userland:               amd64
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                  MEMORY:
                  Swap:           974M          0B        974M
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                27161
                  States:                 21499
                  @draexler sagte in Test Adapter Bosch ebik connect / flow:
                  Nee, das passt.
                  Besser aber den stabilen Befehl
                  iob nodejs-update
                  verwenden.
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    Ich habe auch seit Heute im log:
                    host.iobroker
                    2023-12-02 10:38:18.898	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                    host.iobroker
                    2023-12-02 10:38:18.898	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                    host.iobroker
                    2023-12-02 10:38:18.898	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
                    host.iobroker
                    2023-12-02 10:38:18.898	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'value')
                    host.iobroker
                    2023-12-02 10:38:18.898	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    bosch-ebike.0
                    2023-12-02 10:38:18.322	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    bosch-ebike.0
                    2023-12-02 10:38:18.321	info	terminating
                    bosch-ebike.0
                    2023-12-02 10:38:18.311	error	Cannot read properties of undefined (reading 'value')
                    bosch-ebike.0
                    2023-12-02 10:38:18.311	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                    bosch-ebike.0
                    2023-12-02 10:38:18.307	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
                    bosch-ebike.0
                    2023-12-02 10:38:18.307	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    javascript.0
                    2023-12-02 10:38:17.427	info	script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
                    bosch-ebike.0
                    2023-12-02 10:38:17.265	info	Login to eBike flow
                    Keine Veränderung durchgeführt. Und ich bin aktuell.
                    Habe auch gleich ein issue erstellt.
                    https://github.com/TA2k/ioBroker.bosch-ebike/issues/12
                    Danke.
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      Habe 0.1.5 installiert.
                      Dann war alles ok.
                      Danke.
                        Marcus007
                        der Adapter funktioniert gut (Flow-App).
                        Toll ist, dass die letzte Fahrt immer 01 ist.
                        Was mache ich falsch, dass der Batteriestatus nicht angezeigt wird?
                        Ein entsprechender Datenpunkt ist ja vorhanden.
                        Viele Grüße
                        Marcus
                        • M Marcus007
                          Viele Grüße
                          Marcus
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @marcus007 sagte in Test Adapter Bosch ebik connect / flow:
                          zeig den mal.
                          ich habe bei den Objekten kein DP.
                          Danke.
                          • bahnuhrB bahnuhr
                            zeig den mal.
                            Marcus007
                            @bahnuhr
                            Marcus
                            • M Marcus007
                              @bahnuhr
                              Marcus
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @marcus007
                              Ah, ja doch den hab ich auch.
                              Steht aber nix drin.
                              Danke.
                              • bahnuhrB bahnuhr
                                @marcus007
                                Marcus007
                                #66
                                @bahnuhr
                                Gibts keine Aussicht auf Übernahme des Akkustands?
                                Marcus
                                • M Marcus007
                                  @bahnuhr
                                  Marcus
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #67
                                  @marcus007
                                  Keine Ahnung,
                                  Ich glaube auch nicht, dass dies der Akkustand ist.
                                  Sieht für mich eher aus wie: Verbrauch des Akkus während des trips.
                                  Denn dieser DP gibt es ja bei allen trips.
                                  Aber mach doch mal ein issue auf git auf.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    @marcus007
                                    Keine Ahnung,
                                    tombox
                                    #68
                                    @bahnuhr Ja das ist der Verbrauch pro trip. Wird denn sowas in der app angezeigt? im Debug log sieht man auch immer was direkt von der API kommt
                                    bahnuhrB 2 Antworten Letzte Antwort
                                    • T tombox
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #69
                                      @tombox
                                      Habe gerade mal in die app auf dem Handy unter Statistiken geschaut.
                                      Dort steht bei den trips nichts von Battery.
                                      Aber den DP musst du doch irgendwo her haben. Vielleicht gibt es diesen ja bei dem connect System.
                                      Nur halt nicht bei flow.
                                      Danke.
                                      • T tombox
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #70
                                        @tombox
                                        Aber mal eine andere Frage:
                                        In der app sieht man bei den trips ein kleines Bild (google maps oder unten links steht mapbox).
                                        Könnte man dieses Bild auch einlesen um es dann in vis darstellen zu können.
                                        Unter Details sind jede Menge Infos bzgl. lat und lon. Nur wie macht man daraus ein Bild ?
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          @tombox
                                          tombox
                                          #71
                                          @bahnuhr Er kommt via API als leerer Wert zurück. Er wird nur nicht in der App dargestellt
