  4. Kein iobroker Backup mehr über BackitUp Adapter
112 Beiträge 6 Kommentatoren 14.0k Aufrufe 4 Beobachtet
  • simatecS simatec
    @laser Die IP muss in der Config raus... Lass das Feld leer.
    Vollständiger Pfad ist nur für die User, die die influx-cli nicht im Standardpfad /usr/bin liegen haben
    Laser
    @simatec hier die Meldungen beim Backup:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.57/backup /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 3145 states saved
    [DEBUG] [iobroker] - host.raspberrypi 3839 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-10_31_13_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker" successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t fPGvK9QsLi2jJWNN_q5ccAyETlJ9plh-1qxfgsxuOEPymu9SCsQVHI3j47j44UbAUfqMpv8_in5zeFDC8D2Q0Q== "/opt/iobroker/backups/influxDB_2023_11_20-10_31_26_backupiobroker"
    2023/11/20 10:31:26 INFO: Downloading metadata snapshot
    Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [cifs] - used copy path: /backup
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    • simatecS Offline
      simatecS Offline
      simatec
      @laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
      Dann ist es doch nicht der Operator-Token oder du hast ihn versehentlich gelöscht.
      Du hast mit dem Token keine Berechtigung.
      Hier eine Anleitung, wie du ihn wieder herstellen kannst.
      https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#token-für-influxdb-2x-backup-richtig-erstellen
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      L 1 Antwort Letzte Antwort
      • simatecS simatec
        Laser
        @simatec OK. Mache ich jetzt.
        • L Laser
          Laser
          schrieb am zuletzt editiert von Laser
          @simantec den neuen Token erstellt. heißt jetzt: w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw==
          aber immer noch:
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-10_53_09_backupiobroker.tar.gz
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker"
          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker" successfully deleted
          [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker"
          2023/11/20 10:53:21 INFO: Downloading metadata snapshot
          [EXIT] 0
          Wenn ich den Befehl auf der Konsole ausführe:
          otto@raspberrypi:/opt $ influx backup --bucket iobroker -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== "/opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker"
          2023/11/20 10:56:29 INFO: Downloading metadata snapshot
          • L Laser
            aber immer noch:
            [EXIT] 0
            simatecS Offline
            simatecS Offline
            simatec
            @laser Zeige mal die Config deines Influx Adapters?
            Was ist dort für Token hinterlegt?
            • simatecS simatec
              Laser
              @simatec
              der eingetragene Token ist der Mit "strg&C" kopierte, neu erstellte Token. Den habe ich auch wieder in einer Textdatei gesichert. Für alle Fälle.
              Habe ich mir auch anzeigen lassen. War identisch.
              Marc BergM simatecS 2 Antworten Letzte Antwort
              • L Laser
                @simatec
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                neu erstellte Token
                Da der Link zum Neuerstellen des Operator-Tokens ins Nirwana zeigt, frage ich mich gerade, wie du den Token erstellt hast. Was sagt denn:
                influx auth list -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== --json
                • L Laser
                  @simatec
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @laser Nein nicht die Config von Backitup... Bitte zeige den Influx Adapter
                  • Marc BergM Marc Berg
                    neu erstellte Token
                    Laser
                    @marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                    Den Token habe ich so erstellt: was mache ich mit den "alten" Token?
                    otto@raspberrypi:/opt $ influx auth list -t w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw== --json
                                    "id": "0b4721ccc9305000",
                                    "description": "iobroker's Token",
                                    "token": "9RpnKWzJ2Vuq-Jg85pOljmMaF1PJP0YhAfXZcLYO7QRNUQtKUaV0ezcQeIpnmTR2K1Ve0YWl11lqKTsX2DvQvw==",
                                    "status": "active",
                                    "userName": "iobroker",
                                    "userID": "0b4721cca3305000",
                                    "permissions": [
                                            "read:/authorizations",
                                            "write:/authorizations",
                                            "read:/buckets",
                                            "write:/buckets",
                                            "read:/dashboards",
                                            "write:/dashboards",
                                            "read:/orgs",
                                            "write:/orgs",
                                            "read:/sources",
                                            "write:/sources",
                                            "read:/tasks",
                                            "write:/tasks",
                                            "read:/telegrafs",
                                            "write:/telegrafs",
                                            "read:/users",
                                            "write:/users",
                                            "read:/variables",
                                            "write:/variables",
                                            "read:/scrapers",
                                            "write:/scrapers",
                                            "read:/secrets",
                                            "write:/secrets",
                                            "read:/labels",
                                            "write:/labels",
                                            "read:/views",
                                            "write:/views",
                                            "read:/documents",
                                            "write:/documents",
                                            "read:/notificationRules",
                                            "write:/notificationRules",
                                            "read:/notificationEndpoints",
                                            "write:/notificationEndpoints",
                                            "read:/checks",
                                            "write:/checks",
                                            "read:/dbrp",
                                            "write:/dbrp",
                                            "read:/notebooks",
                                            "write:/notebooks",
                                            "read:/annotations",
                                            "write:/annotations",
                                            "read:/remotes",
                                            "write:/remotes",
                                            "read:/replications",
                                            "write:/replications"
                                    "id": "0b485bd1c75e4000",
                                    "description": "onboarding-cliWizard-token-1685530468858",
                                    "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==",
                                    "status": "active",
                                    "permissions": [
                                            "read:orgs/56ed5fe7a100c804/annotations",
                                            "write:orgs/56ed5fe7a100c804/annotations",
                                            "read:orgs/56ed5fe7a100c804/authorizations",
                                            "write:orgs/56ed5fe7a100c804/authorizations",
                                            "read:orgs/56ed5fe7a100c804/buckets",
                                            "write:orgs/56ed5fe7a100c804/buckets",
                                            "read:orgs/56ed5fe7a100c804/checks",
                                            "write:orgs/56ed5fe7a100c804/checks",
                                            "read:orgs/56ed5fe7a100c804/dashboards",
                                            "write:orgs/56ed5fe7a100c804/dashboards",
                                            "read:orgs/56ed5fe7a100c804/dbrp",
                                            "write:orgs/56ed5fe7a100c804/dbrp",
                                            "read:orgs/56ed5fe7a100c804/documents",
                                            "write:orgs/56ed5fe7a100c804/documents",
                                            "read:orgs/56ed5fe7a100c804/labels",
                                            "write:orgs/56ed5fe7a100c804/labels",
                                            "read:orgs/56ed5fe7a100c804/notebooks",
                                            "write:orgs/56ed5fe7a100c804/notebooks",
                                            "read:orgs/56ed5fe7a100c804/notificationEndpoints",
                                            "write:orgs/56ed5fe7a100c804/notificationEndpoints",
                                            "read:orgs/56ed5fe7a100c804/notificationRules",
                                            "write:orgs/56ed5fe7a100c804/notificationRules",
                                            "read:/orgs/56ed5fe7a100c804",
                                            "read:orgs/56ed5fe7a100c804/remotes",
                                            "write:orgs/56ed5fe7a100c804/remotes",
                                            "read:orgs/56ed5fe7a100c804/replications",
                                            "write:orgs/56ed5fe7a100c804/replications",
                                            "read:orgs/56ed5fe7a100c804/scrapers",
                                            "write:orgs/56ed5fe7a100c804/scrapers",
                                            "read:orgs/56ed5fe7a100c804/secrets",
                                            "write:orgs/56ed5fe7a100c804/secrets",
                                            "read:orgs/56ed5fe7a100c804/sources",
                                            "write:orgs/56ed5fe7a100c804/sources",
                                            "read:orgs/56ed5fe7a100c804/tasks",
                                            "write:orgs/56ed5fe7a100c804/tasks",
                                            "read:orgs/56ed5fe7a100c804/telegrafs",
                                            "write:orgs/56ed5fe7a100c804/telegrafs",
                                            "read:/users/0b4721cca3305000",
                                            "write:/users/0b4721cca3305000",
                                            "read:orgs/56ed5fe7a100c804/variables",
                                            "write:orgs/56ed5fe7a100c804/variables",
                                            "read:orgs/56ed5fe7a100c804/views",
                                            "write:orgs/56ed5fe7a100c804/views"
                                    "id": "0b4862a339de4000",
                                    "description": "iobroker",
                                    "token": "fPGvK9QsLi2jJWNN_q5ccAyETlJ9plh-1qxfgsxuOEPymu9SCsQVHI3j47j44UbAUfqMpv8_in5zeFDC8D2Q0Q==",
                                    "status": "active",
                                    "permissions": [
                                    "id": "0c26fdf572986000",
                                    "description": "onboarding-cliWizard-token-1700471139713",
                                    "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==",
                                    "status": "active",
                                    "permissions": [
                                    "id": "0c2706d518d86000",
                                    "description": "Neuer Token",
                                    "token": "w_82OMhVzJnXMTItS43qdbAwWyvrguzgRAiSQqDuqmb9WohKS3dKqrez-tInxG17EE64gBAC7oihtfkeKcfJBw==",
                                    "status": "active",
                                    "permissions": [
                    Marc BergM L 2 Antworten Letzte Antwort
                    • L Laser
                                      "status": "active",
                                      "permissions": [
                                              "read:/buckets",
                                              "write:/buckets",
                                              "read:/dashboards",
                                              "read:/orgs",
                                              "write:/orgs",
                                              "read:/sources",
                                              "write:/sources",
                                              "read:/tasks",
                                              "write:/tasks",
                                              "read:/telegrafs",
                                              "write:/telegrafs",
                                              "read:/users",
                                              "write:/users",
                                              "read:/variables",
                                              "write:/variables",
                                              "read:/scrapers",
                                              "write:/scrapers",
                                              "read:/secrets",
                                              "write:/secrets",
                                              "read:/labels",
                                              "write:/labels",
                                              "read:/views",
                                              "write:/views",
                                              "read:/documents",
                                              "write:/documents",
                                              "read:/checks",
                                              "write:/checks",
                                              "read:/dbrp",
                                              "write:/dbrp",
                                              "read:/notebooks",
                                              "write:/notebooks",
                                              "read:/remotes",
                                              "write:/remotes",
                                      "status": "active",
                                      "permissions": [
                                      "status": "active",
                                      "permissions": [
                                      "status": "active",
                                      "permissions": [
                                      "status": "active",
                                      "permissions": [
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      dann ist das hier dein Operator - Token:
                      • L Laser
                                        "status": "active",
                                        "permissions": [
                                                "read:/buckets",
                                                "write:/buckets",
                                                "read:/dashboards",
                                                "read:/orgs",
                                                "write:/orgs",
                                                "read:/sources",
                                                "write:/sources",
                                                "read:/tasks",
                                                "write:/tasks",
                                                "read:/telegrafs",
                                                "write:/telegrafs",
                                                "read:/users",
                                                "write:/users",
                                                "read:/variables",
                                                "write:/variables",
                                                "read:/scrapers",
                                                "write:/scrapers",
                                                "read:/secrets",
                                                "write:/secrets",
                                                "read:/labels",
                                                "write:/labels",
                                                "read:/views",
                                                "write:/views",
                                                "read:/documents",
                                                "write:/documents",
                                                "read:/checks",
                                                "write:/checks",
                                                "read:/dbrp",
                                                "write:/dbrp",
                                                "read:/notebooks",
                                                "write:/notebooks",
                                                "read:/remotes",
                                                "write:/remotes",
                                        "status": "active",
                                        "permissions": [
                                        "status": "active",
                                        "permissions": [
                                        "status": "active",
                                        "permissions": [
                                        "status": "active",
                                        "permissions": [
                        Laser
                        @simantec Muß da auch der neu generierte Token rein? Vermutlich ja)
                        Ich möchte ungern die Datenbank unbrauchbar machen.
                        Ich starte den Pi gerade neu...
                        EDIT: wieder das gleiche Verhalten. Kann ich bei der Token- Generierung etwas falsch machen? Was tue ich mit den ganzen "alten" Token's?
                        • L Laser
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          Hast du denn jetzt den Token
                          in Backitup eingetragen???
                            Laser
                            @marc-berg Ich habe die Token in Backitup und in influx eingetragen.
                            Gerade noch einen neuen Token erstellt. Muß der eine bestimmte Bezeichnung erhalten oder ist das nur ein Mektext?
                            Wieder das Gleiche beim Backup:
                            [DEBUG] [iobroker] - host.raspberrypi 3166 states saved
                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-11_34_13_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker"
                            [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker" successfully deleted
                            [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== "/opt/iobroker/backups/influxDB_2023_11_20-11_34_26_backupiobroker"
                            2023/11/20 11:34:26 INFO: Downloading metadata snapshot
                            [EXIT] 0
                            • L Laser
                              [EXIT] 0
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              Welche?
                              Bezeichnung ist egal.
                                Welche?
                                Laser
                                Jetzt heißt der neu generierte Token- in influx und Backitup eingetragen:
                                • L Laser
                                  Marc BergM Online
                                  Marc BergM Online
                                  Marc Berg
                                  Das ist doch aber der Falsche. Du muss den Operator Token (siehe oben) eintragen.
                                    Laser
                                    @marc-berg OK. kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg==
                                    dieser Token muß in den Backitup und influx - Adapter eingetragen werden? Mache ich jetzt.
                                    [DEBUG] [mount] - mount activ... umount is started before mount!!
                                    [DEBUG] [mount] - umount successfully completed
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_11_20-11_47_58_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker"
                                    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker" successfully deleted
                                    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== "/opt/iobroker/backups/influxDB_2023_11_20-11_48_11_backupiobroker"
                                    2023/11/20 11:48:11 INFO: Downloading metadata snapshot
                                    [EXIT] 0
                                    • L Laser
                                      [EXIT] 0
                                      Marc BergM Online
                                      Marc BergM Online
                                      Marc Berg
                                      Du willst mich jetzt vera.., oder?
                                      Ich hatte jetzt 3x geschrieben, dass dieser Token rein muss:
                                        Laser
                                        @marc-berg ich kapiere es nicht! Wo nehme ich den her? Aus der Ausgabe von:
                                        influx auth list -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== --json ?
                                        Da gibt es bei mir 4 Token:
                                        otto@raspberrypi:~ $ influx auth list -t kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg== --json
                                                        "status": "active",
                                                        "permissions": [
        "read:/buckets",
        "write:/buckets",
        "read:/dashboards",
        "read:/orgs",
        "write:/orgs",
        "read:/sources",
        "write:/sources",
        "read:/tasks",
        "write:/tasks",
        "read:/telegrafs",
        "write:/telegrafs",
        "read:/users",
        "write:/users",
        "read:/variables",
        "write:/variables",
        "read:/scrapers",
        "write:/scrapers",
        "read:/secrets",
        "write:/secrets",
        "read:/labels",
        "write:/labels",
        "read:/views",
        "write:/views",
        "read:/documents",
        "write:/documents",
        "read:/checks",
        "write:/checks",
        "read:/dbrp",
        "write:/dbrp",
        "read:/notebooks",
        "write:/notebooks",
        "read:/remotes",
        "write:/remotes",
                                                        "status": "active",
                                                        "permissions": [
                                                        "status": "active",
                                                        "permissions": [
                                                        "status": "active",
                                                        "permissions": [
                                                        "id": "0c271185effd8000",
                                                        "token": "kENxxP6hxicSqtd1R1akRkvk1QF8F9xqW0fmydbvHhCoy5KpRIjFam_H-NxW6u4aKxwaXia4i-1CSqr70HH8kg==",
                                                        "status": "active",
                                                        "permissions": [
                                        • L Laser
                                                          "status": "active",
                                                          "permissions": [
        "read:/buckets",
        "write:/buckets",
        "read:/dashboards",
        "read:/orgs",
        "write:/orgs",
        "read:/sources",
        "write:/sources",
        "read:/tasks",
        "write:/tasks",
        "read:/telegrafs",
        "write:/telegrafs",
        "read:/users",
        "write:/users",
        "read:/variables",
        "write:/variables",
        "read:/scrapers",
        "write:/scrapers",
        "read:/secrets",
        "write:/secrets",
        "read:/labels",
        "write:/labels",
        "read:/views",
        "write:/views",
        "read:/documents",
        "write:/documents",
        "read:/checks",
        "write:/checks",
        "read:/dbrp",
        "write:/dbrp",
        "read:/notebooks",
        "write:/notebooks",
        "read:/remotes",
        "write:/remotes",
                                                          "status": "active",
                                                          "permissions": [
                                                          "status": "active",
                                                          "permissions": [
                                                          "status": "active",
                                                          "permissions": [
                                                          "status": "active",
                                                          "permissions": [
                                          Marc BergM Online
                                          Marc BergM Online
                                          Marc Berg
                                          Korrekt, das ist aber in dem Dokument, welches @simatec dir verlinkt hatte, sehr gut beschrieben.
