  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 653.8k Aufrufe 64 Beobachtet
  • ralleR ralle
    @lucky_esa Danke werd ich noch machen. Habe aber auch erst wieder am Wochenende Zeit.
    Hab auch gerade gesehen das auf Github die 2.3.3 Version ist, habe versucht diese manuell zu Installieren, bricht leider mit Fehler ab...
    $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.worx --host raspberrypi --debug
    install iobroker-community-adapters/ioBroker.worx#39e3cae4ba62910c9a71a568aed53436902d8673
    NPM version: 8.19.4
    Installing iobroker-community-adapters/ioBroker.worx#39e3cae4ba62910c9a71a568aed53436902d8673... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws-crt' -> '/opt/iobroker/node_modules/.aws-crt-nzfhXYLj'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-10-02T07_21_09_454Z-debug-0.log
    Try to solve ENOTEMPTY error automatically
    host.raspberrypi deleted npm temp directory: ".aws-crt-nzfhXYLj")
    host.raspberrypi deleted npm temp directory: ".aws-iot-device-sdk-v2-pIy95WJq")
    host.raspberrypi deleted npm temp directory: ".iobroker.worx-xUH4AlzP")
    host.raspberrypi deleted npm temp directory: ".json2iob-u29WFlXK")
    host.raspberrypi deleted npm temp directory: ".uuid-hFM3FfPu")
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslib' -> '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/.tslib-d2Bg42ur'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-10-02T07_21_53_440Z-debug-0.log
    npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslibnpm ERR! dest /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/.tslib-d2Bg42urnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslib' -> '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/.tslib-d2Bg42ur'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-10-02T07_21_53_440Z-debug-0.loghost.raspberrypi Cannot install iobroker-community-adapters/ioBroker.worx#39e3cae4ba62910c9a71a568aed53436902d8673: 217
    ERROR: Process exited with code 25
    Thomas BraunT
    Thomas BraunT
    #1116
    @ralle
    Jag den
    iob fix
    über das System.
    • ralleR ralle
      NPM version: 8.19.4
      mcm1957M
      mcm1957M
      mcm1957
      #1117
      @ralle said in Adapter: Worx Landroid v2.x.x:
      Installation von GITHUB sollte NUR in Abstimmung mit dem Maintainer erfolgen. Auf Github kann jederzeit auch nicht funktionaler Code liegen der ggF deine ganze Installation lahmlegen kann.
      Was du meinst, ist dass es eine neuere Version 2.3.3 gibt die noch nicht im stable gelistet ist. Diese sollte KEINEFALLS einfach so von Github installiert werden. Du kannst diese Version von npm installieren bzw. ist diese im LATEST Repository verfügbar und kann via LATEST Repository ganz normal installiert werden.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • L
        L
        Lucky_ESA
        #1118
        Hallo Vision Nutzer,
        leider habe ich noch nicht alle Error - und Statusmeldungen zusammen. Kann jemand mit einem Vision mir mal 2 Errormeldungen simulieren?
        Fehlermeldung Licht zu schwach - Camera light too low
        Fehlermeldung Linse verschmutzt - Camera lens is dirty (was vor die Linse hängen)
        Die Meldungen könnt ihr dann aus dem DP worx.0.xxx.activityLog.payload entnehmen.
        Laut APP fehlen noch diese Meldungen;
               //{ App translate
               //    :"Battery Over Temperature",
               //    :"Calibration needed",
               //    :"Camera lens is dirty",
               //    :"Camera light too low",
               //    :"Charging station docking error",
               //    :"Excessive slope",
               //    :"HBI error",
               //    :"Headlight error",
               //    :"No Position",
               //    :"Map error",
               //    :"Lawn exploration failed",
               //    :"Firmware upgrade error",
               //    :"RFID reader error",
               //    :"Map training start not allowed",
               //    :"Unknown",
               //    :"Unreachable charging station",
               //    :"Unreachable zone",
        Gruß//Lucky
        • ralleR
          ralleR
          ralle
          #1119
          Gibt es einen Datenpunkt im Adapter wo ich den Mäher Resetten kann (z.B. wenn er sich festgefahren hat). Entweder bin ich blind oder.... :)
          • ralleR ralle
            S
            S
            saeft_2003
            schrieb am zuletzt editiert von saeft_2003
            #1120
            @ralle
            Sowas gibt es nicht auch nicht aus der App. Das muss man immer manuell machen…
            • S saeft_2003
              @ralle
              K
              K
              Kippe
              #1121
              @saeft_2003
              Also ich habe mir jetzt mal die ganzen Beiträge durchgelesen, aber ich denke keiner hat ein 100% Funktionierendes Skript am laufen, oder sehe ich das Falsch. Ich brauche ein Skript für 1 Zeitplan am Tag, und den Regenquatsch brauche ich auch nicht. Also wenn jemand was passendes Funktionierendes hat, und für mich das Skript zusammenbauen könnte würde ich mich sehr freuen. Ich bekomme es einfach nicht hin den Works nach Zeitplan fahren zu lassen.
              haselchenH S 2 Antworten Letzte Antwort
              • K Kippe
                @saeft_2003
                haselchenH
                haselchenH
                haselchen
                #1122
                @kippe
                Vielleicht zeigst Du mal Deine "Versuche".
                Ich denke , dass sich anhand Deiner , sagen wir mal Formulierungen in Deinem Post, keiner finden wird, der Dir das einfach mal so mundgerecht zusammenbaut.
                • K Kippe
                  @saeft_2003
                  S
                  S
                  saeft_2003
                  #1123
                  @kippe
                  Ich bin der Meinung das ein Großteil ein zu 100% funktionierendes Skript hat. Bei mir ist das auf jeden Fall so.
                  Zeig mal einen Screenshot von deinem Blockly wo die Zeiten gesetzt werden.
                  • S saeft_2003
                    @kippe
                    K
                    K
                    Kippe
                    #1124
                    @saeft_2003
                    Hier ist mein Skript
                    S L 2 Antworten Letzte Antwort
                    • K Kippe
                      @saeft_2003
                      S
                      S
                      saeft_2003
                      #1125
                      @kippe
                      Hier ist kein Objekt ausgewählt…
                      So sieht es bei mir aus
                      Gibt es bei dir unter JavaScript überhaupt die ganzen DP? Falls nein so die DP erstellen lassen indem man das einmal aktiviert….
                      • S saeft_2003
                        @kippe
                        K
                        K
                        Kippe
                        #1126
                        @saeft_2003
                        So sieht es jetzt bei mir aus.Die Datenpunkte sind da
                        • K Kippe
                          @saeft_2003
                          S
                          S
                          saeft_2003
                          #1127
                          @kippe
                          Ok ich würd mal versuchen ob es jetzt funktioniert
                          • K Kippe
                            @saeft_2003
                            L
                            L
                            Lucky_ESA
                            #1128
                            @kippe Welche Adapter Version hast du installiert?
                            • L Lucky_ESA
                              K
                              K
                              Kippe
                              #1129
                              @lucky_esa
                              2.3.4
                              • K Kippe
                                @lucky_esa
                                2.3.4
                                S
                                S
                                saeft_2003
                                #1130
                                @kippe sagte in Adapter: Worx Landroid v2.x.x:
                                @lucky_esa
                                2.3.4
                                Das ist die aktuelleste stable version. Somit passt das. Funktioniert dein Skript jetzt?
                                • S saeft_2003
                                  @lucky_esa
                                  2.3.4
                                  K
                                  K
                                  Kippe
                                  #1131
                                  @saeft_2003
                                  Hallo
                                  Nein nach Zeit geht noch nicht.Ich habe jetzt noch mal alle Skipte vom Rasenmäher gelöscht und habe das hier noch mal probiert, aber auch das funktioniert nicht bei mir.Ich habe noch mal alle Bilder hier hochgeladen, wie es jetzt ist.
                                  Den Datenpunkt in der View für Automatik ist doch der von meinem Adapter State oder? Und der für die Manuelle Fahrt ist doch der Datenpunkt vom JavaScript..oder ?
                                  Screenshot (585).png Screenshot (584).png Screenshot (583).png Screenshot (582).png Screenshot (581).png Screenshot (580).png
                                  • K Kippe
                                    @saeft_2003
                                    Hallo
                                    S
                                    S
                                    saeft_2003
                                    #1132
                                    @kippe
                                    Werden die Zeiten wo du in der VIS einstellst den unter worx.0.calendar eingetragen?
                                    Beachte die 3min Vorlauf. Also nicht um 15:29 15:30 einstellen sonst passiert nichts…
                                    • S saeft_2003
                                      @kippe
                                      K
                                      K
                                      Kippe
                                      #1133
                                      @saeft_2003
                                      Habe in der View den Automatikmodus auf 19Uhr und 50 Minuten eingestellt, und die Daten würden im worx.0 calender eingetragen.Den Button auf Grün gesetzt am Montag und mit 30 Minuten vorlauf hat sich nichts getan.🤕
                                      L 1 Antwort Letzte Antwort
                                      • K Kippe
                                        @saeft_2003
                                        L
                                        L
                                        Lucky_ESA
                                        #1134
                                        @kippe Es gibt hier im Forum nur eine Version die mit der aktuellen Worx Version läuft. Du hast wohl eine andere erwischt.
                                        Hier
                                        Gruß//Lucky
                                        • L Lucky_ESA
                                          Hier
                                          Gruß//Lucky
                                          K
                                          K
                                          Kippe
                                          #1135
                                          @lucky_esa
                                          Hallo
                                          Ich habe jetzt dein Skript und deine View einmal eingespielt.Wenn ich im Skript meine Seriennummer eingebe und auf speichern gehe, dann legt er mir in den Ordner 0/ userdata/ 0 /Mährobotor die Datenpunkte alle an. Nicht in den Java/ 0:
                                          Ist das so richtig ? Und die Datenpunkte von der View müssen alle mit den Ordner 0/userdata/0 /Mahrobotor verknüpft werden....... oder? 🤕
                                          83.9k
