  4. Backitup stürzt ab beim wiederherstellen.
16 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    @mcbeath sagte in Backitup stürzt ab beim wiederherstellen.:
    Könnte mir jemand helfen diesen Fehler zu beheben?
    iob diag
    sagt in der Langfassung?
    McBeath
    schrieb am zuletzt editiert von McBeath
    Hier das Log in Langfassung:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v6.1.0
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     22:35:29 up  4:55,  0 users,  load average: 2.81, 2.77, 2.53
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Nov 16 21:35:29 UTC 2023
    Thu Nov 16 22:35:29 CET 2023
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            7.8G        3.2G        528M        2.5G        4.1G        1.8G
    Swap:           6.7G        1.7G        5.1G
    Total:           14G        4.9G        5.6G
             7802 M total memory
             3192 M used memory
             1815 M active memory
             1809 M inactive memory
              528 M free memory
              740 M buffer memory
             3341 M swap cache
             6727 M total swap
             1660 M used swap
             5067 M free swap
    *** FILESYSTEM ***
    Filesystem        Type   Size  Used Avail Use% Mounted on
    none              aufs   289G   99G  191G  34% /
    tmpfs             tmpfs   64M     0   64M   0% /dev
    tmpfs             tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
    shm               tmpfs   64M     0   64M   0% /dev/shm
    /dev/vg1/volume_1 ext4   289G   99G  191G  34% /opt/iobroker
    tmpfs             tmpfs  3.9G     0  3.9G   0% /proc/acpi
    tmpfs             tmpfs  3.9G     0  3.9G   0% /proc/scsi
    tmpfs             tmpfs  3.9G     0  3.9G   0% /sys/firmware
    [Thu Nov 16 17:41:13 2023] EXT4-fs (md0): barriers disabled
    [Thu Nov 16 17:41:13 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
    [Thu Nov 16 17:41:15 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Thu Nov 16 17:41:17 2023] EXT4-fs (md0): re-mounted. Opts: (null)
    [Thu Nov 16 17:41:39 2023] EXT4-fs (dm-1): barriers disabled
    [Thu Nov 16 17:41:39 2023] EXT4-fs (dm-1): 6 orphan inodes deleted
    [Thu Nov 16 17:41:40 2023] EXT4-fs (dm-1): recovery complete
    [Thu Nov 16 17:41:40 2023] EXT4-fs (dm-1): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,data=writeback
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  none        aufs   rw,relatime,si=c2ca6b475292e9b,dio,dirperm1
    |-/opt/iobroker    /dev/vg1/volume_1[/docker/IOBroker/Mount/opt-iobroker]                                                              ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
    |-/opt/userscripts /dev/vg1/volume_1[/docker/IOBroker/Mount/opt-userscripts]                                                           ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
    |-/etc/resolv.conf /dev/vg1/volume_1[/@docker/containers/a910e7d23e46f1e40a9bf788d878f2eef09b7a744444e405a5c19d4c6ac0d974/resolv.conf] ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
    |-/etc/hostname    /dev/vg1/volume_1[/@docker/containers/a910e7d23e46f1e40a9bf788d878f2eef09b7a744444e405a5c19d4c6ac0d974/hostname]    ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
    `-/etc/hosts       /dev/vg1/volume_1[/@docker/containers/a910e7d23e46f1e40a9bf788d878f2eef09b7a744444e405a5c19d4c6ac0d974/hosts]       ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
    /var:
    34M     /var/
    31M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg/info
    /opt/iobroker/backups:
    28M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
               44M     /opt/iobroker/iobroker-data/
               14M     /opt/iobroker/iobroker-data/files
               13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
               29M     /opt/iobroker/iobroker-data/objects.jsonl
               6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
               2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
               1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
               944K    /opt/iobroker/iobroker-data/states.jsonl
               USB-Devices by-id:
               find: '/dev/serial/by-id/': No such file or directory
               *** NodeJS-Installation ***
               /home/iobroker/.diag.sh: line 277: nodejs: command not found
               /usr/bin/node           v18.17.1
               /usr/bin/npm            9.6.7
               /usr/bin/npx            9.6.7
               /usr/bin/corepack       0.18.0
               /home/iobroker/.diag.sh: line 288: nodejs: command not found
               *** nodejs is NOT correctly installed ***
               nodejs:
                 Installed: 18.17.1-deb-1nodesource1
                 Candidate: 18.17.1-deb-1nodesource1
                 Version table:
                *** 18.17.1-deb-1nodesource1 500
                       500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                    12.22.12~dfsg-1~deb11u4 500
                       500 http://deb.debian.org/debian bullseye/main amd64 Packages
                       500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : buanet-iobroker2                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : buanet-iobroker2                         -  enabled
      system.adapter.enocean.0                : enocean               : buanet-iobroker2                         - disabled
      system.adapter.viessmann.0              : viessmann             : buanet-iobroker2                         - disabled, port: 3002
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.12.4   , installed 6.12.0 [Updatable]
    Adapter    "backitup"     : 2.9.3    , installed 2.8.7  [Updatable]
    Adapter    "enocean"      : 0.9.2    , installed 0.9.2
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "viessmann"    : 1.4.6    , installed 1.4.6
    Objects and States
    Objects:        214
    States:         113
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1875031    -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1875024    -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1874340    -
    2023-11-16 22:33:37.275  - info: host.buanet-iobroker2 4 instances found
    2023-11-16 22:33:37.288  - info: host.buanet-iobroker2 starting 2 instances
    2023-11-16 22:33:37.348  - info: host.buanet-iobroker2 Delete state "system.host.buanet-iobroker2.versions.nodeNewest"
    2023-11-16 22:33:37.359  - info: host.buanet-iobroker2 Delete state "system.host.buanet-iobroker2.versions.nodeNewestNext"
    2023-11-16 22:33:37.366  - info: host.buanet-iobroker2 Delete state "system.host.buanet-iobroker2.versions.npmCurrent"
    2023-11-16 22:33:37.372  - info: host.buanet-iobroker2 Delete state "system.host.buanet-iobroker2.versions.npmNewest"
    2023-11-16 22:33:37.380  - info: host.buanet-iobroker2 Delete state "system.host.buanet-iobroker2.versions.npmNewestNext"
    2023-11-16 22:33:37.387  - info: host.buanet-iobroker2 Some obsolete host states deleted.
    2023-11-16 22:33:37.427  - info: host.buanet-iobroker2 instance system.adapter.admin.0 started with pid 142
    2023-11-16 22:33:37.578  - warn: host.buanet-iobroker2 Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+ep
    i /usr/bin/node
    Failed to set capabilities on file `/usr/bin/node' (Operation not supported)
    The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
    2023-11-16 22:33:41.375  - info: host.buanet-iobroker2 instance system.adapter.backitup.0 started with pid 150
    2023-11-16 22:33:43.608  - info: backitup.0 (150) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.16
    2023-11-16 22:33:44.144  - info: backitup.0 (150) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-11-16 22:33:45.569  - info: admin.0 (142) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.16
    2023-11-16 22:33:45.617  - info: admin.0 (142) requesting all objects
    2023-11-16 22:33:46.698  - info: admin.0 (142) received all objects
    2023-11-16 22:33:47.025  - info: admin.0 (142) Request actual repository...
    2023-11-16 22:33:47.048  - info: admin.0 (142) socket.io server listening on port 8081
    2023-11-16 22:33:47.051  - info: admin.0 (142) http server listening on port 8081
    2023-11-16 22:33:47.052  - info: admin.0 (142) Use link "http://127.0.0.1:8081" to configure.
    2023-11-16 22:33:47.754  - info: host.buanet-iobroker2 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-11-16 22:33:51.112  - info: admin.0 (142) Repository received successfully.
    iob diag has finished.
    Press any key for a summary
    hat etwas gedauert alles aus dem Terminalfenster zu kopieren...
    • M McBeath
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v6.1.0
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
      CET +0100
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
               7802 M total memory
               3192 M used memory
                528 M free memory
                740 M buffer memory
               3341 M swap cache
               6727 M total swap
               1660 M used swap
               5067 M free swap
      *** FILESYSTEM ***
      /var:
      34M     /var/
      31M     /var/lib
      18M     /var/lib/apt
                 USB-Devices by-id:
                 /usr/bin/npm            9.6.7
                 /usr/bin/npx            9.6.7
                 nodejs:
                   Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        214
      States:         113
      Pending Updates: 0
      i /usr/bin/node
      Docker : v6.1.0
      Steinalt.
      M 2 Antworten Letzte Antwort
        Docker : v6.1.0
        Steinalt.
        McBeath
        OKAY.... ?!?
        schau mal nach einem update....
        • M McBeath
          OKAY.... ?!?
          @mcbeath
          Aktuell ist irgendwas mit 9.x
            Docker : v6.1.0
            Steinalt.
            McBeath
            @thomas-braun said in Backitup stürzt ab beim wiederherstellen.:
            Docker : v6.1.0
            Steinalt.
            Instalierte Version laut Syno: 20.10.3-0554
            Vertügbare Verion laut Syno: 20.10.3-0554
            Thomas BraunT M 2 Antworten Letzte Antwort
            • M McBeath
              Docker : v6.1.0
              Steinalt.
              @mcbeath
              Keine Ahnung was du da anschaust, aber die Docker-Büchsen finden sich hier:
              https://hub.docker.com/r/buanet/iobroker
              • M McBeath
                Docker : v6.1.0
                Steinalt.
                McBeath
                @mcbeath said in Backitup stürzt ab beim wiederherstellen.:
                Docker : v6.1.0
                Steinalt.
                Das war die Version von Docker selber, auf der Synology.
                du meintest die Version vom iob.
                Plattform: docker (official image - v6.1.0) das steht im IOB unter info :/
                • M McBeath
                  Docker : v6.1.0
                  Steinalt.
                  Nein, ich meine die Version des Docker-Containers/Images (oder wie man es auch nennen mag).
                    McBeath
                    Ich habe das über das offizielle Image buanet/iobroker:latest installiert.
                    Wenn ich das drauf klicke, lande ich auch bei 9.0.1 wie von dir oben angegeben.
                    • M McBeath
                      @mcbeath
                      Ich hab mit Docker keinen Vertrag...
                      Ich weiß nur, dass die aktuelle Ausgabe V9.0.1 lautet, bei dir eine 6.1.0 erkannt wird. Also steinalt.
                        @mcbeath
                        McBeath
                        Ich werf nochmal einen neuen Container an und schaue mal was da rauskommt....
                        • M McBeath
                          McBeath
                          Hier mal das lange Log vom neuen Container, ist auch jetzt 9.0.1 :)
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                          Kernel          : x86_64
                          Userland        : amd64
                          Docker          : v9.0.1
                          Kernel          : x86_64
                          Userland        : amd64
                           23:36:33 up  5:56,  0 user,  load average: 2.65, 3.10, 3.22
                          CPU threads: 4
                          Thu Nov 16 22:36:33 UTC 2023
                          Thu Nov 16 23:36:33 CET 2023
                          CET +0100
                          Etc/UTC
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:            8.2G        6.1G        407M        2.5G        4.5G        2.1G
                          Swap:           7.1G        1.9G        5.1G
                          Total:           15G        8.0G        5.5G
                                   7802 M total memory
                                   5818 M used memory
                                   1681 M active memory
                                   1766 M inactive memory
                                    388 M free memory
                                    236 M buffer memory
                                   4066 M swap cache
                                   6727 M total swap
                                   1854 M used swap
                                   4873 M free swap
                          *** FILESYSTEM ***
                          none              aufs   289G  101G  188G  35% /
                          /dev/vg1/volume_1 ext4   289G  101G  188G  35% /opt/iobroker
                          /                  none        aufs   rw,relatime,si=c2ca6b43b8d3e9b,dio,dirperm1
                          |-/opt/iobroker    /dev/vg1/volume_1[/docker/IOBroker/Mount/opt-iobbroker3]                                                            ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
                          |-/etc/resolv.conf /dev/vg1/volume_1[/@docker/containers/069d97e9be89eb084e51c93507ea0f9f256a01f6e9c7c3e1c770a22a9218e9b1/resolv.conf] ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
                          |-/etc/hostname    /dev/vg1/volume_1[/@docker/containers/069d97e9be89eb084e51c93507ea0f9f256a01f6e9c7c3e1c770a22a9218e9b1/hostname]    ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
                          `-/etc/hosts       /dev/vg1/volume_1[/@docker/containers/069d97e9be89eb084e51c93507ea0f9f256a01f6e9c7c3e1c770a22a9218e9b1/hosts]       ext4   rw,relatime,synoacl,data=writeback,jqfmt=vfsv0,usrjquot
                          /var:
                          34M     /var/
                          32M     /var/lib
                          19M     /var/lib/apt/lists
                          19M     /var/lib/apt
                          13M     /var/lib/dpkg
                          14M     /opt/iobroker/backups/
                          19M     /opt/iobroker/iobroker-data/
                          15M     /opt/iobroker/iobroker-data/files
                          4.0M    /opt/iobroker/iobroker-data/objects.jsonl
                          652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                          USB-Devices by-id:
                          /usr/bin/nodejs         v18.18.2
                          /usr/bin/node           v18.18.2
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          /usr/bin/corepack       0.19.0
                          nodejs:
                            Installed: 18.18.2-1nodesource1
                            Candidate: 18.18.2-1nodesource1
                            Version table:
                           *** 18.18.2-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                               18.18.1-1nodesource1 500
                               18.18.0-1nodesource1 500
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0+dfsg1-1 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker-iobroker1                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : iobroker-iobroker1                       -  enabled
                          + system.adapter.discovery.0              : discovery             : iobroker-iobroker1                       -  enabled
                          + instance is alive
                          Active repo(s): stable
                          Used repository: stable
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                          Objects and States
                          Objects:        146
                          States:         103
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2354108    -
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2356763    -
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2359355    -
                          2023-11-16 23:34:12.041  - info: host.iobroker-iobroker1 Delete state "system.host.iobroker-iobroker1.versions.nodeNewestNext"
                          2023-11-16 23:34:12.046  - info: host.iobroker-iobroker1 Delete state "system.host.iobroker-iobroker1.versions.npmCurrent"
                          2023-11-16 23:34:12.052  - info: host.iobroker-iobroker1 Delete state "system.host.iobroker-iobroker1.versions.npmNewest"
                          2023-11-16 23:34:12.057  - info: host.iobroker-iobroker1 Delete state "system.host.iobroker-iobroker1.versions.npmNewestNext"
                          2023-11-16 23:34:12.062  - info: host.iobroker-iobroker1 Some obsolete host states deleted.
                          2023-11-16 23:34:14.273  - info: admin.0 (172) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.16
                          2023-11-16 23:34:14.325  - info: admin.0 (172) requesting all objects
                          2023-11-16 23:34:14.667  - info: admin.0 (172) received all objects
                          2023-11-16 23:34:14.808  - info: admin.0 (172) Request actual repository...
                          2023-11-16 23:34:14.843  - info: admin.0 (172) socket.io server listening on port 8081
                          2023-11-16 23:34:14.847  - info: admin.0 (172) http server listening on port 8081
                          2023-11-16 23:34:14.848  - info: admin.0 (172) Use link "http://127.0.0.1:8081" to configure.
                          2023-11-16 23:34:15.106  - info: host.iobroker-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          2023-11-16 23:34:16.179  - info: host.iobroker-iobroker1 instance system.adapter.discovery.0 started with pid 217
                          2023-11-16 23:34:16.328  - info: admin.0 (172) Repository received successfully.
                          2023-11-16 23:34:17.984  - info: discovery.0 (217) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.16
                          2023-11-16 23:34:19.968  - info: host.iobroker-iobroker1 instance system.adapter.backitup.0 started with pid 232
                          2023-11-16 23:34:21.781  - info: backitup.0 (232) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.16
                          2023-11-16 23:34:21.842  - error: backitup.0 (232) [ERROR] [iobroker] No host object found, your backup seems to be corrupted!
                          2023-11-16 23:34:21.870  - info: backitup.0 (232) [iobroker] backup will be activated at 02:40 every 1 day(s)
                          2023-11-16 23:34:55.321  - info: admin.0 (172) ==> Connected system.user.admin from ::ffff:172.17.0.1
                          2023-11-16 23:34:56.551  - info: admin.0 (172) ==> Connected system.user.admin from ::ffff:172.17.0.1
                          2023-11-16 23:35:00.033  - info: admin.0 (172) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                          2023-11-16 23:35:41.347  - info: admin.0 (172) ==> Connected system.user.admin from ::ffff:172.17.0.1
                          2023-11-16 23:35:48.112  - info: admin.0 (172) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                          Hier sagt er bein Backup, es wäre coruppted
                          Kann das an der unterschiedlichen js-controller version liegen?
                          Das backup hat noch die version 4.0.24 der neue Container 5.0.12
                          • M McBeath
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v9.0.1
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 4
                            CET +0100
                            Etc/UTC
                            root
                            /root
                            root
                            X-Server:       false
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                                     7802 M total memory
                                     5818 M used memory
                                      388 M free memory
                                      236 M buffer memory
                                     4066 M swap cache
                                     6727 M total swap
                                     1854 M used swap
                                     4873 M free swap
                            *** FILESYSTEM ***
                            /var:
                            34M     /var/
                            32M     /var/lib
                            19M     /var/lib/apt
                            13M     /var/lib/dpkg
                            USB-Devices by-id:
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        146
                            States:         103
                            Pending Updates: 0
                            Ja.
                              Ja.
                              McBeath
                              Das hatte ich befürchtet, weil der sich nicht aktualiesieren lassen will laut Anleitung, dachte ich mir das ich einfach auf einen neuen Container per Backup umziehen kann. :(
                              Gibt es denn noch einen Weg wie ich zumindes die ganzen Datenpunkte vom alten in den neuen bekomme, ohne alle manuell neu anlegen zu müssen?
                              edit:
                              Hab es schon gefunden, in den Objekten über die beiden Pfeile hoch und runter kann man Im- und Exportierne. 😄
                              Hätte ich auch gleich sehen können, schande über mein Haupt.... 😅
