  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • W Offline
    W Offline
    woupi
    #95
    leider muss ich dieses Thema nochmal hervorholen.
    Ich habe heute einen Sonoff Zigbee Stick bekommen.
    Ich habe ihn in den NUC gesteckt und in Proxmox zur VM iobroker durch gereicht.
    ls -la /dev/serial/by-id/ ergibt
    total 0
    drwxr-xr-x 2 root root 80 Nov  7 17:44 .
    drwxr-xr-x 4 root root 80 Nov  7 17:44 ..
    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-1a86_USB_Serial-if00-port0 -> ../../t        tyUSB1
    lrwxrwxrwx 1 root root 13 Nov  7 17:44 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl        us_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0 -> ../../ttyUSB0
    Eingegeben unter COM-Anschluss im Adapter habe ich
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0
    Hier der komplette log
    zigbee.0
    2023-11-07 19:16:24.684	error	Error herdsman start
    zigbee.0
    2023-11-07 19:16:24.684	error	Failed to start Zigbee
    zigbee.0
    2023-11-07 19:16:24.684	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-11-07 19:16:24.604	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-11-07 19:16:24.596	info	Starting Zigbee npm ...
    zigbee.0
    2023-11-07 19:16:24.596	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-11-07 19:16:14.595	error	Error herdsman start
    zigbee.0
    2023-11-07 19:16:14.594	error	Failed to start Zigbee
    zigbee.0
    2023-11-07 19:16:14.594	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2023-11-07 19:16:14.532	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2023-11-07 19:16:14.532	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2023-11-07 19:16:14.532	error	Please update configuration to prevent further issues.
    zigbee.0
    2023-11-07 19:16:14.532	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2023-11-07 19:16:14.532	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2023-11-07 19:16:14.531	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
    zigbee.0
    2023-11-07 19:16:14.531	error	- PAN ID: configured=6258, adapter=6258
    zigbee.0
    2023-11-07 19:16:14.531	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    2023-11-07 19:16:14.261	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-11-07 19:16:14.159	info	Starting Zigbee npm ...
    zigbee.0
    2023-11-07 19:16:14.097	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
    zigbee.0
    2023-11-07 19:15:37.122	info	terminating
    zigbee.0
    2023-11-07 19:15:36.683	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2023-11-07 19:15:36.683	info	terminating
    zigbee.0
    2023-11-07 19:15:36.674	warn	Failed to stop zigbee during startup
    zigbee.0
    2023-11-07 19:15:36.625	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-11-07 19:15:36.622	info	cleaned everything up...
    zigbee.0
    2023-11-07 19:15:36.621	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2023-11-07 19:09:56.448	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2023-11-07 19:09:56.370	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2023-11-07 18:28:27.996	info	List of port: [{"path":"/dev/ttyUSB1","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"c24d83bbb59ded11acdcdba5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d83bbb59ded11acdcdba5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2023-11-07 18:28:27.938	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2023-11-07 18:26:08.388	error	Error herdsman start
    zigbee.0
    2023-11-07 18:26:08.388	error	Failed to start Zigbee
    zigbee.0
    2023-11-07 18:26:08.388	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-11-07 18:26:08.293	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-11-07 18:26:08.278	info	Starting Zigbee npm ...
    zigbee.0
    2023-11-07 18:26:08.277	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-11-07 18:25:58.275	error	Error herdsman start
    zigbee.0
    2023-11-07 18:25:58.275	error	Failed to start Zigbee
    zigbee.0
    2023-11-07 18:25:58.275	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2023-11-07 18:25:58.233	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2023-11-07 18:25:58.233	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2023-11-07 18:25:58.233	error	Please update configuration to prevent further issues.
    zigbee.0
    2023-11-07 18:25:58.233	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2023-11-07 18:25:58.232	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2023-11-07 18:25:58.232	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
    zigbee.0
    2023-11-07 18:25:58.232	error	- PAN ID: configured=6258, adapter=6258
    zigbee.0
    2023-11-07 18:25:58.232	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    2023-11-07 18:25:57.935	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-11-07 18:25:57.803	info	Starting Zigbee npm ...
    zigbee.0
    2023-11-07 18:25:57.758	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
    zigbee.0
    2023-11-07 18:25:54.553	info	Terminated (NO_ERROR): Without reason
    zigbee.0
    2023-11-07 18:25:54.552	info	terminating
    zigbee.0
    2023-11-07 18:25:54.122	error	Error herdsman start
    zigbee.0
    2023-11-07 18:25:54.122	error	Failed to start Zigbee
    zigbee.0
    2023-11-07 18:25:54.121	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2023-11-07 18:25:54.075	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2023-11-07 18:25:54.075	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2023-11-07 18:25:54.075	error	Please update configuration to prevent further issues.
    zigbee.0
    2023-11-07 18:25:54.074	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2023-11-07 18:25:54.074	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2023-11-07 18:25:54.074	error	- Extended PAN ID: configured=dfddfddddddddeed, adapter=00124b002b48282c
    zigbee.0
    2023-11-07 18:25:54.074	error	- PAN ID: configured=6258, adapter=6258
    zigbee.0
    2023-11-07 18:25:54.074	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    2023-11-07 18:25:54.052	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-11-07 18:25:54.049	info	cleaned everything up...
    zigbee.0
    2023-11-07 18:25:53.725	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.0
    2023-11-07 18:25:53.628	info	Starting Zigbee npm ...
    zigbee.0
    2023-11-07 18:25:53.582	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
    zigbee.0
    2023-11-07 18:25:21.806	info	terminating
    zigbee.0
    2023-11-07 18:25:21.336	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2023-11-07 18:25:21.335	info	terminating
    zigbee.0
    2023-11-07 18:25:21.335	warn	Failed to stop zigbee during startup
    zigbee.0
    2023-11-07 18:25:21.309	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-11-07 18:25:21.306	info	cleaned everything up...
    zigbee.0
    2023-11-07 18:25:21.299	error	Cannot read properties of undefined (reading 'getClients')
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    Wenn ich es richtig verstanden habe, stimmt etwas nicht mit dem Adapterstatus/Backup überein.
    Ich habe allerdings keine Ahnung was und auch nicht wo ich etwas ändern kann.
    Ich würde mich freuen, wenn einem unwissenden etwas unter die Arme gegriffen werden könnte.
    Vielen Dank und VG
    NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
    • W woupi
      total 0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Vielen Dank und VG
      #96
      @woupi
      Die Werte müssen übereinstimmen.
      W 1 Antwort Letzte Antwort
        @woupi
        W Offline
        W Offline
        woupi
        #97
        @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
        00124b002b48282c
        Super, vielen Dank. Ich habe mich nicht getraut das einzutragen, jetzt habe ich es einfach rein kopiert und siehe da funktioniert.
        Nochmal vielen Dank
        • tiobbT Offline
          tiobbT Offline
          tiobb
          #98
          Hallo, ich hänge mich hier mal rein. Mein Zigbee will auch einfach nicht laufen, habe schon einiges ausprobiert was hier so geschrieben wurde, leider ohne Erfolg. Ich hoffe ihr könnt mir helfen. Wie ihr wisst, bin ich ein absoluter Anfänger, wenn möglich für ganz ganz doofe erklären.
          permitted by applicable law.
          Last login: Fri Nov  3 17:54:35 2023 from 192.168.178.45
          pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
          insgesamt 0
          drwxr-xr-x 2 root root 60 Nov 13 14:01 .
          drwxr-xr-x 4 root root 80 Nov 13 14:01 ..
          lrwxrwxrwx 1 root root 13 Nov 13 14:01 usb-Texas_Instruments_TI_CC2531_USB_CDC__
          Opera Momentaufnahme_2023-11-13_151230_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151201_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151139_192.168.178.76.png Opera Momentaufnahme_2023-11-13_151104_192.168.178.76.png
          Raspberry Pi 4 8gb
          • tiobbT tiobb
            insgesamt 0
            #99
            @tiobb
            Der Geräte-Link ist ja auch offensichtlich falsch.
            In den Einstellungen muss
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC__
            eingetragen werden. Wobei mir der Dateiname auch irgendwie abgeschnitten aussieht.
            tiobbT 1 Antwort Letzte Antwort
              @tiobb
              tiobbT Offline
              tiobbT Offline
              tiobb
              schrieb am zuletzt editiert von tiobb
              #100
              Wenn ich das als code eingebe wird der Eintrag beschnitten.
              insgesamt 0
              lrwxrwxrwx 1 root root 13 Nov 13 14:01 usb-Texas_Instruments_TI_CC2531_USB_CDC__ _0X00124B001CDD4A3A-if00 -> ../../ttyACM0
              Raspberry Pi 4 8gb
              • tiobbT tiobb
                insgesamt 0
                #101
                @tiobb sagte in Zigbee iobroker Error while opening serialport:
                Der Eintrag im Adapter muss also
                /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
                lauten. Am besten kopieren. Der vollständige Link steht aber als Service auch in der Ausgabe von
                iob diag
                fertig zum kopieren drin.
                  iob diag
                  tiobbT Offline
                  tiobbT Offline
                  tiobb
                  #102
                  Ok danke, jetzt scheint es zu funktionieren, bin der Meinung ich hatte das schon genauso in den Einstellungen stehen, aber wahrscheinlich irre ich mich.
                  Raspberry Pi 4 8gb
                  • tiobbT tiobb
                    #103
                    In deinen Screenshots definitiv nicht.
                      tiobbT Offline
                      tiobbT Offline
                      tiobb
                      #104
                      Ich hatte ja schon einiges probiert, aber egal, jetzt scheint es zu funktionieren, zumindest ist alles grün. Für meine Sensoren und den Bewegungsmelder von Aqara brauche ich erstmal neue Batterien ☺
                      Raspberry Pi 4 8gb
                      • G Offline
                        Greenhorn
                        #105
                        Ich hänge mich hier mal an mit meinem Problem:
                        Versuche auch den Sonoff Zigbee 3.0 USB Dongle Plus am Raspi 4B zum Laufen zu bringen, aber leider ohne Erfolg :-(
                        Bekomme die Meldung "You need save and run adapter before pairing!"
                        Als Port habe ich den genauen Pfad angegeben:
                        dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                        Die erweiterte und die Pan-ID habe ich geändert, schon tausendmal neu gestartet, nix ändert sich. Bin mit meinem Latein nach Stunden am Ende und würde mich freuen, hier Hilfe zu bekommen...
                        Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                        • G Greenhorn
                          #106
                          @greenhorn
                          Genaues Log vom Adapter-Start?
                          G 1 Antwort Letzte Antwort
                          • G Greenhorn
                            Meister MopperM Offline
                            Meister Mopper
                            #107
                            @greenhorn sagte in Zigbee iobroker Error while opening serialport:
                            Und zeig mal das Ergebnis ls -lAh /dev/serial/by-id
                            Proxmox und HA ...
                              Greenhorn
                              #108
                              @meister-mopper sagte in Zigbee iobroker Error while opening serialport:
                              simon@iobroker:~ $ ls -lAh /dev/serial/by-id
                              total 0
                              lrwxrwxrwx 1 root root 13 Jan 14 13:56 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0 -> ../../ttyUSB0
                                @greenhorn
                                Greenhorn
                                #109
                                Wie mein Username schon sagt bin ich ein absolutes Greenhorn und google mir mein Raspberry-Wissen zusammen. Zum Auslesen der Log-Datei des IOBrokers habe ich jetzt aber keinen Befehl gefunden...
                                • G Greenhorn
                                  #110
                                  @greenhorn
                                  iob logs --watch
                                  in dein Terminal hacken und dann den Adapter starten.
                                    @greenhorn
                                    iob logs --watch
                                    Greenhorn
                                    #111
                                    Hoffe, das ist brauchbar:
                                    iob logs --watch
                                    2024-01-14 17:19:42.262 - info: host.iobroker "system.adapter.zigbee.0" enabled
                                    2024-01-14 17:19:42.390 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 2671
                                    2024-01-14 17:19:44.883 - warn: shelly.0 (718) [authEnabled] 192.168.178.37 (shellyplus1pm / shellyplus1pm-b0b21c1b1e9c / shellyplus1pm#b0b21c1b1e9c#1): This device is not protected via restricted login (see adapter documentation for details)
                                    2024-01-14 17:19:46.988 - info: zigbee.0 (2671) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 4.0.24
                                    2024-01-14 17:19:47.137 - info: zigbee.0 (2671) delete old Backup files. keep only last 10
                                    2024-01-14 17:19:47.139 - info: zigbee.0 (2671) Starting Zigbee npm ...
                                    2024-01-14 17:19:47.464 - error: zigbee.0 (2671) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0'"
                                    2024-01-14 17:19:47.465 - error: zigbee.0 (2671) Failed to start Zigbee
                                    2024-01-14 17:19:47.466 - error: zigbee.0 (2671) Error herdsman start
                                    2024-01-14 17:19:47.930 - info: zigbee.0 (2671) Installed Version: iobroker.zigbee@1.9.7
                                    • G Greenhorn
                                      iob logs --watch
                                      #112
                                      @greenhorn
                                      Finde den Unterschied:
                                      Richtig wäre:
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
                                      • G Greenhorn
                                        iob logs --watch
                                        Meister Mopper
                                        #113
                                        @greenhorn
                                        As i thought.
                                        Proxmox und HA ...
                                          @greenhorn
                                          As i thought.
                                          Greenhorn
                                          #114
                                          @meister-mopper
                                          🤦 Meine Augen waren auch schonmal besser...
                                          Aber leider gehts immer noch nicht:
                                          2024-01-14 17:41:08.404 - error: zigbee.0 (2895) Configuration is not consistent with adapter state/backup!
                                          2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - PAN ID: configured=1964, adapter=1964
                                          2024-01-14 17:41:08.405 - error: zigbee.0 (2895) - Extended PAN ID: configured=24dddddddfddddab, adapter=00124b002c3a7ef1
                                          2024-01-14 17:41:08.406 - error: zigbee.0 (2895) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                          2024-01-14 17:41:08.407 - error: zigbee.0 (2895) - Channel List: configured=11, adapter=11
                                          2024-01-14 17:41:08.408 - error: zigbee.0 (2895) Please update configuration to prevent further issues.
                                          2024-01-14 17:41:08.409 - error: zigbee.0 (2895) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                          2024-01-14 17:41:08.410 - error: zigbee.0 (2895) Re-commissioning your network will require re-pairing of all devices!
                                          2024-01-14 17:41:08.514 - error: zigbee.0 (2895) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                          2024-01-14 17:41:08.515 - error: zigbee.0 (2895) Failed to start Zigbee
                                          2024-01-14 17:41:08.516 - error: zigbee.0 (2895) Error herdsman start
                                          2024-01-14 17:41:08.210 - info: zigbee.0 (2895) Installed Version: iobroker.zigbee@1.9.7
