  4. Cannot find module iobroker.js-controller/iobroker.js
19 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • B Bibo*13
    @thomas-braun Das ist das Summary; sieht irgendwie nicht gesund aus.
                            v.2023-10-10
       Static hostname: iobrokermaster
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.18.2
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            7.9G         86M        6.7G        0.0K        1.1G        7.5G
    Swap:            99M          0B         99M
    Total:          8.0G         86M        6.8G
      throw err;
      requireStack: []
    Node.js v18.18.2
    Active iob-Instances:   0
      throw err;
      requireStack: []
    Node.js v18.18.2
      throw err;
      requireStack: []
    Node.js v18.18.2
    ioBroker Core:          js-controller
      throw err;
      requireStack: []
    Node.js v18.18.2
                            admin
      throw err;
      requireStack: []
    Node.js v18.18.2
    ioBroker Status:
      throw err;
      requireStack: []
    Node.js v18.18.2
    Objects:                0
    States:                 0
    Size of iob-Database:
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/objects.json.migrated
    19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12K     /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.0K    /opt/iobroker/iobroker-data/states.json.old
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    Thomas BraunT Offline
    @bibo-13
    Auf ein Rpi5 knallt man kein Bullseye, da muss ein aktuelles Bookworm drauf. Das Release ist extra für den RPi5 verschoben worden, weil hier diverse Dinge an die andere Hardware angepasst worden sind.
    B 2 Antworten Letzte Antwort
      @bibo-13
      Bibo*13
      @thomas-braun Das ist kein Raspi5 sondern ein 4er.
      • B Bibo*13
        @bibo-13
        Und warum pistest du es dann unter der Überschrift 'Rpi5 im anrollen '???
        Thema verfehlt, setzen.
          @bibo-13
          Bibo*13
          @thomas-braun Ich bin vielleicht im falschen Slot aber der Fehler der Auftritt hat mich nach Forum Suche hierher geführt.
            @bibo-13
            Bibo*13
            @thomas-braun Was soll ich machen? Einen neuen Slot eröffnen. Sorry für den falschen Post.
            • B Bibo*13
              @bibo-13
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                @bibo-13
                cd /opt/iobroker
                Bibo*13
                @thomas-braun Ok Danke. Ich hab ihn wieder am laufen. Ich hoffe das ich die Adapter Updates machen kann.
                Schaun wir mal.
                Nochmal herzlichen Dank für Deine Arbeit und schönes WE
                • B Bibo*13
                  @bibo-13 sagte in Fehler bei web update:
                  Hab das hier abgetrennt.
                  bitte noch den provisorischen Threadtitel sinnvoll ändern!
                  N 1 Antwort Letzte Antwort
                    N Offline
                    N Offline
                    nobl
                    schrieb am zuletzt editiert von nobl
                    Das Problem habe ich seit heute auch auf meiner Debian Installation. (Nachdem Adapter-Updates gelaufen sind.)
                    Versuche gerade herauszufinden, ob es ein bestimmter Adapter ist, dessen Update das ganze hervorruft.
                    Das Problem geht so weit, dass /opt/iobroker/node_modules/iobroker.js-controller/ quasi komplett geleert wird und nur noch das "node_modules" Verzeichnis darin zu finden ist.
                    • N nobl
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @nobl
                      Iob diag in der langfassung bitte
                      Und info was du wie aktualusiett hast...
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        @nobl
                        N Offline
                        N Offline
                        nobl
                        @mcm57 kommt, sobald ich das Problem eingrenzen konnte.
                        Hatte gestern nach Restore dann keine Zeit mehr.
                        Edit:
                        So - alles Mögliche jetzt probiert, um das Phänomen nachzustellen - (leider) erfolglos.
                        Das ist mir gestern mehrfach passiert und iob diag hat dann auch seitenweise rote Meldungen geworfen (leider nicht gesichert).
                        Das Einzige, was ich jetzt nicht nachstellen kann: Adapter Update läuft, in Hintergrund gestellt und dann parallel ein Blockly angepasst.
                        • N nobl
                          Edit:
                          @nobl sagte in Cannot find module iobroker.js-controller/iobroker.js:
                          Dann mach es nochmal...
                          Das Log dazu liegt aber auch in /home/iobroker herum...
                          • N nobl
                            Edit:
                            und damit ist jetzt alles mögliche geändert und der Status den die Helfenden hatten gilt nicht mehr?
                              N Offline
                              N Offline
                              nobl
                              @homoran es ist vielleicht nicht ganz angekommen und ich hätte möglicherweise gleich verständlicher schreiben können:
                              Nachdem das zum ersten und zweiten Mal passiert ist, habe ich jeweils die komplette VM in der iob läuft aus dem Backup zurückgespielt. Also quasi "Ausgangssituation" wiederhergestellt.
                              Allerdings kann ich die Problemsituation nicht (verlässlich) nachstellen. Ich kann hier also nun auch nichts weiter beitragen, wenn ich das Problem nicht verlässlich reproduzieren kann.
                              Es ist direkt nach Updates von Adapter(n) aufgetreten und wenn ich vom gleichen Zustand aus das gleiche Verhalten nicht reproduzieren kann - sprich das Problem nicht auftritt - dann kann ich auch keine weiteren Debuginformationen liefern - sorry.
                              • N nobl
                                @nobl
                                Ja läuft das Ding nun wieder oder nicht?
                                Wird mir irgendwie nicht so ganz klar.
                                  @nobl
                                  N Offline
                                  N Offline
                                  nobl
                                  @thomas-braun bei mir ja. Nicht reproduzierbarer Fehler = nicht mehr aufgetreten. Daher: Mein System läuft.
                                  Ob das beim Threadstarter der Fall ist kann ich nicht beurteilen.
