  4. Cannot find module iobroker.js-controller/iobroker.js
19 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • hg6806H hg6806
    iob status
    gibt folgenden Fehler aus:
    pi@RPI5:/opt/iobroker $ iob status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.18.2
    Eine nachträgliche Installation von js-controller bringt folgendes:
    pi@RPI5:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason                                                    s. As it's a core Node module, we will not transfer it over to other users. You                                                     may safely remove the package from your dependencies.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                                                    hub.com/request/request/issues/3142
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                                                    ersions may use Math.random() in certain circumstances, which is known to be pro                                                    blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN cleanup Failed to remove some directories [
    npm WARN cleanup   [
    npm WARN cleanup     '/opt/iobroker/node_modules',
    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroke                                                    r/node_modules'] {
    npm WARN cleanup       errno: -39,
    npm WARN cleanup       code: 'ENOTEMPTY',
    npm WARN cleanup       syscall: 'rmdir',
    npm WARN cleanup       path: '/opt/iobroker/node_modules'
    npm WARN cleanup     }
    npm WARN cleanup   ]
    npm WARN cleanup ]
    npm ERR! code 24
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! creating conf/iobroker.json
    npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file                                                     "/opt/iobroker/iobroker-data/objects.jsonl"!
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2                                                    023-11-09T21_42_08_685Z-debug-0.log
      throw err;
      requireStack: []
    Node.js v18.18.2
    Bibo*13
    schrieb am zuletzt editiert von Bibo*13
    @hg6806 Ich denke ich habe ein ähnliches Problem. Nachdem ich den Web Adapter 6.1.4 auf 6.1.10 updaten wollte kommt man nicht mehr auf den IOB. In der Raspi Console wird nach Abfrage IOB Status folgendes ausgegeben:
    Gibt es dafür schon eine Lösung?
    • B Bibo*13
      @bibo-13 sagte in Rasperry 5 im anrollen:
      ja, Text kopieren, dann kann man ihn auch in code-tags setzen.
      mit einer schwarzen Briefmarke geht das nicht
        Bibo*13
        Danke für den Hinweis. Jetzt nochmal in Tags
        pi@iobrokermaster:~ $ iob status
          throw err;
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          requireStack: []
        • B Bibo*13
          @thomas-braun Das ist das Summary; sieht irgendwie nicht gesund aus.
                                  v.2023-10-10
             Static hostname: iobrokermaster
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Kernel:                 armv7l
          Userland:               armhf
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
            throw err;
            requireStack: []
          Node.js v18.18.2
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                  /usr/bin/node           v18.18.2
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            7.9G         86M        6.7G        0.0K        1.1G        7.5G
          Swap:            99M          0B         99M
          Total:          8.0G         86M        6.8G
            throw err;
            requireStack: []
          Node.js v18.18.2
          Active iob-Instances:   0
            throw err;
            requireStack: []
          Node.js v18.18.2
            throw err;
            requireStack: []
          Node.js v18.18.2
          ioBroker Core:          js-controller
            throw err;
            requireStack: []
          Node.js v18.18.2
                                  admin
            throw err;
            requireStack: []
          Node.js v18.18.2
          ioBroker Status:
            throw err;
            requireStack: []
          Node.js v18.18.2
          Objects:                0
          States:                 0
          Size of iob-Database:
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          19M     /opt/iobroker/iobroker-data/objects.json.migrated
          19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          12K     /opt/iobroker/iobroker-data/objects.json.old
          0       /opt/iobroker/iobroker-data/objects.json.broken
          8.0K    /opt/iobroker/iobroker-data/states.json.old
          8.0K    /opt/iobroker/iobroker-data/states.json.bak
          @bibo-13
          Auf ein Rpi5 knallt man kein Bullseye, da muss ein aktuelles Bookworm drauf. Das Release ist extra für den RPi5 verschoben worden, weil hier diverse Dinge an die andere Hardware angepasst worden sind.
          B 2 Antworten Letzte Antwort
            @bibo-13
            Bibo*13
            @thomas-braun Das ist kein Raspi5 sondern ein 4er.
            • B Bibo*13
              @bibo-13
              Und warum pistest du es dann unter der Überschrift 'Rpi5 im anrollen '???
              Thema verfehlt, setzen.
                @bibo-13
                Bibo*13
                @thomas-braun Ich bin vielleicht im falschen Slot aber der Fehler der Auftritt hat mich nach Forum Suche hierher geführt.
                  @bibo-13
                  Bibo*13
                  @thomas-braun Was soll ich machen? Einen neuen Slot eröffnen. Sorry für den falschen Post.
                  • B Bibo*13
                    @bibo-13
                    cd /opt/iobroker
                      @bibo-13
                      cd /opt/iobroker
                      Bibo*13
                      @thomas-braun Ok Danke. Ich hab ihn wieder am laufen. Ich hoffe das ich die Adapter Updates machen kann.
                      Schaun wir mal.
                      Nochmal herzlichen Dank für Deine Arbeit und schönes WE
                      • B Bibo*13
                        @bibo-13 sagte in Fehler bei web update:
                        Hab das hier abgetrennt.
                        bitte noch den provisorischen Threadtitel sinnvoll ändern!
                        N 1 Antwort Letzte Antwort
                          N Offline
                          N Offline
                          nobl
                          schrieb am zuletzt editiert von nobl
                          Das Problem habe ich seit heute auch auf meiner Debian Installation. (Nachdem Adapter-Updates gelaufen sind.)
                          Versuche gerade herauszufinden, ob es ein bestimmter Adapter ist, dessen Update das ganze hervorruft.
                          Das Problem geht so weit, dass /opt/iobroker/node_modules/iobroker.js-controller/ quasi komplett geleert wird und nur noch das "node_modules" Verzeichnis darin zu finden ist.
                          • N nobl
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @nobl
                            Iob diag in der langfassung bitte
                            Und info was du wie aktualusiett hast...
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • mcm1957M mcm1957
                              @nobl
                              N Offline
                              N Offline
                              nobl
                              @mcm57 kommt, sobald ich das Problem eingrenzen konnte.
                              Hatte gestern nach Restore dann keine Zeit mehr.
                              Edit:
                              So - alles Mögliche jetzt probiert, um das Phänomen nachzustellen - (leider) erfolglos.
                              Das ist mir gestern mehrfach passiert und iob diag hat dann auch seitenweise rote Meldungen geworfen (leider nicht gesichert).
                              Das Einzige, was ich jetzt nicht nachstellen kann: Adapter Update läuft, in Hintergrund gestellt und dann parallel ein Blockly angepasst.
                              • N nobl
                                Edit:
                                @nobl sagte in Cannot find module iobroker.js-controller/iobroker.js:
                                Dann mach es nochmal...
                                Das Log dazu liegt aber auch in /home/iobroker herum...
                                • N nobl
                                  Edit:
                                  und damit ist jetzt alles mögliche geändert und der Status den die Helfenden hatten gilt nicht mehr?
                                    N Offline
                                    N Offline
                                    nobl
                                    @homoran es ist vielleicht nicht ganz angekommen und ich hätte möglicherweise gleich verständlicher schreiben können:
                                    Nachdem das zum ersten und zweiten Mal passiert ist, habe ich jeweils die komplette VM in der iob läuft aus dem Backup zurückgespielt. Also quasi "Ausgangssituation" wiederhergestellt.
                                    Allerdings kann ich die Problemsituation nicht (verlässlich) nachstellen. Ich kann hier also nun auch nichts weiter beitragen, wenn ich das Problem nicht verlässlich reproduzieren kann.
                                    Es ist direkt nach Updates von Adapter(n) aufgetreten und wenn ich vom gleichen Zustand aus das gleiche Verhalten nicht reproduzieren kann - sprich das Problem nicht auftritt - dann kann ich auch keine weiteren Debuginformationen liefern - sorry.
                                    • N nobl
                                      @nobl
                                      Ja läuft das Ding nun wieder oder nicht?
                                      Wird mir irgendwie nicht so ganz klar.
                                        @nobl
                                        N Offline
                                        N Offline
                                        nobl
                                        @thomas-braun bei mir ja. Nicht reproduzierbarer Fehler = nicht mehr aufgetreten. Daher: Mein System läuft.
                                        Ob das beim Threadstarter der Fall ist kann ich nicht beurteilen.
