  4. BackItUp Update hängt
    6.4k
118 Beiträge 8 Kommentatoren 20.2k Aufrufe 5 Beobachtet
  • M myssv
    nach 17 Minuten kam dies:
    $ iobroker upgrade ws@2.5.8
    Update ws from @2.5.5 to @2.5.8
    Installing iobroker.ws@2.5.8... (System call)
    Adapter "system.adapter.web.0" restarted.
    upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
    Process exited with code 0
    aber
    Volker@ioBroker:~$ iob update
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
    @myssv
    I'm Terminal
    iob upgrade ws@2.5.8 --debug
      @myssv
      I'm Terminal
      myssv
      @thomas-braun sagte in BackItUp Update hängt:
      seit 12 Minuten so
      Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
      This upgrade of "ws" will introduce the following changes:
      -> 2.5.8:
      Corrected adapter termination if the alias has no target
      -> 2.5.7:
      upgraded socket-classes to fix vis problems
      -> 2.5.6:
      upgraded socket-classes to correct the error by unsubscribing on client disconnect
      Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
      NPM version: 9.8.1
        myssv
        So, diesmal hat es länger gedauert ...
        -> 2.5.8:
        -> 2.5.7:
        -> 2.5.6:
        NPM version: 9.8.1
        npm ERR! code ETIMEDOUT
        npm ERR! syscall connect
        npm ERR! errno ETIMEDOUT
        npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
        npm ERR! network This is a problem related to network connectivity.
        npm ERR! network In most cases you are behind a proxy or have bad network settings.
        npm ERR! network
        npm ERR! network If you are behind a proxy, please make sure that the
        npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
        upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
          myssv
          @myssv sagte in BackItUp Update hängt:
          ich kann die Datei manuell herunterladen!
            myssv
            ist das IPv6? Das wäre eine Erklärung, da ich das im Hausnetz nicht will und eigentlich überall deaktiviert habe.
            • M myssv
              @myssv
              Ja, das ist eine ipv6-Adresse.
              Warum willst du das nicht?
              Aktivier das halt, das ist wichtig.
                @myssv
                myssv
                @myssv
                Weil mein gesamtes Netzwerk auf IPv4 ausgerichtet ist und mit V6 z.B. mein Adguard nicht korrekt funktioniert.
                Von daher möchte ich mein Netzwerk rein auf IPv4 behalten, was ja auch überhaupt kein Problem darstellen sollte, da ich so für mich genügend Adressen habe.
                Scheinbar hat der ioBroker damit ein Problem. Kann ich den irgendwie auf rein V4 umstellen?
                • M myssv
                  @myssv
                  Nein, kein Problem.
                  Nodejs/npm nutzen allerdings ipv6 zu Recht bevorzugt.
                  Ipv6/ipv4 kann man auch parallel nutzen. Mache ich z.B. in meinem Netz so.
                  IPv6 ist Stand der Technik, bring dein Netzwerk halt in die Gegenwart. Adguard kann man zu 100% auch mit IPv6 betreiben.
                    Nein, kein Problem.
                    myssv
                    Das stört mich nur, wenn nicht auf IPv4 zurück gegangen wird
                    Kann man IPv6 auch deaktivieren?
                    Sorry, aber das ist kein Argument. E-Autos sind auch stand der Technik, aber ich fahre weiterhin meinen 8 Jahre alten Diesel!
                    Sicher kann man das, aber warum dafür ein funktionierendes Netzwerk ändern?
                    So, das war genug off topic!
                    Kannst Du mir sagen, wie ich den ioBroker mit reinem IPv4 betreiben kann?
                    • M myssv
                      @myssv
                      Nein.
                        @myssv
                        Nein.
                        myssv
                        @thomas-braun ich habe dazu im Netz folgendes gefunden:
                        In der Datei /etc/sysctl.conf
                        folgenden Eintrag einfügen:
                        net.ipv6.conf.all.disable_ipv6 = 1
                        und dann mit
                        sudo sysctl -p
                        übernehmen.
                        Danach wurden beide Adapter anstandslos installiert.
                        Allerdings startet der ioBroker ohne IPv6 nicht mehr.
                        Der Server ist wieder da und ich komme auf die Konsole, daber nicht auf die ioBroker Webseite.
                        • M myssv
                          Dein Netzwerk funktioniert ja eben nicht vollumfänglich.
                            myssv
                            Der ioBroker funktioniert scheinbar nicht ohne IPv6. Mein Netzwerk funktioniert ohne den ioBroker einwandfrei.
                            Ich habe noch 10-15 Jahre zu leben. Da werde ich mir IPv6 nicht mehr antun!
                            Aber ist das jetzt wirklich zielführend?
                            • M myssv
                              @myssv
                              Ob IPv6 eingeführt und verwendet wird entscheidest aber nicht du. Du kannst natürlich sagen, ich spreche kein IPv6, dann musst du sich aber auch nicht wundern, wenn der Rest der Netzwerkwelt dann mit dir nicht mehr kommunizieren kann und Dienste nicht mehr funktionieren.
                                @myssv
                                myssv
                                #66
                                @myssv
                                Ich bin doch überhaupt nicht wichtig auf dieser Welt! Darum geht es doch auch gar nicht.
                                Es ist aber eine klare Aussage, wenn der ioBroker in einem reinen IPv4 Netzwerk nicht mehr funktioniert.
                                Danke dafür!
                                • M myssv
                                  @myssv
                                  Danke dafür!
                                  #67
                                  Wer hat die getätigt? Klar kann man das machen. Man muss dann aber 'gegen das grundsätzliche Setup' anarbeiten und hier und da Einstellungen verändern, damit man sein kleines gallischen Netzwerk weiter mit einer auslaufenden Technik betreiben kann. IPv4 und IPv6 laufen wunderbar gleichzeitig in einem Netzwerk, die sehen einander gar nicht.
                                  Also wird dein kastrierten Netzwerkonstrukt nur unnötig komplexer.
                                  Und das würde ich mir nicht antun.
                                    myssv
                                    #68
                                    @thomas-braun lass gut sein.
                                    ich werde bei IPv4 bleiben und wenn ich dann den ioBroker nicht mehr nutzen kann, dann ist das halt so.
                                    • M myssv
                                      #69
                                      wer sagt den sowas?
                                      auch das stimmt nicht.
                                      ioB läuft bei mir bisher ohne Probleme im IPv4 Netz
                                      Thomas BraunT M 2 Antworten Letzte Antwort
                                        wer sagt den sowas?
                                        #70
                                        @homoran sagte in BackItUp Update hängt:
                                        wer sagt den sowas?
                                        Niemand.
                                        Aber offenbar ist das Netzwerk vom TE ziemlich kaputtkonfiguriert.
                                          wer sagt den sowas?
                                          myssv
                                          #71
                                          bei mir bisher ja auch.
                                          Nur bei den Updates greift er jetzt scheinbar nur noch auf IPv6 zu, wenn es vorhanden ist und macht keinen "fallback" auf IPv4. Wenn ich vor dem Update v6 deaktiviere, dann läuft das Update auch über IPv4 durch. Im Anschluss muss ich IPv6 wieder aktiveren und er startet auch wieder.
