  4. BackItUp Update hängt
    6.4k
118 Beiträge 8 Kommentatoren 20.2k Aufrufe 5 Beobachtet
  • M myssv
    nun habe ich das gleiche Problem beim Updaten von ws bzw. web:
    und er hängt wieder
    auch an der Console
    Volker@ioBroker:~$ iob upgrade all --debug
    This upgrade of "ws" will introduce the following changes:
    -> 2.5.8:
    Corrected adapter termination if the alias has no target
    -> 2.5.7:
    upgraded socket-classes to fix vis problems
    -> 2.5.6:
    upgraded socket-classes to correct the error by unsubscribing on client disconnect
    Would you like to upgrade ws from @2.5.5 to @2.5.8 now? [(y)es, (n)o]: y
    Update ws from @2.5.5 to @2.5.8
    NPM version: 9.8.1
    Installing iobroker.ws@2.5.8... (System call)
    @myssv
    Warten...
      @myssv
      Warten...
      myssv
      @thomas-braun Wie lange denn?
      Sind inzwischen 10 Minuten, ohne dass sich etwas getan hat.
      • M myssv
        @myssv
        Bis sich was tut.
          @myssv
          Bis sich was tut.
          myssv
          @thomas-braun hat sich was getan:
          $ iobroker upgrade ws@2.5.8
          Adapter "system.adapter.web.0" restarted.
          upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
          Process exited with code 0
          Der Adapter scheint aber noch der Alte zu sein:
          • M myssv
            @myssv
            iob update
            zeigen. GUIs lügen.
              @myssv
              iob update
              zeigen. GUIs lügen.
              myssv
              @thomas-braun sagte in BackItUp Update hängt:
              iob update
              Volker@ioBroker:~$ iob update
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "deconz"       : 1.3.21   , installed 1.3.21
              Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
              Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.4  [Updatable]
              Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
              Volker@ioBroker:~$
              • M myssv
                iob update
                Volker@ioBroker:~$
                @myssv iob upload ws
                  myssv
                  @homoran sagte in BackItUp Update hängt:
                  iob upload ws
                  Volker@ioBroker:~$ iob upload ws
                  upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                  • M myssv
                    iob update
                    Volker@ioBroker:~$
                    @myssv
                    Das passt. Du bist auf 'Stable', die Updates sind aber erst in 'Beta' verfügbar.
                    M HomoranH 2 Antworten Letzte Antwort
                      @myssv
                      myssv
                      @thomas-braun Warum werden sie mir dann angezeigt?
                        @myssv
                        Das passt. D
                        nee,
                        @myssv sagte in BackItUp Update hängt:
                          myssv
                            Das passt. D
                            nee,
                            ws
                            github:	2.5.8
                            latest:	2.5.8 for 30 days
                            stable:	2.5.5 for 56 days
                            Kann auch sein, dass die beiden Adapter just im Moment in Stable rüber wandern und der Mirror noch nicht gesynct ist.
                            Schau dir das in ein paar Stunden nochmal an.
                              ws
                              github:	2.5.8
                              myssv
                              @thomas-braun ok, dann versuche ich es morgen früh noch einmal.
                              Danke und einen tollen Abend noch!
                                myssv
                                Guten Morgen zusammen, es hat sich nichts an dem Verhalten geändert.
                                Warte schon wieder 5 Minuten:
                                  myssv
                                  nach 17 Minuten kam dies:
                                  aber
                                  • M myssv
                                    aber
                                    @myssv
                                    I'm Terminal
                                    iob upgrade ws@2.5.8 --debug
                                      @myssv
                                      I'm Terminal
                                      myssv
                                      seit 12 Minuten so
                                      Volker@ioBroker:~$ iob upgrade ws@2.5.8 --debug
                                      -> 2.5.8:
                                      -> 2.5.7:
                                      -> 2.5.6:
                                      NPM version: 9.8.1
                                        myssv
                                        So, diesmal hat es länger gedauert ...
                                        -> 2.5.8:
                                        -> 2.5.7:
                                        -> 2.5.6:
                                        NPM version: 9.8.1
                                        npm ERR! code ETIMEDOUT
                                        npm ERR! syscall connect
                                        npm ERR! errno ETIMEDOUT
                                        npm ERR! network request to https://registry.npmjs.org/iobroker.ws/-/iobroker.ws-2.5.8.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443
                                        npm ERR! network This is a problem related to network connectivity.
                                        npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                        npm ERR! network
                                        npm ERR! network If you are behind a proxy, please make sure that the
                                        npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T08_58_10_931Z-debug-0.log
                                          myssv
                                          ich kann die Datei manuell herunterladen!
