  5. json datei für Chart aus vorhandenen DP's erstellen
80 Beiträge 2 Kommentatoren 9.1k Aufrufe 2 Beobachtet
  • D dos1973
    @mickym
    ich hab da ja mehr als 10 Tage drin...
    mickymM Offline
    mickymM Offline
    mickym
    @dos1973 Ja aber Du siehst ja die sind alle drin?
    • mickymM mickym
      dos1973
      @mickym
      ja alle 30...
      • D dos1973
        @mickym
        ja alle 30...
        mickymM Offline
        mickymM Offline
        mickym
        @dos1973 Ja und die sind doch auch alle im Debug Fenster drin mit den Daten?
        • mickymM mickym
          dos1973
          @mickym
          ja, sieht so aus.
          {"axisLabels":["30.10.","08.11.","07.11.","06.11.","05.11.","04.11.","03.11.","02.11.","01.11.","31.10.","29.10.","28.10.","27.10.","26.10.","25.10.","24.10.","23.10.","22.10.","21.10.","20.10.","19.10.","18.10.","14.10.","13.10.","12.10.","11.10.","10.10.","09.10.","08.10.","07.10.","09.11."],"graphs":[{"type":"line","data":[7.709,6.331,7.655,6.662,7.608,9.776,6.69,5.454,7.404,5.883,9.489,5.748,6.746,5.976,7.549,7.555,2.648,8.254,5.387,6.072,6.68,6.175,6.608,7.354,6.241,6.059,5.622,5.839,7.207,6.357],"yAxis_id":0,"yAxis_zeroLineWidth":0.1,"yAxis_zeroLineColor":"black","barIsStacked":true,"line_pointSize":0,"line_Thickness":4,"datalabel_show":true,"datalabel_maxDigits":2,"datalabel_minDigits":2,"datalabel_fontFamily":"OpenSans-CondLight","datalabel_fontSize":16,"datalabel_borderRadius":6,"datalabel_offset":-10,"datalabel_backgroundColor":"#3E4765","datalabel_color":"#f5f5f5","color":"#ff9900","line_UseFillColor":false,"yAxis_gridLines_show":false,"use_gradient_color":true,"gradient_color":[{"value":8.5,"color":"#d43e3a"},{"value":6,"color":"#ff9900"},{"value":3,"color":"#4f6765"}],"yAxis_appendix":" kw/h"},{"type":"bar","barIsStacked":true,"data":[7.709,6.331,7.655,6.662,7.608,9.776,6.69,5.454,7.404,5.883,9.489,5.748,6.746,5.976,7.549,7.555,2.648,8.254,5.387,6.072,6.68,6.175,6.608,7.354,6.241,6.059,5.622,5.839,7.207,6.357],"yAxis_id":0,"barStackId":0,"datalabel_show":false,"color":"#000000","datalabel_color":"#FFFFFF","datalabel_align":"start","use_gradient_color":true,"yAxis_show":false,"yAxis_min":0,"yAxis_maxSteps":4,"yAxis_gridLines_border_show":false,"yAxis_gridLines_ticks_show":false,"yAxis_gridLines_show":false,"gradient_color":[{"value":9.1,"color":"#ED97A8"},{"value":5.5,"color":"#F3D8A5"},{"value":-5,"color":"#7CA27E"}]}]}
          • D dos1973
            @mickym
            ja, sieht so aus.
            mickymM Offline
            mickymM Offline
            mickym
            @dos1973 na dann passt es doch - oder brauchst nicht alle 30 und Dein Tool hat deswegen ein Problem? Daten sind doch alle da? Schau halt erst mal, ob das Objekt im Debug Fenster mit dem identisch ist, als ob Du das Objekt aus dem iobroker kopierst. Wenn das identisch ist - dann hast Du mit dem Tool ein Problem und musst vielleicht Daten ausselektieren oder wirklich nur die ersten 10 Tage nehmen - ich hab halt alles genommen, weil das am schnellsten ging.
            Willst Du also exakt nur die Daten von Datum-1 bis Datum-10. ?
            • mickymM mickym
              dos1973
              @mickym
              ja, wollte nur 10 Tage haben.
              kann ja nicht die 30 tage in das kleine fenster packen
              mickymM D 2 Antworten Letzte Antwort
              • D dos1973
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @dos1973 OK - also nur Datum-1 bis Datum-10 und Verbrauch genauso?
                ... ich arbeite ...
                • D dos1973
                  @mickym
                  dos1973
                  ich will heute und 10 tage zurück
                  doch komplizierter als gedacht :-)
                  • D dos1973
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @dos1973 Ja aber das Objekt wie im Debug muss genauso im iobroker erscheinen - das kann nicht sein, dass die axisLabels fehlen. Wie gesagt nur die ersten 10 - muss ich noch bissi arbeiten, weil die List Node erst mal alles ausliest.
                    • mickymM mickym
                      ... ich arbeite ...
                      dos1973
                      @mickym
                      gibt noch ein Problem.
                      das Heutige Datum existiert nicht als DP.
                      und
                      die Quelle für den Verbrauch für den Heutigen Tag liegt hier:
                      sourceanalytix.0.0_userdata__0__mqtt__shellies__Pro3_EM__events__rpc__params__em:0__total_act_power.currentYear.consumed.01_currentDay
                      • D dos1973
                        @mickym
                        und
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @dos1973 darum kümmern wir uns später - eins nach dem anderen. Hast du jetzt mal überprüft on das Objekt im iobroker Datenpunkt mit dem Debug Fenster in Node Red identisch ist?
                        • mickymM mickym
                          dos1973
                          @mickym, ja das kommt sauber an, soweit ich das überblicken kann.
                          • D dos1973
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @dos1973 Was hast Du denn da gepostet, wo angeblich die x-Achsen werte fehlen?
                            • mickymM mickym
                              dos1973
                              @mickym ?
                              kann dir nicht folgen...
                              ich hatte den Root folder ursprünglich in deinem export nicht gewählt...
                              • D dos1973
                                @mickym ?
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @dos1973 So tausch mal in der Change Node Analyse den Code wie folgt:
                                Dann sollten jetzt nur die Tage Datum-1 bis Datum-10 und Verbrauch-1 bis Verbrauch-10 ausgefiltert sein.
                                Halt nein 20 und 30 sind jetzt auch drin- warte .... - (schlimm wenn man die Daten selbst nicht hat)
                                So müsste es stimmen:
                                payload.{"xasisLabels": [_id~>/(Datum-\d$|Datum-10$)/] ? val, "data" : [_id~>/(Verbrauch-\d$|Verbrauch-10$)/] ? val}
                                D mickymM 2 Antworten Letzte Antwort
                                • mickymM mickym
                                  dos1973
                                  schrieb am zuletzt editiert von dos1973
                                  @mickym : nicht ganz, es sind 12 Tage, heute fehlt... und die Reihenfolge ist nicht sortiert
                                  • edit:es sind auch nicht die letzten 10, da u.a. auch der 10.10 aufgeführt
                                  • D dos1973
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym Wie gesagt mit dem heute - da muss der gesamte Flow noch ergänzt werden.
                                    payload.{"xasisLabels": [_id~>/(Datum-(\d|10)$)/] ? val, "data" : [_id~>/(Verbrauch-(\d|10)$)/] ? val}
                                    Schau mal ob bis auf heute alles richtig ist - sortieren kommt gleich. Das Dumme ist das Du den 10. Datenpunkt 10 genannt hast. und nicht von 0-9
                                    • mickymM mickym
                                      dos1973
                                      @mickym
                                      ne das passt nicht.
                                      • D dos1973
                                        @mickym
                                        ne das passt nicht.
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @dos1973 Kannst Du einfach eine DebugNode hinter die list Node machen und mir die payload dann in Code-Tags hier reinkopieren?
                                        • mickymM mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @mickym Warte hab den Fehler.
                                          payload.{"axisLabels": [_id~>/(Datum-(\d|10)$)/] ? val, "data" : [_id~>/(Verbrauch-(\d|10)$)/] ? val}
                                          Ich hab unten immer xaxisLabels geschrieben.
