  4. BackItUp Update hängt
    6.4k
118 Beiträge 8 Kommentatoren 20.2k Aufrufe 5 Beobachtet
    @myssv
    iob update
    sagt?
    myssv
    @thomas-braun sagte in BackItUp Update hängt:
    iob update
    Ich habe den Server vorher einmal neu gestartet. Scheinbar auch ohne Erfolg.
    Volker@ioBroker:~$ iob update
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.6
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "openligadb"   : 1.2.4    , installed 1.3.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Volker@ioBroker:~$
      myssv
      Ich habe jetzt nach dem Neustart das Update im Backend noch einmal gestartet und nun lief es durch
      $ iobroker upgrade backitup@2.8.7
      Update backitup from @2.8.1 to @2.8.7
      Installing iobroker.backitup@2.8.7... (System call)
      88 packages are looking for funding run `npm fund` for details
      Update "system.adapter.backitup.0"
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      Process exited with code 0
        @myssv
        iob update
        sagt?
        myssv
        @thomas-braun Danke für Deine Mühen!
          marios774
          Bei mir lief das Update durch. Dann kam aber die Fehlerneldung:
          startInstance system.adapter.backitup.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=6.0.0"!
          admin: 6.12.0
          Node.js: v18.17.1(18.18.2)
          NPM: 9.6.7(9.8.1)
          Auch die Installation einer älteren Version haben nichts gebracht.
          • M marios774
            admin: 6.12.0
            NPM: 9.6.7(9.8.1)
            @marios774
            iob stop
            iob fix
            iob nodejs-update
            iob upload all
            DuffyD 1 Antwort Letzte Antwort
              @marios774
              iob stop
              iob fix
              iob nodejs-update
              iob upload all
              DuffyD Offline
              DuffyD Offline
              Duffy
        iob stop        iob fix        iob nodejs-update        iob upload all
              Kann man das node.js Update immer so machen? Es gibt hier so viele Beschreibungen zu das ich mir da jetzt etwas unsicher bin :-)
              Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
              Node.js: v22.23.2
              NPM: 10.9.4
              js-controller 7.1.2
              Linux: Trixie
              • DuffyD Duffy
                @duffy
                Seit kurzen gibt es den Befehl dazu. Siehe auch die Ankündigungen hier im Forum.
                  @duffy
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  schrieb am zuletzt editiert von Duffy
                  Wenn man am letzten Wochenende den IOB neu installiert hatte muss man dann trotzdem jetzt noch mal
                  fix iob
                  ausführen oder hat das die IOB Version dann schon drin das man jetzt
                  iob nodejs-update
                  ausführen kann?
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • DuffyD Duffy
                    fix iob
                    iob nodejs-update
                    ausführen kann?
                    @duffy
                    Nein, der
                    iob fix
                    ist nur erforderlich, wenn das Kommando 'iobroker nodejs-update' noch nicht geladen wurde (bei Alt-Installationen, Neuinstallationen kommen direkt damit an). Jetzt steht das natürlich direkt zur Verfügung.
                    Probier es halt einfach aus. Wenn es nicht vorhanden ist:
                    iob fix
                      @duffy
                      Nein, der
                      iob fix
                      iob fix
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      Ich komme jetzt gerade nicht an meinen IOB aber woran sollte ich den erkennen ob es verfügbar ist?
                      Gibt es da auch einen Befehl für?
                      Glaub der Groschen ist gefallen, wenn
                      iob nodejs-update
                      funktioniert ist kein
                      fix iob
                      nötig.
                      Werde mir das heute Abend mal anschauen. Danke dir.
                      Gruß Duffy
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      • DuffyD Duffy
                        iob nodejs-update
                        fix iob
                        nötig.
                        Gruß Duffy
                        @duffy
                        iob fix
                        nicht fix iob...
                        DuffyD 2 Antworten Letzte Antwort
                          @duffy
                          iob fix
                          nicht fix iob...
                          DuffyD Offline
                          DuffyD Offline
                          Duffy
                          Ja, danke, war ein Kopierfehler trotzdem danke für den Hinweis, sonst wäre ich vielleicht wieder mal auf dem Schlauch gestanden.
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                            @duffy
                            iob fix
                            nicht fix iob...
                            DuffyD Offline
                            DuffyD Offline
                            Duffy
                            Habe es gerade überprüft. Ich konnte
                            iob nodejs-update
                            ausführen. Dann wurde mir vorgeschlagen um das System up to Date zu halten
                            sudo apt update && sudo apt full-upgrade
                            auszuführen.
                            Dabei kam am Ende die Meldung mit der ich nichts anfangen kann (letzter Satz):
                            pi@raspberrypi:~ $ sudo apt update && sudo apt full-upgrade
                            Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                            Get:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                            Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
                            Get:5 https://repos.influxdata.com/debian stable InRelease [6,901 B]
                            Get:6 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
                            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Get:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [90.9 kB]
                            Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [93.2 kB]
                            Get:10 http://deb.debian.org/debian bookworm-updates/main armhf Packages [6,648 B]
                            Get:11 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [6,672 B]
                            Get:12 http://deb.debian.org/debian bookworm-updates/main Translation-en [5,204 B]
                            Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [346 kB]
                            Get:14 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [338 kB]
                            Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [7,173 B]
                            Get:16 https://packages.grafana.com/oss/deb stable/main arm64 Packages [126 kB]
                            Fetched 1,157 kB in 3s (427 kB/s)
                            Reading package lists... Done
                            ^Cilding dependency tree... 50%
                            Ist
                            was gutes?? 😧
                            VG Duffy
                            Node.js: v22.23.2
                            NPM: 10.9.4
                            js-controller 7.1.2
                            Linux: Trixie
                            Thomas BraunT ? HomoranH 3 Antworten Letzte Antwort
                            • DuffyD Duffy
                              iob nodejs-update
                              auszuführen.
                              Ist
                              was gutes?? 😧
                              VG Duffy
                              @duffy sagte in BackItUp Update hängt:
                              was gutes??
                              Was normales.
                              Dauert hat gglfs. etwas.
                              • DuffyD Duffy
                                iob nodejs-update
                                auszuführen.
                                Ist
                                was gutes?? 😧
                                VG Duffy
                                Moin,
                                der war noch nicht fertig!
                                Da steht eigentlich Building, Du hast aber irgendwie ein ^C gemacht also Control C == Abbruch der Aktion, die gerade auf der Kommandozeile ausgeführt wurde.
                                Also nochmal ausführen und dann nicht immer herumfummeln, halte mal die Finger still und warte!
                                Bernd
                                • DuffyD Duffy
                                  iob nodejs-update
                                  auszuführen.
                                  Ist
                                  was gutes?? 😧
                                  VG Duffy
                                  Ist
                                  was gutes??
                                  das ist ein Zeichen dass du zu ungeduldig warst und mitten im Prozess mit ctrl-c abgebrochen hast
                                    Ist
                                    was gutes??
                                    DuffyD Offline
                                    DuffyD Offline
                                    Duffy
                                    Hmm, eigentlich war ich an etwas anderem dran auf einem 2. Bildschirm aber vielleicht bin ich wirklich drauf gekommen.
                                    Aber sagt mal ist
                                    das gleiche wie
                                    Sudo apt update
                                    und
                                    Sudo apt upgrade
                                    Wenn nein wo ist der Unterschied?
                                    Node.js: v22.23.2
                                    NPM: 10.9.4
                                    js-controller 7.1.2
                                    Linux: Trixie
                                    • DuffyD Duffy
                                      Aber sagt mal ist
                                      das gleiche wie
                                      Sudo apt update
                                      und
                                      Sudo apt upgrade
                                      Der Unterschied besteht darin, das ein apt full-upgrade die Abhängigkeiten anders auflöst. Das macht u. U. auch ein Downgrade, was ein simples apt upgrade nicht macht.
                                      Meist wird allerdings da gleiche gemacht, weil in der Regel kein Downgrade sondern eher ein Upgrade von Paketen vorgesehen ist.
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        Heisst das man sollte lieber immer
                                        verwenden?
                                        Was ihr alles wisst, ihr seid der Hammer 👍
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          verwenden?
                                          @duffy
                                          Ja, full-upgrade ist zu bevorzugen.
