  3. Einsteigerfragen
  4. Installation
  5. keine Updates bei IOB mehr möglich
50 Beiträge 6 Kommentatoren 6.0k Aufrufe 5 Beobachtet
  • ralleR ralle
    @thomas-braun said in keine Updates bei IOB mehr möglich:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     20:49:05 up 31 min,  2 users,  load average: 0.40, 2.03, 2.77
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-11-06 20:49:05 CET
               Universal time: Mon 2023-11-06 19:49:05 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        116M        6.6G        1.0M        1.1G        7.6G
    Swap:            99M          0B         99M
    Total:          7.9G        116M        6.7G
             7812 M total memory
              116 M used memory
              133 M active memory
              747 M inactive memory
             6573 M free memory
              234 M buffer memory
              887 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       15G   11G  3.3G  77% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Mon Nov  6 20:17:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:65:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d0e90a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Nov  6 20:17:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Nov  6 20:17:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Nov  6 20:17:17 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.5G    /var/log/journal/9de79e4d9feb4ead979df62e580afcd8
    1.5G    /var/log
    129M    /var/cache
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    162M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    899M    /opt/iobroker/iobroker-data/history
    617M    /opt/iobroker/iobroker-data/files
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
    npm ERR! extraneous: @types/ws@8.5.8 /opt/iobroker/node_modules/@types/ws
    npm ERR! invalid: iobroker.worx@2.3.4 /opt/iobroker/node_modules/iobroker.worx
    npm ERR! extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
    npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
    npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/duplexify
    npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/isarray
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder
    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
    npm ERR! extraneous: @ampproject/remapping@2.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@ampproject/remapping
    npm ERR! extraneous: @babel/code-frame@7.22.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame
    npm ERR! extraneous: @babel/compat-data@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/compat-data
    npm ERR! extraneous: @babel/core@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core
    npm ERR! extraneous: @babel/generator@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/generator
    npm ERR! extraneous: @babel/helper-compilation-targets@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets
    npm ERR! extraneous: @babel/helper-environment-visitor@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-environment-visitor
    npm ERR! extraneous: @babel/helper-function-name@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-function-name
    npm ERR! extraneous: @babel/helper-hoist-variables@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-hoist-variables
    npm ERR! extraneous: @babel/helper-module-imports@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-imports
    npm ERR! extraneous: @babel/helper-module-transforms@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-transforms
    npm ERR! extraneous: @babel/helper-plugin-utils@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-plugin-utils
    npm ERR! extraneous: @babel/helper-simple-access@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-simple-access
    npm ERR! extraneous: @babel/helper-split-export-declaration@7.22.6 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-split-export-declaration
    npm ERR! extraneous: @babel/helper-string-parser@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-string-parser
    npm ERR! extraneous: @babel/helper-validator-identifier@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-identifier
    npm ERR! extraneous: @babel/helper-validator-option@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-option
    npm ERR! extraneous: @babel/helpers@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helpers
    npm ERR! extraneous: @babel/highlight@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight
    npm ERR! extraneous: @babel/parser@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/parser
    npm ERR! extraneous: @babel/plugin-syntax-async-generators@7.8.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-async-generators
    npm ERR! extraneous: @babel/plugin-syntax-bigint@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-bigint
    npm ERR! extraneous: @babel/plugin-syntax-class-properties@7.12.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-class-properties
    npm ERR! extraneous: @babel/plugin-syntax-import-meta@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-import-meta
    npm ERR! extraneous: @babel/plugin-syntax-json-strings@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-json-strings
    npm ERR! extraneous: @babel/plugin-syntax-logical-assignment-operators@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-logical-assignment-operators
    npm ERR! extraneous: @babel/plugin-syntax-nullish-coalescing-operator@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-nullish-coalescing-operator
    npm ERR! extraneous: @babel/plugin-syntax-numeric-separator@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-numeric-separator
    npm ERR! extraneous: @babel/plugin-syntax-object-rest-spread@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-object-rest-spread
    npm ERR! extraneous: @babel/plugin-syntax-optional-catch-binding@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-catch-binding
    npm ERR! extraneous: @babel/plugin-syntax-optional-chaining@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-chaining
    npm ERR! extraneous: @babel/plugin-syntax-top-level-await@7.14.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-top-level-await
    npm ERR! extraneous: @babel/plugin-syntax-typescript@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-typescript
    npm ERR! extraneous: @babel/template@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/template
    npm ERR! extraneous: @babel/traverse@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/traverse
    npm ERR! extraneous: @babel/types@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/types
    npm ERR! extraneous: @bcoe/v8-coverage@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/@bcoe/v8-coverage
    npm ERR! extraneous: @hapi/hoek@9.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/hoek
    npm ERR! extraneous: @hapi/topo@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/topo
    npm ERR! extraneous: @istanbuljs/load-nyc-config@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/load-nyc-config
    npm ERR! extraneous: @istanbuljs/schema@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/schema
    npm ERR! extraneous: @jest/console@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/console
    npm ERR! extraneous: @jest/core@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/core
    npm ERR! extraneous: @jest/environment@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/environment
    npm ERR! extraneous: @jest/fake-timers@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/fake-timers
    npm ERR! extraneous: @jest/globals@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/globals
    npm ERR! extraneous: @jest/reporters@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/reporters
    npm ERR! extraneous: @jest/source-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/source-map
    npm ERR! extraneous: @jest/test-result@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-result
    npm ERR! extraneous: @jest/test-sequencer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-sequencer
    npm ERR! extraneous: @jest/transform@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/transform
    npm ERR! extraneous: @jest/types@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/types
    npm ERR! extraneous: @jridgewell/gen-mapping@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/gen-mapping
    npm ERR! extraneous: @jridgewell/resolve-uri@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/resolve-uri
    npm ERR! extraneous: @jridgewell/set-array@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/set-array
    npm ERR! extraneous: @jridgewell/sourcemap-codec@1.4.15 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/sourcemap-codec
    npm ERR! extraneous: @jridgewell/trace-mapping@0.3.20 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/trace-mapping
    npm ERR! extraneous: @sideway/address@4.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/address
    npm ERR! extraneous: @sideway/formula@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/formula
    npm ERR! extraneous: @sideway/pinpoint@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/pinpoint
    npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/commons
    npm ERR! extraneous: @sinonjs/fake-timers@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/fake-timers
    npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@tootallnate/once
    npm ERR! extraneous: @types/babel__core@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__core
    npm ERR! extraneous: @types/babel__generator@7.6.6 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__generator
    npm ERR! extraneous: @types/babel__template@7.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__template
    npm ERR! extraneous: @types/babel__traverse@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__traverse
    npm ERR! extraneous: @types/crypto-js@3.1.47 /opt/iobroker/node_modules/aws-crt/node_modules/@types/crypto-js
    npm ERR! extraneous: @types/graceful-fs@4.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/@types/graceful-fs
    npm ERR! extraneous: @types/istanbul-lib-coverage@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-coverage
    npm ERR! extraneous: @types/istanbul-lib-report@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-report
    npm ERR! extraneous: @types/istanbul-reports@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-reports
    npm ERR! extraneous: @types/jest@27.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/jest
    npm ERR! extraneous: @types/prettier@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/@types/prettier
    npm ERR! extraneous: @types/puppeteer@5.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/puppeteer
    npm ERR! extraneous: @types/stack-utils@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/stack-utils
    npm ERR! extraneous: @types/uuid@3.4.12 /opt/iobroker/node_modules/aws-crt/node_modules/@types/uuid
    npm ERR! extraneous: @types/yargs-parser@21.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs-parser
    npm ERR! extraneous: @types/yargs@16.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs
    npm ERR! extraneous: @types/yauzl@2.10.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yauzl
    npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/abab
    npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals
    npm ERR! extraneous: acorn-walk@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-walk
    npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/aws-crt/node_modules/acorn
    npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/agent-base
    npm ERR! extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes
    npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles
    npm ERR! extraneous: ansi@0.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/ansi
    npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/anymatch
    npm ERR! extraneous: are-we-there-yet@1.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet
    npm ERR! extraneous: argparse@1.0.10 /opt/iobroker/node_modules/aws-crt/node_modules/argparse
    npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/arr-union
    npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/asynckit
    npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays
    npm ERR! extraneous: aws-sdk@2.1488.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk
    npm ERR! extraneous: babel-jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest
    npm ERR! extraneous: babel-plugin-istanbul@6.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul
    npm ERR! extraneous: babel-plugin-jest-hoist@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-jest-hoist
    npm ERR! extraneous: babel-preset-current-node-syntax@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-current-node-syntax
    npm ERR! extraneous: babel-preset-jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-jest
    npm ERR! extraneous: big-integer@1.6.51 /opt/iobroker/node_modules/aws-crt/node_modules/big-integer
    npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/binary
    npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/bluebird
    npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/braces
    npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime
    npm ERR! extraneous: browserslist@4.22.1 /opt/iobroker/node_modules/aws-crt/node_modules/browserslist
    npm ERR! extraneous: bs-logger@0.2.6 /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger
    npm ERR! extraneous: bser@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/bser
    npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32
    npm ERR! extraneous: buffer-indexof-polyfill@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill
    npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims
    npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/buffers
    npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/call-bind
    npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/callsites
    npm ERR! extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/camelcase
    npm ERR! extraneous: caniuse-lite@1.0.30001561 /opt/iobroker/node_modules/aws-crt/node_modules/caniuse-lite
    npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/chainsaw
    npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/chalk
    npm ERR! extraneous: char-regex@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/char-regex
    npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/chownr
    npm ERR! extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/ci-info
    npm ERR! extraneous: cjs-module-lexer@1.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/cjs-module-lexer
    npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cliui
    npm ERR! extraneous: clone-deep@0.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep
    npm ERR! extraneous: cmake-js@6.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js
    npm ERR! extraneous: co@4.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/co
    npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at
    npm ERR! extraneous: collect-v8-coverage@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage
    npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/color-name
    npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/combined-stream
    npm ERR! extraneous: commander@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/commander
    npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map
    npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn
    npm ERR! extraneous: cssom@0.4.4 /opt/iobroker/node_modules/aws-crt/node_modules/cssom
    npm ERR! extraneous: cssstyle@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle
    npm ERR! extraneous: cwd@0.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/cwd
    npm ERR! extraneous: data-urls@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/data-urls
    npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/decamelize
    npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/decimal.js
    npm ERR! extraneous: dedent@0.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/dedent
    npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend
    npm ERR! extraneous: deepmerge@4.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/deepmerge
    npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property
    npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/delayed-stream
    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/delegates
    npm ERR! extraneous: detect-newline@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/detect-newline
    npm ERR! extraneous: diff-sequences@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/diff-sequences
    npm ERR! extraneous: domexception@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/domexception
    npm ERR! extraneous: duplexer2@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2
    npm ERR! extraneous: electron-to-chromium@1.4.576 /opt/iobroker/node_modules/aws-crt/node_modules/electron-to-chromium
    npm ERR! extraneous: emittery@0.8.1 /opt/iobroker/node_modules/aws-crt/node_modules/emittery
    npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex
    npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/error-ex
    npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/escalade
    npm ERR! extraneous: escape-string-regexp@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp
    npm ERR! extraneous: escodegen@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/escodegen
    npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/esprima
    npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/estraverse
    npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/esutils
    npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/events
    npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/execa
    npm ERR! extraneous: exit@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/exit
    npm ERR! extraneous: expand-tilde@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde
    npm ERR! extraneous: expect-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/expect-puppeteer
    npm ERR! extraneous: expect@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/expect
    npm ERR! extraneous: extract-zip@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip
    npm ERR! extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify
    npm ERR! extraneous: fb-watchman@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/fb-watchman
    npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer
    npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/fill-range
    npm ERR! extraneous: find-file-up@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/find-file-up
    npm ERR! extraneous: find-pkg@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/find-pkg
    npm ERR! extraneous: find-process@1.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/find-process
    npm ERR! extraneous: find-up@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/find-up
    npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/for-each
    npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/for-in
    npm ERR! extraneous: for-own@0.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/for-own
    npm ERR! extraneous: form-data@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/form-data
    npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants
    npm ERR! extraneous: fs-exists-sync@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-exists-sync
    npm ERR! extraneous: fs-extra@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-extra
    npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass
    npm ERR! extraneous: fstream@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/fstream
    npm ERR! extraneous: function-bind@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/function-bind
    npm ERR! extraneous: gauge@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/gauge
    npm ERR! extraneous: gensync@1.0.0-beta.2 /opt/iobroker/node_modules/aws-crt/node_modules/gensync
    npm ERR! extraneous: get-caller-file@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file
    npm ERR! extraneous: get-intrinsic@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic
    npm ERR! extraneous: get-package-type@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type
    npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/get-stream
    npm ERR! extraneous: global-modules@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/global-modules
    npm ERR! extraneous: global-prefix@0.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/global-prefix
    npm ERR! extraneous: globals@11.12.0 /opt/iobroker/node_modules/aws-crt/node_modules/globals
    npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/gopd
    npm ERR! extraneous: graceful-fs@4.2.11 /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs
    npm ERR! extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/has-flag
    npm ERR! extraneous: has-property-descriptors@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors
    npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-proto
    npm ERR! extraneous: has-symbols@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/has-symbols
    npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag
    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/has-unicode
    npm ERR! extraneous: hasown@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/hasown
    npm ERR! extraneous: homedir-polyfill@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/homedir-polyfill
    npm ERR! extraneous: html-encoding-sniffer@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/html-encoding-sniffer
    npm ERR! extraneous: html-escaper@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/html-escaper
    npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/http-proxy-agent
    npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/https-proxy-agent
    npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/human-signals
    npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite
    npm ERR! extraneous: import-local@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/import-local
    npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash
    npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/ini
    npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/invert-kv
    npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments
    npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-arrayish
    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer
    npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/is-callable
    npm ERR! extraneous: is-core-module@2.13.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module
    npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable
    npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: is-generator-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-fn
    npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function
    npm ERR! extraneous: is-iojs@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-iojs
    npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-number
    npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/is-plain-object
    npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-potential-custom-element-name
    npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/is-stream
    npm ERR! extraneous: is-typed-array@1.1.12 /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array
    npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray
    npm ERR! extraneous: is-windows@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/is-windows
    npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/isexe
    npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/isobject
    npm ERR! extraneous: istanbul-lib-coverage@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage
    npm ERR! extraneous: istanbul-lib-instrument@5.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument
    npm ERR! extraneous: istanbul-lib-report@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report
    npm ERR! extraneous: istanbul-lib-source-maps@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps
    npm ERR! extraneous: istanbul-reports@3.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports
    npm ERR! extraneous: jest-changed-files@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files
    npm ERR! extraneous: jest-circus@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-circus
    npm ERR! extraneous: jest-cli@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli
    npm ERR! extraneous: jest-config@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-config
    npm ERR! extraneous: jest-dev-server@5.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/jest-dev-server
    npm ERR! extraneous: jest-diff@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-diff
    npm ERR! extraneous: jest-docblock@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-docblock
    npm ERR! extraneous: jest-each@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-each
    npm ERR! extraneous: jest-environment-jsdom@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-jsdom
    npm ERR! extraneous: jest-environment-node@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-node
    npm ERR! extraneous: jest-environment-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-puppeteer
    npm ERR! extraneous: jest-get-type@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-get-type
    npm ERR! extraneous: jest-haste-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map
    npm ERR! extraneous: jest-jasmine2@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-jasmine2
    npm ERR! extraneous: jest-leak-detector@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-leak-detector
    npm ERR! extraneous: jest-matcher-utils@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils
    npm ERR! extraneous: jest-message-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util
    npm ERR! extraneous: jest-mock@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock
    npm ERR! extraneous: jest-pnp-resolver@1.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/jest-pnp-resolver
    npm ERR! extraneous: jest-puppeteer@5.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-puppeteer
    npm ERR! extraneous: jest-regex-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util
    npm ERR! extraneous: jest-resolve-dependencies@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies
    npm ERR! extraneous: jest-resolve@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve
    npm ERR! extraneous: jest-runner@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner
    npm ERR! extraneous: jest-runtime@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime
    npm ERR! extraneous: jest-serializer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-serializer
    npm ERR! extraneous: jest-snapshot@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot
    npm ERR! extraneous: jest-util@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-util
    npm ERR! extraneous: jest-validate@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate
    npm ERR! extraneous: jest-watcher@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher
    npm ERR! extraneous: jest-worker@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker
    npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest
    npm ERR! extraneous: jmespath@0.16.0 /opt/iobroker/node_modules/aws-crt/node_modules/jmespath
    npm ERR! extraneous: joi@17.11.0 /opt/iobroker/node_modules/aws-crt/node_modules/joi
    npm ERR! extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens
    npm ERR! extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml
    npm ERR! extraneous: jsdom@16.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom
    npm ERR! extraneous: jsesc@2.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/jsesc
    npm ERR! extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors
    npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/json5
    npm ERR! extraneous: jsonc-parser@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser
    npm ERR! extraneous: jsonfile@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jsonfile
    npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/kind-of
    npm ERR! extraneous: kleur@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/kleur
    npm ERR! extraneous: lazy-cache@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/lazy-cache
    npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/lcid
    npm ERR! extraneous: leven@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/leven
    npm ERR! extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns
    npm ERR! extraneous: listenercount@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/listenercount
    npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/locate-path
    npm ERR! extraneous: lodash.memoize@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.memoize
    npm ERR! extraneous: lodash.pad@4.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.pad
    npm ERR! extraneous: lodash.padend@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padend
    npm ERR! extraneous: lodash.padstart@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padstart
    npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/aws-crt/node_modules/lodash
    npm ERR! extraneous: lru-cache@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/lru-cache
    npm ERR! extraneous: lunr@2.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/lunr
    npm ERR! extraneous: make-dir@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir
    npm ERR! extraneous: make-error@1.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/make-error
    npm ERR! extraneous: makeerror@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/makeerror
    npm ERR! extraneous: marked@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/marked
    npm ERR! extraneous: memory-stream@0.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream
    npm ERR! extraneous: merge-deep@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/merge-deep
    npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/merge-stream
    npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/micromatch
    npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime-db
    npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/aws-crt/node_modules/mime-types
    npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime
    npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/mimic-fn
    npm ERR! extraneous: minipass@3.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/minipass
    npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib
    npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp-classic
    npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp
    npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/natural-compare
    npm ERR! extraneous: node-int64@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/node-int64
    npm ERR! extraneous: node-releases@2.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/node-releases
    npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/normalize-path
    npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/npm-run-path
    npm ERR! extraneous: npmlog@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/npmlog
    npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/number-is-nan
    npm ERR! extraneous: nwsapi@2.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/nwsapi
    npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/onetime
    npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/os-homedir
    npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/os-locale
    npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-limit
    npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-locate
    npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-try
    npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-json
    npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-passwd
    npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/parse5
    npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/path-exists
    npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-key
    npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/path-parse
    npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pend
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/picocolors
    npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/picomatch
    npm ERR! extraneous: pirates@4.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/pirates
    npm ERR! extraneous: pkg-dir@4.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pkg-dir
    npm ERR! extraneous: pretty-format@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format
    npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/progress
    npm ERR! extraneous: prompts@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/prompts
    npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/proxy-from-env
    npm ERR! extraneous: psl@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/psl
    npm ERR! extraneous: punycode@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/punycode
    npm ERR! extraneous: puppeteer@3.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer
    npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystring
    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystringify
    npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/rc
    npm ERR! extraneous: react-is@17.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/react-is
    npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/require-directory
    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/requires-port
    npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-cwd
    npm ERR! extraneous: resolve-dir@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-dir
    npm ERR! extraneous: resolve-from@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-from
    npm ERR! extraneous: resolve.exports@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve.exports
    npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/aws-crt/node_modules/resolve
    npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/rimraf
    npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs
    npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/safer-buffer
    npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/sax
    npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/saxes
    npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/semver
    npm ERR! extraneous: set-function-length@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/set-function-length
    npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/setimmediate
    npm ERR! extraneous: shallow-clone@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone
    npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-command
    npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-regex
    npm ERR! extraneous: shiki@0.10.1 /opt/iobroker/node_modules/aws-crt/node_modules/shiki
    npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/signal-exit
    npm ERR! extraneous: sisteransi@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/sisteransi
    npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/slash
    npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/aws-crt/node_modules/source-map-support
    npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/source-map
    npm ERR! extraneous: spawnd@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/spawnd
    npm ERR! extraneous: splitargs@0.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/splitargs
    npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/sprintf-js
    npm ERR! extraneous: stack-utils@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/stack-utils
    npm ERR! extraneous: string-length@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/string-length
    npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/string-width
    npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-ansi
    npm ERR! extraneous: strip-bom@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-bom
    npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-final-newline
    npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-json-comments
    npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-color
    npm ERR! extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-hyperlinks
    npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-preserve-symlinks-flag
    npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/symbol-tree
    npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs
    npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream
    npm ERR! extraneous: tar@6.1.11 /opt/iobroker/node_modules/aws-crt/node_modules/tar
    npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/terminal-link
    npm ERR! extraneous: test-exclude@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/test-exclude
    npm ERR! extraneous: throat@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/throat
    npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/through
    npm ERR! extraneous: tmpl@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/tmpl
    npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/to-fast-properties
    npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/to-regex-range
    npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie
    npm ERR! extraneous: tr46@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/tr46
    npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/traverse
    npm ERR! extraneous: tree-kill@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/tree-kill
    npm ERR! extraneous: ts-jest@27.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest
    npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/type-detect
    npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/aws-crt/node_modules/type-fest
    npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray-to-buffer
    npm ERR! extraneous: typedoc-plugin-merge-modules@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc-plugin-merge-modules
    npm ERR! extraneous: typedoc@0.22.18 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/typescript
    npm ERR! extraneous: unbzip2-stream@1.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream
    npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/universalify
    npm ERR! extraneous: unzipper@0.8.14 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper
    npm ERR! extraneous: update-browserslist-db@1.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/update-browserslist-db
    npm ERR! extraneous: url-join@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/url-join
    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/aws-crt/node_modules/url-parse
    npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/aws-crt/node_modules/url
    npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-crt/node_modules/util
    npm ERR! extraneous: uuid@8.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/uuid
    npm ERR! extraneous: v8-to-istanbul@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul
    npm ERR! extraneous: vscode-oniguruma@1.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-oniguruma
    npm ERR! extraneous: vscode-textmate@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-textmate
    npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-hr-time
    npm ERR! extraneous: w3c-xmlserializer@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-xmlserializer
    npm ERR! extraneous: wait-on@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on
    npm ERR! extraneous: wait-port@0.2.14 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port
    npm ERR! extraneous: walker@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/walker
    npm ERR! extraneous: webidl-conversions@6.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/webidl-conversions
    npm ERR! extraneous: whatwg-encoding@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-encoding
    npm ERR! extraneous: whatwg-mimetype@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-mimetype
    npm ERR! extraneous: whatwg-url@8.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-url
    npm ERR! extraneous: which-typed-array@1.1.13 /opt/iobroker/node_modules/aws-crt/node_modules/which-typed-array
    npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/which
    npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/window-size
    npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wrap-ansi
    npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/write-file-atomic
    npm ERR! extraneous: xml-name-validator@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml-name-validator
    npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml2js
    npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/xmlbuilder
    npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/xmlchars
    npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/y18n
    npm ERR! extraneous: yallist@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yallist
    npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/aws-crt/node_modules/yargs-parser
    npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/yargs
    npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/yauzl
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-name
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/supports-color
    npm ERR! extraneous: convert-source-map@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/convert-source-map
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/semver
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets/node_modules/semver
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-name
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/supports-color
    npm ERR! extraneous: acorn@7.4.1 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals/node_modules/acorn
    npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/buffer
    npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/uuid
    npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/ansi-regex
    npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/axios
    npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/camelcase
    npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/chownr
    npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/cliui
    npm ERR! extraneous: fs-minipass@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/fs-minipass
    npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: minipass@2.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minipass
    npm ERR! extraneous: minizlib@1.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minizlib
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/mkdirp
    npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/string-width
    npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/strip-ansi
    npm ERR! extraneous: tar@4.4.19 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/tar
    npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/wrap-ansi
    npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/y18n
    npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/yargs
    npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn/node_modules/which
    npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle/node_modules/cssom
    npm ERR! extraneous: webidl-conversions@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/domexception/node_modules/webidl-conversions
    npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip/node_modules/get-stream
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/mkdirp
    npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/rimraf
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument/node_modules/semver
    npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/cliui
    npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/yargs
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/yallist
    npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate/node_modules/camelcase
    npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker/node_modules/supports-color
    npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom/node_modules/ws
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/yallist
    npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/isarray
    npm ERR! extraneous: readable-stream@1.0.34 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/string_decoder
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minipass/node_modules/yallist
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib/node_modules/yallist
    npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object/node_modules/for-in
    npm ERR! extraneous: ansi-styles@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format/node_modules/ansi-styles
    npm ERR! extraneous: agent-base@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/agent-base
    npm ERR! extraneous: https-proxy-agent@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/https-proxy-agent
    npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/ws
    npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/rc/node_modules/strip-json-comments
    npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs/node_modules/tslib
    npm ERR! extraneous: kind-of@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/kind-of
    npm ERR! extraneous: lazy-cache@0.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/lazy-cache
    npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs/node_modules/chownr
    npm ERR! extraneous: readable-stream@3.6.2 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream/node_modules/readable-stream
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar/node_modules/yallist
    npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie/node_modules/universalify
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/yallist
    npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/brace-expansion
    npm ERR! extraneous: glob@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/glob
    npm ERR! extraneous: minimatch@5.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/minimatch
    npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream/node_modules/buffer
    npm ERR! extraneous: bluebird@3.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/bluebird
    npm ERR! extraneous: process-nextick-args@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/process-nextick-args
    npm ERR! extraneous: readable-stream@2.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/string_decoder
    npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/url/node_modules/punycode
    npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul/node_modules/source-map
    npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on/node_modules/axios
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-name
    npm ERR! extraneous: commander@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/commander
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/supports-color
    npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yargs/node_modules/yargs-parser
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-06T19_49_13_303Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-06T19_49_44_467Z-debug-0.log
    Adapters from github:   7
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.bidirectional-counter.0  : bidirectional-counter : raspberrypi                              - disabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
      system.adapter.deyeidc.1                : deyeidc               : raspberrypi                              -  enabled, port: 8899
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              - disabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.material.0               : material              : raspberrypi                              -  enabled
      system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.tuya.1                   : tuya                  : raspberrypi                              - disabled
      system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "landroid"     : 1.0.3    , installed 1.0.3
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.4.5    , installed 6.4.5
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "telegram-menu": 0.7.1    , installed 0.7.1
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vaillant"     : 0.1.2    , installed 0.2.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 6.1.4    , installed 6.1.4
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        33316
    States:         26083
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13873      531/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12106      556/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13872      531/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12108      556/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12011      394/avahi-daemon: r
    udp        0      0 0.0.0.0:35226           0.0.0.0:*                           108        12013      394/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13910      560/cups-browsed
    udp6       0      0 :::5353                 :::*                                108        12012      394/avahi-daemon: r
    udp6       0      0 fe80::74d7:97e8:dd2:546 :::*                                0          15272      404/NetworkManager
    udp6       0      0 :::58181                :::*                                108        12014      394/avahi-daemon: r
    2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.deyeidc.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:34.266  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:34.282  - info: host.raspberrypi instance system.adapter.ws.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:35.104  - info: tuya.0 (3860) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-06 20:40:34.301  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:34.302  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:35.495  - info: tuya.0 (3860) terminating
    2023-11-06 20:40:35.496  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
    2023-11-06 20:40:35.497  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
    2023-11-06 20:40:35.497  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGTERM
    2023-11-06 20:40:35.497  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
    2023-11-06 20:40:35.498  - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGTERM
    2023-11-06 20:40:35.498  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
    2023-11-06 20:40:35.498  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
    2023-11-06 20:40:35.498  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
    2023-11-06 20:40:35.499  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
    2023-11-06 20:40:35.499  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2023-11-06 20:40:35.499  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
    2023-11-06 20:40:35.499  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
    2023-11-06 20:40:35.500  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:35.734  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2023-11-06 20:40:35.905  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-06 20:40:35.906  - info: host.raspberrypi All instances are stopped.
    2023-11-06 20:40:36.030  - info: host.raspberrypi terminated
    iob diag has finished.
    Press any key for a summary
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            7.8G        115M        6.6G        1.0M        1.1G        7.6G
    Swap:            99M          0B         99M
    Total:          7.9G        115M        6.7G
    Active iob-Instances:   1
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:                33316
    States:                 26083
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    7.2M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    @ralle sagte in keine Updates bei IOB mehr möglich:
    npm ERR! invalid: iobroker.worx@2.3.4 /opt/iobroker/node_modules/iobroker.worx
    z.b.
    ralleR 1 Antwort Letzte Antwort
      z.b.
      ralleR Offline
      ralleR Offline
      ralle
      hast du dafür auch etwas parat um die npm error zu beseitigen
      • ralleR ralle
        @ralle
        Hatte ich schon geschrieben:
        iob upgrade worx@2.3.4
        Und dann mal schauen:
        cd /opt/iobroker
        npm prune
        npm ls
          @ralle
          cd /opt/iobroker
          npm prune
          npm ls
          ralleR Offline
          ralleR Offline
          ralle
          @thomas-braun said in keine Updates bei IOB mehr möglich:
          Die Konsole steht seit 7 Minuten
          pi@raspberrypi:~ $ iob upgrade worx@2.3.4
          Would you like to reinstall version 2.3.4 of worx now? [(y)es, (n)o]: y
          Update worx from @2.3.4 to @2.3.4
          NPM version: 9.8.1
          Installing iobroker.worx@2.3.4... (System call)
          passiert nichts mehr........
          • ralleR ralle
            NPM version: 9.8.1
            @ralle zweite session öffnen und wenn es noch geht mit top nachsehen
            • ralleR ralle
              NPM version: 9.8.1
              Doch. Irgendwas muss da irgendwann passieren. Nicht immer so ungeduldig sein mit den kleinen Kistchen.
                ralleR Offline
                ralleR Offline
                ralle
                @homoran hab ich auf und top gestartet, für mich jetzt böhmische Dörfer
                • ralleR ralle
                  und dewegen zeigst du nichts davon?
                    ralleR Offline
                    ralleR Offline
                    ralle
                    hast recht nach 14 minuten gehts weiter
                    • ralleR ralle
                      Natürlich...
                      npm muss sich ja durch die ganzen Fehler quälen.
                        Natürlich...
                        ralleR Offline
                        ralleR Offline
                        ralle
                        so jetzt noch einmal iob diag....
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : armhf
                        Systemuptime and Load:
                         21:57:29 up  1:40,  2 users,  load average: 0.47, 3.05, 3.34
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Mon 2023-11-06 21:57:29 CET
                                   Universal time: Mon 2023-11-06 20:57:29 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        116M        6.0G        1.0M        1.7G        7.6G
                        Swap:            99M          0B         99M
                        Total:          7.9G        116M        6.1G
                                 7812 M total memory
                                  116 M used memory
                                  164 M active memory
                                 1269 M inactive memory
                                 6039 M free memory
                                  244 M buffer memory
                                 1411 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                        * iobroker.service loaded failed failed ioBroker Server
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       15G  8.4G  5.3G  62% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                        tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                        [Mon Nov  6 20:17:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:65:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d0e90a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Mon Nov  6 20:17:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Mon Nov  6 20:17:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Mon Nov  6 20:17:17 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.9G    /var/
                        1.5G    /var/log/journal/9de79e4d9feb4ead979df62e580afcd8
                        1.5G    /var/log
                        129M    /var/cache
                        Archived and active journals take up 1.4G in the file system.
                        /opt/iobroker/backups:
                        162M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        1.6G    /opt/iobroker/iobroker-data/
                        899M    /opt/iobroker/iobroker-data/history
                        617M    /opt/iobroker/iobroker-data/files
                        88M     /opt/iobroker/iobroker-data/files/echarts.admin
                        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                        USB-Devices by-id:
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Installed: 18.18.2-1nodesource1
                          Candidate: 18.18.2-1nodesource1
                          Version table:
                         *** 18.18.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u4 500
                        No problems detected
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        33253
                        States:         26032
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Pending Updates: 0
                        2023-11-06 21:16:45.859  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]: Error: DB closed
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Object.onceWrapper (node:events:632:26)
                        2023-11-06 21:16:45.861  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:517:28)
                        2023-11-06 21:16:45.862  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                        2023-11-06 21:16:45.862  - error: host.raspberrypi Caught by controller[0]:     at TCP.<anonymous> (node:net:350:12)
                        2023-11-06 21:16:45.862  - warn: host.raspberrypi instance system.adapter.shelly.0 terminated due to SIGTERM
                        2023-11-06 21:16:45.862  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code null ()
                        2023-11-06 21:16:45.862  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGTERM
                        2023-11-06 21:16:45.862  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
                        2023-11-06 21:16:45.863  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
                        2023-11-06 21:16:45.863  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
                        2023-11-06 21:16:45.863  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
                        2023-11-06 21:16:45.863  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                        2023-11-06 21:16:45.899  - info: host.raspberrypi instance system.adapter.ws.0 terminated with code 0 (NO_ERROR)
                        2023-11-06 21:16:45.899  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
                        2023-11-06 21:16:45.899  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
                        2023-11-06 21:16:46.055  - info: tuya.0 (7182) terminating
                        2023-11-06 21:16:46.065  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                        2023-11-06 21:16:46.297  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-11-06 21:16:46.297  - info: host.raspberrypi All instances are stopped.
                        2023-11-06 21:16:46.552  - info: host.raspberrypi terminated
                        NPM Fehler sind nach dem Update von Works weg......
                        Copy text starting here:
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               armhf
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        MEMORY:
                        Mem:            7.8G        115M        6.0G        1.0M        1.7G        7.6G
                        Swap:            99M          0B         99M
                        Total:          7.9G        115M        6.1G
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                33253
                        States:                 26032
                        26M     /opt/iobroker/iobroker-data/objects.jsonl
                        • ralleR ralle
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7812 M total memory
                                    116 M used memory
                                    164 M active memory
                                   6039 M free memory
                                    244 M buffer memory
                                   1411 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.9G    /var/
                          1.5G    /var/log
                          129M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        33253
                          States:         26032
                          Pending Updates: 0
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               armhf
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.8.1
                                                  /usr/bin/npx            9.8.1
                          MEMORY:
                          Swap:            99M          0B         99M
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                33253
                          States:                 26032
                          iob fix
                          iob start
                          • ralleR Offline
                            ralleR Offline
                            ralle
                            iob start
                            Soo, IOB startet gerade. Vielen Vielen dank an dich / euch für eure Mühe die ihr euch gemacht habt.
                            DANKE!!
                            • ralleR ralle
                              iob start
                              DANKE!!
                              @ralle
                              Dann zeig jetzt nochmal
                              iob diag
                              mit laufendem ioBroker
                                @ralle
                                iob diag
                                ralleR Offline
                                ralleR Offline
                                ralle
                                siehe da:
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : armhf
                                 22:28:33 up  2:11,  2 users,  load average: 1.24, 1.56, 2.20
                                CPU threads: 4
                                Current issues:
                                               Local time: Mon 2023-11-06 22:28:33 CET
                                           Universal time: Mon 2023-11-06 21:28:33 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.8G        1.3G        4.8G        1.0M        1.7G        6.4G
                                Swap:            99M          0B         99M
                                Total:          7.9G        1.3G        4.9G
                                         7812 M total memory
                                         1326 M used memory
                                         1344 M active memory
                                         1288 M inactive memory
                                         4810 M free memory
                                          250 M buffer memory
                                         1424 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       15G  8.5G  5.3G  62% /
                                /var:
                                1.9G    /var/
                                1.5G    /var/log
                                129M    /var/cache
                                23M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.4
                                Adapter State
                                + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                + system.adapter.deyeidc.1                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                + system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                                + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Objects and States
                                Objects:        31505
                                States:         24472
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       114042     17222/iobroker.js-c
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       114760     17222/iobroker.js-c
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       114989     17346/io.sonoff.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       116925     17578/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       112262     17241/io.admin.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       115958     17602/io.ws.0
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       114533     17339/io.shelly.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       113573     17361/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       113574     17361/io.tuya.0
                                                        v.2023-10-10
                                         Icon name: computer
                                      Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               armhf
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                MEMORY:
                                Mem:            7.8G        1.4G        4.7G        1.0M        1.7G        6.3G
                                Swap:            99M          0B         99M
                                Total:          7.9G        1.4G        4.8G
                                Active iob-Instances:   27
                                                        admin                   6.12.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                31505
                                States:                 24472
                                17M     /opt/iobroker/iobroker-data/states.jsonl
                                • ralleR ralle
                                  siehe da:
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : armhf
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           7812 M total memory
                                           1326 M used memory
                                           4810 M free memory
                                            250 M buffer memory
                                           1424 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  1.9G    /var/
                                  1.5G    /var/log
                                  129M    /var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        31505
                                  States:         24472
                                  Pending Updates: 0
                                                          v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               armhf
                                  User-ID:                1000
                                  X-Server:               false
                                                          /usr/bin/npm            9.8.1
                                                          /usr/bin/npx            9.8.1
                                  MEMORY:
                                  Swap:            99M          0B         99M
                                                          admin                   6.12.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                31505
                                  States:                 24472
                                  @ralle
                                  Jetzt passt es. Die Kiste dürfte auch wieder normal reagieren.
                                    @ralle
                                    ralleR Offline
                                    ralleR Offline
                                    ralle
                                    Ja, ist auf jeden fall schneller... vielen Dank für die Hilfe.
                                    • ralleR ralle
                                      siehe da:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : armhf
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               7812 M total memory
                                               1326 M used memory
                                               4810 M free memory
                                                250 M buffer memory
                                               1424 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.9G    /var/
                                      1.5G    /var/log
                                      129M    /var/cache
                                      USB-Devices by-id:
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        31505
                                      States:         24472
                                      Pending Updates: 0
                                                              v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               armhf
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Swap:            99M          0B         99M
                                                              admin                   6.12.0
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                31505
                                      States:                 24472
                                      ist das noch nötig?
