  4. Test Adapter Adapter-alexa-timer-vis v0.1.x GitHub/Latest
92 Beiträge 15 Kommentatoren 17.6k Aufrufe 23 Beobachtet
  • Michael RolingM Michael Roling
    @siggi0904 schau mal hier https://github.com/MiRo1310/ioBroker.alexa-timer-vis/issues/64
    Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    #79
    @michael-roling ne, das Thema ist mit der aktuellen Stable vom Alexa2-Adapter behoben.
    Bei neuen Timern triggert auch gut. Nur kann ich die Timer nicht abbrechen.
    Siehe og. Fehlerlog passt das Datenformat wohl nicht.
    Deswegen sieht das log ja aktuell so aus:
    2023-11-05 12:00:26.403 - warn: ical.0 (2578407) get state error: Connection is closed.
    2023-11-05 12:00:26.501 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-11-05 12:01:31.927 - error: alexa-timer-vis.0 (2566806) uncaught exception: Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
    2023-11-05 12:01:31.932 - error: alexa-timer-vis.0 (2566806) Error: Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
    at Validator.assertNumber (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:205:19)
    at AlexaTimerVis.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1718:31)
    at interval (/opt/iobroker/node_modules/iobroker.alexa-timer-vis/main.js:646:51)
    at /opt/iobroker/node_modules/iobroker.alexa-timer-vis/main.js:654:11
    at Timeout. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1720:38)
    at listOnTimeout (node:internal/timers:569:17)
    at process.processTimers (node:internal/timers:512:7)
    2023-11-05 12:01:31.932 - error: alexa-timer-vis.0 (2566806) Parameter "timeout" needs to be of type "number" but type "undefined" has been passed
    2023-11-05 12:01:31.943 - info: alexa-timer-vis.0 (2566806) Apdater shuts down
    2023-11-05 12:01:31.948 - info: alexa-timer-vis.0 (2566806) Intervals and timeouts cleared!
    2023-11-05 12:01:31.953 - info: alexa-timer-vis.0 (2566806) terminating
    2023-11-05 12:01:31.955 - warn: alexa-timer-vis.0 (2566806) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-11-05 12:01:32.456 - info: alexa-timer-vis.0 (2566806) terminating
    2023-11-05 12:01:32.576 - error: host.iobroker instance system.adapter.alexa-timer-vis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-11-05 12:01:32.577 - info: host.iobroker Restart adapter system.adapter.alexa-timer-vis.0 because enabled
    2023-11-05 12:02:02.746 - info: host.iobroker instance system.adapter.alexa-timer-vis.0 started with pid 2581587
    2023-11-05 12:02:05.382 - info: alexa-timer-vis.0 (2581587) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.alexa-timer-vis, node: v18.18.2, js-controller: 5.0.12
    2023-11-05 12:02:05.446 - info: alexa-timer-vis.0 (2581587) Alexa State was found
    Michael RolingM 1 Antwort Letzte Antwort
    • Siggi0904S Siggi0904
      Michael RolingM Offline
      Michael Roling
      schrieb am zuletzt editiert von Michael Roling
      #80
      @siggi0904 wie brichst du ab? s
      Siggi0904S 1 Antwort Letzte Antwort
        Siggi0904S Offline
        Siggi0904S Offline
        Siggi0904
        #81
        @michael-roling Ansage "Alexa, Timer abbrechen"
          Michael Roling
          #82
          @siggi0904 leider kann ich so nicht weiter helfen, bei mir läuft es ganz normal durch. welche version hast du denn installiert?
          sorry das steht ja im log, die 0.2.0
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
            #83
            @michael-roling ja, die stable 0.2.0 von deinem Adapter und Alexa2 Version 3.25.5.
            Ach ja, da fällt mir gleich noch was auf:
            Könntest du das Label des Timers aus dem Datenpunkt
            alexa2.0.Echo-Devices.G090L911746609UM.Timer.activeTimerList
            nehmen? Also den Label-Wert aus dem json von dem Datenpunkt?
            Der Text, der in History steht ist zu lang und beinhaltet den kompletten Aufruf.
            Z.B. "Neuer für die wäsche in Timer". Ich benenne nämlich gern die Timer.
              Michael Roling
              #84
              @siggi0904 du hast doch alles was man braucht 4b6e25a3-15a2-405c-91dd-206b6c0b7ddb-grafik.png
              oder versteh ich dich da falsch.
              Anscheinend gibt es immer noch probleme mit alexa2 und der aktualisierung, habe ich gerade mal die latest installiert, im moment geht aber garnichts.
              Im Moment läuft es doch!
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                #85
                @michael-roling Naja, dein Adapter nennt den Timer "Neuer für die wäsche in Timer"
                Alexa führt unter dem Datenpunkt "TimerID" den Timer mit dem richtigen Namen "Wäsche".
                Konntest du dir schon das Abbrechen anschauen?
                Also das falsche Datenformat?
                Wo finde ich eigentlich den Datenpunkt: "timeout"
                  Michael Roling
                  #86
                  @siggi0904 poste mal das komplette log von dem adapter, setze vorher mal log auf debug, wie gesagt hier läuft es ganz normal durch
                    Siggi0904S Offline
                    Siggi0904S Offline
                    Siggi0904
                    #87
                    @michael-roling kann ich dir das per Mail senden?
                    Das ist ganz schön viel.
                    Aber jetzt hat er beim Abbrechen des Timers keinen Fehler erzeugt.
                      Michael Roling
                      #88
                      @siggi0904 solange kein fehler kommt nutzt das log nichts. mit dem Namen könnte ich mir mal anschauen, am besten ein issue auf machen
                        Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        #89
                        @michael-roling okay. Dann beobachte ich das und mach ggf. ein Issue auf.
                        Vielleicht dann auch die Feature Requests zum Adapter. :-)
                        • FredFF Online
                          FredFF Online
                          FredF
                          Most Active Forum Testing
                          schrieb am zuletzt editiert von FredF
                          #90
                          Nach längerer Zeit wollte ich den Adapter wieder nutzen und merke gerade er funktioniert nicht (mehr).
                          Adapter ist grün,
                          Timer Datenpunkt des alexa2.0 Adapters wird auch gefüllt wenn ein Timer eingestellt ist,
                          Debug Log gibt keine Fehlermeldung aus.
                          Ich bin ratlos @Michael-Roling
                          • FredFF FredF
                            Adapter ist grün,
                            Michael Roling
                            #91
                            @fredf schau mal im Alexa2.0 Adapter. Da muss man meine ich optionen aktivieren damit etwas aktualisiert wird.
                              FredFF Online
                              FredFF Online
                              FredF
                              #92
                              @michael-roling
                              Ja, danke Fehler gefunden.
                              Ohne die Verlaufseinstellungen im alexa2.0 Adapter aktiviert zu haben geht es nicht.
