  4. HILFE, kein Zugriff auf IOBroker
    2.9k
    5.0k
138 Beiträge 11 Kommentatoren 18.7k Aufrufe 8 Beobachtet
    @tiobb
    iob nodejs-update
    tiobbT Offline
    tiobbT Offline
    tiobb
    schrieb am zuletzt editiert von tiobb
    #90
    @thomas-braun sagte in HILFE, kein Zugriff auf IOBroker:
    iob nodejs-update
    Läuft nicht wirklich, liegt sicherlich an mir, aber danke für die Geduld!!!
    pi@raspberrypi:~ $ iob nodejs-update
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    Raspberry Pi 4 8gb
    • tiobbT tiobb
      iob nodejs-update
      iobroker [command]
      Commands:
      Options:
      #91
      @tiobb
      iob stop
      iob fix
      iob nodejs-update
      tiobbT 1 Antwort Letzte Antwort
        @tiobb
        iob stop
        iob fix
        iob nodejs-update
        tiobbT Offline
        tiobbT Offline
        tiobb
        #92
        Hat geklappt, vielen Dank. Hast Du ne Ahnung warum ich keine neuen Adapter angezeigt bekomme, ich sehe nur die installierten? Ich brauche den Shelly Adapter für meine Heizungs- und Lichtsteuerung.
        Raspberry Pi 4 8gb
        DJMarc75D ArmilarA 2 Antworten Letzte Antwort
        • tiobbT tiobb
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #93
          @tiobb sagte in HILFE, kein Zugriff auf IOBroker:
          jo, Du hast einen Filter gesetzt:
          Lehrling seit 1975 !!!
          • tiobbT tiobb
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            Most Active Forum Testing
            #94
            Da kommt man einmal zu spät ;-) und die Kiste läuft 😊 ...
            Kleiner Tipp... mache Backups zwischendurch und zum Schluss auch noch ...
            • DJMarc75D DJMarc75
              tiobbT Offline
              tiobbT Offline
              tiobb
              #95
              @djmarc75 sagte in HILFE, kein Zugriff auf IOBroker:
              Komisch, da hatte ich ein paar mal drauf geklickt und das hatte nichts geändert :man-shrugging: DANKE!
              @armilar sagte in HILFE, kein Zugriff auf IOBroker:
              Vor 2 Jahren hatte ich ein Image der Speicherkarte erstellt, aber das zu erstellen dauert jedes mal sehr lange. Gibt es eine einfachere und schnellere Variante?
              Raspberry Pi 4 8gb
              DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
              • tiobbT tiobb
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #96
                Wenn dann klickt man immer nur einmal drauf und wartet bis sich die Ansicht aktualisiert (dauert ein wenig) ;)
                • tiobbT tiobb
                  #97
                  Den Backitup-Adapter? Der ist genau dafür gemacht.
                  DuffyD 1 Antwort Letzte Antwort
                    DuffyD Offline
                    DuffyD Offline
                    Duffy
                    #98
                    Wo wir schon beim Neuaufbau des iob sind, gibt es inzwischen eigentlich den Bücherwurm für den Raspberry und wenn nicht soll man dann nicht doch mal den "Normalen" Bücherwurm installieren oder geht da zu viel für den Raspberry verloren?
                    VG Duffy
                    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                    Node.js: v22.23.1
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                    • DuffyD Duffy
                      VG Duffy
                      #99
                      @duffy
                      Raspberry OS 'Bookworm' ist veröffentlicht.
                      Was soll denn der 'normale' sein?
                        @duffy
                        DuffyD Offline
                        DuffyD Offline
                        Duffy
                        schrieb am zuletzt editiert von Duffy
                        #100
                        Mit „Normale“ meinte ich das was nicht für den Pi war und schon Mitte des Jahres raus kam.
                        Wie bekomme ich den Wurm nun auf meinen Pi? So wie von dir damals hier im Forum beschrieben?
                        Wenn ja, woher weis der Pi dann ob er das „normale“ oder das Pi OS ziehen soll?
                        Du merkst ich bin weit weg von einem Experten ☹️
                        Edit: Habe gerade noch mal deinen Beitrag zum Upgrade gelesen. Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen 🙈, richtig?
                        Auf meinem Testpi hatte ich mal den „normalen“ Bücherwurm installiert ist es vielleicht ratsam diese Version zu nehmen um eine Neuinstallation zu verhindern?
                        Ich habe zwar Backups aber never touch a …..
                        Node.js: v22.23.1
                        NPM: 10.9.4
                        js-controller 7.1.2
                        Linux: Trixie
                        • DuffyD Duffy
                          #101
                          @duffy sagte in HILFE, kein Zugriff auf IOBroker:
                          Wenn ich es richtig verstehe muss ich den Pi ohnehin neu aufsetzen , richtig?
                          Am besten.
                          Aber ich verstehe immer noch nicht, was du mit 'normal' und 'für den Raspberry ' meinst. Es gibt keine zwei Versionen. Lediglich die Raspberry-spezifischen Ergänzungen und Anpassungen wurden erst kürzlich veröffentlicht.
                            tiobbT Offline
                            tiobbT Offline
                            tiobb
                            #102
                            Da war ich wohl zu ungeduldig 😇 MERCI
                            Danke! Ich dachte es gibt eine "einfache" Möglichkeit das extern zu sichern, falls die SD Karte mal schlapp macht. Aber für den Anfang besser als nichts, und wenn alles läuft mach ich ein Image, und ich werde wohl mal eine SSD statt die SD Karte her nehmen.
                            Leider bekomme ich den Shelly und das MQTT nicht zum laufen obwohl ich alle Einstellungen so vorgenommen habe wie vor dem Absturz, hatte mir die Einstellungen mal per Screenshot gespeichert.
                            Raspberry Pi 4 8gb
                            • tiobbT tiobb
                              #103
                              Wie viel externer als die diversen Möglichkeiten das extern abzulegen soll es denn noch sein? NAS, Google Drive, etc ...
                                tiobbT Offline
                                tiobbT Offline
                                tiobb
                                #104
                                dachte ich könnte es direkt vom Pi extern ablegen.
                                Raspberry Pi 4 8gb
                                V DJMarc75D Thomas BraunT 3 Antworten Letzte Antwort
                                • tiobbT tiobb
                                  V Offline
                                  V Offline
                                  Verblizz
                                  #105
                                  @tiobb said in HILFE, kein Zugriff auf IOBroker:
                                  Das kannst Du doch im BackItUp-Adapter einstellen. So sicherst Du direkt vom Pi auf irgendwas externes, was Du halt einstellst...
                                  • tiobbT tiobb
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #106
                                    ja und genau dafür gibt es den Backitup Adapter.
                                    • tiobbT tiobb
                                      #107
                                      @tiobb
                                      ? Das macht der Backitup doch. Wenn man den entsprechend einrichtet in regelmäßigen Intervallen vollkommen automatisch.
                                      Dein händisches Image von irgendwas ist dann wieder genauso veraltet wie dein jetziges 'Backup'.
                                        @tiobb
                                        tiobbT Offline
                                        tiobbT Offline
                                        tiobb
                                        #108
                                        @Verblizz
                                        @DJMarc75
                                        Hab die Einstellungen gefunden und Google Drive aktiviert.
                                        Raspberry Pi 4 8gb
                                          Am besten.
                                          DuffyD Offline
                                          DuffyD Offline
                                          Duffy
                                          #109
                                          Dann will ich mal noch kurz meine Unglückliche Formulierung korrigieren :-)
                                          Mit "normal" meinte ich das Bookworm der OHNE die Raspberry-spezifischen Ergänzungen und Anpassungen.
                                          Node.js: v22.23.1
                                          NPM: 10.9.4
                                          js-controller 7.1.2
                                          Linux: Trixie
