  4. Awattar - die billigsten Strom-Stunden nutzen
    apollon77A
82 Beiträge 10 Kommentatoren 19.6k Aufrufe 9 Beobachtet
  • D Doom.86
    @paul53 geht es so?
    2023-01-11 17:59:00.130 - warn: javascript.0 (11927) getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926bXXXXPricesTomorrow.16.total" not found (3)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:19:17)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
    2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
    2023-01-11 17:59:00.132 - warn: javascript.0 (11927) getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926bXXXXPricesTomorrow.17.total" not found (3)
    2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:19:17)
    2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
    2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    2023-01-11 17:59:00.137 - warn: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
    2023-01-11 17:59:00.137 - warn: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
    2023-01-11 17:59:00.143 - error: javascript.0 (11927) script.js.Heizung_Nacht_Tibber: TypeError: Cannot read properties of undefined (reading 'toString')
    2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:54:62)
    2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
    2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    2023-01-11 17:59:00.145 - error: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    2023-01-11 17:59:00.145 - error: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    2023-01-11 17:59:00.145 - error: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
    2023-01-11 17:59:00.145 - error: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
    Das zieht sich so weiter. Und tibber hat wie gesagt scheinbar Probleme heute.
    paul53P
    paul53P
    @doom-86 sagte:
    getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926b4a69PricesTomorrow.16.total" not found
    Am Ende des Strings der Variablen tibber fehlt ein Punkt! Richtig:
    tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926b4a69.PricesTomorrow.16.total
    Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
    D 2 Antworten Letzte Antwort
      @doom-86 sagte:
      D
      D
      Doom.86
      schrieb am zuletzt editiert von Doom.86
      @paul53 ah. Alles klar. Vielen Dank. Dann morgen auf einen neuen Versuch. Vorausgesetzt tibber bringt ihr Zeug auch wieder auf die Reihe. Bekomme aktuell keine Daten mehr. Auf ihrer Homepage steht etwas mit Problemen.
        @doom-86 sagte:
        D
        D
        Doom.86
        @paul53 Hallo Paul. Es funktioniert. alles so weit. Vielen Dank für deine mühe.
        Eine kleine Frage habe ich noch, lassen sich die Zeiten evtl in einem Datenpunkt auswerten, um diese für andere Dinge zu nutzen oder zur kontrolle, welche Uhrzeiten er berechnet hat?
        • D Doom.86
          paul53P
          paul53P
          @doom-86 sagte: lassen sich die Zeiten evtl in einem Datenpunkt auswerten
          Welche Zeiten? start1h, start3h? Die lassen sich nach der Ermittlung in Datenpunkte schreiben ("aktualisiere").
            D
            D
            Doom.86
            @paul53 genau die meinte ich. Wie setze ich die dann am besten ein?
            • D Doom.86
              paul53P
              paul53P
              @doom-86 sagte: Wie setze ich die dann am besten ein?
              Z.B. ganz unten im Trigger (vor oder nach den Zeitplänen).
                D
                D
                Doom.86
                @paul53 perfekt. Vielen lieben Dank dafür nochmals.
                Jetzt verstehe ich wenigsten schon ein wenig mehr von dem ganzen.
                  @badsnoopy667 sagte: Blockly Export des funktionierenden Scripts posten?
                  Vielleicht kann ich aushelfen?
                   <variables>
                     <variable id="f%{MYK|pqx/msm?jLTCv">sort</variable>
                     <variable id="m[W;a/*+Ku4g|deZEV$r">i</variable>
                     <variable id="@!RPgtnzVwyGIa5#?5i^">id</variable>
                     <variable id=":s^oe|FI,MTykE.d|vjJ">idDate</variable>
                     <variable id="JU=3dvDJ]OgXqBlqGYM[">ww</variable>
                     <variable id="Pw_FHmi}c0-([@-$Ax/M">fbh</variable>
                     <variable id="_Nuc-_3~VS;%yQn+g$9o">stunde</variable>
                     <variable id="eTgx)$hD2knDGoSo3`$M">idPreis</variable>
                   </variables>
                   <block type="schedule" id="t0ptX_hB3?gNErGP2-44" x="113" y="-68">
                     <field name="SCHEDULE">0 * * * *</field>
                     <statement name="STATEMENT">
                       <block type="variables_set" id="m$Bu`}K+wC*Ia!$Q/87$">
                         <field name="VAR" id="f%{MYK|pqx/msm?jLTCv">sort</field>
                         <value name="VALUE">
                           <block type="math_number" id="#Y.8dvJg[RZkNDtw^?ge">
                             <field name="NUM">0</field>
                           </block>
                         </value>
                         <next>
                           <block type="controls_for" id="^I#Vwi@:8cPB@~p6g4[I">
                             <field name="VAR" id="m[W;a/*+Ku4g|deZEV$r">i</field>
                             <value name="FROM">
                               <shadow type="math_number" id="uK{nB-7z.a?d2|?NGC;Y">
                                 <field name="NUM">1</field>
                               </shadow>
                             </value>
                             <value name="TO">
                               <shadow type="math_number" id="y!?o50tye=EtN2yfubW2">
                                 <field name="NUM">10</field>
                               </shadow>
                               <block type="lists_length" id="*oxxY{FFu2$ya+KAs-wC">
                                   <block type="selector" id="UvXOT+v,~RTtJ(+zw]PQ">
                                     <field name="TEXT">awattar.0.pricesOrdered.*.start</field>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="BY">
                               <shadow type="math_number" id="XWtiOpI~HC)?jkUGVR#Z">
                               </shadow>
                             </value>
                             <statement name="DO">
                               <block type="variables_set" id="@6Q{Y~(8Y@DvAP5)^:aE">
                                 <field name="VAR" id="@!RPgtnzVwyGIa5#?5i^">id</field>
                                   <block type="text_join" id=":S}lgn4j$S!St8ojec/%" inline="true">
                                     <value name="ADD0">
                                       <block type="text" id="9YR/b:Op#Q=COcF=yT$$">
                                         <field name="TEXT">awattar.0.pricesOrdered.</field>
                                       </block>
                                     </value>
                                     <value name="ADD1">
                                       <block type="math_arithmetic" id="#{n:)]S0R`q*x*Zz}xDY">
                                         <value name="A">
                                           <shadow type="math_number" id="B(,hr0]jxUo9H6p],:.U">
                                           </shadow>
                                           <block type="variables_get" id="fmi9JMsXie[7AqYh!5?f">
                                           </block>
                                         </value>
                                         <value name="B">
                                           <shadow type="math_number" id="?{U^ty/@sgP38@F_w{Ga">
                                           </shadow>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="ADD2">
                                       <block type="text" id="`O,1MghUJ^/p@hp}d.l0">
                                         <field name="TEXT">.start</field>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                   <block type="variables_set" id="]nDOX,W{}z:NK:^cE_+z">
                                     <field name="VAR" id=":s^oe|FI,MTykE.d|vjJ">idDate</field>
                                       <block type="text_join" id="JO^u9Ozg7[rg?[hC`|bI" inline="true">
                                         <value name="ADD0">
                                           <block type="variables_get" id="$HCexy7I`Z}sE30y`}Si">
                                           </block>
                                         </value>
                                         <value name="ADD1">
                                           <block type="text" id="^%_^Mo2RG**$)[JZch2-">
                                             <field name="TEXT">Date</field>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                       <block type="controls_if" id="Ey5j%EGWhO%gDOn^`uVS">
                                         <value name="IF0">
                                           <block type="logic_compare" id="8xG3/SRk,Q6)#^#9)]rM">
                                             <field name="OP">EQ</field>
                                             <value name="A">
                                               <block type="get_value_var" id="oM%Z$lb7%04#3?HdX9l3">
                                                 <value name="OID">
                                                   <shadow type="text" id="T[22+A?Ql{.;LwfBQFZ^">
                                                     <field name="TEXT"></field>
                                                   </shadow>
                                                   <block type="variables_get" id="Y!n8IH|K)x%M{S1U6YKG">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="B">
                                               <block type="time_get" id=")E[gSkt[:I!t}QmJ$@@z">
                                                 <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                 <field name="OPTION">custom</field>
                                                 <field name="FORMAT">T.M.JJJJ</field>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <statement name="DO0">
                                           <block type="math_change" id="t4_:*m`)g)Lm(1d9NTtt">
                                             <value name="DELTA">
                                               <shadow type="math_number" id="/gPA7?+l(J60?@MMvM[b">
                                               </shadow>
                                             </value>
                                             <next>
                                               <block type="controls_if" id="c37l0tBG(dWgrG[_jJ*H">
                                                 <value name="IF0">
                                                   <block type="logic_compare" id="ggTAH!IN|c^#NP3#fe$i">
                                                     <value name="A">
                                                       <block type="get_value_var" id="DzQ]#W-I`,-WpvdB~r^=">
                                                         <value name="OID">
                                                           <shadow type="text">
                                                           </shadow>
                                                           <block type="variables_get" id="PzTgSjUnKn}L~+Lu7;iE">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <block type="time_get" id="wfRYY0aB3ajC#/tjN2]d">
                                                         <field name="OPTION">hh:mm:ss</field>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                   <block type="controls_if" id="gcRTE/pXe9yqfB@(m(ie">
                                                     <mutation elseif="1" else="1"></mutation>
                                                     <value name="IF0">
                                                       <block type="logic_compare" id="+Gs?^;C}J@CnzUI3]It/">
                                                         <field name="OP">LTE</field>
                                                         <value name="A">
                                                           <block type="variables_get" id="ntc!u-;4R:RVfbXoD,g3">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           <block type="math_number" id="Zh5JIS[O;{KFd7+dglib">
                                                             <field name="NUM">6</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                       <block type="variables_set" id="oK,Vo]}VE~hn!wMb%EaQ">
                                                         <field name="VAR" id="JU=3dvDJ]OgXqBlqGYM[">ww</field>
                                                           <block type="logic_boolean" id="MI7#Ba{K$P~ECPrcQ8~u">
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="variables_set" id="GRjr1|q-qv~bZ_]x-b-V">
                                                             <field name="VAR" id="Pw_FHmi}c0-([@-$Ax/M">fbh</field>
                                                               <block type="logic_boolean" id="+BKshPHTFX$)Axk,s:D3">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <value name="IF1">
                                                       <block type="logic_compare" id="_r:fA@(Q@C=RBwAM0*Aj">
                                                         <value name="A">
                                                           <block type="variables_get" id="LUO{za(7%1bLUGPXF0-I">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           <block type="math_number" id="7J4^!@k2T`nB=tV8earE">
                                                             <field name="NUM">12</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <statement name="DO1">
                                                       <block type="variables_set" id="n.Ik|u:~_:hM36]!*QlD">
                                                           <block type="logic_boolean" id="owYb%`7T54.}wrm+]u-g">
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="variables_set" id="E`4`IKL)y:A}rSN:Kg(p">
                                                               <block type="logic_boolean" id="S+l[m~BVrGqKTJb!u8V-">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <statement name="ELSE">
                                                       <block type="variables_set" id="HS:r/kU.]y/[Z]iPi_Xr">
                                                           <block type="logic_boolean" id="0o]?]!J4GKIPzNqOziK%">
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="variables_set" id="RyL3o?ihAvyDZWomwrme">
                                                               <block type="logic_boolean" id="!QO~MyG$F#Fb;EbX.RB]">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                       <block type="controls_flow_statements" id="eWKTtP5}AB!o0E=d@X15">
                                                         <field name="FLOW">BREAK</field>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <next>
                               <block type="control" id="2`n*#WlwbkPU!2|uD_e`" disabled="true">
                                   <block type="variables_get" id="3;29{]Xqb0Tg.hordU+L">
                                   </block>
                                 </value>
                                 <next>
                                   <block type="control" id="y!s1?^8XonrSSD^d:]-|" disabled="true">
                                       <block type="variables_get" id=")uE};lZj2G04W=qRg|E`">
                                       </block>
                                     </value>
                                     <next>
                                       <block type="variables_set" id="~hBW|XS(8x%+xwAf%Kkv">
                                         <field name="VAR" id="_Nuc-_3~VS;%yQn+g$9o">stunde</field>
                                           <block type="time_get" id=":GeZIU-{w4?TE0BC@D|Y">
                                             <field name="OPTION">h</field>
                                           </block>
                                         </value>
                                         <next>
                                           <block type="variables_set" id="MQ@9vpbm0twY]C|ujABd">
                                               <block type="text_join" id=",ml%b@CiFZA2:9!l,1Hd">
                                                 <value name="ADD0">
                                                   <block type="text" id="K!zbGiH(RdzY+?0kVwG?">
                                                     <field name="TEXT">awattar.0.prices.</field>
                                                   </block>
                                                 </value>
                                                 <value name="ADD1">
                                                   <block type="variables_get" id="]`Ue]rEZm7kbr*_a,O$`">
                                                   </block>
                                                 </value>
                                                 <value name="ADD2">
                                                   <block type="text" id=",|)+9AGe$r8n[(NaedI4">
                                                     <field name="TEXT">.startDate</field>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="controls_if" id="69d^VUAHY?4b|j+@cXXw">
                                                 <value name="IF0">
                                                   <block type="logic_compare" id="0)RD}*w5Z$6h6O6Y{l1+">
                                                     <value name="A">
                                                       <block type="get_value_var" id="m`SbczVWHA#5}g,*s}x^">
                                                         <value name="OID">
                                                           <shadow type="text" id="3LUz^-^E[f,3{G:^Tv_x">
                                                           </shadow>
                                                           <block type="variables_get" id="qEhWJ_x(1|EN.#(R#t=`">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <block type="time_get" id="5{1=BKF0rCri;MxB9KMW">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                   <block type="variables_set" id="r66/JkWBU^B+v3bwZ4N/">
                                                     <field name="VAR" id="eTgx)$hD2knDGoSo3`$M">idPreis</field>
                                                       <block type="text_join" id="TxKK9Mb%:ZwT;xy6`Z?#">
                                                         <value name="ADD0">
                                                           <block type="text" id="!i2i}@Dt?zME37}xdZ4%">
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           <block type="variables_get" id="3Rl5pi,Iqn76rA_Yw,c+">
                                                           </block>
                                                         </value>
                                                         <value name="ADD2">
                                                           <block type="text" id="bYfIMeLQIW-zILKzxG$v">
                                                             <field name="TEXT">.totalPriceKwh</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                                   <block type="variables_set" id="!=SM:O1]Fn%djj4I@[$@">
                                                       <block type="text_join" id="=!:etc4,Sj2`LkAuWUi*">
                                                         <value name="ADD0">
                                                           <block type="text" id="GlFO;(aqT@I[#6XC?F@b">
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           <block type="math_arithmetic" id="J1iK){0l.}VR?9A|H6N3">
                                                             <field name="OP">ADD</field>
                                                             <value name="A">
                                                               <shadow type="math_number" id="S8Ud;PQu.R(l}h{a$ExG">
                                                               </shadow>
                                                               <block type="variables_get" id="/vSTWPMaL^9Zc(4Od2gk">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <shadow type="math_number" id="Whk;c?I`L0q;G{~VUpr+">
        <field name="NUM">24</field>
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="ADD2">
                                                           <block type="text" id="[[)x,2!m+xiek{D+}Ktx">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                   <block type="debug" id="JdM:egWf%4hJYB{}8gx}">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="7kGslysPGVf%Cp7dUL8I">
                                                       </shadow>
                                                       <block type="text_join" id="v{_niA}T~y_?=wCx#Q?M">
                                                         <value name="ADD0">
                                                           <block type="text" id="{-H2@_KSQrc4Y.U=oSfa">
                                                             <field name="TEXT">aktueller Preis: </field>
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           <block type="math_rndfixed" id="IONixpM;:VMse8:5*@eU">
                                                             <field name="n">2</field>
                                                             <value name="x">
                                                               <shadow type="math_number" id="RQE~cVZF?);/~.)Q9fB*">
        <field name="NUM">3.1234</field>
                                                               </shadow>
                                                               <block type="get_value_var" id="SL=6p7RH_[k]M9r45=ls">
        <value name="OID">
        <shadow type="text" id="7zK$!`js6l9s[Ane:X5k">
        </shadow>
        <block type="variables_get" id="X5LHou*mGG0^M;o3!Qi(">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                  </xml>
                  P
                  P
                  peter969
                  @paul53 Hi, ich habe mir aus Post 36 das Skript geholt und meine Funksteckdosen bei "steuere" eingefügt. Leider werden diese nicht geschaltet. Muss ich noch was ändern/machen? Ich sehe da nicht so wirklich durch.
                  • W
                    W
                    wof
                    #66
                    Hallo Leute, zuerst mal vielen Dank an @paul53 für seine Hilfe, hat mir sehr geholfen :-)
                    Ich möchte noch anmerken, das man in Verbindung mit einer Wärmepumpe die Starts derselben im Auge behalten sollte. Die Starts killen den Verdichter, nicht die Laufzeit!
                    Ich zB lese den Status meiner ViessmannWP aus, läuft der Verdichter sowieso und die Preise sind niedrig (oder es ist genug PV Überschuss da), erhöhe ich den jeweiligen Sollwert ( WW/Hzg)
                    Extra starten darf er bei mir jedoch nicht...
                    • J
                      J
                      JayJay 0
                      #67
                      ich bin so frei und hol den thread mal nach oben.
                      hat das ganze irgendwer nun komplett zusammen geschraubt und funktioniert das auch ?
                      • J JayJay 0
                        J
                        J
                        judisi
                        schrieb am zuletzt editiert von judisi
                        #68
                        @jayjay-0 bei mir hängt Waschmaschine, Geschirrspüler und boiler an wlan Steckdosen. So könnte ich zur Not auch manuell bedienen.
                        Boiler schaltet sich automatisch zu den billigsten 3 Stunden ein. Geschirrspüler und Waschmaschine gebe ich über dosenschalter Strom, lasse das Programm starten und schalte dann gleich wieder aus. Das blockly startet dann zu den billigsten Zeiten die Geräte.
                        Fußboden Heizung schaltet zu den billigsten x Zeiten sich ein.
                        Eine der Steckdosen ist eine mit led Licht. Sie leuchtet von grün über gelb zu rot, je nach aktuellem strompreis.
                        Am Nachmittag um 17:00 bekomme ich eine signal Nachricht über die schalteten für morgen.
                        Läuft alles perfekt und die scripte sind alle hier im forum.
                        • J judisi
                          J
                          J
                          JayJay 0
                          #69
                          @judisi oh danke - ich bin anscheinend zu blöd um dieses Script zu finden. Ich find nur teilweise die scripts, welche laut Poster nicht funktionieren…
                          Wäre es eventuell möglich, dass du deines teilst. Dann würde mir wahnsinnig viel Zeit erspart bleiben. Dazu kommt noch, dass mein Geduldsfaden bei Blockly smarthome usw nach diesem Sommer irgendwie sehr gering geworden ist….
                          Es ist nicht mehr Lust und Freude da . Eher mehr Krampf zum Fertigwerden……
                          • J JayJay 0
                            J
                            J
                            judisi
                            #70
                            @jayjay-0 Das Script für die billigsten x Stunden pro Tag und die billigsten x zusammenhängenden Stunden steht hier: https://forum.iobroker.net/post/924438
                            Brauchst du sonst noch was? Bei mir hat die Heizsaison gerade angefangen und muss mich selber wieder einarbeiten ....
                            • J judisi
                              J
                              J
                              JayJay 0
                              schrieb am zuletzt editiert von JayJay 0
                              #71
                              @judisi großen respekt und ein riesiges dankeschön - ich schau mir das am abend an. ich muss noch schnell einen neuen AP montierren und im Wassermesserschacht Antennen auf die AI on the edge geschichte montieren.
                              Wetter ausnutzen - Winterfest wird kommendes Wochenende gemacht
                              sag weil ich gerade gelesen hab: ist das schon das finale script ? Weil bei der Version hattest du noch probleme - hast zumindest geschrieben
                              • J JayJay 0
                                J
                                J
                                judisi
                                #72
                                @jayjay-0 ich hab das script noch mit allem möglichem erweitert (wenn der Wetterbericht für morgen 20 Grad ansagt, dann soll die Heizung ein paar Stunden vorher nicht mehr heizen usw... im Grund unsinniger Aufwand, aber hat mir Spass gemacht). Das hier sollten nun die 2 Scripts auf das wesentliche bereinigt sein.
                                Und Danke für die Blumen, doch die gehören ausschließlich paul53
                                3durchgehendeStundenUnddiebilligstenXvomTag.txt
                                  @judisi sagte: Die Tagespreise stehen am Vortag um 14:00 bereit.
                                  Auch für die Zeiten heute ab 14:00 Uhr?
                                  @judisi sagte in Awattar - die billigsten Strom-Stunden nutzen:
                                  Der Wasserboiler läuft an den billigsten 6 Stunden.
                                  Die Bodenheizung an den billigsten 12 Stunden.
                                  Wenn die Daten von heute zur Verfügung stehen, Vorschlag:
                                  O
                                  O
                                  Opa75+
                                  #73
                                  @paul53 Ich finde leider keine Antwort im Forum für mein Anliegen. Ich habe nun den Strom von Awattar Österreich und möchte damit meine WP steuern. Blockly Kenntnisse vorhanden, aber bescheiden; JavaScripts keine Kenntnisse!
                                  Meine Frage:
                                  Wie kann ich den zu dieser aktuellen Stunde den Strompreis in einen Datenpunkt schreiben. In einem Blockly vergleiche ich den momentan aktuellen Strompreis mit einem fiktiven Preis. Ist der aktuelle Strompreis unter diesem fiktiven Strompreis, soll dann meine WP starten und den Boiler (1m³) auf eine bestimmte Temperatur aufheizen. Wenn ich den DP habe, kann ich den Rest lösen.
                                  Beispiel: Um 20:00 ist der Preis 15 ct/kWh und um 21:00 => 11 ct/kWh usw. der DP sollte dann um 21:00 auf den neuen Wert 11 ct/kWh aktualisiert werden. Das sollte von 0:00 bis 24:00 jede Stundenanfang gemacht werden.
                                  Danke im Voraus für die Unterstützung.
                                  • O Opa75+
                                    Meine Frage:
                                    J
                                    J
                                    judisi
                                    #74
                                    @opa75 Der Datenpunkt "PreisderStunde" wird hier stündlich aktualisiert:
                                    O 2 Antworten Letzte Antwort
                                    • J judisi
                                      O
                                      O
                                      Opa75+
                                      #75
                                      @judisi Danke für die Information. Mache mich gleich gleich an den Nachbau.
                                      O 1 Antwort Letzte Antwort
                                      • O Opa75+
                                        O
                                        O
                                        Opa75+
                                        #76
                                        @opa75 Ich hänge bereits bei 2 Punkten: a) Einstellung bei Zeitplan Cron => 0
                                        b) wie kann ich den Baustein "erstelle text aus" einen 3. Baustein anhängen.
                                        • J judisi
                                          O
                                          O
                                          Opa75+
                                          #77
                                          @judisi Ich hänge bereits bei 2 Punkten: a) Einstellung bei Zeitplan Cron => 0
                                          BananaJoeB paul53P 2 Antworten Letzte Antwort
                                          84.0k
