  4. oft Timeout und langsame Verbindung erkannt
    2.4k
    4.3k
71 Beiträge 10 Kommentatoren 11.0k Aufrufe 10 Beobachtet
  • Thomas123 0T Thomas123 0
    @thomas-braun said in oft Timeout und langsame Verbindung erkannt:
    iob diag
    erst einmal vielen Dank für Deine Geduld.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi4-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     22:08:35 up  2:04,  2 users,  load average: 0.93, 0.95, 0.71
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-10-30 22:08:35 CET
               Universal time: Mon 2023-10-30 21:08:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    Thomas
    /home/Thomas
    Thomas adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.4G        3.1G        1.2M        2.8G        5.8G
    Swap:           104M          0B        104M
    Total:          8.3G        2.4G        3.2G
             7811 M total memory
             2257 M used memory
             2180 M active memory
             2320 M inactive memory
             2975 M free memory
              130 M buffer memory
             2579 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.1M  781M   1% /run
    /dev/mmcblk0p2 ext4       29G  3.7G   24G  14% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Mon Oct 30 20:04:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:F5:7F:DE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=dfee57ec-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Mon Oct 30 20:04:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Oct 30 20:04:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    508M    /var/
    200M    /var/cache
    195M    /var/cache/apt
    159M    /var/lib
    130M    /var/lib/apt/lists
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    256M    /opt/iobroker/iobroker-data/
    176M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    37M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
      system.adapter.botslab360.0             : botslab360            : iobroker                                 - disabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
      system.adapter.chromecast.1             : chromecast            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: ::, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.tvprogram.0              : tvprogram             : iobroker                                 - disabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
      system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 - disabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "botslab360"   : 0.0.2    , installed 0.0.2
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        57852
    States:         51347
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.2.176:2001      0.0.0.0:*               LISTEN      1001       50151      12305/io.hm-rpc.2
    tcp        0      0 192.168.2.176:2010      0.0.0.0:*               LISTEN      1001       48599      11036/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46123      9404/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       44502      9404/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15501      681/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53278      12320/io.simple-api
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       53531      12524/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55365      12426/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       43841      9429/io.admin.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       51913      12366/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15503      681/sshd: /usr/sbin
    udp        0      0 0.0.0.0:33016           0.0.0.0:*                           104        3943       535/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       46966      10850/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3941       535/avahi-daemon: r
    udp6       0      0 fe80::8e9e:365c:6cc:546 :::*                                0          4070       611/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        3942       535/avahi-daemon: r
    udp6       0      0 :::51235                :::*                                104        3944       535/avahi-daemon: r
    E10: 0
    E5: 0
    2023-10-30 22:10:00.163  - info: javascript.0 (9697) script.js.Tanken.Shell: Diesel: 1.739
    E10: 1.819
    E5: 1.809
    2023-10-30 22:10:00.175  - info: javascript.0 (9697) script.js.Tanken.ShellGruiten: Diesel: 1.739
    E10: 1.749
    E5: 1.799
    2023-10-30 22:10:00.180  - info: switchbot-hub.0 (14116) terminating
    2023-10-30 22:10:00.184  - info: switchbot-hub.0 (14116) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-10-30 22:10:00.213  - info: javascript.0 (9697) script.js.Tanken.Status: closed
    2023-10-30 22:10:00.214  - info: javascript.0 (9697) script.js.Tanken.Status: open
    2023-10-30 22:10:00.215  - info: javascript.0 (9697) script.js.Tanken.Status: open
    2023-10-30 22:10:00.240  - info: javascript.0 (9697) script.js.Tanken.Total: Diesel: 0
    E10: 0
    E5: 0
    2023-10-30 22:10:00.266  - info: javascript.0 (9697) script.js.Counter.Timer_umrechnen: 1459
    2023-10-30 22:10:00.266  - info: javascript.0 (9697) script.js.Counter.Timer_umrechnen: 24:19 Minute(n)
    2023-10-30 22:10:00.558  - info: switchbot-hub.0 (14116) terminating
    2023-10-30 22:10:01.268  - info: host.iobroker instance system.adapter.switchbot-hub.0 scheduled normal terminated and will be restarted on schedule.
    2023-10-30 22:10:01.269  - info: host.iobroker Restart adapter system.adapter.switchbot-hub.0 because enabled
    2023-10-30 22:10:01.280  - info: javascript.0 (9697) script.js.Counter.Timer_umrechnen: 1458
    2023-10-30 22:10:01.281  - info: javascript.0 (9697) script.js.Counter.Timer_umrechnen: 24:18 Minute(n)
    @thomas123-0 sagte in oft Timeout und langsame Verbindung erkannt:
    Moin,
    wenn Du Probleme hast, dass sich das gesamte System langsam anfühlt, dann musst Du Dir mal über einen längeren Zeitraum anschauen, was Dir eins der Programme sagt, welcher Prozess besonders viel CPU Zeit verbraucht
    # top
    oder
    # htop
    oder
    # btop
    Wenn Du htop nutzt, dann kann man das auch so einstellen, dass es Dir die IO Auslastung anzeigt, also ob es einen Prozess gibt, der viel/oft auf die SD-Karte zu greift/schreibt.
    Auch mal sein Netzwerk zu betrachten, auf das I/O ist vielleicht keine schlechte Idee.
    Dann, obwohl das bei UDP nicht das Problem sein sollte, der AVAHI Prozess und io.Chromecast haben den gleichen Port 5353
    Bernd
    Thomas123 0T 1 Antwort Letzte Antwort
      Moin,
      # top
      oder
      # htop
      oder
      # btop
      Bernd
      Thomas123 0T Offline
      Thomas123 0
      @dp20eic
      Ich bin ziemlich ahnungslos, was ich aus den Werten lesen kann
      top:
      top - 23:09:04 up 55 min,  3 users,  load average: 1.68, 1.62, 1.58
      Tasks: 176 total,   2 running, 174 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 27.8 us,  2.2 sy,  0.0 ni, 70.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7811.2 total,   4532.3 free,   2940.9 used,    456.2 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4870.2 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
         3532 iobroker  20   0 6352628   1.3g  43932 R 110.9  16.8  15:18.98 iobroker.js-con
         2862 Thomas    20   0    8744   4820   2808 S   3.6   0.1   0:53.71 htop
         3791 iobroker  20   0  687448  81760  37564 S   1.3   1.0   0:16.80 io.hm-rpc.1
         3854 iobroker  20   0  684792  80452  37124 S   1.0   1.0   0:09.17 io.modbus.1
           81 root       0 -20       0      0      0 I   0.7   0.0   0:08.38 kworker/u9:0-brcmf_wq/mmc1:0001:1
           15 root      20   0       0      0      0 I   0.3   0.0   0:06.90 rcu_preempt
          531 avahi     20   0    7620   3508   2816 S   0.3   0.0   0:05.73 avahi-daemon
         2066 Thomas    20   0   11844   4988   2832 R   0.3   0.1   0:12.85 top
         4036 iobroker  20   0 5140052  80256  39220 S   0.3   1.0   0:07.11 io.wolf-smartse
         5192 root      20   0       0      0      0 I   0.3   0.0   0:00.17 kworker/0:0-events
            1 root      20   0  168644  11840   8584 S   0.0   0.1   0:02.73 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:00.03 kthreadd
            3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
            5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
            6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
           10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
           11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
           12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
           13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
           14 root      20   0       0      0      0 S   0.0   0.0   0:00.60 ksoftirqd/0
           16 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/0
           17 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
           18 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
           19 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/1
           20 root      20   0       0      0      0 S   0.0   0.0   0:00.47 ksoftirqd/1
           23 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
           24 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/2
           25 root      20   0       0      0      0 S   0.0   0.0   0:00.40 ksoftirqd/2
           28 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
           29 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/3
           30 root      20   0       0      0      0 S   0.0   0.0   0:00.47 ksoftirqd/3
           33 root      20   0       0      0      0 S   0.0   0.0   0:00.01 kdevtmpfs
           34 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 inet_frag_wq
           36 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
           38 root      20   0       0      0      0 S   0.0   0.0   0:00.00 khungtaskd
           40 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
           41 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 writeback
           42 root      20   0       0      0      0 S   0.0   0.0   0:00.21 kcompactd0
           43 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kintegrityd
           44 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kblockd
           45 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 blkcg_punt_bio
           46 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 watchdogd
           50 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rpciod
      Gruss
      Thomas
        @dp20eic
        top:
        Moin,
        ich werde es mir mal ersparen top zu erklären, da gibt es sehr gute Erklärungen im WWW.
        • https://wiki.ubuntuusers.de/top/
        Ich sehe hier aber auch erst einmal nichts so Kritisches, wobei Du in der Momentaufnahme, einen leichten Stau bei der Abarbeitung von Prozessen hast, das erkennt man am load average der bei Dir, bei ~ 1,6 liegt, drei Werte, weil es gemittelte Werte für 1, 3, 5 Minuten angezeigt.
        Es ist jetzt nicht schlimm, da es ja nur eine Momentaufnahme ist, aber bei Dir verbraucht der iobroker.js-controller einen ganzen Kern,
        Das spiegelt sich dann auch in den Werten für die CPU wider, Du hast ein RasPI, der hat eine CPU, aber darin befinden sich 4 Kerne, also 1 CPU = 4 Kerne -> 1 Kern = 25 %.
        Du kannst die Anzeige umschalten, einfach 1 drücken, dann sieht es so aus
        top - 08:10:49 up 2 days, 13:42,  0 user,  load average: 1.12, 0.71, 0.67
        Tasks:  43 total,   1 running,  42 sleeping,   0 stopped,   0 zombie
        %Cpu0  : 12.0 us,  6.7 sy,  0.0 ni, 76.6 id,  4.0 wa,  0.0 hi,  0.7 si,  0.0 st
        %Cpu1  :  8.9 us,  5.8 sy,  0.0 ni, 81.2 id,  3.4 wa,  0.0 hi,  0.7 si,  0.0 st
        %Cpu2  : 11.6 us,  4.4 sy,  0.0 ni, 82.9 id,  0.3 wa,  0.0 hi,  0.7 si,  0.0 st
        %Cpu3  : 12.8 us,  5.6 sy,  0.0 ni, 76.6 id,  4.3 wa,  0.0 hi,  0.7 si,  0.0 st
        MiB Mem :   4096.0 total,   2213.9 free,   1825.6 used,     56.5 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2270.4 avail Mem
          23799 iobroker  20   0   11.1g 337932  29952 S   5.7   8.1   2:53.08 iobroker.js-con
          23917 iobroker  20   0  960404  76448  26880 S   1.0   1.8   0:18.97 io.influxdb.1
          24266 iobroker  20   0   10.8g  64880  29184 S   1.0   1.5   0:05.15 io.synochat.0
          24066 iobroker  20   0  960224  79164  28160 S   0.7   1.9   0:10.23 io.alexa2.0
          23854 iobroker  20   0  773524 164156  26368 S   0.3   3.9   0:28.52 io.javascript.0
          23868 iobroker  20   0  960140  77776  26752 S   0.3   1.9   0:18.48 io.influxdb.0
          23998 iobroker  20   0  659144  71296  26496 S   0.3   1.7   0:05.76 io.sonoff.0
          24049 iobroker  20   0   10.9g  92124  28416 S   0.3   2.2   0:32.33 io.synology.0
        Wieso es zu diesem Stau kommt, kann ich nicht sagen, aber Du solltest da öfter mal einen Blick drauf werfen, gerade wenn Du der Meinung bist, dass sich das System langsam anfühlt.
        Eine Ursache, kann sein, dass die Performance des Speichermediums SD-Karte? das System ausbremst, aber wie gesagt, kann man aus dieser einen Momentaufnahme nicht mit Sicherheit sagen und würde ein Langzeitmonitoring benötigen.
        Bernd
          Moin,
          Bernd
          Thomas123 0
          @dp20eic
          Ich glaube, ich habe ein Problem mit dem Javasript-Adapter.
          Nachdem der ioBroker im Moment recht normal lief, wollte ich ein Blockly erstellen, dass einen Daten aus einem Datenpunkt (Adapter Switchbot) in einen anderen Datenpunkt (Adapter hm-rega) schreibt.
          Irgendwie waren dann nach dem Speichern des Blockly die gemachten Änderungen trotz speichern verschwunden.
          Im Protokoll hatte ich dann diese Einträge (ich weiss aber nicht, ob die mit dem Problem zusammenhängen):
          hm-rega.0
          2023-11-02 11:56:49.508	warn	Script "!# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin" ignored, because still pending.
          hm-rega.0
          2023-11-02 11:56:49.507	warn	Script "!# pollingInv.fn 0.2 !# !# Dieses Script gibt die Systemvariablen (inklusive uns" ignored, because still pending.
          hm-rega.0
          2023-11-02 11:56:49.507	warn	Script "!# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin" ignored, because still pending.
          hm-rega.0
          hm-rega.0
          2023-11-02 11:56:49.506	warn	Script "!# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin" ignored, because still pending.
          hm-rega.0
          2023-11-02 11:56:49.506	warn	Script "!# pollingInv.fn 0.2 !# !# Dieses Script gibt die Systemvariablen (inklusive uns" ignored, because still pending.
          Ich bin ziemlich hilflos, wie ich das Problem eingrenzen und schlussendlich beheben kann.
          Gruss
          Thomas
          Thomas123 0T ? Samson71S 3 Antworten Letzte Antwort
            @dp20eic
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            Thomas123 0
            @thomas123-0 said in oft Timeout und langsame Verbindung erkannt:
            @dp20eic
            Nachdem der ioBroker im Moment recht normal lief, wollte ich ein Blockly erstellen, dass Daten aus einem Datenpunkt (Adapter Switchbot) in einen anderen Datenpunkt (Adapter hm-rega) schreibt.
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            hm-rega.0
            Gruss
            Thomas
              @dp20eic
              hm-rega.0
              hm-rega.0
              hm-rega.0
              hm-rega.0
              hm-rega.0
              hm-rega.0
              Moin,
              ich auch, aber lass uns das doch mal logisch angehen.
              1. das sind Warnungen, keine Fehler
              2. das kommt nicht vom java-script, sondern von Deinem hm-rega ⇐ zu hm kann ich gar nichts sagen, da bin ich völlig blank!
              3. was da als Skript !# program.fn (1.3 / 0.2) gemeint ist, ist pending = ausstehend, da wartet irgendwas auf jemanden.
              • was tut dieses hm-rega?
              • den betreffenden Adapter schon mal neu gestartet?
              • was, wie sind die Einstellungen des Adapters?
              • sind irgendwelche Geräte ausgeschaltet?
              Bernd
                @dp20eic
                hm-rega.0
                hm-rega.0
                hm-rega.0
                hm-rega.0
                hm-rega.0
                hm-rega.0
                haselchenH Offline
                haselchenH Offline
                haselchen
                @thomas123-0
                Vermutlich hast du in der CCU ein Skript oder mehrere angelegt, was nicht passt?!
                Das kannst nur du wissen und kontrollieren.
                Unter Programme&Zentralenverlnüpfung ( so heisst die Karteikarte bei mir in der GUI), stehen die Skripte.
                  Moin,
                  Bernd
                  Thomas123 0
                  @dp20eic
                  hm-rega ist die CCU3 von Homematic. Dann scheint es "Zufall" gewesen zu sein, dass genau in dem Moment die CCU nicht erreichbar war.
                  Weswegen ich darauf komme, dass es ein Problem im Javascript gibt, versuche ich mal so gut es geht zu erklären.
                  Ich erstelle ein neues Blockly, speichere es schon mal und mache dann noch Änderungen an dem Blockly. Wenn ich dann speichere, sind die gemachten Änderungen wieder weg.
                  Ich wollte jetzt Screenshots von jedem Schritt machen, und bekomme jetzt schon in dem Moment, wo ich nur den Trigger eingebe, nach dem Speichern den Hinweis "Instanz ist deaktiviert".
                  Wenn ich aber dann in den Instanzen nachschaue, läuft der Javascript-Adapter.
                  Zurück im Blockly kann ich wieder etwas einfügen. Beim Speichern wieder "Instanz ist deaktiviert".
                  Möchte ich mir jetzt die Instanzen ansehen, bekomme ich:
                  Cannot read compact mode by host "system.host.iobroker": timeout
                  Nach einiger Zeit öffnen sich dann die Instanzen und alle laufen. Zurück im Blockly gebe eine neue Zeile ein, speichere und es kommt wieder die Meldung "Instanz ist deaktiviert". Diese Meldung erscheint dann auch in allen anderen Scripten.
                  Das deutet doch auf ein Problem mit dem Javascript-Adapter, oder?
                  Gruss
                  Thomas
                  Thomas BraunT ? 2 Antworten Letzte Antwort
                    @dp20eic
                    @thomas123-0
                    Schalt den CompactModus aus, dann nochmal beobachten.
                    • haselchenH haselchen
                      @thomas123-0
                      Thomas123 0
                      @haselchen
                      Ja, ich habe etliche Programme mit Scripten. Auf der CCU laufen sie alle einwandfrei.
                      Bin trotzdem alle Scripte durchgegangen und keine Fehler gefunden
                      Gruss
                      Thomas
                      haselchenH ? Samson71S 3 Antworten Letzte Antwort
                        @haselchen
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @thomas123-0
                        Dann nimm mal im HM Rega Adapter die Haken alle raus bei Synchronisiere und beobachte dann nochmal.
                        Edit:
                        Oder lass zumindest Namen angehakt.
                          @thomas123-0
                          Thomas123 0
                          @thomas123-0
                          Der ist die ganze Zeit schon aus.
                          Gruss
                          Thomas
                            @dp20eic
                            Moin,
                            jaein, ich tendiere eher zu nein, wieso aus den zuvor genannten Posts. Du hast ein Problem, welches Dein System ausbremst.
                            • Load. Du kannst ein zweites Terminal öffnen, ssh -> Putty, what ever, und nebenbei top beobachten
                            • Kompakt Modus, wie @Thomas-Braun schon angemerkt hat ausschalten, Du hast 8 GB an Speicher, ist unnötig
                            • Deine SD-Karte ist ein Flaschenhals und bremst das System aus, dazu mal htop installieren und wie folgt konfigurieren
                            Nach der Installation mit htop aufrufen
                            Dann F2 drücken, und
                            Dann sollte es nach dem F10 so aussehen
                            Jetzt kannst Du mit TAB zwischen den beiden Main u. I/O hin und her springen
                            Dann normal arbeiten und ein Auge auf das System richten.
                            Bernd
                              @haselchen
                              Moin,
                              die Skripte haben auch keinen Fehler, sondern es wurde darauf gewartet, dass jemand ein Ergebnis liefert, deswegen pending!
                              Läuft das CCU Geraffel, nicht böse gemeint, auch auf dem RasPI?
                              Bernd
                                @thomas123-0
                                Moin,
                                kann aber nicht sein -> hier https://forum.iobroker.net/topic/69696/oft-timeout-und-langsame-verbindung-erkannt/20?page=1 die Meldung
                                Hast Du den ausgeschaltet und nicht neu gestartet?
                                Bernd
                                  Moin,
                                  Bernd
                                  Thomas123 0
                                  @dp20eic said in oft Timeout und langsame Verbindung erkannt:
                                  Moin,
                                  Bernd
                                  Im Prinzip. Die CCU hat einen Raspi 3
                                  Gruss
                                  Thomas
                                    Moin,
                                    Bernd
                                    Thomas123 0
                                    @dp20eic
                                    Ich habe nur in den Einstellungen des Host geschaut - und da war kein Haken :man-shrugging:
                                    Gruss
                                    Thomas
                                      @haselchen
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      Es wäre nicht das erst Mal, dass sich ich jemand die CCU blockiert, weil ein Skript ein (Endlos-)Schleife produziert. Die CCU, bzw. die Rega ist für so etwas anfällig, weil die Abarbeitung nacheinander erfolgt und nicht parallel, d.h. "wartet" ein Skript auf ein Ergebnis, geht in der Zeit nix anderes. Die CCU/Rega ist blockiert. Völlig egal was für Ressourcen die Hardware hat.
                                      Weiterer und beliebter Fehler ist Dinge per Skript zu lösen, die sich ebenso gut mit einem zusammengeklickten Programm erledigen lassen würden. Nur eben ohne die Gefahr, sich die Rega zu blockieren.
                                      Wie sieht Dein DutyCycle auf der CCU aus, wenn die Fehlermeldung in ioBroker auftaucht?
                                      Markus
                                      Bitte beachten:
                                        @dp20eic
                                        hm-rega.0
                                        hm-rega.0
                                        hm-rega.0
                                        hm-rega.0
                                        hm-rega.0
                                        hm-rega.0
                                        Samson71S Offline
                                        Samson71S Offline
                                        Samson71
                                        WAS für ein Datenpunkt ist das genau, den Du da beschreiben willst? Eine selbst angelegte Systemvariable?
                                        Markus
                                        Bitte beachten:
                                          @dp20eic
                                          Moin,
                                          ja, ist ja auch alles richtig, nur hast Du ioBroker danach auch einmal neu gestartet?
                                          Oder muss ich Dich jetzt so verstehen, dass Du noch niiiiie Deinen ioBroker im Kompaktmodus betrieben hast?
                                          Dann 🤔
                                          Bernd
                                          P.S.: zur CCU kann ich nichts Sinnvolles beitragen, da lasse ich mal die Wissenden ran :)
