  4. js-controller fehler
    2.9k
    5.0k
11 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • I Offline
    I Offline
    ingenii
    Hallo, ich hab nach langen zeit ein update gemacht und nach neustart kommt dieser fehler:
    web.0
    	2023-10-30 16:33:38.715	info	starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.2, js-controller: 5.0.12
    web.0
    	2023-10-30 15:33:03.693	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
    web.0
    	2023-10-30 15:33:03.693	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:241:19) at AdapterClass.destroySession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1332:19) at Object.commands.logout (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:863:26) at Socket.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1786:43) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14 at processTicksAndRejections (node:internal/process/task_queues:77:11)
    web.0
    	2023-10-30 15:33:03.691	error	uncaught exception: Parameter "id" needs to be of type "string" but type "undefined" has been passed
    mcm1957M HomoranH Thomas BraunT 3 Antworten Letzte Antwort
    • I ingenii
      web.0
      web.0
      web.0
      web.0
      mcm1957M Offline
      mcm1957M Offline
      mcm1957
      @ingenii
      Bitte die Raterunde entlasten:
      Versionen:
      adapter (web)
      js-controller
      admin
      node
      O/S
      Und wenn du den js-controlelr aktualisisert hat, hast du die Adapter aktualisisert?
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      I 1 Antwort Letzte Antwort
      • I ingenii
        web.0
        web.0
        web.0
        web.0
        @ingenii sagte in js-controller fehler:
        dann sieh mal dort nach
        • I ingenii
          web.0
          web.0
          web.0
          web.0
          @ingenii
          Gib mal die Ausgabe von
          iob diag
          zum Besten.
          • mcm1957M mcm1957
            @ingenii
            Versionen:
            adapter (web)
            js-controller
            admin
            node
            O/S
            I Offline
            I Offline
            ingenii
            @mcm57
            Adapter (web) v6.1.2
            admin v6.12.0
            node: v18.18.2
            Rasp 4 debian
              @ingenii
              iob diag
              zum Besten.
              I Offline
              I Offline
              ingenii
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: iobroker-pi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : armhf
              Systemuptime and Load:
               18:21:42 up  3:13,  3 users,  load average: 0.96, 0.84, 0.49
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Mon 2023-10-30 18:21:42 GMT
                         Universal time: Mon 2023-10-30 18:21:42 UTC
                               RTC time: n/a
                              Time zone: Europe/London (GMT, +0000)
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              admin
              /home/admin
              admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            7.9G        1.4G        5.4G        1.0M        1.1G        6.3G
              Swap:            99M          0B         99M
              Total:          8.0G        1.4G        5.5G
                       7862 M total memory
                       1391 M used memory
                       1396 M active memory
                        572 M inactive memory
                       5407 M free memory
                        178 M buffer memory
                        884 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4      235G   30G  195G  14% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
              /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
              tmpfs          tmpfs     787M     0  787M   0% /run/user/0
              tmpfs          tmpfs     787M     0  787M   0% /run/user/1002
              tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
              [Mon Oct 30 15:08:36 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1E:08:F2 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=ba329448-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Mon Oct 30 15:08:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Mon Oct 30 15:08:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Mon Oct 30 15:08:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              685M    /var/
              311M    /var/cache
              306M    /var/cache/apt
              241M    /var/cache/apt/archives
              180M    /var/log
              Archived and active journals take up 176.0M in the file system.
              /opt/iobroker/backups:
              1.3G    /opt/iobroker/backups/
              228K    /opt/iobroker/backups/Heizung_1
              132K    /opt/iobroker/backups/Licht
              44K     /opt/iobroker/backups/Rollo
              20K     /opt/iobroker/backups/Bewässerung
              /opt/iobroker/iobroker-data:
              24G     /opt/iobroker/iobroker-data/
              23G     /opt/iobroker/iobroker-data/history
              886M    /opt/iobroker/iobroker-data/files
              210M    /opt/iobroker/iobroker-data/backup-objects
              121M    /opt/iobroker/iobroker-data/history/20211110
              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              24M     /opt/iobroker/iobroker-data/objects.jsonl
              23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
              USB-Devices by-id:
              find: '/dev/serial/by-id/': No such file or directory
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.2
              /usr/bin/node           v18.18.2
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Installed: 18.18.2-1nodesource1
                Candidate: 18.18.2-1nodesource1
                Version table:
               *** 18.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
              No problems detected
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
              npm ERR! A complete log of this run can be found in: /home/admin/.npm/_logs/2023-10-30T18_21_53_311Z-debug-0.log
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              admin:          6.12.0
              javascript:     7.1.4
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alarm.0                  : alarm                 : iobroker-pi                              - disabled
                system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              - disabled
              + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
              + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
                system.adapter.countdown.0              : countdown             : iobroker-pi                              - disabled
                system.adapter.daswetter.0              : daswetter             : iobroker-pi                              - disabled
                system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              - disabled
                system.adapter.devices.0                : devices               : iobroker-pi                              -  enabled
                system.adapter.discovergy.0             : discovergy            : iobroker-pi                              - disabled
              + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
                system.adapter.email.0                  : email                 : iobroker-pi                              - disabled
                system.adapter.flot.0                   : flot                  : iobroker-pi                              -  enabled
                system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                system.adapter.ham.0                    : ham                   : iobroker-pi                              - disabled
              + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                system.adapter.homeconnect.0            : homeconnect           : iobroker-pi                              - disabled
                system.adapter.ical.0                   : ical                  : iobroker-pi                              -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi                              -  enabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-pi                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker-pi                              -  enabled
                system.adapter.icons-material-png.0     : icons-material-png    : iobroker-pi                              -  enabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-pi                              -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-pi                              -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-pi                              -  enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi                              -  enabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-pi                              -  enabled
              + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
                system.adapter.iogopro.0                : iogopro               : iobroker-pi                              - disabled
                system.adapter.iot.0                    : iot                   : iobroker-pi                              - disabled
              + system.adapter.iqontrol.0               : iqontrol              : iobroker-pi                              -  enabled
                system.adapter.jarvis.0                 : jarvis                : iobroker-pi                              - disabled
              + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                system.adapter.javascript.1             : javascript            : iobroker-pi                              - disabled
                system.adapter.link.0                   : link                  : iobroker-pi                              - disabled
                system.adapter.linkeddevices.0          : linkeddevices         : iobroker-pi                              - disabled
                system.adapter.lovelace.0               : lovelace              : iobroker-pi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                system.adapter.material.0               : material              : iobroker-pi                              -  enabled
              + system.adapter.midea.0                  : midea                 : iobroker-pi                              -  enabled
                system.adapter.mobile.0                 : mobile                : iobroker-pi                              - disabled
              + system.adapter.modbus.0                 : modbus                : iobroker-pi                              -  enabled
              + system.adapter.modbus.1                 : modbus                : iobroker-pi                              -  enabled
                system.adapter.moma.0                   : moma                  : iobroker-pi                              - disabled
                system.adapter.ping.0                   : ping                  : iobroker-pi                              - disabled
                system.adapter.rickshaw.0               : rickshaw              : iobroker-pi                              -  enabled
                system.adapter.scenes.0                 : scenes                : iobroker-pi                              - disabled
              + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-pi                              - disabled
                system.adapter.smartcontrol.0           : smartcontrol          : iobroker-pi                              - disabled
              + system.adapter.solax.0                  : solax                 : iobroker-pi                              -  enabled
                system.adapter.solax.1                  : solax                 : iobroker-pi                              - disabled
              + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pi                              - disabled
                system.adapter.sql.0                    : sql                   : iobroker-pi                              - disabled, port: 0
              + system.adapter.statistics.0             : statistics            : iobroker-pi                              -  enabled
                system.adapter.systeminfo.0             : systeminfo            : iobroker-pi                              - disabled
                system.adapter.text2command.0           : text2command          : iobroker-pi                              - disabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker-pi                              -  enabled
                system.adapter.unifi.0                  : unifi                 : iobroker-pi                              - disabled
                system.adapter.viessmannapi.0           : viessmannapi          : iobroker-pi                              - disabled
                system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-pi                              - disabled
                system.adapter.vis-3dmodel.0            : vis-3dmodel           : iobroker-pi                              -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker-pi                              -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pi                              -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-pi                              -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pi                              -  enabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-pi                              -  enabled
                system.adapter.vis-history.0            : vis-history           : iobroker-pi                              -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-pi                              -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-pi                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-pi                              -  enabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pi                              -  enabled
                system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-pi                              -  enabled
                system.adapter.vis-lcars.0              : vis-lcars             : iobroker-pi                              -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-pi                              -  enabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker-pi                              -  enabled
                system.adapter.vis-material.0           : vis-material          : iobroker-pi                              -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-pi                              -  enabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker-pi                              -  enabled
                system.adapter.vis-plumb.0              : vis-plumb             : iobroker-pi                              -  enabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-pi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker-pi                              -  enabled
                system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
              + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              - disabled
              + system.adapter.yahka.1                  : yahka                 : iobroker-pi                              -  enabled
              + system.adapter.yahka.2                  : yahka                 : iobroker-pi                              -  enabled
              + instance is alive
              ioBroker-Repositories
              beta          : http://iobroker.live/repo/sources-dist-latest.json
              __b2          : http://download.iobroker.net/sources-dist-latest.json
              __b3          : http://iobroker.live/repo/sources-dist.json
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alarm"        : 3.4.0    , installed 3.4.0
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "countdown"    : 2.2.0    , installed 2.2.0
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "device-reminder": 3.0.0  , installed 3.0.0
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
              Adapter    "echarts"      : 1.5.1    , installed 1.5.1
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "ham"          : 5.3.1    , installed 5.3.1
              Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "homekit-controller": 0.5.8, installed 0.5.8
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "iot"          : 1.14.5   , installed 1.14.5
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "link"         : 0.5.12   , installed 0.5.12
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "mbus"         : 2.4.0    , installed 2.4.0
              Adapter    "midea"        : 0.0.7    , installed 0.0.7
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "moma"         : 1.2.9    , installed 1.2.9
              Adapter    "openhab"      : 1.1.0    , installed 1.1.0
              Adapter    "openweathermap": 0.3.9   , installed 0.3.9
              Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
              Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
              Adapter    "shelly"       : 6.4.5    , installed 6.4.5
              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "solax"        : 0.7.7    , installed 0.7.7
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "statistics"   : 2.3.0    , installed 2.3.0
              Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
              Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
              Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
              Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Objects and States
              Objects:        17001
              States:         14964
              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11997      518/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23155      2771/io.sonoff.0
              tcp        0      0 192.168.178.150:2001    0.0.0.0:*               LISTEN      1001       22255      2779/io.hm-rpc.0
              tcp        0      0 192.168.178.150:2010    0.0.0.0:*               LISTEN      1001       23260      2817/io.hm-rpc.1
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22137      2692/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22144      2692/iobroker.js-co
              tcp        0      0 127.0.0.1:45071         0.0.0.0:*               LISTEN      1001       28239      3639/io.yahka.2
              tcp        0      0 127.0.0.1:45295         0.0.0.0:*               LISTEN      1001       28205      3579/io.yahka.1
              tcp6       0      0 :::22                   :::*                    LISTEN      0          11999      518/sshd: /usr/sbin
              tcp6       0      0 :::32961                :::*                    LISTEN      1001       28201      3579/io.yahka.1
              tcp6       0      0 :::39181                :::*                    LISTEN      1001       26284      3639/io.yahka.2
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22194      2718/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30959      4111/io.web.0
              udp        0      0 0.0.0.0:54497           0.0.0.0:*                           108        15015      373/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15013      373/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23342      2877/io.shelly.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12013      629/dhcpcd
              udp6       0      0 :::57557                :::*                                108        15016      373/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        15014      373/avahi-daemon: r
              2023-06-30 21:56:25.750  - info: host.openmediavault instance system.adapter.solax.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:25.804  - info: host.openmediavault instance system.adapter.solax.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:25.835  - info: host.openmediavault instance system.adapter.yahka.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.161  - info: host.openmediavault instance system.adapter.hm-rpc.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.184  - info: host.openmediavault instance system.adapter.modbus.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.216  - info: host.openmediavault instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.266  - info: host.openmediavault instance system.adapter.statistics.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.330  - info: host.openmediavault instance system.adapter.yahka.2 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.355  - warn: host.openmediavault instance system.adapter.sonoff.0 terminated due to SIGTERM
              2023-06-30 21:56:26.355  - info: host.openmediavault instance system.adapter.sonoff.0 terminated with code null ()
              2023-06-30 21:56:26.381  - info: host.openmediavault instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.401  - info: host.openmediavault instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.436  - warn: host.openmediavault instance system.adapter.web.0 terminated due to SIGTERM
              2023-06-30 21:56:26.436  - info: host.openmediavault instance system.adapter.web.0 terminated with code null ()
              2023-06-30 21:56:26.457  - warn: host.openmediavault instance system.adapter.iqontrol.0 terminated due to SIGTERM
              2023-06-30 21:56:26.457  - info: host.openmediavault instance system.adapter.iqontrol.0 terminated with code null ()
              2023-06-30 21:56:26.489  - info: host.openmediavault instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:26.537  - warn: host.openmediavault instance system.adapter.echarts.0 terminated due to SIGTERM
              2023-06-30 21:56:26.537  - info: host.openmediavault instance system.adapter.echarts.0 terminated with code null ()
              2023-06-30 21:56:26.562  - info: host.openmediavault instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2023-06-30 21:56:34.206  - info: host.openmediavault stopInstance timeout 10000 system.adapter.sql.0 killing pid  1636
              2023-06-30 21:56:34.288  - warn: host.openmediavault instance system.adapter.sql.0 terminated due to SIGTERM
              2023-06-30 21:56:34.288  - info: host.openmediavault instance system.adapter.sql.0 terminated with code null ()
              2023-06-30 21:56:34.288  - info: host.openmediavault All instances are stopped.
              2023-06-30 21:56:34.396  - info: host.openmediavault terminated
              iob diag has finished.
              Press any key for a summary
                                      v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Kernel:                 aarch64
              Userland:               armhf
              Timezone:               Europe/London (GMT, +0000)
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              Recommended versions are nodejs 18.18.2 and npm 9.8.1
              MEMORY:
              Swap:            99M          0B         99M
              Active iob-Instances:   25
              ioBroker Core:          js-controller           5.0.12
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                17001
              States:                 14964
              Size of iob-Database:
              16M     /opt/iobroker/iobroker-data/objects.json.migrated
              16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              11M     /opt/iobroker/iobroker-data/states.jsonl
              2.9M    /opt/iobroker/iobroker-data/states.json.migrated
              2.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              • I ingenii
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                admin
                /home/admin
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         7862 M total memory
                         1391 M used memory
                         5407 M free memory
                          178 M buffer memory
                          884 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                685M    /var/
                311M    /var/cache
                306M    /var/cache/apt
                180M    /var/log
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        17001
                States:         14964
                Pending Updates: 0
                                        v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Kernel:                 aarch64
                Userland:               armhf
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                MEMORY:
                Swap:            99M          0B         99M
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                17001
                States:                 14964
                Vermutlich die falsche Zeitzone. Stell das richtig ein.
                Installier den iobroker.ham nochmal.
                Das ist der letzte Eintrag im Log? Was ist denn da los? Kann ja nicht sein, dass da seit Ende Juni nichts mehr passiert ist.
                  I Offline
                  I Offline
                  ingenii
                  mein problem ist das der VIS Geht nicht mehr.
                  und trashschedule hat mit verbindung ein problem.
                  • I ingenii
                    @ingenii
                    Ja, das vielleicht auch. Zusätzlich zu den aufgeführten Problemen.
                      @ingenii
                      I Offline
                      I Offline
                      ingenii
                      hallo,
                      homebridge deinstalliert und zeit richtig aber VIS geht nicht.
                      im iob diag kein Fehler mehr.
                      kompletten update hab ich nach Anleitung gemacht:
                      iob backup
                      iob stop
                      iob update
                      iob upgrade self
                      iob start
                      und auch kein fehler auftreten.
                      • I Offline
                        I Offline
                        ingenii
                        heute update WEB auf v6.12.0 hat auch das Problem nicht behoben, hat niemand eine Idee wo kann das Problem sein ?
