  4. Zigbee Instanz startet nicht mehr
    5.1k
26 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • T Tapdance
    Ist 64 Bit in dem Video wird auch auf den artikel
    https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
    verwiesen aber da hänge ich ebenfalls beim letzten schritt.
    @tapdance
    Und
    iob diag
    sagt nun?
      @tapdance
      Und
      iob diag
      sagt nun?
      Tapdance
      @thomas-braun sagte in Zigbee Instanz startet nicht mehr:
      iob diag
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      449M    /var/
      127M    /var/cache
      124M    /var/lib
      120M    /var/cache/apt
      99M     /var/log
      Archived and active journals take up 96.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      355M    /opt/iobroker/iobroker-data/
      255M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      70M     /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      7.4M    /opt/iobroker/iobroker-data/states.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 277: nodejs: command not found
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      /home/iobroker/.diag.sh: line 288: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.12.0
      javascript:     7.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
      + instance is alive
      ioBroker-Repositories
      Aktuell       : http://download.iobroker.net/sources-dist-latest.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Stable (default): http://download.iobroker.net/sources-dist.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alarm"        : 3.4.0    , installed 3.3.13 [Updatable]
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "synology"     : 3.0.0    , installed 3.0.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        5305
      States:         4677
      W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
      E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
      Pending Updates: 148
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14823      538/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17006      540/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17628      540/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20643      1547/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15543      578/sshd: /usr/sbin
      tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       18180      1470/io.hm-rpc.0
      tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       19642      1495/io.hm-rpc.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22353      2250/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28225      2650/io.admin.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22979      1944/io.terminal.0
      tcp6       0      0 :::35275                :::*                    LISTEN      1001       23436      2418/io.yahka.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14822      538/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15545      578/sshd: /usr/sbin
      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19248      1583/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1677       398/avahi-daemon: r
      udp        0      0 0.0.0.0:54757           0.0.0.0:*                           1001       351092     22479/io.broadlink2
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19717      1530/io.shelly.0
      udp        0      0 0.0.0.0:57197           0.0.0.0:*                           1001       377275     22479/io.broadlink2
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1982       480/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16457      587/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       351089     22479/io.broadlink2
      udp        0      0 0.0.0.0:35694           0.0.0.0:*                           108        1679       398/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        1678       398/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          17476      480/dhcpcd
      udp6       0      0 :::43833                :::*                                108        1680       398/avahi-daemon: r
      2023-10-27 17:52:10.911  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:19.566  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:21.278  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:29.796  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:31.618  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:39.953  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:41.998  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:50.165  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:52:52.359  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:00.319  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:02.699  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:10.506  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:13.092  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:20.642  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:23.456  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:30.807  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:33.826  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:40.960  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:44.212  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:51.213  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:53:54.646  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:54:01.387  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:54:06.526  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:54:11.638  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-10-27 17:54:17.044  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      • T Tapdance
        iob diag
        /var:
        449M    /var/
        127M    /var/cache
        124M    /var/lib
        120M    /var/cache/apt
        99M     /var/log
        USB-Devices by-id:
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        5305
        States:         4677
        @tapdance
        Da fehlt der erste Teil.
        Ist aber eine 32bit-Installation. Bring das in die Gegenwart -> 64Bit Debian 12 'Bookworm' neuinstallieren.
          @tapdance
          Tapdance
          @thomas-braun aber das steht doch
          Architecture: arm64
          Gibt es für die installation 64Bit Debian 12 'Bookworm' eine Anleitung?
          Muss ich das systems dann komplett neu aufsetzen und eine Sicherung einspielen?
          • T Tapdance
            Architecture: arm64
            Tapdance
            @tapdance ich hatte das so verstanden das folgendes mein Problem ist
            pi@raspberrypi:/etc/apt/sources.list.d $ apt policy udev
            udev:
              Installed: 247.3-7+rpi1+deb11u2
              Candidate: 247.3-7+rpi1+deb11u2
              Version table:
             *** 247.3-7+rpi1+deb11u2 500
            • T Tapdance
              udev:
                Version table:
              @tapdance sagte in Zigbee Instanz startet nicht mehr:
              Ja. Da gibt es aber keine gescheite Lösung mehr für ein 32Bit-System. Backports würde ich da nicht einspielen.
              Mach es neu:
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
              Dann Backup einspielen, fertig.
              T 2 Antworten Letzte Antwort
                Mach es neu:
                Tapdance
                @thomas-braun ok dann versuche ich das mal
                  Mach es neu:
                  Tapdance
                  DANKE das neuaufsetzen hat geklappt. Nach der neuinstallation habe ich als erstes
                  sudo apt-mark hold udev
                  gemacht damit das beschädigte packet garnbicht erst geladen wird dann alles andere aktualisiert und dann die sicherung zurückgespielt.
                  Zigbee stick funktioniert wieder leider habe ich jetzt ein anderes Problem. Meien Visualisierung läuft nicht mehr.
                  Deinstalieren und neu Instalieren habe ich schon versucht. Ich hoffe ihr könnt mir noch mal weiter helfen.
                  Hier das log
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi4-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   10:19:36 up 2 days, 15:24,  4 users,  load average: 0.66, 0.99, 0.89
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Mon 2023-10-30 10:19:36 CET
                             Universal time: Mon 2023-10-30 09:19:36 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  PI
                  /home/PI
                  PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        2.4G        744M         15M        1.0G        1.6G
                  Swap:           104M          0B        104M
                  Total:          4.1G        2.4G        849M
                           3793 M total memory
                           2254 M used memory
                           2348 M active memory
                            397 M inactive memory
                            709 M free memory
                             51 M buffer memory
                            923 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  Filesystem                              Type      Size  Used Avail Use% Mounted on
                  udev                                    devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs                                   tmpfs     380M  1.3M  379M   1% /run
                  /dev/mmcblk0p2                          ext4       28G  6.2G   21G  24% /
                  tmpfs                                   tmpfs     1.9G  148K  1.9G   1% /dev/shm
                  tmpfs                                   tmpfs     5.0M   16K  5.0M   1% /run/lock
                  /dev/mmcblk0p1                          vfat      510M   73M  438M  15% /boot/firmware
                  tmpfs                                   tmpfs     380M   36K  380M   1% /run/user/1000
                  //192.168.2.3/all/SI-ioBrocker/Standard cifs       28T   23T  5.7T  80% /opt/iobroker/backups
                  [Fri Oct 27 19:55:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Fri Oct 27 19:55:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Fri Oct 27 19:55:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /                       /dev/mmcblk0p2                          ext4        rw,noatime,commit=600
                  |-/run/user/1000/doc    portal                                  fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  |-/boot/firmware        /dev/mmcblk0p1                          vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  `-/opt/iobroker/backups //192.168.2.3/all/SI-ioBrocker/Standard cifs        rw,relatime,vers=1.0,cache=strict,username=Backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.2.3,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
                  /var:
                  510M    /var/
                  190M    /var/lib
                  178M    /var/cache
                  171M    /var/cache/apt
                  130M    /var/lib/apt/lists
                  Archived and active journals take up 40.0M in the file system.
                  1001M   /opt/iobroker/backups/
                  0       /opt/iobroker/backups/redistmp
                  338M    /opt/iobroker/iobroker-data/
                  245M    /opt/iobroker/iobroker-data/files
                  68M     /opt/iobroker/iobroker-data/backup-objects
                  18M     /opt/iobroker/iobroker-data/objects.jsonl
                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                  6.5M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                       18.18.1-1nodesource1 500
                       18.18.0-1nodesource1 500
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0+dfsg1-1 500
                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.4
                  Adapter State
                    system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                    system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                  + instance is alive
                  Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Objects and States
                  Objects:        5452
                  States:         4811
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       57223      14093/io.sonoff.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14094      758/sshd: /usr/sbin
                  tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       57088      13999/io.hm-rpc.1
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51636      10767/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52534      10767/iobroker.js-c
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1599726    115468/cupsd
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       59576      14108/io.terminal.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57281      14151/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51722      10795/io.admin.0
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1599725    115468/cupsd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14096      758/sshd: /usr/sbin
                  tcp6       0      0 :::35749                :::*                    LISTEN      1001       59641      14177/io.yahka.0
                  udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       60517      14127/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14006      545/avahi-daemon: r
                  udp        0      0 0.0.0.0:60882           0.0.0.0:*                           1001       2089315    150158/io.broadlink
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       59651      14078/io.shelly.0
                  udp        0      0 0.0.0.0:36681           0.0.0.0:*                           1001       2089391    150158/io.broadlink
                  udp        0      0 0.0.0.0:55521           0.0.0.0:*                           1001       673391     10818/io.backitup.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1598109    115470/cups-browsed
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2089312    150158/io.broadlink
                  udp        0      0 0.0.0.0:53948           0.0.0.0:*                           104        14008      545/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        14007      545/avahi-daemon: r
                  udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          18107      678/NetworkManager
                  udp6       0      0 :::35810                :::*                                104        14009      545/avahi-daemon: r
                  2023-10-30 10:20:05.154  - info: broadlink2.0 (150158) discover  [ '192.168.2.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:40677
                  2023-10-30 10:20:05.389  - info: broadlink2.0 (150158) Device RM:RMPRO-MOVE315-b1-1a-8d detected: address=192.168.2.169, mac=24:df:a7:b1:1a:8d, typ=RMP, id=0x27a9 devtype=RM3 Pro Plus
                  2023-10-30 10:20:10.388  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                  2023-10-30 10:20:10.389  - info: broadlink2.0 (150158) discover  [ '192.168.2.169' ] from 0.0.0.0:42251
                  2023-10-30 10:20:11.457  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:13.157  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:14.619  - warn: broadlink2.0 (150158) device RM:Broadlink-RM2-aa-80-31 not found, please rescan later again or delete it! It was: 192.168.2.227,80,10002,智能遥控,0,[object Object],b4:43:0d:aa:80:31,RM,RM:Broadlink-RM2-aa-80-31,0x2712,RM2,Broadlink-RM2-aa-80-31,RM:Broadlink-RM2-aa-80-31,26
                  2023-10-30 10:20:14.620  - warn: broadlink2.0 (150158) device RM:RM4-14-80-2b not found, please rescan later again or delete it! It was: 192.168.2.203,80,25278,智能遥控,0,[object Object],a0:43:b0:14:80:2b,RM4,RM:RM4-14-80-2b,0x62be,RM4c,RM4-14-80-2b,RM:RM4-14-80-2b,52078
                  2023-10-30 10:20:15.036  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                  2023-10-30 10:20:15.037  - info: broadlink2.0 (150158) discover  [ '192.168.2.227' ] from 0.0.0.0:51145
                  2023-10-30 10:20:17.248  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                  2023-10-30 10:20:17.250  - info: broadlink2.0 (150158) discover  [ '192.168.2.203' ] from 0.0.0.0:36681
                  2023-10-30 10:20:19.465  - info: broadlink2.0 (150158) Poll every 30 secods.
                  2023-10-30 10:20:19.466  - info: broadlink2.0 (150158) broadlink2.0 started and found 1 devices named RM:RMPRO-MOVE315-b1-1a-8d
                  2023-10-30 10:20:19.466  - info: broadlink2.0 (150158) 2 were not found: RM:Broadlink-RM2-aa-80-31, RM:RM4-14-80-2b
                  2023-10-30 10:20:19.467  - info: broadlink2.0 (150158) found macs: 24:df:a7:b1:1a:8d
                  2023-10-30 10:20:21.804  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:23.373  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:32.337  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:33.546  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:42.798  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2023-10-30 10:20:43.742  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  DANKE für die Unterstützung
                  Thomas BraunT 3 Antworten Letzte Antwort
                  • T Tapdance
                    Hier das log
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    PI
                    /home/PI
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             3793 M total memory
                             2254 M used memory
                              709 M free memory
                               51 M buffer memory
                              923 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    510M    /var/
                    190M    /var/lib
                    178M    /var/cache
                    171M    /var/cache/apt
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5452
                    States:         4811
                    Pending Updates: 0
                    gemacht
                    Nein, das Paket muss frei schwimmen, unter Bookworm ist der Fehler nicht mehr vorhanden und deswegen muss das Paket auch nicht auf hold gesetzt werden.
                    • T Tapdance
                      Hier das log
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      PI
                      /home/PI
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           104M          0B        104M
                               3793 M total memory
                               2254 M used memory
                                709 M free memory
                                 51 M buffer memory
                                923 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      510M    /var/
                      190M    /var/lib
                      178M    /var/cache
                      171M    /var/cache/apt
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        5452
                      States:         4811
                      Pending Updates: 0
                      @tapdance
                      Die Freigabe für die Backups würde ich nicht mit SMB V1 machen sondern mit der höchstmöglichen Variante.
                      • T Tapdance
                        Hier das log
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        PI
                        /home/PI
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 3793 M total memory
                                 2254 M used memory
                                  709 M free memory
                                   51 M buffer memory
                                  923 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        510M    /var/
                        190M    /var/lib
                        178M    /var/cache
                        171M    /var/cache/apt
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        5452
                        States:         4811
                        Pending Updates: 0
                        Hast du vor dem Zurückspielen den Adapter Vis 'leer' angelegt?
                          Tapdance
                          hallo,
                          nein das habe ich nicht. Muss man das? geht das nachträglich noch und dann noch mal zurücksichern?
                          Wie macht man das?
                          • T Tapdance
                            hallo,
                            Wie macht man das?
                            Muss man das?
                            Ja, muss man. Ist ein Bug.
                            Wie macht man das?
                            Installier eine alte Version von vis und dann das Backup da nochmal drüber gießen.
                              Muss man das?
                              Wie macht man das?
                              Tapdance
                              Ich weiß ist bestimmt eine blöde Frage, aber wo finde ich eine alte Version wo vis? Auf der weboberfläche wird ja nur die aktuelle angezeigt
                              • T Tapdance
                                @tapdance
                                Da kann man aber auch Vorversionen finden.
                                Ansonsten:
                                iobroker upgrade vis@VERSIONSNUMMER
                                Musst du mal schauen welche geht, das Problem hatten schon viele vor dir.
                                  Tapdance
                                  habe alle probiert die ich finden konnte immer der gleiche fehler.
                                  PI@raspberrypi:~ $ iobroker upgrade vis@1.4.13
                                  Adapter "vis"            is not installed.
                                  PI@raspberrypi:~ $ iobroker upgrade vis@1.4.15
                                  PI@raspberrypi:~ $ iobroker upgrade vis@1.4.16
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.0.0
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.0.8
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.0.10
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.0.129
                                  ^[[API@raspberrypi:~ $ iobroker upgrade vis@2.0.29
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.0.36
                                  PI@raspberrypi:~ $ iobroker upgrade vis@2.1.4
                                  PI@raspberrypi:~ $
                                    @tapdance
                                    Ansonsten:
                                    Tapdance
                                    danke für den Tipp habe einen Forum Eintrag gefunden der funktioniert hat.
                                    cd /opt/iobroker
                                    npm i iobroker.vis@1.4.6
                                    und anschließendes Update übers WebUI klappt's dann.
                                    Das hast gebracht. Vielen dank für die Unterstützung. Kann man das hier im Forum irgendwo auf gelöst setzen?
