  4. [erledigt] js.controller update
    2.1k
    4.0k
11 Beiträge 6 Kommentatoren 2.2k Aufrufe
  • N Offline
    N Offline
    nathan1312
    Jetzt hats mich auch erwischt. nach dem controller update von 1.1.2 auf 1.2 (glaub ich) kann ich iobroker nicht mehr starten
    Hab im Forum gesucht und folgende Lösung gefunden
    cd /opt/iobroker
    sudo chmod 777 * -R
    sudo npm install iobroker.js-controller --production
    Hat aber leider nicht funktioniert.
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (module.js:325:15)
    at Function.Module._load (module.js:276:25)
    at Function.Module.runMain (module.js:441:10)
    at startup (node.js:139:18)
    at node.js:974:3
    root@raspberrypi:/opt/iobroker# sudo chmod 777 * -R
    chmod: cannot access ‘iobroker-data/files/scenes.admin’: No such file or directory
    chmod: cannot access ‘iobroker-data/files/text2command.admin’: No such file or directory
    root@raspberrypi:/opt/iobroker# cd /
    root@raspberrypi:/# sudo npm cache clean
    npm ERR! Linux 4.4.26-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "cache" "clean"
    npm ERR! node v4.6.1
    npm ERR! npm v2.15.9
    npm ERR! path /root/.npm/registry.npmjs.org/base64id/.cache.json
    npm ERR! code Unknown system error -117
    npm ERR! errno -117
    npm ERR! syscall unlink
    ! npm ERR! Unknown system error -117: Unknown system error -117, unlink '/root/.npm/registry.npmjs.org/base64id/.cache.json'
    npm ERR!
    npm ERR! If you need help, you may report this error at:
    npm ERR! <https: github.com/npm/issues="">
    ! npm ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    root@raspberrypi:/# sudo chmod -r 777 /opt/iobroker
    chmod: cannot access ‘777’: No such file or directory
    root@raspberrypi:/# cd /opt/iobroker
    root@raspberrypi:/opt/iobroker# sudo npm install iobroker.js.controller
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js.controller"
    npm ERR! code E404
    ! npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/iobroker.js.controller
    npm ERR! 404
    npm ERR! 404 'iobroker.js.controller' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404 It was specified as a dependency of 'iobroker.core'
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! /opt/iobroker/npm-debug.log
    root@raspberrypi:/opt/iobroker# sudo chmod -R 777 /opt/iobroker
    chmod: cannot access ‘/opt/iobroker/node_modules/iobroker.sayit/node_modules/jsftp/.vscode’: Structure needs cleaning
    chmod: cannot access ‘/opt/iobroker/node_modules/iobroker.sayit/node_modules/jsftp/lib’: Structure needs cleaning
    chmod: cannot access ‘/opt/iobroker/node_modules/iobroker.sayit/node_modules/aws-sdk/lib/s3/managed_upload.js’: Structure needs cleaning
    chmod: cannot access ‘/opt/iobroker/iobroker-data/files/scenes.admin’: No such file or directory
    chmod: cannot access ‘/opt/iobroker/iobroker-data/files/text2command.admin’: No such file or directory
    chmod: cannot access ‘node_modules/iobroker.sayit/node_modules/jsftp/.vscode’: Structure needs cleaning
    chmod: cannot access ‘node_modules/iobroker.sayit/node_modules/jsftp/lib’: Structure needs cleaning
    chmod: cannot access ‘node_modules/iobroker.sayit/node_modules/aws-sdk/lib/s3/managed_upload.js’: Structure needs cleaning
    root@raspberrypi:/opt/iobroker# sudo npm install iobroker.js.controller --production
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js.controller" "--production"
    npm ERR! code E404
    npm ERR! 404
    npm ERR! 404
    root@raspberrypi:/opt/iobroker#</https:>
    Vor dem Update hatte ich bereits Probleme den say.it und den web-adapter zu aktualisieren.
    Kann jemand helfen?
    ****ModEdit: Log bitte in code blöcken****
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Moin,
      eine Frage:
      Du bist als root angemeldet (mehr/höher geht nicht) und verwendest trotzdem noch „sudo“?
      Warum?
      Nicht das Du Dir mit sudo, der einem normalen User ja quasi-root einräumen soll, wieder Rechte entziehst ….
      Gruß,
      Eric
      Von unterwegs getippert
      • R Offline
        RappiRN
        Du schreibst:
        ````(lt.log)
        muss es nicht heißen:
        ?? So, wie in deiner gefundenen Lösung?
        Die Sache mit dem "sudo", da würde ich als totaler Linux-Laie behaupten, dass das trotz root-Anmeldung nicht stört, hab ich manchmal, wenn ich Installationen mit copy&paste durchführe, auch mit drin zu stehen und hat glaub ich noch nie gestört.
        Und das hier:
        enstspricht doch auch nicht dem, was du als Lösung im Forum gefunden hast. In deiner Lösung sind "-r" und "777" andersrum. :?:
        Enrico
        • arteckA Offline
          arteckA Offline
          arteck
          man sollte sich auch die Meldungen anschauen was das system rausgibt nicht nur stupide copypaste enter
          FALSCH
          GENAUSO FALSCH
          du hast im Eingang
          cd /opt/iobroker
          sudo chmod 777 * -R
          warum macht du es auch nicht so
          und wenn du schon dabei bist mach ein update auf node 6
          • R Offline
            RappiRN
            … sag ich doch!
            @arteck:
            und wenn du schon dabei bist mach ein update auf node 6 `
            Erstmal eins abschließen, dann das nächste Problem lösen! :D
            Enrico
            • N Offline
              N Offline
              nathan1312
              Sorry, war spät gestern und ich war ein wenig in Panik. Hatte vorher ein wenig rumprobiert und dann zuviel als log gepostet. Den Tippfehler hatte ich auch nicht gesehen. Wenn ich nachher zuhause bin versuche ich es nochnmal.
              Aber danke für die schnellen Antworten!
              • N Offline
                N Offline
                nathan1312
                OK, habs nochmal probiert. Leider immer noch ohne Erfolg :-( ( Das "sudo" brauche ich ja nicht vor den Befehlen wenn ich als "root" angemeldet bin, soweit ich das verstanden habe)
                So wie ich das verstehe ist wohl irgendeine Komponente veraltet. Weiß aber nicht ob das den Fehler auslöst…
                Hier nochmal die Meldungen über die Konsole...
                root@raspberrypi:~# cd /opt/iobroker
                root@raspberrypi:/opt/iobroker# chmod 777 * -R
                root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production
                npm WARN deprecated tar.gz@1.0.7: ⚠️ WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
                npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                npm ERR! unpack Could not read data for debug@2.3.3
                npm ERR! unpack Could not read data for ajv@5.3.0
                unix-dgram@0.2.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
                node-gyp rebuild
                ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
                CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                COPY Release/unix_dgram.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
                npm ERR! unpack Could not read data for bcrypt-pbkdf@1.0.1
                npm WARN optional dep failed, continuing bcrypt-pbkdf@1.0.1
                ! > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa
                node-gyp rebuild
                ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
                CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                SOLINK_MODULE(target) Release/obj.target/ursaNative.node
                COPY Release/ursaNative.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production"
                npm ERR! path /root/.npm/debug/2.3.3/package/package.json
                npm ERR! errno -117
                npm ERR! syscall open
                ! npm ERR! Unknown system error -117: Unknown system error -117, open '/root/.npm/debug/2.3.3/package/package.json'
                npm ERR!
                npm ERR! <https: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
                Ich hoffe Ihr könnt mir nochmal helfen.
                …beim Startversuch kommt dann übrigens folgende Fehlermeldung
                root@raspberrypi:/opt/iobroker# iobroker start
                module.js:327
                    throw err;
                >! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob       roker.js'
                    at node.js:974:3
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  Probier Mal mit
                   sudo npm install iobroker --unsafe-perm
                  Send from mobile device
                  • N Offline
                    N Offline
                    nathan1312
                    Der raspi hat einen kalten Reboot durchgemacht - Stromausfall.
                    Jetzt läuft iobroker wieder…. nur sind nun einige Adapter, die ich schon upgedatet hatte wieder auf einem früheren Stand...
                    Ich kapiers nicht... aber egal - bin froh, dass ich nicht neu aufsetzen muss!
                    Danke für eure Hilfe!
                    Gesendet von meinem SM-T820 mit Tapatalk
                      @nathan1312:
                      nur sind nun einige Adapter, die ich schon upgedatet hatte wieder auf einem früheren Stand… `
                      hattest du diese über github upgedatet?
                      • N Offline
                        N Offline
                        nathan1312
                        Nein, ganz normal über den button auf der adapter-oberfläche
