  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.7k Aufrufe 67 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #510
    bei mir funktioniert der Adapter seit JS-Controller 5 nicht mehr.
    Issue bleibt leider von @Scrounger unbeantwortet (ist etwas mit ihm?).
    nach JS-Controllerupdate von 4.x.x auf 5.0.12
    stoppt Linux-Controll mit Fehler.
    Linux-Control: 1.1.5
    Admin: 6.12.0
    NodeJS: v18.17.1
    NPM: 9.6.7
    host.ioBroker 2023-09-24 20:14:29.178	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[2]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[2]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[2]: ReplyError: Error The pattern "linux-control.0.Proxmox.services.●.stop" is not a valid ID pattern
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[1]: Error: The pattern "io.linux-control.0.Proxmox.services.●.start" is not a valid ID pattern
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[0]: ReplyError: Error The pattern "linux-control.0.Proxmox.services.●.restart" is not a valid ID pattern
    host.ioBroker 2023-09-24 20:14:29.178	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    linux-control.0 2023-09-24 20:14:28.991	error	[servicesInfo] Proxmox (10.0.1.201:22): error: DB closed, stack: Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40) at LinuxControl._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
    linux-control.0 2023-09-24 20:14:28.552	error	Error The pattern "linux-control.0.Proxmox.services.●.stop" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.552	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.●.stop" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0 2023-09-24 20:14:28.552	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.●.stop" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.552	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0 2023-09-24 20:14:28.538	error	The pattern "io.linux-control.0.Proxmox.services.●.start" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.538	error	Error: The pattern "io.linux-control.0.Proxmox.services.●.start" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0 2023-09-24 20:14:28.458	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.●.start" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.458	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0 2023-09-24 20:14:28.367	error	Error The pattern "linux-control.0.Proxmox.services.●.restart" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.366	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0 2023-09-24 20:14:28.365	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.●.restart" is not a valid ID pattern
    linux-control.0 2023-09-24 20:14:28.365	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Der Fork von @copystring funktioniert zumindest bei mir nicht.
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      Admin: 6.12.0
      NodeJS: v18.17.1
      NPM: 9.6.7
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #511
      @negalein sagte in Test Adapter Linux Control v1.x.x:
      hier schon :)
      Aber zeig doch mal die Ausgabe von
      iob diag
      Langfassung bitte
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        hier schon :)
        iob diag
        Langfassung bitte
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #512
        @djmarc75 sagte in Test Adapter Linux Control v1.x.x:
        iob diag
                                v.2023-10-10
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.3 LTS
                  Kernel: Linux 5.15.30-2-pve
            Architecture: x86-64
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Vienna (CEST, +0200)
        User-ID:                1001
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    2
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/node           v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
                                /usr/bin/corepack       0.18.0
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        MEMORY:
        Mem:             10G        4.9G        4.0G        0.0K        1.1G        5.2G
        Swap:           2.0G          0B        2.0G
        Total:           12G        4.9G        6.1G
        Active iob-Instances:   60
        Active repo(s): Beta (latest)
        ioBroker Core:          js-controller           5.0.12
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                51358
        States:                 47172
        Size of iob-Database:
        49M     /opt/iobroker/iobroker-data/objects.jsonl
        29M     /opt/iobroker/iobroker-data/objects.json.migrated
        29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        0       /opt/iobroker/iobroker-data/objects.json.broken
        96M     /opt/iobroker/iobroker-data/states.jsonl
        9.4M    /opt/iobroker/iobroker-data/states.json.migrated
        9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        Langfassung bitte
        komm nur zu der Zusammenfassung
          iob diag
                                  v.2023-10-10
                   Chassis: container
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1001
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:           2.0G          0B        2.0G
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                51358
          States:                 47172
          Langfassung bitte
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #513
          Wie darf man das verstehen ?
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #514
            während iob diag durchläuft kommt ja jede Menge an Infos.
            Und wenn die Summary kommt, wird vorher alles gecleard.
              #515
              Aber nur in 'komischen' Terminals. Da kommt eigentlich ein Aufforderung eine Taste zu drücken.
              NegaleinN 2 Antworten Letzte Antwort
              • mickymM mickym
                @oreider
                xrandr --output LVDS1 --rotate left
                xrandr --output LVDS1 --rotate right
                xrandr --output LVDS1 --rotate normal
                xrandr --output LVDS1 --rotate inverted
                Habe ich hier gefunden https://askubuntu.com/questions/159086/rotate-only-one-screen
                xrandr --output HDMI-1 --auto --rotate left
                vielleicht geht dann sowas.
                OreiderO Offline
                OreiderO Offline
                Oreider
                #516
                @mickym said in Test Adapter Linux Control v1.x.x:
                Super das funktioniert!
                Vielen Dank!
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #517
                  @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
                  MobaXterm und Putty
                  bei beiden das selbe
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #518
                    kommt nichts.
                      kommt nichts.
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #519
                      kommt nichts
                      bei PuTTY kommt da aber definitiv eine Aufforderung. Vll hängt ja eine Taste bei Dir ?! ;)
                      • crunchipC Abwesend
                        crunchipC Abwesend
                        #520
                        du hast da einen Fehler drin, der Adapter an sich funktioniert doch
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #521
                          @crunchip sagte in Test Adapter Linux Control v1.x.x:
                          aber welcher?
                          Ich habe nichts verändert.
                          Trit ja auch erst seit Controller 5 auf.
                          • NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #522
                            siehste ;)
                            https://cloudlogin03.world4you.com/index.php/s/0pf76NDLpUDvfZl
                              aber welcher?
                              Meister MopperM Online
                              Meister Mopper
                              #523
                              Ich habe auch einen iob lxc mit controller 5 laufen, dieser Adapter macht hier keine Probleme. Vielleicht bringst du mal das nodejs auf Stand?
                              Proxmox und HA ...
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #524
                                @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
                                hab erst heute ein
                                sudo apt update
                                sudo apt upgrade
                                gemacht.
                                Sollte doch dann passen?
                                crunchipC Meister MopperM 2 Antworten Letzte Antwort
                                  hab erst heute ein
                                  sudo apt update
                                  sudo apt upgrade
                                  gemacht.
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #525
                                  @negalein je nachdem welche major Version
                                  aber welcher?
                                  vllt mal die entsprechenden Datenpunkte löschen und neu hinzu fügen
                                    hab erst heute ein
                                    sudo apt update
                                    sudo apt upgrade
                                    gemacht.
                                    Meister Mopper
                                    #526
                                    Na dann stimmt etwas nicht, sollte 18.18.2 sein. Guck mal hier.
                                    Proxmox und HA ...
                                      aber welcher?
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #527
                                      schon gemacht. ohne besserung.
                                        kommt nichts
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #528
                                        @DJMarc75
                                        hab jetzt iob diag ein Log erstellen lassen
                                        iob_diag.log
                                        crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                                          @DJMarc75
                                          iob_diag.log
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #529
                                          @negalein
                                          /dev/mapper/pve-vm--100--disk--0 ext4    20G   17G  1.6G  92% /
                                          da is nimmer viel Platz
                                          du hast da
                                          2.2G	/opt/iobroker/backups/
                                          dein Repo
                                          Get:1 https://deb.nodesource.com/node_16.x focal InRelease [4583 B]
                                          Get:2 https://deb.nodesource.com/node_18.x focal InRelease [4583 B]
                                          ich selbst hab keine Proxmox Steuerbefehle
