  4. USB in Docker via neuer Container über Compose u.a. andere
129 Beiträge 8 Kommentatoren 21.9k Aufrufe 6 Beobachtet
  • C Chrisham
    @oliverio ok, weiter geht es:
    Jetzt habe ich noch (versucht):
    • Linux pakete (über Env-Var) mit zu installieren
    • influxdb container
    • grafana container
    aktuelles compose:
    version: '3'
    services:
      iobroker:
        restart: always
        image: buanet/iobroker:latest
        container_name: iobroker-4
        hostname: iobroker-4
        ports:
          - "8081:8081"
        volumes:
          - /volume1/docker/iobroker-Chrisham:/opt/iobroker
          - /volume1/docker/userscripts:/opt/userscripts
          - /volume1/docker/Backup:/opt/backup/
        environment:
          - PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
          - DEBIAN_FRONTEND=teletype
          - LANG=de_DE.UTF-8
          - LANGUAGE=de_DE:de
          - LC_ALL=de_DE.UTF-8
          - SETGID=1000
          - SETUID=1000
          - TZ=Europe/Berlin
          - USBDEVICES=/dev/ttyUSB0
          - PACKAGES="ffmpeg lame sox libsox-fmt-mp3 asterisk"
        devices:
          - /dev/ttyUSB0:/dev/ttyUSB0
      influxdb:
        restart: always
        image: influxdb:latest
        container_name: influxdb-4
        ports:
          - "8086:8086"
        volumes:
          - /volume1/docker/influxdb/config:/etc/influxdb2
          - /volume1/docker/influxdb/data:/var/lib/influxdb2
        environment:
          - GOSU_VER=1.12
          - INFLUXDB_VERSION=2.7.1
          - INFLUX_CLI_VERSION=2.7.3
          - INFLUX_CONFIGS_PATH=/etc/influxdb2/influx-configs
          - INFLUXD_INIT_PORT=8086
          - INFLUXD_INIT_PING_ATTEMPTS=600
          - DOCKER_INFLUXDB_INIT_CLI_CONFIG_NAME=default
          - DOCKER_INFLUXDB_INIT_MODE=setup
          - DOCKER_INFLUXDB_INIT_USERNAME=iobroker
          - DOCKER_INFLUXDB_INIT_PASSWORD=*1Xs(QD5gY0!B&XHe1_x
          - DOCKER_INFLUXDB_INIT_ORG=smarthome
          - DOCKER_INFLUXDB_INIT_BUCKET=iobroker
      grafana:
        restart: always
        image: grafana/grafana:latest
        container_name: grafana-4
        ports:
          - "3000:3000"
        volumes:
          - /volume1/docker/grafana:/var/lib/grafana
          - /volume1/docker/grafana:/var/lib/grafana/plugins
        environment:
          - PATH=/usr/share/grafana/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
          - GF_PATHS_CONFIG=/etc/grafana/grafana.ini
          - GF_PATHS_DATA=/usr/share/grafana
          - GF_PATHS_HOME=/usr/share/grafana
          - GF_PATHS_LOGS=/var/log/grafana
          - GF_PATHS_PLUGINS=/var/lib/grafana/plugins
          - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
          - GF_AUTH_access enabled=true
          - GF_AUTH_org_name=CH_Smart
    Aber es gibt Probleme:
    1.) die Linux-Pakete sind nicht vorhanden im iobroker container
    2.) 2 Adapter sind nicht mit Host verbunden: influxdb und seltsamerweise auch mein KNX-Adapter
    In bisherigem influx-container war das die config (DSM):
    Da ist auch eine IP-Adresse angegeben. Du hattest in deinem Bsp. auch etwas mit Network angegeben:
        networks:
          iobrokerprod4:
    networks:
      dockerMACVLAN:
        external: true
      iobrokerprod4:
    Ideen?
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @chrisham sagte in USB Device für IOBroker in Docker:
    für einmal jedem deiner einzelnen container einen networksabschnitt hinzu
    und dann unter allem ebenfalls einen networks abschnitt ohne einrückung.
    darunter schreibst du einen netzwerknamenmit doppelpunkt (wie in meinem beispiel mit iobrokerprod4
    das erzeugt ein neues bridged netzwerk auf welches nur deine container in dieser konfiguration zugriff haben. jeder container ist mit dem servicenamen als hostname (also influxdb und grafana) erreichbar.
    daher musst du im imfluxdb adapter an der stelle wo die ip dransteht einfach nur influxdb reinschreiben.
    zu knx weiß ich nix. schau mal im log ob da drinsteht,warum er nicht startet.
    Meine Adapter und Widgets
    Links im Profil
    C 1 Antwort Letzte Antwort
    • C Chrisham
      @chrisham achso: die Lovelace-Visu ist auch nicht erreichbar, obwohl der Adapter grün ist....
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      alle im container verwendeten ports, müssen auch in der docker-konfiguration mit notiert werden, sonst werden sie nicht bereitgestellt.
      evtl ist es bei knx genauso, wenn der adapter einen server bereitstellt, dann muss der port auf dem host gemappt werden.
      Links im Profil
      • C Chrisham
        @chrisham logs im iobroker:
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        im adapter steht sicherlich localhost drin, da zuvor influxdb direkt mit iobroker zusammen installiert ist.
        siehe oben, einfach die netzwerkkonfiguration in der docker konfiguration vornehmen und im adapter dann influxdb anstatt localhost eintragen
        Links im Profil
        • GlasfaserG Glasfaser
          Bist du sicher das es mit deinem alten Container ging ( Einstellungen sind uns unbekannt ) ,
          denn du hast nur im neuen Container ( bridge mode ) das drin nur
          ports:
                - "8081:8081"
          mehr nicht !
          Also ist nur eine Verbindung zum Container mit 8081 ( Admin ioBroker ) vorhanden !
          Oder hast du den alten Container im host mode , dann hast du keine Probleme mit den Portfreigaben ( werden nicht benötigt ) !?
          Chrisham
          @glasfaser Ok, danke. Also, nach meinem Tagwerk, gehts jetzt wieder hier weiter mit der Nachtschicht... ;)
          Also Network für Container: tatsächlich habe ich mich da im bisherigen Setup gar nicht groß drum gekümmert, weder bzgl. spezieller Config, noch in Bezug auf das tiefere inhaltliche Verständnis, von daher habe ich auch hier noch eine Lernkurve vor mir.
          • hier mal das bisherige Setup unter Netzwerk (DSM-UI):
          Es gibt da also sowohl was mit "host" (iobroker), als auch mit "bridge" (portainer) und noch eine spezielle Sache für influx-grafana... (hab ich wohl aus irgendeinem Youtube tutorial so übernommen)
          • Das neue Setup (über Portainer docker compose) ergibt an gleicher Stelle nun dieses Config:
          Also meine Fragen:
          • was bedeutet jeweils bridge oder host?
          • wie mache ich es denn im neuen Setup sinnvollerweise?
          Schon mal danke.
            @chrisham
            Der Thread Titel " USB Device für IOBroker in Docker " passt jetzt nicht mehr zum weiteren Inhalt !
            Chrisham
            @glasfaser ok, soll ich neuen aufmachen oder umbenennen?
            • C Chrisham
              GlasfaserG Offline
              GlasfaserG Offline
              oder umbenennen?
              ist ja schon ein Threadtitel :
              Rundum Sorglos Paket
                aktuelles compose:
                Moin,
                ich habe nicht alles verfolgt, aber ein, zwei Anmerkungen.
                1. nur wenn Du weißt, was Du machst, solltest Du latest beim Image angeben, denn wenn dann die V10 kommt, dann bügelst Du die über Deine V9, nur vielleicht hat sich das Env. verändert, dann fängst Du an zu suchen, bleib erst einmal innerhalb eines Releases.
                2. ich sehe, gerade nicht, das Du im ioBroker Container das nötige influxDB-cli mit installierst, brauchst Du aber!
                InfluxDB
                The following is valid for all supported cpu architectures.
                You need to run ioBroker Image Version v8.1.0 or greater.
                To fulfill the prerequisites for running an InfluxDB backup/ restore with ioBroker.backitup adapter you need to add the following packages to your containers environment variable PACKAGES:
                ...for InfluxDB v1.8 and older add influxdb
                ...for InfluxDB InfluxDB v2 and newer add influxdb2-cli
                Ich denke, Du musst die "" bei - PACKAGES="ffmpeg lame sox libsox-fmt-mp3 asterisk" wegnehmen.
                Bernd
                Chrisham
                @dp20eic said in USB Device für IOBroker in Docker:
                Mein Wissen erweitert sich täglich :), aber ok, werde ich nochmals überlegen...
                1. ich sehe, gerade nicht, das Du im ioBroker Container das nötige influxDB-cli mit installierst, brauchst Du aber!
                InfluxDB
                ok, danke.
                Bernd
                aha.
                Vielen Dank.
                • OliverIOO OliverIO
                  Chrisham
                  @oliverio vielen Dank, also so korrekt (schon bei allen services den gleichen netzwerknamen (iobroker-4)?
                  version: '3'
                  services:
                    iobroker:
                      restart: always
                      ports:
                        - "8081:8081"
                      volumes:
                      environment:
                        - LANG=de_DE.UTF-8
                        - LANGUAGE=de_DE:de
                        - SETGID=1000
                        - SETUID=1000
                        - TZ=Europe/Berlin
                        - PACKAGES=ffmpeg lame sox libsox-fmt-mp3 asterisk influxdb2-cli
                      devices:
                      networks:
                        iobroker-4:
                    influxdb:
                      restart: always
                      ports:
                        - "8086:8086"
                      volumes:
                      environment:
                        - GOSU_VER=1.12
                      networks:
                        iobroker-4:
                    grafana:
                      restart: always
                      ports:
                        - "3000:3000"
                      volumes:
                      environment:
                      networks:
                        iobroker-4:
                  networks:
                    dockerMACVLAN:
                      external: true
                    iobroker-4:
                  bei influxdb hatte ich im compose-file nichts mit IP drin, das war nur im DSM-Config, d.h. dann einfach nur den eintrag mit networks...?
                  Container laufen schon, baut aber noch im Hintergrund, bin gespannt...
                  Auf DSM-Ebene habe ich beobachtet, dass sich nun der iobroker-name geändert hat (erklärbar...?):
                  C OliverIOO 2 Antworten Letzte Antwort
                    oder umbenennen?
                    Chrisham
                    @glasfaser gut so?
                    • C Chrisham
                      version: '3'
                      services:
                        iobroker:
                          restart: always
                          ports:
                            - "8081:8081"
                          volumes:
                          environment:
                            - LANG=de_DE.UTF-8
                            - LANGUAGE=de_DE:de
                            - SETGID=1000
                            - SETUID=1000
                            - TZ=Europe/Berlin
                          devices:
                          networks:
                            iobroker-4:
                        influxdb:
                          restart: always
                          ports:
                            - "8086:8086"
                          volumes:
                          environment:
                            - GOSU_VER=1.12
                          networks:
                            iobroker-4:
                        grafana:
                          restart: always
                          ports:
                            - "3000:3000"
                          volumes:
                          environment:
                          networks:
                            iobroker-4:
                      networks:
                        dockerMACVLAN:
                          external: true
                        iobroker-4:
                      Chrisham
                      @chrisham Gibt Probleme, Grafana container will nicht so recht:
                      2023/10/24 23:27:56,stdout,"You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
                      2023/10/24 23:27:56,stdout,GF_PATHS_DATA='/usr/share/grafana' is not writable.
                      Das sind exakt die Env-Var/Pfade, die ich bisher beim DSM-Docker-config angegeben habe:
                      Hat sich doch also nichts geändert und das sind doch Pfade innerhalb des Containers.
                      In der Ref (https://grafana.com/docs/grafana/latest/setup-grafana/installation/docker/#migrate-to-v51-or-later) steht noch was drin, dass der Container mit User gestartet werden soll, der ents. Rechte hat:
                      Use bind mounts
                      If you plan to use directories on your host for the database or configuration when running Grafana in Docker, you must start the container with a user that has the permission to access and write to the directory you map.
                      Die werden ja durch Portainer gestartet....
                      In der o.g. Referenz stehen bei dem docker-compose Bsp. gar keine Env-Variablen/Pfade drin, soll ich die auch mal rausnehmen...?
                      Der Weg ist doch etwas beschwerlicher als gedacht, dabei wollte ich doch nur mein USB-Smart-Meter anschließen... 😠
                      C OliverIOO 3 Antworten Letzte Antwort
                      • C Chrisham
                        Use bind mounts
                        Chrisham
                        @chrisham Es stimmen andere Dinge noch nicht:
                        • der "komische" iobroker-Container (heißt aber nur so in DSM) scheint kaputt zu sein, allerdings in Portainer sieht alles ok aus:
                        • Portainer:
                        • DSM:
                          --> Kann da auch kein Terminal öffnen.
                        Hmm, bin mal gespannt ob dieses Vorhaben irgendwann noch konvergiert....😧
                        • C Chrisham
                          version: '3'
                          services:
                            iobroker:
                              restart: always
                              ports:
                                - "8081:8081"
                              volumes:
                              environment:
                                - LANG=de_DE.UTF-8
                                - LANGUAGE=de_DE:de
                                - SETGID=1000
                                - SETUID=1000
                                - TZ=Europe/Berlin
                              devices:
                              networks:
                                iobroker-4:
                            influxdb:
                              restart: always
                              ports:
                                - "8086:8086"
                              volumes:
                              environment:
                                - GOSU_VER=1.12
                              networks:
                                iobroker-4:
                            grafana:
                              restart: always
                              ports:
                                - "3000:3000"
                              volumes:
                              environment:
                              networks:
                                iobroker-4:
                          networks:
                            dockerMACVLAN:
                              external: true
                            iobroker-4:
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @chrisham sagte in USB in Docker via neuer Container über Compose u.a. andere:
                          diese beiden Zeilen bitte löschen.
                          das hat mit macvlan zu tun. das hast du nicht
                          dockerMACVLAN:
                            external: true
                          dann würde ich den bindestrich im netzwerknamen weglassen iobroker-4:
                          kann funktionieren, weiß ich nicht. bei solchen namen halte ich mich immer an die regel a-z0-9
                          ansonsten passt das.
                          du kannst es ja dann selber mal probieren, in dem du die console bspw im iobroker container öffnest (nicht die console auf deinem host system) und dann
                          ping grafana
                          machen. da müsste dann eine ip adresse kommen, aber keine aus deinem normalen lan-adressbereich.. das ist dann die ip unter der grafana innerhalb dieser service definition erreichbar ist. aber wie gesagt. normalerweise musst du dich bei docker nicht um konkrete ip adressen kümmern. das macht docker für dich. du sprichst die services nur über den servicenamen=hostname an
                          Links im Profil
                            dockerMACVLAN:
                              external: true
                            ping grafana
                            Chrisham
                            @oliverio ok, danke. baut gerade neuen stack mit:
                            version: '3'
                            services:
                              iobroker:
                                restart: always
                                container_name: iobroker-6
                                hostname: iobroker-6
                                ports:
                                  - "8081:8081"
                                volumes:
                                environment:
                                  - LANG=de_DE.UTF-8
                                  - LANGUAGE=de_DE:de
                                  - SETGID=1000
                                  - SETUID=1000
                                  - TZ=Europe/Berlin
                                devices:
                                networks:
                                  iobroker6:
                              influxdb:
                                restart: always
                                container_name: influxdb-6
                                ports:
                                  - "8086:8086"
                                volumes:
                                environment:
                                  - GOSU_VER=1.12
                                networks:
                                  iobroker6:
                              grafana:
                                restart: always
                                container_name: grafana-6
                                ports:
                                  - "3000:3000"
                                volumes:
                                networks:
                                  iobroker6:
                            networks:
                              iobroker6:
                            Für heute noch diesen Versuch, sonst gehts morgen weiter....
                            • C Chrisham
                              Use bind mounts
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              das ist der richtige abschnitt
                              https://grafana.com/docs/grafana/latest/setup-grafana/installation/docker/#use-bind-mounts-1
                              das ist eine berechtigungsgeschichte. viele container laufen intern mit root.
                              das ändert sich aber, so das auch innen, wie es sein sollte mit dedizierten usern gearbeitet wird. diese benötigen allerdings schreibrechte auf dem gastlaufwerk. diese information muss man dem container mitgeben.
                              füge im grafana abschnitt noch hinzu
                              user: '0'
                              und probiere ob es dann geht.
                              alternativ
                              das hier, da weiß ich aber nicht ob shell substitution unter portainer funktioniert.
                              user: $(id -u)
                              Links im Profil
                                user: '0'
                                alternativ
                                user: $(id -u)
                                Chrisham
                                @oliverio ok, danke. mach ich morgen dann.
                                Letzter Versuch mit o.g. Änderungen war leider nicht erfolgreich:
                                • influx connected noch nicht
                                  (auch asterisk install scheint noch nicht zu funktionieren, jedenfalls kann adapter nicht verbinden, oder wird der linux-proc nur nicht automatisch gestartet...? wobei ich die pakete über container-terminal an der üblichen stelle (/etc/init.d) auch nicht gefunden habe....
                                Nunja, war heute halt nicht so erfolgreich, muss noch paar h schlafen, morgen gehts weiter, dennoch vielen dank für den stetigen support!
                                • C Chrisham
                                  Use bind mounts
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  in der container konfiguration immer so sparsam mit angaben umgehen wie möglich.
                                  normalerweise hat ein container meist default werte, so das ein container einfach mal läuft.
                                  daher nur die angaben hinzufügen, die gemäß doku unbedingt gefordert sind. alles andere kann man erst mal weglassen. erst wenn du merkst, das du da was anderes haben wills, dann kannst du ergänzen.
                                  hier der abschnitt zu den ganzen pfad angaben.
                                  https://grafana.com/docs/grafana/latest/setup-grafana/configure-docker/#default-paths
                                  wenn du da nix änderst, dann musst du da auch nix angeben,
                                  ich mach mir bspw bei jedem container gedanken, was will ich da sichern und wo stehen diese daten. dann schaue ich, wie ich die da herausbekommen.
                                  zum besseren verständnis von docker und dem dateisystem. docker nutzt ein layer dateisystem. jeder darüberliegende layer überdeckt die einzelnen dateien und verzeichnisse des darunterliegenden layers. normalerweise kommt ganz unten der layer mit dem betriebssystem. dann wird darauf die applikation gelegt.
                                  jetzt kommst du und legst darüber nochmal ein named volume oder ein verzeichnis/datei aus deinem dateisystem.
                                  dadurch kannst du bspw einzelne dateien oder ganze verzeichnisse nach aussen legen und die dann wegsichern.
                                  alle daten, die während der laufzeit im container erzeugt werden und nicht in einem volume liegen, sind nach der regeneration des containers wieder weg.
                                  wenn du etwas sichern willst, dann ist sicherlich /var/lib/grafana (data) interessant
                                  wenn du plugins installierst evtl auch den pfad zu den plugins, bin aber in grafana sicht so firm und weiß nicht was in den einzelnen verzeichnissen wirklich etwas abgelegt wird.
                                  Links im Profil
                                  • C Chrisham
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    warum steht im protokoll dann immer noch 127.0.0.1?
                                    das ist localhost, also wenn eine applikation zu einer anderen auf der gleichen maschine kontakt aufnehmen will.
                                    influxdb hast du in einem eigenen container. das ist wie ein weiterer rechner mit eigener ip. also musst du dem iobroker-.influx-adapter in der configuration bei ip influxdb eintragen. das ist gemäß deiner konfiguration der servicename und damit auch gleich der hostname unter der der container erreichbar ist.
                                    Links im Profil
                                    C 2 Antworten Letzte Antwort
                                      Chrisham
                                      @oliverio gut Frage. Ich schwör, ich hab nur das im compose:
                                      version: '3'
                                      services:
                                        iobroker:
                                          restart: always
                                          ports:
                                            - "8081:8081"
                                          volumes:
                                          environment:
                                            - LANG=de_DE.UTF-8
                                            - LANGUAGE=de_DE:de
                                            - SETGID=1000
                                            - SETUID=1000
                                            - TZ=Europe/Berlin
                                          devices:
                                          networks:
                                            iobroker6:
                                        influxdb:
                                          restart: always
                                          ports:
                                            - "8086:8086"
                                          volumes:
                                          environment:
                                            - GOSU_VER=1.12
                                          networks:
                                            iobroker6:
                                        grafana:
                                          restart: always
                                          ports:
                                            - "3000:3000"
                                          volumes:
                                          networks:
                                            iobroker6:
                                      networks:
                                        iobroker6:
                                      Oder ist das dann nicht die IP, die für die interne Bridge zwischen den Containern vergeben wird. Aber ich kenn mich ja selbst nicht damit aus... wo könnte da noch was verkehrt konfiguriert sein?
                                        Chrisham
                                        @oliverio Guten Morgen,
                                        gerade kam noch ein Gedanke: Config innerhalb des influx-Adapters, die übernimmt ja dann der neue Container wieder.
                                        Und zwar steht da im influx-Adapter config, innerhalb iobroker, also "localhost":
                                        Kann das sein, dass das dann als 127.0.0.1 aufgelöst wird? Soll ich das rausnehmen? Weiß nur nicht, ob dann Adapter noch in bisheriger Container-Config läuft...
                                        War ne spontane Idee, falls das eine mögliche ursache ist, dann kann ich das heute Abend mal testen (bin jetzt tagsüber erstmal bei der regulären Arbeit...)
                                        • OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          @chrisham
                                          bitte meine posts sorgfältig lesen und bei nicht verstehen nachfragen
                                          ich hatte das schon 2 mal geschrieben
                                          https://de.wikipedia.org/wiki/Localhost
                                          @oliverio sagte in USB in Docker via neuer Container über Compose u.a. andere:
                                          Links im Profil
