  4. Ältere ioBroker Instanz updaten?
    5.1k
31 Beiträge 5 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • TolkinT Tolkin
    Nein habe ich noch nicht, werde ich die Tage mal machen.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     20:38:41 up  1:03,  1 user,  load average: 2.36, 1.87, 1.17
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-22 20:38:41 CEST
               Universal time: Sun 2023-10-22 18:38:41 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G         72M        7.2G        8.0M        607M        7.6G
    Swap:           99M          0B         99M
    Total:         8.0G         72M        7.3G
             7898 M total memory
               72 M used memory
              406 M active memory
              135 M inactive memory
             7218 M free memory
              118 M buffer memory
              488 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.8G   24G  18% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sun Oct 22 19:34:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=676facee-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sun Oct 22 19:34:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Oct 22 19:34:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Oct 22 19:34:59 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    828M    /var/
    625M    /var/cache
    620M    /var/cache/apt
    561M    /var/cache/apt/archives
    95M     /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    7.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    389M    /opt/iobroker/iobroker-data/
    237M    /opt/iobroker/iobroker-data/files
    91M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    17M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/@alcalzone/release-script-core
    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker
    npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package
    npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/@alcalzone/release-script
    npm ERR! extraneous: @aws-sdk/util-utf8-browser@ /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
    npm ERR! extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
    npm ERR! extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
    npm ERR! extraneous: aws-iot-device-sdk-v2@ /opt/iobroker/node_modules/aws-iot-device-sdk-v2
    npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
    npm ERR! invalid: iobroker.worx@ /opt/iobroker/node_modules/iobroker.worx
    npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/js-sdsl
    npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocator
    npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc
    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
    npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package/node_modules/@alcalzone/pak
    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script/node_modules/axios
    npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslib
    npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder
    npm ERR! extraneous: @ampproject/remapping@2.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@ampproject/remapping
    npm ERR! extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/aws-crt/node_modules/@aws-sdk/util-utf8-browser
    npm ERR! extraneous: @babel/code-frame@7.22.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame
    npm ERR! extraneous: @babel/compat-data@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/compat-data
    npm ERR! extraneous: @babel/core@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core
    npm ERR! extraneous: @babel/generator@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/generator
    npm ERR! extraneous: @babel/helper-compilation-targets@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets
    npm ERR! extraneous: @babel/helper-environment-visitor@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-environment-visitor
    npm ERR! extraneous: @babel/helper-function-name@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-function-name
    npm ERR! extraneous: @babel/helper-hoist-variables@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-hoist-variables
    npm ERR! extraneous: @babel/helper-module-imports@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-imports
    npm ERR! extraneous: @babel/helper-module-transforms@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-transforms
    npm ERR! extraneous: @babel/helper-plugin-utils@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-plugin-utils
    npm ERR! extraneous: @babel/helper-simple-access@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-simple-access
    npm ERR! extraneous: @babel/helper-split-export-declaration@7.22.6 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-split-export-declaration
    npm ERR! extraneous: @babel/helper-string-parser@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-string-parser
    npm ERR! extraneous: @babel/helper-validator-identifier@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-identifier
    npm ERR! extraneous: @babel/helper-validator-option@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-option
    npm ERR! extraneous: @babel/helpers@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helpers
    npm ERR! extraneous: @babel/highlight@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight
    npm ERR! extraneous: @babel/parser@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/parser
    npm ERR! extraneous: @babel/plugin-syntax-async-generators@7.8.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-async-generators
    npm ERR! extraneous: @babel/plugin-syntax-bigint@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-bigint
    npm ERR! extraneous: @babel/plugin-syntax-class-properties@7.12.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-class-properties
    npm ERR! extraneous: @babel/plugin-syntax-import-meta@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-import-meta
    npm ERR! extraneous: @babel/plugin-syntax-json-strings@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-json-strings
    npm ERR! extraneous: @babel/plugin-syntax-logical-assignment-operators@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-logical-assignment-operators
    npm ERR! extraneous: @babel/plugin-syntax-nullish-coalescing-operator@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-nullish-coalescing-operator
    npm ERR! extraneous: @babel/plugin-syntax-numeric-separator@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-numeric-separator
    npm ERR! extraneous: @babel/plugin-syntax-object-rest-spread@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-object-rest-spread
    npm ERR! extraneous: @babel/plugin-syntax-optional-catch-binding@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-catch-binding
    npm ERR! extraneous: @babel/plugin-syntax-optional-chaining@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-chaining
    npm ERR! extraneous: @babel/plugin-syntax-top-level-await@7.14.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-top-level-await
    npm ERR! extraneous: @babel/plugin-syntax-typescript@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-typescript
    npm ERR! extraneous: @babel/template@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/template
    npm ERR! extraneous: @babel/traverse@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/traverse
    npm ERR! extraneous: @babel/types@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/types
    npm ERR! extraneous: @bcoe/v8-coverage@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/@bcoe/v8-coverage
    npm ERR! extraneous: @hapi/hoek@9.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/hoek
    npm ERR! extraneous: @hapi/topo@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/topo
    npm ERR! extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream
    npm ERR! extraneous: @istanbuljs/load-nyc-config@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/load-nyc-config
    npm ERR! extraneous: @istanbuljs/schema@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/schema
    npm ERR! extraneous: @jest/console@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/console
    npm ERR! extraneous: @jest/core@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/core
    npm ERR! extraneous: @jest/environment@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/environment
    npm ERR! extraneous: @jest/fake-timers@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/fake-timers
    npm ERR! extraneous: @jest/globals@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/globals
    npm ERR! extraneous: @jest/reporters@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/reporters
    npm ERR! extraneous: @jest/source-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/source-map
    npm ERR! extraneous: @jest/test-result@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-result
    npm ERR! extraneous: @jest/test-sequencer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-sequencer
    npm ERR! extraneous: @jest/transform@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/transform
    npm ERR! extraneous: @jest/types@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/types
    npm ERR! extraneous: @jridgewell/gen-mapping@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/gen-mapping
    npm ERR! extraneous: @jridgewell/resolve-uri@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/resolve-uri
    npm ERR! extraneous: @jridgewell/set-array@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/set-array
    npm ERR! extraneous: @jridgewell/sourcemap-codec@1.4.15 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/sourcemap-codec
    npm ERR! extraneous: @jridgewell/trace-mapping@0.3.20 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/trace-mapping
    npm ERR! extraneous: @sideway/address@4.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/address
    npm ERR! extraneous: @sideway/formula@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/formula
    npm ERR! extraneous: @sideway/pinpoint@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/pinpoint
    npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/commons
    npm ERR! extraneous: @sinonjs/fake-timers@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/fake-timers
    npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@tootallnate/once
    npm ERR! extraneous: @types/babel__core@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__core
    npm ERR! extraneous: @types/babel__generator@7.6.6 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__generator
    npm ERR! extraneous: @types/babel__template@7.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__template
    npm ERR! extraneous: @types/babel__traverse@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__traverse
    npm ERR! extraneous: @types/crypto-js@3.1.47 /opt/iobroker/node_modules/aws-crt/node_modules/@types/crypto-js
    npm ERR! extraneous: @types/graceful-fs@4.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/@types/graceful-fs
    npm ERR! extraneous: @types/istanbul-lib-coverage@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-coverage
    npm ERR! extraneous: @types/istanbul-lib-report@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-report
    npm ERR! extraneous: @types/istanbul-reports@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-reports
    npm ERR! extraneous: @types/jest@27.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/jest
    npm ERR! extraneous: @types/node@10.17.60 /opt/iobroker/node_modules/aws-crt/node_modules/@types/node
    npm ERR! extraneous: @types/prettier@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/@types/prettier
    npm ERR! extraneous: @types/puppeteer@5.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/puppeteer
    npm ERR! extraneous: @types/stack-utils@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/stack-utils
    npm ERR! extraneous: @types/uuid@3.4.12 /opt/iobroker/node_modules/aws-crt/node_modules/@types/uuid
    npm ERR! extraneous: @types/ws@7.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/ws
    npm ERR! extraneous: @types/yargs-parser@21.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs-parser
    npm ERR! extraneous: @types/yargs@16.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs
    npm ERR! extraneous: @types/yauzl@2.10.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yauzl
    npm ERR! extraneous: abab@ /opt/iobroker/node_modules/aws-crt/node_modules/abab
    npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals
    npm ERR! extraneous: acorn-walk@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-walk
    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn
    npm ERR! extraneous: agent-base@ /opt/iobroker/node_modules/aws-crt/node_modules/agent-base
    npm ERR! invalid: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes
    npm ERR! extraneous: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes
    npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles
    npm ERR! extraneous: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi
    npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/aws-crt/node_modules/anymatch
    npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet
    npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/aws-crt/node_modules/argparse
    npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union
    npm ERR! extraneous: asynckit@ /opt/iobroker/node_modules/aws-crt/node_modules/asynckit
    npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays
    npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk
    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/aws-crt/node_modules/axios
    npm ERR! extraneous: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest
    npm ERR! invalid: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul
    npm ERR! extraneous: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul
    npm ERR! extraneous: babel-plugin-jest-hoist@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-jest-hoist
    npm ERR! extraneous: babel-preset-current-node-syntax@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-current-node-syntax
    npm ERR! extraneous: babel-preset-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-jest
    npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match
    npm ERR! extraneous: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js
    npm ERR! extraneous: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer
    npm ERR! extraneous: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary
    npm ERR! extraneous: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl
    npm ERR! extraneous: bluebird@ /opt/iobroker/node_modules/aws-crt/node_modules/bluebird
    npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion
    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces
    npm ERR! extraneous: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime
    npm ERR! invalid: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist
    npm ERR! extraneous: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist
    npm ERR! extraneous: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger
    npm ERR! extraneous: bser@ /opt/iobroker/node_modules/aws-crt/node_modules/bser
    npm ERR! extraneous: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32
    npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from
    npm ERR! extraneous: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill
    npm ERR! extraneous: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims
    npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer
    npm ERR! extraneous: buffers@ /opt/iobroker/node_modules/aws-crt/node_modules/buffers
    npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind
    npm ERR! invalid: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites
    npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites
    npm ERR! invalid: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase
    npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase
    npm ERR! extraneous: caniuse-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/caniuse-lite
    npm ERR! extraneous: chainsaw@ /opt/iobroker/node_modules/aws-crt/node_modules/chainsaw
    npm ERR! invalid: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk
    npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk
    npm ERR! extraneous: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex
    npm ERR! extraneous: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr
    npm ERR! extraneous: ci-info@ /opt/iobroker/node_modules/aws-crt/node_modules/ci-info
    npm ERR! extraneous: cjs-module-lexer@ /opt/iobroker/node_modules/aws-crt/node_modules/cjs-module-lexer
    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui
    npm ERR! extraneous: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep
    npm ERR! extraneous: cmake-js@ /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js
    npm ERR! extraneous: co@ /opt/iobroker/node_modules/aws-crt/node_modules/co
    npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at
    npm ERR! invalid: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage
    npm ERR! extraneous: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage
    npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/aws-crt/node_modules/color-convert
    npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/aws-crt/node_modules/color-name
    npm ERR! extraneous: combined-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/combined-stream
    npm ERR! extraneous: commander@ /opt/iobroker/node_modules/aws-crt/node_modules/commander
    npm ERR! extraneous: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist
    npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-map
    npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream
    npm ERR! invalid: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map
    npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map
    npm ERR! extraneous: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is
    npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn
    npm ERR! extraneous: crypto-js@ /opt/iobroker/node_modules/aws-crt/node_modules/crypto-js
    npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/aws-crt/node_modules/cssom
    npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle
    npm ERR! extraneous: cwd@ /opt/iobroker/node_modules/aws-crt/node_modules/cwd
    npm ERR! extraneous: data-urls@ /opt/iobroker/node_modules/aws-crt/node_modules/data-urls
    npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize
    npm ERR! extraneous: decimal.js@ /opt/iobroker/node_modules/aws-crt/node_modules/decimal.js
    npm ERR! extraneous: dedent@ /opt/iobroker/node_modules/aws-crt/node_modules/dedent
    npm ERR! extraneous: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend
    npm ERR! extraneous: deepmerge@ /opt/iobroker/node_modules/aws-crt/node_modules/deepmerge
    npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property
    npm ERR! extraneous: delayed-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/delayed-stream
    npm ERR! extraneous: delegates@ /opt/iobroker/node_modules/aws-crt/node_modules/delegates
    npm ERR! extraneous: detect-newline@ /opt/iobroker/node_modules/aws-crt/node_modules/detect-newline
    npm ERR! extraneous: diff-sequences@ /opt/iobroker/node_modules/aws-crt/node_modules/diff-sequences
    npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/aws-crt/node_modules/domexception
    npm ERR! extraneous: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2
    npm ERR! invalid: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify
    npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify
    npm ERR! extraneous: electron-to-chromium@ /opt/iobroker/node_modules/aws-crt/node_modules/electron-to-chromium
    npm ERR! invalid: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery
    npm ERR! extraneous: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery
    npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex
    npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream
    npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex
    npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade
    npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp
    npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/aws-crt/node_modules/escodegen
    npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/aws-crt/node_modules/esprima
    npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/aws-crt/node_modules/estraverse
    npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/aws-crt/node_modules/esutils
    npm ERR! extraneous: events@ /opt/iobroker/node_modules/aws-crt/node_modules/events
    npm ERR! extraneous: execa@ /opt/iobroker/node_modules/aws-crt/node_modules/execa
    npm ERR! invalid: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit
    npm ERR! extraneous: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit
    npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde
    npm ERR! extraneous: expect-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/expect-puppeteer
    npm ERR! invalid: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect
    npm ERR! extraneous: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect
    npm ERR! extraneous: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip
    npm ERR! invalid: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify
    npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify
    npm ERR! extraneous: fb-watchman@ /opt/iobroker/node_modules/aws-crt/node_modules/fb-watchman
    npm ERR! extraneous: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer
    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/aws-crt/node_modules/fill-range
    npm ERR! extraneous: find-file-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-file-up
    npm ERR! extraneous: find-pkg@ /opt/iobroker/node_modules/aws-crt/node_modules/find-pkg
    npm ERR! extraneous: find-process@ /opt/iobroker/node_modules/aws-crt/node_modules/find-process
    npm ERR! invalid: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up
    npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up
    npm ERR! extraneous: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects
    npm ERR! extraneous: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each
    npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/aws-crt/node_modules/for-in
    npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/aws-crt/node_modules/for-own
    npm ERR! extraneous: form-data@ /opt/iobroker/node_modules/aws-crt/node_modules/form-data
    npm ERR! extraneous: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants
    npm ERR! extraneous: fs-exists-sync@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-exists-sync
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-extra
    npm ERR! extraneous: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass
    npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath
    npm ERR! extraneous: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream
    npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/function-bind
    npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge
    npm ERR! invalid: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync
    npm ERR! extraneous: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync
    npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file
    npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic
    npm ERR! invalid: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type
    npm ERR! extraneous: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type
    npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/get-stream
    npm ERR! invalid: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob
    npm ERR! extraneous: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob
    npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules
    npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/aws-crt/node_modules/global-prefix
    npm ERR! invalid: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals
    npm ERR! extraneous: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals
    npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd
    npm ERR! invalid: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs
    npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs
    npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag
    npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors
    npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/aws-crt/node_modules/has-proto
    npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/aws-crt/node_modules/has-symbols
    npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag
    npm ERR! extraneous: has-unicode@ /opt/iobroker/node_modules/aws-crt/node_modules/has-unicode
    npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/aws-crt/node_modules/hasown
    npm ERR! extraneous: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me
    npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/homedir-polyfill
    npm ERR! extraneous: html-encoding-sniffer@ /opt/iobroker/node_modules/aws-crt/node_modules/html-encoding-sniffer
    npm ERR! extraneous: html-escaper@ /opt/iobroker/node_modules/aws-crt/node_modules/html-escaper
    npm ERR! extraneous: http-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/http-proxy-agent
    npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/https-proxy-agent
    npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/aws-crt/node_modules/human-signals
    npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite
    npm ERR! extraneous: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754
    npm ERR! extraneous: import-local@ /opt/iobroker/node_modules/aws-crt/node_modules/import-local
    npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash
    npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight
    npm ERR! invalid: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits
    npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits
    npm ERR! extraneous: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini
    npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/aws-crt/node_modules/invert-kv
    npm ERR! extraneous: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments
    npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arrayish
    npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer
    npm ERR! extraneous: is-callable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-callable
    npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module
    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable
    npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: is-generator-fn@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-fn
    npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function
    npm ERR! extraneous: is-iojs@ /opt/iobroker/node_modules/aws-crt/node_modules/is-iojs
    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number
    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/aws-crt/node_modules/is-plain-object
    npm ERR! extraneous: is-potential-custom-element-name@ /opt/iobroker/node_modules/aws-crt/node_modules/is-potential-custom-element-name
    npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/is-stream
    npm ERR! extraneous: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array
    npm ERR! extraneous: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray
    npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/aws-crt/node_modules/is-windows
    npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray
    npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe
    npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/aws-crt/node_modules/isobject
    npm ERR! invalid: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws
    npm ERR! extraneous: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws
    npm ERR! invalid: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage
    npm ERR! extraneous: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage
    npm ERR! invalid: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument
    npm ERR! extraneous: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument
    npm ERR! invalid: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report
    npm ERR! extraneous: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report
    npm ERR! invalid: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps
    npm ERR! extraneous: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps
    npm ERR! invalid: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports
    npm ERR! extraneous: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports
    npm ERR! invalid: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files
    npm ERR! extraneous: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files
    npm ERR! extraneous: jest-circus@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-circus
    npm ERR! extraneous: jest-cli@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli
    npm ERR! invalid: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config
    npm ERR! extraneous: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config
    npm ERR! extraneous: jest-dev-server@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-dev-server
    npm ERR! extraneous: jest-diff@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-diff
    npm ERR! extraneous: jest-docblock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-docblock
    npm ERR! extraneous: jest-each@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-each
    npm ERR! extraneous: jest-environment-jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-jsdom
    npm ERR! extraneous: jest-environment-node@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-node
    npm ERR! extraneous: jest-environment-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-puppeteer
    npm ERR! extraneous: jest-get-type@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-get-type
    npm ERR! invalid: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map
    npm ERR! extraneous: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map
    npm ERR! extraneous: jest-jasmine2@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-jasmine2
    npm ERR! extraneous: jest-leak-detector@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-leak-detector
    npm ERR! invalid: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils
    npm ERR! extraneous: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils
    npm ERR! invalid: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util
    npm ERR! extraneous: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util
    npm ERR! invalid: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock
    npm ERR! extraneous: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock
    npm ERR! extraneous: jest-pnp-resolver@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-pnp-resolver
    npm ERR! extraneous: jest-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-puppeteer
    npm ERR! invalid: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util
    npm ERR! extraneous: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util
    npm ERR! invalid: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies
    npm ERR! extraneous: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies
    npm ERR! invalid: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve
    npm ERR! extraneous: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve
    npm ERR! invalid: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner
    npm ERR! extraneous: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner
    npm ERR! invalid: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime
    npm ERR! extraneous: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime
    npm ERR! extraneous: jest-serializer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-serializer
    npm ERR! invalid: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot
    npm ERR! extraneous: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot
    npm ERR! invalid: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util
    npm ERR! extraneous: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util
    npm ERR! invalid: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate
    npm ERR! extraneous: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate
    npm ERR! invalid: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher
    npm ERR! extraneous: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher
    npm ERR! invalid: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker
    npm ERR! extraneous: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker
    npm ERR! extraneous: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest
    npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/aws-crt/node_modules/jmespath
    npm ERR! extraneous: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi
    npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl
    npm ERR! invalid: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens
    npm ERR! extraneous: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens
    npm ERR! invalid: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml
    npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml
    npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jsdom
    npm ERR! invalid: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc
    npm ERR! extraneous: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc
    npm ERR! extraneous: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors
    npm ERR! invalid: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5
    npm ERR! extraneous: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5
    npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser
    npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonfile
    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of
    npm ERR! extraneous: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur
    npm ERR! extraneous: lazy-cache@ /opt/iobroker/node_modules/aws-crt/node_modules/lazy-cache
    npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid
    npm ERR! extraneous: leven@ /opt/iobroker/node_modules/aws-crt/node_modules/leven
    npm ERR! extraneous: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns
    npm ERR! extraneous: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount
    npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/aws-crt/node_modules/locate-path
    npm ERR! extraneous: lodash.memoize@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.memoize
    npm ERR! extraneous: lodash.pad@4.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.pad
    npm ERR! extraneous: lodash.padend@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padend
    npm ERR! extraneous: lodash.padstart@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padstart
    npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/aws-crt/node_modules/lodash
    npm ERR! extraneous: lru-cache@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/lru-cache
    npm ERR! extraneous: lunr@2.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/lunr
    npm ERR! extraneous: make-dir@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir
    npm ERR! extraneous: make-error@1.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/make-error
    npm ERR! extraneous: makeerror@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/makeerror
    npm ERR! extraneous: marked@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/marked
    npm ERR! extraneous: memory-stream@0.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream
    npm ERR! extraneous: merge-deep@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/merge-deep
    npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/merge-stream
    npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/micromatch
    npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime-db
    npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/aws-crt/node_modules/mime-types
    npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime
    npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/mimic-fn
    npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minimatch
    npm ERR! extraneous: minimist@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/minimist
    npm ERR! extraneous: minipass@3.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/minipass
    npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib
    npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp-classic
    npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp
    npm ERR! extraneous: mqtt-packet@6.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt-packet
    npm ERR! extraneous: mqtt@4.3.7 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt
    npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/natural-compare
    npm ERR! extraneous: node-int64@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/node-int64
    npm ERR! extraneous: node-releases@2.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/node-releases
    npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/normalize-path
    npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/npm-run-path
    npm ERR! extraneous: npmlog@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/npmlog
    npm ERR! extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/aws-crt/node_modules/number-allocator
    npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/number-is-nan
    npm ERR! extraneous: nwsapi@2.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/nwsapi
    npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/once
    npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/onetime
    npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/os-homedir
    npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/os-locale
    npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-limit
    npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-locate
    npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-try
    npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-json
    npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-passwd
    npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/parse5
    npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/path-exists
    npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-is-absolute
    npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-key
    npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/path-parse
    npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pend
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/picocolors
    npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/picomatch
    npm ERR! extraneous: pirates@4.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/pirates
    npm ERR! extraneous: pkg-dir@4.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pkg-dir
    npm ERR! extraneous: pretty-format@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format
    npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/process-nextick-args
    npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/aws-crt/node_modules/process
    npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/progress
    npm ERR! extraneous: prompts@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/prompts
    npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/proxy-from-env
    npm ERR! extraneous: psl@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/psl
    npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/pump
    npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/punycode
    npm ERR! extraneous: puppeteer@3.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer
    npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystring
    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystringify
    npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/rc
    npm ERR! extraneous: react-is@17.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/react-is
    npm ERR! invalid: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream
    npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream
    npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/reinterval
    npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/require-directory
    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/requires-port
    npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-cwd
    npm ERR! extraneous: resolve-dir@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-dir
    npm ERR! extraneous: resolve-from@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-from
    npm ERR! extraneous: resolve.exports@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve.exports
    npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/aws-crt/node_modules/resolve
    npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/rfdc
    npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/rimraf
    npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs
    npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/safer-buffer
    npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/sax
    npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/saxes
    npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/semver
    npm ERR! extraneous: set-function-length@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/set-function-length
    npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/setimmediate
    npm ERR! extraneous: shallow-clone@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone
    npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-command
    npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-regex
    npm ERR! extraneous: shiki@0.10.1 /opt/iobroker/node_modules/aws-crt/node_modules/shiki
    npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/signal-exit
    npm ERR! extraneous: sisteransi@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/sisteransi
    npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/slash
    npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/aws-crt/node_modules/source-map-support
    npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/source-map
    npm ERR! extraneous: spawnd@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/spawnd
    npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/split2
    npm ERR! extraneous: splitargs@0.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/splitargs
    npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/sprintf-js
    npm ERR! extraneous: stack-utils@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/stack-utils
    npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/stream-shift
    npm ERR! extraneous: string-length@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/string-length
    npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/string-width
    npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-ansi
    npm ERR! extraneous: strip-bom@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-bom
    npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-final-newline
    npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-json-comments
    npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-color
    npm ERR! extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-hyperlinks
    npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-preserve-symlinks-flag
    npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/symbol-tree
    npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs
    npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream
    npm ERR! extraneous: tar@6.1.11 /opt/iobroker/node_modules/aws-crt/node_modules/tar
    npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/terminal-link
    npm ERR! extraneous: test-exclude@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/test-exclude
    npm ERR! extraneous: throat@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/throat
    npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/through
    npm ERR! extraneous: tmpl@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/tmpl
    npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/to-fast-properties
    npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/to-regex-range
    npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie
    npm ERR! extraneous: tr46@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/tr46
    npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/traverse
    npm ERR! extraneous: tree-kill@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/tree-kill
    npm ERR! extraneous: ts-jest@27.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest
    npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/aws-crt/node_modules/tslib
    npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/type-detect
    npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/aws-crt/node_modules/type-fest
    npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray-to-buffer
    npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray
    npm ERR! extraneous: typedoc-plugin-merge-modules@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc-plugin-merge-modules
    npm ERR! extraneous: typedoc@0.22.18 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc
    npm ERR! invalid: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript
    npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript
    npm ERR! extraneous: unbzip2-stream@1.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream
    npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/universalify
    npm ERR! extraneous: unzipper@0.8.14 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper
    npm ERR! extraneous: update-browserslist-db@1.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/update-browserslist-db
    npm ERR! extraneous: url-join@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/url-join
    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/aws-crt/node_modules/url-parse
    npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/aws-crt/node_modules/url
    npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/util-deprecate
    npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-crt/node_modules/util
    npm ERR! extraneous: uuid@8.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/uuid
    npm ERR! extraneous: v8-to-istanbul@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul
    npm ERR! extraneous: vscode-oniguruma@1.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-oniguruma
    npm ERR! extraneous: vscode-textmate@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-textmate
    npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-hr-time
    npm ERR! extraneous: w3c-xmlserializer@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-xmlserializer
    npm ERR! extraneous: wait-on@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on
    npm ERR! extraneous: wait-port@0.2.14 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port
    npm ERR! extraneous: walker@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/walker
    npm ERR! extraneous: webidl-conversions@6.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/webidl-conversions
    npm ERR! extraneous: whatwg-encoding@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-encoding
    npm ERR! extraneous: whatwg-mimetype@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-mimetype
    npm ERR! extraneous: whatwg-url@8.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-url
    npm ERR! extraneous: which-typed-array@1.1.13 /opt/iobroker/node_modules/aws-crt/node_modules/which-typed-array
    npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/which
    npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/window-size
    npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wrap-ansi
    npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wrappy
    npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/write-file-atomic
    npm ERR! extraneous: ws@8.14.2 /opt/iobroker/node_modules/aws-crt/node_modules/ws
    npm ERR! extraneous: xml-name-validator@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml-name-validator
    npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml2js
    npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/xmlbuilder
    npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/xmlchars
    npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/xtend
    npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/y18n
    npm ERR! extraneous: yallist@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yallist
    npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/aws-crt/node_modules/yargs-parser
    npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/yargs
    npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/yauzl
    npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/enquirer/node_modules/strip-ansi
    npm ERR! invalid: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
    npm ERR! missing: qs@^6.11.1, required by iobroker.vw-connect@0.0.67
    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.worx/node_modules/axios
    npm ERR! extraneous: http-cookie-agent@ /opt/iobroker/node_modules/iobroker.worx/node_modules/http-cookie-agent
    npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/iobroker.worx/node_modules/tough-cookie
    npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/iobroker.worx/node_modules/uuid
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/number-allocator/node_modules/debug
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-name
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/supports-color
    npm ERR! extraneous: convert-source-map@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/convert-source-map
    npm ERR! invalid: debug@2.6.9 /opt/iobroker/node_modules/debug
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/semver
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets/node_modules/semver
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-name
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/supports-color
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/safe-buffer
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder
    npm ERR! extraneous: acorn@7.4.1 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals/node_modules/acorn
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/readable-stream
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/safe-buffer
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/string_decoder
    npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/buffer
    npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/uuid
    npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/bl/node_modules/buffer
    npm ERR! extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/buffer/node_modules/ieee754
    npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/ansi-regex
    npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/axios
    npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/camelcase
    npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/chownr
    npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/cliui
    npm ERR! extraneous: fs-minipass@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/fs-minipass
    npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: minipass@2.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minipass
    npm ERR! extraneous: minizlib@1.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minizlib
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/mkdirp
    npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/string-width
    npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/strip-ansi
    npm ERR! extraneous: tar@4.4.19 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/tar
    npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/wrap-ansi
    npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/y18n
    npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/yargs
    npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/commist/node_modules/leven
    npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn/node_modules/which
    npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle/node_modules/cssom
    npm ERR! extraneous: webidl-conversions@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/domexception/node_modules/webidl-conversions
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/readable-stream
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/safe-buffer
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/string_decoder
    npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/readable-stream
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/safe-buffer
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/string_decoder
    npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip/node_modules/get-stream
    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/mkdirp
    npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/rimraf
    npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument/node_modules/semver
    npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/cliui
    npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/yargs
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/yallist
    npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate/node_modules/camelcase
    npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker/node_modules/supports-color
    npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom/node_modules/ws
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/yallist
    npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/isarray
    npm ERR! extraneous: readable-stream@1.0.34 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/string_decoder
    npm ERR! invalid: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union
    npm ERR! invalid: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep
    npm ERR! invalid: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of
    npm ERR! invalid: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces
    npm ERR! invalid: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minipass/node_modules/yallist
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib/node_modules/yallist
    npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object/node_modules/for-in
    npm ERR! invalid: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable
    npm ERR! invalid: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl
    npm ERR! invalid: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist
    npm ERR! invalid: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream
    npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/duplexify
    npm ERR! invalid: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/lru-cache
    npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/ws
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/yallist
    npm ERR! invalid: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi
    npm ERR! invalid: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet
    npm ERR! invalid: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge
    npm ERR! invalid: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl
    npm ERR! invalid: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid
    npm ERR! invalid: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex
    npm ERR! invalid: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors
    npm ERR! invalid: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns
    npm ERR! invalid: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format/node_modules/ansi-styles
    npm ERR! invalid: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur
    npm ERR! invalid: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream
    npm ERR! extraneous: agent-base@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/agent-base
    npm ERR! invalid: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip
    npm ERR! extraneous: https-proxy-agent@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/https-proxy-agent
    npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/ws
    npm ERR! invalid: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend
    npm ERR! invalid: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini
    npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/rc/node_modules/strip-json-comments
    npm ERR! invalid: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde
    npm ERR! invalid: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules
    npm ERR! invalid: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module
    npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs/node_modules/tslib
    npm ERR! invalid: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property
    npm ERR! invalid: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic
    npm ERR! invalid: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd
    npm ERR! invalid: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors
    npm ERR! extraneous: kind-of@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/kind-of
    npm ERR! extraneous: lazy-cache@0.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/lazy-cache
    npm ERR! invalid: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser
    npm ERR! invalid: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from
    npm ERR! invalid: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp
    npm ERR! invalid: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex
    npm ERR! invalid: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex
    npm ERR! invalid: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point
    npm ERR! invalid: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag
    npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs/node_modules/chownr
    npm ERR! invalid: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants
    npm ERR! invalid: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr
    npm ERR! invalid: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar/node_modules/yallist
    npm ERR! invalid: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number
    npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie/node_modules/universalify
    npm ERR! invalid: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest
    npm ERR! invalid: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger
    npm ERR! invalid: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest
    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/lru-cache
    npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/semver
    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/yallist
    npm ERR! invalid: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray
    npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/brace-expansion
    npm ERR! extraneous: glob@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/glob
    npm ERR! extraneous: minimatch@5.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/minimatch
    npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream/node_modules/buffer
    npm ERR! invalid: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer
    npm ERR! invalid: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary
    npm ERR! extraneous: bluebird@3.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/bluebird
    npm ERR! invalid: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill
    npm ERR! invalid: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2
    npm ERR! invalid: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream
    npm ERR! invalid: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount
    npm ERR! extraneous: process-nextick-args@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/process-nextick-args
    npm ERR! extraneous: readable-stream@2.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/readable-stream
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/string_decoder
    npm ERR! invalid: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade
    npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/url/node_modules/punycode
    npm ERR! invalid: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments
    npm ERR! invalid: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function
    npm ERR! invalid: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array
    npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul/node_modules/source-map
    npm ERR! invalid: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime
    npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on/node_modules/axios
    npm ERR! invalid: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi
    npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/ansi-styles
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/chalk
    npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-name
    npm ERR! extraneous: commander@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/commander
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/escape-string-regexp
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/has-flag
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/supports-color
    npm ERR! invalid: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite
    npm ERR! invalid: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays
    npm ERR! invalid: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind
    npm ERR! invalid: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each
    npm ERR! invalid: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag
    npm ERR! invalid: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe
    npm ERR! invalid: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles
    npm ERR! invalid: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash
    npm ERR! invalid: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui
    npm ERR! invalid: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file
    npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yargs/node_modules/yargs-parser
    npm ERR! invalid: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32
    npm ERR! invalid: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer
    npm ERR! invalid: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
    npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
    npm ERR! invalid: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is
    npm ERR! invalid: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray
    npm ERR! invalid: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js
    npm ERR! invalid: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754
    npm ERR! invalid: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects
    npm ERR! invalid: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at
    npm ERR! invalid: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize
    npm ERR! invalid: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer
    npm ERR! invalid: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match
    npm ERR! invalid: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath
    npm ERR! invalid: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight
    npm ERR! invalid: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims
    npm ERR! missing: qs@^6.7.0, required by googleapis-common@7.0.0
    npm ERR! missing: ws@^7.5.0, required by mqtt@4.2.8
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-22T18_38_48_336Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    [/s]
    @tolkin sagte in Ältere ioBroker Instanz updaten?:
    Nein habe ich noch nicht, werde ich die Tage mal machen.
    Dann schau ich mir das dann die Tage an.
    TolkinT 1 Antwort Letzte Antwort
      TolkinT Offline
      TolkinT Offline
      Tolkin
      Kann ich das System auf Bookworm updaten oder soll ich neu flashen?
      • TolkinT Tolkin
        neu flashen?
        und backup zurückspielen
        R 1 Antwort Letzte Antwort
        • TolkinT Tolkin
          @tolkin
          Neuinstallation als 64bit-Lite-Version.
            @tolkin
            TolkinT Offline
            TolkinT Offline
            Tolkin
            Alles klar, hast du ein Link für das Image
            • TolkinT Tolkin
              @tolkin
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                neu flashen?
                reutli
                @homoran sagte in Ältere ioBroker Instanz updaten?:
                Wenn überhaupt vorhanden?!
                Habe ich in den bisherigen Infos nicht gesehen!
                iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                *Wer freundlich ist, dem wird freundlich geholfen *
                • TolkinT Offline
                  TolkinT Offline
                  Tolkin
                  Heute habe ich ein neues Image Debian 12 geflasht und ioBroker nach Anleitung installiert. Zum Schluss wieder das letzte Backup eingespielt. Jetzt komme ich zwar per Putty drauf aber die Weboberfläsche läuft nicht. Kann mir jemand helfen und sagen, wie ich die Weboberfläsche wieder ans laufen bekomme?
                  • TolkinT Tolkin
                    @tolkin
                    iob diag
                    sagt?
                    Im simpelsten Fall hilft
                    iob start admin
                      @tolkin
                      iob diag
                      sagt?
                      iob start admin
                      TolkinT Offline
                      TolkinT Offline
                      Tolkin
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi4-rpi-v8
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : arm64
                      Systemuptime and Load:
                       21:37:29 up 15 min,  2 users,  load average: 0.04, 0.22, 0.19
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Tue 2023-10-24 21:37:30 CEST
                                 Universal time: Tue 2023-10-24 19:37:30 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            8.2G        268M        7.5G        1.2M        565M        7.9G
                      Swap:           104M          0B        104M
                      Total:          8.3G        268M        7.6G
                               7811 M total memory
                                256 M used memory
                                220 M active memory
                                343 M inactive memory
                               7138 M free memory
                                 30 M buffer memory
                                509 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.6G     0  3.6G   0% /dev
                      tmpfs          tmpfs     782M  1.1M  781M   1% /run
                      /dev/mmcblk0p2 ext4       59G  2.7G   53G   5% /
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                      [Tue Oct 24 21:22:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c509a9ba-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Tue Oct 24 21:22:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Tue Oct 24 21:22:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      TARGET           SOURCE         FSTYPE OPTIONS
                      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      492M    /var/
                      201M    /var/cache
                      195M    /var/cache/apt
                      159M    /var/lib
                      130M    /var/lib/apt/lists
                      Archived and active journals take up 32.0M in the file system.
                      /opt/iobroker/backups:
                      5.0M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      19M     /opt/iobroker/iobroker-data/
                      15M     /opt/iobroker/iobroker-data/files
                      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                      3.8M    /opt/iobroker/iobroker-data/objects.jsonl
                      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                      USB-Devices by-id:
                      find: '/dev/serial/by-id/': No such file or directory
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.18.2
                      /usr/bin/node           v18.18.2
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      /usr/bin/corepack       0.19.0
                      nodejs:
                        Installed: 18.18.2-1nodesource1
                        Candidate: 18.18.2-1nodesource1
                        Version table:
                       *** 18.18.2-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                           18.18.1-1nodesource1 500
                           18.18.0-1nodesource1 500
                           18.17.1-1nodesource1 500
                           18.17.0-1nodesource1 500
                           18.16.1-1nodesource1 500
                           18.16.0-1nodesource1 500
                           18.15.0-1nodesource1 500
                           18.14.2-1nodesource1 500
                           18.14.1-1nodesource1 500
                           18.14.0-1nodesource1 500
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                           18.13.0-1nodesource1 500
                           18.12.0-1nodesource1 500
                           18.11.0-1nodesource1 500
                           18.10.0-1nodesource1 500
                           18.9.1-1nodesource1 500
                           18.9.0-1nodesource1 500
                           18.8.0-1nodesource1 500
                           18.7.0-1nodesource1 500
                           18.6.0-1nodesource1 500
                           18.5.0-1nodesource1 500
                           18.4.0-1nodesource1 500
                           18.3.0-1nodesource1 500
                           18.2.0-1nodesource1 500
                           18.1.0-1nodesource1 500
                           18.0.0-1nodesource1 500
                      No problems detected
                      Errors in npm tree:
                      ioBroker Status
                      No connection to states 127.0.0.1:6379[redis]
                      Core adapters versions
                      js-controller:  5.0.12
                      admin:          "admin" not found
                      javascript:     "javascript" not found
                      Adapters from github:   0
                      Adapter State
                      ioBroker-Repositories
                      Installed ioBroker-Instances
                      Objects and States
                      Objects:        1
                      States:         1
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29953      4445/iobroker.js-co
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3990       681/sshd: /usr/sbin
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          3992       681/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:50025           0.0.0.0:*                           104        13702      531/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13700      531/avahi-daemon: r
                      udp6       0      0 :::47411                :::*                                104        13703      531/avahi-daemon: r
                      udp6       0      0 fe80::573c:9b67:23c:546 :::*                                0          16494      601/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        13701      531/avahi-daemon: r
                      2023-10-24 21:36:54.637  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
                      2023-10-24 21:37:24.657  - error: host.raspberrypi No connection to databases possible, restart
                      2023-10-24 21:37:24.673  - info: host.raspberrypi iobroker _restart
                      2023-10-24 21:37:30.540  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-24 21:37:30.546  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-24 21:37:30.548  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
                      2023-10-24 21:37:30.550  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
                      2023-10-24 21:38:00.571  - error: host.raspberrypi No connection to databases possible, restart
                      2023-10-24 21:38:00.578  - info: host.raspberrypi iobroker _restart
                      2023-10-24 21:38:06.332  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-24 21:38:06.337  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-24 21:38:06.338  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
                      2023-10-24 21:38:06.340  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
                      2023-10-24 21:38:36.359  - error: host.raspberrypi No connection to databases possible, restart
                      2023-10-24 21:38:36.366  - info: host.raspberrypi iobroker _restart
                      2023-10-24 21:38:42.122  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-24 21:38:42.128  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-24 21:38:42.129  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
                      2023-10-24 21:38:42.130  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
                      2023-10-24 21:39:12.149  - error: host.raspberrypi No connection to databases possible, restart
                      2023-10-24 21:39:12.166  - info: host.raspberrypi iobroker _restart
                      2023-10-24 21:39:18.223  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-24 21:39:18.230  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-24 21:39:18.232  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
                      2023-10-24 21:39:18.234  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
                      • TolkinT Tolkin
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 7811 M total memory
                                  256 M used memory
                                  220 M active memory
                                 7138 M free memory
                                   30 M buffer memory
                                  509 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        492M    /var/
                        201M    /var/cache
                        195M    /var/cache/apt
                        159M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Adapter State
                        Objects and States
                        Objects:        1
                        States:         1
                        Pending Updates: 0
                        War das ein redis-Setup? Dann muss redis noch nachinstalliert werden.
                        sudo apt install redis
                          TolkinT Offline
                          TolkinT Offline
                          Tolkin
                          Habe ich nachinstalliert, aber die Weboberfläsche funktioniert nicht. Irgendwas ist noch faul.
                          • TolkinT Tolkin
                            @tolkin
                            iobroker (oder den Server) neugestartet?
                            systemctl status redis
                            sagt?
                              @tolkin
                              sagt?
                              TolkinT Offline
                              TolkinT Offline
                              Tolkin
                              @thomas-braun sagte in Ältere ioBroker Instanz updaten?:
                              pi@raspberrypi:~ $ systemctl status redis
                              ● redis-server.service - Advanced key-value store
                              Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset:>
                              Active: active (running) since Tue 2023-10-24 21:45:50 CEST; 5min ago
                              Docs: http://redis.io/documentation,
                              man:redis-server(1)
                              Main PID: 672 (redis-server)
                              Status: "Ready to accept connections"
                              Tasks: 5 (limit: 8741)
                              CPU: 1.485s
                              CGroup: /system.slice/redis-server.service
                              └─672 "/usr/bin/redis-server 127.0.0.1:6379"
                              Oct 24 21:45:50 raspberrypi systemd[1]: Starting redis-server.service - Advance>
                              Oct 24 21:45:50 raspberrypi systemd[1]: Started redis-server.service - Advanced>
                              lines 1-14/14 (END)...skipping...
                              Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled)
                              man:redis-server(1)
                              CPU: 1.485s
                              Oct 24 21:45:50 raspberrypi systemd[1]: Starting redis-server.service - Advanced key-value store...
                              Oct 24 21:45:50 raspberrypi systemd[1]: Started redis-server.service - Advanced key-value store.
                              • TolkinT Tolkin
                                man:redis-server(1)
                                CPU: 1.485s
                                man:redis-server(1)
                                CPU: 1.485s
                                @tolkin
                                iob restart
                                Und dann
                                iob list adapters
                                  @tolkin
                                  iob restart
                                  Und dann
                                  iob list adapters
                                  TolkinT Offline
                                  TolkinT Offline
                                  Tolkin
                                  iob list adapters
                                  pi@raspberrypi:~ $ iob list adapters
                                  system.adapter.admin : admin - v6.10.1
                                  system.adapter.backitup : backitup - v2.8.1
                                  system.adapter.discovery : discovery - v3.1.0
                                  • TolkinT Tolkin
                                    iob list adapters
                                    @tolkin
                                    iob list instances
                                    Besser statt Spoiler die CodeTags verwenden. Oder beides...
                                      @tolkin
                                      iob list instances
                                      TolkinT Offline
                                      TolkinT Offline
                                      Tolkin
                                      iob list instances
                                      pi@raspberrypi:~ $ iob list instances
                                      + system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      pi@raspberrypi:~ $
                                      • TolkinT Tolkin
                                        iob list instances
                                        + instance is alive
                                        pi@raspberrypi:~ $
                                        @tolkin
                                        disabled...
                                        Hatte ich lange nicht mehr. Weiß gerade nicht wie man den wieder 'enabled'.
                                        iob restart admin
                                        vielleicht.
                                          @tolkin
                                          disabled...
                                          iob restart admin
                                          vielleicht.
                                          TolkinT Offline
                                          TolkinT Offline
                                          Tolkin
                                          iob restart admin
                                          Das hat geholfen, vielen Dank ;)
