- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- Ältere ioBroker Instanz updaten?
Wie wäre es mit mehr Infos?
Welches OS?
Wieviel RAM Speicher ?Und und und …
Am besten ein
iob diag
hier posten.
Sorry, hier das iob diag
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker*** X-Server-Setup ***
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.60-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 14:13:22 up 84 days, 15:58, 1 user, load average: 13.42, 13.32, 13.12 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. This system needs to be REBOOTED! *** Time and Time Zones *** Local time: Sun 2023-10-22 14:13:23 CEST Universal time: Sun 2023-10-22 12:13:23 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** [/s] -
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.60-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 14:13:22 up 84 days, 15:58, 1 user, load average: 13.42, 13.32, 13.12 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. This system needs to be REBOOTED! *** Time and Time Zones *** Local time: Sun 2023-10-22 14:13:23 CEST Universal time: Sun 2023-10-22 12:13:23 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** [/s]Die Langfassung bitte .
Und was man schon sehen kann, das OS Buster ist längst tot.
Update auf Bullseye, noch besser Bookworm ( aktuell)
Und vorher das System rebooten ( steht fett im Log)Edit: irgendwas macht der Kiste schwer zu schaffen, Average Load von 13 ….
Hey,
wir wollen gerade bei einem Bekannten eine ioBroker Version updaten. Als Hauptsystem läuft ein Debian auf einem Raspberry PI. Debian haben wir bereits aktualisiert. Als Node.js läuft v14.21.3 und NPM v6.14.18
Kann ich jetzt mit einfachen Befehlen das System updaten? Oder muss alles manuell upgedatet werden?Danke
@tolkin sagte in Ältere ioBroker Instanz updaten?:
Nö, da läuft noch ein Debian 10 'Buster'.
In Anbetracht von
Kernel : armv7l Userland : armhfwürde ich da aber auch ein Bookworm komplett neuinstallieren. 64bit-Lite.
In Anbetracht von
Ich habe mal eine Langversion gemacht. Kann mir jemand sagen, wie ich die npm installation wieder hinbekomme?
nicht, wenn du nicht sagst was drin steht
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
@tolkin dann teil es auf 2 Posts auf.
Dann ist aber schon massiv was schiefkein Support per PN! - Fragen im Forum stellen -
Ich kann es nicht posten, bekomme die Fehlermeldung FEHLER Payload Too Large
Das spricht aber schon für ein unrundes System. Das wäre sonst nicht so/zu groß.
Hast du jetzt Bookworm frisch installiert?
Nein habe ich noch nicht, werde ich die Tage mal machen.
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 20:38:41 up 1:03, 1 user, load average: 2.36, 1.87, 1.17 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2023-10-22 20:38:41 CEST Universal time: Sun 2023-10-22 18:38:41 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 72M 7.2G 8.0M 607M 7.6G Swap: 99M 0B 99M Total: 8.0G 72M 7.3G 7898 M total memory 72 M used memory 406 M active memory 135 M inactive memory 7218 M free memory 118 M buffer memory 488 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 4.8G 24G 18% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 8.5M 3.9G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 0 790M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Oct 22 19:34:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=676facee-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Sun Oct 22 19:34:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Sun Oct 22 19:34:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Oct 22 19:34:59 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 828M /var/ 625M /var/cache 620M /var/cache/apt 561M /var/cache/apt/archives 95M /var/lib Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 7.4M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 389M /opt/iobroker/iobroker-data/ 237M /opt/iobroker/iobroker-data/files 91M /opt/iobroker/iobroker-data/backup-objects 52M /opt/iobroker/iobroker-data/files/javascript.admin 48M /opt/iobroker/iobroker-data/files/telegram.admin The five largest files in iobroker-data are: 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map 19M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map 17M /opt/iobroker/iobroker-data/objects.json.migrated USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /home/iobroker/.diag.sh: line 277: nodejs: command not found /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 /usr/bin/corepack 0.18.0 /home/iobroker/.diag.sh: line 288: nodejs: command not found *** nodejs is NOT correctly installed *** nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/@alcalzone/release-script-core npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/@alcalzone/release-script npm ERR! extraneous: @aws-sdk/util-utf8-browser@ /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser npm ERR! extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream npm ERR! extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt npm ERR! extraneous: aws-iot-device-sdk-v2@ /opt/iobroker/node_modules/aws-iot-device-sdk-v2 npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/enquirer npm ERR! invalid: iobroker.worx@ /opt/iobroker/node_modules/iobroker.worx npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/js-sdsl npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocator npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package/node_modules/@alcalzone/pak npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script/node_modules/axios npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslib npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream npm ERR! extraneous: string_decoder@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder npm ERR! extraneous: @ampproject/remapping@2.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@ampproject/remapping npm ERR! extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/aws-crt/node_modules/@aws-sdk/util-utf8-browser npm ERR! extraneous: @babel/code-frame@7.22.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame npm ERR! extraneous: @babel/compat-data@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/compat-data npm ERR! extraneous: @babel/core@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core npm ERR! extraneous: @babel/generator@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/generator npm ERR! extraneous: @babel/helper-compilation-targets@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets npm ERR! extraneous: @babel/helper-environment-visitor@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-environment-visitor npm ERR! extraneous: @babel/helper-function-name@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-function-name npm ERR! extraneous: @babel/helper-hoist-variables@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-hoist-variables npm ERR! extraneous: @babel/helper-module-imports@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-imports npm ERR! extraneous: @babel/helper-module-transforms@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-transforms npm ERR! extraneous: @babel/helper-plugin-utils@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-plugin-utils npm ERR! extraneous: @babel/helper-simple-access@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-simple-access npm ERR! extraneous: @babel/helper-split-export-declaration@7.22.6 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-split-export-declaration npm ERR! extraneous: @babel/helper-string-parser@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-string-parser npm ERR! extraneous: @babel/helper-validator-identifier@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-identifier npm ERR! extraneous: @babel/helper-validator-option@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-option npm ERR! extraneous: @babel/helpers@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helpers npm ERR! extraneous: @babel/highlight@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight npm ERR! extraneous: @babel/parser@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/parser npm ERR! extraneous: @babel/plugin-syntax-async-generators@7.8.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-async-generators npm ERR! extraneous: @babel/plugin-syntax-bigint@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-bigint npm ERR! extraneous: @babel/plugin-syntax-class-properties@7.12.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-class-properties npm ERR! extraneous: @babel/plugin-syntax-import-meta@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-import-meta npm ERR! extraneous: @babel/plugin-syntax-json-strings@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-json-strings npm ERR! extraneous: @babel/plugin-syntax-logical-assignment-operators@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-logical-assignment-operators npm ERR! extraneous: @babel/plugin-syntax-nullish-coalescing-operator@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-nullish-coalescing-operator npm ERR! extraneous: @babel/plugin-syntax-numeric-separator@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-numeric-separator npm ERR! extraneous: @babel/plugin-syntax-object-rest-spread@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-object-rest-spread npm ERR! extraneous: @babel/plugin-syntax-optional-catch-binding@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-catch-binding npm ERR! extraneous: @babel/plugin-syntax-optional-chaining@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-chaining npm ERR! extraneous: @babel/plugin-syntax-top-level-await@7.14.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-top-level-await npm ERR! extraneous: @babel/plugin-syntax-typescript@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-typescript npm ERR! extraneous: @babel/template@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/template npm ERR! extraneous: @babel/traverse@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/traverse npm ERR! extraneous: @babel/types@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/types npm ERR! extraneous: @bcoe/v8-coverage@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/@bcoe/v8-coverage npm ERR! extraneous: @hapi/hoek@9.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/hoek npm ERR! extraneous: @hapi/topo@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/topo npm ERR! extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream npm ERR! extraneous: @istanbuljs/load-nyc-config@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/load-nyc-config npm ERR! extraneous: @istanbuljs/schema@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/schema npm ERR! extraneous: @jest/console@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/console npm ERR! extraneous: @jest/core@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/core npm ERR! extraneous: @jest/environment@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/environment npm ERR! extraneous: @jest/fake-timers@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/fake-timers npm ERR! extraneous: @jest/globals@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/globals npm ERR! extraneous: @jest/reporters@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/reporters npm ERR! extraneous: @jest/source-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/source-map npm ERR! extraneous: @jest/test-result@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-result npm ERR! extraneous: @jest/test-sequencer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-sequencer npm ERR! extraneous: @jest/transform@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/transform npm ERR! extraneous: @jest/types@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/types npm ERR! extraneous: @jridgewell/gen-mapping@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/gen-mapping npm ERR! extraneous: @jridgewell/resolve-uri@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/resolve-uri npm ERR! extraneous: @jridgewell/set-array@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/set-array npm ERR! extraneous: @jridgewell/sourcemap-codec@1.4.15 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/sourcemap-codec npm ERR! extraneous: @jridgewell/trace-mapping@0.3.20 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/trace-mapping npm ERR! extraneous: @sideway/address@4.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/address npm ERR! extraneous: @sideway/formula@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/formula npm ERR! extraneous: @sideway/pinpoint@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/pinpoint npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/commons npm ERR! extraneous: @sinonjs/fake-timers@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/fake-timers npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@tootallnate/once npm ERR! extraneous: @types/babel__core@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__core npm ERR! extraneous: @types/babel__generator@7.6.6 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__generator npm ERR! extraneous: @types/babel__template@7.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__template npm ERR! extraneous: @types/babel__traverse@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__traverse npm ERR! extraneous: @types/crypto-js@3.1.47 /opt/iobroker/node_modules/aws-crt/node_modules/@types/crypto-js npm ERR! extraneous: @types/graceful-fs@4.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/@types/graceful-fs npm ERR! extraneous: @types/istanbul-lib-coverage@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-coverage npm ERR! extraneous: @types/istanbul-lib-report@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-report npm ERR! extraneous: @types/istanbul-reports@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-reports npm ERR! extraneous: @types/jest@27.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/jest npm ERR! extraneous: @types/node@10.17.60 /opt/iobroker/node_modules/aws-crt/node_modules/@types/node npm ERR! extraneous: @types/prettier@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/@types/prettier npm ERR! extraneous: @types/puppeteer@5.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/puppeteer npm ERR! extraneous: @types/stack-utils@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/stack-utils npm ERR! extraneous: @types/uuid@3.4.12 /opt/iobroker/node_modules/aws-crt/node_modules/@types/uuid npm ERR! extraneous: @types/ws@7.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/ws npm ERR! extraneous: @types/yargs-parser@21.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs-parser npm ERR! extraneous: @types/yargs@16.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs npm ERR! extraneous: @types/yauzl@2.10.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yauzl npm ERR! extraneous: abab@ /opt/iobroker/node_modules/aws-crt/node_modules/abab npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals npm ERR! extraneous: acorn-walk@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-walk npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn npm ERR! extraneous: agent-base@ /opt/iobroker/node_modules/aws-crt/node_modules/agent-base npm ERR! invalid: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes npm ERR! extraneous: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles npm ERR! extraneous: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/aws-crt/node_modules/anymatch npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/aws-crt/node_modules/argparse npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union npm ERR! extraneous: asynckit@ /opt/iobroker/node_modules/aws-crt/node_modules/asynckit npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk npm ERR! extraneous: axios@ /opt/iobroker/node_modules/aws-crt/node_modules/axios npm ERR! extraneous: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest npm ERR! invalid: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul npm ERR! extraneous: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul npm ERR! extraneous: babel-plugin-jest-hoist@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-jest-hoist npm ERR! extraneous: babel-preset-current-node-syntax@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-current-node-syntax npm ERR! extraneous: babel-preset-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-jest npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match npm ERR! extraneous: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js npm ERR! extraneous: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer npm ERR! extraneous: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary npm ERR! extraneous: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl npm ERR! extraneous: bluebird@ /opt/iobroker/node_modules/aws-crt/node_modules/bluebird npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion npm ERR! extraneous: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces npm ERR! extraneous: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime npm ERR! invalid: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist npm ERR! extraneous: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist npm ERR! extraneous: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger npm ERR! extraneous: bser@ /opt/iobroker/node_modules/aws-crt/node_modules/bser npm ERR! extraneous: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32 npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from npm ERR! extraneous: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill npm ERR! extraneous: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer npm ERR! extraneous: buffers@ /opt/iobroker/node_modules/aws-crt/node_modules/buffers npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind npm ERR! invalid: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites npm ERR! invalid: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase npm ERR! extraneous: caniuse-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/caniuse-lite npm ERR! extraneous: chainsaw@ /opt/iobroker/node_modules/aws-crt/node_modules/chainsaw npm ERR! invalid: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk npm ERR! extraneous: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex npm ERR! extraneous: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr npm ERR! extraneous: ci-info@ /opt/iobroker/node_modules/aws-crt/node_modules/ci-info npm ERR! extraneous: cjs-module-lexer@ /opt/iobroker/node_modules/aws-crt/node_modules/cjs-module-lexer npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui npm ERR! extraneous: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep npm ERR! extraneous: cmake-js@ /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js npm ERR! extraneous: co@ /opt/iobroker/node_modules/aws-crt/node_modules/co npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at npm ERR! invalid: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage npm ERR! extraneous: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/aws-crt/node_modules/color-convert npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/aws-crt/node_modules/color-name npm ERR! extraneous: combined-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/combined-stream npm ERR! extraneous: commander@ /opt/iobroker/node_modules/aws-crt/node_modules/commander npm ERR! extraneous: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-map npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream npm ERR! invalid: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map npm ERR! extraneous: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn npm ERR! extraneous: crypto-js@ /opt/iobroker/node_modules/aws-crt/node_modules/crypto-js npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/aws-crt/node_modules/cssom npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle npm ERR! extraneous: cwd@ /opt/iobroker/node_modules/aws-crt/node_modules/cwd npm ERR! extraneous: data-urls@ /opt/iobroker/node_modules/aws-crt/node_modules/data-urls npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize npm ERR! extraneous: decimal.js@ /opt/iobroker/node_modules/aws-crt/node_modules/decimal.js npm ERR! extraneous: dedent@ /opt/iobroker/node_modules/aws-crt/node_modules/dedent npm ERR! extraneous: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend npm ERR! extraneous: deepmerge@ /opt/iobroker/node_modules/aws-crt/node_modules/deepmerge npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property npm ERR! extraneous: delayed-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/delayed-stream npm ERR! extraneous: delegates@ /opt/iobroker/node_modules/aws-crt/node_modules/delegates npm ERR! extraneous: detect-newline@ /opt/iobroker/node_modules/aws-crt/node_modules/detect-newline npm ERR! extraneous: diff-sequences@ /opt/iobroker/node_modules/aws-crt/node_modules/diff-sequences npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/aws-crt/node_modules/domexception npm ERR! extraneous: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2 npm ERR! invalid: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify npm ERR! extraneous: electron-to-chromium@ /opt/iobroker/node_modules/aws-crt/node_modules/electron-to-chromium npm ERR! invalid: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery npm ERR! extraneous: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/aws-crt/node_modules/escodegen npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/aws-crt/node_modules/esprima npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/aws-crt/node_modules/estraverse npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/aws-crt/node_modules/esutils npm ERR! extraneous: events@ /opt/iobroker/node_modules/aws-crt/node_modules/events npm ERR! extraneous: execa@ /opt/iobroker/node_modules/aws-crt/node_modules/execa npm ERR! invalid: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit npm ERR! extraneous: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde npm ERR! extraneous: expect-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/expect-puppeteer npm ERR! invalid: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect npm ERR! extraneous: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect npm ERR! extraneous: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip npm ERR! invalid: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify npm ERR! extraneous: fb-watchman@ /opt/iobroker/node_modules/aws-crt/node_modules/fb-watchman npm ERR! extraneous: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/aws-crt/node_modules/fill-range npm ERR! extraneous: find-file-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-file-up npm ERR! extraneous: find-pkg@ /opt/iobroker/node_modules/aws-crt/node_modules/find-pkg npm ERR! extraneous: find-process@ /opt/iobroker/node_modules/aws-crt/node_modules/find-process npm ERR! invalid: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up npm ERR! extraneous: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects npm ERR! extraneous: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/aws-crt/node_modules/for-in npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/aws-crt/node_modules/for-own npm ERR! extraneous: form-data@ /opt/iobroker/node_modules/aws-crt/node_modules/form-data npm ERR! extraneous: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants npm ERR! extraneous: fs-exists-sync@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-exists-sync npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-extra npm ERR! extraneous: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath npm ERR! extraneous: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/function-bind npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge npm ERR! invalid: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync npm ERR! extraneous: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic npm ERR! invalid: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type npm ERR! extraneous: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/get-stream npm ERR! invalid: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob npm ERR! extraneous: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/aws-crt/node_modules/global-prefix npm ERR! invalid: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals npm ERR! extraneous: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd npm ERR! invalid: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/aws-crt/node_modules/has-proto npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/aws-crt/node_modules/has-symbols npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag npm ERR! extraneous: has-unicode@ /opt/iobroker/node_modules/aws-crt/node_modules/has-unicode npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/aws-crt/node_modules/hasown npm ERR! extraneous: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/homedir-polyfill npm ERR! extraneous: html-encoding-sniffer@ /opt/iobroker/node_modules/aws-crt/node_modules/html-encoding-sniffer npm ERR! extraneous: html-escaper@ /opt/iobroker/node_modules/aws-crt/node_modules/html-escaper npm ERR! extraneous: http-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/http-proxy-agent npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/https-proxy-agent npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/aws-crt/node_modules/human-signals npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite npm ERR! extraneous: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754 npm ERR! extraneous: import-local@ /opt/iobroker/node_modules/aws-crt/node_modules/import-local npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight npm ERR! invalid: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits npm ERR! extraneous: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/aws-crt/node_modules/invert-kv npm ERR! extraneous: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arrayish npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer npm ERR! extraneous: is-callable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-callable npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point npm ERR! extraneous: is-generator-fn@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-fn npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function npm ERR! extraneous: is-iojs@ /opt/iobroker/node_modules/aws-crt/node_modules/is-iojs npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/aws-crt/node_modules/is-plain-object npm ERR! extraneous: is-potential-custom-element-name@ /opt/iobroker/node_modules/aws-crt/node_modules/is-potential-custom-element-name npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/is-stream npm ERR! extraneous: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array npm ERR! extraneous: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/aws-crt/node_modules/is-windows npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/aws-crt/node_modules/isobject npm ERR! invalid: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws npm ERR! extraneous: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws npm ERR! invalid: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage npm ERR! extraneous: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage npm ERR! invalid: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument npm ERR! extraneous: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument npm ERR! invalid: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report npm ERR! extraneous: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report npm ERR! invalid: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps npm ERR! extraneous: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps npm ERR! invalid: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports npm ERR! extraneous: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports npm ERR! invalid: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files npm ERR! extraneous: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files npm ERR! extraneous: jest-circus@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-circus npm ERR! extraneous: jest-cli@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli npm ERR! invalid: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config npm ERR! extraneous: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config npm ERR! extraneous: jest-dev-server@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-dev-server npm ERR! extraneous: jest-diff@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-diff npm ERR! extraneous: jest-docblock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-docblock npm ERR! extraneous: jest-each@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-each npm ERR! extraneous: jest-environment-jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-jsdom npm ERR! extraneous: jest-environment-node@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-node npm ERR! extraneous: jest-environment-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-puppeteer npm ERR! extraneous: jest-get-type@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-get-type npm ERR! invalid: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map npm ERR! extraneous: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map npm ERR! extraneous: jest-jasmine2@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-jasmine2 npm ERR! extraneous: jest-leak-detector@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-leak-detector npm ERR! invalid: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils npm ERR! extraneous: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils npm ERR! invalid: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util npm ERR! extraneous: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util npm ERR! invalid: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock npm ERR! extraneous: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock npm ERR! extraneous: jest-pnp-resolver@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-pnp-resolver npm ERR! extraneous: jest-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-puppeteer npm ERR! invalid: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util npm ERR! extraneous: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util npm ERR! invalid: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies npm ERR! extraneous: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies npm ERR! invalid: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve npm ERR! extraneous: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve npm ERR! invalid: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner npm ERR! extraneous: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner npm ERR! invalid: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime npm ERR! extraneous: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime npm ERR! extraneous: jest-serializer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-serializer npm ERR! invalid: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot npm ERR! extraneous: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot npm ERR! invalid: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util npm ERR! extraneous: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util npm ERR! invalid: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate npm ERR! extraneous: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate npm ERR! invalid: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher npm ERR! extraneous: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher npm ERR! invalid: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker npm ERR! extraneous: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker npm ERR! extraneous: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/aws-crt/node_modules/jmespath npm ERR! extraneous: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl npm ERR! invalid: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens npm ERR! extraneous: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens npm ERR! invalid: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jsdom npm ERR! invalid: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc npm ERR! extraneous: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc npm ERR! extraneous: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors npm ERR! invalid: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5 npm ERR! extraneous: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5 npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonfile npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of npm ERR! extraneous: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur npm ERR! extraneous: lazy-cache@ /opt/iobroker/node_modules/aws-crt/node_modules/lazy-cache npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid npm ERR! extraneous: leven@ /opt/iobroker/node_modules/aws-crt/node_modules/leven npm ERR! extraneous: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns npm ERR! extraneous: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/aws-crt/node_modules/locate-path npm ERR! extraneous: lodash.memoize@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.memoize npm ERR! extraneous: lodash.pad@4.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.pad npm ERR! extraneous: lodash.padend@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padend npm ERR! extraneous: lodash.padstart@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padstart npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/aws-crt/node_modules/lodash npm ERR! extraneous: lru-cache@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/lru-cache npm ERR! extraneous: lunr@2.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/lunr npm ERR! extraneous: make-dir@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir npm ERR! extraneous: make-error@1.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/make-error npm ERR! extraneous: makeerror@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/makeerror npm ERR! extraneous: marked@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/marked npm ERR! extraneous: memory-stream@0.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream npm ERR! extraneous: merge-deep@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/merge-deep npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/merge-stream npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/micromatch npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime-db npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/aws-crt/node_modules/mime-types npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/mimic-fn npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minimatch npm ERR! extraneous: minimist@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/minimist npm ERR! extraneous: minipass@3.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/minipass npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp-classic npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp npm ERR! extraneous: mqtt-packet@6.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt-packet npm ERR! extraneous: mqtt@4.3.7 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/natural-compare npm ERR! extraneous: node-int64@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/node-int64 npm ERR! extraneous: node-releases@2.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/node-releases npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/normalize-path npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/npm-run-path npm ERR! extraneous: npmlog@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/npmlog npm ERR! extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/aws-crt/node_modules/number-allocator npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/number-is-nan npm ERR! extraneous: nwsapi@2.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/nwsapi npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/once npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/onetime npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/os-homedir npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/os-locale npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-limit npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-locate npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-try npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-json npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-passwd npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/parse5 npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/path-exists npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-is-absolute npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-key npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/path-parse npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pend npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/picocolors npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/picomatch npm ERR! extraneous: pirates@4.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/pirates npm ERR! extraneous: pkg-dir@4.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pkg-dir npm ERR! extraneous: pretty-format@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/process-nextick-args npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/aws-crt/node_modules/process npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/progress npm ERR! extraneous: prompts@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/prompts npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/proxy-from-env npm ERR! extraneous: psl@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/psl npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/pump npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/punycode npm ERR! extraneous: puppeteer@3.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystring npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystringify npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/rc npm ERR! extraneous: react-is@17.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/react-is npm ERR! invalid: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/reinterval npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/require-directory npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/requires-port npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-cwd npm ERR! extraneous: resolve-dir@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-dir npm ERR! extraneous: resolve-from@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-from npm ERR! extraneous: resolve.exports@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve.exports npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/aws-crt/node_modules/resolve npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/rfdc npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/rimraf npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/safer-buffer npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/sax npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/saxes npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/semver npm ERR! extraneous: set-function-length@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/set-function-length npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/setimmediate npm ERR! extraneous: shallow-clone@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-command npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-regex npm ERR! extraneous: shiki@0.10.1 /opt/iobroker/node_modules/aws-crt/node_modules/shiki npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/signal-exit npm ERR! extraneous: sisteransi@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/sisteransi npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/slash npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/aws-crt/node_modules/source-map-support npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/source-map npm ERR! extraneous: spawnd@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/spawnd npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/split2 npm ERR! extraneous: splitargs@0.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/splitargs npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/sprintf-js npm ERR! extraneous: stack-utils@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/stack-utils npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/stream-shift npm ERR! extraneous: string-length@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/string-length npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/string-width npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-ansi npm ERR! extraneous: strip-bom@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-bom npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-final-newline npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-json-comments npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-color npm ERR! extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-hyperlinks npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-preserve-symlinks-flag npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/symbol-tree npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream npm ERR! extraneous: tar@6.1.11 /opt/iobroker/node_modules/aws-crt/node_modules/tar npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/terminal-link npm ERR! extraneous: test-exclude@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/test-exclude npm ERR! extraneous: throat@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/throat npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/through npm ERR! extraneous: tmpl@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/tmpl npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/to-fast-properties npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/to-regex-range npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie npm ERR! extraneous: tr46@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/tr46 npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/traverse npm ERR! extraneous: tree-kill@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/tree-kill npm ERR! extraneous: ts-jest@27.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/aws-crt/node_modules/tslib npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/type-detect npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/aws-crt/node_modules/type-fest npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray-to-buffer npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray npm ERR! extraneous: typedoc-plugin-merge-modules@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc-plugin-merge-modules npm ERR! extraneous: typedoc@0.22.18 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc npm ERR! invalid: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript npm ERR! extraneous: unbzip2-stream@1.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/universalify npm ERR! extraneous: unzipper@0.8.14 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper npm ERR! extraneous: update-browserslist-db@1.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/update-browserslist-db npm ERR! extraneous: url-join@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/url-join npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/aws-crt/node_modules/url-parse npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/aws-crt/node_modules/url npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/util-deprecate npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-crt/node_modules/util npm ERR! extraneous: uuid@8.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/uuid npm ERR! extraneous: v8-to-istanbul@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul npm ERR! extraneous: vscode-oniguruma@1.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-oniguruma npm ERR! extraneous: vscode-textmate@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-textmate npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-hr-time npm ERR! extraneous: w3c-xmlserializer@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-xmlserializer npm ERR! extraneous: wait-on@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on npm ERR! extraneous: wait-port@0.2.14 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port npm ERR! extraneous: walker@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/walker npm ERR! extraneous: webidl-conversions@6.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/webidl-conversions npm ERR! extraneous: whatwg-encoding@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-encoding npm ERR! extraneous: whatwg-mimetype@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-mimetype npm ERR! extraneous: whatwg-url@8.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-url npm ERR! extraneous: which-typed-array@1.1.13 /opt/iobroker/node_modules/aws-crt/node_modules/which-typed-array npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/which npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/window-size npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wrap-ansi npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wrappy npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/write-file-atomic npm ERR! extraneous: ws@8.14.2 /opt/iobroker/node_modules/aws-crt/node_modules/ws npm ERR! extraneous: xml-name-validator@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml-name-validator npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml2js npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/xmlbuilder npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/xmlchars npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/xtend npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/y18n npm ERR! extraneous: yallist@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yallist npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/aws-crt/node_modules/yargs-parser npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/yargs npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/yauzl npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/enquirer/node_modules/strip-ansi npm ERR! invalid: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core npm ERR! missing: qs@^6.11.1, required by iobroker.vw-connect@0.0.67 npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.worx/node_modules/axios npm ERR! extraneous: http-cookie-agent@ /opt/iobroker/node_modules/iobroker.worx/node_modules/http-cookie-agent npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/iobroker.worx/node_modules/tough-cookie npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/iobroker.worx/node_modules/uuid npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/number-allocator/node_modules/debug npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-name npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/supports-color npm ERR! extraneous: convert-source-map@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/convert-source-map npm ERR! invalid: debug@2.6.9 /opt/iobroker/node_modules/debug npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/semver npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets/node_modules/semver npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-name npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/supports-color npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder npm ERR! extraneous: acorn@7.4.1 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals/node_modules/acorn npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/string_decoder npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/buffer npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/uuid npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/bl/node_modules/buffer npm ERR! extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/buffer/node_modules/ieee754 npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/ansi-regex npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/axios npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/camelcase npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/chownr npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/cliui npm ERR! extraneous: fs-minipass@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/fs-minipass npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/is-fullwidth-code-point npm ERR! extraneous: minipass@2.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minipass npm ERR! extraneous: minizlib@1.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minizlib npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/mkdirp npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/string-width npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/strip-ansi npm ERR! extraneous: tar@4.4.19 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/tar npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/wrap-ansi npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/y18n npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/yargs npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/commist/node_modules/leven npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn/node_modules/which npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle/node_modules/cssom npm ERR! extraneous: webidl-conversions@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/domexception/node_modules/webidl-conversions npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/string_decoder npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/string_decoder npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip/node_modules/get-stream npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/mkdirp npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/rimraf npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument/node_modules/semver npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/cliui npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/yargs npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/yallist npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate/node_modules/camelcase npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker/node_modules/supports-color npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom/node_modules/ws npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/yallist npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/isarray npm ERR! extraneous: readable-stream@1.0.34 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/readable-stream npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/string_decoder npm ERR! invalid: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union npm ERR! invalid: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep npm ERR! invalid: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of npm ERR! invalid: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces npm ERR! invalid: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minipass/node_modules/yallist npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib/node_modules/yallist npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object/node_modules/for-in npm ERR! invalid: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable npm ERR! invalid: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl npm ERR! invalid: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist npm ERR! invalid: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/duplexify npm ERR! invalid: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/lru-cache npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/ws npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/yallist npm ERR! invalid: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi npm ERR! invalid: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet npm ERR! invalid: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge npm ERR! invalid: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl npm ERR! invalid: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid npm ERR! invalid: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex npm ERR! invalid: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors npm ERR! invalid: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns npm ERR! invalid: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex npm ERR! extraneous: ansi-styles@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format/node_modules/ansi-styles npm ERR! invalid: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur npm ERR! invalid: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream npm ERR! extraneous: agent-base@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/agent-base npm ERR! invalid: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip npm ERR! extraneous: https-proxy-agent@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/https-proxy-agent npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/ws npm ERR! invalid: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend npm ERR! invalid: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/rc/node_modules/strip-json-comments npm ERR! invalid: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde npm ERR! invalid: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules npm ERR! invalid: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs/node_modules/tslib npm ERR! invalid: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property npm ERR! invalid: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic npm ERR! invalid: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd npm ERR! invalid: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors npm ERR! extraneous: kind-of@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/kind-of npm ERR! extraneous: lazy-cache@0.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/lazy-cache npm ERR! invalid: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser npm ERR! invalid: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from npm ERR! invalid: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp npm ERR! invalid: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex npm ERR! invalid: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex npm ERR! invalid: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point npm ERR! invalid: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs/node_modules/chownr npm ERR! invalid: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants npm ERR! invalid: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr npm ERR! invalid: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar/node_modules/yallist npm ERR! invalid: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie/node_modules/universalify npm ERR! invalid: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest npm ERR! invalid: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger npm ERR! invalid: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/yallist npm ERR! invalid: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/brace-expansion npm ERR! extraneous: glob@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/glob npm ERR! extraneous: minimatch@5.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/minimatch npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream/node_modules/buffer npm ERR! invalid: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer npm ERR! invalid: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary npm ERR! extraneous: bluebird@3.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/bluebird npm ERR! invalid: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill npm ERR! invalid: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2 npm ERR! invalid: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream npm ERR! invalid: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount npm ERR! extraneous: process-nextick-args@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/process-nextick-args npm ERR! extraneous: readable-stream@2.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/readable-stream npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/string_decoder npm ERR! invalid: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/url/node_modules/punycode npm ERR! invalid: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments npm ERR! invalid: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function npm ERR! invalid: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul/node_modules/source-map npm ERR! invalid: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on/node_modules/axios npm ERR! invalid: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-name npm ERR! extraneous: commander@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/commander npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/supports-color npm ERR! invalid: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite npm ERR! invalid: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays npm ERR! invalid: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind npm ERR! invalid: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each npm ERR! invalid: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag npm ERR! invalid: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe npm ERR! invalid: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles npm ERR! invalid: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash npm ERR! invalid: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui npm ERR! invalid: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yargs/node_modules/yargs-parser npm ERR! invalid: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32 npm ERR! invalid: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer npm ERR! invalid: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms npm ERR! invalid: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is npm ERR! invalid: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray npm ERR! invalid: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js npm ERR! invalid: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754 npm ERR! invalid: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects npm ERR! invalid: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at npm ERR! invalid: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize npm ERR! invalid: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer npm ERR! invalid: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match npm ERR! invalid: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath npm ERR! invalid: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight npm ERR! invalid: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims npm ERR! missing: qs@^6.7.0, required by googleapis-common@7.0.0 npm ERR! missing: ws@^7.5.0, required by mqtt@4.2.8 npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-22T18_38_48_336Z-debug-0.log *** ioBroker-Installation *** ioBroker Status [/s] -
Nein habe ich noch nicht, werde ich die Tage mal machen.
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 20:38:41 up 1:03, 1 user, load average: 2.36, 1.87, 1.17 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2023-10-22 20:38:41 CEST Universal time: Sun 2023-10-22 18:38:41 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 72M 7.2G 8.0M 607M 7.6G Swap: 99M 0B 99M Total: 8.0G 72M 7.3G 7898 M total memory 72 M used memory 406 M active memory 135 M inactive memory 7218 M free memory 118 M buffer memory 488 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 4.8G 24G 18% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 8.5M 3.9G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 0 790M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Oct 22 19:34:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=676facee-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Sun Oct 22 19:34:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Sun Oct 22 19:34:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Oct 22 19:34:59 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 828M /var/ 625M /var/cache 620M /var/cache/apt 561M /var/cache/apt/archives 95M /var/lib Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 7.4M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 389M /opt/iobroker/iobroker-data/ 237M /opt/iobroker/iobroker-data/files 91M /opt/iobroker/iobroker-data/backup-objects 52M /opt/iobroker/iobroker-data/files/javascript.admin 48M /opt/iobroker/iobroker-data/files/telegram.admin The five largest files in iobroker-data are: 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map 19M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map 17M /opt/iobroker/iobroker-data/objects.json.migrated USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /home/iobroker/.diag.sh: line 277: nodejs: command not found /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 /usr/bin/corepack 0.18.0 /home/iobroker/.diag.sh: line 288: nodejs: command not found *** nodejs is NOT correctly installed *** nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/@alcalzone/release-script-core npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/@alcalzone/release-script npm ERR! extraneous: @aws-sdk/util-utf8-browser@ /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser npm ERR! extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream npm ERR! extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt npm ERR! extraneous: aws-iot-device-sdk-v2@ /opt/iobroker/node_modules/aws-iot-device-sdk-v2 npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/enquirer npm ERR! invalid: iobroker.worx@ /opt/iobroker/node_modules/iobroker.worx npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/js-sdsl npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocator npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/release-script-plugin-package/node_modules/@alcalzone/pak npm ERR! extraneous: axios@ /opt/iobroker/node_modules/@alcalzone/release-script/node_modules/axios npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser/node_modules/tslib npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream npm ERR! extraneous: string_decoder@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder npm ERR! extraneous: @ampproject/remapping@2.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@ampproject/remapping npm ERR! extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/aws-crt/node_modules/@aws-sdk/util-utf8-browser npm ERR! extraneous: @babel/code-frame@7.22.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame npm ERR! extraneous: @babel/compat-data@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/compat-data npm ERR! extraneous: @babel/core@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core npm ERR! extraneous: @babel/generator@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/generator npm ERR! extraneous: @babel/helper-compilation-targets@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets npm ERR! extraneous: @babel/helper-environment-visitor@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-environment-visitor npm ERR! extraneous: @babel/helper-function-name@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-function-name npm ERR! extraneous: @babel/helper-hoist-variables@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-hoist-variables npm ERR! extraneous: @babel/helper-module-imports@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-imports npm ERR! extraneous: @babel/helper-module-transforms@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-module-transforms npm ERR! extraneous: @babel/helper-plugin-utils@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-plugin-utils npm ERR! extraneous: @babel/helper-simple-access@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-simple-access npm ERR! extraneous: @babel/helper-split-export-declaration@7.22.6 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-split-export-declaration npm ERR! extraneous: @babel/helper-string-parser@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-string-parser npm ERR! extraneous: @babel/helper-validator-identifier@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-identifier npm ERR! extraneous: @babel/helper-validator-option@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-validator-option npm ERR! extraneous: @babel/helpers@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helpers npm ERR! extraneous: @babel/highlight@7.22.20 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight npm ERR! extraneous: @babel/parser@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/parser npm ERR! extraneous: @babel/plugin-syntax-async-generators@7.8.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-async-generators npm ERR! extraneous: @babel/plugin-syntax-bigint@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-bigint npm ERR! extraneous: @babel/plugin-syntax-class-properties@7.12.13 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-class-properties npm ERR! extraneous: @babel/plugin-syntax-import-meta@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-import-meta npm ERR! extraneous: @babel/plugin-syntax-json-strings@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-json-strings npm ERR! extraneous: @babel/plugin-syntax-logical-assignment-operators@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-logical-assignment-operators npm ERR! extraneous: @babel/plugin-syntax-nullish-coalescing-operator@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-nullish-coalescing-operator npm ERR! extraneous: @babel/plugin-syntax-numeric-separator@7.10.4 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-numeric-separator npm ERR! extraneous: @babel/plugin-syntax-object-rest-spread@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-object-rest-spread npm ERR! extraneous: @babel/plugin-syntax-optional-catch-binding@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-catch-binding npm ERR! extraneous: @babel/plugin-syntax-optional-chaining@7.8.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-optional-chaining npm ERR! extraneous: @babel/plugin-syntax-top-level-await@7.14.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-top-level-await npm ERR! extraneous: @babel/plugin-syntax-typescript@7.22.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/plugin-syntax-typescript npm ERR! extraneous: @babel/template@7.22.15 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/template npm ERR! extraneous: @babel/traverse@7.23.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/traverse npm ERR! extraneous: @babel/types@7.23.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/types npm ERR! extraneous: @bcoe/v8-coverage@0.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/@bcoe/v8-coverage npm ERR! extraneous: @hapi/hoek@9.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/hoek npm ERR! extraneous: @hapi/topo@5.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@hapi/topo npm ERR! extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream npm ERR! extraneous: @istanbuljs/load-nyc-config@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/load-nyc-config npm ERR! extraneous: @istanbuljs/schema@0.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@istanbuljs/schema npm ERR! extraneous: @jest/console@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/console npm ERR! extraneous: @jest/core@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/core npm ERR! extraneous: @jest/environment@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/environment npm ERR! extraneous: @jest/fake-timers@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/fake-timers npm ERR! extraneous: @jest/globals@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/globals npm ERR! extraneous: @jest/reporters@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/reporters npm ERR! extraneous: @jest/source-map@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/source-map npm ERR! extraneous: @jest/test-result@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-result npm ERR! extraneous: @jest/test-sequencer@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/test-sequencer npm ERR! extraneous: @jest/transform@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/transform npm ERR! extraneous: @jest/types@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jest/types npm ERR! extraneous: @jridgewell/gen-mapping@0.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/gen-mapping npm ERR! extraneous: @jridgewell/resolve-uri@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/resolve-uri npm ERR! extraneous: @jridgewell/set-array@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/set-array npm ERR! extraneous: @jridgewell/sourcemap-codec@1.4.15 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/sourcemap-codec npm ERR! extraneous: @jridgewell/trace-mapping@0.3.20 /opt/iobroker/node_modules/aws-crt/node_modules/@jridgewell/trace-mapping npm ERR! extraneous: @sideway/address@4.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/address npm ERR! extraneous: @sideway/formula@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/formula npm ERR! extraneous: @sideway/pinpoint@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sideway/pinpoint npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/commons npm ERR! extraneous: @sinonjs/fake-timers@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/@sinonjs/fake-timers npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@tootallnate/once npm ERR! extraneous: @types/babel__core@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__core npm ERR! extraneous: @types/babel__generator@7.6.6 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__generator npm ERR! extraneous: @types/babel__template@7.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__template npm ERR! extraneous: @types/babel__traverse@7.20.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/babel__traverse npm ERR! extraneous: @types/crypto-js@3.1.47 /opt/iobroker/node_modules/aws-crt/node_modules/@types/crypto-js npm ERR! extraneous: @types/graceful-fs@4.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/@types/graceful-fs npm ERR! extraneous: @types/istanbul-lib-coverage@2.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-coverage npm ERR! extraneous: @types/istanbul-lib-report@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-lib-report npm ERR! extraneous: @types/istanbul-reports@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/@types/istanbul-reports npm ERR! extraneous: @types/jest@27.5.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/jest npm ERR! extraneous: @types/node@10.17.60 /opt/iobroker/node_modules/aws-crt/node_modules/@types/node npm ERR! extraneous: @types/prettier@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/@types/prettier npm ERR! extraneous: @types/puppeteer@5.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/puppeteer npm ERR! extraneous: @types/stack-utils@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/stack-utils npm ERR! extraneous: @types/uuid@3.4.12 /opt/iobroker/node_modules/aws-crt/node_modules/@types/uuid npm ERR! extraneous: @types/ws@7.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/ws npm ERR! extraneous: @types/yargs-parser@21.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs-parser npm ERR! extraneous: @types/yargs@16.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yargs npm ERR! extraneous: @types/yauzl@2.10.2 /opt/iobroker/node_modules/aws-crt/node_modules/@types/yauzl npm ERR! extraneous: abab@ /opt/iobroker/node_modules/aws-crt/node_modules/abab npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals npm ERR! extraneous: acorn-walk@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn-walk npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/aws-crt/node_modules/acorn npm ERR! extraneous: agent-base@ /opt/iobroker/node_modules/aws-crt/node_modules/agent-base npm ERR! invalid: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes npm ERR! extraneous: ansi-escapes@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-escapes npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles npm ERR! extraneous: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/aws-crt/node_modules/anymatch npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/aws-crt/node_modules/argparse npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union npm ERR! extraneous: asynckit@ /opt/iobroker/node_modules/aws-crt/node_modules/asynckit npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk npm ERR! extraneous: axios@ /opt/iobroker/node_modules/aws-crt/node_modules/axios npm ERR! extraneous: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest npm ERR! invalid: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul npm ERR! extraneous: babel-plugin-istanbul@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-istanbul npm ERR! extraneous: babel-plugin-jest-hoist@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-plugin-jest-hoist npm ERR! extraneous: babel-preset-current-node-syntax@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-current-node-syntax npm ERR! extraneous: babel-preset-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-preset-jest npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match npm ERR! extraneous: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js npm ERR! extraneous: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer npm ERR! extraneous: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary npm ERR! extraneous: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl npm ERR! extraneous: bluebird@ /opt/iobroker/node_modules/aws-crt/node_modules/bluebird npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion npm ERR! extraneous: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces npm ERR! extraneous: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime npm ERR! invalid: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist npm ERR! extraneous: browserslist@ /opt/iobroker/node_modules/aws-crt/node_modules/browserslist npm ERR! extraneous: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger npm ERR! extraneous: bser@ /opt/iobroker/node_modules/aws-crt/node_modules/bser npm ERR! extraneous: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32 npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from npm ERR! extraneous: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill npm ERR! extraneous: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer npm ERR! extraneous: buffers@ /opt/iobroker/node_modules/aws-crt/node_modules/buffers npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind npm ERR! invalid: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/aws-crt/node_modules/callsites npm ERR! invalid: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/aws-crt/node_modules/camelcase npm ERR! extraneous: caniuse-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/caniuse-lite npm ERR! extraneous: chainsaw@ /opt/iobroker/node_modules/aws-crt/node_modules/chainsaw npm ERR! invalid: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/aws-crt/node_modules/chalk npm ERR! extraneous: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex npm ERR! extraneous: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr npm ERR! extraneous: ci-info@ /opt/iobroker/node_modules/aws-crt/node_modules/ci-info npm ERR! extraneous: cjs-module-lexer@ /opt/iobroker/node_modules/aws-crt/node_modules/cjs-module-lexer npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui npm ERR! extraneous: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep npm ERR! extraneous: cmake-js@ /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js npm ERR! extraneous: co@ /opt/iobroker/node_modules/aws-crt/node_modules/co npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at npm ERR! invalid: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage npm ERR! extraneous: collect-v8-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/collect-v8-coverage npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/aws-crt/node_modules/color-convert npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/aws-crt/node_modules/color-name npm ERR! extraneous: combined-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/combined-stream npm ERR! extraneous: commander@ /opt/iobroker/node_modules/aws-crt/node_modules/commander npm ERR! extraneous: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-map npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream npm ERR! invalid: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/aws-crt/node_modules/convert-source-map npm ERR! extraneous: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn npm ERR! extraneous: crypto-js@ /opt/iobroker/node_modules/aws-crt/node_modules/crypto-js npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/aws-crt/node_modules/cssom npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle npm ERR! extraneous: cwd@ /opt/iobroker/node_modules/aws-crt/node_modules/cwd npm ERR! extraneous: data-urls@ /opt/iobroker/node_modules/aws-crt/node_modules/data-urls npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize npm ERR! extraneous: decimal.js@ /opt/iobroker/node_modules/aws-crt/node_modules/decimal.js npm ERR! extraneous: dedent@ /opt/iobroker/node_modules/aws-crt/node_modules/dedent npm ERR! extraneous: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend npm ERR! extraneous: deepmerge@ /opt/iobroker/node_modules/aws-crt/node_modules/deepmerge npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property npm ERR! extraneous: delayed-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/delayed-stream npm ERR! extraneous: delegates@ /opt/iobroker/node_modules/aws-crt/node_modules/delegates npm ERR! extraneous: detect-newline@ /opt/iobroker/node_modules/aws-crt/node_modules/detect-newline npm ERR! extraneous: diff-sequences@ /opt/iobroker/node_modules/aws-crt/node_modules/diff-sequences npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/aws-crt/node_modules/domexception npm ERR! extraneous: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2 npm ERR! invalid: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexify npm ERR! extraneous: electron-to-chromium@ /opt/iobroker/node_modules/aws-crt/node_modules/electron-to-chromium npm ERR! invalid: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery npm ERR! extraneous: emittery@ /opt/iobroker/node_modules/aws-crt/node_modules/emittery npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/aws-crt/node_modules/escodegen npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/aws-crt/node_modules/esprima npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/aws-crt/node_modules/estraverse npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/aws-crt/node_modules/esutils npm ERR! extraneous: events@ /opt/iobroker/node_modules/aws-crt/node_modules/events npm ERR! extraneous: execa@ /opt/iobroker/node_modules/aws-crt/node_modules/execa npm ERR! invalid: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit npm ERR! extraneous: exit@ /opt/iobroker/node_modules/aws-crt/node_modules/exit npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde npm ERR! extraneous: expect-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/expect-puppeteer npm ERR! invalid: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect npm ERR! extraneous: expect@ /opt/iobroker/node_modules/aws-crt/node_modules/expect npm ERR! extraneous: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip npm ERR! invalid: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/aws-crt/node_modules/fast-json-stable-stringify npm ERR! extraneous: fb-watchman@ /opt/iobroker/node_modules/aws-crt/node_modules/fb-watchman npm ERR! extraneous: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/aws-crt/node_modules/fill-range npm ERR! extraneous: find-file-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-file-up npm ERR! extraneous: find-pkg@ /opt/iobroker/node_modules/aws-crt/node_modules/find-pkg npm ERR! extraneous: find-process@ /opt/iobroker/node_modules/aws-crt/node_modules/find-process npm ERR! invalid: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/aws-crt/node_modules/find-up npm ERR! extraneous: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects npm ERR! extraneous: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/aws-crt/node_modules/for-in npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/aws-crt/node_modules/for-own npm ERR! extraneous: form-data@ /opt/iobroker/node_modules/aws-crt/node_modules/form-data npm ERR! extraneous: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants npm ERR! extraneous: fs-exists-sync@0.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/fs-exists-sync npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-extra npm ERR! extraneous: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath npm ERR! extraneous: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/function-bind npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge npm ERR! invalid: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync npm ERR! extraneous: gensync@ /opt/iobroker/node_modules/aws-crt/node_modules/gensync npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic npm ERR! invalid: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type npm ERR! extraneous: get-package-type@ /opt/iobroker/node_modules/aws-crt/node_modules/get-package-type npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/get-stream npm ERR! invalid: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob npm ERR! extraneous: glob@ /opt/iobroker/node_modules/aws-crt/node_modules/glob npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/aws-crt/node_modules/global-prefix npm ERR! invalid: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals npm ERR! extraneous: globals@ /opt/iobroker/node_modules/aws-crt/node_modules/globals npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd npm ERR! invalid: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/aws-crt/node_modules/graceful-fs npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/aws-crt/node_modules/has-proto npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/aws-crt/node_modules/has-symbols npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag npm ERR! extraneous: has-unicode@ /opt/iobroker/node_modules/aws-crt/node_modules/has-unicode npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/aws-crt/node_modules/hasown npm ERR! extraneous: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/homedir-polyfill npm ERR! extraneous: html-encoding-sniffer@ /opt/iobroker/node_modules/aws-crt/node_modules/html-encoding-sniffer npm ERR! extraneous: html-escaper@ /opt/iobroker/node_modules/aws-crt/node_modules/html-escaper npm ERR! extraneous: http-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/http-proxy-agent npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/aws-crt/node_modules/https-proxy-agent npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/aws-crt/node_modules/human-signals npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite npm ERR! extraneous: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754 npm ERR! extraneous: import-local@ /opt/iobroker/node_modules/aws-crt/node_modules/import-local npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight npm ERR! invalid: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/aws-crt/node_modules/inherits npm ERR! extraneous: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/aws-crt/node_modules/invert-kv npm ERR! extraneous: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arrayish npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer npm ERR! extraneous: is-callable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-callable npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point npm ERR! extraneous: is-generator-fn@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-fn npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function npm ERR! extraneous: is-iojs@ /opt/iobroker/node_modules/aws-crt/node_modules/is-iojs npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/aws-crt/node_modules/is-plain-object npm ERR! extraneous: is-potential-custom-element-name@ /opt/iobroker/node_modules/aws-crt/node_modules/is-potential-custom-element-name npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/is-stream npm ERR! extraneous: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array npm ERR! extraneous: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/aws-crt/node_modules/is-windows npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/aws-crt/node_modules/isobject npm ERR! invalid: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws npm ERR! extraneous: isomorphic-ws@ /opt/iobroker/node_modules/aws-crt/node_modules/isomorphic-ws npm ERR! invalid: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage npm ERR! extraneous: istanbul-lib-coverage@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-coverage npm ERR! invalid: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument npm ERR! extraneous: istanbul-lib-instrument@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument npm ERR! invalid: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report npm ERR! extraneous: istanbul-lib-report@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-report npm ERR! invalid: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps npm ERR! extraneous: istanbul-lib-source-maps@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-source-maps npm ERR! invalid: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports npm ERR! extraneous: istanbul-reports@ /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-reports npm ERR! invalid: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files npm ERR! extraneous: jest-changed-files@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-changed-files npm ERR! extraneous: jest-circus@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-circus npm ERR! extraneous: jest-cli@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli npm ERR! invalid: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config npm ERR! extraneous: jest-config@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-config npm ERR! extraneous: jest-dev-server@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-dev-server npm ERR! extraneous: jest-diff@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-diff npm ERR! extraneous: jest-docblock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-docblock npm ERR! extraneous: jest-each@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-each npm ERR! extraneous: jest-environment-jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-jsdom npm ERR! extraneous: jest-environment-node@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-node npm ERR! extraneous: jest-environment-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-environment-puppeteer npm ERR! extraneous: jest-get-type@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-get-type npm ERR! invalid: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map npm ERR! extraneous: jest-haste-map@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-haste-map npm ERR! extraneous: jest-jasmine2@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-jasmine2 npm ERR! extraneous: jest-leak-detector@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-leak-detector npm ERR! invalid: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils npm ERR! extraneous: jest-matcher-utils@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-matcher-utils npm ERR! invalid: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util npm ERR! extraneous: jest-message-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-message-util npm ERR! invalid: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock npm ERR! extraneous: jest-mock@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-mock npm ERR! extraneous: jest-pnp-resolver@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-pnp-resolver npm ERR! extraneous: jest-puppeteer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-puppeteer npm ERR! invalid: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util npm ERR! extraneous: jest-regex-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-regex-util npm ERR! invalid: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies npm ERR! extraneous: jest-resolve-dependencies@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve-dependencies npm ERR! invalid: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve npm ERR! extraneous: jest-resolve@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-resolve npm ERR! invalid: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner npm ERR! extraneous: jest-runner@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runner npm ERR! invalid: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime npm ERR! extraneous: jest-runtime@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-runtime npm ERR! extraneous: jest-serializer@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-serializer npm ERR! invalid: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot npm ERR! extraneous: jest-snapshot@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot npm ERR! invalid: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util npm ERR! extraneous: jest-util@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-util npm ERR! invalid: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate npm ERR! extraneous: jest-validate@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate npm ERR! invalid: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher npm ERR! extraneous: jest-watcher@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-watcher npm ERR! invalid: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker npm ERR! extraneous: jest-worker@ /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker npm ERR! extraneous: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/aws-crt/node_modules/jmespath npm ERR! extraneous: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl npm ERR! invalid: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens npm ERR! extraneous: js-tokens@ /opt/iobroker/node_modules/aws-crt/node_modules/js-tokens npm ERR! invalid: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/aws-crt/node_modules/js-yaml npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/aws-crt/node_modules/jsdom npm ERR! invalid: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc npm ERR! extraneous: jsesc@ /opt/iobroker/node_modules/aws-crt/node_modules/jsesc npm ERR! extraneous: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors npm ERR! invalid: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5 npm ERR! extraneous: json5@ /opt/iobroker/node_modules/aws-crt/node_modules/json5 npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonfile npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of npm ERR! extraneous: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur npm ERR! extraneous: lazy-cache@ /opt/iobroker/node_modules/aws-crt/node_modules/lazy-cache npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid npm ERR! extraneous: leven@ /opt/iobroker/node_modules/aws-crt/node_modules/leven npm ERR! extraneous: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns npm ERR! extraneous: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/aws-crt/node_modules/locate-path npm ERR! extraneous: lodash.memoize@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.memoize npm ERR! extraneous: lodash.pad@4.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.pad npm ERR! extraneous: lodash.padend@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padend npm ERR! extraneous: lodash.padstart@4.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/lodash.padstart npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/aws-crt/node_modules/lodash npm ERR! extraneous: lru-cache@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/lru-cache npm ERR! extraneous: lunr@2.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/lunr npm ERR! extraneous: make-dir@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir npm ERR! extraneous: make-error@1.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/make-error npm ERR! extraneous: makeerror@1.0.12 /opt/iobroker/node_modules/aws-crt/node_modules/makeerror npm ERR! extraneous: marked@4.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/marked npm ERR! extraneous: memory-stream@0.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream npm ERR! extraneous: merge-deep@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/merge-deep npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/merge-stream npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/micromatch npm ERR! extraneous: mime-db@1.52.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime-db npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/aws-crt/node_modules/mime-types npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/aws-crt/node_modules/mime npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/mimic-fn npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minimatch npm ERR! extraneous: minimist@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/minimist npm ERR! extraneous: minipass@3.3.6 /opt/iobroker/node_modules/aws-crt/node_modules/minipass npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp-classic npm ERR! extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/mkdirp npm ERR! extraneous: mqtt-packet@6.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt-packet npm ERR! extraneous: mqtt@4.3.7 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/natural-compare npm ERR! extraneous: node-int64@0.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/node-int64 npm ERR! extraneous: node-releases@2.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/node-releases npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/normalize-path npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/npm-run-path npm ERR! extraneous: npmlog@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/npmlog npm ERR! extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/aws-crt/node_modules/number-allocator npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/number-is-nan npm ERR! extraneous: nwsapi@2.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/nwsapi npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/once npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/onetime npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/os-homedir npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/aws-crt/node_modules/os-locale npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-limit npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-locate npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/p-try npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-json npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/parse-passwd npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/parse5 npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/path-exists npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-is-absolute npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/path-key npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/path-parse npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pend npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/picocolors npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/picomatch npm ERR! extraneous: pirates@4.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/pirates npm ERR! extraneous: pkg-dir@4.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pkg-dir npm ERR! extraneous: pretty-format@27.5.1 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/process-nextick-args npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/aws-crt/node_modules/process npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/progress npm ERR! extraneous: prompts@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/prompts npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/proxy-from-env npm ERR! extraneous: psl@1.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/psl npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/pump npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/punycode npm ERR! extraneous: puppeteer@3.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystring npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/querystringify npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/aws-crt/node_modules/rc npm ERR! extraneous: react-is@17.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/react-is npm ERR! invalid: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/readable-stream npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/reinterval npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/require-directory npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/requires-port npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-cwd npm ERR! extraneous: resolve-dir@0.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-dir npm ERR! extraneous: resolve-from@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/resolve-from npm ERR! extraneous: resolve.exports@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/resolve.exports npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/aws-crt/node_modules/resolve npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/rfdc npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/rimraf npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/safer-buffer npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/sax npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/saxes npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/semver npm ERR! extraneous: set-function-length@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/set-function-length npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/setimmediate npm ERR! extraneous: shallow-clone@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-command npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/shebang-regex npm ERR! extraneous: shiki@0.10.1 /opt/iobroker/node_modules/aws-crt/node_modules/shiki npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/signal-exit npm ERR! extraneous: sisteransi@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/sisteransi npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/slash npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/aws-crt/node_modules/source-map-support npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/aws-crt/node_modules/source-map npm ERR! extraneous: spawnd@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/spawnd npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/split2 npm ERR! extraneous: splitargs@0.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/splitargs npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/sprintf-js npm ERR! extraneous: stack-utils@2.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/stack-utils npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/stream-shift npm ERR! extraneous: string-length@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/string-length npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/aws-crt/node_modules/string-width npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-ansi npm ERR! extraneous: strip-bom@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-bom npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/strip-final-newline npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/strip-json-comments npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-color npm ERR! extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-hyperlinks npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/supports-preserve-symlinks-flag npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/aws-crt/node_modules/symbol-tree npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar-stream npm ERR! extraneous: tar@6.1.11 /opt/iobroker/node_modules/aws-crt/node_modules/tar npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/terminal-link npm ERR! extraneous: test-exclude@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/test-exclude npm ERR! extraneous: throat@6.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/throat npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/through npm ERR! extraneous: tmpl@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/tmpl npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/to-fast-properties npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/to-regex-range npm ERR! extraneous: tough-cookie@4.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie npm ERR! extraneous: tr46@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/tr46 npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/aws-crt/node_modules/traverse npm ERR! extraneous: tree-kill@1.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/tree-kill npm ERR! extraneous: ts-jest@27.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest npm ERR! extraneous: tslib@2.6.2 /opt/iobroker/node_modules/aws-crt/node_modules/tslib npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/type-detect npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/aws-crt/node_modules/type-fest npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray-to-buffer npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedarray npm ERR! extraneous: typedoc-plugin-merge-modules@3.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc-plugin-merge-modules npm ERR! extraneous: typedoc@0.22.18 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc npm ERR! invalid: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/aws-crt/node_modules/typescript npm ERR! extraneous: unbzip2-stream@1.4.3 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/universalify npm ERR! extraneous: unzipper@0.8.14 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper npm ERR! extraneous: update-browserslist-db@1.0.13 /opt/iobroker/node_modules/aws-crt/node_modules/update-browserslist-db npm ERR! extraneous: url-join@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/url-join npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/aws-crt/node_modules/url-parse npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/aws-crt/node_modules/url npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/util-deprecate npm ERR! extraneous: util@0.12.5 /opt/iobroker/node_modules/aws-crt/node_modules/util npm ERR! extraneous: uuid@8.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/uuid npm ERR! extraneous: v8-to-istanbul@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul npm ERR! extraneous: vscode-oniguruma@1.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-oniguruma npm ERR! extraneous: vscode-textmate@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/vscode-textmate npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-hr-time npm ERR! extraneous: w3c-xmlserializer@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/w3c-xmlserializer npm ERR! extraneous: wait-on@5.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on npm ERR! extraneous: wait-port@0.2.14 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port npm ERR! extraneous: walker@1.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/walker npm ERR! extraneous: webidl-conversions@6.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/webidl-conversions npm ERR! extraneous: whatwg-encoding@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-encoding npm ERR! extraneous: whatwg-mimetype@2.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-mimetype npm ERR! extraneous: whatwg-url@8.7.0 /opt/iobroker/node_modules/aws-crt/node_modules/whatwg-url npm ERR! extraneous: which-typed-array@1.1.13 /opt/iobroker/node_modules/aws-crt/node_modules/which-typed-array npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/which npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/window-size npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wrap-ansi npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wrappy npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/aws-crt/node_modules/write-file-atomic npm ERR! extraneous: ws@8.14.2 /opt/iobroker/node_modules/aws-crt/node_modules/ws npm ERR! extraneous: xml-name-validator@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml-name-validator npm ERR! extraneous: xml2js@0.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/xml2js npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/xmlbuilder npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/xmlchars npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/xtend npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/aws-crt/node_modules/y18n npm ERR! extraneous: yallist@3.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yallist npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/aws-crt/node_modules/yargs-parser npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/aws-crt/node_modules/yargs npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/aws-crt/node_modules/yauzl npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/enquirer/node_modules/strip-ansi npm ERR! invalid: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core npm ERR! missing: qs@^6.11.1, required by iobroker.vw-connect@0.0.67 npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.worx/node_modules/axios npm ERR! extraneous: http-cookie-agent@ /opt/iobroker/node_modules/iobroker.worx/node_modules/http-cookie-agent npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/iobroker.worx/node_modules/tough-cookie npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/iobroker.worx/node_modules/uuid npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/number-allocator/node_modules/debug npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/color-name npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/code-frame/node_modules/supports-color npm ERR! extraneous: convert-source-map@2.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/convert-source-map npm ERR! invalid: debug@2.6.9 /opt/iobroker/node_modules/debug npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/core/node_modules/semver npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/helper-compilation-targets/node_modules/semver npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/color-name npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/@babel/highlight/node_modules/supports-color npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/@httptoolkit/websocket-stream/node_modules/string_decoder npm ERR! extraneous: acorn@7.4.1 /opt/iobroker/node_modules/aws-crt/node_modules/acorn-globals/node_modules/acorn npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet/node_modules/string_decoder npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/buffer npm ERR! extraneous: uuid@8.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/aws-sdk/node_modules/uuid npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/bl/node_modules/buffer npm ERR! extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/buffer/node_modules/ieee754 npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/ansi-regex npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/axios npm ERR! extraneous: camelcase@2.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/camelcase npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/chownr npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/cliui npm ERR! extraneous: fs-minipass@1.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/fs-minipass npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/is-fullwidth-code-point npm ERR! extraneous: minipass@2.9.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minipass npm ERR! extraneous: minizlib@1.3.3 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/minizlib npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/mkdirp npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/string-width npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/strip-ansi npm ERR! extraneous: tar@4.4.19 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/tar npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/wrap-ansi npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/y18n npm ERR! extraneous: yargs@3.32.0 /opt/iobroker/node_modules/aws-crt/node_modules/cmake-js/node_modules/yargs npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/commist/node_modules/leven npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/cross-spawn/node_modules/which npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/cssstyle/node_modules/cssom npm ERR! extraneous: webidl-conversions@5.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/domexception/node_modules/webidl-conversions npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2/node_modules/string_decoder npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/readable-stream npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/safe-buffer npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/duplexify/node_modules/string_decoder npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip/node_modules/get-stream npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/mkdirp npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/fstream/node_modules/rimraf npm ERR! extraneous: semver@6.3.1 /opt/iobroker/node_modules/aws-crt/node_modules/istanbul-lib-instrument/node_modules/semver npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/cliui npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-cli/node_modules/yargs npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-snapshot/node_modules/yallist npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/aws-crt/node_modules/jest-validate/node_modules/camelcase npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/jest-worker/node_modules/supports-color npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/jsdom/node_modules/ws npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/make-dir/node_modules/yallist npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/isarray npm ERR! extraneous: readable-stream@1.0.34 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/readable-stream npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/memory-stream/node_modules/string_decoder npm ERR! invalid: arr-union@ /opt/iobroker/node_modules/aws-crt/node_modules/arr-union npm ERR! invalid: clone-deep@ /opt/iobroker/node_modules/aws-crt/node_modules/clone-deep npm ERR! invalid: kind-of@ /opt/iobroker/node_modules/aws-crt/node_modules/kind-of npm ERR! invalid: braces@ /opt/iobroker/node_modules/aws-crt/node_modules/braces npm ERR! invalid: brace-expansion@ /opt/iobroker/node_modules/aws-crt/node_modules/brace-expansion npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minipass/node_modules/yallist npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/minizlib/node_modules/yallist npm ERR! extraneous: for-in@0.1.8 /opt/iobroker/node_modules/aws-crt/node_modules/mixin-object/node_modules/for-in npm ERR! invalid: is-extendable@ /opt/iobroker/node_modules/aws-crt/node_modules/is-extendable npm ERR! invalid: bl@ /opt/iobroker/node_modules/aws-crt/node_modules/bl npm ERR! invalid: commist@ /opt/iobroker/node_modules/aws-crt/node_modules/commist npm ERR! invalid: concat-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/concat-stream npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/duplexify npm ERR! invalid: help-me@ /opt/iobroker/node_modules/aws-crt/node_modules/help-me npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/lru-cache npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/ws npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/mqtt/node_modules/yallist npm ERR! invalid: ansi@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi npm ERR! invalid: are-we-there-yet@ /opt/iobroker/node_modules/aws-crt/node_modules/are-we-there-yet npm ERR! invalid: gauge@ /opt/iobroker/node_modules/aws-crt/node_modules/gauge npm ERR! invalid: js-sdsl@ /opt/iobroker/node_modules/aws-crt/node_modules/js-sdsl npm ERR! invalid: lcid@ /opt/iobroker/node_modules/aws-crt/node_modules/lcid npm ERR! invalid: error-ex@ /opt/iobroker/node_modules/aws-crt/node_modules/error-ex npm ERR! invalid: json-parse-even-better-errors@ /opt/iobroker/node_modules/aws-crt/node_modules/json-parse-even-better-errors npm ERR! invalid: lines-and-columns@ /opt/iobroker/node_modules/aws-crt/node_modules/lines-and-columns npm ERR! invalid: ansi-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-regex npm ERR! extraneous: ansi-styles@5.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/pretty-format/node_modules/ansi-styles npm ERR! invalid: kleur@ /opt/iobroker/node_modules/aws-crt/node_modules/kleur npm ERR! invalid: end-of-stream@ /opt/iobroker/node_modules/aws-crt/node_modules/end-of-stream npm ERR! extraneous: agent-base@5.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/agent-base npm ERR! invalid: extract-zip@ /opt/iobroker/node_modules/aws-crt/node_modules/extract-zip npm ERR! extraneous: https-proxy-agent@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/https-proxy-agent npm ERR! extraneous: ws@7.5.9 /opt/iobroker/node_modules/aws-crt/node_modules/puppeteer/node_modules/ws npm ERR! invalid: deep-extend@ /opt/iobroker/node_modules/aws-crt/node_modules/deep-extend npm ERR! invalid: ini@ /opt/iobroker/node_modules/aws-crt/node_modules/ini npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/rc/node_modules/strip-json-comments npm ERR! invalid: expand-tilde@ /opt/iobroker/node_modules/aws-crt/node_modules/expand-tilde npm ERR! invalid: global-modules@ /opt/iobroker/node_modules/aws-crt/node_modules/global-modules npm ERR! invalid: is-core-module@ /opt/iobroker/node_modules/aws-crt/node_modules/is-core-module npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/aws-crt/node_modules/rxjs/node_modules/tslib npm ERR! invalid: define-data-property@ /opt/iobroker/node_modules/aws-crt/node_modules/define-data-property npm ERR! invalid: get-intrinsic@ /opt/iobroker/node_modules/aws-crt/node_modules/get-intrinsic npm ERR! invalid: gopd@ /opt/iobroker/node_modules/aws-crt/node_modules/gopd npm ERR! invalid: has-property-descriptors@ /opt/iobroker/node_modules/aws-crt/node_modules/has-property-descriptors npm ERR! extraneous: kind-of@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/kind-of npm ERR! extraneous: lazy-cache@0.2.7 /opt/iobroker/node_modules/aws-crt/node_modules/shallow-clone/node_modules/lazy-cache npm ERR! invalid: jsonc-parser@ /opt/iobroker/node_modules/aws-crt/node_modules/jsonc-parser npm ERR! invalid: buffer-from@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-from npm ERR! invalid: escape-string-regexp@ /opt/iobroker/node_modules/aws-crt/node_modules/escape-string-regexp npm ERR! invalid: char-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/char-regex npm ERR! invalid: emoji-regex@ /opt/iobroker/node_modules/aws-crt/node_modules/emoji-regex npm ERR! invalid: is-fullwidth-code-point@ /opt/iobroker/node_modules/aws-crt/node_modules/is-fullwidth-code-point npm ERR! invalid: has-flag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-flag npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/aws-crt/node_modules/tar-fs/node_modules/chownr npm ERR! invalid: fs-constants@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-constants npm ERR! invalid: chownr@ /opt/iobroker/node_modules/aws-crt/node_modules/chownr npm ERR! invalid: fs-minipass@ /opt/iobroker/node_modules/aws-crt/node_modules/fs-minipass npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/tar/node_modules/yallist npm ERR! invalid: is-number@ /opt/iobroker/node_modules/aws-crt/node_modules/is-number npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/aws-crt/node_modules/tough-cookie/node_modules/universalify npm ERR! invalid: babel-jest@ /opt/iobroker/node_modules/aws-crt/node_modules/babel-jest npm ERR! invalid: bs-logger@ /opt/iobroker/node_modules/aws-crt/node_modules/bs-logger npm ERR! invalid: jest@ /opt/iobroker/node_modules/aws-crt/node_modules/jest npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/lru-cache npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/semver npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/ts-jest/node_modules/yallist npm ERR! invalid: is-typedarray@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typedarray npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/brace-expansion npm ERR! extraneous: glob@8.1.0 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/glob npm ERR! extraneous: minimatch@5.1.6 /opt/iobroker/node_modules/aws-crt/node_modules/typedoc/node_modules/minimatch npm ERR! extraneous: buffer@5.7.1 /opt/iobroker/node_modules/aws-crt/node_modules/unbzip2-stream/node_modules/buffer npm ERR! invalid: big-integer@ /opt/iobroker/node_modules/aws-crt/node_modules/big-integer npm ERR! invalid: binary@ /opt/iobroker/node_modules/aws-crt/node_modules/binary npm ERR! extraneous: bluebird@3.4.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/bluebird npm ERR! invalid: buffer-indexof-polyfill@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-indexof-polyfill npm ERR! invalid: duplexer2@ /opt/iobroker/node_modules/aws-crt/node_modules/duplexer2 npm ERR! invalid: fstream@ /opt/iobroker/node_modules/aws-crt/node_modules/fstream npm ERR! invalid: listenercount@ /opt/iobroker/node_modules/aws-crt/node_modules/listenercount npm ERR! extraneous: process-nextick-args@1.0.7 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/process-nextick-args npm ERR! extraneous: readable-stream@2.1.5 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/readable-stream npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/aws-crt/node_modules/unzipper/node_modules/string_decoder npm ERR! invalid: escalade@ /opt/iobroker/node_modules/aws-crt/node_modules/escalade npm ERR! extraneous: punycode@1.3.2 /opt/iobroker/node_modules/aws-crt/node_modules/url/node_modules/punycode npm ERR! invalid: is-arguments@ /opt/iobroker/node_modules/aws-crt/node_modules/is-arguments npm ERR! invalid: is-generator-function@ /opt/iobroker/node_modules/aws-crt/node_modules/is-generator-function npm ERR! invalid: is-typed-array@ /opt/iobroker/node_modules/aws-crt/node_modules/is-typed-array npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/aws-crt/node_modules/v8-to-istanbul/node_modules/source-map npm ERR! invalid: browser-process-hrtime@ /opt/iobroker/node_modules/aws-crt/node_modules/browser-process-hrtime npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/aws-crt/node_modules/wait-on/node_modules/axios npm ERR! invalid: joi@ /opt/iobroker/node_modules/aws-crt/node_modules/joi npm ERR! extraneous: ansi-styles@3.2.1 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/ansi-styles npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/chalk npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-convert npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/color-name npm ERR! extraneous: commander@3.0.2 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/commander npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/escape-string-regexp npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/has-flag npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/aws-crt/node_modules/wait-port/node_modules/supports-color npm ERR! invalid: iconv-lite@ /opt/iobroker/node_modules/aws-crt/node_modules/iconv-lite npm ERR! invalid: available-typed-arrays@ /opt/iobroker/node_modules/aws-crt/node_modules/available-typed-arrays npm ERR! invalid: call-bind@ /opt/iobroker/node_modules/aws-crt/node_modules/call-bind npm ERR! invalid: for-each@ /opt/iobroker/node_modules/aws-crt/node_modules/for-each npm ERR! invalid: has-tostringtag@ /opt/iobroker/node_modules/aws-crt/node_modules/has-tostringtag npm ERR! invalid: isexe@ /opt/iobroker/node_modules/aws-crt/node_modules/isexe npm ERR! invalid: ansi-styles@ /opt/iobroker/node_modules/aws-crt/node_modules/ansi-styles npm ERR! invalid: imurmurhash@ /opt/iobroker/node_modules/aws-crt/node_modules/imurmurhash npm ERR! invalid: cliui@ /opt/iobroker/node_modules/aws-crt/node_modules/cliui npm ERR! invalid: get-caller-file@ /opt/iobroker/node_modules/aws-crt/node_modules/get-caller-file npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/aws-crt/node_modules/yargs/node_modules/yargs-parser npm ERR! invalid: buffer-crc32@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-crc32 npm ERR! invalid: fd-slicer@ /opt/iobroker/node_modules/aws-crt/node_modules/fd-slicer npm ERR! invalid: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms npm ERR! invalid: core-util-is@ /opt/iobroker/node_modules/aws-crt/node_modules/core-util-is npm ERR! invalid: isarray@ /opt/iobroker/node_modules/aws-crt/node_modules/isarray npm ERR! invalid: base64-js@ /opt/iobroker/node_modules/aws-crt/node_modules/base64-js npm ERR! invalid: ieee754@ /opt/iobroker/node_modules/aws-crt/node_modules/ieee754 npm ERR! invalid: follow-redirects@ /opt/iobroker/node_modules/aws-crt/node_modules/follow-redirects npm ERR! invalid: code-point-at@ /opt/iobroker/node_modules/aws-crt/node_modules/code-point-at npm ERR! invalid: decamelize@ /opt/iobroker/node_modules/aws-crt/node_modules/decamelize npm ERR! invalid: is-buffer@ /opt/iobroker/node_modules/aws-crt/node_modules/is-buffer npm ERR! invalid: balanced-match@ /opt/iobroker/node_modules/aws-crt/node_modules/balanced-match npm ERR! invalid: fs.realpath@ /opt/iobroker/node_modules/aws-crt/node_modules/fs.realpath npm ERR! invalid: inflight@ /opt/iobroker/node_modules/aws-crt/node_modules/inflight npm ERR! invalid: buffer-shims@ /opt/iobroker/node_modules/aws-crt/node_modules/buffer-shims npm ERR! missing: qs@^6.7.0, required by googleapis-common@7.0.0 npm ERR! missing: ws@^7.5.0, required by mqtt@4.2.8 npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-22T18_38_48_336Z-debug-0.log *** ioBroker-Installation *** ioBroker Status [/s]@tolkin sagte in Ältere ioBroker Instanz updaten?:
Nein habe ich noch nicht, werde ich die Tage mal machen.
Dann schau ich mir das dann die Tage an.
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
Neuinstallation als 64bit-Lite-Version.
Alles klar, hast du ein Link für das Image -
@homoran sagte in Ältere ioBroker Instanz updaten?:
und backup zurückspielen
Wenn überhaupt vorhanden?!
Habe ich in den bisherigen Infos nicht gesehen!iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
*Wer freundlich ist, dem wird freundlich geholfen *
Heute habe ich ein neues Image Debian 12 geflasht und ioBroker nach Anleitung installiert. Zum Schluss wieder das letzte Backup eingespielt. Jetzt komme ich zwar per Putty drauf aber die Weboberfläsche läuft nicht. Kann mir jemand helfen und sagen, wie ich die Weboberfläsche wieder ans laufen bekomme?
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi4-rpi-v8 Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 21:37:29 up 15 min, 2 users, load average: 0.04, 0.22, 0.19 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2023-10-24 21:37:30 CEST Universal time: Tue 2023-10-24 19:37:30 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 268M 7.5G 1.2M 565M 7.9G Swap: 104M 0B 104M Total: 8.3G 268M 7.6G 7811 M total memory 256 M used memory 220 M active memory 343 M inactive memory 7138 M free memory 30 M buffer memory 509 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 782M 1.1M 781M 1% /run /dev/mmcblk0p2 ext4 59G 2.7G 53G 5% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 61M 450M 12% /boot/firmware tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Oct 24 21:22:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c509a9ba-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Oct 24 21:22:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Tue Oct 24 21:22:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 492M /var/ 201M /var/cache 195M /var/cache/apt 159M /var/lib 130M /var/lib/apt/lists Archived and active journals take up 32.0M in the file system. /opt/iobroker/backups: 5.0M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 19M /opt/iobroker/iobroker-data/ 15M /opt/iobroker/iobroker-data/files 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static 13M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 3.8M /opt/iobroker/iobroker-data/objects.jsonl 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js 1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map 652K /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status No connection to states 127.0.0.1:6379[redis] Core adapters versions js-controller: 5.0.12 admin: "admin" not found javascript: "javascript" not found Adapters from github: 0 Adapter State No connection to states 127.0.0.1:6379[redis] Enabled adapters with bindings ioBroker-Repositories No connection to states 127.0.0.1:6379[redis] Installed ioBroker-Instances No connection to states 127.0.0.1:6379[redis] Objects and States Please stand by - This may take a while Objects: 1 States: 1 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 29953 4445/iobroker.js-co tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 3990 681/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 3992 681/sshd: /usr/sbin udp 0 0 0.0.0.0:50025 0.0.0.0:* 104 13702 531/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 13700 531/avahi-daemon: r udp6 0 0 :::47411 :::* 104 13703 531/avahi-daemon: r udp6 0 0 fe80::573c:9b67:23c:546 :::* 0 16494 601/NetworkManager udp6 0 0 :::5353 :::* 104 13701 531/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-10-24 21:36:54.637 - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d 2023-10-24 21:37:24.657 - error: host.raspberrypi No connection to databases possible, restart 2023-10-24 21:37:24.673 - info: host.raspberrypi iobroker _restart 2023-10-24 21:37:30.540 - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting 2023-10-24 21:37:30.546 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-10-24 21:37:30.548 - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2 2023-10-24 21:37:30.550 - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d 2023-10-24 21:38:00.571 - error: host.raspberrypi No connection to databases possible, restart 2023-10-24 21:38:00.578 - info: host.raspberrypi iobroker _restart 2023-10-24 21:38:06.332 - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting 2023-10-24 21:38:06.337 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-10-24 21:38:06.338 - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2 2023-10-24 21:38:06.340 - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d 2023-10-24 21:38:36.359 - error: host.raspberrypi No connection to databases possible, restart 2023-10-24 21:38:36.366 - info: host.raspberrypi iobroker _restart 2023-10-24 21:38:42.122 - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting 2023-10-24 21:38:42.128 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-10-24 21:38:42.129 - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2 2023-10-24 21:38:42.130 - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d 2023-10-24 21:39:12.149 - error: host.raspberrypi No connection to databases possible, restart 2023-10-24 21:39:12.166 - info: host.raspberrypi iobroker _restart 2023-10-24 21:39:18.223 - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting 2023-10-24 21:39:18.230 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker 2023-10-24 21:39:18.232 - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2 2023-10-24 21:39:18.234 - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d============ Mark until here for C&P =============
War das ein redis-Setup? Dann muss redis noch nachinstalliert werden.
sudo apt install redis
