  4. Wert aus Modbus lesen und bei änderung größer als…..auf KNX Objekt senden
61 Beiträge 4 Kommentatoren 11.8k Aufrufe 1 Beobachtet
    alexmosel
    …ok habe auch gerade die Fehlermeldung dazu im LOG gesehen..
    knx.0 2017-11-10 08:58:58.405 error at module.exports.machina.Fsm.extend.states.sendTunnReq._onEnter (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\FSM.js:236:14)
    knx.0 2017-11-10 08:58:58.405 error at FSM.send (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\Connection.js:172:28)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.(anonymous function) [as KNXNetHeader] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:594:35)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.(anonymous function) [as CEMI] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:501:8)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.(anonymous function) [as APDU] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:415:14)
    knx.0 2017-11-10 08:58:58.405 error at CustomProtocolWriter.ProtocolWriter$raw [as raw] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:74:24)
    knx.0 2017-11-10 08:58:58.405 error at Function.Buffer.concat (buffer.js:290:9)
    knx.0 2017-11-10 08:58:58.405 error TypeError: buf.copy is not a function
    knx.0 2017-11-10 08:58:58.405 error message knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung [object Object] buf.copy is not a function
    • paul53P Offline
      Die Anzeige soll auf dem KNX-Display erfolgen ? Dann soll sicherlich wieder eine Mittelwertbildung erfolgen.
      const idEinspeis = 'modbus.0.inputRegisters.30867_Netz-Einspeisung';
      const idBezug = 'modbus.0.inputRegisters.30865_Netz-Bezug';
      const idAnz = 'knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung';  // Anzeige-DP
      const werte = 10;  // Anzahl der Messwerte für Mittelwertbildung
      var cnt = 0;  // Zähler
      var sum = 0;  // Summe der Messwerte
      function knxText(text) {
          var txt = text;
          for(var i = 0; i < 14 - text.length; i++) {
              txt = txt + String.fromCharCode(0);
          setState(idAnz, txt);
      function anzeige(dir, val) {
          cnt++;
          sum = sum + val;
          if(cnt >= werte) {
              var power = sum / cnt;
              knxText(dir + power.toFixed() + ' W');
              cnt = 0;
              sum = 0;
      on({id: idEinspeis, valGt: 0}, function(dp) {
         if(dp.oldState.val === 0) {
            cnt = 0;
            sum = 0;
         anzeige('Einsp ', dp.state.val)
      on({id: idBezug, valGt: 0}, function(dp) {
            cnt = 0;
            sum = 0;
         anzeige('Bezug ', dp.state.val)
      Passt so der Text in die Displayzeile ohne zu scrollen ?
      • paul53P Offline
        Anmerkung: Du hast 2 unterschiedliche Funktionen mit identischem Namen (anzeige()) deklariert !!
        Habe es gerade mal getestet: Der Parser meckert (leider) nicht. Es wird die zuletzt deklarierte Funktion aufgerufen.
          alexmosel
          Habe das Script so getestet, es soll der Mittelwert gebildet werden, jedoch kommt am Bus garnix mehr an…
          Das Scrollende Display benutze ich im moment nicht dafür, da das Blöd von der Darstellung war, aber ich zeige es auf dem Display eines anderen Tasters an...
          Beim Starten des Scriptes stzeht im Log von IObroker und kein Script funktioniert mehr bis zum neustart des adapters
          ` > knx.0 2017-11-10 15:47:40.781 error at module.exports.machina.Fsm.extend.states.sendTunnReq._onEnter (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\FSM.js:236:14)
          knx.0 2017-11-10 15:47:40.781 error at FSM.send (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\Connection.js:172:28)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.(anonymous function) [as KNXNetHeader] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:594:35)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.(anonymous function) [as CEMI] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:501:8)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.(anonymous function) [as APDU] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:20:18)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.KnxProtocol.define.write (C:\ioBroker\node_modules\iobroker.knx\lib\knx-mod\src\KnxProtocol.js:415:14)
          knx.0 2017-11-10 15:47:40.781 error at CustomProtocolWriter.ProtocolWriter$raw [as raw] (C:\ioBroker\node_modules\iobroker.knx\node_modules\binary-protocol\lib\writer.js:74:24)
          knx.0 2017-11-10 15:47:40.781 error at Function.Buffer.concat (buffer.js:290:9)
          knx.0 2017-11-10 15:47:40.781 error TypeError: buf.copy is not a function
          knx.0 2017-11-10 15:47:40.779 error message knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung [object Object] buf.copy is not a function `
          • paul53P Offline
            Das wird wohl am Datenpunkt liegen. Poste bitte die Eigenschaften (raw) des Datenpunktes 'knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung'. Um zu sehen, ob das Skript ohne den Datenpunkt funktioniert, ersetze zum Testen in der Funktion knxText()
                // setState(idAnz, txt);
                log(txt.length + ' ' + txt);
              alexmosel
              …binmir nicht sicher wo ich das ersetzen soll...
              hier das raw
                "common": {
                  "name": "",
                  "type": "number",
                  "role": "value",
                  "unit": "W",
                  "def": 0,
                  "read": true,
                  "write": false
                "native": {
                  "regType": "inputRegs",
                  "type": "int32be",
                  "address": 30865,
                  "len": 2,
                  "offset": 0,
                  "factor": 1
                "acl": {
                  "object": 1638,
                  "owner": "system.user.admin",
                  "state": 1638
                "_id": "modbus.0.inputRegisters.30865_Netz-Bezug",
                "type": "state"
                alexmosel
                Scheint wirklich am Datenpunkt zu liegen, der sollte eigentlich genau so sein wie der andere…
                hier raw vom Datenpunkt Bezug/Einspeisung
                "_id": "knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung",
                "type": "state",
                "common": {
                "name": "PV_Bezug_oder_Einspeisung",
                "type": "string",
                "role": "text.string",
                "min": null,
                "max": null,
                "read": false,
                "write": true
                "native": {
                "dpt": "",
                "address": "0/7/1",
                "addressRefId": "P-057F-0_GA-386",
                "statusGARefId": "",
                "actGARefId": ""
                "acl": {
                "object": 1638,
                "state": 1638
                und hier von dem PV , der funktioniert…
                "_id": "knx.0.Zentralbefehle_u_Visu.Visualisierung.Aktuelle_PV_Leistung",
                "type": "state",
                "common": {
                "name": "Aktuelle_PV_Leistung",
                "type": "string",
                "read": false,
                "write": true,
                "min": "",
                "max": ""
                "native": {
                "dpt": "DPT16.000",
                "address": "0/7/0",
                "addressRefId": "P-057F-0_GA-385",
                "actGARefId": ""
                "acl": {
                "object": 1638,
                "state": 1638
                • paul53P Offline
                  Der DP "knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung" sieht soweit o.k. aus, außer dass native.dpt leer ist.
                  Ich würde
                  __"min": null,
                  "max": null,__
                  löschen, denn die machen bei einem String keinen Sinn.
                  EDIT: Die Werte null für "min" und "max" deuten darauf hin, dass die KNX-Quelle kein String ist, sondern ein Objekt; ebenfalls die unterste (1.) Fehlermeldung. Da hast Du wohl einen falschen Datenpunkt für die Anzeige gewählt ?
                    alexmosel
                    Moin,
                    scheint jetzt tatsächlich zu funktionieren…
                    Aus mir nicht verständlichen Gründen wurde das Objekt vollkommen falsch importiert und ließ sich auch nicht wirklich ändern.
                    Habe es dann gelöscht und neu importiert, das liess sich dann auch ändern... nach Neustart des Adapters scheint es zu laufen...ich beobachte noch
                    Vielen Vielen Dank erstmal
                      alexmosel
                      Gerade gesehen,
                      bei Nacht, also wenn der Wechselrichter abgeschaltet hat, gibt er als PV -Erzeugungswert -2147483648 W aus…
                      Kommt das Script damit auch klar ? Aktuell steht noch die 0 W Meldung da, aber wird auch nicht mehr aktualisiert...
                      • paul53P Offline
                        @alexmosel:
                        Kommt das Script damit auch klar ? Aktuell steht noch die 0 W Meldung da, aber wird auch nicht mehr aktualisiert... `
                        Um sicher zu gehen, dass es auch bei Sonnenaufgang funktioniert, ändere
                           if(dp.state.val === 0) {
                        in
                           if(dp.state.val <= 0) {
                        • C Offline
                          chibitz
                          Moin,
                          ist zwar schon 1,5 Jahre alt, aber mich würde deine aktuelle Konfiguration interessieren. Ich hätte auch gerne die Werte meiner 3 SMA-WR (über Modbus) auf dem KNX-Bus..
                          Wie sieht dein aktuelles Skript aus? Muss doch auch irgendwie mit Blockly gehen...
                            alexmosel
                            Hallo, lange Zeit liefen meine Scripte jetzt völlig problemlos. Jetzt möchte ich gerne den Windows-Rechner der doch recht viel Energie verbraucht gegen einen Raspberry austauschen, habe dort IO Broker am laufen, alles eingerichtet.
                            Er zeigt mir bei den Objekten im KNX beim passenden Objekt auch die Werte aus Modbus an, also funktionieren die 2 Scripte noch.
                            Problem ist, er sendets nicht auf den KNX Bus, folgender Fehler steht im LOG
                            nx.0	2019-09-01 19:35:00.656	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            knx.0	2019-09-01 19:35:00.656	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                            knx.0	2019-09-01 19:35:00.656	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            knx.0	2019-09-01 19:35:00.656	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            knx.0	2019-09-01 19:35:00.656	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                            knx.0	2019-09-01 19:35:00.656	error	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                            knx.0	2019-09-01 19:35:00.656	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            knx.0	2019-09-01 19:35:00.656	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                            knx.0	2019-09-01 19:35:00.656	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                            knx.0	2019-09-01 19:35:00.656	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:79:2901)
                            knx.0	2019-09-01 19:35:00.656	error	TypeError: Cannot read property 'write' of undefined
                            knx.0	2019-09-01 19:35:00.654	error	message knx.0.Zentralbefehle_u_Visu.Visualisierung.PV_Bezug_oder_Einspeisung [object Object] Cannot read property 'write' of undefined
                            Verstehen tue ich das nicht wirklich.....kann mir jemand helfen ?
                            Besten Dank
                              alexmosel
                              Problem scheint gelöst, habe ältere Adapterversion installiert und die Struktur aus der vorherigen Installation kopiert damit gings....
