  3. Off Topic
  4. InfluxDB
  5. partieller Datenverlust InfluxDB?
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
26 Beiträge 6 Kommentatoren 3.4k Aufrufe 5 Beobachtet
  • I IOJoker
    Hi Bernd, vielen Dank für die Antwort. Ich versuche etwas weniger Text und mehr Substanz hinzuzufügen.
    Fangen wir mal hiermit an:
    @dp20eic said in partieller Datenverlust InfluxDB?:
    Zeig mal die lange Fassung von
    # iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: unger-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     16:59:03 up 12:53,  1 user,  load average: 1.22, 1.01, 0.85
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-22 16:59:03 CEST
               Universal time: Sun 2023-10-22 14:59:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    unger
    /home/unger
    unger adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           7.9G        1.3G        2.0G        379M        4.6G        6.4G
    Swap:           99M          0B         99M
    Total:         8.0G        1.3G        2.1G
             7897 M total memory
             1342 M used memory
              922 M active memory
             4763 M inactive memory
             1980 M free memory
              278 M buffer memory
             4296 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * openplc.service       loaded failed failed OpenPLC Service
    2 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4      917G   27G  853G   4% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G  3.7M  3.9G   1% /dev/shm
    tmpfs          tmpfs     3.9G  372M  3.5G  10% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1001
    [Sun Oct 22 04:05:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x720M@60D smsc95xx.macaddr=E4:5F:01:25:03:02 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=eb45b446-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Oct 22 04:05:22 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Oct 22 04:05:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Oct 22 04:05:25 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    13G     /var/
    5.2G    /var/cache/apt/archives
    5.2G    /var/cache/apt
    5.2G    /var/cache
    4.3G    /var/log
    Archived and active journals take up 369.5M in the file system.
    /opt/iobroker/backups:
    67M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    260M    /opt/iobroker/iobroker-data/
    142M    /opt/iobroker/iobroker-data/files
    82M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_9c6ff58c7ebfeb119605fc3965476099-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : unger-pi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : unger-pi                                 -  enabled
    + system.adapter.email.0                  : email                 : unger-pi                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : unger-pi                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : unger-pi                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : unger-pi                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : unger-pi                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : unger-pi                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : unger-pi                                 -  enabled
    + system.adapter.modbus.2                 : modbus                : unger-pi                                 -  enabled
    + system.adapter.psa.0                    : psa                   : unger-pi                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : unger-pi                                 -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : unger-pi                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : unger-pi                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : unger-pi                                 -  enabled
      system.adapter.vis.0                    : vis                   : unger-pi                                 -  enabled
    + system.adapter.web.0                    : web                   : unger-pi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "psa"          : 0.0.11   , installed 0.0.11
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        1570
    States:         1404
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://repos.influxdata.com/debian buster InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/raspbian buster InRelease [5123 B]
    Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
    Fetched 5123 B in 2s (2828 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          17180      712/lighttpd
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19434      634/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18135      612/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15972      399/cupsd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        18696      597/influxd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22679      985/smbd
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        19440      634/pihole-FTL
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       22119      1043/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       22112      1043/iobroker.js-co
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      116        17285      751/mysqld
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22680      985/smbd
    tcp6       0      0 :::80                   :::*                    LISTEN      0          17181      712/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       21326      1077/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       25227      1570/io.web.0
    tcp6       0      0 :::53                   :::*                    LISTEN      999        19436      634/pihole-FTL
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        21085      597/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18137      612/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15971      399/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        22357      1042/grafana
    tcp6       0      0 :::445                  :::*                    LISTEN      0          22677      985/smbd
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        19441      634/pihole-FTL
    tcp6       0      0 :::139                  :::*                    LISTEN      0          22678      985/smbd
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19433      634/pihole-FTL
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           999        19430      634/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20704      445/dhcpcd
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          17155      -
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16061      518/cups-browsed
    udp        0      0 10.2.28.255:137         0.0.0.0:*                           0          21059      594/nmbd
    udp        0      0 10.2.28.20:137          0.0.0.0:*                           0          21058      594/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18419      594/nmbd
    udp        0      0 10.2.28.255:138         0.0.0.0:*                           0          21061      594/nmbd
    udp        0      0 10.2.28.20:138          0.0.0.0:*                           0          21060      594/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18420      594/nmbd
    udp        0      0 0.0.0.0:46222           0.0.0.0:*                           108        17436      403/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17434      403/avahi-daemon: r
    udp6       0      0 :::59834                :::*                                108        17437      403/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          20808      445/dhcpcd
    udp6       0      0 :::53                   :::*                                999        19435      634/pihole-FTL
    udp6       0      0 :::51820                :::*                                0          17156      -
    udp6       0      0 :::5353                 :::*                                108        17435      403/avahi-daemon: r
    2023-10-22 15:25:51.527  - error: javascript.0 (1308) Request error: Error: read ECONNRESET
    2023-10-22 15:25:53.195  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:25:53.195  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:25:59.219  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:25:59.221  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:04.237  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:04.238  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:07.644  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:07.645  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:11.201  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:11.202  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:16.147  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: read ECONNRESET
    2023-10-22 15:26:16.148  - error: javascript.0 (1308) Request error: Error: read ECONNRESET
    2023-10-22 15:26:23.146  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:23.146  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:25.369  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:25.369  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:26:34.855  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: read ECONNRESET
    2023-10-22 15:26:34.856  - error: javascript.0 (1308) Request error: Error: read ECONNRESET
    2023-10-22 15:26:59.352  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=amp,psm,frc,nrg,modelStatus,err: Error: socket hang up
    2023-10-22 15:26:59.353  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:27:01.168  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-SET amp=13: Error: socket hang up
    2023-10-22 15:27:01.169  - error: javascript.0 (1308) Request error: Error: socket hang up
    2023-10-22 15:27:11.157  - error: javascript.0 (1308) script.js.Energie.Ladestation: Fehler bei http-request mit filter=wh,eto,car,rssi,tma: Error: socket hang up
    2023-10-22 15:27:11.157  - error: javascript.0 (1308) Request error: Error: socket hang up
    @iojoker sagte in partieller Datenverlust InfluxDB?:
    Moin,
    machen wir mal damit weiter :)
    Dass Du mit angestaubten Softwareständen unterwegs bist, haben @Thomas-Braun und ich ja schon gesagt.
    Jetzt mal schauen, ob Du noch Logs aus dem Zeitraum hast, ein denen die Daten verloren gegangen sind!
    Bernd
    P.S.: Ein weiterer Punkt, warum Daten fehlen können, ist ein erhöhter Load, wenn die Kiste nur noch mit Fehlermeldung schreiben zu tun hat, z. B.
    I 1 Antwort Letzte Antwort
      Moin,
      Bernd
      I Offline
      I Offline
      IOJoker
      Ja gut, würde ich prinzipiell versuchen, auch wenn ich es bisher noch nicht gemacht habe und großen Respekt davor habe...
      Wie hoch ist das Risiko eines Updates von buster und node? Sollte ich die Updates erst machen, bevor wir hier fortsetzen?
      Es sieht so aus, dass ich kein persistentes Journal eingerichtet habe. :man-bowing:
      -- Logs begin at Sun 2023-10-22 11:21:25 CEST, end at Sun 2023-10-22 17:56:17 CEST. --
      Selbst, wenn es so wäre, liegen die Datenlücken teilweise sehr weit in der Vergangenheit. Die letzte Datenlücke endet am Fr., den 13.10.23.
      Hierbei bitte bedenken, dass bereits vorhandene Daten verloren gegangen sind. Das habe ich beim Vergleich zwischen den Daten von vorgestern und heute eigentlich bewiesen. Ich glaube nicht, dass es ein Problem des Schreibens in die Datenbank ist. Vielmehr gehen Daten verloren, ich vermute beim Reboot.
      Danke für eure Hilfe in der Sache! Ich weiß das sehr zu schätzen.
      Thomas BraunT ? 2 Antworten Letzte Antwort
      • I IOJoker
        Je länger du das schleifen lässt desto komplizierter wird das.
        Ich würde hier aber gleich ein komplette Neuinstallation von Debian12 'Bookworm' vorsehen, diesmal als 64bit-Version 'Lite'.
        • I IOJoker
          Moin,
          @Thomas-Braun hat da ja schon einen guten Einwand gegeben, ich möchte das nur noch insoweit ergänzen, je höher der Linux Skill ist, umso leichter fällt es Dir, Updates über mehrere Releases zu machen. Somit kann ich das von @Thomas-Braun gesagte, nur unterstützen, sauberes Backup dann neu aufsetzen.
          Wenn die Datenlücken, mit den in Deiner Erinnerung befindlichen Reboots zusammenpassen, dann ist die Frage, warum gab es die Reboots, vielleicht weil Deine Kiste mit sich selbst beschäftigt war?
          Ein Reboot sollte ja in wenigen Minuten durch sein und nicht Tage dauern :)
          Bernd
            Moin,
            Bernd
            I Offline
            I Offline
            IOJoker
            Ich befürchte, hier liegt eines der größten Probleme. Mein Skill-Level würde ich selbst nicht so hoch einschätzen. Erschwerend kommt hinzu, dass ich bereits beim Einrichten des raspi (wahrscheinlich?) eine Fehlentscheidung getroffen habe, die mir jetzt auf die Füße fällt. Ich habe das Betriebssystem auf eine 1TB große SSD aufgespielt und nicht auf eine SD-Karte. Es ist mir momentan überhaupt nicht möglich, ein komplettes Systembackup zu erstellen, weil ich keine freie SSD mit dieser Reserve habe. So habe ich es zumindest verstanden. Das ist ein anderes Thema, um das ich mich noch kümmern wollte. Jedenfalls muss ich das Risiko im Blick behalten, weil der raspi mittlerweile wichtige Aufgaben im Haushalt übernimmt.
            Nein, die Datenlücken passen zeitlich überhaupt nicht mit den Reboots zusammen. Den Grund für die Reboots habe ich in dem vielen Text im ersten Post geschildert. 😬
            • I IOJoker
              Kannst du eh nichts mit anfangen, weil eine 64bit-Installation komplett von Null an vorgenommen werden muss.
              • I IOJoker
                Moin,
                meine Schwäche sind die RasPIs, ich kann da nicht immer mit Gewissheit sagen, ob sich die so verhalten, wie die großen Brüder der PC.
                Aber wenn es möglich ist, dann würde ich der SSD eine neue Partition verpassen, dann darauf das neue System installieren und grub von der ersten Installation so anpassen, dass es von der neuen startet.
                Wenn alles gut ist, dann kann man die alte Partition löschen und den Speicher, der neuen Installation zuschieben.
                Na, dann habe ich ja vielleicht mit meiner Annahme doch recht, dass Du die Daten verlierst, verloren hast, weil die Kiste mit sich selbst beschäftigt ist, aber ohne aussagekräftige Logs, sind es halt nur Annahmen, Vermutungen.
                Bernd
                Thomas BraunT I 2 Antworten Letzte Antwort
                  Moin,
                  Bernd
                  @dp20eic sagte in partieller Datenverlust InfluxDB?:
                  Nein, nicht so. Raspberry nutzen keinen grub.
                  Da wird in der cat /boot/cmdline.txt das Dateisystem gemountet (und noch anderes Zeug getrieben, das ich aber auch nicht auf dem Schirm habe).
                    @thomas-braun sagte in partieller Datenverlust InfluxDB?:
                    Moin,
                    ja, jetzt wo Du das erwähnst, da war was, genau.
                    Dann muss ich mal weiter meine Fantasie bemühen, aber da ich keine passende Hardware habe, kann ich da nichts probieren, sorry.
                    Bernd
                    P.S.: Sollte doch gehen, wenn ich mir die Dokumentation -> https://www.raspberrypi.com/documentation/computers/config_txt.html anschaue
                    [all]
                    tryboot_a_b=1
                    boot_partition=2
                    [tryboot]
                    boot_partition=3
                      Moin,
                      Bernd
                      I Offline
                      I Offline
                      IOJoker
                      Also als ersten Schritt habe ich das journal jetzt auf persistant gestellt (hoffentlich erfolgreich). Zweitens habe ich den geplanten Reboot deaktiviert. Ich lasse das System jetzt mal eine Zeit durchlaufen und kontrolliere regelmäßig die Datenbank auf neue Lücken. Ich kann mir nicht vorstellen, dass ich Daten verliere, weil die Kiste mit sich selbst beschäftigt ist.
                      Dann werde ich versuchen, tiefer in die Influx-Community einzutauchen. Ich habe immernoch die Hoffnung, dass die Daten garnicht verloren sind, sondern möglicherweise nur nicht gefunden werden.
                      Mittelfristig werde ich das Gesamtkonzept auf den Prüfstand stellen. Ich würde schon gern eine Lösung haben, wo ich vom kompletten System ein Backup machen kann. Ich hoffe, dass ich die jetzige Partition teilen und die große Datenbank auf eine andere Partition verschieben kann. Die Systempartition sollte dann klein genug sein, dass ein Backup möglich sein sollte. Partitionieren habe ich jedoch bisher nur in der Windows-Welt gemacht und auch noch nicht oft.
                      Ich melde mich, wenn es neue Erkenntnisse gibt.
                      Vielen Dank bis hierhin! 🤝
                      • Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        Vielleicht kann mir ja jemand bei der Beantwortung meiner Fragen helfen.
                        Ähnliche Probleme kannst du auf github in den InfluxDB Issues einige finden. Die Ursache scheint hier im begrenzten adressierbaren Speicherbereich auf 32bit Systemen zu liegen.
                        InfluxDB führt regelmäßig "compaction" Jobs durch, in diesen Jobs werden die Datenbankfiles optimiert und neu geschrieben. Wenn es dann zu einem Speicherproblem kommt, gehen Daten verloren. Sehr gut passt dazu, dass meist ganze Wochen fehlen. Diese Fehler findet man dann aber in den Logs (wenn man welche hat).
                        Bin mir ziemlich sicher, dass sich dein Problem mit einem 64bit OS in Luft auflöst.
                        Edit: habe gerade gesehen, dass du auch "naturfreund" angefragt hast, da er ähnliche Probleme hatte. Auch er hat(te) übrigens ein 32bit System.
                        Marc BergM I 2 Antworten Letzte Antwort
                        • Marc BergM Marc Berg
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          doppelt, gelöscht
                            I Offline
                            I Offline
                            IOJoker
                            @marc-berg said in partieller Datenverlust InfluxDB?:
                            Puh, das ist ja ein ganz schöner Hammer. 2,8GB groß ist die Datenbank auf der SSD. Also sind die Daten wirklich unwiederbringlich verloren. 😥
                            Ich werde schnellstmöglich das BS neu aufsetzen. Zunächst kaufe ich mir einen zweiten kleinen raspi, auf den ich Pi-hole auslagern werde. Wireguard wollte ich schon länger auf die Fritzbox bringen. Dann kann ich mich voll und ganz auf den ioBroker / InfluxDB / Grafana auf dem Hauptsystem kümmern. Mir geht schon ein Bisschen die Düse. 😨
                            Trotzdem Danke für die wichtige Info!
                            • I IOJoker
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Wenn du noch ein paar ältere Backups rumliegen hättest, könnte man da sicher etwas wiederholen.
                              Wenn...
                                Wenn...
                                I Offline
                                I Offline
                                IOJoker
                                Nein, leider nicht. Der Datenverlust ist zwar ärgerlich, jedoch kein Weltuntergang. Die wichtigsten Werte für die Photovoltaikanlage habe ich zum Monatsübergang auch immer in eine Excel-Datei gesichert. Mund abwischen und weitermachen. Wichtiger ist, dass der ioBroker zuverlässig läuft. Ich muss jetzt zusehen, dass ich die Neuinstallation gut vorbereite, damit ich das alles hinbekomme. Ist jetzt schließlich auch schon wieder eine Weile her, dass ich das gemacht habe.
                                • I IOJoker
                                  I Offline
                                  I Offline
                                  IOJoker
                                  schrieb am zuletzt editiert von IOJoker
                                  So, ich habe jetzt am Wochenende einiges an Zeit damit verbracht, den Raspi mit dem neuesten Raspberry Pi OS light in 64bit aufzusetzen und es hat weitestgehend gut funktioniert. Ich bin mit den Adaptern jetzt wieder auf dem gleichen Stand wie vorher und werde gespannt beobachten, ob es weiterhin zu dieser Art von Datenverlust kommt. Ich hoffe, der Aufwand hat sich gelohnt. 🙏
                                  H 1 Antwort Letzte Antwort
                                  • I IOJoker
                                    Hans_M
                                    @IOJoker
                                    Hallo, habe das selbe Problem.
                                    Hat das Upgrade auf 64-bit das Problem gelöst?
                                    • H Hans_M
                                      @IOJoker
                                      @hans_m
                                      Ganz unabhängig vom konkreten 'Problem' fährt man 2025 ohnehin besser auf einem reinen 64Bit-System.
                                      Also in Kürze man neuinstallieren.
                                      • H Hans_M
                                        @IOJoker
                                        I Offline
                                        I Offline
                                        IOJoker
                                        @hans_m said in partieller Datenverlust InfluxDB?:
                                        @IOJoker
                                        Das hier konkret besprochene Problem mit Datenverlust von bereits gespeicherten Daten habe ich seit der Neuinstallation nicht mehr beobachtet.
                                        Allerdings habe ich jetzt das Problem, dass einige Datenpunkte nach einiger Zeit plötzlich nicht mehr in die Datenbank geschrieben werden. Beim Neustart des influxdb Adapters läuft es einige Zeit, dann fehlen plötzlich die Daten einiger Datenpunkte (nicht alle). Müsste ich mich auch mal mit beschäftigen...
                                        Ro75R 1 Antwort Letzte Antwort
                                        • I IOJoker
                                          @IOJoker
                                          Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          @iojoker Hi, Fehler im Log? SSD oder SD-Card? Freier Speicher, RAM?
                                          ein
                                          iob diag
                                          wäre toll.
                                          Ro75.
