  4. Iobroker Absturz - Ursache?
    5.1k
56 Beiträge 6 Kommentatoren 5.9k Aufrufe 4 Beobachtet
  • B brokeling
    nodejs müsste upgedated sein...
    an den ports bin ich gerade dran.
    Gibt es ein Auflistung welche ports in Benutzung sind?
    Ich würde shelly ändern.
    Kann ich sie beliebig ändern?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     20:42:26 up  1:35,  1 user,  load average: 0.58, 1.87, 2.04
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-20 20:42:26 CEST
               Universal time: Fri 2023-10-20 18:42:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.4G        817M        0.0K        1.5G        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.4G        917M
             3786 M total memory
             1421 M used memory
              514 M active memory
             2301 M inactive memory
              817 M free memory
              435 M buffer memory
             1112 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   19G   92G  17% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     758M  868K  757M   1% /run
    /dev/sdb1      ext4      113G   79G   29G  74% /backup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     379M   16K  379M   1% /run/user/1000
    [Fri Oct 20 19:07:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Oct 20 19:07:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 20 19:07:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Oct 20 19:07:29 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Fri Oct 20 19:07:31 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 9962198: comm find: unable to read itable block
    [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 9962198: comm find: unable to read itable block
    [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 9962198: comm find: unable to read itable block
    [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 9962197: comm find: unable to read itable block
    [Fri Oct 20 20:20:43 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 9962197: comm find: unable to read itable block
    [Fri Oct 20 20:20:47 2023] EXT4-fs error: 33 callbacks suppressed
    [Fri Oct 20 20:20:47 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501456: block 9962196: comm find: unable to read itable block
    [Fri Oct 20 20:31:14 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212836: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:15 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #1578762: block 6291856: comm find: unable to read itable block
    [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213028: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213014: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213020: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213018: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:16 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212436: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum invalid
    [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum invalid
    [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum invalid
    [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum invalid
    [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578923: comm find: iget: checksum invalid
    [Fri Oct 20 20:31:18 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212254: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:18 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212241: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212155: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212151: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361724: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212356: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212340: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212936: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361429: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361425: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:24 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212632: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212634: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning: 1 callbacks suppressed
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212643: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212649: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212645: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816144: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816543: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816384: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816546: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:37 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816868: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:37 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816874: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:39 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295018: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:39 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294294: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6293930: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295038: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295036: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294560: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294556: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:41 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295040: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:42 2023] EXT4-fs warning: 5 callbacks suppressed
    [Fri Oct 20 20:31:42 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6424206: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1184835: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056874: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056811: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056879: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056602: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7362338: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056607: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056903: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6951908: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821023: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821020: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:48 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6820752: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:48 2023] EXT4-fs error: 21 callbacks suppressed
    [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 9962194: comm find: unable to read itable block
    [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 9962194: comm find: unable to read itable block
    [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 9962193: comm find: unable to read itable block
    [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 9962193: comm find: unable to read itable block
    [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 9962194: comm find: unable to read itable block
    [Fri Oct 20 20:31:50 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4481932: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:50 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4482754: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:31:57 2023] EXT4-fs error: 4 callbacks suppressed
    [Fri Oct 20 20:31:57 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 17827376: comm find: unable to read itable block
    [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 17827368: comm find: unable to read itable block
    [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 17827385: comm find: unable to read itable block
    [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 17827377: comm find: unable to read itable block
    [Fri Oct 20 20:31:59 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 17827385: comm find: unable to read itable block
    [Fri Oct 20 20:32:01 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893701: lblock 0: comm find: error -5 reading directory block
    [Fri Oct 20 20:32:01 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893470: lblock 0: comm find: error -5 reading directory block
    TARGET    SOURCE    FSTYPE OPTIONS
    /         /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/backup /dev/sdb1 ext4   rw,noatime
    `-/boot   /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    6.4G    /var/
    3.4G    /var/cache/apt
    3.4G    /var/cache
    3.3G    /var/cache/apt/archives
    2.6G    /var/lib
    Archived and active journals take up 232.0M in the file system.
    /opt/iobroker/backups:
    3.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    552M    /opt/iobroker/iobroker-data/backup-objects
    383M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    41M     /opt/iobroker/iobroker-data/states.json.old
    41M     /opt/iobroker/iobroker-data/states.json.bak
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
      system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
      system.adapter.devices.0                : devices               : raspi                                    -  enabled
      system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
      system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
      system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
      system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
      system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
    + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspi                                    -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
    + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
    + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
      system.adapter.reolink.4                : reolink               : raspi                                    - disabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    - disabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.2         : sourceanalytix        : raspi                                    -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    -  enabled
    + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
      system.adapter.statistics.0             : statistics            : raspi                                    - disabled
    + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspi                                    - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
      system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 3.1.0    , installed 3.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.10.0   , installed 3.10.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mydlink"      : 1.3.4    , installed 1.3.4
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "pushover"     : 3.0.3    , installed 3.0.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.0  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        15185
    States:         11056
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12897      350/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12058      510/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14693      459/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       458023     2123/io.sonoff.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14750      350/deCONZ
    tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       460503     2779/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       457155     1757/iobroker.js-co
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12935      586/mariadbd
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        13918      473/redis-server 12
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       456110     1849/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       460147     2534/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12060      510/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       464627     3567/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14692      459/cupsd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      118        13919      473/redis-server 12
    udp        0      0 0.0.0.0:59397           0.0.0.0:*                           108        11914      343/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       459997     2432/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12999      903/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12141      610/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       459488     2196/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11912      343/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14963      350/deCONZ
    udp6       0      0 :::546                  :::*                                0          13018      903/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11913      343/avahi-daemon: r
    udp6       0      0 :::45894                :::*                                108        11915      343/avahi-daemon: r
    2023-10-20 20:41:05.366  - warn: sonoff.0 (2123) Client "TAS-2NICE-1" not connected
    2023-10-20 20:43:34.170  - info: host.raspi iobroker add shelly auto --host raspi --debug
    2023-10-20 20:43:38.123  - info: host.raspi iobroker host.raspi create instance shelly
    2023-10-20 20:43:38.215  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.alive created
    2023-10-20 20:43:38.289  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.connected created
    2023-10-20 20:43:38.317  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.compactMode created
    2023-10-20 20:43:38.394  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.cpu created
    2023-10-20 20:43:38.435  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.cputime created
    2023-10-20 20:43:38.453  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memHeapUsed created
    2023-10-20 20:43:38.480  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memHeapTotal created
    2023-10-20 20:43:38.496  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memRss created
    2023-10-20 20:43:38.508  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.uptime created
    2023-10-20 20:43:38.519  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.inputCount created
    2023-10-20 20:43:38.548  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.outputCount created
    2023-10-20 20:43:38.562  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.eventLoopLag created
    2023-10-20 20:43:38.573  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.sigKill created
    2023-10-20 20:43:38.583  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.logLevel created
    2023-10-20 20:43:38.600  - info: host.raspi iobroker host.raspi object shelly.1 created
    2023-10-20 20:43:38.644  - info: host.raspi iobroker host.raspi object shelly.1.info created
    2023-10-20 20:43:38.690  - info: host.raspi iobroker host.raspi object shelly.1.info.connection created
    2023-10-20 20:43:38.706  - info: host.raspi iobroker host.raspi object shelly.1.info.update created
    2023-10-20 20:43:38.722  - info: host.raspi iobroker host.raspi object shelly.1.info.downloadScripts created
    2023-10-20 20:43:38.728  - info: host.raspi iobroker host.raspi Set default value of shelly.1.info.connection: false
    2023-10-20 20:43:38.758  - info: host.raspi iobroker host.raspi object system.adapter.shelly.1 created
    2023-10-20 20:43:39.787  - info: host.raspi iobroker exit 0
    brokeling
    Ich nehme an, es ist dieser part:
    @haselchen
    woher hast du gesehen, dass shelly und sonoff den gleichen port haben?
    (es stimmt wohl, beide auf 1883)
      @brokeling
      nodejs ist jetzt richtig.
      Aber dem Datenträger sdb1 auf /backup geht es schlecht. Ich vermute da auch den Grund für dein Problem.
      brokeling
      @thomas-braun said in Iobroker Absturz - Ursache?:
      @brokeling
      Was ist da?
      • B brokeling
        @brokeling
        Was ist da?
        @brokeling
        Das ist da:
          @brokeling
          Das ist da:
          brokeling
          evtl. Festplatten-Schaden?
          • B brokeling
            @brokeling
            Ich weiß ja nicht was das da für ein Datenträger ist. Jedenfalls sind das viel zu viele Fehler da auf dem Hobel.
              @brokeling
              brokeling
              schrieb am zuletzt editiert von brokeling
              @brokeling
              Es sind zwei USB Sticks dran. Aber es betrifft wohl den backup usb stick.
              Denkst du das kann sich im laufenden Betrieb auswirken?
              pi@raspi:~ $ lsblk
              NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
              sda      8:0    0 119,2G  0 disk
              ├─sda1   8:1    0   256M  0 part /boot
              └─sda2   8:2    0   119G  0 part /
              sdb      8:16   1 114,6G  0 disk
              └─sdb1   8:17   1 114,6G  0 part /backup
              • B brokeling
                @brokeling
                pi@raspi:~ $ lsblk
                @brokeling sagte in Iobroker Absturz - Ursache?:
                Na logisch.
                Sonst hättest du ja nicht die ganze Latte an Fehlermeldungen.
                  Na logisch.
                  brokeling
                  Na logisch.
                  ok, danke!
                  Den werde ich dann austauschen.
                  den shelly port konnte ich ändern 1883 -> 1885
                  jetzt aber zu den beiden anderen doppel-port-Belegungen:
                   0      0 0.0.0.0:5353            0.0.0.0:*                           1001       283538     12415/io.chromecast
                  jetzt ist die Frage wie ich da rankommen kann, die zu ändern...
                  • B brokeling
                    Na logisch.
                    ok, danke!
                    Von avahi würde ich die Finger lassen. Ob und wie man den chromcast abschalten kann weiß ich nicht.
                      brokeling
                      ok, ich lass das jetzt mal so. Und tausche schnellstmöglich den USB Stick.
                      Oder kann man da was "reparieren"?
                      Danke für die Hilfe!!!
                      Thomas BraunT ? 2 Antworten Letzte Antwort
                      • B brokeling
                        Nö.
                        • B brokeling
                          Moin,
                          reparieren, kann ich nicht sagen, aber bei einem korrupten Filesystem, kann man immer ein Check machen
                          # fsck
                          In Deinem Fall, so
                          # sudo umount /backup
                          # sudo fsck.ext4 /dev/sdb1
                          Dann schauen was kommt, falls Du Dir nicht sicher bist, dann hier posten. Den Vorgang wiederholen wenn Fehler auftauchen.
                          Bernd
                            brokeling
                            @dp20eic said in Iobroker Absturz - Ursache?:
                            leider ist mir iobroker heute abgestürzt, wahrscheinlich um so 18:50!?!
                            Moin,
                            schau mal nicht nur ins ioBroker Log, es kann auch ein Problem außerhalb gewesen sein.
                            Du könntest ins journal schauen,
                            # sudo journalctl --since="2023-10-20 18:45:00"
                            Bernd
                            Vielen Dank übrigens für die codes!
                            Ich stelle den das Resultat des letzteren hier rein, vielleicht kann der ein oder andere noch was draus lesen:
                            pi@raspi:~ $ sudo journalctl --since="2023-10-20 18:45:00" -g 'error'
                            -- Journal begins at Thu 2023-08-17 15:42:50 CEST, ends at Sat 2023-10-21 21:43:52 CEST. --
                            -- Boot f657936a502c4d5899b0bd648d6120d7 --
                            Okt 20 19:32:46 raspi pipewire[18775]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0>
                            Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0>
                            Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 996>
                            Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 996>
                            Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 996>
                            Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 996>
                            Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 996>
                            Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 996>
                            Okt 20 20:20:47 raspi kernel: print_req_error: 72 callbacks suppressed
                            Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0>
                            Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0>
                            Okt 20 20:20:47 raspi kernel: EXT4-fs error: 33 callbacks suppressed
                            Okt 20 20:20:47 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501456: block 996>
                            Okt 20 20:31:02 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 74160 op 0x0:(READ) flags 0x80>
                            Okt 20 20:31:14 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767768 op 0x0:(READ) flags >
                            Okt 20 20:31:14 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212836: lblock 0: com>
                            Okt 20 20:31:15 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 50334880 op 0x0:(READ) flags 0>
                            Okt 20 20:31:15 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #1578762: block 629>
                            Okt 20 20:31:15 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768536 op 0x0:(READ) flags >
                            Okt 20 20:31:15 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213028: lblock 0: com>
                            Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768480 op 0x0:(READ) flags >
                            Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213014: lblock 0: com>
                            Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768504 op 0x0:(READ) flags >
                            Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213020: lblock 0: com>
                            Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768496 op 0x0:(READ) flags >
                            Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213018: lblock 0: com>
                            Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 197141808 op 0x0:(READ) flags >
                            Okt 20 20:31:17 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230766184 op 0x0:(READ) flags >
                            Okt 20 20:31:17 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212436: lblock 0: com>
                            Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum >
                            Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum >
                            Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum >
                            Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum >
                            Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578923: comm find: iget: checksum >
                            Okt 20 20:31:18 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765472 op 0x0:(READ) flags >
                            Okt 20 20:31:18 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212254: lblock 0: com>
                            Okt 20 20:31:18 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765424 op 0x0:(READ) flags >
                            Okt 20 20:31:18 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212241: lblock 0: com>
                            Okt 20 20:31:20 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765088 op 0x0:(READ) flags >
                            Okt 20 20:31:20 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212155: lblock 0: com>
                            Okt 20 20:31:20 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765072 op 0x0:(READ) flags >
                            Okt 20 20:31:20 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212151: lblock 0: com>
                            Okt 20 20:31:21 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234968984 op 0x0:(READ) flags >
                            Okt 20 20:31:21 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361724: lblock 0: com>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 58724392 op 0x0:(READ) flags 0>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765864 op 0x0:(READ) flags >
                            Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212356: lblock 0: com>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765800 op 0x0:(READ) flags >
                            Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212340: lblock 0: com>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768168 op 0x0:(READ) flags >
                            Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212936: lblock 0: com>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234967824 op 0x0:(READ) flags >
                            Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361429: lblock 0: com>
                            Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234967808 op 0x0:(READ) flags >
                            Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361425: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230766952 op 0x0:(READ) flags >
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212632: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212634: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: print_req_error: 2 callbacks suppressed
                            Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767000 op 0x0:(READ) flags >
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212643: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767024 op 0x0:(READ) flags >
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212649: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767008 op 0x0:(READ) flags >
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212645: lblock 0: com>
                            Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218171528 op 0x0:(READ) flags >
                            Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816144: lblock 0: com>
                            Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218173424 op 0x0:(READ) flags >
                            Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816543: lblock 0: com>
                            Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218172680 op 0x0:(READ) flags >
                            Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816384: lblock 0: com>
                            Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218173440 op 0x0:(READ) flags >
                            Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816546: lblock 0: com>
                            Okt 20 20:31:37 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218174960 op 0x0:(READ) flags >
                            Okt 20 20:31:37 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816868: lblock 0: com>
                            Okt 20 20:31:37 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218174984 op 0x0:(READ) flags >
                            Okt 20 20:31:37 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816874: lblock 0: com>
                            Okt 20 20:31:39 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407536 op 0x0:(READ) flags >
                            Okt 20 20:31:39 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295018: lblock 0: com>
                            Okt 20 20:31:39 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201404528 op 0x0:(READ) flags >
                            Okt 20 20:31:39 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294294: lblock 0: com>
                            Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201403016 op 0x0:(READ) flags >
                            Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6293930: lblock 0: com>
                            Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407616 op 0x0:(READ) flags >
                            Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295038: lblock 0: com>
                            Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407608 op 0x0:(READ) flags >
                            Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295036: lblock 0: com>
                            Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201405632 op 0x0:(READ) flags >
                            Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294560: lblock 0: com>
                            Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201405616 op 0x0:(READ) flags >
                            Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294556: lblock 0: com>
                            Okt 20 20:31:41 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407624 op 0x0:(READ) flags >
                            Okt 20 20:31:41 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295040: lblock 0: com>
                            Okt 20 20:31:42 raspi kernel: print_req_error: 5 callbacks suppressed
                            Okt 20 20:31:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 205593712 op 0x0:(READ) flags >
                            Okt 20 20:31:42 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6424206: lblock 0: com>
                            Okt 20 20:31:46 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 37835504 op 0x0:(READ) flags 0>
                            Okt 20 20:31:46 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1184835: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648672 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056874: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648656 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056811: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648680 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056879: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648352 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056602: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234970008 op 0x0:(READ) flags >
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7362338: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648360 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056607: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648736 op 0x0:(READ) flags 0>
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056903: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 222384016 op 0x0:(READ) flags >
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6951908: lblock 0: com>
                            Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218190272 op 0x0:(READ) flags >
                            Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821023: lblock 0: com>
                            Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218190256 op 0x0:(READ) flags >
                            Okt 20 20:31:48 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821020: lblock 0: com>
                            Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218189888 op 0x0:(READ) flags >
                            Okt 20 20:31:48 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6820752: lblock 0: com>
                            Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0>
                            Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0>
                            Okt 20 20:31:48 raspi kernel: EXT4-fs error: 21 callbacks suppressed
                            Okt 20 20:31:48 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 996>
                            Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 996>
                            Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 996>
                            Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 996>
                            Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 996>
                            Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 996>
                            Okt 20 20:31:50 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4481932: lblock 0: com>
                            Okt 20 20:31:50 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4482754: lblock 0: com>
                            Okt 20 20:31:57 raspi kernel: print_req_error: 26 callbacks suppressed
                            Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags >
                            Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags >
                            Okt 20 20:31:57 raspi kernel: EXT4-fs error: 4 callbacks suppressed
                            Okt 20 20:31:57 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 178>
                            Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags >
                            Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags >
                            Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 178>
                            Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 178>
                            Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 178>
                            Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 178>
                            Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 178>
                            Okt 20 20:32:01 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893701: lblock 0: com>
                            Okt 20 20:32:02 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893470: lblock 0: com>
                            Okt 20 20:35:30 raspi bash[1130]: [ioredis] Unhandled error event: Error: write EPIPE
                            Okt 20 21:10:59 raspi sshd[26773]: error: kex_exchange_identification: Connection closed by remote host
                            Okt 20 21:58:27 raspi sshd[27425]: error: kex_exchange_identification: Connection closed by remote host
                            Okt 20 21:58:35 raspi pipewire-media-session[18783]: error id:0 seq:293 res:-32 (Broken pipe): connection error
                            Okt 20 21:58:36 raspi bash[1757]: This error originated either by throwing inside of an async function without a catch >
                            Okt 20 21:58:36 raspi bash[1757]: Error: DB closed
                            -- Boot 9034ae27f1174260808e596c062cf691 --
                            Okt 20 21:58:46 raspi raspi-config[473]: Error opening '/dev/input/event*': No such file or directory
                            Okt 20 22:23:56 raspi pipewire[16483]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 20 22:24:02 raspi sshd[16619]: error: kex_exchange_identification: Connection closed by remote host
                            Okt 20 22:33:28 raspi sshd[22886]: error: kex_exchange_identification: Connection closed by remote host
                            Okt 20 22:33:31 raspi pipewire[22918]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 20 22:33:32 raspi sshd[22979]: error: kex_exchange_identification: Connection closed by remote host
                            Okt 21 09:29:13 raspi pipewire[11613]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 21 09:35:25 raspi pipewire-media-session[11623]: error id:0 seq:293 res:-32 (Broken pipe): connection error
                            Okt 21 09:35:46 raspi pipewire[16025]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 21 09:36:03 raspi sudo[16220]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl --since=20>
                            Okt 21 09:37:51 raspi pipewire-media-session[16033]: error id:0 seq:293 res:-32 (Broken pipe): connection error
                            Okt 21 21:43:37 raspi pipewire[19010]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
                            Okt 21 21:43:52 raspi sudo[19205]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl --since=20>
                            lines 199-227/227 (END)
                            • B brokeling
                              Moin,
                              Bernd
                              @brokeling
                              Ich würde behaupten, das Ding ist fratze.
                              Neuinstallation (auf frischem Datenträger), Backup von vor dem Crash einspielen.
                              Und diesmal gleich ohne Desktop installieren.
                                @brokeling
                                brokeling
                                Aber die Haupt-SSD ist doch in Ordnung und läuft, oder wo ist das Problem?
                                Das Problem hat doch nur der backup-USB Stick!?!
                                Und die backups sind ja leider auf dem corrupten USB Stick - ob die auslesbar sind?
                                B Thomas BraunT 2 Antworten Letzte Antwort
                                • B brokeling
                                  brokeling
                                  pi@raspi:~ $ sudo umount /backup
                                  umount: /backup: not mounted.
                                  pi@raspi:~ $ sudo fsck.ext4 /dev/sdb1
                                  e2fsck 1.46.2 (28-Feb-2021)
                                  /dev/sdb1 is in use.
                                  e2fsck: Cannot continue, aborting.
                                  • B brokeling
                                    Kannste ja probieren. Ich würde das Dateisystem aber tunlichst 'nur-lesend'-ro einhängen. Du schrabbelst das Ding sonst nur noch weiter kaputt.
                                      brokeling
                                      wie mache ich das?
                                      • B brokeling
                                        wie mache ich das?
                                        @brokeling
                                        Ist die in der fstab drin?
                                        cat /etc/fstab
                                          @brokeling
                                          cat /etc/fstab
                                          brokeling
                                          cat /etc/fstab
                                          pi@raspi:~ $ cat /etc/fstab
                                          proc            /proc           proc    defaults          0       0
                                          PARTUUID=6c586e13-01  /boot           vfat    defaults,flush    0       2
                                          PARTUUID=6c586e13-02  /               ext4    defaults,noatime  0       1
                                          # a swapfile is not a swap partition, no line here
                                          #   use  dphys-swapfile swap[on|off]  for that
                                          PARTUUID=85032a97-01 /backup          ext4    defaults,noatime,nofail 0 2
