  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.8k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 736.2k Aufrufe 117 Beobachtet
    TT-Tom
    #1136
    Hallo @tombox
    seit zwei Tagen habe ich das Problem "Error: read ETIMEDOUT" mit der DHL. Login und Abfrage funktionieren laut Log, nur halt diese Error Meldung bei jeder Abfrage. Adapter öfter neu gestartet, kein Erfolg.
    parcel.0
    2023-10-13 10:43:44.153	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    parcel.0
    2023-10-13 10:43:44.219	debug	Objects client ready ... initialize now
    parcel.0
    2023-10-13 10:43:44.221	debug	Objects create System PubSub Client
    parcel.0
    2023-10-13 10:43:44.223	debug	Objects create User PubSub Client
    parcel.0
    2023-10-13 10:43:44.360	debug	Objects client initialize lua scripts
    parcel.0
    2023-10-13 10:43:44.370	debug	Objects connected to redis: 127.0.0.1:9001
    parcel.0
    2023-10-13 10:43:44.424	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    parcel.0
    2023-10-13 10:43:44.455	debug	States create System PubSub Client
    parcel.0
    2023-10-13 10:43:44.457	debug	States create User PubSub Client
    parcel.0
    2023-10-13 10:43:44.549	debug	States connected to redis: 127.0.0.1:9000
    parcel.0
    2023-10-13 10:43:44.804	debug	Plugin sentry Initialize Plugin (enabled=true)
    parcel.0
    2023-10-13 10:43:45.945	info	starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.0, js-controller: 4.0.24
    parcel.0
    2023-10-13 10:43:46.027	info	Login to DHL
    parcel.0
    2023-10-13 10:43:46.694	debug	[object Object]
    parcel.0
    2023-10-13 10:43:47.915	debug	Please close this window to continue.
    parcel.0
    2023-10-13 10:43:48.028	debug	(janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"u2AWhKtqH9WSD.........
    parcel.0
    2023-10-13 10:43:49.328	debug	{"access_token":"jK3QAVmNnJTFwiKM........
    parcel.0
    2023-10-13 10:43:49.330	info	Login to DHL successful
    parcel.0
    2023-10-13 10:45:01.396	error	Error: read ETIMEDOUT
    parcel.0
    2023-10-13 10:45:01.399	debug	https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app
    parcel.0
    2023-10-13 10:45:02.763	debug	{"sendungen":[{"id":"003404346972........
    parcel.0
    2023-10-13 10:45:02.789	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    parcel.0
    2023-10-13 10:45:02.869	debug	dhl merge provider json
    parcel.0
    2023-10-13 10:45:02.872	debug	https://www.dhl.de/int-aviseanzeigen/advices?width=414
    parcel.0
    2023-10-13 10:45:03.146	debug	{"currentAdvice":{"date":"13.10.2023","advices":[{"image_url":"https://briefankuendigung.dhl.de/pdapp-web/image/v1.0/..........
    parcel.0
    2023-10-13 10:45:03.407	debug	""
    parcel.0
    2023-10-13 10:45:05.658	debug	dhl merge provider json
    parcel.0
    2023-10-13 10:45:05.672	debug	Write states
    ist es sinnvoll auf die Beta zu wechseln?
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    Thomas BraunT T 2 Antworten Letzte Antwort
    • T TT-Tom
      Hallo @tombox
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      #1137
      @tt-tom sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
      Aber auf die aktuellen stable-Releases könntest du schon mal wechseln. (js-controler, nodejs).
      • haselchenH Offline
        haselchenH Offline
        haselchen
        #1138
        @tt-tom
        Gleiche Meldung habe ich auch trotz der neuen Versionen der letzten Tage.
        Hab den Adapter erstmal ausgeschaltet.
        • haselchenH haselchen
          @tt-tom
          TT-Tom
          #1139
          @haselchen okay, danke. Warten wir mal ab, ob @tombox was klären kann.
          Gruß Tom
          Public Transport
            TT-Tom
            #1140
            @thomas-braun gab es danach bei Nodejs ein Bug oder ist der schon gefixt??
            Gruß Tom
            Public Transport
            • T TT-Tom
              #1141
              nodejs 18.18.1 ist die fehlerfreiste Version aller Zeiten! ;-)
              • Ro75R Ro75
                @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                Dann lass es uns wissen woran es genau lag bitte
                Ich hatte gestern im LOG zahlreiche Fehlereinträge, jetzt auch wieder den selben
                parcel.0
                2023-10-11 17:47:55.265	error	Error: read ETIMEDOUT
                Davon aber gestern eine ganze Menge. Das hatte ich in der Vergangenheit auch schon eins, zwei, drei mal.
                Ein Neustart vom Adapter brachte für die nächste Zeit Ruhe rein. Also kam ich auf den schlauen Gedanken, den Adapter automatisch neu starten zu lassen. Allerdings funktioniert das wohl am Adapter selbst nicht immer ganz so richtig.
                Ergebnis war. Statt Mittwoch und Sonntag in der Nacht um 3 den Adapter neu zu starten, wurde dieser nun fast minütlich neu gestartet.
                Ro75.
                L Online
                L Online
                Lucky_ESA
                #1142
                @ro75
                parcel.0
                Hatte auch diesen Fehler. Bei mir war es UPS...Musste mich auf der HomePage einloggen und die neuen AGB`s akzeptieren.
                Gruß//Lucky
                • T TT-Tom
                  Hallo @tombox
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  tombox
                  #1143
                  @tt-tom besteht das Problem immer noch?
                  O T 2 Antworten Letzte Antwort
                  • L Lucky_ESA
                    @ro75
                    parcel.0
                    Gruß//Lucky
                    #1144
                    @lucky_esa sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                    @ro75
                    parcel.0
                    Gruß//Lucky
                    habe die Fehlermeldung auch, und habe mich mal auf den Seiten (DPD, DHL usw) angemeldet. Leider habe ich nicht wie bei dir AGB´S zu akzeptieren. Hast du sonst noch eine Idee?
                    LG phantomkommander
                    L 1 Antwort Letzte Antwort
                    • Chris76eC Chris76e
                      @tombox
                      Unknown Error: Login to Amazon failed, please login to Amazon and check your credentials
                      Habe seit 2 Tagen das Problem das der Login zu Amazon nicht mehr bestehen bleibt. Wenn ich unter parcel.0.auth.cookie die cookies lösche, funktioniert es wieder, aber nach bei der 2. Aktualisierung kommt dann der obengenannte Fehler.
                      Version 0.0.27 und 0.1.1 getestet
                      https://github.com/TA2k/ioBroker.parcel/issues/63
                      Chris76eC Offline
                      Chris76eC Offline
                      Chris76e
                      #1145
                      @chris76e sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      @tombox
                      Bei mir läuft es seit gestern ca. 21:00 Uhr wieder, hatte den Adapter solange ausgeschaltet gelassen
                      • T tombox
                        O Offline
                        O Offline
                        oFbEQnpoLKKl6mbY5e13
                        #1146
                        @tombox
                        Ja.
                        • J Offline
                          jensven
                          schrieb am zuletzt editiert von jensven
                          #1147
                          @tombox
                          habe den Adapter letzte Woche neu Installiert. Durch die Errors habe ich den Adapter auch erstmal abgeschaltet.
                          gerade nochmal gestartet
                          parcel.0
                          2023-10-18 08:33:05.579	error	Error: read ETIMEDOUT
                          parcel.0
                          2023-10-18 08:31:51.279	info	Login to DHL successful
                          parcel.0
                          2023-10-18 08:31:47.610	info	Login to DHL
                          parcel.0
                          2023-10-18 08:31:47.510	info	starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.0, js-controller: 5.0.12
                          OmnedonO 1 Antwort Letzte Antwort
                          • J jensven
                            @tombox
                            parcel.0
                            parcel.0
                            parcel.0
                            parcel.0
                            OmnedonO Online
                            OmnedonO Online
                            Omnedon
                            #1148
                            @tombox
                            Bei mir das gleiche Problem.
                            Ständig die gleiche Fehlermeldung:
                            parcel.0  3466335	2023-10-18 09:06:41.502	error	Error: read ETIMEDOUT
                            • T tombox
                              TT-Tom
                              #1149
                              @tombox
                              Ja, bei mir auch immer noch das Problem bei DHL.
                              Gruß Tom
                              Public Transport
                                @ro75
                                parcel.0
                                Gruß//Lucky
                                LG phantomkommander
                                L Online
                                L Online
                                Lucky_ESA
                                #1150
                                @phantomkommander
                                LG phantomkommander
                                Habe den Fehler leider weiterhin. Bei Adapter Neustart habe ich bei UPS eine Fehlermeldung. Alle anderen berichten hier von DHL.
                                Was kommt den bei euch im Log wenn der Adapter neu gestartet wird bzw. auch mal auf debug stellen.
                                • L Lucky_ESA
                                  @phantomkommander
                                  LG phantomkommander
                                  TT-Tom
                                  #1151
                                  @lucky_esa
                                  sieht bei mir so aus
                                  2023-10-18 18:07:51.990 - debug: parcel.0 (1107844) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2023-10-18 18:07:52.059 - debug: parcel.0 (1107844) Objects client ready ... initialize now
                                  2023-10-18 18:07:52.063 - debug: parcel.0 (1107844) Objects create System PubSub Client
                                  2023-10-18 18:07:52.066 - debug: parcel.0 (1107844) Objects create User PubSub Client
                                  2023-10-18 18:07:52.166 - debug: parcel.0 (1107844) Objects client initialize lua scripts
                                  2023-10-18 18:07:52.175 - debug: parcel.0 (1107844) Objects connected to redis: 127.0.0.1:9001
                                  2023-10-18 18:07:52.242 - debug: parcel.0 (1107844) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2023-10-18 18:07:52.271 - debug: parcel.0 (1107844) States create System PubSub Client
                                  2023-10-18 18:07:52.272 - debug: parcel.0 (1107844) States create User PubSub Client
                                  2023-10-18 18:07:52.369 - debug: parcel.0 (1107844) States connected to redis: 127.0.0.1:9000
                                  2023-10-18 18:07:52.644 - debug: parcel.0 (1107844) Plugin sentry Initialize Plugin (enabled=true)
                                  2023-10-18 18:07:54.191 - info: parcel.0 (1107844) starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.2, js-controller: 5.0.12
                                  2023-10-18 18:07:54.306 - info: parcel.0 (1107844) Login to DHL
                                  2023-10-18 18:07:55.502 - debug: parcel.0 (1107844) Please close this window to continue.
                                  2023-10-18 18:07:55.613 - debug: parcel.0 (1107844) (janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"IXj9Mw6dKo2roM1Rg........
                                  2023-10-18 18:07:57.001 - info: parcel.0 (1107844) Login to DHL successful
                                  2023-10-18 18:09:08.946 - error: parcel.0 (1107844) Error: read ETIMEDOUT
                                  2023-10-18 18:09:08.949 - debug: parcel.0 (1107844) https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app
                                  2023-10-18 18:09:09.863 - debug: parcel.0 (1107844) {"sendungen":[{"id":"00340434.........
                                  2023-10-18 18:09:09.905 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen01.id
                                  2023-10-18 18:09:11.189 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen02.id
                                  2023-10-18 18:09:12.038 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen03.id
                                  2023-10-18 18:09:13.104 - debug: parcel.0 (1107844) dhl merge provider json
                                  2023-10-18 18:09:13.107 - debug: parcel.0 (1107844) https://www.dhl.de/int-aviseanzeigen/advices?width=414
                                  2023-10-18 18:09:13.587 - debug: parcel.0 (1107844) {"currentAdvice":null,"oldAdvices":[{"date":"16.10.2023","advices":[{"image_url":"https://briefankuendigung.dhl.de/pdapp-web/image/v1.0/.......
                                  2023-10-18 18:09:13.904 - debug: parcel.0 (1107844) ""
                                  2023-10-18 18:09:15.900 - debug: parcel.0 (1107844) dhl merge provider json
                                  2023-10-18 18:09:15.901 - debug: parcel.0 (1107844) Write states
                                  Die Daten kommen trotzdem an und werden auch eingelesen. Es gibt nur regelmäßig die Error Meldung "error: parcel.0 (1107844) Error: read ETIMEDOUT"
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @lucky_esa
                                    tombox
                                    #1152
                                    @tt-tom Bitte mal die aktuelle version via beta channel verwenden.
                                    Kommt der Fehler bei jeder Aktualisierung
                                    • T tombox
                                      #1153
                                      @tombox
                                      Hier weiterhin mit iobroker.parcel@0.1.5:
                                      2023-10-18 18:06:29.468  - error: parcel.0 (18793) Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
                                      2023-10-18 18:06:29.469  - error: parcel.0 (18793) Error: read ETIMEDOUT
                                      2023-10-18 18:06:32.634  - info: parcel.0 (18793) Login to Amazon successful
                                      2023-10-18 18:31:30.653  - error: parcel.0 (18793) Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
                                      2023-10-18 18:31:30.654  - error: parcel.0 (18793) Error: read ETIMEDOUT
                                      2023-10-18 18:31:33.933  - info: parcel.0 (18793) Login to Amazon successful
                                        @tombox
                                        LibertyX82
                                        #1154
                                        DHL hat seit ca 1 Woche Probleme mit Ihrer Paketverfolgung, selbst auf der Webseite wird sporadisch kein Status angezeigt.
                                        Der Fehler tritt immer mal wieder auf und verschwindet auch wieder.
                                        • T tombox
                                          TT-Tom
                                          #1155
                                          @tombox
                                          parcel.0
                                          2023-10-18 18:57:31.134	info	starting. Version 0.1.5 (non-npm: TA2k/ioBroker.parcel) in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.2, js-controller: 5.0.12
                                          parcel.0
                                          2023-10-18 18:57:31.238	info	Login to DHL
                                          parcel.0
                                          2023-10-18 18:57:34.456	info	Login to DHL successful
                                          parcel.0
                                          2023-10-18 18:58:46.738	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
                                          parcel.0
                                          2023-10-18 18:58:46.741	error	Error: read ETIMEDOUT
                                          parcel.0
                                          2023-10-18 19:10:00.529	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
                                          parcel.0
                                          2023-10-18 19:10:00.529	error	Error: read ETIMEDOUT
                                          Gruß Tom
                                          Public Transport
