  4. ioBroker hängt sich regelmäßig auf
    5.1k
48 Beiträge 7 Kommentatoren 5.8k Aufrufe 5 Beobachtet
  • Samson71S Samson71
    @kukli31
    Es gibt einer Fixer dafür von @Thomas-Braun
    kukli31
    @samson71 said in ioBroker hängt sich regelmäßig auf:
    @kukli31
    Ich habe den Fixer laufen lassen. Danke schon mal für den Tipp.
    Sieht es jetzt besser aus?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi4-master
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:10:31 up 42 min,  1 user,  load average: 4.03, 2.47, 2.04
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-10-17 16:10:31 CEST
               Universal time: Tue 2023-10-17 14:10:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.6G        248M        0.0K        949M        1.1G
    Swap:            99M        1.0M         98M
    Total:          3.9G        2.6G        346M
             3793 M total memory
             2591 M used memory
             3042 M active memory
              164 M inactive memory
              251 M free memory
               11 M buffer memory
              938 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      235G  5.9G  220G   3% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Oct 17 15:28:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:71:9F:4D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=58e76898-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): 2 orphan inodes deleted
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): recovery complete
    [Tue Oct 17 15:28:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Oct 17 15:28:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Tue Oct 17 15:28:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    846M    /var/log
    793M    /var/log/journal/49f5cfb508e342378183307452dc5b73
    444M    /var/cache
    Archived and active journals take up 792.1M in the file system.
    /opt/iobroker/backups:
    125M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    493M    /opt/iobroker/iobroker-data/
    286M    /opt/iobroker/iobroker-data/files
    150M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    16M     /opt/iobroker/iobroker-data/states.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-master                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-master                      -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi4-master                      - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi4-master                      -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-master                      -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-master                      -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi4-master                      -  enabled
    + system.adapter.device-reminder.1        : device-reminder       : raspberrypi4-master                      -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-master                      -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi4-master                      -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi4-master                      -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-master                      -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi4-master                      -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi4-master                      - disabled
    + system.adapter.history.0                : history               : raspberrypi4-master                      -  enabled
    + system.adapter.homepilot20.0            : homepilot20           : raspberrypi4-master                      -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi4-master                      -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi4-master                      -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi4-master                      - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4-master                      - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-master                      - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi4-master                      -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi4-master                      -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi4-master                      -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi4-master                      - disabled
      system.adapter.jarvis.1                 : jarvis                : raspberrypi4-master                      - disabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-master                      -  enabled
    + system.adapter.life360.0                : life360               : raspberrypi4-master                      -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-master                      -  enabled
      system.adapter.meross.0                 : meross                : raspberrypi4-master                      - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4neu                          -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : raspberrypi4-master                      - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : raspberrypi4-master                      -  enabled
      system.adapter.powerfox2.0              : powerfox2             : raspberrypi4-master                      -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4-master                      -  enabled
    + system.adapter.pushover.1               : pushover              : raspberrypi4-master                      -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-master                      -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : raspberrypi4-master                      -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi4-master                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4-master                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi4-master                      -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4neu                          -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi4-master                      -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi4-master                      - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-master                      -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-master                      -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi4-master                      -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-master                      -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi4-master                      - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-master                      - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-master                      - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi4-master                      - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-master                      - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-master                      - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4-master                      -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-master                      - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi4-master                      - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4-master                      - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-master                      - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi4-master                      - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-master                      - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-master                      - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-master                      -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-master                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4-master                      -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi4-master                      -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi4-master                      -  enabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi4-master                      -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4neu                          -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_76e54d3c6f12ec118f7721c7bd930c07-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.2.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.3
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
    Adapter    "pushover"     : 3.0.3    , installed 3.0.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.8.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        19704
    States:         16161
    W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       132141     14958/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       132134     14958/iobroker.js-c
    tcp        0      0 127.0.0.1:45531         0.0.0.0:*               LISTEN      1001       135040     15730/io.yahka.0
    tcp        0      0 0.0.0.0:36917           0.0.0.0:*               LISTEN      1001       135024     15730/io.yahka.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13632      521/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:33495         0.0.0.0:*               LISTEN      1001       135741     15779/io.yahka.1
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       132686     15264/io.shelly.1
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        129431     13931/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13634      521/sshd: /usr/sbin
    tcp6       0      0 :::46621                :::*                    LISTEN      1001       135737     15779/io.yahka.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       136772     15710/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131147     14979/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        1897       707/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       135544     15627/io.simple-api
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       132700     15279/io.sonos.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       130891     15357/io.broadlink2
    udp        0      0 0.0.0.0:42105           0.0.0.0:*                           1001       129820     15204/io.shelly.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12772      394/avahi-daemon: r
    udp        0      0 0.0.0.0:52763           0.0.0.0:*                           1001       132881     15357/io.broadlink2
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       129746     15204/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15069      703/dhcpcd
    udp        0      0 0.0.0.0:47476           0.0.0.0:*                           108        12774      394/avahi-daemon: r
    udp        0      0 0.0.0.0:45468           0.0.0.0:*                           1001       131813     15357/io.broadlink2
    udp6       0      0 :::5353                 :::*                                108        12773      394/avahi-daemon: r
    udp6       0      0 :::40833                :::*                                108        12775      394/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          127441     703/dhcpcd
    2023-10-17 16:11:15.390  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16682
    2023-10-17 16:11:19.473  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.37" greater than max "100"
    2023-10-17 16:11:21.407  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
    2023-10-17 16:11:21.458  - info: cloud.0 (15797) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
    2023-10-17 16:11:21.461  - info: cloud.0 (15797) Connection changed: disconnect
    2023-10-17 16:11:26.630  - info: powerfox2.0 (16682) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
    2023-10-17 16:11:30.042  - warn: host.raspberrypi4-master instance system.adapter.powerfox2.0 already running with pid 16682
    2023-10-17 16:11:31.113  - info: powerfox2.0 (16682) Terminated (NO_ERROR): Without reason
    2023-10-17 16:11:31.695  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-10-17 16:11:45.070  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16749
    2023-10-17 16:11:49.638  - warn: shelly.0 (15204) State value to set for "shelly.0.SHDM-1#D3F1BE#1.temperatureF" has value "104.49" greater than max "100"
    2023-10-17 16:11:49.966  - info: powerfox2.0 (16749) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
    2023-10-17 16:11:52.217  - info: powerfox2.0 (16749) Terminated (NO_ERROR): Without reason
    2023-10-17 16:11:52.760  - warn: powerfox2.0 (16749) get state error: Connection is closed.
    2023-10-17 16:11:52.904  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-10-17 16:12:00.068  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 16835
    2023-10-17 16:12:03.990  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
    2023-10-17 16:12:06.244  - info: powerfox2.0 (16835) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
    2023-10-17 16:12:11.486  - info: powerfox2.0 (16835) Terminated (NO_ERROR): Without reason
    2023-10-17 16:12:12.048  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-10-17 16:12:15.215  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 17434
    2023-10-17 16:12:20.635  - info: powerfox2.0 (17434) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
    2023-10-17 16:12:21.623  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
    2023-10-17 16:12:24.250  - info: powerfox2.0 (17434) Terminated (NO_ERROR): Without reason
    2023-10-17 16:12:25.251  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      @kukli31 sagte in ioBroker hängt sich regelmäßig auf:
      Die Doublette in der Datei auch rauswerfen.
      Zusätzlich halt das nodejs-Trümmerfeld aufräumen:
      https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
      kukli31
      @thomas-braun said in ioBroker hängt sich regelmäßig auf:
      So, ich habe beides bereinigt und sieht jetzt so aus:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
       16:19:40 up 51 min,  1 user,  load average: 1.87, 2.28, 2.20
      CPU threads: 4
      Current issues:
                     Local time: Tue 2023-10-17 16:19:40 CEST
                 Universal time: Tue 2023-10-17 14:19:40 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.4G        716M        0.0K        637M        1.2G
      Swap:            99M         95M        4.0M
      Total:          3.9G        2.5G        721M
               3793 M total memory
               2439 M used memory
                601 M active memory
               2196 M inactive memory
                716 M free memory
                  5 M buffer memory
                632 M swap cache
                 99 M total swap
                 95 M used swap
                  4 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.6G    /var/
      846M    /var/log
      444M    /var/cache
      518M    /opt/iobroker/iobroker-data/
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      30M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        19704
      States:         16161
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://repos.influxdata.com/debian stable InRelease
      Pending Updates: 0
      2023-10-17 16:20:19.759  - info: powerfox2.0 (19266) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
      2023-10-17 16:20:21.899  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
      2023-10-17 16:20:23.268  - info: powerfox2.0 (19266) Terminated (NO_ERROR): Without reason
      2023-10-17 16:20:23.805  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 16:20:30.125  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19323
      2023-10-17 16:20:38.246  - info: powerfox2.0 (19323) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
      2023-10-17 16:20:39.263  - info: powerfox2.0 (19323) Terminated (NO_ERROR): Without reason
      2023-10-17 16:20:40.056  - warn: powerfox2.0 (19323) get state error: Connection is closed.
      2023-10-17 16:20:40.180  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 16:20:45.069  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19371
      2023-10-17 16:20:50.071  - info: powerfox2.0 (19371) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
      2023-10-17 16:20:52.169  - info: wolf-smartset.0 (15320) Initialization with Login and new Session done!
      2023-10-17 16:20:52.404  - info: powerfox2.0 (19371) Terminated (NO_ERROR): Without reason
      2023-10-17 16:20:53.477  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 16:21:00.064  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19455
      2023-10-17 16:21:06.027  - info: powerfox2.0 (19455) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
      2023-10-17 16:21:08.498  - info: smartcontrol.0 (15638) Trigger 'Bewegung.Flur' was already activated 0.04 seconds ago and is ignored. Must be at least 2 seconds.
      2023-10-17 16:21:11.620  - info: powerfox2.0 (19455) Terminated (NO_ERROR): Without reason
      2023-10-17 16:21:12.157  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      2023-10-17 16:21:15.245  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 started with pid 19998
      2023-10-17 16:21:20.020  - info: powerfox2.0 (19998) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.18.2, js-controller: 5.0.12
      2023-10-17 16:21:21.136  - info: powerfox2.0 (19998) Terminated (NO_ERROR): Without reason
      2023-10-17 16:21:21.735  - info: cloud.0 (15797) Trying to connect as system.user.admin to cloud
      2023-10-17 16:21:21.797  - warn: powerfox2.0 (19998) get state error: Connection is closed.
      2023-10-17 16:21:21.992  - info: host.raspberrypi4-master instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
      • K kukli31
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         95M        4.0M
                 3793 M total memory
                 2439 M used memory
                  601 M active memory
                  716 M free memory
                    5 M buffer memory
                  632 M swap cache
                   99 M total swap
                   95 M used swap
                    4 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.6G    /var/
        846M    /var/log
        444M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        19704
        States:         16161
        Pending Updates: 0
        Dein Dateisystem ist löchrig.
        K HomoranH 2 Antworten Letzte Antwort
          kukli31
          Was heißt das, bzw. wie und wo muss ich was fixen?
            @thomas-braun sagte in ioBroker hängt sich regelmäßig auf:
            Ich muss den Raspberry aus- und einschalten
            aka Stecker ziehen.
            killt Dateisysteme
            • K kukli31
              @kukli31
              Das heißt, das zwei inodes nicht mehr zugeordnet werden konnten und gelöscht wurden.
              Konkret kann das alles mögliche verursachen, hängt davon ab was da drin stand.
              Bei grafana ist immer noch was krumm:
              Da sollte nur eine Zeile erscheinen.
                @kukli31
                kukli31
                @kukli31
                Und nun? Hast du einen Tipp?
                • K kukli31
                  @kukli31
                  Schau in /etc/apt/sources.list.d ob es etweder zwei .list-Dateien zu grafana gibt oder ob die bestehende Datei zwei entsprechende Zeilen hat.
                    kukli31
                    schrieb am zuletzt editiert von kukli31
                    pi@raspberrypi4-master:~ $ ls /etc/apt/
                    apt.conf.d  auth.conf.d  keyrings  listchanges.conf  listchanges.conf.d  preferences.d  sources.list  sources.list.d  trusted.gpg  trusted.gpg.d
                    sources.list.d ist leer
                    • K kukli31
                      @kukli31 Das kann/soll nicht sein.
                      ls -lAh /etc/apt/sources.list.d/
                        kukli31
                        pi@raspberrypi4-master:~ $ ls -lAh /etc/apt/sources.list.d/
                        total 16K
                        -rw-r--r-- 1 root root 137 Oct 17 16:18 grafana.list
                        -rw-r--r-- 1 root root 117 Sep  4 13:04 influxdata.list
                        -rw-r--r-- 1 root root 100 Oct 17 16:05 nodesource.list
                        -rw-r--r-- 1 root root 191 May  3 04:52 raspi.list
                        • K kukli31
                          total 16K
                          Ich sag doch, das Verzeichnis ist nicht leer...
                          cat /etc/apt/sources.list.d/grafana.list
                            kukli31
                            pi@raspberrypi4-master:~ $ cat /etc/apt/sources.list.d/grafana.list
                            deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                            deb https://packages.grafana.com/oss/deb stable main
                            • K kukli31
                              @kukli31
                              Lösch die zweite Zeile.
                                @kukli31
                                kukli31
                                @kukli31
                                Ok, habe ich gemacht:
                                pi@raspberrypi4-master:~ $ sudo nano /etc/apt/sources.list.d/grafana.list
                                • K kukli31
                                  @kukli31
                                  kukli31
                                  @kukli31 said in ioBroker hängt sich regelmäßig auf:
                                  @kukli31
                                  Vielen lieben Dank an alle. Super Support hier :)
                                  Ich hoffe, dass mein ioBroker jetzt nicht mehr abstürzt und ich nicht den Stecker ziehen muss ;)
                                  • K kukli31
                                    @kukli31
                                    Das muss/macht man eh nie.
                                    Schau dir den 'Klammergriff' für Linux an. Und wie man den auf deiner Tastatur verwendet.
                                    K 2 Antworten Letzte Antwort
                                      kukli31
                                      Danke für den Tipp :)
                                        kukli31
                                        Aber das funktioniert doch nicht wenn man sich über ssh gar nicht mehr anmelden kann?
                                        Thomas BraunT ? 2 Antworten Letzte Antwort
                                        • K kukli31
                                          @kukli31
                                          Aber lokal
