  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 679.5k Aufrufe 146 Beobachtet
  • T todde
    Ich habe heute den Adapter für meine RLC-510WA installiert. Nach dem Start des Adapters bleibt dieser gelb und im Log bekomme ich folgenden Fehler "connect ECONNREFUSED 127.0.0.1:443: ECONNREFUSED".
    Hier das Log dazu:
    2023-10-12 15:24:49.600 - debug: reolink.0 (1499891) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-10-12 15:24:49.683 - debug: reolink.0 (1499891) Objects client ready ... initialize now
    2023-10-12 15:24:49.685 - debug: reolink.0 (1499891) Objects create System PubSub Client
    2023-10-12 15:24:49.687 - debug: reolink.0 (1499891) Objects create User PubSub Client
    2023-10-12 15:24:49.818 - debug: reolink.0 (1499891) Objects client initialize lua scripts
    2023-10-12 15:24:49.830 - debug: reolink.0 (1499891) Objects connected to redis: 0.0.0.0:9001
    2023-10-12 15:24:49.927 - debug: reolink.0 (1499891) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-10-12 15:24:49.974 - debug: reolink.0 (1499891) States create System PubSub Client
    2023-10-12 15:24:49.975 - debug: reolink.0 (1499891) States create User PubSub Client
    2023-10-12 15:24:50.104 - debug: reolink.0 (1499891) States connected to redis: 0.0.0.0:9000
    2023-10-12 15:24:51.010 - info: reolink.0 (1499891) starting. Version 0.1.1 (non-npm: aendue/ioBroker.reolink#b3916258a14620eee9267794fcacf6a320ac1457) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.17.1, js-controller: 5.0.13
    2023-10-12 15:24:51.043 - info: reolink.0 (1499891) Reolink adapter has started
    2023-10-12 15:24:51.046 - info: reolink.0 (1499891) Current IP: 192.168.xxx.yyy
    2023-10-12 15:24:51.174 - info: reolink.0 (1499891) State value to set for "reolink.0.network.channel" has to be type "number" but received type "string"
    2023-10-12 15:24:51.419 - error: reolink.0 (1499891) Error: connect ECONNREFUSED 127.0.0.1:443: ECONNREFUSED
    Zugriff über den Browser auf die API mit https://192.168.xxx.yyy/api.cgi?cmd=GetDevInfo&channel=0&user=MyUser&password=MyPassword funktioniert. Das Passwort hat keine Sonderzeichen.
    Hat jemand eine Idee warum der Adapter versucht auf Locahost zuzugreifen?
    oelisonO Offline
    oelisonO Offline
    oelison
    #528
    Bitte mal Deine Einstellungen zeigen. Im Code kann ich sonst nichts entecken, was das verursachen könnte.
    I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
    • oelisonO oelison
      todde
      schrieb am zuletzt editiert von todde
      #529
      @oelison, gerne:
      Kanal=0 hatte ich auch schon versucht. Oder liegt es an js-controler Version 5.0.13? Node.js ist v18.17.1.
        todde
        #530
        @oelison mit dem FQDN anstatt der IP-Adresse funktioniert die Verbindung jetzt. Warum auch immer ...
        oelisonO S 2 Antworten Letzte Antwort
        • S Sushibomba
          @skvarel
          Du hattest mir ja freundlicherweise deine VIS zur Verfügung gestellt.
          Bin nun endlich dazu gekommen sie bei mir zu implementieren.
          Leider fehlen einige Dinge.
          Hast du mir zufällig eine alte Version geschickt?
          Oder fehlen mir noch irgendwelche Widgets die ich installieren muss?
          Z.B. unterhalb des Kamerabildes hast du Buttons für andere Cams so wie es aussieht. Diese sind bei mir gar nicht vorhanden.
          EDIT: Hat sich glaube ich schon geklärt. Lagen unterem einem anderen Widget und zwar unter dem Notsignal. Warum hast du das Bild dort eingefügt?
          skvarelS Online
          skvarelS Online
          skvarel
          #531
          @sushibomba .. NO SIGNAL kommt zum Vorschein, wenn ich die Steckdosen der Kameras abschalte. Ab und zu möchten wir mal nicht gefilmt werden ;)
          #TeamInventwo
          Unsere Adapter:
          • S Sushibomba
            @skvarel
            Noch zwei kurze Fragen...
            Und was steuerst du z.B. mit "Auffahrt" Stromlos und dem dahinter liegenden Block?
            Habe einige Zigbee geräte gesehen in den datenpunkten und frage mich was du da verwendest? :)
            skvarelS Online
            skvarelS Online
            skvarel
            #532
            @sushibomba .. ich habe ein paar LIDL Steckdosen für die Kameras. Ich schalte so die ganze Kamera stromlos, wenn wir mal nicht überwacht werden wollen.
            #TeamInventwo
            Unsere Adapter:
              Simps
              #533
              Servus,
              im normalen und beta Repository finde ich ihn nicht, habe ihn firekt von github installiert: Basisobjekte hat er angelegt aber keinen Adapter. Mach ich was falsch? Hab den iobroker auf nem raspi... Danke!!
              oelisonO 1 Antwort Letzte Antwort
              • T todde
                oelisonO Offline
                oelisonO Offline
                oelison
                #534
                @todde Leider keine Ahnung was da schief geht. Aber wenn es jetzt klappt ist es ja erstmal egal.
                • S Simps
                  Servus,
                  oelisonO Offline
                  oelisonO Offline
                  oelison
                  #535
                  @simps Bitte mal im ioBroker den Experten modus aktivieren. Dann unter Adapter auf die GitHub-Katze klicken. Im Tab Benutzerdefiniert den Link zum Repo angeben und dann sollte es gehen.
                  • N Offline
                    N Offline
                    nex
                    #536
                    ich habe eine Reolink Duo Floodlight PoE.
                    Grundsätzlich funktioniert der Adapter bei mir, es werden diverse Metainformationen zur Kamera korrekt in den Objekten angezeigt.
                    Leider aktualisiert sich das Objekt reolink.0.sensor.motion nicht. Es bleibt immer bei 0.
                    Per api-call "https://<ip>/api.cgi?cmd=GetMdState&channel=0&rs=Get&user=<user>&password=<password>" bekomme ich jedoch die korrekte Rückmeldung: "[ { "cmd" : "GetMdState", "code" : 0, "value" : { "state" : 1 } } ]"
                    Hat jemand eine Idee woran das liegen könnte?
                    • T todde
                      simplyclever
                      #537
                      @todde Ich habe eine neue Reolink E1 (Indoor) und der Adapter wird nicht grün. Auch über den Browser (Api Call) erhalte ich keinen Zugriff / keine Infos. Per App funktioniert alles einwandfrei.
                      Welchen Kanal muss ich nehmen bzw. wo ist der definiert? Habe 0 und 1 versucht.
                      Und wie sieht die FQDN aus? Dann würde ich es damit mal testen.
                      • S simplyclever
                        todde
                        #538
                        @simplyclever ich kenne die E1 nicht, aber hast du in den Einstellungen http oder/und https aktiviert?
                        Der FQDN (Fully Qualified Domain Name) ist der Name, unter dem die Kamera im Netzwerk erreicht werden kann. Wenn du eine FritzBox im Einsatz hast, ist das z.B. KameraName.fritz.box.
                        • T todde
                          simplyclever
                          #539
                          @todde Danke! Ja, habe eine Fritzbox und ein ping der FQDN (rcam1.fritz.box) ist erfolgreich.
                          Ich habe http und https getestet. Im Adapter bleibt das 3. icon rot (Connected to device or service).
                          Und im debug log kommt dieser Fehler: Error: getaddrinfo ENOTFOUND rcam1.fritz.box: ENOTFOUND
                          Via Browser auch mit FQDN kein Erfolg.
                          Evtl. kann die E1 das nicht? Wäre jetzt nicht so tragisch; ist mehr nice-to-have.
                          Bin jetzt gleich unterwegs, werde es heute Abend noch mal versuchen.
                          W 2 Antworten Letzte Antwort
                          • S simplyclever
                            W Offline
                            W Offline
                            Wolfi
                            schrieb am zuletzt editiert von Wolfi
                            #540
                            @simplyclever
                            Kanal spielt glaube ich keine Rolle:
                            Meiner E1 läuft mit Kanal 0
                            IPAdresse:port (88)
                            http:
                            Protokolle und Port in den reolink Einstellungen aktivieren.
                            Preset funzt mit dem Adapter für die E1 nicht!
                            • S simplyclever
                              W Offline
                              W Offline
                              Wolfi
                              #541
                              @simplyclever
                              Meine E1 Outdoor steuere ich direkt via die API (Wachpunkte, preset) (das Adapter funktioniert da glaube ich noch nicht)
                              Die Befehle setze ich mit einem blockly ab.
                              https://forum.iobroker.net/topic/56116/neuer-adapter-reolink-kamera/89?_=1695403375469
                              kannst du unter Windows in einer cmd Box testen.
                              Und dann zb. via Blockly mit exec absetzen.
                              • W Wolfi
                                @simplyclever
                                IPAdresse:port (88)
                                http:
                                simplyclever
                                #542
                                Danke für Eure Hilfe!
                                In der Reolink Android App finde ich nicht die Einstellungen für Protokoll und Port.
                                Habe jetzt den Reolink Client auf meinem MacBook installiert und dort kann ich es konfigurieren.
                                Für http ist Port 80 und für https Port 443 voreingestellt.
                                Ich komme über den Browser aber nicht auf die Kamera.
                                url: https://192.168.178.91/api.cgi?cmd=GetDevInfo&channel=0&user=iob&password=xyz
                                Das PW hat nur Zahlen und Buchstaben.
                                Habe die IP mit und ohne Port versucht, http und https, und mit FQDN.
                                Es kommt immer "Safari can't connect to server 192.168.178.91"
                                Irgendwo stehe ich wohl auf dem Schlauch. Hat jemand eine Idee, woran es haken könnte?
                                • S simplyclever
                                  Tobi68
                                  schrieb am zuletzt editiert von Tobi68
                                  #543
                                  @simplyclever
                                  Schau mal am Pc im Reolink client in die Netzwerkeinstellungen.
                                  Dort muss einiges weitere Freigegeben werden.
                                  Rtsp, usw..
                                  sorry lange nicht reingeschaut..
                                  -1
                                  • Andy GrundtA Andy Grundt
                                    da ich jetzt auch Besitzer einer Reolink Kamera bin und es dafür noch keinen Adapter gibt, würde ich mich gerne an der Entwicklung eines Adapters versuchen. Zudem gibt es zu einem Reolink Adapter auch schon einen Adapter Request. (https://github.com/ioBroker/AdapterRequests/issues/596)
                                    Aktuell habe ich schon einen Prototypen entwickelt, welcher auch schon getestet werden kann: https://github.com/aendue/ioBroker.reolink
                                    Features:
                                    • Kamera Infos auslesen
                                    • Netzwerk Infos auslesen
                                    • Motion Detection überwachen
                                    Eine offizielle API Doku seitens Reolink gibt es leider nicht wirklich, dafür aber folgendes Dokument:
                                    https://drive.google.com/drive/folders/19vQBJia0wKvzwscA-EpTDSFV5OfNYUL6
                                    Über Tests und euer Feedback freue ich mich sehr.
                                    Fragen, wünsche oder Anregungen sind gerne gesehen.
                                    Viele Grüße
                                    Andy
                                    biker1602
                                    #544
                                    @andy-grundt
                                    Eine Frage funktioniert von Reolink die Argus 3 Pro+
                                    • T Tobi68
                                      @simplyclever
                                      Rtsp, usw..
                                      simplyclever
                                      #545
                                      @tobi68 Ich vermute, dass die E1 den Web Access nicht unterstüzt.
                                      Zumindest lese ich das hier so:
                                      https://support.reolink.com/hc/en-us/articles/360003981973-Remote-access-on-web-browser/
                                      Oder hat jemand eine E1 und kann über die API zugreifen? Wenn ja, wäre es nett, die Settings/Schritte hier zu teilen.
                                      • S simplyclever
                                        W Offline
                                        W Offline
                                        Wolfi
                                        #546
                                        @simplyclever
                                        Hast du eigentlich meinen Betrag für dich vom 17. oktober gelesen?
                                        Natürlich hat die E1 Outdoor ein Webinterface bzw.webaccess. Da macht du was falsch.
                                        Probier es mal am pc nicht am Tablet. Mit einem gescheiden Browser.
                                        • S simplyclever
                                          W Offline
                                          W Offline
                                          Wolfi
                                          #547
                                          @simplyclever
                                          Der Auruf des webinterface erfolgt entweder
                                          BEI http
                                          IPADRESSE:80
                                          Oder bei https
                                          IPADRESSE:443
