  4. ioBroker extrem langsam
iobrokerlangsamkeine aktualisierung möglich
95 Beiträge 8 Kommentatoren 19.0k Aufrufe 6 Beobachtet
  • S Spidermike
    *** BASE SYSTEM ***
       Static hostname: raspberrypi4-iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     19:18:03 up 44 min,  1 user,  load average: 2.13, 2.49, 2.37
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-10-16 19:18:03 CEST
               Universal time: Mon 2023-10-16 17:18:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        1.4G        5.1G        0.0K        1.3G        6.4G
    Swap:            99M          0B         99M
    Total:          7.9G        1.4G        5.2G
             7811 M total memory
             1437 M used memory
             2081 M active memory
              495 M inactive memory
             5076 M free memory
               82 M buffer memory
             1214 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      118G   23G   90G  21% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
    tmpfs          tmpfs     1.6G  904K  1.6G   1% /run
    /dev/sdb1      exfat      29G  2.7G   27G  10% /mnt/usb0
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Mon Oct 16 18:33:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:FD:BB:CC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 console=ttyS0,115200 root=PARTUUID=1045efe5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Oct 16 18:33:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Oct 16 18:33:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Oct 16 18:33:11 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,noatime
    |-/mnt/usb0 /dev/sdb1 exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    `-/boot     /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.9G    /var/
    3.9G    /var/log
    3.7G    /var/log/journal/ceda8666c83a44189d7d8b22875c3095
    486M    /var/lib
    Archived and active journals take up 3.6G in the file system.
    /opt/iobroker/backups:
    6.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    894M    /opt/iobroker/iobroker-data/
    431M    /opt/iobroker/iobroker-data/history
    324M    /opt/iobroker/iobroker-data/files
    85M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.broken
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iobroker                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iobroker                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iobroker                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iobroker                    -  enabled
      system.adapter.devices.0                : devices               : raspberrypi4-iobroker                    - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iobroker                    -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-iobroker                    -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : raspberrypi4-iobroker                    -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi4-iobroker                    - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4-iobroker                    - disabled
    + system.adapter.growatt.0                : growatt               : raspberrypi4-iobroker                    -  enabled
    + system.adapter.history.0                : history               : raspberrypi4-iobroker                    -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iobroker                    -  enabled
    + system.adapter.hs100.0                  : hs100                 : raspberrypi4-iobroker                    -  enabled
    + system.adapter.info.0                   : info                  : raspberrypi4-iobroker                    -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi4-iobroker                    -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iobroker                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iobroker                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.plenticore.0             : plenticore            : raspberrypi4-iobroker                    -  enabled, port: 80
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iobroker                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi4-iobroker                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartthings.0            : smartthings           : raspberrypi4-iobroker                    -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iobroker                    -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi4-iobroker                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tuya.0                   : tuya                  : raspberrypi4-iobroker                    - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iobroker                    - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iobroker                    -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iobroker                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspberrypi4-iobroker                    -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iobroker                    - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2414409-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "growatt"      : 3.2.1    , installed 3.2.1
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "plenticore"   : 2.2.0    , installed 2.3.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        8967
    States:         16358
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        3971       565/mosquitto
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        3948       431/influxd
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          14704      424/python
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15383      567/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16563      1093/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14996      1093/iobroker.js-co
    tcp6       0      0 :::1883                 :::*                    LISTEN      110        3972       565/mosquitto
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15385      567/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15735      1122/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17402      1712/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17488      431/influxd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14756      476/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17386      1925/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14497      398/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15923      1282/io.shelly.0
    udp        0      0 0.0.0.0:43207           0.0.0.0:*                           108        14499      398/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14769      476/dhcpcd
    udp6       0      0 :::33860                :::*                                108        14500      398/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14498      398/avahi-daemon: r
    2023-10-16 19:20:55.065  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1005Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:20:56.227  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 998Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:20:58.810  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 997Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:01.758  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 980Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:03.320  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 969Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:04.738  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 977Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:05.333  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 996Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:06.825  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1027Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:08.736  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1045Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:10.255  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1059Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:15.346  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1028Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:17.015  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1037Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:18.524  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1030Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:20.274  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1021Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:23.318  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1027Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:24.371  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1040Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:26.455  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1046Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:27.042  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1044Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:29.435  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1045Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:30.672  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1052Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:32.978  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1031Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:33.685  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1033Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:37.013  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1036Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:39.018  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 999Heiz-Stufe: 0Boilertemp: 43.8
    2023-10-16 19:21:40.270  - info: javascript.0 (1166) script.js.Warmwasser_.Test_2: Einspeisung: 0Netz-Bezug: 1002Heiz-Stufe: 0Boilertemp: 43.8
    Ich glaube das schaut jetzt ok aus, oder?
    #77
    @spidermike sagte in ioBroker extrem langsam:
    oder
    was rotiert denn da auf dem Pi?
    ist schon nicht wenig
      oder
      Spidermike
      #78
      @homoran sagte in ioBroker extrem langsam:
      oder
      was meinst Du?
      mach mir jetzt nicht angst.
      • S Spidermike
        oder
        was meinst Du?
        #79
        was meinst Du?
        dein pi ist noch gut unter Last.
        nicht grenzwertig, aber bei einer Load average durchgehend über 2 würde ich neugierig werden und wissen wollen warum
        • S Spidermike
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7811 M total memory
                   1437 M used memory
                   5076 M free memory
                     82 M buffer memory
                   1214 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          4.9G    /var/
          3.9G    /var/log
          486M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.10.1
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8967
          States:         16358
          Pending Updates: 0
          #80
          Moin,
          da spuckt ein Skript, alle Sekunde was aus, das ist sicherlich so nicht gewollt, was machst Du da, das kann auch dazu führen, dass Du einen erhöhten Load hast, also dass Dein System sich langsamer anfühlt.
          Bernd
            Moin,
            Bernd
            Spidermike
            #81
            @dp20eic sagte in ioBroker extrem langsam:
            Moin,
            Bernd
            Moin,
            das Script (zumindest das depug output) lief nur zu diesen Zeitpunkt schalte das Protokoll nur zu wenn ich schauen will was passiert.
            Ich teste das Script momentan und schaue ob die Werte und schaltungen stimmen wie es soll.
            Ist PV Überschuss zum schalten von 2 Heizstäben. Ist einer andere Sache im Forum unter Blockly Script in Diskussion.
            • S Spidermike
              Moin,
              Bernd
              Moin,
              Spidermike
              #82
              @spidermike
              aber dieser adapter bringt mir sehr oft fehlermeldungen im Protokoll.
              Aber ich denke das ist hier dann die falsche Stelle um das Problem zu diskutieren
              • S Spidermike
                @spidermike
                #83
                @spidermike
                Vor allen Dingen klatscht der im Milisekundenbereich auf den Bauch.
                Das dürfte auch die Load verursachen. Ist aber was für einen eigenen Thread.
                Da dann bitte keine bunten Bildchens sondern Textauszüge aus dem Terminal.
                  @spidermike
                  Spidermike
                  #84
                  @thomas-braun sagte in ioBroker extrem langsam:
                  @spidermike
                  @Thomas-Braun
                  da stellt du mich wieder vor Herrausforderungen,
                  ich bin über 50 jahre alt. Stehe jeden Tag um 5 Uhr auf und gehe arbeiten von 6 Uhr bis 15 Uhr (nichts zu tun mit dem hier) bin um 16 Uhr zuhause.
                  Ich bin einfach auf Eure Hilfe angewiesen denn ich verstehe ehrlich gesagt fast null was ihr hier alles leistet. (Honig ums Maul)
                  Ich bin wirklich froh das ihr mir helft,
                  Also bitte ich um rücksicht wenn ich nerve und doppelt nachfagen muss wie und was. Und hab ehrlich gesagt nicht die Zeit mich Stundenlang hinzusetzen um alles im Forum oder Internet zu suchen und zu lesen um es dann eh nicht zu verstehen.
                  Sorry Leute, bin sehr dankbar für Eure Hilfe
                  Gruß Maik
                  • S Spidermike
                    @spidermike
                    @Thomas-Braun
                    Gruß Maik
                    #85
                    soo jung war ich auch irgend wann mal.
                    willnicht kannnicht?
                    einfach lesen und Bildchen gucken
                      Spidermike
                      #86
                      ok verstehe,
                      ich bin zu blöd für mein alter und habe keine Lust (willnicht kannnicht) um zu lesen und Bildchen zu gucken weil ich einfach keine Zeit dafür habe.
                      aber trotzdem danke ich Dir @Thomas-Braun für Deine Hilfe bei meinen Problemen
                      Gruß Maik
                      • S Spidermike
                        ok verstehe,
                        Gruß Maik
                        #87
                        Die Basics muss/kann man sich aneignen. Musste ich auch irgendwann machen.
                        Logfile schaut man u. a. per
                        iob logs --watch | uniq
                        an.
                        • S Spidermike
                          ok verstehe,
                          Gruß Maik
                          #88
                          ok verstehe,
                          nicht falsch verstehen!!
                          das war es was ich andeutete.
                          Ein wenig Zeit findet sich immer.
                          und hier hilft dir jeder gerne. Dann geht's noch schneller
                            ok verstehe,
                            Spidermike
                            #89
                            ok verstehe,
                            klar für Euch ist das alles einfach weil ihr jeden Tag damit zu tun habt. Ich mache das nebebei zu meinen Job (bin selbstständig) ich bin so schon über 12 Std am arbeiten. egal
                            ich bin ja auch dankbar das es Euch gibt aber diese Hinweise "Ein wenig Zeit findet sich immer" hilft mir nicht.
                            Wenn man eine Familie mit zwei Kindern und Job hat dann ist die Zeit das größte Problem. Ich glaube da brauche nicht weiter darüber zu schreiben, wer in der gleichen Sitution ist weiß was ich meine.
                            ok lassen wir das Thema, ich schaue mal wie es mit mit meinen problemen weiter geht.
                            Danke an Euch und gute Nacht
                            • S Spidermike
                              ok verstehe,
                              #90
                              Das ist aber auch nicht mein Job hier. Meine Brötchen verdiene ich natürlich auch anders.
                              • S Spidermike
                                ok verstehe,
                                #91
                                mit 50+ hab ich noch nichts von Javascript, Linux&Co gekannt. Smarthome hatte ich nicht mal auf dem Schirm.
                                Ich hab mich auch erst mit ioBroker damit beschäftigt, auch bei 60h Wochen und länger.
                                2 Kinder & Job (mit Chefs!) hatte ich auch.
                                Und der Job hatte nicht annähernd irgendetwas mit hier dem Kram zu tun.
                                Ist alles nur Hobby nebenbei
                                genau!
                                Und deswegen bin ich sicher, dass du es auch noch hinbekommen wirst.
                                Deswegen unterstützen wir ja auch die, die erst anfangen.
                                  an.
                                  Spidermike
                                  schrieb am zuletzt editiert von Spidermike
                                  #92
                                  Hallo
                                  konnte mich erst jetzt wieder melden, sorry.
                                  hier die Auswertung
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.551  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.552  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.553  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.554  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.555  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.556  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Growatt._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at processImmediate (node:internal/timers:447:9)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]: Error: DB closed
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-10-21 11:35:54.557  - error: host.raspberrypi4-iobroker Caught by controller[15]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  das ist nur ein kleiner Ausug, bekomme es nicht alles in eine Nachricht
                                  da scheint noch mehr probleme zu geben
                                  • S Spidermike
                                    Hallo
                                    hier die Auswertung
                                    #93
                                    @Spidermike
                                    das sind ja mehrere Einträge innerhalb einer Millisekunde.
                                    ich kann da nichts zuordnen, nur
                                    Growatt._setState
                                    bleibt es wenn du den Adapter deaktivierst?
                                      @Spidermike
                                      Growatt._setState
                                      Spidermike
                                      #94
                                      @Spidermike
                                      Growatt._setState
                                      es war kurz nach einen neustart befehl "sudo reboot" weil nur dadurch bebomme ich dann relativ schnellen zugriff auf den iobroker
                                      • S Spidermike
                                        @Spidermike
                                        Growatt._setState
                                        #95
                                        Moin,
                                        meine Fantasie geht mal wieder mit mir durch, aber kann man den RasPI nicht nach einem Reboot, beim Neustart in den abgesicherten Modus hochfahren, da sollten ja dann keine Applikationen starten.
                                        Dann, einzeln die Adapter starten, die man zum Anmelden an den ioBroker braucht
                                        # iob start <adapter>
                                        Dann alle anderen ausschalten und neu booten, dann wieder ein Adapter nach dem anderen starten und schauen wie sich die Kiste verhält.
                                        Bernd
