  4. js-controller 5.0.x jetzt für alle User im STABLE!
    apollon77A
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 184.4k Aufrufe 65 Beobachtet
  • B Borio85
    Ich hoffe die summary reicht
                         v.2023-06-20
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm
            Machine ID: 9bc0d88846bd437dbec4dd93845c120d
               Boot ID: db0b2180df1e46f3a39f9fc5c13f0a15
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-20-amd64
          Architecture: x86-64
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     62
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
    /usr/lib/node_modules/npm/lib/cli.js:35
        throw err
    TypeError: Class extends value undefined is not a constructor or null
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:121:18)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
    Node.js v18.17.1
                            /usr/bin/npm
        throw err
    Node.js v18.17.1
                            /usr/bin/npx
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            8.0G        1.6G        4.5G        0.0K        1.9G        6.1G
    Swap:           974M          0B        974M
    Total:          8.9G        1.6G        5.5G
    Active iob-Instances:   18
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 7575, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                4956
    States:                 3745
    Size of iob-Database:
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    4.9M    /opt/iobroker/iobroker-data/states.jsonl
    Thomas BraunT
    Thomas BraunT
    #324
    @borio85
    Jag das node-fix-Skript aus meiner Signatur drüber.
    Und das System auf Stand halten!
      @borio85
      B
      B
      Borio85
      #325
      vielen Dank, dein Script hat geholfen iob diag sagt das es keine Probleme gibt und die Summary sieht so aus
                           v.2023-06-20
                 Chassis: vm
                 Boot ID: 1b67447b9d654caf803a3abd83c5bada
          Virtualization: kvm
                  Kernel: Linux 5.10.0-25-amd64
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                              /usr/bin/node           v18.18.0
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      MEMORY:
      Mem:            7.9G        1.2G        6.2G        0.0K        492M        6.5G
      Swap:           974M          0B        974M
      Total:          8.9G        1.2G        7.2G
      Active iob-Instances:   19
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                4956
      States:                 3761
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      6.7M    /opt/iobroker/iobroker-data/states.jsonl
      Werde mich jetzt um mein System kümmern, vielen Dank für deine Unterstützung!
      • foxriver76F
        foxriver76F
        foxriver76
        #326
        Es kommt zeitnah erst mal ins Latest ein Controller 5.0.13
        Grob folgende Änderungen:
        • Diverse Type Improvements (nur für Entwickler itneressant)
        • Besserer vis-2 Support (zB in Backups)
        • Edge Case Fehler im Backup Prozess behoben
        • getForeignObjects liefert nun wieder alle enums wenn nicht näher spezifiziert
        • Binary State Depreaction Log, loggt nun die ID des betroffenen DPs
        • Verbesserter Prozess für das finden des Config Folders (Edge Case)
        • setObjectNotExists ersetzt nun nicht erlaubte Zeichen, wie die Alternativmethoden dies bereits seit langem tun
        • Frontend Push Funktionalität nach ersten Tests weiter optimiert
        • Fehler bei multihost browse Kommando behoben
        • Es werden nicht länger alle States die auf .logging enden fehlerhaft als Log Subscriber betrachtet sondern nun noch diese in system.adapter.*.logging
        • deleteState erlaubt nun wieder die Übergabe von null für parentDevice und parentChannel
        Videotutorials & mehr
        FeuersturmF O 2 Antworten Letzte Antwort
        • foxriver76F foxriver76
          FeuersturmF
          FeuersturmF
          Feuersturm
          #327
          @foxriver76 Master + Slave erfolgreich auf 5.0.13 aktualisiert und System ist ohne Probleme gestartet. Dankeschön :-)
            O
            O
            oFbEQnpoLKKl6mbY5e13
            #328
            @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
            2023-10-08 21:15:40.356  - warn: mqtt-client.0 (9112) Used invalid characters: mqtt-client.0.stat.� 0� stat.tasmota_95F changed to mqtt-client.0.stat._0_stat.tasmota_95F
            Vielen Dank!
            • S
              S
              SaschaL
              #329
              ich habe versucht das Upgrade von js-controller 4.0.24 auf 5.0.12 durchzuführen:
              iobroker stop
              iobroker update
              iobroker fix
              iobroker upgrade self
              iobroker start
              Es kommt keine Fehlermeldung und läuft auch problemlos durch, aber am Ende ist immer noch die 4.0.24 installiert. Alle Adapter sind (soweit aufgrund der js-controller version möglich) auf Stand.
              Hier das Summary der Diagnose:
                                      v.2023-10-10
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Kernel:                 armv7l
              Userland:               armhf
              User-ID:                1000
              X-Server:               false
              Pending iob updates:    11
              Nodejs-Installation:    /usr/bin/nodejs         v14.21.3
                                      /usr/bin/node           v14.21.3
                                      /usr/bin/npm            6.14.18
                                      /usr/bin/npx            6.14.18
                                      /usr/bin/corepack       0.15.1
              Recommended versions are nodejs 16.20.2 and npm 8.19.4
              MEMORY:
              Mem:           3.8G        1.4G        1.5G        8.0M        935M        2.8G
              Swap:           99M          0B         99M
              Total:         3.9G        1.4G        1.6G
              Active iob-Instances:   24
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.68, run as: admin
              Objects:                5374
              States:                 4564
              20M     /opt/iobroker/iobroker-data/objects.jsonl
              8.3M    /opt/iobroker/iobroker-data/objects.json.migrated
              8.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
              3.7M    /opt/iobroker/iobroker-data/states.jsonl
              1.1M    /opt/iobroker/iobroker-data/states.json.migrated
              1.1M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              Was kann ich noch tun?
              Vorab vielen Dank für die Hilfe
              mcm1957M 2 Antworten Letzte Antwort
              • S SaschaL
                iobroker stop
                iobroker update
                iobroker fix
                iobroker start
                                        v.2023-10-10
                         Icon name: computer
                      Architecture: arm
                Kernel:                 armv7l
                Userland:               armhf
                User-ID:                1000
                X-Server:               false
                MEMORY:
                Swap:           99M          0B         99M
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                5374
                States:                 4564
                mcm1957M
                mcm1957M
                mcm1957
                #330
                @saschal
                Node 14 ist zu alt. Siehe Eröffnungsposting
                Aktualisiere auf node 18.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • S SaschaL
                  iobroker stop
                  iobroker update
                  iobroker fix
                  iobroker start
                                          v.2023-10-10
                           Icon name: computer
                        Architecture: arm
                  Kernel:                 armv7l
                  Userland:               armhf
                  User-ID:                1000
                  X-Server:               false
                  MEMORY:
                  Swap:           99M          0B         99M
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                5374
                  States:                 4564
                  mcm1957M
                  mcm1957M
                  mcm1957
                  #331
                  @saschal
                  Schau in signatu v thomas brakn bezügluch node fix acript. Könnte ev helfen.
                  S Thomas BraunT 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @saschal
                    S
                    S
                    SaschaL
                    #332
                    @mcm57 Super! Vielen Dank. Genau das hat geholfen und jetzt ist wieder alles auf Stand.
                    Danke und Gruß,
                    Sascha
                    • mcm1957M mcm1957
                      @saschal
                      S
                      S
                      SaschaL
                      #333
                      @mcm57 Ja, genau das war das Problem
                      Vielen Dank!
                      • mcm1957M mcm1957
                        @saschal
                        Thomas BraunT
                        Thomas BraunT
                        #334
                        @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                        @saschal
                        Und seit heute auch offiziell Familienmitglied:
                        https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
                        • S SaschaL
                          Vielen Dank!
                          Thomas BraunT
                          Thomas BraunT
                          #335
                          @saschal
                          Dein Betriebssystem Debian 10 'Buster' ist auch veraltet und muss aktualisiert werden.
                            @saschal
                            S
                            S
                            SaschaL
                            #336
                            @thomas-braun ...ich hatte befürchtet das da noch was kommt 😨 Da muss ich mich erstmal schlau machen wie das ohne Probleme und Datenverlust funktioniert.
                            Danke für den Tip
                            • S SaschaL
                              Danke für den Tip
                              Thomas BraunT
                              Thomas BraunT
                              #337
                              @saschal
                              https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                              S 2 Antworten Letzte Antwort
                                @saschal
                                S
                                S
                                SaschaL
                                #338
                                @thomas-braun Vielen Dank, da werde ich mich mal am Wochenende beschäftigen 👍
                                  @saschal
                                  mcm1957M
                                  mcm1957M
                                  mcm1957
                                  #339
                                  Alles Gute dem Nachwuchs
                                  • foxriver76F
                                    foxriver76F
                                    foxriver76
                                    #340
                                    5.0.14 zeitnah im latest verfügbar:
                                    Änderungen:
                                    • Probleme mit Compact-Mode behoben
                                    • Neue Notification Kategorie um zukünftig auf Sicherheitslücken hinzuweisen
                                    • Auto Completion für das neue Kommando iob nodejs-update [<version>] hinzugefügt
                                    • Bei Instanzen die als schedule laufen wird nun validiert ob der eingestellt Cron Job valide ist, sonst wird der Start unterbunden, bis der Cron korrigiert wurde
                                    FeuersturmF Thomas BraunT ? 3 Antworten Letzte Antwort
                                      Änderungen:
                                      FeuersturmF
                                      FeuersturmF
                                      Feuersturm
                                      #341
                                      @foxriver76 Master Slave Testsystem wurde problemlos auf 5.0.14 aktualisiert und bisher keine Probleme :-)
                                      Dankeschön
                                        Änderungen:
                                        Thomas BraunT
                                        Thomas BraunT
                                        #342
                                        Die schlägt bei mir aber gerade grundlos an.
                                        Mein Admin ist nicht von außen (direkt) erreichbar.
                                        foxriver76F W 2 Antworten Letzte Antwort
                                          Änderungen:
                                          #343
                                          @foxriver76
                                          Dankeschoen, von 5.0.13 aktualisiert, VM Debian Bookworm, Node 18.18.2, ohne Probleme.
                                          Diese Notification, dass der Admin von aussen erreichbar ist, hat mich gewundert, isser naemlich garantiert nicht..
                                          Vielleicht weil kein https aktiv ist??
                                          Edit: mal https beim Admin aktiviert, achherrjee bei knapp 50000 Objects and states eiert sich der Spinner tot.. bei den Objects.. dann gehts mal fuern paar sekunden.. wieder timeout error..
                                          beim umstellen zurueck auf http kackt der Notification manager ab, weil bei Sicherheit-Instanzen nichts eingetragen ist..
                                          :-) wie auch.. wurde ja gerade erst hinzugefuegt.. aber email geht wohl.. obwohl nix drin steht.. hmmm feature oder bug oder ..???
                                          2023-10-17 14:14:33.907  - error: admin.0 (2859955) TypeError [ERR_INVALID_URL]: Invalid URL
                                          2023-10-17 14:14:33.910  - info: notification-manager.0 (2726865) New notification on "iobroker" detected
                                          2023-10-17 14:14:33.914  - info: notification-manager.0 (2726865) Send notification "system.securityIssues" to "synochat.0"
                                          2023-10-17 14:14:35.368  - info: admin.0 (2859955) ==> Connected system.user.admin from ::ffff:192.168.0.9
                                          2023-10-17 14:14:35.373  - error: synochat.0 (2774896) Unable to send the received message '16872333' from Notification-Manager! > Request will not be processed!
                                          2023-10-17 14:14:35.374  - error: notification-manager.0 (2726865) Instance synochat.0 could not handle the notification for "system.securityIssues"
                                          2023-10-17 14:14:35.375  - info: notification-manager.0 (2726865) Send notification "system.securityIssues" to "email.0"
                                          2023-10-17 14:14:35.378  - info: email.0 (2719366) New notification received from system.adapter.notification-manager.0
                                          2023-10-17 14:14:35.442  - info: email.0 (2719366) Send email: {"subject":"Instanz hat Sicherheitsprobleme","text":"Instanz hat Probleme mit der Sicherheit und sollte überprüft werden.\n\nsystem.host.iobroker:   \nadmin.0: 10/17/2023, 2:14:33 PM\n    ","from":"topsecret@gmail.com ","to":"bloedmann@gmail.com "}
                                          2023-10-17 14:14:35.486  - info: tuya.0 (2721505) bfedd2eb6e3f7a5077nwea: Connect locally to device
                                          2023-10-17 14:14:35.487  - info: tuya.0 (2721505) bfedd2eb6e3f7a5077nwea Init with IP=10.1.5.152, Key=0d92c4914f5a16ef, Version=3.3
                                          83.9k
