  3. Einsteigerfragen
  4. Modbus nur niedrigste ID funktioniert
    5.5k
80 Beiträge 7 Kommentatoren 10.2k Aufrufe 4 Beobachtet
    @cdn hab noch editiert!
    dann bitte komplett ab Neustart
    cdn
    schrieb am zuletzt editiert von cdn
    2023-10-13 16:50:03.143 - info: host.FHEM stopInstance system.adapter.modbus.1 (force=false, process=true)
    2023-10-13 16:50:03.152 - info: modbus.1 (964) Got terminate signal TERMINATE_YOURSELF
    2023-10-13 16:50:03.154 - info: modbus.1 (964) terminating
    2023-10-13 16:50:03.156 - debug: modbus.1 (964) Plugin sentry destroyed
    2023-10-13 16:50:03.156 - info: modbus.1 (964) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-13 16:50:03.226 - info: host.FHEM stopInstance system.adapter.modbus.1 send kill signal
    2023-10-13 16:50:03.660 - info: modbus.1 (964) terminating
    2023-10-13 16:50:03.745 - info: host.FHEM instance system.adapter.modbus.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-13 16:50:06.314 - info: host.FHEM instance system.adapter.modbus.1 started with pid 980
    2023-10-13 16:50:07.806 - debug: modbus.1 (980) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-10-13 16:50:07.862 - debug: modbus.1 (980) Objects client ready ... initialize now
    2023-10-13 16:50:07.865 - debug: modbus.1 (980) Objects create System PubSub Client
    2023-10-13 16:50:07.867 - debug: modbus.1 (980) Objects create User PubSub Client
    2023-10-13 16:50:07.917 - debug: modbus.1 (980) Objects client initialize lua scripts
    2023-10-13 16:50:07.930 - debug: modbus.1 (980) Objects connected to redis: 127.0.0.1:9001
    2023-10-13 16:50:07.977 - debug: modbus.1 (980) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-10-13 16:50:07.992 - debug: modbus.1 (980) States create System PubSub Client
    2023-10-13 16:50:07.993 - debug: modbus.1 (980) States create User PubSub Client
    2023-10-13 16:50:08.065 - debug: modbus.1 (980) States connected to redis: 127.0.0.1:9000
    2023-10-13 16:50:08.158 - debug: modbus.1 (980) Plugin sentry Initialize Plugin (enabled=true)
    2023-10-13 16:50:08.706 - info: modbus.1 (980) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.18.1, js-controller: 5.0.12
    2023-10-13 16:50:08.918 - debug: modbus.1 (980) Initialize Objects for disInputs: []
    2023-10-13 16:50:08.920 - debug: modbus.1 (980) Initialize Objects for coils: []
    2023-10-13 16:50:08.920 - debug: modbus.1 (980) Initialize Objects for inputRegs: []
    2023-10-13 16:50:08.921 - debug: modbus.1 (980) Initialize Objects for holdingRegs: [{"_address":"6","name":"","description":"","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"state","room":"","poll":true,"wp":"","cw":"","isScale":"","address":6,"deviceId":25,"id":"holdingRegisters.25.6"}]
    2023-10-13 16:50:08.922 - debug: modbus.1 (980) Add holdingRegisters.25.6: {"_id":"holdingRegisters.25.6","type":"state","common":{"name":"","role":"state","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":6,"deviceId":25,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    2023-10-13 16:50:09.292 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:09.301 - info: modbus.1 (980) Connected to slave
    2023-10-13 16:50:09.302 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:09.305 - debug: modbus.1 (980) Initialization of scale factors done!
    2023-10-13 16:50:09.306 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:09.353 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:10.412 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:10.413 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:10.469 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:11.525 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:11.527 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:11.556 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:12.611 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:12.613 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:12.643 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:13.697 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:13.699 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:13.763 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:14.818 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:14.820 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:14.882 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:15.939 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:15.941 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:16.000 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:17.054 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:17.055 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:17.120 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:18.174 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:18.176 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:18.240 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:19.297 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:19.298 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:19.358 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:20.411 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:20.413 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:20.477 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:21.534 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:21.535 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:21.596 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:22.653 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:22.655 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:22.716 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:23.770 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:23.772 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:23.834 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:24.887 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:24.892 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:24.954 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:26.009 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:26.011 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:26.073 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:27.128 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:27.130 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:27.192 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 DONE
    2023-10-13 16:50:28.248 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:28.249 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:33.254 - warn: modbus.1 (980) Error: undefined
    2023-10-13 16:50:33.256 - error: modbus.1 (980) Request timed out.
    2023-10-13 16:50:33.258 - warn: modbus.1 (980) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2023-10-13 16:50:34.261 - info: modbus.1 (980) Disconnected from slave
    2023-10-13 16:50:34.266 - debug: modbus.1 (980) Clearing timeout of the current request.
    2023-10-13 16:50:34.267 - debug: modbus.1 (980) Cleaning up request fifo.
    2023-10-13 16:50:35.265 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:35.273 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:35.276 - info: modbus.1 (980) Connected to slave
    2023-10-13 16:50:35.278 - debug: modbus.1 (980) [DevID_25] Poll start ---------------------
    2023-10-13 16:50:35.279 - debug: modbus.1 (980) [DevID_25/holdingRegs] Poll address 6 - 1 registers
    2023-10-13 16:50:35.280 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:35.283 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:36.275 - info: modbus.1 (980) Disconnected from slave
    2023-10-13 16:50:36.277 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:37.278 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:37.282 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:37.287 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:38.287 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:38.291 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:38.296 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:39.296 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:39.301 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:39.303 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:40.281 - warn: modbus.1 (980) Error: undefined
    2023-10-13 16:50:40.282 - error: modbus.1 (980) Request timed out.
    2023-10-13 16:50:40.301 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:40.304 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:40.305 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:41.304 - debug: modbus.1 (980) connect to serial /dev/ttyUSB0 with 9600
    2023-10-13 16:50:41.310 - warn: modbus.1 (980) On error: {}
    2023-10-13 16:50:41.312 - warn: modbus.1 (980) On error: {}
    Nicht über FHEM wundern. Hatte hier noch alte Hardware zum testen rumfliegen ;-)
    • C cdn
      @cdn nicht dauernd editieten, während ich versuche die Zeilen zu verstehen :-)
      du pollst jede Sekunde?
      nach 20 Sekunden knallts?
      der Timeout greift nach 5 Sekunden, dazwischen wurden aber weitere Polls abgesetzt
      hast du immer noch die selben Grundeinstellungen?
      und immer noch alle tausend Adressen?
      oder pollst du nur device ID 6?
      C 1 Antwort Letzte Antwort
        cdn
        @homoran Nein ich habe zum testen eine frische Instanz mit nur einer Adresse erstellt und den Grundeinstellungen.
        Nur die Wartezeitzum erneuten verbinden habe ich runtergeschraubt auf 1s.
        Sorry, wollte nur noch etwas hinzufügen, damit nachher nichts fehlt :-)
        • C cdn
          @cdn wieviele Geräte hängen am Bus und wie sind die verdrahtet?
            cdn
            @homoran Natürlich keine Sternverdrathung. Da habe ich mich dran gehalten :-) Es sind 13 Geräte gerade.
            Interessant ist: Den Fehler hatte ich mit den beiden anderen RS485 2 ETH Geräten nicht.
            Sobald ich die Instanz dann wieder neustarte klappt es dann ja auch ohne Probleme.
            • C cdn
              @cdn sagte in Modbus nur niedrigste ID funktioniert:
              kommen auch Werte an?
              sieht man im log leider nicht?
              wieso nur Holdingregister?
              du schreibst doch nichts.
              aber 20 sekunden bis zum Error, der mit 5 Sekunden delay, sind gerade mal 15 polls.
              möglich wäre noch ein Problem mit USB
                cdn
                @homoran Ähm ja was soll ich denn sonst nehmen, anstatt holding register? Ich möchte nur die Werte auslesen.
                USB-Port habe ich schon 3 Stück durchprobiert. Dort hing bis vor kurzem ein CUL dran der ohne Probleme funktioniert hat.
                Ja Werte kommen an.
                bahnuhrB HomoranH 3 Antworten Letzte Antwort
                • C cdn
                  Ja Werte kommen an.
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Wäre nicht
                  das richtige ?!
                  Danke.
                  • C cdn
                    Ja Werte kommen an.
                    dafür sind die Inputregister
                    Holdingregister sind schreibregister
                    • C cdn
                      Ja Werte kommen an.
                      der CUL wird nicht mit dieser Datenrate gearbeitet haben.
                      Apropos: hast du mal die Baudrate hochgesetzt (oder runter, solange nur eine Adresse läuft)
                        cdn
                        @homoran Da klappt es gar nicht.
                          cdn
                          @homoran Die Melder die an dem Bus hängen unterstützen nur 9600 laut Hersteller.
                          • C cdn
                            dann verstärkt sich die Befürchtung, dass die Geräte selbst das Problem sind.
                            was steht denn in deren Anleitung?
                            bitte nochmal zum Verständnis.
                            ich dachte die "Melder" hängen an den Modbus Geräten.
                            sind die Melder eigene Modbus Geräte?
                              cdn
                              @homoran ganz genau. Die Melder sind eigene Modbusgeräte. Die Baudrate klappt auch nur mit 9600. Weder mehr, noch weniger klappt.
                              • C cdn
                                @cdn und es sind nur die Melder im Bus?
                                linear verdrahtet in Reihe?
                                mit twistet pair, abgeschirmt?
                                wie lang ist die Busleitung gesamt?
                                  cdn
                                  @homoran said in Modbus nur niedrigste ID funktioniert:
                                  Ja korrekt so ist es. Ich habe ein cat7 Kabel verwendet. Puh ich würde sagen ca. 120m. Also noch lange nicht zu lang.
                                  Komisch ist aber doch, dass es mit dem rs485 ethernet konvertern durchgehend geht, nur halt zu langsam. USB (wo ich denke, wir haben weniger Layer drüber) geht dann nach ein paar Sekunden in einen errorstate und macht nichts mehr...
                                  • C cdn
                                    mit Abschlusswiderständen?
                                    und nochmal zu Sicherheit:
                                    kein Stern (check) und auch keine Stichleitungen?
                                    An jedem Gerät höchstens 2 Leitungen?
                                    Gnd angeschlossen?
                                    an allen Geräten und am Konverter?
                                    A und B nicht vertauscht?
                                    USB
                                    welcher Konverter?
                                    mal mit /dev/by-id/ versucht?
                                      Gnd angeschlossen?
                                      USB
                                      welcher Konverter?
                                      cdn
                                      Gnd angeschlossen?
                                      Ja wirklich alles in einer Linie. GND habe ich nicht bzw. haben die Geräte auch nicht. Ich habe +,- (24V) A(+), B(-). Die Geräte sind alle aus plastik.
                                      Konverter meine ich die beiden die ich genannt habe. Einmal der von Waveshare und einmal der USR.
                                      • C cdn
                                        Gnd angeschlossen?
                                        der ist doch eth
                                        • C cdn
                                          @homoran so habe es als erstes einmal mit einem anderen Gerät getestet.
                                          U.S.R. USR-TCP232-410S Serieller zu Ethernet RS232 RS485 auf TCP Modbus RTU zu Modbus TCP Modbus Polling https://amzn.eu/d/963UUj9
                                          Antwortzeiten sind besser, das Problem an sich bleibt aber bestehen. Werde es als nächstes mit dem USB Gerät testen.
                                          #66
                                          @glasfaser https://www.amazon.de/gp/product/B0BGHVRMPJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                                          Das Ding hier
                                          beides 2eth
