  4. Nochmal Waschmaschine (Blockly)
    5.5k
153 Beiträge 18 Kommentatoren 40.7k Aufrufe 4 Beobachtet
  • rantanplanR Offline
    rantanplanR Offline
    rantanplan
    #68
    Hmm, bin etwas ratlos :(
    Beobachte mal die Variable "WaschmaschineFertig" Bleibt die auf den Status True ?
    Ich habe hier mal den Meldetext etwas erweitert.
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-737" y="-162"><mutation items="1"></mutation>
    <value name="OID0"><shadow type="field_oid" id="@Uda~stBc8L/=2DFzrvo"><field name="oid">hm-rpc.0.KEQ0964000.2.POWER</field></shadow></value>
    <statement name="STATEMENT"><block type="controls_if" id="Z5|[vDkx-;wE)n{g3h5A"><mutation elseif="2"></mutation>
        <value name="IF0"><block type="logic_operation" id="NOVG1{{6R.;TAAh#v:UO" inline="false"><field name="OP">AND</field>
            <value name="A"><block type="logic_compare" id="RDf^,X[TFQ#jOw9*+|a|"><field name="OP">GT</field>
                <value name="A"><block type="get_value" id="Y}z?|,]x;.[Y?nmoB_s/"><field name="ATTR">val</field>
                    <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value>
                <value name="B"><block type="math_number" id="+|Yj%~7wLv8n4e4dH./g"><field name="NUM">5</field></block></value></block></value>
            <value name="B"><block type="logic_compare" id=")}{w;ZbwB)k3txT,A;=#"><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="@c(1!S?xMk}JGgK|bGlx"><field name="ATTR">val</field>
                    <field name="OID">javascript.0.WaschmaschineFertig</field></block></value>
                <value name="B"><block type="logic_boolean" id="z_W;~p[!3,i7T%Fz9ta."><field name="BOOL">TRUE</field></block></value></block></value></block></value>
        <statement name="DO0"><block type="comment" id="AQ2D[:gclugPLA1/8}x!"><field name="COMMENT">Waschgang beginnt</field>
            <next><block type="control" id="TZy1bs~cU0]#Q/llGnxT"><mutation delay_input="false"></mutation>
                <value name="VALUE"><block type="logic_boolean" id="G/q*p]xf4ro}^~?xKTM:"><field name="BOOL">FALSE</field></block></value>
                <next><block type="procedures_callnoreturn" id="=!*WIp};Ta`)XeMMk,iR"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                    <value name="ARG0"><block type="text_join" id="]VT9FNVk`pS5#Pk9_mRR"><mutation items="3"></mutation>
                        <value name="ADD0"><block type="text" id="{QcAY3oi:,FGG.929?TS"><field name="TEXT">Waschmaschine läuft</field></block></value>
                        <value name="ADD1"><block type="text" id="t-]|nx8Dr4=#oNBg{nr#"><field name="TEXT"> Power=</field></block></value>
                        <value name="ADD2"><block type="get_value" id="@TX(b[*}rDsMeInQdE^w"><field name="ATTR">val</field>
                            <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value></block></next></block></next></block></statement>
        <value name="IF1"><block type="logic_operation" id="@{7k94li-JxVqj@t@gQ!" inline="false"><field name="OP">AND</field>
            <value name="A"><block type="logic_compare" id="C0*35eawvw`t+v-WVWP@"><field name="OP">GT</field>
                <value name="A"><block type="get_value" id="8R*A2%8%:I8t3Kix6XO+"><field name="ATTR">val</field>
                <value name="B"><block type="math_number" id="{Kw5XA/x9p0{z4yQ_6r3"><field name="NUM">5</field></block></value></block></value>
            <value name="B"><block type="logic_compare" id="7Uc{g8acG,c-8t`{]:L)"><field name="OP">EQ</field>
                <value name="A"><block type="variables_get" id="kY*iz1~X^Xd2p.8hJM)D"><field name="VAR">check_ready</field></block></value>
                <value name="B"><block type="logic_boolean" id=",I1.9I/cktHnk%W9z-xj"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
        <statement name="DO1"><block type="comment" id="HQL/_vWme!|w^~@lTM`U"><field name="COMMENT">Power war schon mal unter 2.5</field>
            <next><block type="comment" id="kL+[~..qKXP923)-(QTH"><field name="COMMENT">Timer wieder stoppen</field>
                <next><block type="timeouts_cleartimeout" id="CUH4u1*~,d8@=rn|d[-t"><field name="NAME">ready</field>
                    <next><block type="variables_set" id="Mpln]FVs06lI17me1NW0"><field name="VAR">check_ready</field>
                        <value name="VALUE"><block type="logic_boolean" id="MNwyF2ChG*X{lSgp0Rq4"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></statement>
        <value name="IF2"><block type="logic_operation" id="ITf[:#D]rT*N(OE9k(])" inline="false"><field name="OP">AND</field>
            <value name="A"><block type="logic_compare" id="TpC0To:j6|8MzRy1.f2k"><field name="OP">LT</field>
                <value name="A"><block type="get_value" id="T=u6bL/a/n!;dBAIYw6}"><field name="ATTR">val</field>
                <value name="B"><block type="math_number" id="G7qj]rc!Em08Z:ZUsn5x"><field name="NUM">2.5</field></block></value></block></value>
            <value name="B"><block type="logic_operation" id="t|X/`_5/NFsnY4Ej!p1@" inline="false"><field name="OP">AND</field>
                <value name="A"><block type="logic_compare" id="8rTp8F1^XtG_[nleJ@G3"><field name="OP">EQ</field>
                    <value name="A"><block type="get_value" id="e,Ywtew-),wrj7KJ4W]Y"><field name="ATTR">val</field>
                    <value name="B"><block type="logic_boolean" id="-RVml^-rH[c*)cCu4}oV"><field name="BOOL">FALSE</field></block></value></block></value>
                <value name="B"><block type="logic_compare" id="}C@yU^z*.TPRlSzP6+05"><field name="OP">EQ</field>
                    <value name="A"><block type="variables_get" id="Rf}b@/f5qTJELOy92#:g"><field name="VAR">check_ready</field></block></value>
                    <value name="B"><block type="logic_boolean" id="Qz}!muDx94x=?b`A/nhO"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value>
        <statement name="DO2"><block type="comment" id="G~cT}m2_UG;fFEXQywAM"><field name="COMMENT">Power geht unter 2.5</field>
            <next><block type="variables_set" id="@7_1gL2z!VBA_Phg+5]B"><field name="VAR">check_ready</field>
                <value name="VALUE"><block type="logic_boolean" id="4R2+st0_Td6FV?D[GPve"><field name="BOOL">TRUE</field></block></value>
                <next><block type="timeouts_cleartimeout" id="`4wEif?i7xM%Wty}?F*L"><field name="NAME">ready</field>
                    <next><block type="timeouts_settimeout" id=";F~?;,Bq-Lq[ShIwPxcD"><field name="NAME">ready</field>
                        <field name="DELAY">5</field>
                        <field name="UNIT">min</field>
                        <statement name="STATEMENT"><block type="control" id="TW.9Qyp_]qo(-{!4/W`6"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="logic_boolean" id="@ue~G;yl^o]24s](g]`5"><field name="BOOL">TRUE</field></block></value>
                            <next><block type="procedures_callnoreturn" id="B`l`+_QZ59(g^%)j}HaL"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                                <value name="ARG0"><block type="text_join" id="w[L3_.p||Ib9zKIy46Ri"><mutation items="3"></mutation>
                                    <value name="ADD0"><block type="text" id="(]@zEC}t.vRad}u(e.jr"><field name="TEXT">Die Waschmaschine ist fertig</field></block></value>
                                    <value name="ADD1"><block type="text" id="L1~*+tMXtluadyiu7av)"><field name="TEXT"> Power=</field></block></value>
                                    <value name="ADD2"><block type="get_value" id="831j%M^pYMDO*ap-DAxy"><field name="ATTR">val</field>
                                        <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement></block></statement></block>
    <block type="procedures_callnoreturn" id="IVHR(]?K6E(XAH3iw" disabled="true" x="38" y="-112"><mutation name="Melden"><arg name="Meldetext"></arg></mutation> <value name="ARG0"><block type="text_join" id="93tj,#+Z4-mx=Fv_Ve0Q"><mutation items="2"></mutation> <value name="ADD0"><block type="text" id="ln:{E)TNG?6tAh1bOVh)"><field name="TEXT">Leistung Waschmaschine</field></block></value> <value name="ADD1"><block type="get_value" id="!yLn|?I4;qOFtJ3Ga2hW"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.KEQ0964000.2.POWER</field></block></value></block></value></block> <block type="procedures_defnoreturn" id="l1.gmYNTt2#Ww;_Stf+" x="38" y="-13"><mutation><arg name="Meldetext"></arg></mutation>
    <field name="NAME">Melden</field>
    <statement name="STACK"><block type="telegram" id="qeXSX4ZqV)9r]%/aF^c-"><value name="MESSAGE"><shadow type="text" id="B[gXJTVryMHY0%3dMM-V"><field name="TEXT">text</field></shadow>
    <block type="variables_get" id="Vv@sYq]5EIaZ7]yd2=,U"><field name="VAR">Meldetext</field></block></value>
    <next><block type="sayit" id="OBX-i}?Pff]w@CV,gAOQ"><field name="INSTANCE">.0</field>
    <field name="LANGUAGE">de</field>
            <value name="MESSAGE"><shadow type="text" id="H?c?t#M!gEg`p~A-}D)p"><field name="TEXT">text</field></shadow>
              <block type="variables_get" id="vb*+mV[r3)ql7(BL,uDu"><field name="VAR">Meldetext</field></block></value>
            <next><block type="debug" id="SYQu;@N0JgE!W~[JZcZ_"><field name="Severity">log</field>
                <value name="TEXT"><shadow type="text" id="4+J8c.^+FrkDV^]dAda-"><field name="TEXT">test</field></shadow>
                  <block type="variables_get" id="KuX^Hf4/i6gnp|rmq9WR"><field name="VAR">Meldetext</field></block></value></block></next></block></next></block></statement></block></xml>
    Rantanplan
    • totocotonioT Offline
      totocotonio
      #69
      Waschmaschine gerade gestartet.
      Kein Telegramm , kein Saying.
      State= false
      sayit.0	2017-11-09 19:00:45.168	error	null
      sayit.0	2017-11-09 19:00:45.163	info	Copied file "/opt/iobroker/node_modules/iobroker.sayit/lib/../say.mp3" to "/opt/iobroker/cache/4e5d74dc5f642dd0d794de1b460e9b41.mp3"
      sayit.0	2017-11-09 19:00:44.802	info	saying: Waschmaschine läuft Power=11.58
      sayit.0	2017-11-09 19:00:43.773	info	saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
      javascript.0	2017-11-09 19:00:43.755	info	script.js.aktwaschmaschninerantanplan: Waschmaschine läuft Power=11.58
      Alles neu gestartet.
      Jetzt kam ein saying aber kein telegramm.
      Telegramm Bot , neu getartet mal sehen was passiert wenn die Maschine fertig ist.
      Gruß Totocotonio
      Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
        totocotonio
        #70
        so der Waschgang wurde beendet. Habe 10 Minten gewartet.
        Leistung 2,13 Watt.
        State ist immer noch false.
        Kein Telegramm, kein Saying
        Gruß Totocotonio
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #71
          @totocotonio:
          Leistung 2,13 Watt.
          Kein Telegramm, kein Saying `
          passiert was en du den state manuell auf true setzt ? ich moechte mal wissen ob das script ueberhaupt noch was macht (btw: anstatt auf waschmachine zu warten kannst du auch mal schnell nen staubsauger nehmen :)
            totocotonio
            #72
            wenn ich den Script auf true setzte, dann kommt die Meldung per sayit und telgramm mit Waschmaschine läuft.
            power…
            State springt direkt wieder auf false.
            Gruß Totocotonio
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #73
              @totocotonio:
              power…
              State springt direkt wieder auf false. `
              jetzt mal in meine worten:
              • Du setzt manuel den datenpunkt (also nicht script ) auf true
              • du sorgst dafuer das ein verbraucher >5 watt zieht
              • sayit geht und der datenpunkt springt auf false
              richtig ?
              Und nac 5 minuten kommt keine meldung waschmaschine fertig und state bleibt false ?
                totocotonio
                #74
                ja genau so wars es.
                Habe jetzt nochmal eine Kurzwäsche gemacht (Jetzt ist die Wäsche weg)
                Telegram Waschmaschine läuft kam, saying nicht.
                Waschmaschine fertig, nichts kam , State false
                Bin jetzt ratlos. Für heute bin ich fertig.
                Vielleicht kannst du mir helfen.
                Morgen würde ich dann den Staubsauger nehmen(gute Idee) :lol: Dann ist die Wohnung auch sauber.
                Gruß Totocotonio
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #75
                  @totocotonio:
                  Morgen würde ich dann den Staubsauger nehmen(gute Idee) :lol: Dann ist die Wohnung auch sauber. `
                  Lol ich sehe den Fehler nicht aber werde nochmal in Ruhe drüber schauen
                  Send from mobile device
                    totocotonio
                    #76
                    Das ist das Objekt das ich manuell angelegt hatte,
                    das scheint i.O. zu sein.
                    Gruß Totocotonio
                      rantanplanR Offline
                      rantanplan
                      #77
                      Wähle Deine Datenpunkte nochmal im Blockly explizit aus.
                      Vielleicht ist bei dem ganz Ex- und Import was schief gelaufen.
                      Rantanplan
                        rantanplanR Offline
                        rantanplan
                        #78
                        EDIT: Es gab noch Probleme beim Einschalten einiger Geräte. Neue Version weiter unten.
                        Bild und Export habe ich hier gelöscht.
                        Hallo
                        Ich wollte sowieso mal unsere Waschmaschine überwachen.
                        Habe das alles mal etwas zusammengerafft.
                        ACHTUNG!!
                        Die Logik hat sich zum Blockly von totocotonio geändert.
                        Bei mir geht das über die Variable "WaschmaschineAN".
                        Das hat eine umgekehrte Logik zu "WaschmaschineFertig"
                        (WaschmaschineFertig = wahr bedeutet bei mir WaschmaschineAN = unwahr)
                        "WaschmaschineAN" dient bei mir nur der Visualisierung.
                        Die POWER Werte und Länge des Timeouts muss man an seine Waschmaschine anpassen.
                        Habe auch noch ein bisschen aus der "Trickkiste" reingepackt. Ihr wollt ja lernen. ;)
                        Rantanplan
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #79
                          Zur Erklärung der trickkiste: die variabelen Wert und vorheriger Wert die rantanplan Benutzt sind die Werte des triggers.
                          Dadurch erspart man sich den Block "Wert von object xxx"
                            totocotonio
                            #80
                            gelöscht.
                            Rantanplan hat was neues gemacht
                            Gruß Totocotonio
                              totocotonio
                              #81
                              Hallo Rantanplan,
                              ich werde verrückt.
                              Ich habe dein Blockly eingebaut, angepasst.
                              Timer auf eine Miunte gstellt.
                              Fön eingebaut :lol:
                              Beim Start des Föns Meldung: läuft. OK
                              Fön aus
                              1 Minute Später Meldung: fertig. OK
                              Und jetzt 2 Minuten Später die Meldung : Läuft 😢
                              Standby Steckdose schwankt mit fön drin zwischen
                              0.03 und 0.04W
                              Wo habe ich den da meinen Denkfehler
                              Gruß Totocotonio
                                rantanplanR Offline
                                rantanplan
                                #82
                                @totocotonio:
                                Wo habe ich denn da den Denkfehler gemacht. Weil der Fön direkt wieder auf die unter 0.04 Watt geht und
                                die Leistung kleiner 2.5 watt ist. `
                                Hast Du oben mein "<0.07" auf "<0.04" gestellt?
                                Rantanplan
                                  totocotonio
                                  #83
                                  0,05 , denn wenn ich ihn auf 0.04 Stelle ändert sich der State gar nicht
                                  Auf kleiner = 0.04 W scheint es zu gehen.
                                  Gruß Totocotonio
                                    rantanplanR Offline
                                    rantanplan
                                    #84
                                    @totocotonio:
                                    0,05 , denn wenn ich ihn auf 0.04 Stelle ändert sich der State gar nicht `
                                    Steckdose aus = 0 W
                                    Steckdose ein wenn Lüfter angeschlossen = ? W
                                    Rantanplan
                                      rantanplanR Offline
                                      rantanplan
                                      #85
                                      Habe jetzt auch mal unterschiedliche Geräte an den Funkstecker gehängt.
                                      Unterschiedliche Einschaltspannungen ist ein Problem. Kann man sehr schön in der WEBUI der CCU sehen.
                                      Wenn ich mir überlege wie viel unterschiedliche Waschmaschienen es gibt. :roll:
                                      Ich denk mir was anderes aus.
                                      Rantanplan
                                        rantanplanR Offline
                                        rantanplan
                                        #86
                                        Noch ein Versuch. (sonst wird wieder mit der Hand gewaschen :D )
                                        Ich habe jetzt einige Geräte an meiner Funksteckdose angeschlossen.
                                        Problem waren die Spannungsspitzen, die einige Geräte erzeugten und dann nach kurzer Zeit auf den StandBy Level gingen.
                                        Dafür habe ich nun einen Timeout eingesetzt.
                                        Beispiel jetzt ohne viele Worte.
                                        (Ich muss zum Essen. Sonst muss ich die nächsten 4 Wochen waschen :lol: )
                                        Export.
                                        <xml xmlns="http://www.w3.org/1999/xhtml"><block type="variables_set" id="pE;t15K()B2=@=,RY5D_" x="-713" y="-137"><field name="VAR">GrenzWertInWatt</field>
                                        <value name="VALUE"><block type="math_number" id="OB=)nO2pXH:1HNwm(JpG"><field name="NUM">2.5</field></block></value>
                                        <next><block type="comment" id="|2tm%?,yK/o3_AA)J{ah"><field name="COMMENT">Steckdose überwachen</field>
                                        <next><block type="on_ext" id="n)UklDS{=z!-#^HfL@Ly"><mutation items="1"></mutation>
                                                <value name="OID0"><shadow type="field_oid" id="@Uda~stBc8L/=2DFzrvo"><field name="oid">hm-rpc.0.LEQ0661170.2.POWER</field></shadow></value>
                                                <statement name="STATEMENT"><block type="controls_if" id="=n/Jfc]x(Ib[NRPJZ%7X"><mutation elseif="3"></mutation>
                                                    <value name="IF0"><block type="logic_compare" id="?m1STicTe5=N-/f:Ji2s"><field name="OP">EQ</field>
                                                        <value name="A"><block type="on_source" id="QjKQBx`PdHENcy)eGM,5"><field name="ATTR">oldState.val</field></block></value>
                                                        <value name="B"><block type="math_number" id=":(p2PWPzD2(~R-q9upeS"><field name="NUM">0</field></block></value></block></value>
                                                    <statement name="DO0"><block type="timeouts_settimeout" id="v[ws-ZxN:-nNl,kERlT8"><field name="NAME">Einschaltverzögerung</field>
                                                        <field name="DELAY">10</field>
                                                        <statement name="STATEMENT"><block type="comment" id="UyUTD{W;Ef;u2!)%y5h|"><field name="COMMENT">Funkstecker wurde eingeschaltet</field>
                                                            <next><block type="comment" id="^wiM;VZ*5RLS-+SMsG7?"><field name="COMMENT">Einschaltleistung abfangen</field></block></next></block></statement></block></statement>
                                                    <value name="IF1"><block type="logic_operation" id="s(;r=_ekdU*dF=_Tsrbb" inline="false"><field name="OP">AND</field>
                                                        <value name="A"><block type="logic_compare" id="d_lZY_VlNaa40/Pob=Um"><field name="OP">GT</field>
                                                            <value name="A"><block type="on_source" id="`c4GU.`+o2_G+Vdxq;n/"><field name="ATTR">state.val</field></block></value>
                                                            <value name="B"><block type="variables_get" id="FD[JnQcwajuYLgGmTX`."><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
                                                        <value name="B"><block type="logic_compare" id="zC,(}TPXAvX2yd^k`W._"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id=";a;[[bw/v2oQnG9DHZIn"><field name="ATTR">val</field>
        <field name="OID">HomeStatus.0.Sonstiges.WaschmaschineAN</field></block></value>
                                                            <value name="B"><block type="logic_boolean" id=";a5=vVD`86hstjR{4y~+"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
                                                    <statement name="DO1"><block type="control" id="S6URE:3#}}.v#e!X.A4D"><mutation delay_input="false"></mutation>
                                                        <value name="VALUE"><block type="logic_boolean" id="QqpwRU?xP?P=bvS9HS[1"><field name="BOOL">TRUE</field></block></value>
                                                            <value name="ARG0"><block type="text" id="{QcAY3oi:,FGG.929?TS"><field name="TEXT">Waschmaschine LÄUFT</field></block></value></block></next></block></statement>
                                                    <value name="IF2"><block type="logic_compare" id="Yuagp|w@)mC+asceXLLu"><field name="OP">GT</field>
                                                        <value name="A"><block type="on_source" id="P(tu4AS{);E?w-p?]{1q"><field name="ATTR">state.val</field></block></value>
                                                        <value name="B"><block type="variables_get" id="ou6,Zi?vbs[;{]@93U`!"><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
                                                    <statement name="DO2"><block type="comment" id="H90l#sdGb5I}Wqsbz=9s"><field name="COMMENT">Timer stoppen</field>
                                                        <next><block type="procedures_callnoreturn" id="zo=cPu~=j#pus6bWVaJl"><mutation name="checkFertig"><arg name="parameter"></arg></mutation>
                                                            <value name="ARG0"><block type="logic_boolean" id="1SYbGS^3xkqD/Uj?{bvJ"><field name="BOOL">FALSE</field></block></value></block></next></block></statement>
                                                    <value name="IF3"><block type="logic_operation" id="_@|YxZPYI(z3![Q=ZbX4" inline="false"><field name="OP">AND</field>
                                                        <value name="A"><block type="logic_compare" id="Ge6FX#6b5WYoc;wF%%iH"><field name="OP">LT</field>
                                                            <value name="A"><block type="on_source" id="0Vw33+AwVD~={g{aHa~d"><field name="ATTR">state.val</field></block></value>
                                                            <value name="B"><block type="variables_get" id="NufLwbvZR1.fEmqJNOTZ"><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
                                                        <value name="B"><block type="logic_compare" id="X[1t=zl25bQ]aHT[:`,8"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id="4WFkiPOYU?#zQhOL)0u("><field name="ATTR">val</field>
                                                            <value name="B"><block type="logic_boolean" id="?jrLY7K)k;1?sa!Ef{VO"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                                                    <statement name="DO3"><block type="comment" id="}Q59!:8+Dc~b~LwZhq-("><field name="COMMENT">Timer starten</field>
                                                        <next><block type="procedures_callnoreturn" id=";MD%1IF[[H29g_f=vvYH"><mutation name="checkFertig"><arg name="parameter"></arg></mutation>
                                                            <value name="ARG0"><block type="logic_boolean" id="/yX*,4aU!HHUO#/2U-NR"><field name="BOOL">TRUE</field></block></value></block></next></block></statement></block></statement></block></next></block></next></block>
                                        <block type="procedures_defnoreturn" id="l1.gmYNTt2#Ww;_Stf+" x="-62" y="-37"><mutation><arg name="Meldetext"></arg></mutation> <field name="NAME">Melden</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="SYQu;@N0JgE!W~[JZcZ_"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="4+J8c.^+FrkDV^]dAda-"><field name="TEXT">test</field></shadow> <block type="variables_get" id="KuX^Hf4/i6gnp|rmq9WR"><field name="VAR">Meldetext</field></block></value> <next><block type="telegram" id="wH+*?1;8L0VjK1Z7kg[i"><value name="MESSAGE"><shadow type="text" id="%5P)E^1xJK@PFTHr7#jG"><field name="TEXT">text</field></shadow> <block type="variables_get" id="b+NYSEXrl]fx5Ms:F4Jp"><field name="VAR">Meldetext</field></block></value></block></next></block></statement></block> <block type="procedures_defnoreturn" id="sDP?w~)oJD}Z95[_?EY0" x="-62" y="163"><mutation><arg name="parameter"></arg></mutation> <field name="NAME">checkFertig</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="comment" id="V2@7jqv5RTl+}q}xfEsZ"><field name="COMMENT">Timer stoppen</field> <next><block type="timeouts_cleartimeout" id="y7iPL;/^^,*);q|%Pk6;"><field name="NAME">timeout</field> <next><block type="controls_if" id="*DX-*|5t*M5.|5Qw0p76"><value name="IF0"><block type="logic_compare" id="[-Hs2uzeFf6L7XO4:d6g"><field name="OP">EQ</field> <value name="A"><block type="variables_get" id="uT*6f!Y:?Sivq1F-y;7_"><field name="VAR">parameter</field></block></value> <value name="B"><block type="logic_boolean" id="w?1)4.uK{/ey3NJ)NjH:"><field name="BOOL">TRUE</field></block></value></block></value> <statement name="DO0"><block type="comment" id="fUTRz:hy1K[t@GmyY:"><field name="COMMENT">Timer starten</field>
                                        <next><block type="timeouts_settimeout" id="k%sy5:QdTn+3f@{OZshs"><field name="NAME">timeout</field>
                                        <field name="DELAY">3</field>
                                        <statement name="STATEMENT"><block type="control" id="UOquZ.)w|Dv~5_@iC
                                        HO"><mutation delay_input="false"></mutation>
                                        <value name="VALUE"><block type="logic_boolean" id="ttQizIf!/AB*HLfb9Kw1"><field name="BOOL">FALSE</field></block></value>
                                        <next><block type="procedures_callnoreturn" id="HHrpaU=vtt6v1JInTG~l"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                                        <value name="ARG0"><block type="text" id="leE4:W;JI@,LD;n0Gs6r"><field name="TEXT">Waschmaschine FERTIG</field></block></value></block></next></block></statement></block></next></block></statement></block></next></block></next></block></statement></block></xml>
                                        Rantanplan
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #87
                                          Dein Block bei eeinschaltverzögerung ist Lehr führt also nichts aus ?
