    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • M michael_4358
    @tt-tom
    4.10.2023, 20:12:44.109	[info ]: javascript.0 (763806) Stop script script.js.NSPanel.pdf
    4.10.2023, 20:12:45.148	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: compiling TypeScript source...
    4.10.2023, 20:12:45.520	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: source code did not change, using cached compilation result...
    4.10.2023, 20:12:45.555	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: setObjects enabled - create Alias Channels possible
    4.10.2023, 20:12:45.574	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: registered 29 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    4.10.2023, 20:12:45.597	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"dimmode~8~100~6371","ack":false,"ts":1696443165559,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165559}
    4.10.2023, 20:12:45.597	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"dimmode~8~100~6371","ack":false,"ts":1696443165559,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165559}
    4.10.2023, 20:12:45.598	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~pageStartup","ack":false,"ts":1696443165573,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165573}
    4.10.2023, 20:12:45.598	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~pageStartup","ack":false,"ts":1696443165573,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165573}
    4.10.2023, 20:12:45.654	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Desired TFT Firmware: 53 / v4.3.1
    4.10.2023, 20:12:45.654	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Installed TFT Firmware: 53 / v4.3.1
    4.10.2023, 20:12:45.739	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Debugmodus deaktiviert
    4.10.2023, 20:12:46.199	[warn ]: javascript.0 (763806)     at script.js.NSPanel.pdf:3352:46
    4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at step (script.js.NSPanel.pdf:33:23)
    4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at Object.next (script.js.NSPanel.pdf:14:53)
    4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at fulfilled (script.js.NSPanel.pdf:5:58)
    4.10.2023, 20:12:46.284	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"date~Mittwoch, 4. Oktober 2023","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.284	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"date~Mittwoch, 4. Oktober 2023","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.285	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"time~20:12","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.285	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"time~20:12","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.290	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"timeout~10","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.290	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"timeout~10","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
    4.10.2023, 20:12:46.295	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~cardEntities","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
    4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~cardEntities","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
    4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"entityUpd~Rollos~button~bPrev~~65535~~~button~bNext~~65535~~~shutter~alias.0.NSPanel.MacRollo~~64512~MacRollo~~shutter~alias.0.NSPanel.KuechenRollo~~64512~Küche~~shutter~alias.0.NSPanel.LenaRollo~~64512~Lena~~shutter~alias.0.NSPanel.SchlafRollo~~64512~Schlafzimmer~","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
    4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"entityUpd~Rollos~button~bPrev~~65535~~~button~bNext~~65535~~~shutter~alias.0.NSPanel.MacRollo~~64512~MacRollo~~shutter~alias.0.NSPanel.KuechenRollo~~64512~Küche~~shutter~alias.0.NSPanel.LenaRollo~~64512~Lena~~shutter~alias.0.NSPanel.SchlafRollo~~64512~Schlafzimmer~","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Start MQTT-Port-Check -------------------------------------
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- admin.0                   - 8081
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- hue.0                     - 443
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- lovelace.0                - 8091
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- mqtt.0                    - 1890
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- sainlogic.0               - 4500
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- shelly.0                  - 1885
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- simple-api.0              - 8087
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- sonoff.0                  - 1883
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- telegram.0                - 8443
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- zigbee.0                  - /dev
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1890
    4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: End MQTT-Port-Check ---------------------------------------
    TT-Tom
    #3900
    @michael_4358
    das Script erkennt nicht das der Ordner gelöscht ist.
    die Warnung kann ich nicht nachvollziehen.
    bist du bei discord angemeldet? dann können wir das Direkt machen.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
      michael_4358
      #3901
      Leider nein…
      Kann ich das nicht ggf selber regeln❓
      • M michael_4358
        @tt-tom said in SONOFF NSPanel mit Lovelace UI:
        @michael_4358
        zeige bitte nochmal wie es jetzt aussieht. von Alias angefangen
        na es fehlt halt der wetter Objekt Ordner und es sind keine alias da
        TT-Tom
        #3902
        @michael_4358
        wenn ich dein Screenshot nochmal ansehe, kann es sein das unter Alias.0. doch ein Wetter Ordner noch ist. das sieht halt so aus, das du nicht unter 0 stehst.
        Gruß Tom
        Public Transport
        • T TT-Tom
          @michael_4358
          michael_4358
          schrieb am zuletzt editiert von michael_4358
          #3903
          @tt-tom
          ich hab mich mal angemeldet,
          bei discord Benutzername hab ich dir geschickt
          • ArmilarA Armilar
            @michael_4358
            Das Icon wird aus dem jeweiligen DP WeatherIcon aus accuweather.0... extrahiert.
            Die Symbole sind im NSPanel selbst hinterlegt und ist ein Teil der Icons-Datei:
            https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
            Die Farbzuordnung im TS-Script unter:
            //Auto-Weather-Colors
            const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
            const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
            const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
            const swFog:            RGB = { red: 150, green: 150, blue: 150};
            const swHail:           RGB = { red: 200, green: 200, blue: 200};
            const swLightning:      RGB = { red: 200, green: 200, blue:   0};
            const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
            const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
            const swPouring:        RGB = { red:  50, green:  50, blue: 255};
            const swRainy:          RGB = { red: 100, green: 100, blue: 255};
            const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
            const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
            const swSunny:          RGB = { red: 255, green: 255, blue:   0};
            const swWindy:          RGB = { red: 150, green: 150, blue: 150};
            Das Mapping in:
            function GetAccuWeatherIcon
            und die Farbzuweisung in:
            function GetAccuWeatherIconColor
            philipp.schlueter
            #3904
            @armilar vielen Dank für deinen Support bei github 👍
            Mir ist das Panel auf dem Home screen zu bunt. Wie bekomme ich diese Beiden Glühbirnen Icons weg? 😳
            -1
            • P philipp.schlueter
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              Most Active Forum Testing
              #3905
              @philipp-schlueter
              suche mal in der Config nach mrIcon1ScreensaverEntity und mrIcon2ScreensaverEntity. Dann bei beiden null eintragen:
              mrIcon1ScreensaverEntity:
                          ScreensaverEntity: null,
                          ScreensaverEntityIconOn: 'lightbulb',
                          ScreensaverEntityIconOff: null,
                          ScreensaverEntityValue: null,
                          ScreensaverEntityValueDecimalPlace : 0,
                          ScreensaverEntityValueUnit: null,
                          ScreensaverEntityOnColor: On,
                          ScreensaverEntityOffColor: HMIOff
              P 2 Antworten Letzte Antwort
              • ArmilarA Armilar
                @philipp-schlueter
                philipp.schlueter
                #3906
                @armilar vielen Dank für die schnelle Rückmeldung, ich werde es spätestens morgen ausprobieren. 👍
                • ArmilarA Armilar
                  @philipp-schlueter
                  philipp.schlueter
                  schrieb am zuletzt editiert von philipp.schlueter
                  #3907
                  @armilar super es hat geklappt. einfach das 'lightbulb' mit "null" (ohne die tüddel) ersetzt und weg waren die icons. Ich habe auch alle Wetterfarbwerte mit 255 ersetzt. Jetzt habe ich ein komplett schwarz weißes Panel. Ich finde das sieht einfach eleganter aus. Nicht so verspielt. :) Danke nochmal für deinen schnellen support
                  • NinjaTurtle85N Offline
                    NinjaTurtle85
                    #3908
                    Wo und wie muss ich diesen PageItem eintragen?
                    <PageItem>{ id: "alias.0.NSPanel_1.Countdown", icon: "timer-outline", name: "Timer", onColor: White},
                    Das ist der popUpTimer
                    Gibt es eine Möglichkeit den hier dazu zu packen?:
                    let Kabinentemp = <PageThermo>
                        "type": "cardThermo",
                        "heading": "Kabinen Temperatur",
                        "useColor": true,
                        "subPage": false,
                        "parent": undefined,
                        "items": [
                                <PageItem>{ id: "alias.0.NSPanel.1.Thermostat_IRKabine", minValue: 250, maxValue: 800, stepValue: 50 }
                    • NinjaTurtle85N NinjaTurtle85
                          "useColor": true,
                          "subPage": false,
                          "items": [
                      TT-Tom
                      #3909
                      @ninjaturtle85
                      Nein die cardThermo ist eine eigene Page und fest. Für den Counter findest du alles im Wiki inkl. Blockly und so.
                      Gruß Tom
                      Public Transport
                      NinjaTurtle85N 1 Antwort Letzte Antwort
                      • T TT-Tom
                        @ninjaturtle85
                        NinjaTurtle85
                        #3910
                        @tt-tom danke für die Antwort,
                        Ich habe alles wie im Wiki angelegt.
                        Nur weiß ich nicht wo im TS Skript ich die PageItem eintragen muss, diese Info finde ich im Wiki nicht.
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #3911
                          @ninjaturtle85
                          Der Timer ist ein popUp und wird direkt aus einer cardEntities oder einer cardGrid aufgerufen.
                          Hier das Beispiel aus der Wiki:
                          let Radiosender = <PageGrid>
                              'type': 'cardGrid',
                              'heading': 'Büro 2',
                              'useColor': true,
                              'items': [
                                  <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
                                  <PageItem>{ id: 'alias.0.NSPanel_1.Countdown', icon: 'timer-outline', name: 'Timer', onColor: White}
                          CardGrid - WLED
                          • ArmilarA Armilar
                            @ninjaturtle85
                                'type': 'cardGrid',
                                'useColor': true,
                                'items': [
                            CardGrid - WLED
                            Tom_W
                            #3912
                            gibt es eigentlich eine Liste, welche Datenpunkte in userdate und welche aliase automatisch angelegt werden sollen.
                            Hintergrund ist der:
                            In meinem Panel ist die Seite Einstellungen/Screensaver/Dimmode leer, alle andern (Brightness z.B.) funktionieren.
                            Ich habe keine Aliase in alias.0.NSPanel.1 mit Dimmode.
                            Warum weiß ich nicht, aber ich würde die Einträge gerne erstellen, da sie auch bei einem Neustart des Skripts nicht erstellt werden.
                            • eierfeileE Offline
                              eierfeileE Offline
                              eierfeile
                              schrieb am zuletzt editiert von eierfeile
                              #3913
                              Ich erhalte täglich im NSPanel immer wieder den Hinweis, dass das Update Tasmota 13 erhältlich sei. Das muss ich auch immer bestätigen.
                              • Muss ich das Update machen?
                              • Falls nein, kann ich den Hinweis unterdrücken?
                              • Falls ja, folge ich einfach dieser Anleitung. Installiere Partition Wizard und Partition Manager, Reboot, lösche die beiden Tools wieder und mache das Tasmota13 update mit der nspanel bin. Das wars oder?
                              • T Tom_W
                                TT-Tom
                                #3914
                                @tom_w
                                eine Liste gibt es noch nicht, aber wir werden im Wiki mal eine anlegen und auch die Prüfung beschreiben.
                                hast du unter 0_userdata.0.Panelxxx folgende Datenpunkte
                                NSPanel_Dimmode_brightnessDay
                                NSPanel_Dimmode_hourDay
                                NSPanel_Dimmode_brightnessNight
                                NSPanel_Dimmode_hourNight
                                dann diese bitte löschen und das Script neu starten. Sie werden neu angelegt und die Alias dann auch.
                                Gruß Tom
                                Public Transport
                                • eierfeileE eierfeile
                                  TT-Tom
                                  #3915
                                  @eierfeile sagte in SONOFF NSPanel mit Lovelace UI:
                                  aktuell nicht, wurde durch Matter nur erweitert. Darum benötigt es jetzt mehr Platz
                                  ohne den Code zu verändern, fällt mir nix ein.
                                  das Script fragt die Tasmota Version vom Panel ab und vergleicht mit der online Version.
                                  der Wizard reicht, nach dem du ihn gestartet hast stellt er die Partition um und installiert auch das aktuelle Tasmota.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @tom_w
                                    Tom_W
                                    #3916
                                    @tt-tom
                                    Stimmt, diese hatte ich, hat auch super geklappt, danke.
                                    Woher kommt das? Vermutlich habe ich ein paar Versionen des Skripts übersprungen und dann nicht mehr alle einzelnen Update Anleitungen gelesen, oder?
                                    Ich vermute aber, dass es sehr viele gibt, die ihr Panel nicht so oft updaten und hier immer mitlesen, solche Problemchen werden also vermutlich mehrere haben?
                                    Gibt es eine Seite auf der ich alle update Anleitungen übersichtlich finde?
                                    • T Tom_W
                                      @tt-tom
                                      TT-Tom
                                      #3917
                                      @tom_w sagte in SONOFF NSPanel mit Lovelace UI:
                                      @tt-tom
                                      ja, bei großen Sprüngen kann das passieren. @Armilar weisst aber extra darauf hin, wenn es ein Breaking Changes gibt und wie das Update durchzuführen ist. Des Weiteren werden hier auch alle wichtigen Updates kommuniziert.
                                      eine Übersicht findest du im Wiki unter Changelog
                                      Gruß Tom
                                      Public Transport
                                      • P Offline
                                        philipp.schlueter
                                        #3918
                                        Okay, es gibt ein neues Problem. Auf dem Startscreen habe ich 2 Werte zu den zusätzlichen 4 im unteren Bereich. Ich möchte mir dort die Luftfeuchtigkeit und Temperaur des Wohnbereiches anzeigen.
                                         // bottomScreensaverEntity 3
                                                        ScreensaverEntity: '0_userdata.0.Datenpunkte.Wohnbereich.Luftfeuchtigkeit',
                                                        ScreensaverEntityFactor: (1000/3600),
                                                        ScreensaverEntityDecimalPlaces: 1,
                                                        ScreensaverEntityIconOn: 'water-percent',
                                                        ScreensaverEntityText: 'Luft',
                                                        ScreensaverEntityUnitText: '%',
                                                        ScreensaverEntityIconColor: White //{ 'val_min': 0, 'val_max': 120 }
                                                    // bottomScreensaverEntity 4
                                                        ScreensaverEntity: '0_userdata.0.Datenpunkte.Wohnbereich.Temperatur',
                                                        ScreensaverEntityFactor: 1,
                                                        ScreensaverEntityDecimalPlaces: 0,
                                                        ScreensaverEntityIconOn: 'temperature-celsius',
                                                        ScreensaverEntityText: 'Innen',
                                                        ScreensaverEntityUnitText: '°C',
                                        Ich habe jetzt schon alles versucht. Jetzt sind DPs hinterlegt die per Skript jede Minute auf eine runde Zahl aktualisiert werden. Auch die DPs die direkt vom Zigbee kommen werden nicht aktzeptiert. Die Windgeschwindigkeit in km/h von Accu wird auch nicht aktualisiert.
                                        Ich es hat sich nur irgendwo der Fehlerteufel eingeschlichen.
                                        Wenn ich das skript starte wird das Panel auch neu beladen. Werte aus einem Test-DP werden ebenfalls nicht übernommen
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #3919
                                          @philipp-schlueter
                                          Interessant ist die bottomScreensaverEntity 3
                                          Da ist eine Umrechnung für Geschwindigkeit (1000/3600) drin sowie Dezimalstellen = 1
                                          Mich würde mal interessieren, unter welchem Datentyp '0_userdata.0.Datenpunkte.Wohnbereich.Luftfeuchtigkeit' angelegt ist
                                          P 1 Antwort Letzte Antwort
