    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • M michael_4358
    @tt-tom
    ja
    TT-Tom
    #3896
    @michael_4358
    dann starte mal die Java Instanz bitte neu. da muss sich irgend etwas verschluckt haben.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @michael_4358
      michael_4358
      #3897
      @tt-tom
      gemacht nun hat er immer noch keine Symbole im panel :)
      • M michael_4358
        @tt-tom
        TT-Tom
        #3898
        @michael_4358
        kannst du mal das Script neu starten und die Meldungen vom Log posten
        Gruß Tom
        Public Transport
        • T TT-Tom
          @michael_4358
          michael_4358
          #3899
          @tt-tom
          4.10.2023, 20:12:44.109	[info ]: javascript.0 (763806) Stop script script.js.NSPanel.pdf
          4.10.2023, 20:12:45.148	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: compiling TypeScript source...
          4.10.2023, 20:12:45.520	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: source code did not change, using cached compilation result...
          4.10.2023, 20:12:45.555	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: setObjects enabled - create Alias Channels possible
          4.10.2023, 20:12:45.574	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: registered 29 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
          4.10.2023, 20:12:45.597	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"dimmode~8~100~6371","ack":false,"ts":1696443165559,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165559}
          4.10.2023, 20:12:45.597	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"dimmode~8~100~6371","ack":false,"ts":1696443165559,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165559}
          4.10.2023, 20:12:45.598	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~pageStartup","ack":false,"ts":1696443165573,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165573}
          4.10.2023, 20:12:45.598	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~pageStartup","ack":false,"ts":1696443165573,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443165573}
          4.10.2023, 20:12:45.654	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Desired TFT Firmware: 53 / v4.3.1
          4.10.2023, 20:12:45.654	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Installed TFT Firmware: 53 / v4.3.1
          4.10.2023, 20:12:45.739	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Debugmodus deaktiviert
          4.10.2023, 20:12:46.199	[warn ]: javascript.0 (763806)     at script.js.NSPanel.pdf:3352:46
          4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at step (script.js.NSPanel.pdf:33:23)
          4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at Object.next (script.js.NSPanel.pdf:14:53)
          4.10.2023, 20:12:46.200	[warn ]: javascript.0 (763806)     at fulfilled (script.js.NSPanel.pdf:5:58)
          4.10.2023, 20:12:46.284	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"date~Mittwoch, 4. Oktober 2023","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.284	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"date~Mittwoch, 4. Oktober 2023","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.285	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"time~20:12","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.285	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"time~20:12","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.290	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"timeout~10","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.290	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"timeout~10","ack":false,"ts":1696443166272,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166272}
          4.10.2023, 20:12:46.295	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~cardEntities","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
          4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"pageType~cardEntities","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
          4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) stateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"entityUpd~Rollos~button~bPrev~~65535~~~button~bNext~~65535~~~shutter~alias.0.NSPanel.MacRollo~~64512~MacRollo~~shutter~alias.0.NSPanel.KuechenRollo~~64512~Küche~~shutter~alias.0.NSPanel.LenaRollo~~64512~Lena~~shutter~alias.0.NSPanel.SchlafRollo~~64512~Schlafzimmer~","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
          4.10.2023, 20:12:46.296	[debug]: mqtt.0 (758904) onStateChange mqtt.0.NSPanel.cmnd.NsPanel.CustomSend: {"val":"entityUpd~Rollos~button~bPrev~~65535~~~button~bNext~~65535~~~shutter~alias.0.NSPanel.MacRollo~~64512~MacRollo~~shutter~alias.0.NSPanel.KuechenRollo~~64512~Küche~~shutter~alias.0.NSPanel.LenaRollo~~64512~Lena~~shutter~alias.0.NSPanel.SchlafRollo~~64512~Schlafzimmer~","ack":false,"ts":1696443166276,"q":0,"c":"script.js.NSPanel.pdf","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1696443166276}
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: Start MQTT-Port-Check -------------------------------------
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- admin.0                   - 8081
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- hue.0                     - 443
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- lovelace.0                - 8091
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- mqtt.0                    - 1890
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- sainlogic.0               - 4500
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- shelly.0                  - 1885
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- simple-api.0              - 8087
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- sonoff.0                  - 1883
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- telegram.0                - 8443
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: -- zigbee.0                  - /dev
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1890
          4.10.2023, 20:12:47.603	[info ]: javascript.0 (763806) script.js.NSPanel.pdf: End MQTT-Port-Check ---------------------------------------
          • M michael_4358
            @tt-tom
            TT-Tom
            #3900
            @michael_4358
            das Script erkennt nicht das der Ordner gelöscht ist.
            die Warnung kann ich nicht nachvollziehen.
            bist du bei discord angemeldet? dann können wir das Direkt machen.
            Gruß Tom
            Public Transport
              michael_4358
              #3901
              Leider nein…
              Kann ich das nicht ggf selber regeln❓
              • M michael_4358
                @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                @michael_4358
                zeige bitte nochmal wie es jetzt aussieht. von Alias angefangen
                na es fehlt halt der wetter Objekt Ordner und es sind keine alias da
                TT-Tom
                #3902
                @michael_4358
                wenn ich dein Screenshot nochmal ansehe, kann es sein das unter Alias.0. doch ein Wetter Ordner noch ist. das sieht halt so aus, das du nicht unter 0 stehst.
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @michael_4358
                  michael_4358
                  schrieb am zuletzt editiert von michael_4358
                  #3903
                  @tt-tom
                  ich hab mich mal angemeldet,
                  bei discord Benutzername hab ich dir geschickt
                  • ArmilarA Armilar
                    @michael_4358
                    Das Icon wird aus dem jeweiligen DP WeatherIcon aus accuweather.0... extrahiert.
                    Die Symbole sind im NSPanel selbst hinterlegt und ist ein Teil der Icons-Datei:
                    https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
                    Die Farbzuordnung im TS-Script unter:
                    //Auto-Weather-Colors
                    const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
                    const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
                    const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
                    const swFog:            RGB = { red: 150, green: 150, blue: 150};
                    const swHail:           RGB = { red: 200, green: 200, blue: 200};
                    const swLightning:      RGB = { red: 200, green: 200, blue:   0};
                    const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
                    const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
                    const swPouring:        RGB = { red:  50, green:  50, blue: 255};
                    const swRainy:          RGB = { red: 100, green: 100, blue: 255};
                    const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
                    const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
                    const swSunny:          RGB = { red: 255, green: 255, blue:   0};
                    const swWindy:          RGB = { red: 150, green: 150, blue: 150};
                    Das Mapping in:
                    function GetAccuWeatherIcon
                    und die Farbzuweisung in:
                    function GetAccuWeatherIconColor
                    philipp.schlueter
                    #3904
                    @armilar vielen Dank für deinen Support bei github 👍
                    Mir ist das Panel auf dem Home screen zu bunt. Wie bekomme ich diese Beiden Glühbirnen Icons weg? 😳
                    -1
                    • P philipp.schlueter
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      Most Active Forum Testing
                      #3905
                      @philipp-schlueter
                      suche mal in der Config nach mrIcon1ScreensaverEntity und mrIcon2ScreensaverEntity. Dann bei beiden null eintragen:
                      mrIcon1ScreensaverEntity:
                                  ScreensaverEntity: null,
                                  ScreensaverEntityIconOn: 'lightbulb',
                                  ScreensaverEntityIconOff: null,
                                  ScreensaverEntityValue: null,
                                  ScreensaverEntityValueDecimalPlace : 0,
                                  ScreensaverEntityValueUnit: null,
                                  ScreensaverEntityOnColor: On,
                                  ScreensaverEntityOffColor: HMIOff
                      P 2 Antworten Letzte Antwort
                      • ArmilarA Armilar
                        @philipp-schlueter
                        philipp.schlueter
                        #3906
                        @armilar vielen Dank für die schnelle Rückmeldung, ich werde es spätestens morgen ausprobieren. 👍
                        • ArmilarA Armilar
                          @philipp-schlueter
                          philipp.schlueter
                          schrieb am zuletzt editiert von philipp.schlueter
                          #3907
                          @armilar super es hat geklappt. einfach das 'lightbulb' mit "null" (ohne die tüddel) ersetzt und weg waren die icons. Ich habe auch alle Wetterfarbwerte mit 255 ersetzt. Jetzt habe ich ein komplett schwarz weißes Panel. Ich finde das sieht einfach eleganter aus. Nicht so verspielt. :) Danke nochmal für deinen schnellen support
                          • NinjaTurtle85N Offline
                            NinjaTurtle85
                            #3908
                            Wo und wie muss ich diesen PageItem eintragen?
                            <PageItem>{ id: "alias.0.NSPanel_1.Countdown", icon: "timer-outline", name: "Timer", onColor: White},
                            Das ist der popUpTimer
                            Gibt es eine Möglichkeit den hier dazu zu packen?:
                            let Kabinentemp = <PageThermo>
                                "type": "cardThermo",
                                "heading": "Kabinen Temperatur",
                                "useColor": true,
                                "subPage": false,
                                "parent": undefined,
                                "items": [
                                        <PageItem>{ id: "alias.0.NSPanel.1.Thermostat_IRKabine", minValue: 250, maxValue: 800, stepValue: 50 }
                            • NinjaTurtle85N NinjaTurtle85
                                  "useColor": true,
                                  "subPage": false,
                                  "items": [
                              TT-Tom
                              #3909
                              @ninjaturtle85
                              Nein die cardThermo ist eine eigene Page und fest. Für den Counter findest du alles im Wiki inkl. Blockly und so.
                              Gruß Tom
                              Public Transport
                              NinjaTurtle85N 1 Antwort Letzte Antwort
                              • T TT-Tom
                                @ninjaturtle85
                                NinjaTurtle85
                                #3910
                                @tt-tom danke für die Antwort,
                                Ich habe alles wie im Wiki angelegt.
                                Nur weiß ich nicht wo im TS Skript ich die PageItem eintragen muss, diese Info finde ich im Wiki nicht.
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #3911
                                  @ninjaturtle85
                                  Der Timer ist ein popUp und wird direkt aus einer cardEntities oder einer cardGrid aufgerufen.
                                  Hier das Beispiel aus der Wiki:
                                  let Radiosender = <PageGrid>
                                      'type': 'cardGrid',
                                      'heading': 'Büro 2',
                                      'useColor': true,
                                      'items': [
                                          <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
                                          <PageItem>{ id: 'alias.0.NSPanel_1.Countdown', icon: 'timer-outline', name: 'Timer', onColor: White}
                                  CardGrid - WLED
                                  • ArmilarA Armilar
                                    @ninjaturtle85
                                        'type': 'cardGrid',
                                        'useColor': true,
                                        'items': [
                                    CardGrid - WLED
                                    Tom_W
                                    #3912
                                    gibt es eigentlich eine Liste, welche Datenpunkte in userdate und welche aliase automatisch angelegt werden sollen.
                                    Hintergrund ist der:
                                    In meinem Panel ist die Seite Einstellungen/Screensaver/Dimmode leer, alle andern (Brightness z.B.) funktionieren.
                                    Ich habe keine Aliase in alias.0.NSPanel.1 mit Dimmode.
                                    Warum weiß ich nicht, aber ich würde die Einträge gerne erstellen, da sie auch bei einem Neustart des Skripts nicht erstellt werden.
                                    • eierfeileE Offline
                                      eierfeileE Offline
                                      eierfeile
                                      schrieb am zuletzt editiert von eierfeile
                                      #3913
                                      Ich erhalte täglich im NSPanel immer wieder den Hinweis, dass das Update Tasmota 13 erhältlich sei. Das muss ich auch immer bestätigen.
                                      • Muss ich das Update machen?
                                      • Falls nein, kann ich den Hinweis unterdrücken?
                                      • Falls ja, folge ich einfach dieser Anleitung. Installiere Partition Wizard und Partition Manager, Reboot, lösche die beiden Tools wieder und mache das Tasmota13 update mit der nspanel bin. Das wars oder?
                                      • T Tom_W
                                        TT-Tom
                                        #3914
                                        @tom_w
                                        eine Liste gibt es noch nicht, aber wir werden im Wiki mal eine anlegen und auch die Prüfung beschreiben.
                                        hast du unter 0_userdata.0.Panelxxx folgende Datenpunkte
                                        NSPanel_Dimmode_brightnessDay
                                        NSPanel_Dimmode_hourDay
                                        NSPanel_Dimmode_brightnessNight
                                        NSPanel_Dimmode_hourNight
                                        dann diese bitte löschen und das Script neu starten. Sie werden neu angelegt und die Alias dann auch.
                                        Gruß Tom
                                        Public Transport
                                        • eierfeileE eierfeile
                                          TT-Tom
                                          #3915
                                          @eierfeile sagte in SONOFF NSPanel mit Lovelace UI:
                                          aktuell nicht, wurde durch Matter nur erweitert. Darum benötigt es jetzt mehr Platz
                                          ohne den Code zu verändern, fällt mir nix ein.
                                          das Script fragt die Tasmota Version vom Panel ab und vergleicht mit der online Version.
                                          der Wizard reicht, nach dem du ihn gestartet hast stellt er die Partition um und installiert auch das aktuelle Tasmota.
                                          Gruß Tom
                                          Public Transport
