  4. [Gelöst] admin adapter restart loop
28 Beiträge 3 Kommentatoren 3.9k Aufrufe 3 Beobachtet
    @johnnybahama sagte in admin adapter restart loop:
    Allerdings scheint irgendwo etwas schief gegangen zu sein
    iob diag
    sagt dazu?
    JohnnyBahama
    schrieb am zuletzt editiert von JohnnyBahama
    @thomas-braun sagte in admin adapter restart loop:
    iob diag
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: raspberrypi4
             Icon name: computer
            Machine ID: 226172a9cc584d89b1963a4dd6da7a12
               Boot ID: 2494d8224bcc44c3801d8b3291358267
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     18:50:33 up 13 days,  6:46,  1 user,  load average: 0.84, 0.97, 0.80
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=47.7'C
    volt=0.8600V
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 18:50:34 CEST
               Universal time: Fri 2023-09-29 16:50:34 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           1.9G        1.3G        287M         42M        253M        416M
    Swap:           99M         95M        4.0M
    Total:         2.0G        1.4G        291M
             1872 M total memory
             1330 M used memory
              196 M active memory
             1299 M inactive memory
              287 M free memory
               18 M buffer memory
              235 M swap cache
               99 M total swap
               95 M used swap
                4 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.7G   49G  14% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M  5.3M  931M   1% /dev/shm
    tmpfs          tmpfs     937M   91M  846M  10% /run
    tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/999
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    [Sat Sep 16 12:04:21 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2A:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=87f0f292-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Sep 16 12:04:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Sep 16 12:04:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Sep 16 12:04:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    734M    /var/
    313M    /var/cache
    307M    /var/cache/apt
    248M    /var/cache/apt/archives
    140M    /var/log
    Archived and active journals take up 89.9M in the file system.
    /opt/iobroker/backups:
    843M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    349M    /opt/iobroker/iobroker-data/
    195M    /opt/iobroker/iobroker-data/files
    102M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
         18.18.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
     *** 18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   6
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4                             -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi4                             -  enabled, port: 80
    + system.adapter.denon.0                  : denon                 : raspberrypi4                             -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi4                             -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4                             -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
    + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
    + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4                             -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi4                             -  enabled, port: 443
    + system.adapter.hyperion_ng.0            : hyperion_ng           : raspberrypi4                             -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
    + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
      system.adapter.labcom.0                 : labcom                : raspberrypi4                             - disabled
      system.adapter.material.0               : material              : raspberrypi4                             - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4                             -  enabled, port: 54321
    + system.adapter.octoprint.0              : octoprint             : raspberrypi4                             -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4                             -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : raspberrypi4                             - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi4                             -  enabled
      system.adapter.statistics.0             : statistics            : raspberrypi4                             - disabled
    + system.adapter.tado.0                   : tado                  : raspberrypi4                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi4                             - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4                             - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : raspberrypi4                             - disabled
    + system.adapter.worx.0                   : worx                  : raspberrypi4                             -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "tado"         : 0.4.9    , installed 0.4.9
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        15592
    States:         13693
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15639      369/deCONZ
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        20532      738/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15871      658/sshd
    tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          15926      691/lighttpd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       58538663   25358/io.sonoff.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17769      369/deCONZ
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18028      738/pihole-FTL
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58535259   24214/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58535252   24214/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58538151   24823/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       58542569   25979/io.web.0
    tcp6       0      0 :::53                   :::*                    LISTEN      999        20534      738/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15873      658/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       58542520   25949/io.simple-api
    tcp6       0      0 :::8090                 :::*                    LISTEN      0          15927      691/lighttpd
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       58550130   26789/io.harmony.0
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18029      738/pihole-FTL
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       58550131   26789/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       58540625   25160/io.shelly.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        20531      738/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16834      617/dhcpcd
    udp        0      0 0.0.0.0:49771           0.0.0.0:*                           108        15344      352/avahi-daemon: r
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       58539682   25464/io.mihome-vac
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15342      352/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58541727   26069/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17772      369/deCONZ
    udp6       0      0 :::53                   :::*                                999        20533      738/pihole-FTL
    udp6       0      0 :::60644                :::*                                108        15345      352/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15343      352/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       58541729   26069/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       58541728   26069/io.deconz.0
    2023-09-29 18:00:00.043  - info: javascript.0 (24975) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
    2023-09-29 18:00:00.557  - info: javascript.0 (24975) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung
    2023-09-29 18:00:00.567  - info: javascript.0 (24975) Start javascript script.js.Meldungen_Pushover.Wohnungsüberwachung
    2023-09-29 18:00:00.662  - info: javascript.0 (24975) script.js.Meldungen_Pushover.Wohnungsüberwachung: registered 1 subscription, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-09-29 18:15:00.037  - info: javascript.0 (24975) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
    2023-09-29 18:22:22.074  - info: homeconnect.0 (26437) BOSCH-PXY801KW1E-68A40E49A816/programs/selected/options: There is no program selected.
    2023-09-29 18:22:22.080  - info: homeconnect.0 (26437) BOSCH-PXY801KW1E-68A40E49A816/programs/active/options: There is no program active.
    2023-09-29 18:22:22.118  - info: homeconnect.0 (26437) NEFF-D96BMV5N5-68A40E08BA18/programs/active/options: There is no program active.
    2023-09-29 18:22:22.187  - info: homeconnect.0 (26437) NEFF-D96BMV5N5-68A40E08BA18/programs/active/options: There is no program active.
    2023-09-29 18:22:26.063  - info: homeconnect.0 (26437) NEFF-D96BMV5N5-68A40E08BA18/programs/active/options: There is no program active.
    2023-09-29 18:30:00.037  - info: javascript.0 (24975) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
    2023-09-29 18:31:59.698  - info: homeconnect.0 (26437) NEFF-D96BMV5N5-68A40E08BA18/programs/active/options: There is no program active.
    2023-09-29 18:35:51.520  - info: web.0 (25979) ==> Connected system.user.admin from ::ffff:192.168.178.22
    2023-09-29 18:36:30.653  - info: admin.0 (24823) failed connection to socket.io from ::ffff:192.168.178.60: Passport was not initialized
    2023-09-29 18:36:38.699  - info: admin.0 (24823) ==> Connected system.user.admin from ::ffff:192.168.178.60
    2023-09-29 18:43:12.180  - info: web.0 (25979) <== Disconnect system.user.admin from ::ffff:192.168.178.22 vis.0
    2023-09-29 18:43:58.839  - info: admin.0 (24823) ==> Connected system.user.admin from ::ffff:192.168.178.60
    2023-09-29 18:44:02.021  - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2023-09-29 18:45:00.072  - info: javascript.0 (24975) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
    2023-09-29 18:49:48.135  - info: worx.0 (26743) Refresh token for MQTT-Connection
    2023-09-29 18:49:48.200  - info: worx.0 (26743) Disconnected
    2023-09-29 18:49:48.626  - info: worx.0 (26743) MQTT connected to: iot.eu-west-1.worxlandroid.com
    2023-09-29 18:51:50.826  - info: homeconnect.0 (26437) CONNECTED: BOSCH-PXY801KW1E-68A40E49A816
    2023-09-29 18:51:52.459  - info: homeconnect.0 (26437) BOSCH-PXY801KW1E-68A40E49A816/programs/selected: There is no program selected.
    2023-09-29 18:51:52.463  - info: homeconnect.0 (26437) BOSCH-PXY801KW1E-68A40E49A816/programs/active: There is no program active.
    iob diag has finished.
    Summary
    Pending OS-Updates:     2
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           1.9G        1.4G        271M         42M        244M        391M
    Swap:           99M         96M        3.0M
    Total:         2.0G        1.5G        275M
    Active iob-Instances:   29
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                15592
    States:                 13693
    Size of iob-Database:
    12K     /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    9.7M    /opt/iobroker/iobroker-data/states.jsonl
    2.3M    /opt/iobroker/iobroker-data/states.json.migrated
    2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    780K    /opt/iobroker/iobroker-data/states.json.old
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    • J JohnnyBahama
      iob diag
      Skript v.2023-06-20
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=47.7'C
      volt=0.8600V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M         95M        4.0M
               1872 M total memory
               1330 M used memory
                196 M active memory
                287 M free memory
                 18 M buffer memory
                235 M swap cache
                 99 M total swap
                 95 M used swap
                  4 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      734M    /var/
      313M    /var/cache
      307M    /var/cache/apt
      140M    /var/log
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15592
      States:         13693
      Pending Updates: 2
      Summary
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:           99M         96M        3.0M
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                15592
      States:                 13693
      GlasfaserG Offline
      GlasfaserG Offline
      Mem: 1.9G
      free 287M
      dein Raspberry geht in die Knie und bei den vielen Adaptern dann auch noch kein Wunder .
      • GlasfaserG Glasfaser
        Mem: 1.9G
        free 287M
        JohnnyBahama
        @glasfaser
        Ja das ist aber neu, lief jetzt Jahre ohne Probleme mit den ganzen Adaptern. Einige sind vor kurzem disabled und trotzdem stürzt der ab. Er sagt mir ja das der Loop das Problem ist und admin neu gestartet wurde. Die Meldung kommt erst seit dem update. Wie kann man den Loop herausfinden?
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
        • J JohnnyBahama
          @glasfaser
          @johnnybahama
          Ich würde auch sagen, die Kiste ist ausgereizt.
          Updates einspielen und in nächster Zeit den 'Buster' begraben und den Nachfolger neu in der 64Bit-Version installieren.
            @johnnybahama
            JohnnyBahama
            @thomas-braun Mehr adapter kommen auch nicht infrage, dennoch steht das Problem im Raum, dass der admin einen restart loop hat. Wie gesagt vor dem Update keine Probleme gehabt mit dem loop bei gleichen Adaptern
            • J JohnnyBahama
              @johnnybahama
              Im Log sieht man keinen Loop.
              • J JohnnyBahama
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @johnnybahama
                ich habe mein System in Bezug auf Node und NPM mal auf aktuellem Stand gebracht.
                Welchen sprung hast du dann gemacht , von
                10.24.0
                Laut Log :
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                Wo .. ich sehe noch die alte !
                • J Offline
                  JohnnyBahama
                  @glasfaser NPM v6.3.5; Muss ich wohl warten bis es wieder passiert. Lade dann das Log nochmal hoch.
                  • J Offline
                    JohnnyBahama
                    @Glasfaser
                    @Thomas-Braun
                    Es ist wieder passiert, hier der Log diesesmal im debug aus dem Broker:
                    2023-10-09 08:19:18.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 08:19:18.266 - info: worx.0 (3594) Disconnected
                    2023-10-09 08:19:18.614 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 08:42:37.100 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-10-09 09:15:58.160 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 09:15:58.162 - info: worx.0 (3594) Disconnected
                    2023-10-09 09:15:58.520 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 10:12:38.231 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 10:12:38.232 - info: worx.0 (3594) Disconnected
                    2023-10-09 10:12:38.600 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 10:54:00.074 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                    2023-10-09 10:54:01.439 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-10-09 11:09:18.284 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 11:09:18.286 - info: worx.0 (3594) Disconnected
                    2023-10-09 11:09:18.711 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 12:05:58.262 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 12:05:58.264 - info: worx.0 (3594) Disconnected
                    2023-10-09 12:05:58.639 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 13:02:38.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 13:02:38.266 - info: worx.0 (3594) Disconnected
                    2023-10-09 13:02:38.601 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 13:48:33.414 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                    2023-10-09 13:48:34.794 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-10-09 13:59:18.174 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 13:59:18.176 - info: worx.0 (3594) Disconnected
                    2023-10-09 13:59:18.539 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 14:55:58.210 - info: worx.0 (3594) Refresh token for MQTT-Connection
                    2023-10-09 14:55:58.212 - info: worx.0 (3594) Disconnected
                    2023-10-09 14:55:58.607 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    2023-10-09 15:00:00.055 - info: javascript.0 (1909) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                    2023-10-09 15:07:19.526 - info: admin.0 (1735) Adapter rating updated
                    2023-10-09 15:07:40.176 - info: admin.0 (1735) Request actual repository...
                    2023-10-09 15:07:41.017 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                    2023-10-09 15:07:55.157 - info: admin.0 (1735) Repository received successfully.
                    2023-10-09 15:07:55.320 - error: homeconnect.0 (3340) States database error: read ECONNRESET
                    2023-10-09 15:07:55.425 - error: worx.0 (3594) States database error: read ECONNRESET
                    2023-10-09 15:07:55.448 - error: javascript.0 (1909) States database error: read ECONNRESET
                    2023-10-09 15:07:55.532 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ambilight
                    2023-10-09 15:07:55.533 - info: javascript.0 (1909) Stop script script.js.Fernseher.Disney
                    2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ein_Ausschalten
                    2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Film
                    2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Netflix
                    2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.PS4
                    2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Umschalten
                    2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Fernseher.Youtube
                    2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Hyperion
                    2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Küche.Backofen.Rechner_Ablaufende_Zeit
                    2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.An_Aus
                    2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.Arbeitslicht
                    2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Licht.Wohnzimmer.Licht_an
                    2023-10-09 15:07:55.539 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Adapterüberwachung
                    2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Badezimmerfenster_schließen
                    2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Batteriestatus
                    2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Gartenstromversorgung_unterbrochen
                    2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Neustart
                    2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Power_Waschmaschine
                    2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Pumpe_an
                    2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Roborock
                    2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Tado_nicht_erreichbar
                    2023-10-09 15:07:55.543 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung_Cron
                    2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Pi_Hole.Deaktivieren
                    2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Roborock.Abwesenheitsreinigung
                    2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Alexa
                    2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Amelies_platz_reinigen
                    2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Einstellungen
                    2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Mülleimer_fahrt___laden
                    2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pausieren_Stoppen
                    2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pushover_Nachrichten
                    2023-10-09 15:07:55.547 - info: javascript.0 (1909) Stop script script.js.Roborock.Wartungszustand
                    2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Roborock.Zimmer_Reinigung
                    2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Abwesenheitsschließung
                    2023-10-09 15:07:55.549 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Rolladenautomatik
                    2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Terrase_schießen_verhindern
                    2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Verbrauch
                    2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Fernseher.Kino
                    2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Rasenmäher
                    2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Salzanlage_Status
                    2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Alexa.Poolwerteprüfung
                    2023-10-09 15:07:55.553 - info: javascript.0 (1909) Stop script script.js.Octoprint.Fertigmeldung
                    2023-10-09 15:07:55.554 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung
                    2023-10-09 15:07:55.274 - error: harmony.0 (3641) States database error: write EPIPE
                    2023-10-09 15:07:55.413 - info: backitup.0 (2623) cleaned everything up...
                    2023-10-09 15:07:55.411 - info: tado.0 (2927) cleaned everything up...
                    2023-10-09 15:07:55.411 - info: simple-api.0 (2807) terminating http server on port 8087
                    2023-10-09 15:07:55.416 - info: pi-hole.0 (3220) cleaned everything up...
                    2023-10-09 15:07:55.319 - error: device-reminder.0 (3424) States database error: read ECONNRESET
                    2023-10-09 15:07:55.418 - info: deconz.0 (2958) cleaned everything up...
                    2023-10-09 15:07:55.378 - error: denon.0 (3333) States database error: write EPIPE
                    2023-10-09 15:07:55.713 - info: denon.0 (3333) [END] Stopping Denon AVR adapter...
                    2023-10-09 15:07:55.348 - error: iot.0 (3002) States database error: read ECONNRESET
                    2023-10-09 15:07:55.791 - info: harmony.0 (3641) [END] Terminating
                    2023-10-09 15:07:55.912 - warn: web.0 (2876) Timeout by termination of web-extensions!
                    2023-10-09 15:07:55.922 - info: web.0 (2876) terminated http server on port 8082
                    2023-10-09 15:07:56.025 - info: iot.0 (3002) Connection changed: disconnect
                    2023-10-09 15:07:56.026 - info: iot.0 (3002) Connection lost
                    2023-10-09 15:07:56.193 - info: worx.0 (3594) Disconnected
                    2023-10-09 15:07:56.705 - error: shuttercontrol.0 (7987) States database error: write EPIPE
                    2023-10-09 15:07:56.722 - info: shuttercontrol.0 (7987) cleaned everything up...
                    2023-10-09 15:07:56.705 - error: info.0 (2870) States database error: write EPIPE
                    2023-10-09 15:07:56.720 - error: mihome-vacuum.0 (2407) States database error: write EPIPE
                    2023-10-09 15:07:56.760 - info: info.0 (2870) cleaned everything up...
                    2023-10-09 15:07:56.712 - error: hue.0 (2181) States database error: write EPIPE
                    2023-10-09 15:07:56.701 - error: pushover.0 (1939) States database error: write EPIPE
                    2023-10-09 15:07:56.717 - error: sonoff.0 (2325) States database error: write EPIPE
                    2023-10-09 15:07:56.774 - error: mihome-vacuum.0 (2407) Socket Close
                    2023-10-09 15:07:56.702 - error: shelly.0 (2068) States database error: write EPIPE
                    2023-10-09 15:07:56.736 - error: ping.0 (2467) States database error: write EPIPE
                    2023-10-09 15:07:56.726 - error: octoprint.0 (3660) States database error: write EPIPE
                    2023-10-09 15:07:56.913 - info: sony-bravia.0 (2297) terminating with timeout
                    2023-10-09 15:07:56.919 - info: sony-bravia.0 (2297) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:56.953 - info: web.0 (2876) terminating with timeout
                    2023-10-09 15:07:56.955 - info: web.0 (2876) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.033 - info: javascript.0 (1909) terminating with timeout
                    2023-10-09 15:07:57.034 - info: javascript.0 (1909) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.067 - info: hyperion_ng.0 (3062) terminating with timeout
                    2023-10-09 15:07:57.086 - info: hyperion_ng.0 (3062) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.110 - info: homeconnect.0 (3340) terminating with timeout
                    2023-10-09 15:07:57.126 - info: alexa2.0 (2661) terminating with timeout
                    2023-10-09 15:07:57.128 - info: alexa2.0 (2661) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.144 - info: backitup.0 (2623) terminating with timeout
                    2023-10-09 15:07:57.146 - info: backitup.0 (2623) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.181 - info: homeconnect.0 (3340) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.216 - info: denon.0 (3333) terminating with timeout
                    2023-10-09 15:07:57.257 - info: tado.0 (2927) terminating with timeout
                    2023-10-09 15:07:57.259 - info: tado.0 (2927) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.260 - info: deconz.0 (2958) terminating with timeout
                    2023-10-09 15:07:57.261 - info: simple-api.0 (2807) terminating with timeout
                    2023-10-09 15:07:57.262 - info: deconz.0 (2958) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.265 - info: simple-api.0 (2807) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.268 - info: pi-hole.0 (3220) terminating with timeout
                    2023-10-09 15:07:57.270 - info: pi-hole.0 (3220) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.272 - info: denon.0 (3333) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.296 - info: harmony.0 (3641) terminating with timeout
                    2023-10-09 15:07:57.324 - info: harmony.0 (3641) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.410 - info: device-reminder.0 (3424) terminating with timeout
                    2023-10-09 15:07:57.413 - info: iot.0 (3002) terminating with timeout
                    2023-10-09 15:07:57.441 - info: device-reminder.0 (3424) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.431 - info: iot.0 (3002) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:57.453 - info: worx.0 (3594) terminating with timeout
                    2023-10-09 15:07:57.468 - info: worx.0 (3594) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.210 - info: history.0 (1771) Delete old history "/opt/iobroker/history/20221008/history.denon.0.zoneMain.powerZone.json"
                    2023-10-09 15:07:58.227 - info: shuttercontrol.0 (7987) terminating with timeout
                    2023-10-09 15:07:58.230 - info: shuttercontrol.0 (7987) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:55.477 - debug: admin.0 (1735) Next repo update on 10/10/2023, 15:07:55
                    2023-10-09 15:07:58.260 - error: admin.0 (1735) States database error: write EPIPE
                    2023-10-09 15:07:58.264 - info: info.0 (2870) terminating with timeout
                    2023-10-09 15:07:58.267 - info: mihome-vacuum.0 (2407) terminating with timeout
                    2023-10-09 15:07:58.267 - info: info.0 (2870) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.269 - info: mihome-vacuum.0 (2407) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.285 - info: pushover.0 (1939) terminating with timeout
                    2023-10-09 15:07:58.291 - info: pushover.0 (1939) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.290 - info: admin.0 (1735) terminating https server on port 8081
                    2023-10-09 15:07:58.308 - info: sonoff.0 (2325) terminating with timeout
                    2023-10-09 15:07:58.310 - info: sonoff.0 (2325) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.321 - info: shelly.0 (2068) terminating with timeout
                    2023-10-09 15:07:58.323 - info: shelly.0 (2068) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.331 - info: hue.0 (2181) terminating with timeout
                    2023-10-09 15:07:58.333 - info: hue.0 (2181) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.340 - info: ping.0 (2467) terminating with timeout
                    2023-10-09 15:07:58.342 - info: ping.0 (2467) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:58.394 - info: octoprint.0 (3660) terminating with timeout
                    2023-10-09 15:07:58.397 - info: octoprint.0 (3660) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:07:59.795 - info: admin.0 (1735) terminating with timeout
                    2023-10-09 15:07:59.799 - debug: admin.0 (1735) Plugin sentry destroyed
                    2023-10-09 15:07:59.799 - info: admin.0 (1735) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:08:00.187 - error: web.0 (2876) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.196 - error: backitup.0 (2623) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.223 - error: hyperion_ng.0 (3062) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.241 - error: sony-bravia.0 (2297) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.269 - error: alexa2.0 (2661) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.270 - error: tado.0 (2927) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.265 - warn: sony-bravia.0 (2297) get state error: Connection is closed.
                    2023-10-09 15:08:00.267 - warn: sony-bravia.0 (2297) get state error: DB closed
                    2023-10-09 15:08:00.272 - info: sony-bravia.0 (2297) terminating
                    2023-10-09 15:08:00.278 - info: sony-bravia.0 (2297) terminating
                    2023-10-09 15:08:00.291 - error: pi-hole.0 (3220) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.295 - error: simple-api.0 (2807) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.335 - error: deconz.0 (2958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.348 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.362 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                    2023-10-09 15:08:00.369 - warn: pi-hole.0 (3220) get state error: Connection is closed.
                    2023-10-09 15:08:00.370 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.371 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.372 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.374 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.376 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.377 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.378 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.379 - warn: pi-hole.0 (3220) get state error: DB closed
                    2023-10-09 15:08:00.395 - info: pi-hole.0 (3220) terminating
                    2023-10-09 15:08:00.397 - info: pi-hole.0 (3220) terminating
                    2023-10-09 15:08:00.432 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.433 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.439 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.440 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.441 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.442 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.443 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.444 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.445 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.446 - warn: homeconnect.0 (3340) get state error: DB closed
                    2023-10-09 15:08:00.453 - info: homeconnect.0 (3340) terminating
                    2023-10-09 15:08:00.454 - info: homeconnect.0 (3340) terminating
                    2023-10-09 15:08:00.480 - error: javascript.0 (1909) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.539 - warn: javascript.0 (1909) get state error: DB closed
                    2023-10-09 15:08:00.539 - error: worx.0 (3594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.542 - warn: javascript.0 (1909) get state error: DB closed
                    2023-10-09 15:08:00.543 - warn: javascript.0 (1909) get state error: DB closed
                    2023-10-09 15:08:00.544 - warn: javascript.0 (1909) get state error: DB closed
                    2023-10-09 15:08:00.545 - warn: javascript.0 (1909) get state error: DB closed
                    2023-10-09 15:08:00.550 - info: javascript.0 (1909) terminating
                    2023-10-09 15:08:00.554 - warn: worx.0 (3594) get state error: DB closed
                    2023-10-09 15:08:00.557 - warn: worx.0 (3594) get state error: DB closed
                    2023-10-09 15:08:00.558 - warn: worx.0 (3594) get state error: DB closed
                    2023-10-09 15:08:00.559 - warn: worx.0 (3594) get state error: DB closed
                    2023-10-09 15:08:00.566 - info: worx.0 (3594) terminating
                    2023-10-09 15:08:00.781 - error: device-reminder.0 (3424) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.791 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.792 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.793 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.794 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.795 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.796 - warn: device-reminder.0 (3424) get state error: DB closed
                    2023-10-09 15:08:00.800 - info: device-reminder.0 (3424) terminating
                    2023-10-09 15:08:00.801 - info: device-reminder.0 (3424) terminating
                    2023-10-09 15:08:00.823 - error: denon.0 (3333) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.841 - warn: denon.0 (3333) get state error: Connection is closed.
                    2023-10-09 15:08:00.842 - warn: denon.0 (3333) get state error: DB closed
                    2023-10-09 15:08:00.843 - warn: denon.0 (3333) get state error: DB closed
                    2023-10-09 15:08:00.845 - warn: denon.0 (3333) get state error: DB closed
                    2023-10-09 15:08:00.846 - warn: denon.0 (3333) get state error: DB closed
                    2023-10-09 15:08:00.850 - info: denon.0 (3333) terminating
                    2023-10-09 15:08:00.851 - info: denon.0 (3333) terminating
                    2023-10-09 15:08:00.857 - error: harmony.0 (3641) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.875 - error: iot.0 (3002) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:00.910 - warn: harmony.0 (3641) get state error: Connection is closed.
                    2023-10-09 15:08:01.747 - error: shuttercontrol.0 (7987) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.784 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10F9B0#1.Relay1.Timer, error - DB closed
                    2023-10-09 15:08:01.801 - error: info.0 (2870) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.787 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10CD90#1.Shutter.Duration, error - DB closed
                    2023-10-09 15:08:01.788 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#F3353D#1.Shutter.Duration, error - DB closed
                    2023-10-09 15:08:01.789 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10D202#1.Shutter.Duration, error - DB closed
                    2023-10-09 15:08:01.790 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#110D76#1.Relay1.Timer, error - DB closed
                    2023-10-09 15:08:01.790 - warn: shelly.0 (2068) get state error: DB closed
                    2023-10-09 15:08:01.791 - warn: shelly.0 (2068) get state error: DB closed
                    2023-10-09 15:08:01.805 - error: pushover.0 (1939) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.822 - error: mihome-vacuum.0 (2407) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.836 - error: sonoff.0 (2325) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.842 - info: shelly.0 (2068) terminating
                    2023-10-09 15:08:01.843 - info: shelly.0 (2068) terminating
                    2023-10-09 15:08:01.874 - error: hue.0 (2181) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.881 - error: ping.0 (2467) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:01.925 - error: octoprint.0 (3660) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:03.308 - error: admin.0 (1735) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:03.318 - warn: admin.0 (1735) get state error: Connection is closed.
                    2023-10-09 15:08:03.319 - warn: admin.0 (1735) get state error: DB closed
                    2023-10-09 15:08:03.320 - warn: admin.0 (1735) get state error: DB closed
                    2023-10-09 15:08:03.321 - warn: admin.0 (1735) get state error: DB closed
                    2023-10-09 15:08:03.322 - warn: admin.0 (1735) get state error: DB closed
                    2023-10-09 15:08:03.324 - info: admin.0 (1735) terminating
                    2023-10-09 15:08:05.306 - error: pi-hole.0 (3220) Cannot check object existence of "pi-hole.0.version": Connection is closed.
                    2023-10-09 15:08:05.379 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                    2023-10-09 15:08:05.383 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:08.324 - error: admin.0 (1735) Cannot find view "system" for search "instance" : Connection is closed.
                    2023-10-09 15:08:09.759 - info: history.0 (1771) terminating with timeout
                    2023-10-09 15:08:09.763 - info: history.0 (1771) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:08:10.388 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2023-10-09 15:08:17.666 - info: host.raspberrypi4 iobroker.js-controller version 5.0.12 js-controller starting
                    2023-10-09 15:08:17.673 - info: host.raspberrypi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                    2023-10-09 15:08:17.675 - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.1
                    2023-10-09 15:08:17.675 - info: host.raspberrypi4 ip addresses: 192.168.178.70 2003:f5:f26:b900:3583:2470:ce5:f0d4 fe80::a637:87cf:1b83:c822
                    2023-10-09 15:08:20.777 - info: host.raspberrypi4 connected to Objects and States
                    2023-10-09 15:08:20.876 - info: host.raspberrypi4 added notifications configuration of host
                    2023-10-09 15:08:22.204 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeCurrent"
                    2023-10-09 15:08:22.206 - info: host.raspberrypi4 38 instances found
                    2023-10-09 15:08:22.296 - info: host.raspberrypi4 starting 28 instances
                    2023-10-09 15:08:22.491 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewest"
                    2023-10-09 15:08:22.536 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4461
                    2023-10-09 15:08:22.546 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
                    2023-10-09 15:08:22.557 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
                    2023-10-09 15:08:22.568 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
                    2023-10-09 15:08:22.578 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
                    2023-10-09 15:08:22.589 - info: host.raspberrypi4 Some obsolete host states deleted.
                    2023-10-09 15:08:26.272 - error: admin.0 (4461) admin.0 already running
                    2023-10-09 15:08:26.277 - warn: admin.0 (4461) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:26.479 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4501
                    2023-10-09 15:08:27.111 - error: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:27.112 - info: host.raspberrypi4 Restart adapter system.adapter.admin.0 because enabled
                    2023-10-09 15:08:29.053 - error: history.0 (4501) history.0 already running
                    2023-10-09 15:08:29.061 - warn: history.0 (4501) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:29.727 - error: host.raspberrypi4 instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:29.728 - info: host.raspberrypi4 Restart adapter system.adapter.history.0 because enabled
                    2023-10-09 15:08:30.543 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 4570
                    2023-10-09 15:08:34.600 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 4605
                    2023-10-09 15:08:35.010 - error: javascript.0 (4570) javascript.0 already running
                    2023-10-09 15:08:35.015 - warn: javascript.0 (4570) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:35.730 - error: host.raspberrypi4 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:35.731 - info: host.raspberrypi4 Restart adapter system.adapter.javascript.0 because enabled
                    2023-10-09 15:08:37.148 - error: pushover.0 (4605) pushover.0 already running
                    2023-10-09 15:08:37.153 - warn: pushover.0 (4605) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:37.856 - error: host.raspberrypi4 instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:37.856 - info: host.raspberrypi4 Restart adapter system.adapter.pushover.0 because enabled
                    2023-10-09 15:08:38.510 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 4672
                    2023-10-09 15:08:41.117 - error: alexa2.0 (4672) alexa2.0 already running
                    2023-10-09 15:08:41.121 - warn: alexa2.0 (4672) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:41.800 - error: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:41.800 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
                    2023-10-09 15:08:42.545 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 4706
                    2023-10-09 15:08:45.475 - error: shelly.0 (4706) shelly.0 already running
                    2023-10-09 15:08:45.479 - warn: shelly.0 (4706) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:46.194 - error: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:46.196 - info: host.raspberrypi4 Restart adapter system.adapter.shelly.0 because enabled
                    2023-10-09 15:08:46.491 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 4741
                    2023-10-09 15:08:49.352 - error: hue.0 (4741) hue.0 already running
                    2023-10-09 15:08:49.356 - warn: hue.0 (4741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:50.077 - error: host.raspberrypi4 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:50.078 - info: host.raspberrypi4 Restart adapter system.adapter.hue.0 because enabled
                    2023-10-09 15:08:50.500 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 4813
                    2023-10-09 15:08:53.519 - error: sony-bravia.0 (4813) sony-bravia.0 already running
                    2023-10-09 15:08:53.523 - warn: sony-bravia.0 (4813) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:54.203 - error: host.raspberrypi4 instance system.adapter.sony-bravia.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:54.203 - info: host.raspberrypi4 Restart adapter system.adapter.sony-bravia.0 because enabled
                    2023-10-09 15:08:54.521 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 4848
                    2023-10-09 15:08:57.007 - error: sonoff.0 (4848) sonoff.0 already running
                    2023-10-09 15:08:57.011 - warn: sonoff.0 (4848) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:08:57.299 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4883
                    2023-10-09 15:08:57.707 - error: host.raspberrypi4 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:08:57.708 - info: host.raspberrypi4 Restart adapter system.adapter.sonoff.0 because enabled
                    2023-10-09 15:08:58.511 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 4927
                    2023-10-09 15:08:59.991 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4945
                    2023-10-09 15:09:02.069 - error: mihome-vacuum.0 (4927) mihome-vacuum.0 already running
                    2023-10-09 15:09:02.076 - warn: mihome-vacuum.0 (4927) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:02.148 - info: admin.0 (4883) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:02.226 - info: admin.0 (4883) requesting all objects
                    2023-10-09 15:09:04.821 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5003
                    2023-10-09 15:09:04.935 - error: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:04.937 - info: host.raspberrypi4 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                    2023-10-09 15:09:05.363 - info: admin.0 (4883) received all objects
                    2023-10-09 15:09:05.993 - info: admin.0 (4883) Request actual repository...
                    2023-10-09 15:09:06.225 - info: admin.0 (4883) Secure socket.io server listening on port 8081
                    2023-10-09 15:09:06.241 - info: admin.0 (4883) https server listening on port 8081
                    2023-10-09 15:09:06.241 - info: admin.0 (4883) Use link "https://127.0.0.1:8081" to configure.
                    2023-10-09 15:09:06.473 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 5021
                    2023-10-09 15:09:07.317 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5038
                    2023-10-09 15:09:08.167 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 5092
                    2023-10-09 15:09:09.099 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                    2023-10-09 15:09:09.373 - info: history.0 (4945) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.history, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:11.534 - error: ping.0 (5003) ping.0 already running
                    2023-10-09 15:09:11.540 - warn: ping.0 (5003) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:11.615 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5167
                    2023-10-09 15:09:13.043 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5189
                    2023-10-09 15:09:13.099 - error: host.raspberrypi4 instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:13.100 - info: host.raspberrypi4 Restart adapter system.adapter.ping.0 because enabled
                    2023-10-09 15:09:13.392 - error: backitup.0 (5038) backitup.0 already running
                    2023-10-09 15:09:13.398 - warn: backitup.0 (5038) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:14.317 - error: host.raspberrypi4 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:14.318 - info: host.raspberrypi4 Restart adapter system.adapter.backitup.0 because enabled
                    2023-10-09 15:09:14.934 - info: host.raspberrypi4 instance system.adapter.simple-api.0 started with pid 5275
                    2023-10-09 15:09:20.498 - info: admin.0 (4883) Repository received successfully.
                    2023-10-09 15:09:21.185 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 5366
                    2023-10-09 15:09:21.419 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 5379
                    2023-10-09 15:09:21.714 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 5386
                    2023-10-09 15:09:21.856 - error: info.0 (5167) info.0 already running
                    2023-10-09 15:09:21.863 - warn: info.0 (5167) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:22.066 - error: simple-api.0 (5275) simple-api.0 already running
                    2023-10-09 15:09:22.083 - warn: simple-api.0 (5275) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:22.766 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 5399
                    2023-10-09 15:09:23.115 - error: host.raspberrypi4 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:23.116 - info: host.raspberrypi4 Restart adapter system.adapter.info.0 because enabled
                    2023-10-09 15:09:23.341 - error: host.raspberrypi4 instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:23.342 - info: host.raspberrypi4 Restart adapter system.adapter.simple-api.0 because enabled
                    2023-10-09 15:09:23.423 - info: pushover.0 (5092) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:23.705 - info: javascript.0 (5021) starting. Version 7.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:24.059 - info: alexa2.0 (5189) starting. Version 3.25.2 (non-npm: Apollon77/ioBroker.alexa2#2f00d64d7149f65565470bf222734cab76e303ec) in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:24.583 - info: alexa2.0 (5189) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                    2023-10-09 15:09:26.947 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 5454
                    2023-10-09 15:09:27.615 - info: javascript.0 (5021) requesting all states
                    2023-10-09 15:09:27.619 - info: javascript.0 (5021) requesting all objects
                    2023-10-09 15:09:29.302 - info: alexa2.0 (5189) Update cookie in adapter configuration ... restarting ...
                    2023-10-09 15:09:31.235 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 5531
                    2023-10-09 15:09:31.555 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 (force=false, process=true)
                    2023-10-09 15:09:31.814 - info: javascript.0 (5021) received all objects
                    2023-10-09 15:09:32.123 - info: javascript.0 (5021) received all states
                    2023-10-09 15:09:32.135 - info: alexa2.0 (5189) Got terminate signal TERMINATE_YOURSELF
                    2023-10-09 15:09:32.148 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 send kill signal
                    2023-10-09 15:09:32.143 - info: alexa2.0 (5189) terminating
                    2023-10-09 15:09:32.166 - info: alexa2.0 (5189) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-09 15:09:32.557 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 5544
                    2023-10-09 15:09:32.670 - info: alexa2.0 (5189) terminating
                    2023-10-09 15:09:32.878 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 5551
                    2023-10-09 15:09:33.191 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 killing pid 5189
                    2023-10-09 15:09:33.247 - error: web.0 (5379) web.0 already running
                    2023-10-09 15:09:33.256 - warn: web.0 (5379) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:34.968 - error: tado.0 (5399) tado.0 already running
                    2023-10-09 15:09:34.976 - warn: tado.0 (5399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:35.951 - error: host.raspberrypi4 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:35.953 - info: host.raspberrypi4 Restart adapter system.adapter.web.0 because enabled
                    2023-10-09 15:09:36.784 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 5592
                    2023-10-09 15:09:37.084 - error: host.raspberrypi4 instance system.adapter.tado.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:37.085 - info: host.raspberrypi4 Restart adapter system.adapter.tado.0 because enabled
                    2023-10-09 15:09:37.477 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 5609
                    2023-10-09 15:09:37.823 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5616
                    2023-10-09 15:09:39.022 - error: deconz.0 (5531) deconz.0 already running
                    2023-10-09 15:09:39.027 - warn: deconz.0 (5531) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:39.453 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 5667
                    2023-10-09 15:09:40.033 - error: iot.0 (5551) iot.0 already running
                    2023-10-09 15:09:40.047 - warn: iot.0 (5551) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:40.543 - error: host.raspberrypi4 instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:40.546 - info: host.raspberrypi4 Restart adapter system.adapter.deconz.0 because enabled
                    2023-10-09 15:09:41.055 - error: host.raspberrypi4 instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:41.056 - info: host.raspberrypi4 Restart adapter system.adapter.iot.0 because enabled
                    2023-10-09 15:09:42.156 - error: hyperion_ng.0 (5592) hyperion_ng.0 already running
                    2023-10-09 15:09:42.161 - warn: hyperion_ng.0 (5592) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:42.219 - info: hue.0 (5386) starting. Version 3.10.0 in /opt/iobroker/node_modules/iobroker.hue, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:42.237 - info: shelly.0 (5366) starting. Version 6.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:43.424 - info: hue.0 (5386) Push connection established
                    2023-10-09 15:09:43.769 - error: host.raspberrypi4 instance system.adapter.hyperion_ng.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:43.780 - info: host.raspberrypi4 Restart adapter system.adapter.hyperion_ng.0 because enabled
                    2023-10-09 15:09:44.343 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5734
                    2023-10-09 15:09:45.388 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5747
                    2023-10-09 15:09:45.991 - error: shuttercontrol.0 (5667) shuttercontrol.0 already running
                    2023-10-09 15:09:46.002 - warn: shuttercontrol.0 (5667) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:46.430 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 5764
                    2023-10-09 15:09:47.187 - error: host.raspberrypi4 instance system.adapter.shuttercontrol.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:47.188 - info: host.raspberrypi4 Restart adapter system.adapter.shuttercontrol.0 because enabled
                    2023-10-09 15:09:52.766 - error: pi-hole.0 (5764) pi-hole.0 already running
                    2023-10-09 15:09:52.784 - warn: pi-hole.0 (5764) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:55.371 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5896
                    2023-10-09 15:09:55.429 - error: host.raspberrypi4 instance system.adapter.pi-hole.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:55.430 - info: host.raspberrypi4 Restart adapter system.adapter.pi-hole.0 because enabled
                    2023-10-09 15:09:56.413 - info: vis.0 (5727) Terminated (NO_ERROR): Without reason
                    2023-10-09 15:09:56.632 - error: denon.0 (5862) denon.0 already running
                    2023-10-09 15:09:56.641 - warn: denon.0 (5862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:09:56.934 - info: ping.0 (5734) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:09:59.473 - info: host.raspberrypi4 instance system.adapter.vis.0 terminated while should be started once
                    2023-10-09 15:09:59.995 - error: host.raspberrypi4 instance system.adapter.denon.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:09:59.996 - info: host.raspberrypi4 Restart adapter system.adapter.denon.0 because enabled
                    2023-10-09 15:10:04.282 - error: homeconnect.0 (5915) homeconnect.0 already running
                    2023-10-09 15:10:04.291 - warn: homeconnect.0 (5915) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:10:05.585 - error: device-reminder.0 (6014) device-reminder.0 already running
                    2023-10-09 15:10:05.593 - warn: device-reminder.0 (6014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:10:06.078 - error: host.raspberrypi4 instance system.adapter.homeconnect.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:10:06.979 - info: host.raspberrypi4 instance system.adapter.harmony.0 started with pid 6106
                    2023-10-09 15:10:07.062 - error: host.raspberrypi4 instance system.adapter.device-reminder.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:10:07.063 - info: host.raspberrypi4 Restart adapter system.adapter.device-reminder.0 because enabled
                    2023-10-09 15:10:07.129 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 6118
                    2023-10-09 15:10:07.759 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 6130
                    2023-10-09 15:10:08.603 - info: simple-api.0 (5908) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:08.809 - warn: simple-api.0 (5908) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                    2023-10-09 15:10:08.895 - info: simple-api.0 (5908) simpleAPI server listening on port 8087
                    2023-10-09 15:10:08.897 - info: simple-api.0 (5908) Allow states only when user is owner: false
                    2023-10-09 15:10:08.927 - info: simple-api.0 (5908) http server listening on port 8087
                    2023-10-09 15:10:09.091 - info: backitup.0 (5747) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:09.988 - info: backitup.0 (5747) [iobroker] backup will be activated at 02:40 every 1 day(s)
                    2023-10-09 15:10:11.599 - error: worx.0 (6085) worx.0 already running
                    2023-10-09 15:10:11.611 - warn: worx.0 (6085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:10:11.818 - info: host.raspberrypi4 instance system.adapter.octoprint.0 started with pid 6206
                    2023-10-09 15:10:12.009 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 6216
                    2023-10-09 15:10:12.314 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 6228
                    2023-10-09 15:10:13.226 - error: host.raspberrypi4 instance system.adapter.worx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:10:13.257 - info: host.raspberrypi4 Restart adapter system.adapter.worx.0 because enabled
                    2023-10-09 15:10:15.518 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 6257
                    2023-10-09 15:10:16.612 - error: harmony.0 (6106) harmony.0 already running
                    2023-10-09 15:10:16.620 - warn: harmony.0 (6106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:10:18.718 - error: host.raspberrypi4 instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:10:18.719 - info: host.raspberrypi4 Restart adapter system.adapter.harmony.0 because enabled
                    2023-10-09 15:10:19.320 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 6304
                    2023-10-09 15:10:20.117 - error: octoprint.0 (6206) octoprint.0 already running
                    2023-10-09 15:10:20.134 - warn: octoprint.0 (6206) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                    2023-10-09 15:10:21.821 - error: host.raspberrypi4 instance system.adapter.octoprint.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                    2023-10-09 15:10:21.822 - info: host.raspberrypi4 Restart adapter system.adapter.octoprint.0 because enabled
                    2023-10-09 15:10:23.534 - info: web.0 (6118) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:23.633 - info: tado.0 (6130) starting. Version 0.4.9 in /opt/iobroker/node_modules/iobroker.tado, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:23.787 - info: hyperion_ng.0 (6257) starting. Version 0.1.23 (non-npm: felixganzer/ioBroker.hyperion_ng#b27f55704d34a7eed2865ca421409d091d86cd38) in /opt/iobroker/node_modules/iobroker.hyperion_ng, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:23.856 - info: hyperion_ng.0 (6257) create Control Parameter
                    2023-10-09 15:10:23.720 - info: tado.0 (6130) Started with JSON-Explorer version 0.1.12
                    2023-10-09 15:10:24.450 - info: tado.0 (6130) Connected to Tado cloud, initialyzing...
                    2023-10-09 15:10:24.456 - info: sony-bravia.0 (5454) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.sony-bravia, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:24.727 - info: web.0 (6118) socket.io server listening on port 8082
                    2023-10-09 15:10:24.761 - info: web.0 (6118) http server listening on port 8082
                    2023-10-09 15:10:25.033 - info: deconz.0 (6216) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:25.075 - info: hyperion_ng.0 (6257) 210,0.5000000000000001,0.39215686274509803
                    2023-10-09 15:10:25.582 - info: deconz.0 (6216) deConz Version: 2.22.2; API version: 1.16.0
                    2023-10-09 15:10:25.806 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 6469
                    2023-10-09 15:10:26.007 - info: hyperion_ng.0 (6257) socket is connected
                    2023-10-09 15:10:28.243 - info: iot.0 (6228) starting. Version 1.14.5 in /opt/iobroker/node_modules/iobroker.iot, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:28.796 - info: iot.0 (6228) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2023-10-09 15:10:31.212 - info: host.raspberrypi4 instance system.adapter.denon.0 started with pid 6552
                    2023-10-09 15:10:32.365 - info: iot.0 (6228) Connection changed: connect
                    2023-10-09 15:10:32.854 - info: info.0 (5896) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:33.435 - info: pi-hole.0 (6469) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:33.627 - info: info.0 (5896) Reading/updating systemdata.
                    2023-10-09 15:10:35.029 - info: hyperion_ng.0 (6257) read out components finished
                    2023-10-09 15:10:36.567 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.blue" has to be stringified but received type "object"
                    2023-10-09 15:10:36.708 - info: host.raspberrypi4 instance system.adapter.homeconnect.0 started with pid 6619
                    2023-10-09 15:10:37.014 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.cyan" has to be stringified but received type "object"
                    2023-10-09 15:10:37.767 - info: host.raspberrypi4 instance system.adapter.device-reminder.0 started with pid 6636
                    2023-10-09 15:10:38.027 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.green" has to be stringified but received type "object"
                    2023-10-09 15:10:38.324 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.magenta" has to be stringified but received type "object"
                    2023-10-09 15:10:38.521 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.red" has to be stringified but received type "object"
                    2023-10-09 15:10:38.783 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.white" has to be stringified but received type "object"
                    2023-10-09 15:10:38.946 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.yellow" has to be stringified but received type "object"
                    2023-10-09 15:10:38.984 - info: shuttercontrol.0 (6304) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:39.001 - info: hyperion_ng.0 (6257) read out Adjustments finished
                    2023-10-09 15:10:39.428 - info: hyperion_ng.0 (6257) create priorities
                    2023-10-09 15:10:40.347 - info: denon.0 (6552) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.denon, node: v18.17.1, js-controller: 5.0.12
                    2023-10-09 15:10:40.442 - info: denon.0 (6552) [START] Starting DENON AVR adapter
                    2023-10-09 15:10:40.448 - info: denon.0 (6552) [CONNECT] Trying to connect to 192.168.178.37:23
                    2023-10-09 15:10:40.482 - info: denon.0 (6552) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.37:23
                    2023-10-09 15:10:40.820 - info: hyperion_ng.0 (6257) read out priorities finished
                    2023-10-09 15:10:41.173 - info: hyperion_ng.0 (6257) create effects
                    2023-10-09 15:10:41.637 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                    2023-10-09 15:10:44.059 - info: host.raspberrypi4 instance system.adapter.worx.0 started with pid 6764
                    2023-10-09 15:10:44.827 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                    2023-10-09 15:10:44.998 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                    2023-10-09 15:10:45.148 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                    2023-10-09 15:10:45.294 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                    Aus dem Iob diag
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                       Static hostname: raspberrypi4
                             Icon name: computer
                            Machine ID: 226172a9cc584d89b1963a4dd6da7a12
                               Boot ID: 8e888aa4fd59407dbddcad5931c7d04e
                      Operating System: Raspbian GNU/Linux 10 (buster)
                                Kernel: Linux 5.10.103-v7l+
                          Architecture: arm
                    Model           : Raspberry Pi 4 Model B Rev 1.4
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : armhf
                    Systemuptime and Load:
                     17:06:24 up 3 days,  2:00,  1 user,  load average: 1.33, 0.92, 0.73
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    Other values than 0x0 hint to temperature/voltage problems
                    temp=46.7'C
                    volt=0.8600V
                    *** Time and Time Zones ***
                                   Local time: Mon 2023-10-09 17:06:25 CEST
                               Universal time: Mon 2023-10-09 15:06:25 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           1.9G        1.3G        152M         95M        451M        419M
                    Swap:           99M         24M         75M
                    Total:         2.0G        1.3G        227M
                             1872 M total memory
                             1268 M used memory
                              245 M active memory
                             1378 M inactive memory
                              152 M free memory
                               54 M buffer memory
                              396 M swap cache
                               99 M total swap
                               24 M used swap
                               75 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G  7.7G   49G  14% /
                    devtmpfs       devtmpfs  776M     0  776M   0% /dev
                    tmpfs          tmpfs     937M  3.4M  933M   1% /dev/shm
                    tmpfs          tmpfs     937M   91M  846M  10% /run
                    tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
                    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                    tmpfs          tmpfs     188M     0  188M   0% /run/user/999
                    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
                    [Fri Oct  6 15:06:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2A:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=87f0f292-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                    [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                    [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                    [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): recovery complete
                    [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                    [Fri Oct  6 15:06:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Fri Oct  6 15:06:06 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    [Mon Oct  9 15:07:54 2023] [<c03b6448>] (filemap_fault) from [<c0537e28>] (ext4_filemap_fault+0x38/0x4c)
                    [Mon Oct  9 15:07:54 2023] [<c0537df0>] (ext4_filemap_fault) from [<c03ef158>] (__do_fault+0x48/0x134)
                    TARGET        SOURCE         FSTYPE OPTIONS
                    /             /dev/mmcblk0p2 ext4   rw,noatime
                    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    699M    /var/
                    313M    /var/cache
                    307M    /var/cache/apt
                    248M    /var/cache/apt/archives
                    104M    /var/log
                    Archived and active journals take up 89.9M in the file system.
                    /opt/iobroker/backups:
                    917M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    353M    /opt/iobroker/iobroker-data/
                    193M    /opt/iobroker/iobroker-data/files
                    102M    /opt/iobroker/iobroker-data/backup-objects
                    52M     /opt/iobroker/iobroker-data/files/javascript.admin
                    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                    18M     /opt/iobroker/iobroker-data/states.jsonl
                    14M     /opt/iobroker/iobroker-data/objects.jsonl
                    11M     /opt/iobroker/iobroker-data/objects.json.migrated
                    *** NodeJS-Installation ***
                    /usr/bin/node           v18.17.1
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Installed: 18.17.1-1nodesource1
                      Candidate: 18.18.0-1nodesource1
                      Version table:
                         18.18.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     *** 18.17.1-1nodesource1 500
                         18.17.0-1nodesource1 500
                         18.16.1-1nodesource1 500
                         18.16.0-1nodesource1 500
                         18.15.0-1nodesource1 500
                         18.14.2-1nodesource1 500
                         18.14.1-1nodesource1 500
                         18.14.0-1nodesource1 500
                         18.13.0-1nodesource1 500
                         18.12.0-1nodesource1 500
                         18.11.0-1nodesource1 500
                         18.10.0-1nodesource1 500
                         18.9.1-1nodesource1 500
                         18.9.0-1nodesource1 500
                         18.8.0-1nodesource1 500
                         18.7.0-1nodesource1 500
                         18.6.0-1nodesource1 500
                         18.5.0-1nodesource1 500
                         18.4.0-1nodesource1 500
                         18.3.0-1nodesource1 500
                         18.2.0-1nodesource1 500
                         18.1.0-1nodesource1 500
                         18.0.0-1nodesource1 500
                         10.24.0~dfsg-1~deb10u3 500
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    No configuration change needed.
                    Multihost discovery server: disabled
                    Discovery authentication:   enabled
                    Persistent activation:      disabled
                    Objects:                    jsonl on 127.0.0.1
                    States:                     jsonl on 127.0.0.1
                    Core adapters versions
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapters from github:   5
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4                             -  enabled
                    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                    + system.adapter.deconz.0                 : deconz                : raspberrypi4                             -  enabled, port: 80
                    + system.adapter.denon.0                  : denon                 : raspberrypi4                             -  enabled
                    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi4                             -  enabled
                      system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                    + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                    + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4                             -  enabled
                    + system.adapter.hue.0                    : hue                   : raspberrypi4                             -  enabled, port: 443
                    + system.adapter.hyperion_ng.0            : hyperion_ng           : raspberrypi4                             -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                    + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                    + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
                    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                      system.adapter.labcom.0                 : labcom                : raspberrypi4                             - disabled
                      system.adapter.material.0               : material              : raspberrypi4                             - disabled
                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4                             -  enabled, port: 54321
                    + system.adapter.octoprint.0              : octoprint             : raspberrypi4                             -  enabled
                    + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4                             -  enabled
                    + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
                    + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
                    + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4                             -  enabled
                    + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.socketio.0               : socketio              : raspberrypi4                             - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi4                             -  enabled
                    + system.adapter.tado.0                   : tado                  : raspberrypi4                             -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4                             - disabled
                      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                      system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                    + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.wled.0                   : wled                  : raspberrypi4                             - disabled
                    + system.adapter.worx.0                   : worx                  : raspberrypi4                             -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Stable (default): http://download.iobroker.net/sources-dist.json
                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                    Installed ioBroker-Instances
                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                    Adapter    "denon"        : 1.15.4   , installed 1.15.4
                    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                    Adapter    "history"      : 2.2.6    , installed 2.2.6
                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                    Adapter    "hue"          : 3.10.0   , installed 3.10.0
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                    Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
                    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                    Adapter    "tado"         : 0.4.9    , installed 0.4.9
                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                    Adapter    "wled"         : 0.6.7    , installed 0.6.7
                    Adapter    "worx"         : 2.3.2    , installed 2.3.2
                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                    Objects and States
                    Objects:        15625
                    States:         13724
                    Hit:1 http://phoscon.de/apt/deconz buster InRelease
                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 28
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15056      361/deCONZ
                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19740      790/pihole-FTL
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19628      690/sshd
                    tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          18112      721/lighttpd
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13478912   5544/io.sonoff.0
                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15065      361/deCONZ
                    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18245      790/pihole-FTL
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13475861   4358/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13472588   4358/iobroker.js-co
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13478112   4883/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13482716   6118/io.web.0
                    tcp6       0      0 :::53                   :::*                    LISTEN      999        19742      790/pihole-FTL
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          19630      690/sshd
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13482392   5908/io.simple-api.
                    tcp6       0      0 :::8090                 :::*                    LISTEN      0          18113      721/lighttpd
                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       13484398   6813/io.harmony.0
                    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18246      790/pihole-FTL
                    udp        0      0 0.0.0.0:41887           0.0.0.0:*                           108        16332      356/avahi-daemon: r
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13484399   6813/io.harmony.0
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13479340   5366/io.shelly.0
                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19739      790/pihole-FTL
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17526      653/dhcpcd
                    udp        0      0 0.0.0.0:48757           0.0.0.0:*                           1001       13862241   5366/io.shelly.0
                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       13479330   5609/io.mihome-vacu
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16330      356/avahi-daemon: r
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13482735   6216/io.deconz.0
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18461      361/deCONZ
                    udp6       0      0 :::46030                :::*                                108        16333      356/avahi-daemon: r
                    udp6       0      0 :::53                   :::*                                999        19741      790/pihole-FTL
                    udp6       0      0 :::5353                 :::*                                108        16331      356/avahi-daemon: r
                    udp6       0      0 :::1900                 :::*                                1001       13482737   6216/io.deconz.0
                    udp6       0      0 :::1900                 :::*                                1001       13482736   6216/io.deconz.0
                    2023-10-09 16:19:50.668  - info: javascript.0 (5021) script.js.Fernseher.PS4: PS4 an
                    2023-10-09 16:19:51.670  - info: javascript.0 (5021) script.js.Fernseher.PS4: Sony an
                    2023-10-09 16:19:51.671  - info: javascript.0 (5021) script.js.Fernseher.PS4: Eingangsquelle Tv
                    2023-10-09 16:19:51.680  - info: hyperion_ng.0 (6257) set component V4L of instance 0 to false
                    2023-10-09 16:19:51.684  - info: harmony.0 (6813) hub busy, stateChange delayed: harmony.0.Harmony_Hub.Denon_AV-Empfänger.InputGame = 1
                    2023-10-09 16:19:51.712  - info: hyperion_ng.0 (6257) socket is connected
                    2023-10-09 16:19:52.048  - info: hyperion_ng.0 (6257) read out components finished
                    2023-10-09 16:19:52.049  - info: hyperion_ng.0 (6257) component is set
                    2023-10-09 16:19:54.680  - info: hyperion_ng.0 (6257) set component LEDDEVICE of instance 0 to false
                    2023-10-09 16:19:55.059  - info: hyperion_ng.0 (6257) read out components finished
                    2023-10-09 16:19:55.060  - info: hyperion_ng.0 (6257) component is set
                    2023-10-09 16:20:54.966  - info: hyperion_ng.0 (6257) socket timeout
                    2023-10-09 16:20:54.986  - info: hyperion_ng.0 (6257) Connection closed
                    2023-10-09 16:29:10.952  - info: mihome-vacuum.0 (5609) trigger cleaning segment 22
                    2023-10-09 16:30:00.069  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                    2023-10-09 16:31:31.277  - info: admin.0 (4883) failed connection to socket.io from ::ffff:192.168.178.60: Passport was not initialized
                    2023-10-09 16:31:43.629  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                    2023-10-09 16:37:33.190  - warn: javascript.0 (5021) script.js.Roborock.Wartungszustand: pushover: Rocki muss gewartet werden.
                    2023-10-09 16:43:55.977  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                    2023-10-09 16:43:56.960  - info: admin.0 (4883) <== Disconnect system.user.admin from ::ffff:192.168.178.60 admin
                    2023-10-09 16:45:00.061  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                    2023-10-09 17:00:00.097  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                    2023-10-09 17:04:26.119  - info: worx.0 (6764) Refresh token for MQTT-Connection
                    2023-10-09 17:04:26.122  - info: worx.0 (6764) Disconnected
                    2023-10-09 17:04:26.554  - info: worx.0 (6764) MQTT connected to: iot.eu-west-1.worxlandroid.com
                    Dazu noch der Screendshot aus dem Admin
                    GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
                    • J JohnnyBahama
                      @Glasfaser
                      @Thomas-Braun
                      Es ist wieder passiert, hier der Log diesesmal im debug aus dem Broker:
                      2023-10-09 08:19:18.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 08:19:18.266 - info: worx.0 (3594) Disconnected
                      2023-10-09 08:19:18.614 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 08:42:37.100 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-10-09 09:15:58.160 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 09:15:58.162 - info: worx.0 (3594) Disconnected
                      2023-10-09 09:15:58.520 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 10:12:38.231 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 10:12:38.232 - info: worx.0 (3594) Disconnected
                      2023-10-09 10:12:38.600 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 10:54:00.074 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-10-09 10:54:01.439 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-10-09 11:09:18.284 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 11:09:18.286 - info: worx.0 (3594) Disconnected
                      2023-10-09 11:09:18.711 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 12:05:58.262 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 12:05:58.264 - info: worx.0 (3594) Disconnected
                      2023-10-09 12:05:58.639 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 13:02:38.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 13:02:38.266 - info: worx.0 (3594) Disconnected
                      2023-10-09 13:02:38.601 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 13:48:33.414 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-10-09 13:48:34.794 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-10-09 13:59:18.174 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 13:59:18.176 - info: worx.0 (3594) Disconnected
                      2023-10-09 13:59:18.539 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 14:55:58.210 - info: worx.0 (3594) Refresh token for MQTT-Connection
                      2023-10-09 14:55:58.212 - info: worx.0 (3594) Disconnected
                      2023-10-09 14:55:58.607 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      2023-10-09 15:00:00.055 - info: javascript.0 (1909) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                      2023-10-09 15:07:19.526 - info: admin.0 (1735) Adapter rating updated
                      2023-10-09 15:07:40.176 - info: admin.0 (1735) Request actual repository...
                      2023-10-09 15:07:41.017 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                      2023-10-09 15:07:55.157 - info: admin.0 (1735) Repository received successfully.
                      2023-10-09 15:07:55.320 - error: homeconnect.0 (3340) States database error: read ECONNRESET
                      2023-10-09 15:07:55.425 - error: worx.0 (3594) States database error: read ECONNRESET
                      2023-10-09 15:07:55.448 - error: javascript.0 (1909) States database error: read ECONNRESET
                      2023-10-09 15:07:55.532 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ambilight
                      2023-10-09 15:07:55.533 - info: javascript.0 (1909) Stop script script.js.Fernseher.Disney
                      2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ein_Ausschalten
                      2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Film
                      2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Netflix
                      2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.PS4
                      2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Umschalten
                      2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Fernseher.Youtube
                      2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Hyperion
                      2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Küche.Backofen.Rechner_Ablaufende_Zeit
                      2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.An_Aus
                      2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.Arbeitslicht
                      2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Licht.Wohnzimmer.Licht_an
                      2023-10-09 15:07:55.539 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Adapterüberwachung
                      2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Badezimmerfenster_schließen
                      2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Batteriestatus
                      2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Gartenstromversorgung_unterbrochen
                      2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Neustart
                      2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Power_Waschmaschine
                      2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Pumpe_an
                      2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Roborock
                      2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Tado_nicht_erreichbar
                      2023-10-09 15:07:55.543 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung_Cron
                      2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Pi_Hole.Deaktivieren
                      2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Roborock.Abwesenheitsreinigung
                      2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Alexa
                      2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Amelies_platz_reinigen
                      2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Einstellungen
                      2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Mülleimer_fahrt___laden
                      2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pausieren_Stoppen
                      2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pushover_Nachrichten
                      2023-10-09 15:07:55.547 - info: javascript.0 (1909) Stop script script.js.Roborock.Wartungszustand
                      2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Roborock.Zimmer_Reinigung
                      2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Abwesenheitsschließung
                      2023-10-09 15:07:55.549 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Rolladenautomatik
                      2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Terrase_schießen_verhindern
                      2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Verbrauch
                      2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Fernseher.Kino
                      2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Rasenmäher
                      2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Salzanlage_Status
                      2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Alexa.Poolwerteprüfung
                      2023-10-09 15:07:55.553 - info: javascript.0 (1909) Stop script script.js.Octoprint.Fertigmeldung
                      2023-10-09 15:07:55.554 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung
                      2023-10-09 15:07:55.274 - error: harmony.0 (3641) States database error: write EPIPE
                      2023-10-09 15:07:55.413 - info: backitup.0 (2623) cleaned everything up...
                      2023-10-09 15:07:55.411 - info: tado.0 (2927) cleaned everything up...
                      2023-10-09 15:07:55.411 - info: simple-api.0 (2807) terminating http server on port 8087
                      2023-10-09 15:07:55.416 - info: pi-hole.0 (3220) cleaned everything up...
                      2023-10-09 15:07:55.319 - error: device-reminder.0 (3424) States database error: read ECONNRESET
                      2023-10-09 15:07:55.418 - info: deconz.0 (2958) cleaned everything up...
                      2023-10-09 15:07:55.378 - error: denon.0 (3333) States database error: write EPIPE
                      2023-10-09 15:07:55.713 - info: denon.0 (3333) [END] Stopping Denon AVR adapter...
                      2023-10-09 15:07:55.348 - error: iot.0 (3002) States database error: read ECONNRESET
                      2023-10-09 15:07:55.791 - info: harmony.0 (3641) [END] Terminating
                      2023-10-09 15:07:55.912 - warn: web.0 (2876) Timeout by termination of web-extensions!
                      2023-10-09 15:07:55.922 - info: web.0 (2876) terminated http server on port 8082
                      2023-10-09 15:07:56.025 - info: iot.0 (3002) Connection changed: disconnect
                      2023-10-09 15:07:56.026 - info: iot.0 (3002) Connection lost
                      2023-10-09 15:07:56.193 - info: worx.0 (3594) Disconnected
                      2023-10-09 15:07:56.705 - error: shuttercontrol.0 (7987) States database error: write EPIPE
                      2023-10-09 15:07:56.722 - info: shuttercontrol.0 (7987) cleaned everything up...
                      2023-10-09 15:07:56.705 - error: info.0 (2870) States database error: write EPIPE
                      2023-10-09 15:07:56.720 - error: mihome-vacuum.0 (2407) States database error: write EPIPE
                      2023-10-09 15:07:56.760 - info: info.0 (2870) cleaned everything up...
                      2023-10-09 15:07:56.712 - error: hue.0 (2181) States database error: write EPIPE
                      2023-10-09 15:07:56.701 - error: pushover.0 (1939) States database error: write EPIPE
                      2023-10-09 15:07:56.717 - error: sonoff.0 (2325) States database error: write EPIPE
                      2023-10-09 15:07:56.774 - error: mihome-vacuum.0 (2407) Socket Close
                      2023-10-09 15:07:56.702 - error: shelly.0 (2068) States database error: write EPIPE
                      2023-10-09 15:07:56.736 - error: ping.0 (2467) States database error: write EPIPE
                      2023-10-09 15:07:56.726 - error: octoprint.0 (3660) States database error: write EPIPE
                      2023-10-09 15:07:56.913 - info: sony-bravia.0 (2297) terminating with timeout
                      2023-10-09 15:07:56.919 - info: sony-bravia.0 (2297) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:56.953 - info: web.0 (2876) terminating with timeout
                      2023-10-09 15:07:56.955 - info: web.0 (2876) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.033 - info: javascript.0 (1909) terminating with timeout
                      2023-10-09 15:07:57.034 - info: javascript.0 (1909) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.067 - info: hyperion_ng.0 (3062) terminating with timeout
                      2023-10-09 15:07:57.086 - info: hyperion_ng.0 (3062) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.110 - info: homeconnect.0 (3340) terminating with timeout
                      2023-10-09 15:07:57.126 - info: alexa2.0 (2661) terminating with timeout
                      2023-10-09 15:07:57.128 - info: alexa2.0 (2661) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.144 - info: backitup.0 (2623) terminating with timeout
                      2023-10-09 15:07:57.146 - info: backitup.0 (2623) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.181 - info: homeconnect.0 (3340) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.216 - info: denon.0 (3333) terminating with timeout
                      2023-10-09 15:07:57.257 - info: tado.0 (2927) terminating with timeout
                      2023-10-09 15:07:57.259 - info: tado.0 (2927) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.260 - info: deconz.0 (2958) terminating with timeout
                      2023-10-09 15:07:57.261 - info: simple-api.0 (2807) terminating with timeout
                      2023-10-09 15:07:57.262 - info: deconz.0 (2958) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.265 - info: simple-api.0 (2807) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.268 - info: pi-hole.0 (3220) terminating with timeout
                      2023-10-09 15:07:57.270 - info: pi-hole.0 (3220) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.272 - info: denon.0 (3333) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.296 - info: harmony.0 (3641) terminating with timeout
                      2023-10-09 15:07:57.324 - info: harmony.0 (3641) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.410 - info: device-reminder.0 (3424) terminating with timeout
                      2023-10-09 15:07:57.413 - info: iot.0 (3002) terminating with timeout
                      2023-10-09 15:07:57.441 - info: device-reminder.0 (3424) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.431 - info: iot.0 (3002) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:57.453 - info: worx.0 (3594) terminating with timeout
                      2023-10-09 15:07:57.468 - info: worx.0 (3594) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.210 - info: history.0 (1771) Delete old history "/opt/iobroker/history/20221008/history.denon.0.zoneMain.powerZone.json"
                      2023-10-09 15:07:58.227 - info: shuttercontrol.0 (7987) terminating with timeout
                      2023-10-09 15:07:58.230 - info: shuttercontrol.0 (7987) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:55.477 - debug: admin.0 (1735) Next repo update on 10/10/2023, 15:07:55
                      2023-10-09 15:07:58.260 - error: admin.0 (1735) States database error: write EPIPE
                      2023-10-09 15:07:58.264 - info: info.0 (2870) terminating with timeout
                      2023-10-09 15:07:58.267 - info: mihome-vacuum.0 (2407) terminating with timeout
                      2023-10-09 15:07:58.267 - info: info.0 (2870) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.269 - info: mihome-vacuum.0 (2407) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.285 - info: pushover.0 (1939) terminating with timeout
                      2023-10-09 15:07:58.291 - info: pushover.0 (1939) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.290 - info: admin.0 (1735) terminating https server on port 8081
                      2023-10-09 15:07:58.308 - info: sonoff.0 (2325) terminating with timeout
                      2023-10-09 15:07:58.310 - info: sonoff.0 (2325) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.321 - info: shelly.0 (2068) terminating with timeout
                      2023-10-09 15:07:58.323 - info: shelly.0 (2068) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.331 - info: hue.0 (2181) terminating with timeout
                      2023-10-09 15:07:58.333 - info: hue.0 (2181) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.340 - info: ping.0 (2467) terminating with timeout
                      2023-10-09 15:07:58.342 - info: ping.0 (2467) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:58.394 - info: octoprint.0 (3660) terminating with timeout
                      2023-10-09 15:07:58.397 - info: octoprint.0 (3660) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:07:59.795 - info: admin.0 (1735) terminating with timeout
                      2023-10-09 15:07:59.799 - debug: admin.0 (1735) Plugin sentry destroyed
                      2023-10-09 15:07:59.799 - info: admin.0 (1735) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:08:00.187 - error: web.0 (2876) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.196 - error: backitup.0 (2623) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.223 - error: hyperion_ng.0 (3062) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.241 - error: sony-bravia.0 (2297) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.269 - error: alexa2.0 (2661) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.270 - error: tado.0 (2927) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.265 - warn: sony-bravia.0 (2297) get state error: Connection is closed.
                      2023-10-09 15:08:00.267 - warn: sony-bravia.0 (2297) get state error: DB closed
                      2023-10-09 15:08:00.272 - info: sony-bravia.0 (2297) terminating
                      2023-10-09 15:08:00.278 - info: sony-bravia.0 (2297) terminating
                      2023-10-09 15:08:00.291 - error: pi-hole.0 (3220) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.295 - error: simple-api.0 (2807) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.335 - error: deconz.0 (2958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.348 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.362 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                      2023-10-09 15:08:00.369 - warn: pi-hole.0 (3220) get state error: Connection is closed.
                      2023-10-09 15:08:00.370 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.371 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.372 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.374 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.376 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.377 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.378 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.379 - warn: pi-hole.0 (3220) get state error: DB closed
                      2023-10-09 15:08:00.395 - info: pi-hole.0 (3220) terminating
                      2023-10-09 15:08:00.397 - info: pi-hole.0 (3220) terminating
                      2023-10-09 15:08:00.432 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.433 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.439 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.440 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.441 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.442 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.443 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.444 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.445 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.446 - warn: homeconnect.0 (3340) get state error: DB closed
                      2023-10-09 15:08:00.453 - info: homeconnect.0 (3340) terminating
                      2023-10-09 15:08:00.454 - info: homeconnect.0 (3340) terminating
                      2023-10-09 15:08:00.480 - error: javascript.0 (1909) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.539 - warn: javascript.0 (1909) get state error: DB closed
                      2023-10-09 15:08:00.539 - error: worx.0 (3594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.542 - warn: javascript.0 (1909) get state error: DB closed
                      2023-10-09 15:08:00.543 - warn: javascript.0 (1909) get state error: DB closed
                      2023-10-09 15:08:00.544 - warn: javascript.0 (1909) get state error: DB closed
                      2023-10-09 15:08:00.545 - warn: javascript.0 (1909) get state error: DB closed
                      2023-10-09 15:08:00.550 - info: javascript.0 (1909) terminating
                      2023-10-09 15:08:00.554 - warn: worx.0 (3594) get state error: DB closed
                      2023-10-09 15:08:00.557 - warn: worx.0 (3594) get state error: DB closed
                      2023-10-09 15:08:00.558 - warn: worx.0 (3594) get state error: DB closed
                      2023-10-09 15:08:00.559 - warn: worx.0 (3594) get state error: DB closed
                      2023-10-09 15:08:00.566 - info: worx.0 (3594) terminating
                      2023-10-09 15:08:00.781 - error: device-reminder.0 (3424) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.791 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.792 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.793 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.794 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.795 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.796 - warn: device-reminder.0 (3424) get state error: DB closed
                      2023-10-09 15:08:00.800 - info: device-reminder.0 (3424) terminating
                      2023-10-09 15:08:00.801 - info: device-reminder.0 (3424) terminating
                      2023-10-09 15:08:00.823 - error: denon.0 (3333) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.841 - warn: denon.0 (3333) get state error: Connection is closed.
                      2023-10-09 15:08:00.842 - warn: denon.0 (3333) get state error: DB closed
                      2023-10-09 15:08:00.843 - warn: denon.0 (3333) get state error: DB closed
                      2023-10-09 15:08:00.845 - warn: denon.0 (3333) get state error: DB closed
                      2023-10-09 15:08:00.846 - warn: denon.0 (3333) get state error: DB closed
                      2023-10-09 15:08:00.850 - info: denon.0 (3333) terminating
                      2023-10-09 15:08:00.851 - info: denon.0 (3333) terminating
                      2023-10-09 15:08:00.857 - error: harmony.0 (3641) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.875 - error: iot.0 (3002) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:00.910 - warn: harmony.0 (3641) get state error: Connection is closed.
                      2023-10-09 15:08:01.747 - error: shuttercontrol.0 (7987) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.784 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10F9B0#1.Relay1.Timer, error - DB closed
                      2023-10-09 15:08:01.801 - error: info.0 (2870) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.787 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10CD90#1.Shutter.Duration, error - DB closed
                      2023-10-09 15:08:01.788 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#F3353D#1.Shutter.Duration, error - DB closed
                      2023-10-09 15:08:01.789 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10D202#1.Shutter.Duration, error - DB closed
                      2023-10-09 15:08:01.790 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#110D76#1.Relay1.Timer, error - DB closed
                      2023-10-09 15:08:01.790 - warn: shelly.0 (2068) get state error: DB closed
                      2023-10-09 15:08:01.791 - warn: shelly.0 (2068) get state error: DB closed
                      2023-10-09 15:08:01.805 - error: pushover.0 (1939) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.822 - error: mihome-vacuum.0 (2407) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.836 - error: sonoff.0 (2325) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.842 - info: shelly.0 (2068) terminating
                      2023-10-09 15:08:01.843 - info: shelly.0 (2068) terminating
                      2023-10-09 15:08:01.874 - error: hue.0 (2181) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.881 - error: ping.0 (2467) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:01.925 - error: octoprint.0 (3660) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:03.308 - error: admin.0 (1735) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:03.318 - warn: admin.0 (1735) get state error: Connection is closed.
                      2023-10-09 15:08:03.319 - warn: admin.0 (1735) get state error: DB closed
                      2023-10-09 15:08:03.320 - warn: admin.0 (1735) get state error: DB closed
                      2023-10-09 15:08:03.321 - warn: admin.0 (1735) get state error: DB closed
                      2023-10-09 15:08:03.322 - warn: admin.0 (1735) get state error: DB closed
                      2023-10-09 15:08:03.324 - info: admin.0 (1735) terminating
                      2023-10-09 15:08:05.306 - error: pi-hole.0 (3220) Cannot check object existence of "pi-hole.0.version": Connection is closed.
                      2023-10-09 15:08:05.379 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                      2023-10-09 15:08:05.383 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:08.324 - error: admin.0 (1735) Cannot find view "system" for search "instance" : Connection is closed.
                      2023-10-09 15:08:09.759 - info: history.0 (1771) terminating with timeout
                      2023-10-09 15:08:09.763 - info: history.0 (1771) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:08:10.388 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2023-10-09 15:08:17.666 - info: host.raspberrypi4 iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-09 15:08:17.673 - info: host.raspberrypi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-09 15:08:17.675 - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.1
                      2023-10-09 15:08:17.675 - info: host.raspberrypi4 ip addresses: 192.168.178.70 2003:f5:f26:b900:3583:2470:ce5:f0d4 fe80::a637:87cf:1b83:c822
                      2023-10-09 15:08:20.777 - info: host.raspberrypi4 connected to Objects and States
                      2023-10-09 15:08:20.876 - info: host.raspberrypi4 added notifications configuration of host
                      2023-10-09 15:08:22.204 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeCurrent"
                      2023-10-09 15:08:22.206 - info: host.raspberrypi4 38 instances found
                      2023-10-09 15:08:22.296 - info: host.raspberrypi4 starting 28 instances
                      2023-10-09 15:08:22.491 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewest"
                      2023-10-09 15:08:22.536 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4461
                      2023-10-09 15:08:22.546 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
                      2023-10-09 15:08:22.557 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
                      2023-10-09 15:08:22.568 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
                      2023-10-09 15:08:22.578 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
                      2023-10-09 15:08:22.589 - info: host.raspberrypi4 Some obsolete host states deleted.
                      2023-10-09 15:08:26.272 - error: admin.0 (4461) admin.0 already running
                      2023-10-09 15:08:26.277 - warn: admin.0 (4461) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:26.479 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4501
                      2023-10-09 15:08:27.111 - error: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:27.112 - info: host.raspberrypi4 Restart adapter system.adapter.admin.0 because enabled
                      2023-10-09 15:08:29.053 - error: history.0 (4501) history.0 already running
                      2023-10-09 15:08:29.061 - warn: history.0 (4501) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:29.727 - error: host.raspberrypi4 instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:29.728 - info: host.raspberrypi4 Restart adapter system.adapter.history.0 because enabled
                      2023-10-09 15:08:30.543 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 4570
                      2023-10-09 15:08:34.600 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 4605
                      2023-10-09 15:08:35.010 - error: javascript.0 (4570) javascript.0 already running
                      2023-10-09 15:08:35.015 - warn: javascript.0 (4570) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:35.730 - error: host.raspberrypi4 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:35.731 - info: host.raspberrypi4 Restart adapter system.adapter.javascript.0 because enabled
                      2023-10-09 15:08:37.148 - error: pushover.0 (4605) pushover.0 already running
                      2023-10-09 15:08:37.153 - warn: pushover.0 (4605) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:37.856 - error: host.raspberrypi4 instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:37.856 - info: host.raspberrypi4 Restart adapter system.adapter.pushover.0 because enabled
                      2023-10-09 15:08:38.510 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 4672
                      2023-10-09 15:08:41.117 - error: alexa2.0 (4672) alexa2.0 already running
                      2023-10-09 15:08:41.121 - warn: alexa2.0 (4672) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:41.800 - error: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:41.800 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
                      2023-10-09 15:08:42.545 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 4706
                      2023-10-09 15:08:45.475 - error: shelly.0 (4706) shelly.0 already running
                      2023-10-09 15:08:45.479 - warn: shelly.0 (4706) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:46.194 - error: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:46.196 - info: host.raspberrypi4 Restart adapter system.adapter.shelly.0 because enabled
                      2023-10-09 15:08:46.491 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 4741
                      2023-10-09 15:08:49.352 - error: hue.0 (4741) hue.0 already running
                      2023-10-09 15:08:49.356 - warn: hue.0 (4741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:50.077 - error: host.raspberrypi4 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:50.078 - info: host.raspberrypi4 Restart adapter system.adapter.hue.0 because enabled
                      2023-10-09 15:08:50.500 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 4813
                      2023-10-09 15:08:53.519 - error: sony-bravia.0 (4813) sony-bravia.0 already running
                      2023-10-09 15:08:53.523 - warn: sony-bravia.0 (4813) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:54.203 - error: host.raspberrypi4 instance system.adapter.sony-bravia.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:54.203 - info: host.raspberrypi4 Restart adapter system.adapter.sony-bravia.0 because enabled
                      2023-10-09 15:08:54.521 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 4848
                      2023-10-09 15:08:57.007 - error: sonoff.0 (4848) sonoff.0 already running
                      2023-10-09 15:08:57.011 - warn: sonoff.0 (4848) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:08:57.299 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4883
                      2023-10-09 15:08:57.707 - error: host.raspberrypi4 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:08:57.708 - info: host.raspberrypi4 Restart adapter system.adapter.sonoff.0 because enabled
                      2023-10-09 15:08:58.511 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 4927
                      2023-10-09 15:08:59.991 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4945
                      2023-10-09 15:09:02.069 - error: mihome-vacuum.0 (4927) mihome-vacuum.0 already running
                      2023-10-09 15:09:02.076 - warn: mihome-vacuum.0 (4927) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:02.148 - info: admin.0 (4883) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:02.226 - info: admin.0 (4883) requesting all objects
                      2023-10-09 15:09:04.821 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5003
                      2023-10-09 15:09:04.935 - error: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:04.937 - info: host.raspberrypi4 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                      2023-10-09 15:09:05.363 - info: admin.0 (4883) received all objects
                      2023-10-09 15:09:05.993 - info: admin.0 (4883) Request actual repository...
                      2023-10-09 15:09:06.225 - info: admin.0 (4883) Secure socket.io server listening on port 8081
                      2023-10-09 15:09:06.241 - info: admin.0 (4883) https server listening on port 8081
                      2023-10-09 15:09:06.241 - info: admin.0 (4883) Use link "https://127.0.0.1:8081" to configure.
                      2023-10-09 15:09:06.473 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 5021
                      2023-10-09 15:09:07.317 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5038
                      2023-10-09 15:09:08.167 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 5092
                      2023-10-09 15:09:09.099 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                      2023-10-09 15:09:09.373 - info: history.0 (4945) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.history, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:11.534 - error: ping.0 (5003) ping.0 already running
                      2023-10-09 15:09:11.540 - warn: ping.0 (5003) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:11.615 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5167
                      2023-10-09 15:09:13.043 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5189
                      2023-10-09 15:09:13.099 - error: host.raspberrypi4 instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:13.100 - info: host.raspberrypi4 Restart adapter system.adapter.ping.0 because enabled
                      2023-10-09 15:09:13.392 - error: backitup.0 (5038) backitup.0 already running
                      2023-10-09 15:09:13.398 - warn: backitup.0 (5038) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:14.317 - error: host.raspberrypi4 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:14.318 - info: host.raspberrypi4 Restart adapter system.adapter.backitup.0 because enabled
                      2023-10-09 15:09:14.934 - info: host.raspberrypi4 instance system.adapter.simple-api.0 started with pid 5275
                      2023-10-09 15:09:20.498 - info: admin.0 (4883) Repository received successfully.
                      2023-10-09 15:09:21.185 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 5366
                      2023-10-09 15:09:21.419 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 5379
                      2023-10-09 15:09:21.714 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 5386
                      2023-10-09 15:09:21.856 - error: info.0 (5167) info.0 already running
                      2023-10-09 15:09:21.863 - warn: info.0 (5167) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:22.066 - error: simple-api.0 (5275) simple-api.0 already running
                      2023-10-09 15:09:22.083 - warn: simple-api.0 (5275) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:22.766 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 5399
                      2023-10-09 15:09:23.115 - error: host.raspberrypi4 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:23.116 - info: host.raspberrypi4 Restart adapter system.adapter.info.0 because enabled
                      2023-10-09 15:09:23.341 - error: host.raspberrypi4 instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:23.342 - info: host.raspberrypi4 Restart adapter system.adapter.simple-api.0 because enabled
                      2023-10-09 15:09:23.423 - info: pushover.0 (5092) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:23.705 - info: javascript.0 (5021) starting. Version 7.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:24.059 - info: alexa2.0 (5189) starting. Version 3.25.2 (non-npm: Apollon77/ioBroker.alexa2#2f00d64d7149f65565470bf222734cab76e303ec) in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:24.583 - info: alexa2.0 (5189) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                      2023-10-09 15:09:26.947 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 5454
                      2023-10-09 15:09:27.615 - info: javascript.0 (5021) requesting all states
                      2023-10-09 15:09:27.619 - info: javascript.0 (5021) requesting all objects
                      2023-10-09 15:09:29.302 - info: alexa2.0 (5189) Update cookie in adapter configuration ... restarting ...
                      2023-10-09 15:09:31.235 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 5531
                      2023-10-09 15:09:31.555 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 (force=false, process=true)
                      2023-10-09 15:09:31.814 - info: javascript.0 (5021) received all objects
                      2023-10-09 15:09:32.123 - info: javascript.0 (5021) received all states
                      2023-10-09 15:09:32.135 - info: alexa2.0 (5189) Got terminate signal TERMINATE_YOURSELF
                      2023-10-09 15:09:32.148 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 send kill signal
                      2023-10-09 15:09:32.143 - info: alexa2.0 (5189) terminating
                      2023-10-09 15:09:32.166 - info: alexa2.0 (5189) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-10-09 15:09:32.557 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 5544
                      2023-10-09 15:09:32.670 - info: alexa2.0 (5189) terminating
                      2023-10-09 15:09:32.878 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 5551
                      2023-10-09 15:09:33.191 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 killing pid 5189
                      2023-10-09 15:09:33.247 - error: web.0 (5379) web.0 already running
                      2023-10-09 15:09:33.256 - warn: web.0 (5379) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:34.968 - error: tado.0 (5399) tado.0 already running
                      2023-10-09 15:09:34.976 - warn: tado.0 (5399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:35.951 - error: host.raspberrypi4 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:35.953 - info: host.raspberrypi4 Restart adapter system.adapter.web.0 because enabled
                      2023-10-09 15:09:36.784 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 5592
                      2023-10-09 15:09:37.084 - error: host.raspberrypi4 instance system.adapter.tado.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:37.085 - info: host.raspberrypi4 Restart adapter system.adapter.tado.0 because enabled
                      2023-10-09 15:09:37.477 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 5609
                      2023-10-09 15:09:37.823 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5616
                      2023-10-09 15:09:39.022 - error: deconz.0 (5531) deconz.0 already running
                      2023-10-09 15:09:39.027 - warn: deconz.0 (5531) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:39.453 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 5667
                      2023-10-09 15:09:40.033 - error: iot.0 (5551) iot.0 already running
                      2023-10-09 15:09:40.047 - warn: iot.0 (5551) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:40.543 - error: host.raspberrypi4 instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:40.546 - info: host.raspberrypi4 Restart adapter system.adapter.deconz.0 because enabled
                      2023-10-09 15:09:41.055 - error: host.raspberrypi4 instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:41.056 - info: host.raspberrypi4 Restart adapter system.adapter.iot.0 because enabled
                      2023-10-09 15:09:42.156 - error: hyperion_ng.0 (5592) hyperion_ng.0 already running
                      2023-10-09 15:09:42.161 - warn: hyperion_ng.0 (5592) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:42.219 - info: hue.0 (5386) starting. Version 3.10.0 in /opt/iobroker/node_modules/iobroker.hue, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:42.237 - info: shelly.0 (5366) starting. Version 6.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:43.424 - info: hue.0 (5386) Push connection established
                      2023-10-09 15:09:43.769 - error: host.raspberrypi4 instance system.adapter.hyperion_ng.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:43.780 - info: host.raspberrypi4 Restart adapter system.adapter.hyperion_ng.0 because enabled
                      2023-10-09 15:09:44.343 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5734
                      2023-10-09 15:09:45.388 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5747
                      2023-10-09 15:09:45.991 - error: shuttercontrol.0 (5667) shuttercontrol.0 already running
                      2023-10-09 15:09:46.002 - warn: shuttercontrol.0 (5667) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:46.430 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 5764
                      2023-10-09 15:09:47.187 - error: host.raspberrypi4 instance system.adapter.shuttercontrol.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:47.188 - info: host.raspberrypi4 Restart adapter system.adapter.shuttercontrol.0 because enabled
                      2023-10-09 15:09:52.766 - error: pi-hole.0 (5764) pi-hole.0 already running
                      2023-10-09 15:09:52.784 - warn: pi-hole.0 (5764) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:55.371 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5896
                      2023-10-09 15:09:55.429 - error: host.raspberrypi4 instance system.adapter.pi-hole.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:55.430 - info: host.raspberrypi4 Restart adapter system.adapter.pi-hole.0 because enabled
                      2023-10-09 15:09:56.413 - info: vis.0 (5727) Terminated (NO_ERROR): Without reason
                      2023-10-09 15:09:56.632 - error: denon.0 (5862) denon.0 already running
                      2023-10-09 15:09:56.641 - warn: denon.0 (5862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:09:56.934 - info: ping.0 (5734) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:09:59.473 - info: host.raspberrypi4 instance system.adapter.vis.0 terminated while should be started once
                      2023-10-09 15:09:59.995 - error: host.raspberrypi4 instance system.adapter.denon.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:09:59.996 - info: host.raspberrypi4 Restart adapter system.adapter.denon.0 because enabled
                      2023-10-09 15:10:04.282 - error: homeconnect.0 (5915) homeconnect.0 already running
                      2023-10-09 15:10:04.291 - warn: homeconnect.0 (5915) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:10:05.585 - error: device-reminder.0 (6014) device-reminder.0 already running
                      2023-10-09 15:10:05.593 - warn: device-reminder.0 (6014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:10:06.078 - error: host.raspberrypi4 instance system.adapter.homeconnect.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:10:06.979 - info: host.raspberrypi4 instance system.adapter.harmony.0 started with pid 6106
                      2023-10-09 15:10:07.062 - error: host.raspberrypi4 instance system.adapter.device-reminder.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:10:07.063 - info: host.raspberrypi4 Restart adapter system.adapter.device-reminder.0 because enabled
                      2023-10-09 15:10:07.129 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 6118
                      2023-10-09 15:10:07.759 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 6130
                      2023-10-09 15:10:08.603 - info: simple-api.0 (5908) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:08.809 - warn: simple-api.0 (5908) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                      2023-10-09 15:10:08.895 - info: simple-api.0 (5908) simpleAPI server listening on port 8087
                      2023-10-09 15:10:08.897 - info: simple-api.0 (5908) Allow states only when user is owner: false
                      2023-10-09 15:10:08.927 - info: simple-api.0 (5908) http server listening on port 8087
                      2023-10-09 15:10:09.091 - info: backitup.0 (5747) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:09.988 - info: backitup.0 (5747) [iobroker] backup will be activated at 02:40 every 1 day(s)
                      2023-10-09 15:10:11.599 - error: worx.0 (6085) worx.0 already running
                      2023-10-09 15:10:11.611 - warn: worx.0 (6085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:10:11.818 - info: host.raspberrypi4 instance system.adapter.octoprint.0 started with pid 6206
                      2023-10-09 15:10:12.009 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 6216
                      2023-10-09 15:10:12.314 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 6228
                      2023-10-09 15:10:13.226 - error: host.raspberrypi4 instance system.adapter.worx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:10:13.257 - info: host.raspberrypi4 Restart adapter system.adapter.worx.0 because enabled
                      2023-10-09 15:10:15.518 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 6257
                      2023-10-09 15:10:16.612 - error: harmony.0 (6106) harmony.0 already running
                      2023-10-09 15:10:16.620 - warn: harmony.0 (6106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:10:18.718 - error: host.raspberrypi4 instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:10:18.719 - info: host.raspberrypi4 Restart adapter system.adapter.harmony.0 because enabled
                      2023-10-09 15:10:19.320 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 6304
                      2023-10-09 15:10:20.117 - error: octoprint.0 (6206) octoprint.0 already running
                      2023-10-09 15:10:20.134 - warn: octoprint.0 (6206) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-09 15:10:21.821 - error: host.raspberrypi4 instance system.adapter.octoprint.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-09 15:10:21.822 - info: host.raspberrypi4 Restart adapter system.adapter.octoprint.0 because enabled
                      2023-10-09 15:10:23.534 - info: web.0 (6118) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:23.633 - info: tado.0 (6130) starting. Version 0.4.9 in /opt/iobroker/node_modules/iobroker.tado, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:23.787 - info: hyperion_ng.0 (6257) starting. Version 0.1.23 (non-npm: felixganzer/ioBroker.hyperion_ng#b27f55704d34a7eed2865ca421409d091d86cd38) in /opt/iobroker/node_modules/iobroker.hyperion_ng, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:23.856 - info: hyperion_ng.0 (6257) create Control Parameter
                      2023-10-09 15:10:23.720 - info: tado.0 (6130) Started with JSON-Explorer version 0.1.12
                      2023-10-09 15:10:24.450 - info: tado.0 (6130) Connected to Tado cloud, initialyzing...
                      2023-10-09 15:10:24.456 - info: sony-bravia.0 (5454) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.sony-bravia, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:24.727 - info: web.0 (6118) socket.io server listening on port 8082
                      2023-10-09 15:10:24.761 - info: web.0 (6118) http server listening on port 8082
                      2023-10-09 15:10:25.033 - info: deconz.0 (6216) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:25.075 - info: hyperion_ng.0 (6257) 210,0.5000000000000001,0.39215686274509803
                      2023-10-09 15:10:25.582 - info: deconz.0 (6216) deConz Version: 2.22.2; API version: 1.16.0
                      2023-10-09 15:10:25.806 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 6469
                      2023-10-09 15:10:26.007 - info: hyperion_ng.0 (6257) socket is connected
                      2023-10-09 15:10:28.243 - info: iot.0 (6228) starting. Version 1.14.5 in /opt/iobroker/node_modules/iobroker.iot, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:28.796 - info: iot.0 (6228) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                      2023-10-09 15:10:31.212 - info: host.raspberrypi4 instance system.adapter.denon.0 started with pid 6552
                      2023-10-09 15:10:32.365 - info: iot.0 (6228) Connection changed: connect
                      2023-10-09 15:10:32.854 - info: info.0 (5896) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:33.435 - info: pi-hole.0 (6469) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:33.627 - info: info.0 (5896) Reading/updating systemdata.
                      2023-10-09 15:10:35.029 - info: hyperion_ng.0 (6257) read out components finished
                      2023-10-09 15:10:36.567 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.blue" has to be stringified but received type "object"
                      2023-10-09 15:10:36.708 - info: host.raspberrypi4 instance system.adapter.homeconnect.0 started with pid 6619
                      2023-10-09 15:10:37.014 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.cyan" has to be stringified but received type "object"
                      2023-10-09 15:10:37.767 - info: host.raspberrypi4 instance system.adapter.device-reminder.0 started with pid 6636
                      2023-10-09 15:10:38.027 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.green" has to be stringified but received type "object"
                      2023-10-09 15:10:38.324 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.magenta" has to be stringified but received type "object"
                      2023-10-09 15:10:38.521 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.red" has to be stringified but received type "object"
                      2023-10-09 15:10:38.783 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.white" has to be stringified but received type "object"
                      2023-10-09 15:10:38.946 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.yellow" has to be stringified but received type "object"
                      2023-10-09 15:10:38.984 - info: shuttercontrol.0 (6304) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:39.001 - info: hyperion_ng.0 (6257) read out Adjustments finished
                      2023-10-09 15:10:39.428 - info: hyperion_ng.0 (6257) create priorities
                      2023-10-09 15:10:40.347 - info: denon.0 (6552) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.denon, node: v18.17.1, js-controller: 5.0.12
                      2023-10-09 15:10:40.442 - info: denon.0 (6552) [START] Starting DENON AVR adapter
                      2023-10-09 15:10:40.448 - info: denon.0 (6552) [CONNECT] Trying to connect to 192.168.178.37:23
                      2023-10-09 15:10:40.482 - info: denon.0 (6552) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.37:23
                      2023-10-09 15:10:40.820 - info: hyperion_ng.0 (6257) read out priorities finished
                      2023-10-09 15:10:41.173 - info: hyperion_ng.0 (6257) create effects
                      2023-10-09 15:10:41.637 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                      2023-10-09 15:10:44.059 - info: host.raspberrypi4 instance system.adapter.worx.0 started with pid 6764
                      2023-10-09 15:10:44.827 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                      2023-10-09 15:10:44.998 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                      2023-10-09 15:10:45.148 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                      2023-10-09 15:10:45.294 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                      Aus dem Iob diag
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                         Static hostname: raspberrypi4
                               Icon name: computer
                              Machine ID: 226172a9cc584d89b1963a4dd6da7a12
                                 Boot ID: 8e888aa4fd59407dbddcad5931c7d04e
                        Operating System: Raspbian GNU/Linux 10 (buster)
                                  Kernel: Linux 5.10.103-v7l+
                            Architecture: arm
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : armv7l
                      Userland        : armhf
                      Systemuptime and Load:
                       17:06:24 up 3 days,  2:00,  1 user,  load average: 1.33, 0.92, 0.73
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      Other values than 0x0 hint to temperature/voltage problems
                      temp=46.7'C
                      volt=0.8600V
                      *** Time and Time Zones ***
                                     Local time: Mon 2023-10-09 17:06:25 CEST
                                 Universal time: Mon 2023-10-09 15:06:25 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           1.9G        1.3G        152M         95M        451M        419M
                      Swap:           99M         24M         75M
                      Total:         2.0G        1.3G        227M
                               1872 M total memory
                               1268 M used memory
                                245 M active memory
                               1378 M inactive memory
                                152 M free memory
                                 54 M buffer memory
                                396 M swap cache
                                 99 M total swap
                                 24 M used swap
                                 75 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  7.7G   49G  14% /
                      devtmpfs       devtmpfs  776M     0  776M   0% /dev
                      tmpfs          tmpfs     937M  3.4M  933M   1% /dev/shm
                      tmpfs          tmpfs     937M   91M  846M  10% /run
                      tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
                      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                      tmpfs          tmpfs     188M     0  188M   0% /run/user/999
                      tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
                      [Fri Oct  6 15:06:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2A:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=87f0f292-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                      [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                      [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                      [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): recovery complete
                      [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                      [Fri Oct  6 15:06:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Fri Oct  6 15:06:06 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                      [Mon Oct  9 15:07:54 2023] [<c03b6448>] (filemap_fault) from [<c0537e28>] (ext4_filemap_fault+0x38/0x4c)
                      [Mon Oct  9 15:07:54 2023] [<c0537df0>] (ext4_filemap_fault) from [<c03ef158>] (__do_fault+0x48/0x134)
                      TARGET        SOURCE         FSTYPE OPTIONS
                      /             /dev/mmcblk0p2 ext4   rw,noatime
                      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      699M    /var/
                      313M    /var/cache
                      307M    /var/cache/apt
                      248M    /var/cache/apt/archives
                      104M    /var/log
                      Archived and active journals take up 89.9M in the file system.
                      /opt/iobroker/backups:
                      917M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      353M    /opt/iobroker/iobroker-data/
                      193M    /opt/iobroker/iobroker-data/files
                      102M    /opt/iobroker/iobroker-data/backup-objects
                      52M     /opt/iobroker/iobroker-data/files/javascript.admin
                      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                      18M     /opt/iobroker/iobroker-data/states.jsonl
                      14M     /opt/iobroker/iobroker-data/objects.jsonl
                      11M     /opt/iobroker/iobroker-data/objects.json.migrated
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.17.1
                      /usr/bin/node           v18.17.1
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Installed: 18.17.1-1nodesource1
                        Candidate: 18.18.0-1nodesource1
                        Version table:
                           18.18.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                       *** 18.17.1-1nodesource1 500
                           18.17.0-1nodesource1 500
                           18.16.1-1nodesource1 500
                           18.16.0-1nodesource1 500
                           18.15.0-1nodesource1 500
                           18.14.2-1nodesource1 500
                           18.14.1-1nodesource1 500
                           18.14.0-1nodesource1 500
                           18.13.0-1nodesource1 500
                           18.12.0-1nodesource1 500
                           18.11.0-1nodesource1 500
                           18.10.0-1nodesource1 500
                           18.9.1-1nodesource1 500
                           18.9.0-1nodesource1 500
                           18.8.0-1nodesource1 500
                           18.7.0-1nodesource1 500
                           18.6.0-1nodesource1 500
                           18.5.0-1nodesource1 500
                           18.4.0-1nodesource1 500
                           18.3.0-1nodesource1 500
                           18.2.0-1nodesource1 500
                           18.1.0-1nodesource1 500
                           18.0.0-1nodesource1 500
                           10.24.0~dfsg-1~deb10u3 500
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      No configuration change needed.
                      Multihost discovery server: disabled
                      Discovery authentication:   enabled
                      Persistent activation:      disabled
                      Objects:                    jsonl on 127.0.0.1
                      States:                     jsonl on 127.0.0.1
                      Core adapters versions
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapters from github:   5
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : raspberrypi4                             -  enabled
                      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                      + system.adapter.deconz.0                 : deconz                : raspberrypi4                             -  enabled, port: 80
                      + system.adapter.denon.0                  : denon                 : raspberrypi4                             -  enabled
                      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi4                             -  enabled
                        system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                      + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                      + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4                             -  enabled
                      + system.adapter.hue.0                    : hue                   : raspberrypi4                             -  enabled, port: 443
                      + system.adapter.hyperion_ng.0            : hyperion_ng           : raspberrypi4                             -  enabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                      + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                      + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                        system.adapter.labcom.0                 : labcom                : raspberrypi4                             - disabled
                        system.adapter.material.0               : material              : raspberrypi4                             - disabled
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4                             -  enabled, port: 54321
                      + system.adapter.octoprint.0              : octoprint             : raspberrypi4                             -  enabled
                      + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4                             -  enabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
                      + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
                      + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4                             -  enabled
                      + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.socketio.0               : socketio              : raspberrypi4                             - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi4                             -  enabled
                      + system.adapter.tado.0                   : tado                  : raspberrypi4                             -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4                             - disabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                        system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                      + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.wled.0                   : wled                  : raspberrypi4                             - disabled
                      + system.adapter.worx.0                   : worx                  : raspberrypi4                             -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 6.10.1   , installed 6.10.1
                      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "denon"        : 1.15.4   , installed 1.15.4
                      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                      Adapter    "history"      : 2.2.6    , installed 2.2.6
                      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                      Adapter    "hue"          : 3.10.0   , installed 3.10.0
                      Adapter    "info"         : 2.0.0    , installed 2.0.0
                      Adapter    "iot"          : 1.14.5   , installed 1.14.5
                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                      Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                      Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                      Adapter    "tado"         : 0.4.9    , installed 0.4.9
                      Adapter    "web"          : 6.1.2    , installed 6.1.2
                      Adapter    "wled"         : 0.6.7    , installed 0.6.7
                      Adapter    "worx"         : 2.3.2    , installed 2.3.2
                      Adapter    "ws"           : 2.5.5    , installed 2.5.5
                      Objects and States
                      Objects:        15625
                      States:         13724
                      Hit:1 http://phoscon.de/apt/deconz buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 28
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15056      361/deCONZ
                      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19740      790/pihole-FTL
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19628      690/sshd
                      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          18112      721/lighttpd
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13478912   5544/io.sonoff.0
                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15065      361/deCONZ
                      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18245      790/pihole-FTL
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13475861   4358/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13472588   4358/iobroker.js-co
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13478112   4883/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13482716   6118/io.web.0
                      tcp6       0      0 :::53                   :::*                    LISTEN      999        19742      790/pihole-FTL
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          19630      690/sshd
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13482392   5908/io.simple-api.
                      tcp6       0      0 :::8090                 :::*                    LISTEN      0          18113      721/lighttpd
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       13484398   6813/io.harmony.0
                      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18246      790/pihole-FTL
                      udp        0      0 0.0.0.0:41887           0.0.0.0:*                           108        16332      356/avahi-daemon: r
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13484399   6813/io.harmony.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13479340   5366/io.shelly.0
                      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19739      790/pihole-FTL
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17526      653/dhcpcd
                      udp        0      0 0.0.0.0:48757           0.0.0.0:*                           1001       13862241   5366/io.shelly.0
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       13479330   5609/io.mihome-vacu
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16330      356/avahi-daemon: r
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13482735   6216/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18461      361/deCONZ
                      udp6       0      0 :::46030                :::*                                108        16333      356/avahi-daemon: r
                      udp6       0      0 :::53                   :::*                                999        19741      790/pihole-FTL
                      udp6       0      0 :::5353                 :::*                                108        16331      356/avahi-daemon: r
                      udp6       0      0 :::1900                 :::*                                1001       13482737   6216/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       13482736   6216/io.deconz.0
                      2023-10-09 16:19:50.668  - info: javascript.0 (5021) script.js.Fernseher.PS4: PS4 an
                      2023-10-09 16:19:51.670  - info: javascript.0 (5021) script.js.Fernseher.PS4: Sony an
                      2023-10-09 16:19:51.671  - info: javascript.0 (5021) script.js.Fernseher.PS4: Eingangsquelle Tv
                      2023-10-09 16:19:51.680  - info: hyperion_ng.0 (6257) set component V4L of instance 0 to false
                      2023-10-09 16:19:51.684  - info: harmony.0 (6813) hub busy, stateChange delayed: harmony.0.Harmony_Hub.Denon_AV-Empfänger.InputGame = 1
                      2023-10-09 16:19:51.712  - info: hyperion_ng.0 (6257) socket is connected
                      2023-10-09 16:19:52.048  - info: hyperion_ng.0 (6257) read out components finished
                      2023-10-09 16:19:52.049  - info: hyperion_ng.0 (6257) component is set
                      2023-10-09 16:19:54.680  - info: hyperion_ng.0 (6257) set component LEDDEVICE of instance 0 to false
                      2023-10-09 16:19:55.059  - info: hyperion_ng.0 (6257) read out components finished
                      2023-10-09 16:19:55.060  - info: hyperion_ng.0 (6257) component is set
                      2023-10-09 16:20:54.966  - info: hyperion_ng.0 (6257) socket timeout
                      2023-10-09 16:20:54.986  - info: hyperion_ng.0 (6257) Connection closed
                      2023-10-09 16:29:10.952  - info: mihome-vacuum.0 (5609) trigger cleaning segment 22
                      2023-10-09 16:30:00.069  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                      2023-10-09 16:31:31.277  - info: admin.0 (4883) failed connection to socket.io from ::ffff:192.168.178.60: Passport was not initialized
                      2023-10-09 16:31:43.629  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                      2023-10-09 16:37:33.190  - warn: javascript.0 (5021) script.js.Roborock.Wartungszustand: pushover: Rocki muss gewartet werden.
                      2023-10-09 16:43:55.977  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                      2023-10-09 16:43:56.960  - info: admin.0 (4883) <== Disconnect system.user.admin from ::ffff:192.168.178.60 admin
                      2023-10-09 16:45:00.061  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                      2023-10-09 17:00:00.097  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                      2023-10-09 17:04:26.119  - info: worx.0 (6764) Refresh token for MQTT-Connection
                      2023-10-09 17:04:26.122  - info: worx.0 (6764) Disconnected
                      2023-10-09 17:04:26.554  - info: worx.0 (6764) MQTT connected to: iot.eu-west-1.worxlandroid.com
                      Dazu noch der Screendshot aus dem Admin
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @johnnybahama
                      zeige mal den Ordner
                      ls -lh /opt/iobroker/iobroker-data/
                      • J JohnnyBahama
                        @Glasfaser
                        @Thomas-Braun
                        Es ist wieder passiert, hier der Log diesesmal im debug aus dem Broker:
                        2023-10-09 08:19:18.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 08:19:18.266 - info: worx.0 (3594) Disconnected
                        2023-10-09 08:19:18.614 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 08:42:37.100 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-10-09 09:15:58.160 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 09:15:58.162 - info: worx.0 (3594) Disconnected
                        2023-10-09 09:15:58.520 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 10:12:38.231 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 10:12:38.232 - info: worx.0 (3594) Disconnected
                        2023-10-09 10:12:38.600 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 10:54:00.074 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-10-09 10:54:01.439 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-10-09 11:09:18.284 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 11:09:18.286 - info: worx.0 (3594) Disconnected
                        2023-10-09 11:09:18.711 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 12:05:58.262 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 12:05:58.264 - info: worx.0 (3594) Disconnected
                        2023-10-09 12:05:58.639 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 13:02:38.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 13:02:38.266 - info: worx.0 (3594) Disconnected
                        2023-10-09 13:02:38.601 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 13:48:33.414 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-10-09 13:48:34.794 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-10-09 13:59:18.174 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 13:59:18.176 - info: worx.0 (3594) Disconnected
                        2023-10-09 13:59:18.539 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 14:55:58.210 - info: worx.0 (3594) Refresh token for MQTT-Connection
                        2023-10-09 14:55:58.212 - info: worx.0 (3594) Disconnected
                        2023-10-09 14:55:58.607 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        2023-10-09 15:00:00.055 - info: javascript.0 (1909) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                        2023-10-09 15:07:19.526 - info: admin.0 (1735) Adapter rating updated
                        2023-10-09 15:07:40.176 - info: admin.0 (1735) Request actual repository...
                        2023-10-09 15:07:41.017 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                        2023-10-09 15:07:55.157 - info: admin.0 (1735) Repository received successfully.
                        2023-10-09 15:07:55.320 - error: homeconnect.0 (3340) States database error: read ECONNRESET
                        2023-10-09 15:07:55.425 - error: worx.0 (3594) States database error: read ECONNRESET
                        2023-10-09 15:07:55.448 - error: javascript.0 (1909) States database error: read ECONNRESET
                        2023-10-09 15:07:55.532 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ambilight
                        2023-10-09 15:07:55.533 - info: javascript.0 (1909) Stop script script.js.Fernseher.Disney
                        2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ein_Ausschalten
                        2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Film
                        2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Netflix
                        2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.PS4
                        2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Umschalten
                        2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Fernseher.Youtube
                        2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Hyperion
                        2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Küche.Backofen.Rechner_Ablaufende_Zeit
                        2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.An_Aus
                        2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.Arbeitslicht
                        2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Licht.Wohnzimmer.Licht_an
                        2023-10-09 15:07:55.539 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Adapterüberwachung
                        2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Badezimmerfenster_schließen
                        2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Batteriestatus
                        2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Gartenstromversorgung_unterbrochen
                        2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Neustart
                        2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Power_Waschmaschine
                        2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Pumpe_an
                        2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Roborock
                        2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Tado_nicht_erreichbar
                        2023-10-09 15:07:55.543 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung_Cron
                        2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Pi_Hole.Deaktivieren
                        2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Roborock.Abwesenheitsreinigung
                        2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Alexa
                        2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Amelies_platz_reinigen
                        2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Einstellungen
                        2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Mülleimer_fahrt___laden
                        2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pausieren_Stoppen
                        2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pushover_Nachrichten
                        2023-10-09 15:07:55.547 - info: javascript.0 (1909) Stop script script.js.Roborock.Wartungszustand
                        2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Roborock.Zimmer_Reinigung
                        2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Abwesenheitsschließung
                        2023-10-09 15:07:55.549 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Rolladenautomatik
                        2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Terrase_schießen_verhindern
                        2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Verbrauch
                        2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Fernseher.Kino
                        2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Rasenmäher
                        2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Salzanlage_Status
                        2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Alexa.Poolwerteprüfung
                        2023-10-09 15:07:55.553 - info: javascript.0 (1909) Stop script script.js.Octoprint.Fertigmeldung
                        2023-10-09 15:07:55.554 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung
                        2023-10-09 15:07:55.274 - error: harmony.0 (3641) States database error: write EPIPE
                        2023-10-09 15:07:55.413 - info: backitup.0 (2623) cleaned everything up...
                        2023-10-09 15:07:55.411 - info: tado.0 (2927) cleaned everything up...
                        2023-10-09 15:07:55.411 - info: simple-api.0 (2807) terminating http server on port 8087
                        2023-10-09 15:07:55.416 - info: pi-hole.0 (3220) cleaned everything up...
                        2023-10-09 15:07:55.319 - error: device-reminder.0 (3424) States database error: read ECONNRESET
                        2023-10-09 15:07:55.418 - info: deconz.0 (2958) cleaned everything up...
                        2023-10-09 15:07:55.378 - error: denon.0 (3333) States database error: write EPIPE
                        2023-10-09 15:07:55.713 - info: denon.0 (3333) [END] Stopping Denon AVR adapter...
                        2023-10-09 15:07:55.348 - error: iot.0 (3002) States database error: read ECONNRESET
                        2023-10-09 15:07:55.791 - info: harmony.0 (3641) [END] Terminating
                        2023-10-09 15:07:55.912 - warn: web.0 (2876) Timeout by termination of web-extensions!
                        2023-10-09 15:07:55.922 - info: web.0 (2876) terminated http server on port 8082
                        2023-10-09 15:07:56.025 - info: iot.0 (3002) Connection changed: disconnect
                        2023-10-09 15:07:56.026 - info: iot.0 (3002) Connection lost
                        2023-10-09 15:07:56.193 - info: worx.0 (3594) Disconnected
                        2023-10-09 15:07:56.705 - error: shuttercontrol.0 (7987) States database error: write EPIPE
                        2023-10-09 15:07:56.722 - info: shuttercontrol.0 (7987) cleaned everything up...
                        2023-10-09 15:07:56.705 - error: info.0 (2870) States database error: write EPIPE
                        2023-10-09 15:07:56.720 - error: mihome-vacuum.0 (2407) States database error: write EPIPE
                        2023-10-09 15:07:56.760 - info: info.0 (2870) cleaned everything up...
                        2023-10-09 15:07:56.712 - error: hue.0 (2181) States database error: write EPIPE
                        2023-10-09 15:07:56.701 - error: pushover.0 (1939) States database error: write EPIPE
                        2023-10-09 15:07:56.717 - error: sonoff.0 (2325) States database error: write EPIPE
                        2023-10-09 15:07:56.774 - error: mihome-vacuum.0 (2407) Socket Close
                        2023-10-09 15:07:56.702 - error: shelly.0 (2068) States database error: write EPIPE
                        2023-10-09 15:07:56.736 - error: ping.0 (2467) States database error: write EPIPE
                        2023-10-09 15:07:56.726 - error: octoprint.0 (3660) States database error: write EPIPE
                        2023-10-09 15:07:56.913 - info: sony-bravia.0 (2297) terminating with timeout
                        2023-10-09 15:07:56.919 - info: sony-bravia.0 (2297) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:56.953 - info: web.0 (2876) terminating with timeout
                        2023-10-09 15:07:56.955 - info: web.0 (2876) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.033 - info: javascript.0 (1909) terminating with timeout
                        2023-10-09 15:07:57.034 - info: javascript.0 (1909) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.067 - info: hyperion_ng.0 (3062) terminating with timeout
                        2023-10-09 15:07:57.086 - info: hyperion_ng.0 (3062) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.110 - info: homeconnect.0 (3340) terminating with timeout
                        2023-10-09 15:07:57.126 - info: alexa2.0 (2661) terminating with timeout
                        2023-10-09 15:07:57.128 - info: alexa2.0 (2661) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.144 - info: backitup.0 (2623) terminating with timeout
                        2023-10-09 15:07:57.146 - info: backitup.0 (2623) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.181 - info: homeconnect.0 (3340) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.216 - info: denon.0 (3333) terminating with timeout
                        2023-10-09 15:07:57.257 - info: tado.0 (2927) terminating with timeout
                        2023-10-09 15:07:57.259 - info: tado.0 (2927) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.260 - info: deconz.0 (2958) terminating with timeout
                        2023-10-09 15:07:57.261 - info: simple-api.0 (2807) terminating with timeout
                        2023-10-09 15:07:57.262 - info: deconz.0 (2958) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.265 - info: simple-api.0 (2807) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.268 - info: pi-hole.0 (3220) terminating with timeout
                        2023-10-09 15:07:57.270 - info: pi-hole.0 (3220) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.272 - info: denon.0 (3333) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.296 - info: harmony.0 (3641) terminating with timeout
                        2023-10-09 15:07:57.324 - info: harmony.0 (3641) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.410 - info: device-reminder.0 (3424) terminating with timeout
                        2023-10-09 15:07:57.413 - info: iot.0 (3002) terminating with timeout
                        2023-10-09 15:07:57.441 - info: device-reminder.0 (3424) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.431 - info: iot.0 (3002) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:57.453 - info: worx.0 (3594) terminating with timeout
                        2023-10-09 15:07:57.468 - info: worx.0 (3594) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.210 - info: history.0 (1771) Delete old history "/opt/iobroker/history/20221008/history.denon.0.zoneMain.powerZone.json"
                        2023-10-09 15:07:58.227 - info: shuttercontrol.0 (7987) terminating with timeout
                        2023-10-09 15:07:58.230 - info: shuttercontrol.0 (7987) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:55.477 - debug: admin.0 (1735) Next repo update on 10/10/2023, 15:07:55
                        2023-10-09 15:07:58.260 - error: admin.0 (1735) States database error: write EPIPE
                        2023-10-09 15:07:58.264 - info: info.0 (2870) terminating with timeout
                        2023-10-09 15:07:58.267 - info: mihome-vacuum.0 (2407) terminating with timeout
                        2023-10-09 15:07:58.267 - info: info.0 (2870) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.269 - info: mihome-vacuum.0 (2407) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.285 - info: pushover.0 (1939) terminating with timeout
                        2023-10-09 15:07:58.291 - info: pushover.0 (1939) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.290 - info: admin.0 (1735) terminating https server on port 8081
                        2023-10-09 15:07:58.308 - info: sonoff.0 (2325) terminating with timeout
                        2023-10-09 15:07:58.310 - info: sonoff.0 (2325) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.321 - info: shelly.0 (2068) terminating with timeout
                        2023-10-09 15:07:58.323 - info: shelly.0 (2068) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.331 - info: hue.0 (2181) terminating with timeout
                        2023-10-09 15:07:58.333 - info: hue.0 (2181) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.340 - info: ping.0 (2467) terminating with timeout
                        2023-10-09 15:07:58.342 - info: ping.0 (2467) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:58.394 - info: octoprint.0 (3660) terminating with timeout
                        2023-10-09 15:07:58.397 - info: octoprint.0 (3660) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:07:59.795 - info: admin.0 (1735) terminating with timeout
                        2023-10-09 15:07:59.799 - debug: admin.0 (1735) Plugin sentry destroyed
                        2023-10-09 15:07:59.799 - info: admin.0 (1735) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:08:00.187 - error: web.0 (2876) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.196 - error: backitup.0 (2623) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.223 - error: hyperion_ng.0 (3062) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.241 - error: sony-bravia.0 (2297) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.269 - error: alexa2.0 (2661) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.270 - error: tado.0 (2927) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.265 - warn: sony-bravia.0 (2297) get state error: Connection is closed.
                        2023-10-09 15:08:00.267 - warn: sony-bravia.0 (2297) get state error: DB closed
                        2023-10-09 15:08:00.272 - info: sony-bravia.0 (2297) terminating
                        2023-10-09 15:08:00.278 - info: sony-bravia.0 (2297) terminating
                        2023-10-09 15:08:00.291 - error: pi-hole.0 (3220) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.295 - error: simple-api.0 (2807) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.335 - error: deconz.0 (2958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.348 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.362 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                        2023-10-09 15:08:00.369 - warn: pi-hole.0 (3220) get state error: Connection is closed.
                        2023-10-09 15:08:00.370 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.371 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.372 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.374 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.376 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.377 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.378 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.379 - warn: pi-hole.0 (3220) get state error: DB closed
                        2023-10-09 15:08:00.395 - info: pi-hole.0 (3220) terminating
                        2023-10-09 15:08:00.397 - info: pi-hole.0 (3220) terminating
                        2023-10-09 15:08:00.432 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.433 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.439 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.440 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.441 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.442 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.443 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.444 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.445 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.446 - warn: homeconnect.0 (3340) get state error: DB closed
                        2023-10-09 15:08:00.453 - info: homeconnect.0 (3340) terminating
                        2023-10-09 15:08:00.454 - info: homeconnect.0 (3340) terminating
                        2023-10-09 15:08:00.480 - error: javascript.0 (1909) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.539 - warn: javascript.0 (1909) get state error: DB closed
                        2023-10-09 15:08:00.539 - error: worx.0 (3594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.542 - warn: javascript.0 (1909) get state error: DB closed
                        2023-10-09 15:08:00.543 - warn: javascript.0 (1909) get state error: DB closed
                        2023-10-09 15:08:00.544 - warn: javascript.0 (1909) get state error: DB closed
                        2023-10-09 15:08:00.545 - warn: javascript.0 (1909) get state error: DB closed
                        2023-10-09 15:08:00.550 - info: javascript.0 (1909) terminating
                        2023-10-09 15:08:00.554 - warn: worx.0 (3594) get state error: DB closed
                        2023-10-09 15:08:00.557 - warn: worx.0 (3594) get state error: DB closed
                        2023-10-09 15:08:00.558 - warn: worx.0 (3594) get state error: DB closed
                        2023-10-09 15:08:00.559 - warn: worx.0 (3594) get state error: DB closed
                        2023-10-09 15:08:00.566 - info: worx.0 (3594) terminating
                        2023-10-09 15:08:00.781 - error: device-reminder.0 (3424) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.791 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.792 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.793 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.794 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.795 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.796 - warn: device-reminder.0 (3424) get state error: DB closed
                        2023-10-09 15:08:00.800 - info: device-reminder.0 (3424) terminating
                        2023-10-09 15:08:00.801 - info: device-reminder.0 (3424) terminating
                        2023-10-09 15:08:00.823 - error: denon.0 (3333) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.841 - warn: denon.0 (3333) get state error: Connection is closed.
                        2023-10-09 15:08:00.842 - warn: denon.0 (3333) get state error: DB closed
                        2023-10-09 15:08:00.843 - warn: denon.0 (3333) get state error: DB closed
                        2023-10-09 15:08:00.845 - warn: denon.0 (3333) get state error: DB closed
                        2023-10-09 15:08:00.846 - warn: denon.0 (3333) get state error: DB closed
                        2023-10-09 15:08:00.850 - info: denon.0 (3333) terminating
                        2023-10-09 15:08:00.851 - info: denon.0 (3333) terminating
                        2023-10-09 15:08:00.857 - error: harmony.0 (3641) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.875 - error: iot.0 (3002) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:00.910 - warn: harmony.0 (3641) get state error: Connection is closed.
                        2023-10-09 15:08:01.747 - error: shuttercontrol.0 (7987) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.784 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10F9B0#1.Relay1.Timer, error - DB closed
                        2023-10-09 15:08:01.801 - error: info.0 (2870) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.787 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10CD90#1.Shutter.Duration, error - DB closed
                        2023-10-09 15:08:01.788 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#F3353D#1.Shutter.Duration, error - DB closed
                        2023-10-09 15:08:01.789 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10D202#1.Shutter.Duration, error - DB closed
                        2023-10-09 15:08:01.790 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#110D76#1.Relay1.Timer, error - DB closed
                        2023-10-09 15:08:01.790 - warn: shelly.0 (2068) get state error: DB closed
                        2023-10-09 15:08:01.791 - warn: shelly.0 (2068) get state error: DB closed
                        2023-10-09 15:08:01.805 - error: pushover.0 (1939) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.822 - error: mihome-vacuum.0 (2407) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.836 - error: sonoff.0 (2325) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.842 - info: shelly.0 (2068) terminating
                        2023-10-09 15:08:01.843 - info: shelly.0 (2068) terminating
                        2023-10-09 15:08:01.874 - error: hue.0 (2181) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.881 - error: ping.0 (2467) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:01.925 - error: octoprint.0 (3660) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:03.308 - error: admin.0 (1735) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:03.318 - warn: admin.0 (1735) get state error: Connection is closed.
                        2023-10-09 15:08:03.319 - warn: admin.0 (1735) get state error: DB closed
                        2023-10-09 15:08:03.320 - warn: admin.0 (1735) get state error: DB closed
                        2023-10-09 15:08:03.321 - warn: admin.0 (1735) get state error: DB closed
                        2023-10-09 15:08:03.322 - warn: admin.0 (1735) get state error: DB closed
                        2023-10-09 15:08:03.324 - info: admin.0 (1735) terminating
                        2023-10-09 15:08:05.306 - error: pi-hole.0 (3220) Cannot check object existence of "pi-hole.0.version": Connection is closed.
                        2023-10-09 15:08:05.379 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                        2023-10-09 15:08:05.383 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:08.324 - error: admin.0 (1735) Cannot find view "system" for search "instance" : Connection is closed.
                        2023-10-09 15:08:09.759 - info: history.0 (1771) terminating with timeout
                        2023-10-09 15:08:09.763 - info: history.0 (1771) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:08:10.388 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2023-10-09 15:08:17.666 - info: host.raspberrypi4 iobroker.js-controller version 5.0.12 js-controller starting
                        2023-10-09 15:08:17.673 - info: host.raspberrypi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                        2023-10-09 15:08:17.675 - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.1
                        2023-10-09 15:08:17.675 - info: host.raspberrypi4 ip addresses: 192.168.178.70 2003:f5:f26:b900:3583:2470:ce5:f0d4 fe80::a637:87cf:1b83:c822
                        2023-10-09 15:08:20.777 - info: host.raspberrypi4 connected to Objects and States
                        2023-10-09 15:08:20.876 - info: host.raspberrypi4 added notifications configuration of host
                        2023-10-09 15:08:22.204 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeCurrent"
                        2023-10-09 15:08:22.206 - info: host.raspberrypi4 38 instances found
                        2023-10-09 15:08:22.296 - info: host.raspberrypi4 starting 28 instances
                        2023-10-09 15:08:22.491 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewest"
                        2023-10-09 15:08:22.536 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4461
                        2023-10-09 15:08:22.546 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
                        2023-10-09 15:08:22.557 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
                        2023-10-09 15:08:22.568 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
                        2023-10-09 15:08:22.578 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
                        2023-10-09 15:08:22.589 - info: host.raspberrypi4 Some obsolete host states deleted.
                        2023-10-09 15:08:26.272 - error: admin.0 (4461) admin.0 already running
                        2023-10-09 15:08:26.277 - warn: admin.0 (4461) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:26.479 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4501
                        2023-10-09 15:08:27.111 - error: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:27.112 - info: host.raspberrypi4 Restart adapter system.adapter.admin.0 because enabled
                        2023-10-09 15:08:29.053 - error: history.0 (4501) history.0 already running
                        2023-10-09 15:08:29.061 - warn: history.0 (4501) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:29.727 - error: host.raspberrypi4 instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:29.728 - info: host.raspberrypi4 Restart adapter system.adapter.history.0 because enabled
                        2023-10-09 15:08:30.543 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 4570
                        2023-10-09 15:08:34.600 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 4605
                        2023-10-09 15:08:35.010 - error: javascript.0 (4570) javascript.0 already running
                        2023-10-09 15:08:35.015 - warn: javascript.0 (4570) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:35.730 - error: host.raspberrypi4 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:35.731 - info: host.raspberrypi4 Restart adapter system.adapter.javascript.0 because enabled
                        2023-10-09 15:08:37.148 - error: pushover.0 (4605) pushover.0 already running
                        2023-10-09 15:08:37.153 - warn: pushover.0 (4605) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:37.856 - error: host.raspberrypi4 instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:37.856 - info: host.raspberrypi4 Restart adapter system.adapter.pushover.0 because enabled
                        2023-10-09 15:08:38.510 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 4672
                        2023-10-09 15:08:41.117 - error: alexa2.0 (4672) alexa2.0 already running
                        2023-10-09 15:08:41.121 - warn: alexa2.0 (4672) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:41.800 - error: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:41.800 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
                        2023-10-09 15:08:42.545 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 4706
                        2023-10-09 15:08:45.475 - error: shelly.0 (4706) shelly.0 already running
                        2023-10-09 15:08:45.479 - warn: shelly.0 (4706) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:46.194 - error: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:46.196 - info: host.raspberrypi4 Restart adapter system.adapter.shelly.0 because enabled
                        2023-10-09 15:08:46.491 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 4741
                        2023-10-09 15:08:49.352 - error: hue.0 (4741) hue.0 already running
                        2023-10-09 15:08:49.356 - warn: hue.0 (4741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:50.077 - error: host.raspberrypi4 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:50.078 - info: host.raspberrypi4 Restart adapter system.adapter.hue.0 because enabled
                        2023-10-09 15:08:50.500 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 4813
                        2023-10-09 15:08:53.519 - error: sony-bravia.0 (4813) sony-bravia.0 already running
                        2023-10-09 15:08:53.523 - warn: sony-bravia.0 (4813) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:54.203 - error: host.raspberrypi4 instance system.adapter.sony-bravia.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:54.203 - info: host.raspberrypi4 Restart adapter system.adapter.sony-bravia.0 because enabled
                        2023-10-09 15:08:54.521 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 4848
                        2023-10-09 15:08:57.007 - error: sonoff.0 (4848) sonoff.0 already running
                        2023-10-09 15:08:57.011 - warn: sonoff.0 (4848) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:08:57.299 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4883
                        2023-10-09 15:08:57.707 - error: host.raspberrypi4 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:08:57.708 - info: host.raspberrypi4 Restart adapter system.adapter.sonoff.0 because enabled
                        2023-10-09 15:08:58.511 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 4927
                        2023-10-09 15:08:59.991 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4945
                        2023-10-09 15:09:02.069 - error: mihome-vacuum.0 (4927) mihome-vacuum.0 already running
                        2023-10-09 15:09:02.076 - warn: mihome-vacuum.0 (4927) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:02.148 - info: admin.0 (4883) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:02.226 - info: admin.0 (4883) requesting all objects
                        2023-10-09 15:09:04.821 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5003
                        2023-10-09 15:09:04.935 - error: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:04.937 - info: host.raspberrypi4 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                        2023-10-09 15:09:05.363 - info: admin.0 (4883) received all objects
                        2023-10-09 15:09:05.993 - info: admin.0 (4883) Request actual repository...
                        2023-10-09 15:09:06.225 - info: admin.0 (4883) Secure socket.io server listening on port 8081
                        2023-10-09 15:09:06.241 - info: admin.0 (4883) https server listening on port 8081
                        2023-10-09 15:09:06.241 - info: admin.0 (4883) Use link "https://127.0.0.1:8081" to configure.
                        2023-10-09 15:09:06.473 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 5021
                        2023-10-09 15:09:07.317 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5038
                        2023-10-09 15:09:08.167 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 5092
                        2023-10-09 15:09:09.099 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                        2023-10-09 15:09:09.373 - info: history.0 (4945) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.history, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:11.534 - error: ping.0 (5003) ping.0 already running
                        2023-10-09 15:09:11.540 - warn: ping.0 (5003) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:11.615 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5167
                        2023-10-09 15:09:13.043 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5189
                        2023-10-09 15:09:13.099 - error: host.raspberrypi4 instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:13.100 - info: host.raspberrypi4 Restart adapter system.adapter.ping.0 because enabled
                        2023-10-09 15:09:13.392 - error: backitup.0 (5038) backitup.0 already running
                        2023-10-09 15:09:13.398 - warn: backitup.0 (5038) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:14.317 - error: host.raspberrypi4 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:14.318 - info: host.raspberrypi4 Restart adapter system.adapter.backitup.0 because enabled
                        2023-10-09 15:09:14.934 - info: host.raspberrypi4 instance system.adapter.simple-api.0 started with pid 5275
                        2023-10-09 15:09:20.498 - info: admin.0 (4883) Repository received successfully.
                        2023-10-09 15:09:21.185 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 5366
                        2023-10-09 15:09:21.419 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 5379
                        2023-10-09 15:09:21.714 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 5386
                        2023-10-09 15:09:21.856 - error: info.0 (5167) info.0 already running
                        2023-10-09 15:09:21.863 - warn: info.0 (5167) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:22.066 - error: simple-api.0 (5275) simple-api.0 already running
                        2023-10-09 15:09:22.083 - warn: simple-api.0 (5275) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:22.766 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 5399
                        2023-10-09 15:09:23.115 - error: host.raspberrypi4 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:23.116 - info: host.raspberrypi4 Restart adapter system.adapter.info.0 because enabled
                        2023-10-09 15:09:23.341 - error: host.raspberrypi4 instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:23.342 - info: host.raspberrypi4 Restart adapter system.adapter.simple-api.0 because enabled
                        2023-10-09 15:09:23.423 - info: pushover.0 (5092) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:23.705 - info: javascript.0 (5021) starting. Version 7.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:24.059 - info: alexa2.0 (5189) starting. Version 3.25.2 (non-npm: Apollon77/ioBroker.alexa2#2f00d64d7149f65565470bf222734cab76e303ec) in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:24.583 - info: alexa2.0 (5189) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                        2023-10-09 15:09:26.947 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 5454
                        2023-10-09 15:09:27.615 - info: javascript.0 (5021) requesting all states
                        2023-10-09 15:09:27.619 - info: javascript.0 (5021) requesting all objects
                        2023-10-09 15:09:29.302 - info: alexa2.0 (5189) Update cookie in adapter configuration ... restarting ...
                        2023-10-09 15:09:31.235 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 5531
                        2023-10-09 15:09:31.555 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 (force=false, process=true)
                        2023-10-09 15:09:31.814 - info: javascript.0 (5021) received all objects
                        2023-10-09 15:09:32.123 - info: javascript.0 (5021) received all states
                        2023-10-09 15:09:32.135 - info: alexa2.0 (5189) Got terminate signal TERMINATE_YOURSELF
                        2023-10-09 15:09:32.148 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 send kill signal
                        2023-10-09 15:09:32.143 - info: alexa2.0 (5189) terminating
                        2023-10-09 15:09:32.166 - info: alexa2.0 (5189) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-10-09 15:09:32.557 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 5544
                        2023-10-09 15:09:32.670 - info: alexa2.0 (5189) terminating
                        2023-10-09 15:09:32.878 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 5551
                        2023-10-09 15:09:33.191 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 killing pid 5189
                        2023-10-09 15:09:33.247 - error: web.0 (5379) web.0 already running
                        2023-10-09 15:09:33.256 - warn: web.0 (5379) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:34.968 - error: tado.0 (5399) tado.0 already running
                        2023-10-09 15:09:34.976 - warn: tado.0 (5399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:35.951 - error: host.raspberrypi4 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:35.953 - info: host.raspberrypi4 Restart adapter system.adapter.web.0 because enabled
                        2023-10-09 15:09:36.784 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 5592
                        2023-10-09 15:09:37.084 - error: host.raspberrypi4 instance system.adapter.tado.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:37.085 - info: host.raspberrypi4 Restart adapter system.adapter.tado.0 because enabled
                        2023-10-09 15:09:37.477 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 5609
                        2023-10-09 15:09:37.823 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5616
                        2023-10-09 15:09:39.022 - error: deconz.0 (5531) deconz.0 already running
                        2023-10-09 15:09:39.027 - warn: deconz.0 (5531) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:39.453 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 5667
                        2023-10-09 15:09:40.033 - error: iot.0 (5551) iot.0 already running
                        2023-10-09 15:09:40.047 - warn: iot.0 (5551) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:40.543 - error: host.raspberrypi4 instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:40.546 - info: host.raspberrypi4 Restart adapter system.adapter.deconz.0 because enabled
                        2023-10-09 15:09:41.055 - error: host.raspberrypi4 instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:41.056 - info: host.raspberrypi4 Restart adapter system.adapter.iot.0 because enabled
                        2023-10-09 15:09:42.156 - error: hyperion_ng.0 (5592) hyperion_ng.0 already running
                        2023-10-09 15:09:42.161 - warn: hyperion_ng.0 (5592) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:42.219 - info: hue.0 (5386) starting. Version 3.10.0 in /opt/iobroker/node_modules/iobroker.hue, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:42.237 - info: shelly.0 (5366) starting. Version 6.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:43.424 - info: hue.0 (5386) Push connection established
                        2023-10-09 15:09:43.769 - error: host.raspberrypi4 instance system.adapter.hyperion_ng.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:43.780 - info: host.raspberrypi4 Restart adapter system.adapter.hyperion_ng.0 because enabled
                        2023-10-09 15:09:44.343 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5734
                        2023-10-09 15:09:45.388 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5747
                        2023-10-09 15:09:45.991 - error: shuttercontrol.0 (5667) shuttercontrol.0 already running
                        2023-10-09 15:09:46.002 - warn: shuttercontrol.0 (5667) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:46.430 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 5764
                        2023-10-09 15:09:47.187 - error: host.raspberrypi4 instance system.adapter.shuttercontrol.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:47.188 - info: host.raspberrypi4 Restart adapter system.adapter.shuttercontrol.0 because enabled
                        2023-10-09 15:09:52.766 - error: pi-hole.0 (5764) pi-hole.0 already running
                        2023-10-09 15:09:52.784 - warn: pi-hole.0 (5764) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:55.371 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5896
                        2023-10-09 15:09:55.429 - error: host.raspberrypi4 instance system.adapter.pi-hole.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:55.430 - info: host.raspberrypi4 Restart adapter system.adapter.pi-hole.0 because enabled
                        2023-10-09 15:09:56.413 - info: vis.0 (5727) Terminated (NO_ERROR): Without reason
                        2023-10-09 15:09:56.632 - error: denon.0 (5862) denon.0 already running
                        2023-10-09 15:09:56.641 - warn: denon.0 (5862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:09:56.934 - info: ping.0 (5734) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:09:59.473 - info: host.raspberrypi4 instance system.adapter.vis.0 terminated while should be started once
                        2023-10-09 15:09:59.995 - error: host.raspberrypi4 instance system.adapter.denon.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:09:59.996 - info: host.raspberrypi4 Restart adapter system.adapter.denon.0 because enabled
                        2023-10-09 15:10:04.282 - error: homeconnect.0 (5915) homeconnect.0 already running
                        2023-10-09 15:10:04.291 - warn: homeconnect.0 (5915) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:10:05.585 - error: device-reminder.0 (6014) device-reminder.0 already running
                        2023-10-09 15:10:05.593 - warn: device-reminder.0 (6014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:10:06.078 - error: host.raspberrypi4 instance system.adapter.homeconnect.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:10:06.979 - info: host.raspberrypi4 instance system.adapter.harmony.0 started with pid 6106
                        2023-10-09 15:10:07.062 - error: host.raspberrypi4 instance system.adapter.device-reminder.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:10:07.063 - info: host.raspberrypi4 Restart adapter system.adapter.device-reminder.0 because enabled
                        2023-10-09 15:10:07.129 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 6118
                        2023-10-09 15:10:07.759 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 6130
                        2023-10-09 15:10:08.603 - info: simple-api.0 (5908) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:08.809 - warn: simple-api.0 (5908) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                        2023-10-09 15:10:08.895 - info: simple-api.0 (5908) simpleAPI server listening on port 8087
                        2023-10-09 15:10:08.897 - info: simple-api.0 (5908) Allow states only when user is owner: false
                        2023-10-09 15:10:08.927 - info: simple-api.0 (5908) http server listening on port 8087
                        2023-10-09 15:10:09.091 - info: backitup.0 (5747) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:09.988 - info: backitup.0 (5747) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-10-09 15:10:11.599 - error: worx.0 (6085) worx.0 already running
                        2023-10-09 15:10:11.611 - warn: worx.0 (6085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:10:11.818 - info: host.raspberrypi4 instance system.adapter.octoprint.0 started with pid 6206
                        2023-10-09 15:10:12.009 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 6216
                        2023-10-09 15:10:12.314 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 6228
                        2023-10-09 15:10:13.226 - error: host.raspberrypi4 instance system.adapter.worx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:10:13.257 - info: host.raspberrypi4 Restart adapter system.adapter.worx.0 because enabled
                        2023-10-09 15:10:15.518 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 6257
                        2023-10-09 15:10:16.612 - error: harmony.0 (6106) harmony.0 already running
                        2023-10-09 15:10:16.620 - warn: harmony.0 (6106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:10:18.718 - error: host.raspberrypi4 instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:10:18.719 - info: host.raspberrypi4 Restart adapter system.adapter.harmony.0 because enabled
                        2023-10-09 15:10:19.320 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 6304
                        2023-10-09 15:10:20.117 - error: octoprint.0 (6206) octoprint.0 already running
                        2023-10-09 15:10:20.134 - warn: octoprint.0 (6206) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-10-09 15:10:21.821 - error: host.raspberrypi4 instance system.adapter.octoprint.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-10-09 15:10:21.822 - info: host.raspberrypi4 Restart adapter system.adapter.octoprint.0 because enabled
                        2023-10-09 15:10:23.534 - info: web.0 (6118) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:23.633 - info: tado.0 (6130) starting. Version 0.4.9 in /opt/iobroker/node_modules/iobroker.tado, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:23.787 - info: hyperion_ng.0 (6257) starting. Version 0.1.23 (non-npm: felixganzer/ioBroker.hyperion_ng#b27f55704d34a7eed2865ca421409d091d86cd38) in /opt/iobroker/node_modules/iobroker.hyperion_ng, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:23.856 - info: hyperion_ng.0 (6257) create Control Parameter
                        2023-10-09 15:10:23.720 - info: tado.0 (6130) Started with JSON-Explorer version 0.1.12
                        2023-10-09 15:10:24.450 - info: tado.0 (6130) Connected to Tado cloud, initialyzing...
                        2023-10-09 15:10:24.456 - info: sony-bravia.0 (5454) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.sony-bravia, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:24.727 - info: web.0 (6118) socket.io server listening on port 8082
                        2023-10-09 15:10:24.761 - info: web.0 (6118) http server listening on port 8082
                        2023-10-09 15:10:25.033 - info: deconz.0 (6216) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:25.075 - info: hyperion_ng.0 (6257) 210,0.5000000000000001,0.39215686274509803
                        2023-10-09 15:10:25.582 - info: deconz.0 (6216) deConz Version: 2.22.2; API version: 1.16.0
                        2023-10-09 15:10:25.806 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 6469
                        2023-10-09 15:10:26.007 - info: hyperion_ng.0 (6257) socket is connected
                        2023-10-09 15:10:28.243 - info: iot.0 (6228) starting. Version 1.14.5 in /opt/iobroker/node_modules/iobroker.iot, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:28.796 - info: iot.0 (6228) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                        2023-10-09 15:10:31.212 - info: host.raspberrypi4 instance system.adapter.denon.0 started with pid 6552
                        2023-10-09 15:10:32.365 - info: iot.0 (6228) Connection changed: connect
                        2023-10-09 15:10:32.854 - info: info.0 (5896) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:33.435 - info: pi-hole.0 (6469) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:33.627 - info: info.0 (5896) Reading/updating systemdata.
                        2023-10-09 15:10:35.029 - info: hyperion_ng.0 (6257) read out components finished
                        2023-10-09 15:10:36.567 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.blue" has to be stringified but received type "object"
                        2023-10-09 15:10:36.708 - info: host.raspberrypi4 instance system.adapter.homeconnect.0 started with pid 6619
                        2023-10-09 15:10:37.014 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.cyan" has to be stringified but received type "object"
                        2023-10-09 15:10:37.767 - info: host.raspberrypi4 instance system.adapter.device-reminder.0 started with pid 6636
                        2023-10-09 15:10:38.027 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.green" has to be stringified but received type "object"
                        2023-10-09 15:10:38.324 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.magenta" has to be stringified but received type "object"
                        2023-10-09 15:10:38.521 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.red" has to be stringified but received type "object"
                        2023-10-09 15:10:38.783 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.white" has to be stringified but received type "object"
                        2023-10-09 15:10:38.946 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.yellow" has to be stringified but received type "object"
                        2023-10-09 15:10:38.984 - info: shuttercontrol.0 (6304) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:39.001 - info: hyperion_ng.0 (6257) read out Adjustments finished
                        2023-10-09 15:10:39.428 - info: hyperion_ng.0 (6257) create priorities
                        2023-10-09 15:10:40.347 - info: denon.0 (6552) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.denon, node: v18.17.1, js-controller: 5.0.12
                        2023-10-09 15:10:40.442 - info: denon.0 (6552) [START] Starting DENON AVR adapter
                        2023-10-09 15:10:40.448 - info: denon.0 (6552) [CONNECT] Trying to connect to 192.168.178.37:23
                        2023-10-09 15:10:40.482 - info: denon.0 (6552) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.37:23
                        2023-10-09 15:10:40.820 - info: hyperion_ng.0 (6257) read out priorities finished
                        2023-10-09 15:10:41.173 - info: hyperion_ng.0 (6257) create effects
                        2023-10-09 15:10:41.637 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                        2023-10-09 15:10:44.059 - info: host.raspberrypi4 instance system.adapter.worx.0 started with pid 6764
                        2023-10-09 15:10:44.827 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                        2023-10-09 15:10:44.998 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                        2023-10-09 15:10:45.148 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                        2023-10-09 15:10:45.294 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                        Aus dem Iob diag
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                           Static hostname: raspberrypi4
                                 Icon name: computer
                                Machine ID: 226172a9cc584d89b1963a4dd6da7a12
                                   Boot ID: 8e888aa4fd59407dbddcad5931c7d04e
                          Operating System: Raspbian GNU/Linux 10 (buster)
                                    Kernel: Linux 5.10.103-v7l+
                              Architecture: arm
                        Model           : Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : armv7l
                        Userland        : armhf
                        Systemuptime and Load:
                         17:06:24 up 3 days,  2:00,  1 user,  load average: 1.33, 0.92, 0.73
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        Other values than 0x0 hint to temperature/voltage problems
                        temp=46.7'C
                        volt=0.8600V
                        *** Time and Time Zones ***
                                       Local time: Mon 2023-10-09 17:06:25 CEST
                                   Universal time: Mon 2023-10-09 15:06:25 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           1.9G        1.3G        152M         95M        451M        419M
                        Swap:           99M         24M         75M
                        Total:         2.0G        1.3G        227M
                                 1872 M total memory
                                 1268 M used memory
                                  245 M active memory
                                 1378 M inactive memory
                                  152 M free memory
                                   54 M buffer memory
                                  396 M swap cache
                                   99 M total swap
                                   24 M used swap
                                   75 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  7.7G   49G  14% /
                        devtmpfs       devtmpfs  776M     0  776M   0% /dev
                        tmpfs          tmpfs     937M  3.4M  933M   1% /dev/shm
                        tmpfs          tmpfs     937M   91M  846M  10% /run
                        tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                        tmpfs          tmpfs     188M     0  188M   0% /run/user/999
                        tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
                        [Fri Oct  6 15:06:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2A:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=87f0f292-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                        [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                        [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): recovery complete
                        [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Fri Oct  6 15:06:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Fri Oct  6 15:06:06 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        [Mon Oct  9 15:07:54 2023] [<c03b6448>] (filemap_fault) from [<c0537e28>] (ext4_filemap_fault+0x38/0x4c)
                        [Mon Oct  9 15:07:54 2023] [<c0537df0>] (ext4_filemap_fault) from [<c03ef158>] (__do_fault+0x48/0x134)
                        TARGET        SOURCE         FSTYPE OPTIONS
                        /             /dev/mmcblk0p2 ext4   rw,noatime
                        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        699M    /var/
                        313M    /var/cache
                        307M    /var/cache/apt
                        248M    /var/cache/apt/archives
                        104M    /var/log
                        Archived and active journals take up 89.9M in the file system.
                        /opt/iobroker/backups:
                        917M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        353M    /opt/iobroker/iobroker-data/
                        193M    /opt/iobroker/iobroker-data/files
                        102M    /opt/iobroker/iobroker-data/backup-objects
                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                        18M     /opt/iobroker/iobroker-data/states.jsonl
                        14M     /opt/iobroker/iobroker-data/objects.jsonl
                        11M     /opt/iobroker/iobroker-data/objects.json.migrated
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.17.1
                        /usr/bin/node           v18.17.1
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Installed: 18.17.1-1nodesource1
                          Candidate: 18.18.0-1nodesource1
                          Version table:
                             18.18.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         *** 18.17.1-1nodesource1 500
                             18.17.0-1nodesource1 500
                             18.16.1-1nodesource1 500
                             18.16.0-1nodesource1 500
                             18.15.0-1nodesource1 500
                             18.14.2-1nodesource1 500
                             18.14.1-1nodesource1 500
                             18.14.0-1nodesource1 500
                             18.13.0-1nodesource1 500
                             18.12.0-1nodesource1 500
                             18.11.0-1nodesource1 500
                             18.10.0-1nodesource1 500
                             18.9.1-1nodesource1 500
                             18.9.0-1nodesource1 500
                             18.8.0-1nodesource1 500
                             18.7.0-1nodesource1 500
                             18.6.0-1nodesource1 500
                             18.5.0-1nodesource1 500
                             18.4.0-1nodesource1 500
                             18.3.0-1nodesource1 500
                             18.2.0-1nodesource1 500
                             18.1.0-1nodesource1 500
                             18.0.0-1nodesource1 500
                             10.24.0~dfsg-1~deb10u3 500
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        No configuration change needed.
                        Multihost discovery server: disabled
                        Discovery authentication:   enabled
                        Persistent activation:      disabled
                        Objects:                    jsonl on 127.0.0.1
                        States:                     jsonl on 127.0.0.1
                        Core adapters versions
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapters from github:   5
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi4                             -  enabled
                        + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                        + system.adapter.deconz.0                 : deconz                : raspberrypi4                             -  enabled, port: 80
                        + system.adapter.denon.0                  : denon                 : raspberrypi4                             -  enabled
                        + system.adapter.device-reminder.0        : device-reminder       : raspberrypi4                             -  enabled
                          system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                        + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                        + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4                             -  enabled
                        + system.adapter.hue.0                    : hue                   : raspberrypi4                             -  enabled, port: 443
                        + system.adapter.hyperion_ng.0            : hyperion_ng           : raspberrypi4                             -  enabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                        + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                        + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                          system.adapter.labcom.0                 : labcom                : raspberrypi4                             - disabled
                          system.adapter.material.0               : material              : raspberrypi4                             - disabled
                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4                             -  enabled, port: 54321
                        + system.adapter.octoprint.0              : octoprint             : raspberrypi4                             -  enabled
                        + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4                             -  enabled
                        + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
                        + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4                             -  enabled
                        + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.socketio.0               : socketio              : raspberrypi4                             - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi4                             -  enabled
                        + system.adapter.tado.0                   : tado                  : raspberrypi4                             -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4                             - disabled
                          system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                          system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                        + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.wled.0                   : wled                  : raspberrypi4                             - disabled
                        + system.adapter.worx.0                   : worx                  : raspberrypi4                             -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Installed ioBroker-Instances
                        Adapter    "admin"        : 6.10.1   , installed 6.10.1
                        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                        Adapter    "denon"        : 1.15.4   , installed 1.15.4
                        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                        Adapter    "hue"          : 3.10.0   , installed 3.10.0
                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                        Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                        Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                        Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                        Adapter    "tado"         : 0.4.9    , installed 0.4.9
                        Adapter    "web"          : 6.1.2    , installed 6.1.2
                        Adapter    "wled"         : 0.6.7    , installed 0.6.7
                        Adapter    "worx"         : 2.3.2    , installed 2.3.2
                        Adapter    "ws"           : 2.5.5    , installed 2.5.5
                        Objects and States
                        Objects:        15625
                        States:         13724
                        Hit:1 http://phoscon.de/apt/deconz buster InRelease
                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 28
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15056      361/deCONZ
                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19740      790/pihole-FTL
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19628      690/sshd
                        tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          18112      721/lighttpd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13478912   5544/io.sonoff.0
                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15065      361/deCONZ
                        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18245      790/pihole-FTL
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13475861   4358/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13472588   4358/iobroker.js-co
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13478112   4883/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13482716   6118/io.web.0
                        tcp6       0      0 :::53                   :::*                    LISTEN      999        19742      790/pihole-FTL
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          19630      690/sshd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13482392   5908/io.simple-api.
                        tcp6       0      0 :::8090                 :::*                    LISTEN      0          18113      721/lighttpd
                        tcp6       0      0 :::61991                :::*                    LISTEN      1001       13484398   6813/io.harmony.0
                        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18246      790/pihole-FTL
                        udp        0      0 0.0.0.0:41887           0.0.0.0:*                           108        16332      356/avahi-daemon: r
                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13484399   6813/io.harmony.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13479340   5366/io.shelly.0
                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19739      790/pihole-FTL
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17526      653/dhcpcd
                        udp        0      0 0.0.0.0:48757           0.0.0.0:*                           1001       13862241   5366/io.shelly.0
                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       13479330   5609/io.mihome-vacu
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16330      356/avahi-daemon: r
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13482735   6216/io.deconz.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18461      361/deCONZ
                        udp6       0      0 :::46030                :::*                                108        16333      356/avahi-daemon: r
                        udp6       0      0 :::53                   :::*                                999        19741      790/pihole-FTL
                        udp6       0      0 :::5353                 :::*                                108        16331      356/avahi-daemon: r
                        udp6       0      0 :::1900                 :::*                                1001       13482737   6216/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1001       13482736   6216/io.deconz.0
                        2023-10-09 16:19:50.668  - info: javascript.0 (5021) script.js.Fernseher.PS4: PS4 an
                        2023-10-09 16:19:51.670  - info: javascript.0 (5021) script.js.Fernseher.PS4: Sony an
                        2023-10-09 16:19:51.671  - info: javascript.0 (5021) script.js.Fernseher.PS4: Eingangsquelle Tv
                        2023-10-09 16:19:51.680  - info: hyperion_ng.0 (6257) set component V4L of instance 0 to false
                        2023-10-09 16:19:51.684  - info: harmony.0 (6813) hub busy, stateChange delayed: harmony.0.Harmony_Hub.Denon_AV-Empfänger.InputGame = 1
                        2023-10-09 16:19:51.712  - info: hyperion_ng.0 (6257) socket is connected
                        2023-10-09 16:19:52.048  - info: hyperion_ng.0 (6257) read out components finished
                        2023-10-09 16:19:52.049  - info: hyperion_ng.0 (6257) component is set
                        2023-10-09 16:19:54.680  - info: hyperion_ng.0 (6257) set component LEDDEVICE of instance 0 to false
                        2023-10-09 16:19:55.059  - info: hyperion_ng.0 (6257) read out components finished
                        2023-10-09 16:19:55.060  - info: hyperion_ng.0 (6257) component is set
                        2023-10-09 16:20:54.966  - info: hyperion_ng.0 (6257) socket timeout
                        2023-10-09 16:20:54.986  - info: hyperion_ng.0 (6257) Connection closed
                        2023-10-09 16:29:10.952  - info: mihome-vacuum.0 (5609) trigger cleaning segment 22
                        2023-10-09 16:30:00.069  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                        2023-10-09 16:31:31.277  - info: admin.0 (4883) failed connection to socket.io from ::ffff:192.168.178.60: Passport was not initialized
                        2023-10-09 16:31:43.629  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                        2023-10-09 16:37:33.190  - warn: javascript.0 (5021) script.js.Roborock.Wartungszustand: pushover: Rocki muss gewartet werden.
                        2023-10-09 16:43:55.977  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                        2023-10-09 16:43:56.960  - info: admin.0 (4883) <== Disconnect system.user.admin from ::ffff:192.168.178.60 admin
                        2023-10-09 16:45:00.061  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                        2023-10-09 17:00:00.097  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                        2023-10-09 17:04:26.119  - info: worx.0 (6764) Refresh token for MQTT-Connection
                        2023-10-09 17:04:26.122  - info: worx.0 (6764) Disconnected
                        2023-10-09 17:04:26.554  - info: worx.0 (6764) MQTT connected to: iot.eu-west-1.worxlandroid.com
                        Dazu noch der Screendshot aus dem Admin
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @johnnybahama sagte in admin adapter restart loop:
                        Dein Dateisystem hat ein Schuss weg .
                        • J JohnnyBahama
                          @Glasfaser
                          @Thomas-Braun
                          Es ist wieder passiert, hier der Log diesesmal im debug aus dem Broker:
                          2023-10-09 08:19:18.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 08:19:18.266 - info: worx.0 (3594) Disconnected
                          2023-10-09 08:19:18.614 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 08:42:37.100 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2023-10-09 09:15:58.160 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 09:15:58.162 - info: worx.0 (3594) Disconnected
                          2023-10-09 09:15:58.520 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 10:12:38.231 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 10:12:38.232 - info: worx.0 (3594) Disconnected
                          2023-10-09 10:12:38.600 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 10:54:00.074 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                          2023-10-09 10:54:01.439 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2023-10-09 11:09:18.284 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 11:09:18.286 - info: worx.0 (3594) Disconnected
                          2023-10-09 11:09:18.711 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 12:05:58.262 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 12:05:58.264 - info: worx.0 (3594) Disconnected
                          2023-10-09 12:05:58.639 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 13:02:38.264 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 13:02:38.266 - info: worx.0 (3594) Disconnected
                          2023-10-09 13:02:38.601 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 13:48:33.414 - info: alexa2.0 (2661) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                          2023-10-09 13:48:34.794 - info: alexa2.0 (2661) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2023-10-09 13:59:18.174 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 13:59:18.176 - info: worx.0 (3594) Disconnected
                          2023-10-09 13:59:18.539 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 14:55:58.210 - info: worx.0 (3594) Refresh token for MQTT-Connection
                          2023-10-09 14:55:58.212 - info: worx.0 (3594) Disconnected
                          2023-10-09 14:55:58.607 - info: worx.0 (3594) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          2023-10-09 15:00:00.055 - info: javascript.0 (1909) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                          2023-10-09 15:07:19.526 - info: admin.0 (1735) Adapter rating updated
                          2023-10-09 15:07:40.176 - info: admin.0 (1735) Request actual repository...
                          2023-10-09 15:07:41.017 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                          2023-10-09 15:07:55.157 - info: admin.0 (1735) Repository received successfully.
                          2023-10-09 15:07:55.320 - error: homeconnect.0 (3340) States database error: read ECONNRESET
                          2023-10-09 15:07:55.425 - error: worx.0 (3594) States database error: read ECONNRESET
                          2023-10-09 15:07:55.448 - error: javascript.0 (1909) States database error: read ECONNRESET
                          2023-10-09 15:07:55.532 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ambilight
                          2023-10-09 15:07:55.533 - info: javascript.0 (1909) Stop script script.js.Fernseher.Disney
                          2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Ein_Ausschalten
                          2023-10-09 15:07:55.535 - info: javascript.0 (1909) Stop script script.js.Fernseher.Film
                          2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Netflix
                          2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.PS4
                          2023-10-09 15:07:55.536 - info: javascript.0 (1909) Stop script script.js.Fernseher.Umschalten
                          2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Fernseher.Youtube
                          2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Hyperion
                          2023-10-09 15:07:55.537 - info: javascript.0 (1909) Stop script script.js.Küche.Backofen.Rechner_Ablaufende_Zeit
                          2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.An_Aus
                          2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Küche.Dunstabzugshaube.Arbeitslicht
                          2023-10-09 15:07:55.538 - info: javascript.0 (1909) Stop script script.js.Licht.Wohnzimmer.Licht_an
                          2023-10-09 15:07:55.539 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Adapterüberwachung
                          2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Badezimmerfenster_schließen
                          2023-10-09 15:07:55.540 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Batteriestatus
                          2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Gartenstromversorgung_unterbrochen
                          2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Neustart
                          2023-10-09 15:07:55.541 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Power_Waschmaschine
                          2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Pumpe_an
                          2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Roborock
                          2023-10-09 15:07:55.542 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Tado_nicht_erreichbar
                          2023-10-09 15:07:55.543 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung_Cron
                          2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Pi_Hole.Deaktivieren
                          2023-10-09 15:07:55.544 - info: javascript.0 (1909) Stop script script.js.Roborock.Abwesenheitsreinigung
                          2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Alexa
                          2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Amelies_platz_reinigen
                          2023-10-09 15:07:55.545 - info: javascript.0 (1909) Stop script script.js.Roborock.Einstellungen
                          2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Mülleimer_fahrt___laden
                          2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pausieren_Stoppen
                          2023-10-09 15:07:55.546 - info: javascript.0 (1909) Stop script script.js.Roborock.Pushover_Nachrichten
                          2023-10-09 15:07:55.547 - info: javascript.0 (1909) Stop script script.js.Roborock.Wartungszustand
                          2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Roborock.Zimmer_Reinigung
                          2023-10-09 15:07:55.548 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Abwesenheitsschließung
                          2023-10-09 15:07:55.549 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Rolladenautomatik
                          2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Terrase_schießen_verhindern
                          2023-10-09 15:07:55.550 - info: javascript.0 (1909) Stop script script.js.Rolladensteuerung.Verbrauch
                          2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Fernseher.Kino
                          2023-10-09 15:07:55.551 - info: javascript.0 (1909) Stop script script.js.Rasenmäher
                          2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Salzanlage_Status
                          2023-10-09 15:07:55.552 - info: javascript.0 (1909) Stop script script.js.Alexa.Poolwerteprüfung
                          2023-10-09 15:07:55.553 - info: javascript.0 (1909) Stop script script.js.Octoprint.Fertigmeldung
                          2023-10-09 15:07:55.554 - info: javascript.0 (1909) Stop script script.js.Meldungen_Pushover.Wohnungsüberwachung
                          2023-10-09 15:07:55.274 - error: harmony.0 (3641) States database error: write EPIPE
                          2023-10-09 15:07:55.413 - info: backitup.0 (2623) cleaned everything up...
                          2023-10-09 15:07:55.411 - info: tado.0 (2927) cleaned everything up...
                          2023-10-09 15:07:55.411 - info: simple-api.0 (2807) terminating http server on port 8087
                          2023-10-09 15:07:55.416 - info: pi-hole.0 (3220) cleaned everything up...
                          2023-10-09 15:07:55.319 - error: device-reminder.0 (3424) States database error: read ECONNRESET
                          2023-10-09 15:07:55.418 - info: deconz.0 (2958) cleaned everything up...
                          2023-10-09 15:07:55.378 - error: denon.0 (3333) States database error: write EPIPE
                          2023-10-09 15:07:55.713 - info: denon.0 (3333) [END] Stopping Denon AVR adapter...
                          2023-10-09 15:07:55.348 - error: iot.0 (3002) States database error: read ECONNRESET
                          2023-10-09 15:07:55.791 - info: harmony.0 (3641) [END] Terminating
                          2023-10-09 15:07:55.912 - warn: web.0 (2876) Timeout by termination of web-extensions!
                          2023-10-09 15:07:55.922 - info: web.0 (2876) terminated http server on port 8082
                          2023-10-09 15:07:56.025 - info: iot.0 (3002) Connection changed: disconnect
                          2023-10-09 15:07:56.026 - info: iot.0 (3002) Connection lost
                          2023-10-09 15:07:56.193 - info: worx.0 (3594) Disconnected
                          2023-10-09 15:07:56.705 - error: shuttercontrol.0 (7987) States database error: write EPIPE
                          2023-10-09 15:07:56.722 - info: shuttercontrol.0 (7987) cleaned everything up...
                          2023-10-09 15:07:56.705 - error: info.0 (2870) States database error: write EPIPE
                          2023-10-09 15:07:56.720 - error: mihome-vacuum.0 (2407) States database error: write EPIPE
                          2023-10-09 15:07:56.760 - info: info.0 (2870) cleaned everything up...
                          2023-10-09 15:07:56.712 - error: hue.0 (2181) States database error: write EPIPE
                          2023-10-09 15:07:56.701 - error: pushover.0 (1939) States database error: write EPIPE
                          2023-10-09 15:07:56.717 - error: sonoff.0 (2325) States database error: write EPIPE
                          2023-10-09 15:07:56.774 - error: mihome-vacuum.0 (2407) Socket Close
                          2023-10-09 15:07:56.702 - error: shelly.0 (2068) States database error: write EPIPE
                          2023-10-09 15:07:56.736 - error: ping.0 (2467) States database error: write EPIPE
                          2023-10-09 15:07:56.726 - error: octoprint.0 (3660) States database error: write EPIPE
                          2023-10-09 15:07:56.913 - info: sony-bravia.0 (2297) terminating with timeout
                          2023-10-09 15:07:56.919 - info: sony-bravia.0 (2297) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:56.953 - info: web.0 (2876) terminating with timeout
                          2023-10-09 15:07:56.955 - info: web.0 (2876) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.033 - info: javascript.0 (1909) terminating with timeout
                          2023-10-09 15:07:57.034 - info: javascript.0 (1909) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.067 - info: hyperion_ng.0 (3062) terminating with timeout
                          2023-10-09 15:07:57.086 - info: hyperion_ng.0 (3062) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.110 - info: homeconnect.0 (3340) terminating with timeout
                          2023-10-09 15:07:57.126 - info: alexa2.0 (2661) terminating with timeout
                          2023-10-09 15:07:57.128 - info: alexa2.0 (2661) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.144 - info: backitup.0 (2623) terminating with timeout
                          2023-10-09 15:07:57.146 - info: backitup.0 (2623) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.181 - info: homeconnect.0 (3340) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.216 - info: denon.0 (3333) terminating with timeout
                          2023-10-09 15:07:57.257 - info: tado.0 (2927) terminating with timeout
                          2023-10-09 15:07:57.259 - info: tado.0 (2927) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.260 - info: deconz.0 (2958) terminating with timeout
                          2023-10-09 15:07:57.261 - info: simple-api.0 (2807) terminating with timeout
                          2023-10-09 15:07:57.262 - info: deconz.0 (2958) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.265 - info: simple-api.0 (2807) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.268 - info: pi-hole.0 (3220) terminating with timeout
                          2023-10-09 15:07:57.270 - info: pi-hole.0 (3220) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.272 - info: denon.0 (3333) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.296 - info: harmony.0 (3641) terminating with timeout
                          2023-10-09 15:07:57.324 - info: harmony.0 (3641) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.410 - info: device-reminder.0 (3424) terminating with timeout
                          2023-10-09 15:07:57.413 - info: iot.0 (3002) terminating with timeout
                          2023-10-09 15:07:57.441 - info: device-reminder.0 (3424) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.431 - info: iot.0 (3002) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:57.453 - info: worx.0 (3594) terminating with timeout
                          2023-10-09 15:07:57.468 - info: worx.0 (3594) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.210 - info: history.0 (1771) Delete old history "/opt/iobroker/history/20221008/history.denon.0.zoneMain.powerZone.json"
                          2023-10-09 15:07:58.227 - info: shuttercontrol.0 (7987) terminating with timeout
                          2023-10-09 15:07:58.230 - info: shuttercontrol.0 (7987) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:55.477 - debug: admin.0 (1735) Next repo update on 10/10/2023, 15:07:55
                          2023-10-09 15:07:58.260 - error: admin.0 (1735) States database error: write EPIPE
                          2023-10-09 15:07:58.264 - info: info.0 (2870) terminating with timeout
                          2023-10-09 15:07:58.267 - info: mihome-vacuum.0 (2407) terminating with timeout
                          2023-10-09 15:07:58.267 - info: info.0 (2870) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.269 - info: mihome-vacuum.0 (2407) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.285 - info: pushover.0 (1939) terminating with timeout
                          2023-10-09 15:07:58.291 - info: pushover.0 (1939) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.290 - info: admin.0 (1735) terminating https server on port 8081
                          2023-10-09 15:07:58.308 - info: sonoff.0 (2325) terminating with timeout
                          2023-10-09 15:07:58.310 - info: sonoff.0 (2325) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.321 - info: shelly.0 (2068) terminating with timeout
                          2023-10-09 15:07:58.323 - info: shelly.0 (2068) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.331 - info: hue.0 (2181) terminating with timeout
                          2023-10-09 15:07:58.333 - info: hue.0 (2181) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.340 - info: ping.0 (2467) terminating with timeout
                          2023-10-09 15:07:58.342 - info: ping.0 (2467) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:58.394 - info: octoprint.0 (3660) terminating with timeout
                          2023-10-09 15:07:58.397 - info: octoprint.0 (3660) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:07:59.795 - info: admin.0 (1735) terminating with timeout
                          2023-10-09 15:07:59.799 - debug: admin.0 (1735) Plugin sentry destroyed
                          2023-10-09 15:07:59.799 - info: admin.0 (1735) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:08:00.187 - error: web.0 (2876) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.196 - error: backitup.0 (2623) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.223 - error: hyperion_ng.0 (3062) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.241 - error: sony-bravia.0 (2297) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.269 - error: alexa2.0 (2661) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.270 - error: tado.0 (2927) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.265 - warn: sony-bravia.0 (2297) get state error: Connection is closed.
                          2023-10-09 15:08:00.267 - warn: sony-bravia.0 (2297) get state error: DB closed
                          2023-10-09 15:08:00.272 - info: sony-bravia.0 (2297) terminating
                          2023-10-09 15:08:00.278 - info: sony-bravia.0 (2297) terminating
                          2023-10-09 15:08:00.291 - error: pi-hole.0 (3220) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.295 - error: simple-api.0 (2807) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.335 - error: deconz.0 (2958) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.348 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.362 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                          2023-10-09 15:08:00.369 - warn: pi-hole.0 (3220) get state error: Connection is closed.
                          2023-10-09 15:08:00.370 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.371 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.372 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.374 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.376 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.377 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.378 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.379 - warn: pi-hole.0 (3220) get state error: DB closed
                          2023-10-09 15:08:00.395 - info: pi-hole.0 (3220) terminating
                          2023-10-09 15:08:00.397 - info: pi-hole.0 (3220) terminating
                          2023-10-09 15:08:00.432 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.433 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.439 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.440 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.441 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.442 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.443 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.444 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.445 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.446 - warn: homeconnect.0 (3340) get state error: DB closed
                          2023-10-09 15:08:00.453 - info: homeconnect.0 (3340) terminating
                          2023-10-09 15:08:00.454 - info: homeconnect.0 (3340) terminating
                          2023-10-09 15:08:00.480 - error: javascript.0 (1909) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.539 - warn: javascript.0 (1909) get state error: DB closed
                          2023-10-09 15:08:00.539 - error: worx.0 (3594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.542 - warn: javascript.0 (1909) get state error: DB closed
                          2023-10-09 15:08:00.543 - warn: javascript.0 (1909) get state error: DB closed
                          2023-10-09 15:08:00.544 - warn: javascript.0 (1909) get state error: DB closed
                          2023-10-09 15:08:00.545 - warn: javascript.0 (1909) get state error: DB closed
                          2023-10-09 15:08:00.550 - info: javascript.0 (1909) terminating
                          2023-10-09 15:08:00.554 - warn: worx.0 (3594) get state error: DB closed
                          2023-10-09 15:08:00.557 - warn: worx.0 (3594) get state error: DB closed
                          2023-10-09 15:08:00.558 - warn: worx.0 (3594) get state error: DB closed
                          2023-10-09 15:08:00.559 - warn: worx.0 (3594) get state error: DB closed
                          2023-10-09 15:08:00.566 - info: worx.0 (3594) terminating
                          2023-10-09 15:08:00.781 - error: device-reminder.0 (3424) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.791 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.792 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.793 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.794 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.795 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.796 - warn: device-reminder.0 (3424) get state error: DB closed
                          2023-10-09 15:08:00.800 - info: device-reminder.0 (3424) terminating
                          2023-10-09 15:08:00.801 - info: device-reminder.0 (3424) terminating
                          2023-10-09 15:08:00.823 - error: denon.0 (3333) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.841 - warn: denon.0 (3333) get state error: Connection is closed.
                          2023-10-09 15:08:00.842 - warn: denon.0 (3333) get state error: DB closed
                          2023-10-09 15:08:00.843 - warn: denon.0 (3333) get state error: DB closed
                          2023-10-09 15:08:00.845 - warn: denon.0 (3333) get state error: DB closed
                          2023-10-09 15:08:00.846 - warn: denon.0 (3333) get state error: DB closed
                          2023-10-09 15:08:00.850 - info: denon.0 (3333) terminating
                          2023-10-09 15:08:00.851 - info: denon.0 (3333) terminating
                          2023-10-09 15:08:00.857 - error: harmony.0 (3641) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.875 - error: iot.0 (3002) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:00.910 - warn: harmony.0 (3641) get state error: Connection is closed.
                          2023-10-09 15:08:01.747 - error: shuttercontrol.0 (7987) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.784 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10F9B0#1.Relay1.Timer, error - DB closed
                          2023-10-09 15:08:01.801 - error: info.0 (2870) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.787 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10CD90#1.Shutter.Duration, error - DB closed
                          2023-10-09 15:08:01.788 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#F3353D#1.Shutter.Duration, error - DB closed
                          2023-10-09 15:08:01.789 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#10D202#1.Shutter.Duration, error - DB closed
                          2023-10-09 15:08:01.790 - warn: shelly.0 (2068) redis get shelly.0.SHSW-25#110D76#1.Relay1.Timer, error - DB closed
                          2023-10-09 15:08:01.790 - warn: shelly.0 (2068) get state error: DB closed
                          2023-10-09 15:08:01.791 - warn: shelly.0 (2068) get state error: DB closed
                          2023-10-09 15:08:01.805 - error: pushover.0 (1939) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.822 - error: mihome-vacuum.0 (2407) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.836 - error: sonoff.0 (2325) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.842 - info: shelly.0 (2068) terminating
                          2023-10-09 15:08:01.843 - info: shelly.0 (2068) terminating
                          2023-10-09 15:08:01.874 - error: hue.0 (2181) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.881 - error: ping.0 (2467) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:01.925 - error: octoprint.0 (3660) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:03.308 - error: admin.0 (1735) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:03.318 - warn: admin.0 (1735) get state error: Connection is closed.
                          2023-10-09 15:08:03.319 - warn: admin.0 (1735) get state error: DB closed
                          2023-10-09 15:08:03.320 - warn: admin.0 (1735) get state error: DB closed
                          2023-10-09 15:08:03.321 - warn: admin.0 (1735) get state error: DB closed
                          2023-10-09 15:08:03.322 - warn: admin.0 (1735) get state error: DB closed
                          2023-10-09 15:08:03.324 - info: admin.0 (1735) terminating
                          2023-10-09 15:08:05.306 - error: pi-hole.0 (3220) Cannot check object existence of "pi-hole.0.version": Connection is closed.
                          2023-10-09 15:08:05.379 - error: history.0 (1771) States database error: connect ECONNREFUSED 127.0.0.1:9000
                          2023-10-09 15:08:05.383 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:08.324 - error: admin.0 (1735) Cannot find view "system" for search "instance" : Connection is closed.
                          2023-10-09 15:08:09.759 - info: history.0 (1771) terminating with timeout
                          2023-10-09 15:08:09.763 - info: history.0 (1771) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:08:10.388 - error: history.0 (1771) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2023-10-09 15:08:17.666 - info: host.raspberrypi4 iobroker.js-controller version 5.0.12 js-controller starting
                          2023-10-09 15:08:17.673 - info: host.raspberrypi4 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                          2023-10-09 15:08:17.675 - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.1
                          2023-10-09 15:08:17.675 - info: host.raspberrypi4 ip addresses: 192.168.178.70 2003:f5:f26:b900:3583:2470:ce5:f0d4 fe80::a637:87cf:1b83:c822
                          2023-10-09 15:08:20.777 - info: host.raspberrypi4 connected to Objects and States
                          2023-10-09 15:08:20.876 - info: host.raspberrypi4 added notifications configuration of host
                          2023-10-09 15:08:22.204 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeCurrent"
                          2023-10-09 15:08:22.206 - info: host.raspberrypi4 38 instances found
                          2023-10-09 15:08:22.296 - info: host.raspberrypi4 starting 28 instances
                          2023-10-09 15:08:22.491 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewest"
                          2023-10-09 15:08:22.536 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4461
                          2023-10-09 15:08:22.546 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
                          2023-10-09 15:08:22.557 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
                          2023-10-09 15:08:22.568 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
                          2023-10-09 15:08:22.578 - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
                          2023-10-09 15:08:22.589 - info: host.raspberrypi4 Some obsolete host states deleted.
                          2023-10-09 15:08:26.272 - error: admin.0 (4461) admin.0 already running
                          2023-10-09 15:08:26.277 - warn: admin.0 (4461) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:26.479 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4501
                          2023-10-09 15:08:27.111 - error: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:27.112 - info: host.raspberrypi4 Restart adapter system.adapter.admin.0 because enabled
                          2023-10-09 15:08:29.053 - error: history.0 (4501) history.0 already running
                          2023-10-09 15:08:29.061 - warn: history.0 (4501) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:29.727 - error: host.raspberrypi4 instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:29.728 - info: host.raspberrypi4 Restart adapter system.adapter.history.0 because enabled
                          2023-10-09 15:08:30.543 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 4570
                          2023-10-09 15:08:34.600 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 4605
                          2023-10-09 15:08:35.010 - error: javascript.0 (4570) javascript.0 already running
                          2023-10-09 15:08:35.015 - warn: javascript.0 (4570) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:35.730 - error: host.raspberrypi4 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:35.731 - info: host.raspberrypi4 Restart adapter system.adapter.javascript.0 because enabled
                          2023-10-09 15:08:37.148 - error: pushover.0 (4605) pushover.0 already running
                          2023-10-09 15:08:37.153 - warn: pushover.0 (4605) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:37.856 - error: host.raspberrypi4 instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:37.856 - info: host.raspberrypi4 Restart adapter system.adapter.pushover.0 because enabled
                          2023-10-09 15:08:38.510 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 4672
                          2023-10-09 15:08:41.117 - error: alexa2.0 (4672) alexa2.0 already running
                          2023-10-09 15:08:41.121 - warn: alexa2.0 (4672) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:41.800 - error: host.raspberrypi4 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:41.800 - info: host.raspberrypi4 Restart adapter system.adapter.alexa2.0 because enabled
                          2023-10-09 15:08:42.545 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 4706
                          2023-10-09 15:08:45.475 - error: shelly.0 (4706) shelly.0 already running
                          2023-10-09 15:08:45.479 - warn: shelly.0 (4706) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:46.194 - error: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:46.196 - info: host.raspberrypi4 Restart adapter system.adapter.shelly.0 because enabled
                          2023-10-09 15:08:46.491 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 4741
                          2023-10-09 15:08:49.352 - error: hue.0 (4741) hue.0 already running
                          2023-10-09 15:08:49.356 - warn: hue.0 (4741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:50.077 - error: host.raspberrypi4 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:50.078 - info: host.raspberrypi4 Restart adapter system.adapter.hue.0 because enabled
                          2023-10-09 15:08:50.500 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 4813
                          2023-10-09 15:08:53.519 - error: sony-bravia.0 (4813) sony-bravia.0 already running
                          2023-10-09 15:08:53.523 - warn: sony-bravia.0 (4813) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:54.203 - error: host.raspberrypi4 instance system.adapter.sony-bravia.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:54.203 - info: host.raspberrypi4 Restart adapter system.adapter.sony-bravia.0 because enabled
                          2023-10-09 15:08:54.521 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 4848
                          2023-10-09 15:08:57.007 - error: sonoff.0 (4848) sonoff.0 already running
                          2023-10-09 15:08:57.011 - warn: sonoff.0 (4848) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:08:57.299 - info: host.raspberrypi4 instance system.adapter.admin.0 started with pid 4883
                          2023-10-09 15:08:57.707 - error: host.raspberrypi4 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:08:57.708 - info: host.raspberrypi4 Restart adapter system.adapter.sonoff.0 because enabled
                          2023-10-09 15:08:58.511 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 4927
                          2023-10-09 15:08:59.991 - info: host.raspberrypi4 instance system.adapter.history.0 started with pid 4945
                          2023-10-09 15:09:02.069 - error: mihome-vacuum.0 (4927) mihome-vacuum.0 already running
                          2023-10-09 15:09:02.076 - warn: mihome-vacuum.0 (4927) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:02.148 - info: admin.0 (4883) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:02.226 - info: admin.0 (4883) requesting all objects
                          2023-10-09 15:09:04.821 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5003
                          2023-10-09 15:09:04.935 - error: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:04.937 - info: host.raspberrypi4 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                          2023-10-09 15:09:05.363 - info: admin.0 (4883) received all objects
                          2023-10-09 15:09:05.993 - info: admin.0 (4883) Request actual repository...
                          2023-10-09 15:09:06.225 - info: admin.0 (4883) Secure socket.io server listening on port 8081
                          2023-10-09 15:09:06.241 - info: admin.0 (4883) https server listening on port 8081
                          2023-10-09 15:09:06.241 - info: admin.0 (4883) Use link "https://127.0.0.1:8081" to configure.
                          2023-10-09 15:09:06.473 - info: host.raspberrypi4 instance system.adapter.javascript.0 started with pid 5021
                          2023-10-09 15:09:07.317 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5038
                          2023-10-09 15:09:08.167 - info: host.raspberrypi4 instance system.adapter.pushover.0 started with pid 5092
                          2023-10-09 15:09:09.099 - info: host.raspberrypi4 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                          2023-10-09 15:09:09.373 - info: history.0 (4945) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.history, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:11.534 - error: ping.0 (5003) ping.0 already running
                          2023-10-09 15:09:11.540 - warn: ping.0 (5003) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:11.615 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5167
                          2023-10-09 15:09:13.043 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5189
                          2023-10-09 15:09:13.099 - error: host.raspberrypi4 instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:13.100 - info: host.raspberrypi4 Restart adapter system.adapter.ping.0 because enabled
                          2023-10-09 15:09:13.392 - error: backitup.0 (5038) backitup.0 already running
                          2023-10-09 15:09:13.398 - warn: backitup.0 (5038) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:14.317 - error: host.raspberrypi4 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:14.318 - info: host.raspberrypi4 Restart adapter system.adapter.backitup.0 because enabled
                          2023-10-09 15:09:14.934 - info: host.raspberrypi4 instance system.adapter.simple-api.0 started with pid 5275
                          2023-10-09 15:09:20.498 - info: admin.0 (4883) Repository received successfully.
                          2023-10-09 15:09:21.185 - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 5366
                          2023-10-09 15:09:21.419 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 5379
                          2023-10-09 15:09:21.714 - info: host.raspberrypi4 instance system.adapter.hue.0 started with pid 5386
                          2023-10-09 15:09:21.856 - error: info.0 (5167) info.0 already running
                          2023-10-09 15:09:21.863 - warn: info.0 (5167) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:22.066 - error: simple-api.0 (5275) simple-api.0 already running
                          2023-10-09 15:09:22.083 - warn: simple-api.0 (5275) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:22.766 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 5399
                          2023-10-09 15:09:23.115 - error: host.raspberrypi4 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:23.116 - info: host.raspberrypi4 Restart adapter system.adapter.info.0 because enabled
                          2023-10-09 15:09:23.341 - error: host.raspberrypi4 instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:23.342 - info: host.raspberrypi4 Restart adapter system.adapter.simple-api.0 because enabled
                          2023-10-09 15:09:23.423 - info: pushover.0 (5092) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:23.705 - info: javascript.0 (5021) starting. Version 7.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:24.059 - info: alexa2.0 (5189) starting. Version 3.25.2 (non-npm: Apollon77/ioBroker.alexa2#2f00d64d7149f65565470bf222734cab76e303ec) in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:24.583 - info: alexa2.0 (5189) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                          2023-10-09 15:09:26.947 - info: host.raspberrypi4 instance system.adapter.sony-bravia.0 started with pid 5454
                          2023-10-09 15:09:27.615 - info: javascript.0 (5021) requesting all states
                          2023-10-09 15:09:27.619 - info: javascript.0 (5021) requesting all objects
                          2023-10-09 15:09:29.302 - info: alexa2.0 (5189) Update cookie in adapter configuration ... restarting ...
                          2023-10-09 15:09:31.235 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 5531
                          2023-10-09 15:09:31.555 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 (force=false, process=true)
                          2023-10-09 15:09:31.814 - info: javascript.0 (5021) received all objects
                          2023-10-09 15:09:32.123 - info: javascript.0 (5021) received all states
                          2023-10-09 15:09:32.135 - info: alexa2.0 (5189) Got terminate signal TERMINATE_YOURSELF
                          2023-10-09 15:09:32.148 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 send kill signal
                          2023-10-09 15:09:32.143 - info: alexa2.0 (5189) terminating
                          2023-10-09 15:09:32.166 - info: alexa2.0 (5189) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-10-09 15:09:32.557 - info: host.raspberrypi4 instance system.adapter.sonoff.0 started with pid 5544
                          2023-10-09 15:09:32.670 - info: alexa2.0 (5189) terminating
                          2023-10-09 15:09:32.878 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 5551
                          2023-10-09 15:09:33.191 - info: host.raspberrypi4 stopInstance system.adapter.alexa2.0 killing pid 5189
                          2023-10-09 15:09:33.247 - error: web.0 (5379) web.0 already running
                          2023-10-09 15:09:33.256 - warn: web.0 (5379) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:34.968 - error: tado.0 (5399) tado.0 already running
                          2023-10-09 15:09:34.976 - warn: tado.0 (5399) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:35.951 - error: host.raspberrypi4 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:35.953 - info: host.raspberrypi4 Restart adapter system.adapter.web.0 because enabled
                          2023-10-09 15:09:36.784 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 5592
                          2023-10-09 15:09:37.084 - error: host.raspberrypi4 instance system.adapter.tado.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:37.085 - info: host.raspberrypi4 Restart adapter system.adapter.tado.0 because enabled
                          2023-10-09 15:09:37.477 - info: host.raspberrypi4 instance system.adapter.mihome-vacuum.0 started with pid 5609
                          2023-10-09 15:09:37.823 - info: host.raspberrypi4 instance system.adapter.alexa2.0 started with pid 5616
                          2023-10-09 15:09:39.022 - error: deconz.0 (5531) deconz.0 already running
                          2023-10-09 15:09:39.027 - warn: deconz.0 (5531) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:39.453 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 5667
                          2023-10-09 15:09:40.033 - error: iot.0 (5551) iot.0 already running
                          2023-10-09 15:09:40.047 - warn: iot.0 (5551) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:40.543 - error: host.raspberrypi4 instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:40.546 - info: host.raspberrypi4 Restart adapter system.adapter.deconz.0 because enabled
                          2023-10-09 15:09:41.055 - error: host.raspberrypi4 instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:41.056 - info: host.raspberrypi4 Restart adapter system.adapter.iot.0 because enabled
                          2023-10-09 15:09:42.156 - error: hyperion_ng.0 (5592) hyperion_ng.0 already running
                          2023-10-09 15:09:42.161 - warn: hyperion_ng.0 (5592) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:42.219 - info: hue.0 (5386) starting. Version 3.10.0 in /opt/iobroker/node_modules/iobroker.hue, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:42.237 - info: shelly.0 (5366) starting. Version 6.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:43.424 - info: hue.0 (5386) Push connection established
                          2023-10-09 15:09:43.769 - error: host.raspberrypi4 instance system.adapter.hyperion_ng.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:43.780 - info: host.raspberrypi4 Restart adapter system.adapter.hyperion_ng.0 because enabled
                          2023-10-09 15:09:44.343 - info: host.raspberrypi4 instance system.adapter.ping.0 started with pid 5734
                          2023-10-09 15:09:45.388 - info: host.raspberrypi4 instance system.adapter.backitup.0 started with pid 5747
                          2023-10-09 15:09:45.991 - error: shuttercontrol.0 (5667) shuttercontrol.0 already running
                          2023-10-09 15:09:46.002 - warn: shuttercontrol.0 (5667) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:46.430 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 5764
                          2023-10-09 15:09:47.187 - error: host.raspberrypi4 instance system.adapter.shuttercontrol.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:47.188 - info: host.raspberrypi4 Restart adapter system.adapter.shuttercontrol.0 because enabled
                          2023-10-09 15:09:52.766 - error: pi-hole.0 (5764) pi-hole.0 already running
                          2023-10-09 15:09:52.784 - warn: pi-hole.0 (5764) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:55.371 - info: host.raspberrypi4 instance system.adapter.info.0 started with pid 5896
                          2023-10-09 15:09:55.429 - error: host.raspberrypi4 instance system.adapter.pi-hole.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:55.430 - info: host.raspberrypi4 Restart adapter system.adapter.pi-hole.0 because enabled
                          2023-10-09 15:09:56.413 - info: vis.0 (5727) Terminated (NO_ERROR): Without reason
                          2023-10-09 15:09:56.632 - error: denon.0 (5862) denon.0 already running
                          2023-10-09 15:09:56.641 - warn: denon.0 (5862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:09:56.934 - info: ping.0 (5734) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:09:59.473 - info: host.raspberrypi4 instance system.adapter.vis.0 terminated while should be started once
                          2023-10-09 15:09:59.995 - error: host.raspberrypi4 instance system.adapter.denon.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:09:59.996 - info: host.raspberrypi4 Restart adapter system.adapter.denon.0 because enabled
                          2023-10-09 15:10:04.282 - error: homeconnect.0 (5915) homeconnect.0 already running
                          2023-10-09 15:10:04.291 - warn: homeconnect.0 (5915) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:10:05.585 - error: device-reminder.0 (6014) device-reminder.0 already running
                          2023-10-09 15:10:05.593 - warn: device-reminder.0 (6014) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:10:06.078 - error: host.raspberrypi4 instance system.adapter.homeconnect.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:10:06.979 - info: host.raspberrypi4 instance system.adapter.harmony.0 started with pid 6106
                          2023-10-09 15:10:07.062 - error: host.raspberrypi4 instance system.adapter.device-reminder.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:10:07.063 - info: host.raspberrypi4 Restart adapter system.adapter.device-reminder.0 because enabled
                          2023-10-09 15:10:07.129 - info: host.raspberrypi4 instance system.adapter.web.0 started with pid 6118
                          2023-10-09 15:10:07.759 - info: host.raspberrypi4 instance system.adapter.tado.0 started with pid 6130
                          2023-10-09 15:10:08.603 - info: simple-api.0 (5908) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:08.809 - warn: simple-api.0 (5908) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                          2023-10-09 15:10:08.895 - info: simple-api.0 (5908) simpleAPI server listening on port 8087
                          2023-10-09 15:10:08.897 - info: simple-api.0 (5908) Allow states only when user is owner: false
                          2023-10-09 15:10:08.927 - info: simple-api.0 (5908) http server listening on port 8087
                          2023-10-09 15:10:09.091 - info: backitup.0 (5747) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:09.988 - info: backitup.0 (5747) [iobroker] backup will be activated at 02:40 every 1 day(s)
                          2023-10-09 15:10:11.599 - error: worx.0 (6085) worx.0 already running
                          2023-10-09 15:10:11.611 - warn: worx.0 (6085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:10:11.818 - info: host.raspberrypi4 instance system.adapter.octoprint.0 started with pid 6206
                          2023-10-09 15:10:12.009 - info: host.raspberrypi4 instance system.adapter.deconz.0 started with pid 6216
                          2023-10-09 15:10:12.314 - info: host.raspberrypi4 instance system.adapter.iot.0 started with pid 6228
                          2023-10-09 15:10:13.226 - error: host.raspberrypi4 instance system.adapter.worx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:10:13.257 - info: host.raspberrypi4 Restart adapter system.adapter.worx.0 because enabled
                          2023-10-09 15:10:15.518 - info: host.raspberrypi4 instance system.adapter.hyperion_ng.0 started with pid 6257
                          2023-10-09 15:10:16.612 - error: harmony.0 (6106) harmony.0 already running
                          2023-10-09 15:10:16.620 - warn: harmony.0 (6106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:10:18.718 - error: host.raspberrypi4 instance system.adapter.harmony.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:10:18.719 - info: host.raspberrypi4 Restart adapter system.adapter.harmony.0 because enabled
                          2023-10-09 15:10:19.320 - info: host.raspberrypi4 instance system.adapter.shuttercontrol.0 started with pid 6304
                          2023-10-09 15:10:20.117 - error: octoprint.0 (6206) octoprint.0 already running
                          2023-10-09 15:10:20.134 - warn: octoprint.0 (6206) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2023-10-09 15:10:21.821 - error: host.raspberrypi4 instance system.adapter.octoprint.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2023-10-09 15:10:21.822 - info: host.raspberrypi4 Restart adapter system.adapter.octoprint.0 because enabled
                          2023-10-09 15:10:23.534 - info: web.0 (6118) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:23.633 - info: tado.0 (6130) starting. Version 0.4.9 in /opt/iobroker/node_modules/iobroker.tado, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:23.787 - info: hyperion_ng.0 (6257) starting. Version 0.1.23 (non-npm: felixganzer/ioBroker.hyperion_ng#b27f55704d34a7eed2865ca421409d091d86cd38) in /opt/iobroker/node_modules/iobroker.hyperion_ng, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:23.856 - info: hyperion_ng.0 (6257) create Control Parameter
                          2023-10-09 15:10:23.720 - info: tado.0 (6130) Started with JSON-Explorer version 0.1.12
                          2023-10-09 15:10:24.450 - info: tado.0 (6130) Connected to Tado cloud, initialyzing...
                          2023-10-09 15:10:24.456 - info: sony-bravia.0 (5454) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.sony-bravia, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:24.727 - info: web.0 (6118) socket.io server listening on port 8082
                          2023-10-09 15:10:24.761 - info: web.0 (6118) http server listening on port 8082
                          2023-10-09 15:10:25.033 - info: deconz.0 (6216) starting. Version 1.3.21 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:25.075 - info: hyperion_ng.0 (6257) 210,0.5000000000000001,0.39215686274509803
                          2023-10-09 15:10:25.582 - info: deconz.0 (6216) deConz Version: 2.22.2; API version: 1.16.0
                          2023-10-09 15:10:25.806 - info: host.raspberrypi4 instance system.adapter.pi-hole.0 started with pid 6469
                          2023-10-09 15:10:26.007 - info: hyperion_ng.0 (6257) socket is connected
                          2023-10-09 15:10:28.243 - info: iot.0 (6228) starting. Version 1.14.5 in /opt/iobroker/node_modules/iobroker.iot, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:28.796 - info: iot.0 (6228) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                          2023-10-09 15:10:31.212 - info: host.raspberrypi4 instance system.adapter.denon.0 started with pid 6552
                          2023-10-09 15:10:32.365 - info: iot.0 (6228) Connection changed: connect
                          2023-10-09 15:10:32.854 - info: info.0 (5896) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:33.435 - info: pi-hole.0 (6469) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:33.627 - info: info.0 (5896) Reading/updating systemdata.
                          2023-10-09 15:10:35.029 - info: hyperion_ng.0 (6257) read out components finished
                          2023-10-09 15:10:36.567 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.blue" has to be stringified but received type "object"
                          2023-10-09 15:10:36.708 - info: host.raspberrypi4 instance system.adapter.homeconnect.0 started with pid 6619
                          2023-10-09 15:10:37.014 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.cyan" has to be stringified but received type "object"
                          2023-10-09 15:10:37.767 - info: host.raspberrypi4 instance system.adapter.device-reminder.0 started with pid 6636
                          2023-10-09 15:10:38.027 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.green" has to be stringified but received type "object"
                          2023-10-09 15:10:38.324 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.magenta" has to be stringified but received type "object"
                          2023-10-09 15:10:38.521 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.red" has to be stringified but received type "object"
                          2023-10-09 15:10:38.783 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.white" has to be stringified but received type "object"
                          2023-10-09 15:10:38.946 - info: hyperion_ng.0 (6257) State value to set for "hyperion_ng.0.0.adjustments.yellow" has to be stringified but received type "object"
                          2023-10-09 15:10:38.984 - info: shuttercontrol.0 (6304) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:39.001 - info: hyperion_ng.0 (6257) read out Adjustments finished
                          2023-10-09 15:10:39.428 - info: hyperion_ng.0 (6257) create priorities
                          2023-10-09 15:10:40.347 - info: denon.0 (6552) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.denon, node: v18.17.1, js-controller: 5.0.12
                          2023-10-09 15:10:40.442 - info: denon.0 (6552) [START] Starting DENON AVR adapter
                          2023-10-09 15:10:40.448 - info: denon.0 (6552) [CONNECT] Trying to connect to 192.168.178.37:23
                          2023-10-09 15:10:40.482 - info: denon.0 (6552) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.37:23
                          2023-10-09 15:10:40.820 - info: hyperion_ng.0 (6257) read out priorities finished
                          2023-10-09 15:10:41.173 - info: hyperion_ng.0 (6257) create effects
                          2023-10-09 15:10:41.637 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                          2023-10-09 15:10:44.059 - info: host.raspberrypi4 instance system.adapter.worx.0 started with pid 6764
                          2023-10-09 15:10:44.827 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                          2023-10-09 15:10:44.998 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                          2023-10-09 15:10:45.148 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                          2023-10-09 15:10:45.294 - info: info.0 (5896) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                          Aus dem Iob diag
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                             Static hostname: raspberrypi4
                                   Icon name: computer
                                  Machine ID: 226172a9cc584d89b1963a4dd6da7a12
                                     Boot ID: 8e888aa4fd59407dbddcad5931c7d04e
                            Operating System: Raspbian GNU/Linux 10 (buster)
                                      Kernel: Linux 5.10.103-v7l+
                                Architecture: arm
                          Model           : Raspberry Pi 4 Model B Rev 1.4
                          Docker          : false
                          Virtualization  : none
                          Kernel          : armv7l
                          Userland        : armhf
                          Systemuptime and Load:
                           17:06:24 up 3 days,  2:00,  1 user,  load average: 1.33, 0.92, 0.73
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          Other values than 0x0 hint to temperature/voltage problems
                          temp=46.7'C
                          volt=0.8600V
                          *** Time and Time Zones ***
                                         Local time: Mon 2023-10-09 17:06:25 CEST
                                     Universal time: Mon 2023-10-09 15:06:25 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           1.9G        1.3G        152M         95M        451M        419M
                          Swap:           99M         24M         75M
                          Total:         2.0G        1.3G        227M
                                   1872 M total memory
                                   1268 M used memory
                                    245 M active memory
                                   1378 M inactive memory
                                    152 M free memory
                                     54 M buffer memory
                                    396 M swap cache
                                     99 M total swap
                                     24 M used swap
                                     75 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G  7.7G   49G  14% /
                          devtmpfs       devtmpfs  776M     0  776M   0% /dev
                          tmpfs          tmpfs     937M  3.4M  933M   1% /dev/shm
                          tmpfs          tmpfs     937M   91M  846M  10% /run
                          tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
                          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                          tmpfs          tmpfs     188M     0  188M   0% /run/user/999
                          tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
                          [Fri Oct  6 15:06:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:34:2A:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=87f0f292-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                          [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                          [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                          [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): recovery complete
                          [Fri Oct  6 15:06:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          [Fri Oct  6 15:06:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Fri Oct  6 15:06:06 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          [Mon Oct  9 15:07:54 2023] [<c03b6448>] (filemap_fault) from [<c0537e28>] (ext4_filemap_fault+0x38/0x4c)
                          [Mon Oct  9 15:07:54 2023] [<c0537df0>] (ext4_filemap_fault) from [<c03ef158>] (__do_fault+0x48/0x134)
                          TARGET        SOURCE         FSTYPE OPTIONS
                          /             /dev/mmcblk0p2 ext4   rw,noatime
                          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          699M    /var/
                          313M    /var/cache
                          307M    /var/cache/apt
                          248M    /var/cache/apt/archives
                          104M    /var/log
                          Archived and active journals take up 89.9M in the file system.
                          /opt/iobroker/backups:
                          917M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          353M    /opt/iobroker/iobroker-data/
                          193M    /opt/iobroker/iobroker-data/files
                          102M    /opt/iobroker/iobroker-data/backup-objects
                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                          18M     /opt/iobroker/iobroker-data/states.jsonl
                          14M     /opt/iobroker/iobroker-data/objects.jsonl
                          11M     /opt/iobroker/iobroker-data/objects.json.migrated
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.17.1
                          /usr/bin/node           v18.17.1
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Installed: 18.17.1-1nodesource1
                            Candidate: 18.18.0-1nodesource1
                            Version table:
                               18.18.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                           *** 18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                               10.24.0~dfsg-1~deb10u3 500
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          No configuration change needed.
                          Multihost discovery server: disabled
                          Discovery authentication:   enabled
                          Persistent activation:      disabled
                          Objects:                    jsonl on 127.0.0.1
                          States:                     jsonl on 127.0.0.1
                          Core adapters versions
                          admin:          6.10.1
                          javascript:     7.1.4
                          Adapters from github:   5
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : raspberrypi4                             -  enabled
                          + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                          + system.adapter.deconz.0                 : deconz                : raspberrypi4                             -  enabled, port: 80
                          + system.adapter.denon.0                  : denon                 : raspberrypi4                             -  enabled
                          + system.adapter.device-reminder.0        : device-reminder       : raspberrypi4                             -  enabled
                            system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                          + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
                          + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                          + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4                             -  enabled
                          + system.adapter.hue.0                    : hue                   : raspberrypi4                             -  enabled, port: 443
                          + system.adapter.hyperion_ng.0            : hyperion_ng           : raspberrypi4                             -  enabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4                             - disabled
                          + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
                          + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                            system.adapter.labcom.0                 : labcom                : raspberrypi4                             - disabled
                            system.adapter.material.0               : material              : raspberrypi4                             - disabled
                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4                             -  enabled, port: 54321
                          + system.adapter.octoprint.0              : octoprint             : raspberrypi4                             -  enabled
                          + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4                             -  enabled
                          + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
                          + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
                          + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4                             -  enabled
                          + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.socketio.0               : socketio              : raspberrypi4                             - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi4                             -  enabled
                          + system.adapter.tado.0                   : tado                  : raspberrypi4                             -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4                             - disabled
                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                            system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                          + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.wled.0                   : wled                  : raspberrypi4                             - disabled
                          + system.adapter.worx.0                   : worx                  : raspberrypi4                             -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          Installed ioBroker-Instances
                          Adapter    "admin"        : 6.10.1   , installed 6.10.1
                          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                          Adapter    "denon"        : 1.15.4   , installed 1.15.4
                          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                          Adapter    "history"      : 2.2.6    , installed 2.2.6
                          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                          Adapter    "hue"          : 3.10.0   , installed 3.10.0
                          Adapter    "info"         : 2.0.0    , installed 2.0.0
                          Adapter    "iot"          : 1.14.5   , installed 1.14.5
                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                          Controller "js-controller": 5.0.12   , installed 5.0.12
                          Adapter    "material"     : 1.3.1    , installed 1.3.1
                          Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                          Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
                          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                          Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                          Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                          Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                          Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                          Adapter    "tado"         : 0.4.9    , installed 0.4.9
                          Adapter    "web"          : 6.1.2    , installed 6.1.2
                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Adapter    "worx"         : 2.3.2    , installed 2.3.2
                          Adapter    "ws"           : 2.5.5    , installed 2.5.5
                          Objects and States
                          Objects:        15625
                          States:         13724
                          Hit:1 http://phoscon.de/apt/deconz buster InRelease
                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 28
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15056      361/deCONZ
                          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19740      790/pihole-FTL
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19628      690/sshd
                          tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          18112      721/lighttpd
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13478912   5544/io.sonoff.0
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15065      361/deCONZ
                          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        18245      790/pihole-FTL
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13475861   4358/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13472588   4358/iobroker.js-co
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13478112   4883/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13482716   6118/io.web.0
                          tcp6       0      0 :::53                   :::*                    LISTEN      999        19742      790/pihole-FTL
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          19630      690/sshd
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13482392   5908/io.simple-api.
                          tcp6       0      0 :::8090                 :::*                    LISTEN      0          18113      721/lighttpd
                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       13484398   6813/io.harmony.0
                          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18246      790/pihole-FTL
                          udp        0      0 0.0.0.0:41887           0.0.0.0:*                           108        16332      356/avahi-daemon: r
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13484399   6813/io.harmony.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13479340   5366/io.shelly.0
                          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19739      790/pihole-FTL
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17526      653/dhcpcd
                          udp        0      0 0.0.0.0:48757           0.0.0.0:*                           1001       13862241   5366/io.shelly.0
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       13479330   5609/io.mihome-vacu
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16330      356/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13482735   6216/io.deconz.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       18461      361/deCONZ
                          udp6       0      0 :::46030                :::*                                108        16333      356/avahi-daemon: r
                          udp6       0      0 :::53                   :::*                                999        19741      790/pihole-FTL
                          udp6       0      0 :::5353                 :::*                                108        16331      356/avahi-daemon: r
                          udp6       0      0 :::1900                 :::*                                1001       13482737   6216/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       13482736   6216/io.deconz.0
                          2023-10-09 16:19:50.668  - info: javascript.0 (5021) script.js.Fernseher.PS4: PS4 an
                          2023-10-09 16:19:51.670  - info: javascript.0 (5021) script.js.Fernseher.PS4: Sony an
                          2023-10-09 16:19:51.671  - info: javascript.0 (5021) script.js.Fernseher.PS4: Eingangsquelle Tv
                          2023-10-09 16:19:51.680  - info: hyperion_ng.0 (6257) set component V4L of instance 0 to false
                          2023-10-09 16:19:51.684  - info: harmony.0 (6813) hub busy, stateChange delayed: harmony.0.Harmony_Hub.Denon_AV-Empfänger.InputGame = 1
                          2023-10-09 16:19:51.712  - info: hyperion_ng.0 (6257) socket is connected
                          2023-10-09 16:19:52.048  - info: hyperion_ng.0 (6257) read out components finished
                          2023-10-09 16:19:52.049  - info: hyperion_ng.0 (6257) component is set
                          2023-10-09 16:19:54.680  - info: hyperion_ng.0 (6257) set component LEDDEVICE of instance 0 to false
                          2023-10-09 16:19:55.059  - info: hyperion_ng.0 (6257) read out components finished
                          2023-10-09 16:19:55.060  - info: hyperion_ng.0 (6257) component is set
                          2023-10-09 16:20:54.966  - info: hyperion_ng.0 (6257) socket timeout
                          2023-10-09 16:20:54.986  - info: hyperion_ng.0 (6257) Connection closed
                          2023-10-09 16:29:10.952  - info: mihome-vacuum.0 (5609) trigger cleaning segment 22
                          2023-10-09 16:30:00.069  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                          2023-10-09 16:31:31.277  - info: admin.0 (4883) failed connection to socket.io from ::ffff:192.168.178.60: Passport was not initialized
                          2023-10-09 16:31:43.629  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                          2023-10-09 16:37:33.190  - warn: javascript.0 (5021) script.js.Roborock.Wartungszustand: pushover: Rocki muss gewartet werden.
                          2023-10-09 16:43:55.977  - info: admin.0 (4883) ==> Connected system.user.admin from ::ffff:192.168.178.60
                          2023-10-09 16:43:56.960  - info: admin.0 (4883) <== Disconnect system.user.admin from ::ffff:192.168.178.60 admin
                          2023-10-09 16:45:00.061  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                          2023-10-09 17:00:00.097  - info: javascript.0 (5021) script.js.Rolladensteuerung.Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 25
                          2023-10-09 17:04:26.119  - info: worx.0 (6764) Refresh token for MQTT-Connection
                          2023-10-09 17:04:26.122  - info: worx.0 (6764) Disconnected
                          2023-10-09 17:04:26.554  - info: worx.0 (6764) MQTT connected to: iot.eu-west-1.worxlandroid.com
                          Dazu noch der Screendshot aus dem Admin
                          @johnnybahama sagte in admin adapter restart loop:
                          (buster)
                          Kernel : armv7l
                          Userland : armhf
                          nodejs:
                          Pending Updates: 28
                          Alles veraltet. Ich würde das neu! auf ein 64bit-RaspberryOS 'Bullseye' aufsetzen. Das Dateisystem auf der SD-Karte scheint mir auch einen Schuß zu haben.
                          • GlasfaserG Glasfaser
                            Dein Dateisystem hat ein Schuss weg .
                            JohnnyBahama
                            @glasfaser
                            total 65M
                            drwxrwxrwx+  2 iobroker iobroker 4.0K Feb  4  2023 backitup
                            drwxrwxrwx+  2 iobroker iobroker  12K Oct  9 17:08 backup-objects
                            drwxrwxrwx+ 54 iobroker iobroker 4.0K Oct  7 15:34 files
                            drwxrwxrwx+  2 iobroker iobroker 4.0K Jul  4  2021 history
                            -rwxrwxrwx+  1 iobroker iobroker 4.7K Feb  4  2023 iobroker.json
                            -rwxrwxrwx+  1 iobroker iobroker  111 Sep 16 13:35 notifications.json
                            -rwxrwxrwx+  1 iobroker iobroker  11M May  1  2022 objects.json.bak.migrated
                            -rwxrwxrwx+  1 iobroker iobroker    0 Apr 26  2022 objects.json.broken
                            -rw-rw-r--+  1 iobroker iobroker  18M Oct  9 17:21 objects.jsonl
                            drwxrwxr-x+  2 iobroker iobroker 4.0K Oct  9 17:22 objects.jsonl.lock
                            -rwxrwxrwx+  1 iobroker iobroker  11M May  1  2022 objects.json.migrated
                            -rwxrwxrwx+  1 iobroker iobroker  12K Jul  4  2021 objects.json.old
                            -rwxrwxrwx+  1 iobroker iobroker 2.3M May  1  2022 states.json.bak.migrated
                            -rwxrwxrwx+  1 iobroker iobroker    0 Apr 26  2022 states.json.broken
                            -rw-rw-r--+  1 iobroker iobroker  21M Oct  9 17:21 states.jsonl
                            drwxrwxr-x+  2 iobroker iobroker 4.0K Oct  9 17:22 states.jsonl.lock
                            -rwxrwxrwx+  1 iobroker iobroker 2.3M May  1  2022 states.json.migrated
                            -rwxrwxrwx+  1 iobroker iobroker 778K Jul  4  2021 states.json.old
                            drwxrwxrwx+  2 iobroker iobroker 4.0K May 22  2022 zigbee_0
                            • J JohnnyBahama
                              @glasfaser
                              total 65M
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Uhii .... was da drin !? oder nicht drin
                              ls -lh /opt/iobroker/iobroker-data/backitup
                                (buster)
                                Kernel : armv7l
                                Userland : armhf
                                nodejs:
                                Pending Updates: 28
                                JohnnyBahama
                                Na toll und das wegen dem update. Muss ich mich wohl hinsetzen.
                                Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                  JohnnyBahama
                                  @glasfaser
                                  -rwxrwxr--+ 1 iobroker iobroker 288 Oct  9 15:10 external.sh
                                  -rwxrwxr--+ 1 iobroker iobroker 512 Oct  9 15:10 startIOB.sh
                                  -rwxrwxr--+ 1 iobroker iobroker 113 Oct  9 15:10 stopIOB.sh
                                  • J JohnnyBahama
                                    Nö, das Update zerballert dir nicht das Dateisystem. Und das installiert da auch kein altes OS.
                                    • J JohnnyBahama
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @johnnybahama
                                      Wo sind deine Backups , hast du Sie ausgelagert !?
                                      Thomas BraunT J 2 Antworten Letzte Antwort
                                        @johnnybahama
                                        @glasfaser @JohnnyBahama
                                        ls -lAh /opt/iobroker/backups
                                          @johnnybahama
                                          JohnnyBahama
                                          schrieb am zuletzt editiert von JohnnyBahama
                                          @glasfaser
                                          Ja die gehen auf die Google Drive, weil ich mir mal die Karte vollgeschrieben habe und den IoBroker nicht mehr erreichen konnte.
