  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    @great-sun
    Klingt verlockend aber momentan nicht. Bin zu arm :(
    Great SUNG Offline
    Great SUNG Offline
    Great SUN
    #147
    @krisiun Kostet bei Amazon gerade 89 EUR
    KrisiunK 1 Antwort Letzte Antwort
      @krisiun
      Dann jetzt nodejs installieren.
      sudo apt install nodejs
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #148
      krisiun@Marek2:~$ sudo apt install nodejs
      Reading package lists... Done
      The following package was automatically installed and is no longer required:
        libc-ares2
      Use 'sudo apt autoremove' to remove it.
      The following NEW packages will be installed:
        nodejs
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/29.5 MB of archives.
      After this operation, 189 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database ... 47253 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) ...
      Setting up nodejs (18.18.0-1nodesource1) ...
      Processing triggers for man-db (2.10.2-1) ...
      Scanning processes...
      Scanning candidates...
      Scanning processor microcode...
      Scanning linux images...
      Failed to retrieve available kernel versions.
      Failed to check for processor microcode upgrades.
      No services need to be restarted.
      No containers need to be restarted.
      User sessions running outdated binaries:
       krisiun @ /dev/tty1: bash[5843]
       root @ /dev/pts/0: apt[7531,7603], sh[7608]
       root @ /dev/tty1: bash[5801], init[5800], su[5842]
      No VM guests are running outdated hypervisor (qemu) binaries on this host.
      • Great SUNG Great SUN
        @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W ;-)
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #149
        @great-sun sagte in iobroker zeschossen:
        Ich kann auch noch einen HP Mini-PC empfehlen........usw
        Ist das jetzt die ungewollte Werbepause in diesem amüsantem Popcornbeitrag ?
        Lehrling seit 1975 !!!
        Great SUNG 1 Antwort Letzte Antwort
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #150
          @Krisiun
          @Thomas-Braun
          Danke für euren regen Austausch hier.
          Hat mir Spaß gemacht.
          Und wieder einmal von @Thomas-Braun viel gelernt.
          Ich geh jetzt ins Bett.
          Danke.
          • DJMarc75D DJMarc75
            Great SUNG Offline
            Great SUNG Offline
            Great SUN
            #151
            @djmarc75 Ja, ich wollt auch mal was (sinnvolles) beitragen :D
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #152
              @great-sun
              für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
              • bahnuhrB bahnuhr
                @Krisiun
                @Thomas-Braun
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #153
                @bahnuhr sagte in iobroker zeschossen:
                @Krisiun
                @Thomas-Braun
                Gute Nacht
                • KrisiunK Krisiun
                  @great-sun
                  Great SUNG Offline
                  Great SUNG Offline
                  Great SUN
                  #154
                  @krisiun sagte in iobroker zeschossen:
                  @great-sun
                  Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
                  • KrisiunK Krisiun
                      libc-ares2
                      nodejs
                    #155
                    sudo apt autoremove
                    Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
                    sudo reboot
                    vielleicht?
                    Great SUNG KrisiunK 2 Antworten Letzte Antwort
                      sudo apt autoremove
                      sudo reboot
                      vielleicht?
                      Great SUNG Offline
                      Great SUNG Offline
                      Great SUN
                      #156
                      @thomas-braun sagte in iobroker zeschossen:
                      sudo apt autoremove
                      sudo reboot
                      vielleicht?
                      Windoze hat das als Windows-Service laufen. Kannste nicht direkt neu starten... Am Besten WinDoze neu starten:
                      https://www.wikihow.com/Shut-Down-Your-PC-with-a-Shortcut-Key
                        sudo apt autoremove
                        sudo reboot
                        vielleicht?
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #157
                          libc-ares2
                          nodejs
                        (Reading database ... 52877 files and directories currently installed.)st.
                        Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
                        Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                        krisiun@Marek2:~$ sudo reboot
                        System has not been booted with systemd as init system (PID 1). Can't operate.
                        Failed to connect to bus: Host is down
                        Failed to talk to init daemon.
                        krisiun@Marek2:~$ yytree... Done
                        The following packages will be REMOVED:
                          libc-ares2
                        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                        After this operation, 115 kB disk space will be freed.
                        Do you want to continue? [Y/n] y
                          @great-sun
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #158
                          @great-sun
                          Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
                          • KrisiunK Krisiun
                            @great-sun
                            Great SUNG Offline
                            Great SUNG Offline
                            Great SUN
                            #159
                            @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch ;-)
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #160
                              @great-sun
                              Ist OK. Danke
                              • KrisiunK Krisiun
                                @great-sun
                                Ist OK. Danke
                                #161
                                @krisiun
                                System neugestartet?
                                  @krisiun
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #162
                                  krisiun@Marek2:/root$ reboot
                                  • KrisiunK Krisiun
                                    Great SUNG Offline
                                    Great SUNG Offline
                                    Great SUN
                                    #163
                                    Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                                    KrisiunK Thomas BraunT 2 Antworten Letzte Antwort
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #164
                                      @great-sun
                                      OK dann bin ich kurz weg
                                        #165
                                        @great-sun
                                        https://www.how2shout.com/how-to/how-to-reboot-wsl-windows-subsystem-linux-in-windows-10.html
                                        • KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #166
                                          Ihr seid einfach die BESTEN !!!
                                          Danke vielmals. Danke Thomas du bist ein echte Profi aber das weißt Du ja selbst.
                                          Es geht wieder.
                                          Nur beim konsolen start bin ich immer als root. Muss dann su krisiun immer eingeben. Ist das so normal?
