  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • bahnuhrB bahnuhr
    @krisiun sagte in iobroker zeschossen:
    @bahnuhr
    Ja das passt schon. Danke
    Und wat für einen ?
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #138
    @bahnuhr sagte in iobroker zeschossen:
    @bahnuhr
    Und wat für einen ?
    Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
      @krisiun
      sudo apt remove nodejs libnode72
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #139
      krisiun@Marek2:~$ apt policy nodejs
      nodejs:
        Installed: 12.22.9~dfsg-1ubuntu3
        Candidate: 18.18.0-1nodesource1
        Version table:
           18.18.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
       *** 12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      (Reading database ... 47321 files and directories currently installed.)
      Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
      Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
      Processing triggers for man-db (2.10.2-1) ...
      Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
      Scanning processes...
      Scanning candidates...
      Scanning processor microcode...
      Scanning linux images...
      Failed to retrieve available kernel versions.
      The following package was automatically installed and is no longer required:
      Failed to check for processor microcode upgrades.
      Use 'sudo apt autoremove' to remove it.
      No services need to be restarted.MOVED:
        libnode72 nodejs
      No containers need to be restarted. remove and 0 not upgraded.
      After this operation, 42.1 MB disk space will be freed.
      User sessions running outdated binaries:
       krisiun @ /dev/tty1: bash[5843]
       root @ /dev/pts/0: apt[7094,7146], sh[7151]
       root @ /dev/tty1: bash[5801], init[5800], su[5842]
      No VM guests are running outdated hypervisor (qemu) binaries on this host.
      • KrisiunK Krisiun
        @bahnuhr
        Und wat für einen ?
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #140
        @bahnuhr
        Und wat für einen ?
        Musst es ja nicht verraten.
        War nur neugierig.
        Danke.
        KrisiunK 1 Antwort Letzte Antwort
        • bahnuhrB bahnuhr
          @bahnuhr
          Und wat für einen ?
          War nur neugierig.
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #141
          @bahnuhr
          Und wat für einen ?
          War nur neugierig.
          Nein du hast mich falsch verstanden das ist doch kein Geheimnis aber ich bin jetzt wo anders beschäftigt und die daten habe ich doch nicht im kopf
          • KrisiunK Krisiun
            nodejs:
              Version table:
              libnode72 nodejs
            #142
            @krisiun
            sudo apt update
            sudo apt full-upgrade
              @krisiun
              sudo apt update
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #143
              krisiun@Marek2:~$ sudo apt update
              Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
              Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
              Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
              Get:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
              Fetched 338 kB in 3s (98.9 kB/s)
              Reading package lists... Done
              All packages are up to date.
              krisiun@Marek2:~$ sudo apt full-upgrade
              Calculating upgrade... Done
                libc-ares2
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              • OliverIOO OliverIO
                @krisiun
                zum probieren schon,
                aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                daher, kauf dir lieber eine raspi.
                die sind nicht so teuer.
                denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                und kannst dich langsam in das thema linux einlesen.
                ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                da kommen dann eher 100W und höher auf.
                10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                100w
                24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                Fürs Jahr kannst dir das ja selber ausrechnen.
                Great SUNG Offline
                Great SUNG Offline
                Great SUN
                #144
                @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W ;-)
                KrisiunK DJMarc75D 2 Antworten Letzte Antwort
                • KrisiunK Krisiun
                    libc-ares2
                  #145
                  @krisiun
                  Dann jetzt nodejs installieren.
                  sudo apt install nodejs
                  • Great SUNG Great SUN
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #146
                    @great-sun
                    Klingt verlockend aber momentan nicht. Bin zu arm :(
                    Great SUNG 1 Antwort Letzte Antwort
                    • KrisiunK Krisiun
                      @great-sun
                      Great SUNG Offline
                      Great SUNG Offline
                      Great SUN
                      #147
                      @krisiun Kostet bei Amazon gerade 89 EUR
                        @krisiun
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #148
                        krisiun@Marek2:~$ sudo apt install nodejs
                          libc-ares2
                        The following NEW packages will be installed:
                          nodejs
                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 0 B/29.5 MB of archives.
                        After this operation, 189 MB of additional disk space will be used.
                        Selecting previously unselected package nodejs.
                        (Reading database ... 47253 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
                        Unpacking nodejs (18.18.0-1nodesource1) ...
                        Setting up nodejs (18.18.0-1nodesource1) ...
                         root @ /dev/pts/0: apt[7531,7603], sh[7608]
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #149
                          @great-sun sagte in iobroker zeschossen:
                          Ich kann auch noch einen HP Mini-PC empfehlen........usw
                          Ist das jetzt die ungewollte Werbepause in diesem amüsantem Popcornbeitrag ?
                          Lehrling seit 1975 !!!
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #150
                            @Krisiun
                            @Thomas-Braun
                            Danke für euren regen Austausch hier.
                            Hat mir Spaß gemacht.
                            Und wieder einmal von @Thomas-Braun viel gelernt.
                            Ich geh jetzt ins Bett.
                            Danke.
                            • DJMarc75D DJMarc75
                              Great SUNG Offline
                              Great SUNG Offline
                              Great SUN
                              #151
                              @djmarc75 Ja, ich wollt auch mal was (sinnvolles) beitragen :D
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #152
                                @great-sun
                                für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
                                • bahnuhrB bahnuhr
                                  @Krisiun
                                  @Thomas-Braun
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #153
                                  @Krisiun
                                  @Thomas-Braun
                                  Gute Nacht
                                  • KrisiunK Krisiun
                                    @great-sun
                                    Great SUNG Offline
                                    Great SUNG Offline
                                    Great SUN
                                    #154
                                    @great-sun
                                    Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
                                    • KrisiunK Krisiun
                                        libc-ares2
                                        nodejs
                                      #155
                                      sudo apt autoremove
                                      Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
                                      sudo reboot
                                      vielleicht?
                                      Great SUNG KrisiunK 2 Antworten Letzte Antwort
                                        sudo apt autoremove
                                        sudo reboot
                                        vielleicht?
                                        Great SUNG Offline
                                        Great SUNG Offline
                                        Great SUN
                                        #156
                                        @thomas-braun sagte in iobroker zeschossen:
                                        sudo apt autoremove
                                        sudo reboot
                                        vielleicht?
                                        Windoze hat das als Windows-Service laufen. Kannste nicht direkt neu starten... Am Besten WinDoze neu starten:
                                        https://www.wikihow.com/Shut-Down-Your-PC-with-a-Shortcut-Key
                                          sudo apt autoremove
                                          sudo reboot
                                          vielleicht?
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #157
                                            libc-ares2
                                            nodejs
                                          (Reading database ... 52877 files and directories currently installed.)st.
                                          Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
                                          krisiun@Marek2:~$ sudo reboot
                                          System has not been booted with systemd as init system (PID 1). Can't operate.
                                          Failed to connect to bus: Host is down
                                          Failed to talk to init daemon.
                                          krisiun@Marek2:~$ yytree... Done
                                          The following packages will be REMOVED:
                                            libc-ares2
                                          0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                          After this operation, 115 kB disk space will be freed.
                                          Do you want to continue? [Y/n] y
