  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    @great-sun
    für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
    Great SUNG Offline
    Great SUNG Offline
    Great SUN
    #154
    @krisiun sagte in iobroker zeschossen:
    @great-sun
    Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
    KrisiunK 1 Antwort Letzte Antwort
    • KrisiunK Krisiun
      krisiun@Marek2:~$ sudo apt install nodejs
      Reading package lists... Done
      The following package was automatically installed and is no longer required:
        libc-ares2
      Use 'sudo apt autoremove' to remove it.
      The following NEW packages will be installed:
        nodejs
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/29.5 MB of archives.
      After this operation, 189 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database ... 47253 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) ...
      Setting up nodejs (18.18.0-1nodesource1) ...
      Processing triggers for man-db (2.10.2-1) ...
      Scanning processes...
      Scanning candidates...
      Scanning processor microcode...
      Scanning linux images...
      Failed to retrieve available kernel versions.
      Failed to check for processor microcode upgrades.
      No services need to be restarted.
      No containers need to be restarted.
      User sessions running outdated binaries:
       krisiun @ /dev/tty1: bash[5843]
       root @ /dev/pts/0: apt[7531,7603], sh[7608]
       root @ /dev/tty1: bash[5801], init[5800], su[5842]
      No VM guests are running outdated hypervisor (qemu) binaries on this host.
      #155
      sudo apt autoremove
      Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
      sudo reboot
      vielleicht?
      Great SUNG KrisiunK 2 Antworten Letzte Antwort
        sudo apt autoremove
        sudo reboot
        vielleicht?
        Great SUNG Offline
        Great SUNG Offline
        Great SUN
        #156
        @thomas-braun sagte in iobroker zeschossen:
        sudo apt autoremove
        sudo reboot
        vielleicht?
        Windoze hat das als Windows-Service laufen. Kannste nicht direkt neu starten... Am Besten WinDoze neu starten:
        https://www.wikihow.com/Shut-Down-Your-PC-with-a-Shortcut-Key
          sudo apt autoremove
          sudo reboot
          vielleicht?
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #157
            libc-ares2
            nodejs
          (Reading database ... 52877 files and directories currently installed.)st.
          Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
          Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
          krisiun@Marek2:~$ sudo reboot
          System has not been booted with systemd as init system (PID 1). Can't operate.
          Failed to connect to bus: Host is down
          Failed to talk to init daemon.
          krisiun@Marek2:~$ yytree... Done
          The following packages will be REMOVED:
            libc-ares2
          0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
          After this operation, 115 kB disk space will be freed.
          Do you want to continue? [Y/n] y
          • Great SUNG Great SUN
            @great-sun
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #158
            @great-sun sagte in iobroker zeschossen:
            @great-sun
            Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
            Great SUNG 1 Antwort Letzte Antwort
            • KrisiunK Krisiun
              @great-sun
              Great SUNG Offline
              Great SUNG Offline
              Great SUN
              #159
              @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch ;-)
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #160
                @great-sun
                Ist OK. Danke
                • KrisiunK Krisiun
                  @great-sun
                  Ist OK. Danke
                  #161
                  @krisiun
                  System neugestartet?
                    @krisiun
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #162
                    krisiun@Marek2:/root$ reboot
                    • KrisiunK Krisiun
                      Great SUNG Offline
                      Great SUNG Offline
                      Great SUN
                      #163
                      Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                      KrisiunK Thomas BraunT 2 Antworten Letzte Antwort
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #164
                        @great-sun
                        OK dann bin ich kurz weg
                          #165
                          @great-sun
                          https://www.how2shout.com/how-to/how-to-reboot-wsl-windows-subsystem-linux-in-windows-10.html
                          • KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #166
                            Ihr seid einfach die BESTEN !!!
                            Danke vielmals. Danke Thomas du bist ein echte Profi aber das weißt Du ja selbst.
                            Es geht wieder.
                            Nur beim konsolen start bin ich immer als root. Muss dann su krisiun immer eingeben. Ist das so normal?
                            • KrisiunK Krisiun
                              Es geht wieder.
                              #167
                              Ist das so normal?
                              Nein. Auf einem 'richtigen' Linux meldet man sich mit user/passwort an.
                              Bei dem Ersatz-Linux da ist man wohl direkt als root angemeldet. Was natürlich hochgradiger Schwachsinn ist. Ob man das anders einstellen kann?
                              Weiß ich nicht, vermutlich schon. Musste mal irgendwo nachlesen.
                                Ist das so normal?
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #168
                                Ist ok Thomas. Mach Dir jetzt kein Kopf deswegen. Ich bin Dir unendlich dankbar für alles. Und wünsche eine Gute Nacht
                                • KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #169
                                  Hallo nochmal , eine Frage hätte ich noch. Wie soll ich jetzt richtig nadje auf meinem Raspberry updaten damit ich nicht nochmal so ein Horror wie gestern erleben muss?
                                  • KrisiunK Krisiun
                                    #170
                                    @krisiun
                                    Auf dem Raspberry wird das node-fix-Skript aus meiner Signatur funktionieren.
                                      @krisiun
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #171
                                      Danke Thomas werde ich mich wagen 😀
                                      • KrisiunK Krisiun
                                        #172
                                        Moin,
                                        hoffe noch nicht zu spät ;)
                                        An das Backup vorher denken, nicht nur BackitUP, sondern vielleicht auch mal die SD-Karte klonen.
                                        Bernd
                                        HomoranH KrisiunK 2 Antworten Letzte Antwort
                                          Moin,
                                          Bernd
                                          #173
                                          @dp20eic sagte in iobroker zeschossen:
                                          CD-Karte
                                          Kenn ich!
                                          CDs im Visitenkartenformat
