  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
    @krisiun sagte in iobroker zeschossen:
    sudo apt autoremove
    Und dann die Kiste mal neustarten. Wie auch immer das bei dem WSL-Ding geht.
    sudo reboot
    vielleicht?
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #157
    krisiun@Marek2:~$ sudo apt install nodejs
    Reading package lists... Done
    The following package was automatically installed and is no longer required:
      libc-ares2
    Use 'sudo apt autoremove' to remove it.
    The following NEW packages will be installed:
      nodejs
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/29.5 MB of archives.
    After this operation, 189 MB of additional disk space will be used.
    Selecting previously unselected package nodejs.
    (Reading database ... 47253 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.18.0-1nodesource1) ...
    Setting up nodejs (18.18.0-1nodesource1) ...
    Processing triggers for man-db (2.10.2-1) ...
    Scanning processes...
    Scanning candidates...
    Scanning processor microcode...
    Scanning linux images...
    Failed to retrieve available kernel versions.
    Failed to check for processor microcode upgrades.
    No services need to be restarted.
    No containers need to be restarted.
    User sessions running outdated binaries:
     krisiun @ /dev/tty1: bash[5843]
     root @ /dev/pts/0: apt[7531,7603], sh[7608]
     root @ /dev/tty1: bash[5801], init[5800], su[5842]
    (Reading database ... 52877 files and directories currently installed.)st.
    Removing libc-ares2:amd64 (1.18.1-1ubuntu0.22.04.2) ...
    Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
    krisiun@Marek2:~$ sudo reboot
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Failed to talk to init daemon.
    krisiun@Marek2:~$ yytree... Done
    The following packages will be REMOVED:
      libc-ares2
    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
    After this operation, 115 kB disk space will be freed.
    Do you want to continue? [Y/n] y
    • Great SUNG Great SUN
      @great-sun
      für einen sind das nur 89€ für die anderen viel Geld. Nicht böse sein bitte
      Wieso? Ich wollte nur sichergehen, dass Du nicht denkst, das Ding kostet mega viel Kohle.
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #158
      @great-sun sagte in iobroker zeschossen:
      @great-sun
      Danke, sehr nett aber ich habe die preise nicht verglichen weil ich das im moment nicht für relevant halte
      Great SUNG 1 Antwort Letzte Antwort
      • KrisiunK Krisiun
        @great-sun
        Great SUNG Offline
        Great SUNG Offline
        Great SUN
        #159
        @krisiun Verglichen hab ich sie auch nicht. Hab nur gerade selbst so ein Teil gekauft, deswegen wusste ich es noch ;-)
        KrisiunK 1 Antwort Letzte Antwort
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #160
          @great-sun
          Ist OK. Danke
          • KrisiunK Krisiun
            @great-sun
            Ist OK. Danke
            #161
            @krisiun
            System neugestartet?
              @krisiun
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #162
              krisiun@Marek2:/root$ reboot
              • KrisiunK Krisiun
                Great SUNG Offline
                Great SUNG Offline
                Great SUN
                #163
                Wie ich sagte, Du hast WSL, das ist ein Service in Deinem Windows. Damit das sauber neu gestartet ist, Rechner neu starten.
                KrisiunK Thomas BraunT 2 Antworten Letzte Antwort
                  KrisiunK Offline
                  KrisiunK Offline
                  Krisiun
                  #164
                  @great-sun
                  OK dann bin ich kurz weg
                    #165
                    @great-sun
                    https://www.how2shout.com/how-to/how-to-reboot-wsl-windows-subsystem-linux-in-windows-10.html
                    • KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #166
                      Ihr seid einfach die BESTEN !!!
                      Danke vielmals. Danke Thomas du bist ein echte Profi aber das weißt Du ja selbst.
                      Es geht wieder.
                      Nur beim konsolen start bin ich immer als root. Muss dann su krisiun immer eingeben. Ist das so normal?
                      • KrisiunK Krisiun
                        Es geht wieder.
                        #167
                        Ist das so normal?
                        Nein. Auf einem 'richtigen' Linux meldet man sich mit user/passwort an.
                        Bei dem Ersatz-Linux da ist man wohl direkt als root angemeldet. Was natürlich hochgradiger Schwachsinn ist. Ob man das anders einstellen kann?
                        Weiß ich nicht, vermutlich schon. Musste mal irgendwo nachlesen.
                          Ist das so normal?
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #168
                          Ist ok Thomas. Mach Dir jetzt kein Kopf deswegen. Ich bin Dir unendlich dankbar für alles. Und wünsche eine Gute Nacht
                          • KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #169
                            Hallo nochmal , eine Frage hätte ich noch. Wie soll ich jetzt richtig nadje auf meinem Raspberry updaten damit ich nicht nochmal so ein Horror wie gestern erleben muss?
                            • KrisiunK Krisiun
                              #170
                              @krisiun
                              Auf dem Raspberry wird das node-fix-Skript aus meiner Signatur funktionieren.
                                @krisiun
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #171
                                Danke Thomas werde ich mich wagen 😀
                                • KrisiunK Krisiun
                                  #172
                                  Moin,
                                  hoffe noch nicht zu spät ;)
                                  An das Backup vorher denken, nicht nur BackitUP, sondern vielleicht auch mal die SD-Karte klonen.
                                  Bernd
                                  HomoranH KrisiunK 2 Antworten Letzte Antwort
                                    Moin,
                                    Bernd
                                    #173
                                    @dp20eic sagte in iobroker zeschossen:
                                    CD-Karte
                                    Kenn ich!
                                    CDs im Visitenkartenformat
                                      Moin,
                                      Bernd
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #174
                                      @dp20eic
                                      Vielen dank. Es war schon zu spät aber nach der Anleitung von Thomas hat natürlich alles super geklappt.
                                      Da hatte ich niemals zweifeln.
                                      Und Backup war sowieso vorhanden.
                                      Danke nochmal
                                        CD-Karte
                                        Kenn ich!
                                        #175
                                        @homoran sagte in iobroker zeschossen:
                                        Moin,
                                        ja manchmal macht die Autokorrektur schon lustige Sachen :)
                                        Korrigiere ich gleich mal :)
                                        Bernd
