  4. VIS 2 update auf 2.3.0 keine Widgets mehr
27 Beiträge 5 Kommentatoren 1.9k Aufrufe 5 Beobachtet
  • E edi1975
    @feuersturm
    2023-10-04 21:05:48.555  - warn: host.iobroker startInstance cannot find adapter "vis-2@2.2.7". Try to install it... 4 attempt
    2023-10-04 21:05:48.555  - info: host.iobroker iobroker install vis-2@2.2.7 using installedVersion
    2023-10-04 21:05:48.689  - info: zigbee2mqtt.0 (122916) MQTT publish: topic 'zigbee2mqtt/Steckdose Gewekshaus', payload '{"child_lock":"UNLOCK","current":0,"energy":24.48,"indicator_mode":"off/on","last_seen":"2023-10-04T21:05:37+02:00","linkquality":83,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":231}'
    2023-10-04 21:05:48.702  - info: zigbee2mqtt.0 (122916) MQTT publish: topic 'zigbee2mqtt/Steckdose Gewekshaus', payload '{"child_lock":"UNLOCK","current":0,"energy":24.48,"indicator_mode":"off/on","last_seen":"2023-10-04T21:05:37+02:00","linkquality":83,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":231}'
    2023-10-04 21:05:50.188  - info: web.0 (122776) ==> Connected system.user.admin from ::ffff:192.168.178.12
    2023-10-04 21:05:52.132  - error: host.iobroker iobroker npm-install: host.iobroker Unknown packetName vis-2. Please install packages from outside the repository using npm!
    2023-10-04 21:05:53.180  - info: host.iobroker iobroker npm-install: exit 12
    2023-10-04 21:05:53.484  - error: host.iobroker Cannot download and install adapter "vis-2@2.2.7". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    GlasfaserG Offline
    GlasfaserG Offline
    @edi1975 sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
    Falscher Befehl !
    So :
    Wie wird es aktualisiert?
    Wenn es im Rahmen der Tests neue Versionen gibt werden diese ebenfalls manuell installiert. Die Befehle sind dann (hier am Beispiel des Haupt-Paketes - ist dann identisch für die anderen):
    cd /opt/iobroker
    npm i iobroker.vis-2-beta@latest
    iob upload vis-2-beta
    FeuersturmF sigi234S 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      Falscher Befehl !
      So :
      cd /opt/iobroker
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      @glasfaser sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
      Falscher Befehl !
      vis-2-beta wird doch nicht mehr weiter entwickelt. Die Entwicklung findet jetzt über den vis-2 Adapter statt (siehe https://forum.iobroker.net/topic/67676/vis-2-0-neuer-adapter-als-beta)
        Falscher Befehl !
        So :
        cd /opt/iobroker
        sigi234S Online
        sigi234S Online
        Falscher Befehl !
        So :
        Auch Falsch!
        Zitat:
        Damit gesagt ist vis-2 als neuer Adapter seit ein paar Tagen im beta Repository und vis2-beta ist nicht mehr verfügbar und bekommt auch keine Updates mehr.
        • FeuersturmF Feuersturm
          Falscher Befehl !
          GlasfaserG Offline
          GlasfaserG Offline
          @feuersturm
          @sigi234
          OK , habe nur die Fehlermeldung von @edi1975 gesehen mit :
          und da ich noch nicht vis-2 nutze , habe ich noch die Alpha im Kopf gehabt ;)
            @edi1975 Lösch doch einfach mal deinen vis-2 Adapter und installiere ihn so über den Admin (falls du im stable repository unterwegs bist, alternativ bei den Adaptern einfach nach vis-2 suchen)
            Was sagt die Langfassung von iob diag auf der Konsole?
            edi1975
            @feuersturm
            Gelöscht neu installiert und ist alles wider da.
            Warum Backup Wiederherstellung hat nicht das Geschäft?
            Danke für Hilfe.
            • E edi1975
              @feuersturm
              Danke für Hilfe.
              FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              Gute Frage. Hierzu müsste man tiefer abtauchen. Wie hast du dein Backup gemacht, wie hast du es zurück gespielt. War das Backup auf der gleichen Version vom js-controller?
              E 2 Antworten Letzte Antwort
                edi1975
                @feuersturm
                über Backup Adapter
                  edi1975
                  @feuersturm sagte in VIS 2 update auf 2.3.0 keine Widgets mehr:
                  Ja
                  • E edi1975
                    @feuersturm
                    über Backup Adapter
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    @edi1975 Dann solltest du mal deine Backups testen ob sie sich wiederherstellen lassen oder ob du das Problem reproduzieren kannst.
                    E 1 Antwort Letzte Antwort
                      edi1975
                      @feuersturm
                      Was ist mit mein ioBroker los?
                      Backup gemacht und sofort wiederherstellt wenn ist fertig alle Adapter sin rot außer Admin und Backup.
                      In Protokolle kommen Meldungen das Adapter nicht gefunden und wird installiert nach lange zeit alles grün außer in VIS-2 alle Wigets sind noch nicht da. Ich habe kein Lust wider ioBroker von 0 anfangen.
                      host.iobroker 2023-10-05 21:13:33.944	warn	startInstance cannot find adapter "heos@2.1.0". Try to install it... 1 attempt
                      host.iobroker 2023-10-05 21:14:21.651	warn	startInstance cannot find adapter "iot@2.0.11". Try to install it... 1 attempt
                      host.iobroker 2023-10-05 21:13:57.892	warn	startInstance cannot find adapter "info@2.0.0". Try to install it... 1 attempt
                      host.iobroker 2023-10-05 21:18:30.082	warn	startInstance cannot find adapter "vis-2-widgets-energy@0.3.8". Try to install it... 1 attempt
                      host.iobroker 2023-10-05 21:19:33.215	warn	startInstance cannot find adapter "vis-2@2.3.0". Try to install it... 1 attempt
                      host.iobroker 2023-10-05 21:28:41.005	warn	startInstance cannot find adapter "web@6.1.2". Try to install it... 1 attempt
                      FeuersturmF GlasfaserG 2 Antworten Letzte Antwort
                      • E edi1975
                        @feuersturm
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        @edi1975 Was mit deinem ioBroker los ist weiß ich nicht, die 🔮 ist kaputt ;-)
                        Bitte wie oben schon einmal angefordert einmal die Langfassung von iob diag hier in Codetags posten. Dazu auf der SSH Konsole einfach folgendes eingeben:
                        iob diag
                        Eine Wiederherstellung kann lange Zeit >1h in Anspruch nehmen, hier einfach das System in Ruhe lassen und warten bis keine regelmäßigen Updates mehr im Log kommen.
                        Wenn es danach nicht funktioniert, bitte hier mal ein vollständigs Log posten. 4 Zeilen helfen da leider nicht weiter.
                        Ich kann heute Abend parallel mal bei mir testen, ob sich mein System mit vis-2 wieder sauber wiederherstellen lässt.
                        • E edi1975
                          @feuersturm
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Nur eine Empfehlung,
                          man sollte nicht auf einem produktiven ioBroker es gleich damit versuchen ,
                          Vis-2 war Alpha , dann aktuell jetzt in Beta also kann immer noch etwas passieren / nicht richtig laufen .
                          Und wie ich sehe , hast du sonst alles in Stable !
                            iob diag
                            edi1975
                            iob diag
                            OK Repositories ist jetzt auf Beta deswegen Updates zeigt.
                            *** ioBroker Diagnosis ***
                            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                            Just copy and paste the Summary Page, including the ``` characters at start and end.
                            It helps us to help you!
                            Press any key to continue
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer
                                    Machine ID: 14803bb7a50c4def81086c9b741cdd12
                                       Boot ID: bca142a15bfd4377aef46189724c0809
                              Operating System: Debian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            Model		: Raspberry Pi 4 Model B Rev 1.4
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : arm64
                            Systemuptime and Load:
                             20:08:39 up 23:37,  3 users,  load average: 1.04, 0.85, 0.78
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            Other values than 0x0 hint to temperature/voltage problems
                            temp=47.7'C
                            volt=0.9160V
                            *** Time and Time Zones ***
                                           Local time: Fri 2023-10-06 20:08:39 CEST
                                       Universal time: Fri 2023-10-06 18:08:39 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            edi_admin
                            /home/edi_admin
                            edi_admin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            *** X-Server-Setup ***
                            X-Server: 	true
                            Desktop:
                            Terminal: 	tty
                            Boot Target: 	graphical.target
                            *** MEMORY ***
                            Mem:            7.8G        3.4G        325M         51M        4.1G        4.2G
                            Swap:            99M          0B         99M
                            Total:          7.9G        3.4G        425M
                                     7811 M total memory
                                     3422 M used memory
                                     4783 M active memory
                                     2274 M inactive memory
                                      325 M free memory
                                      295 M buffer memory
                                     3767 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            Filesystem                      Type      Size  Used Avail Use% Mounted on
                            /dev/root                       ext4      117G  8.3G  103G   8% /
                            devtmpfs                        devtmpfs  3.6G     0  3.6G   0% /dev
                            tmpfs                           tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs                           tmpfs     1.6G  1.3M  1.6G   1% /run
                            tmpfs                           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                            /dev/sda1                       vfat      251M   31M  220M  13% /boot
                            tmpfs                           tmpfs     782M   24K  782M   1% /run/user/1000
                            //192.168.178.7/Backup-ioBroker cifs      2.7T  1.6T  1.2T  58% /opt/iobroker/backups
                            TARGET                  SOURCE                          FSTYPE OPTIONS
                            /                       /dev/sda2                       ext4   rw,noatime,stripe=8191
                            |-/boot                 /dev/sda1                       vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            `-/opt/iobroker/backups //192.168.178.7/Backup-ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=edi_admin,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.7,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                            /var:
                            1.6G	/var/
                            994M	/var/log
                            969M	/var/log/journal/14803bb7a50c4def81086c9b741cdd12
                            288M	/var/cache
                            Archived and active journals take up 968.0M in the file system.
                            /opt/iobroker/backups:
                            1.1G	/opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            697M	/opt/iobroker/iobroker-data/
                            565M	/opt/iobroker/iobroker-data/files
                            174M	/opt/iobroker/iobroker-data/files/vis-2
                            90M	/opt/iobroker/iobroker-data/files/vis
                            82M	/opt/iobroker/iobroker-data/files/vis/widgets
                            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                            21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
                            18M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs 	v18.17.1
                            /usr/bin/node 		v18.17.1
                            /usr/bin/npm 		9.6.7
                            /usr/bin/npx 		9.6.7
                            nodejs:
                              Installed: 18.17.1-deb-1nodesource1
                              Candidate: 18.17.1-deb-1nodesource1
                              Version table:
                             *** 18.17.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                 12.22.12~dfsg-1~deb11u4 500
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                 12.22.12~dfsg-1~deb11u3 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            No configuration change needed.
                            Multihost discovery server: disabled
                            Discovery authentication:   enabled
                            Persistent activation:      disabled
                            Objects:                    jsonl on 127.0.0.1
                            States:                     jsonl on 127.0.0.1
                            Core adapters versions
                            js-controller: 	5.0.12
                            admin: 		6.10.2
                            javascript: 	7.1.4
                            Adapters from github: 	2
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                            + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                              system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                            + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
                            + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                            + system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
                            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                            + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                            + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
                              system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                            + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                            + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 1080, bind: 0.0.0.0
                            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.26
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.26
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                              system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                              system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                              system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                            + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
                            + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): beta
                            Installed ioBroker-Instances
                            Used repository: beta
                            Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
                            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                            Adapter    "awtrix-light" : 0.9.1    , installed 0.8.0  [Updatable]
                            Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
                            Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
                            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                            Adapter    "denon"        : 1.15.4   , installed 1.15.4
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "discovery"    : 4.1.0    , installed 4.0.0  [Updatable]
                            Adapter    "doorbird"     : 1.3.0    , installed 1.2.4  [Updatable]
                            Adapter    "ems-esp"      : 2.4.1    , installed 2.4.1
                            Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                            Adapter    "fhem"         : 2.0.5    , installed 2.0.5
                            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                            Adapter    "heos"         : 2.1.0    , installed 2.1.0
                            Adapter    "ical"         : 1.13.3   , installed 1.13.3
                            Adapter    "info"         : 2.0.0    , installed 2.0.0
                            Adapter    "iot"          : 2.0.11   , installed 2.0.11
                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                            Controller "js-controller": 5.0.12   , installed 5.0.12
                            Adapter    "lightcontrol" : 0.4.0    , installed 0.4.0
                            Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                            Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.4  [Updatable]
                            Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                            Adapter    "s7"           : 1.3.15   , installed 1.3.15
                            Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                            Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                            Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                            Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
                            Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                            Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
                            Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                            Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                            Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                            Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                            Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
                            Adapter    "wled"         : 0.7.1    , installed 0.7.0  [Updatable]
                            Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
                            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                            Adapter    "zigbee2mqtt"  : 2.13.2   , installed 2.13.1 [Updatable]
                            Objects and States
                            Objects: 	10532
                            States: 	9152
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:5 http://giteduberger.fr rpimonitor/ InRelease
                            Get:6 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                            Update rpimonitor Packages Status
                            Fetched 4586 B in 2s (2356 B/s)
                            Reading package lists...
                            Pending Updates: 25
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14269      621/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          16462      677/perl
                            tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1001       50949      11834/io.sainlogic.
                            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14323      608/vncserver-x11-c
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39707      7652/io.mqtt.0
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38242      7247/node-red
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37337      6556/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35603      6556/iobroker.js-co
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          147718     26659/cupsd
                            tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       899600     127695/sshd: edi_ad
                            tcp        0      0 192.168.178.26:1882     0.0.0.0:*               LISTEN      1001       44141      9171/io.shelly.0
                            tcp        0      0 192.168.178.26:1884     0.0.0.0:*               LISTEN      1001       43482      9234/io.sonoff.0
                            tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       44736      9976/io.doorbird.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14271      621/sshd: /usr/sbin
                            tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       899599     127695/sshd: edi_ad
                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       48183      10269/io.harmony.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          147717     26659/cupsd
                            tcp6       0      0 :::5900                 :::*                    LISTEN      0          14322      608/vncserver-x11-c
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53283      11962/io.simple-api
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52686      12069/io.socketio.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60297      14019/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35664      6581/io.admin.0
                            udp        0      0 0.0.0.0:48671           0.0.0.0:*                           1001       46507      10341/io.heos.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16587      504/dhcpcd
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       48184      10269/io.harmony.0
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          146869     26662/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       60919      14089/io.wled.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12112      442/avahi-daemon: r
                            udp        0      0 0.0.0.0:34211           0.0.0.0:*                           108        12114      442/avahi-daemon: r
                            udp6       0      0 :::33872                :::*                                108        12115      442/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        12113      442/avahi-daemon: r
                            2023-10-06 20:10:05.069  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:05.079  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:06.067  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:06.072  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:06.080  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:07.063  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:07.066  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:07.075  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:07.078  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:07.085  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.064  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.065  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.081  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.085  - info: web.0 (14019) ==> Connected system.user.admin from undefined
                            2023-10-06 20:10:08.089  - info: web.0 (14019) <== Disconnect system.user.admin from undefined
                            2023-10-06 20:10:08.186  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.188  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.190  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.192  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.193  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.195  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.196  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.197  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:08.200  - info: web.0 (14019) <== Disconnect system.user.admin from ::ffff:192.168.178.12
                            2023-10-06 20:10:10.107  - info: web.0 (14019) ==> Connected system.user.admin from ::ffff:192.168.178.12
                            iob diag has finished.
                            Press any key for a summary
                            Copy text starting here:
                            		     v.2023-06-20
                                     Icon name: computer
                                  Architecture: arm64
                            Installation: 		native
                            Kernel: 		aarch64
                            Userland: 		arm64
                            Timezone: 		Europe/Berlin (CEST, +0200)
                            User-ID: 		1000
                            X-Server: 		true
                            Pending OS-Updates: 	25
                            Pending iob updates: 	13
                            Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
                            			/usr/bin/npm 		9.6.7
                            			/usr/bin/npx 		9.6.7
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            MEMORY:
                            Mem:            7.8G        3.6G        847M         51M        3.3G        4.0G
                            Swap:            99M          0B         99M
                            Total:          7.9G        3.6G        947M
                            Active iob-Instances: 	41
                            ioBroker Core: 		js-controller 		5.0.12
                            			admin 			6.10.2
                            ioBroker Status: 	iobroker is running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		10532
                            States: 		9152
                            Size of iob-Database:
                            25M	/opt/iobroker/iobroker-data/objects.jsonl
                            2.2M	/opt/iobroker/iobroker-data/states.jsonl
                            === Mark text until here for copying ===
                            • E edi1975
                              iob diag
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=47.7'C
                              volt=0.9160V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              edi_admin
                              /home/edi_admin
                              X-Server: 	true
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7811 M total memory
                                       3422 M used memory
                                        325 M free memory
                                        295 M buffer memory
                                       3767 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.6G	/var/
                              994M	/var/log
                              288M	/var/cache
                              /usr/bin/npm 		9.6.7
                              /usr/bin/npx 		9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin: 		6.10.2
                              javascript: 	7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	10532
                              States: 	9152
                              Pending Updates: 25
                              		     v.2023-06-20
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		arm64
                              User-ID: 		1000
                              X-Server: 		true
                              			/usr/bin/npm 		9.6.7
                              			/usr/bin/npx 		9.6.7
                              MEMORY:
                              Swap:            99M          0B         99M
                              			admin 			6.10.2
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		10532
                              States: 		9152
                              Thomas BraunT Offline
                              X-Server: true
                              Ausschalten.
                              Pending Updates: 25
                              Updaten
                              • GlasfaserG Offline
                                GlasfaserG Offline
                                X-Server: true
                                vncserver-x11-c
                                cups-browsed
                                wofür !?
                                  X-Server: true
                                  vncserver-x11-c
                                  cups-browsed
                                  wofür !?
                                  edi1975
                                  vncserver-x11-c
                                  also angeschlossen ist noch monitor deswegen Desktop, und vnc für zugriff wen monitor ist aus. Updates weil jetzt ist auf Beta umgeschaltet, aber das hat nichts zu tun mit meinem Problem meine ich so.
                                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                  • E edi1975
                                    vncserver-x11-c
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @edi1975
                                    iob upload all
                                    einmal durchlaufen lassen ,
                                    dann
                                    sudo reboot
                                    was ist dann !?
                                    • E edi1975
                                      vncserver-x11-c
                                      Auf einem Server wird beides nicht benötigt. VNC schon gerade gar nicht.
                                        @edi1975
                                        iob upload all
                                        dann
                                        sudo reboot
                                        was ist dann !?
                                        edi1975
                                        @glasfaser
                                        durchgeführt aber ioBroker funktioniert jetzt, mein plan ist Proxmox VM alles neu Installieren und immer snapshot machen und Backup dort wird alles klappen, Backup von ioBroker hat mich schon mehr Mals enttäuscht.
                                        GlasfaserG Thomas BraunT FeuersturmF 3 Antworten Letzte Antwort
                                        • E edi1975
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          ist deine Entscheidung ... aber falsch ...
                                          So schleppst du immer Fehler mit
                                          nutze BackitUp
